@c19342a7
06/05/14 14:19:21 |
Sebastian Huber |
bsps/arm: Fix Cortex-A9 MPCore clock driver
The nanoseconds extension …
4.115
@1468d70
06/05/14 08:03:55 |
Sebastian Huber |
bsp/altera-cyclone-v: Enable unified L2 cache
4.115
@2a1d86c
06/05/14 08:03:06 |
Sebastian Huber |
bsp/altera-cyclone-v: Move SMP support
4.115
@40599e7e
06/05/14 08:01:42 |
Sebastian Huber |
bsps/arm: Change L2 cache initialization
Do not touch the L1 caches …
4.115
@8fb685b
06/05/14 06:41:56 |
Sebastian Huber |
bsp/altera-cyclone-v: Simplify start hooks
Use …
4.115
@330ccc5
06/04/14 13:34:10 |
Sebastian Huber |
bsp/altera-cyclone-v: Change default baud
Use value for standard U-Boot.
4.115
@82054c80
06/04/14 13:33:42 |
Sebastian Huber |
bsp/altera-cyclone-v: Use NOLOAD for nocache sec
4.115
@9fa88124
06/04/14 09:12:01 |
Sebastian Huber |
bsp/altera-cyclone-v: Simplify MMU config table
4.115
@2d3caccf
06/05/14 11:22:08 |
Sebastian Huber |
bsps/arm: Define ARM_CP15_TEXT_SECTION
Define ARM_CP15_TEXT_SECTION …
4.115
@66a2409d
06/05/14 09:40:48 |
Sebastian Huber |
bsps/arm: Add ARM_CP15_TEXT_SECTION
Allow users of this header file …
4.115
@44fbca3
06/04/14 09:21:43 |
Sebastian Huber |
bsps/arm: Simplify L1 caches support
Delete superfluous/incorrect …
4.115
@d0a8f513
06/05/14 06:32:15 |
Sebastian Huber |
bsps/arm: Add all level data cache invalidation
4.115
@def03ae
06/05/14 06:31:45 |
Sebastian Huber |
bsps/arm: Typo
4.115
@82850b8
06/04/14 09:07:11 |
Sebastian Huber |
bsps/arm: Cortex-A9 MPCore start
Invalidate entire branch predictor array.
4.115
@e87ccf5
06/04/14 08:05:14 |
Sebastian Huber |
Enable SCU only on the boot processor.
4.115
@b938108b
06/04/14 08:03:40 |
Sebastian Huber |
Add …
4.115
@041bf16
06/04/14 07:56:49 |
Sebastian Huber |
bsps/arm: Simplify Cortex-A9 MPCore start
Add …
4.115
@537f7271
05/27/14 14:02:22 |
Daniel Hellstrom |
LEON2: enable exception prinout by default
4.115
@8343aa41
05/27/14 07:15:42 |
Daniel Hellstrom |
LEON3: enable exception prinout by default
4.115
@a20c114
05/27/14 09:42:44 |
Daniel Hellstrom |
GRETH: remove TCP/UDP HW checksum generation
The GRETH doesn't …
4.115
@8df1f408
06/02/14 14:31:51 |
Christian.Mauderer |
score/sparc: Add support for paravirtualization
Guest systems in …
4.115
@3660154
06/01/14 23:18:28 |
Joel Sherrill |
mrm332: Tests now build and fewer warnings
4.115
@6ddc4da
06/01/14 23:18:00 |
Joel Sherrill |
m68k/shared/misc/memProbe.c: Add prototype to eliminate warning
4.115
@4d58458
05/29/14 23:11:30 |
Chris Johns |
bsps/gdbarmsim: Add the missing bspstarthooks.c.
4.115
@d6f1ec91
05/26/14 13:22:12 |
Daniel Hellstrom |
SPARC: syscall optimizations and PSR-write fix
The last optimization …
4.115
@70eff78
05/26/14 15:08:34 |
Daniel Hellstrom |
LEON3: coding style clean bsp_irq_fixup()
4.115
@3a76d830
05/19/14 20:52:18 |
Daniel Hellstrom |
LEON3: add support for IRQ16..31 for CPU!=0
4.115
@5b45d51
05/24/14 00:17:11 |
Chris Johns |
bsps: Do not build tests that require a tick interrupt.
The following …
4.115
@7280fe3f
05/28/14 12:47:07 |
ralf.kirchner |
bsp/altera-cyclone-v: Cleanup
4.115
@12a4d085
05/28/14 12:47:06 |
ralf.kirchner |
bsp/altera-cyclone-v: Reduce size of nocache heap
Network mbufs and …
4.115
@bb70bea1
05/28/14 12:47:05 |
ralf.kirchner |
bsp/altera-cyclone-v: Cache mbufs and clusters
4.115
@32c8960
05/28/14 12:47:03 |
ralf.kirchner |
bsp/altera-cyclone-v: Enable L2 cache for network driver
4.115
@dda78f43
05/28/14 12:47:01 |
ralf.kirchner |
bsp/altera-vyclone-v: Broadcast cache maintenances
4.115
@5fd4e35f
05/28/14 12:47:02 |
ralf.kirchner |
bsp/arm: Broadcast cache maintenances
4.115
@9f058fb
05/08/14 15:08:04 |
cederman |
bsps/sparc: Change tabs to spaces.
4.115
@c903fc2
05/08/14 14:33:08 |
cederman |
bsps/sparc: Add copyright and license information
4.115
@363b1f7
05/08/14 13:42:12 |
cederman |
bsps/sparc: Make lines in SPARC BSPs adhere to 80 character limit.
4.115
@97d0b9b
05/26/14 11:48:36 |
Chris Johns |
bsp/gdbarmsim: Switch to the standard arm/shared/startup.
Switch to …
4.115
@b3fb2ff
05/26/14 01:44:48 |
Chris Johns |
bsp/gdbarmsim: Change syscall functions to not clash with RTEMS …
4.115
@6a740c2
05/23/14 13:52:16 |
Daniel Hellstrom |
SPARC: add syscall 1 (exit) function entry point
The exit SPARC …
4.115
@434e7f7
05/23/14 13:52:15 |
Daniel Hellstrom |
SPARC: syscall code clean-up and minor optimizations
4.115
@decff888
05/22/14 23:05:46 |
Joel Sherrill |
c/src/aclocal/check-smp.m4: Use HAS_SMP not HAS_POSIX_API
4.115
@e9d98071
05/22/14 06:21:38 |
Chris Johns |
bsp/zynq: Add BSP_ZYNQ_RAM_LENGTH to allow a user to override the RAM …
4.115
@18bd35bc
05/22/14 06:15:34 |
Chris Johns |
bsps/zynq: Add BSP_ARM_A9MPCORE_UARTCLK to set the UART clock rate.
4.115
@249eaf9
05/14/14 08:28:09 |
Sebastian Huber |
bsps/sparc: Fix BSS initialization
Use bss_start available via %g2 …
4.115
@b2d191e
05/14/14 08:23:18 |
Sebastian Huber |
bsps/sparc: Fix data copy in start procedure
Use the register %g4 for …
4.115
@c8b7b32
05/12/14 13:21:52 |
ralf.kirchner |
bsp/altera-caclone-v: Early printk support
Make sure printk can work …
4.115
@fa0a9a18
05/12/14 07:32:20 |
Sebastian Huber |
bsps: Declare bsp_start_on_secondary_processors()
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@64a04ac
05/12/14 06:53:11 |
Sebastian Huber |
bsps: Use standard file name for BSP support
4.115
@ca2dd1e
05/12/14 06:35:57 |
Sebastian Huber |
bsp/leon3: Delete unused function
4.115
@3a3869c4
05/09/14 12:25:40 |
bsps/sparc: Move flags to grlib header
This enables re-use for other BSPs
4.115
@89f0794
05/08/14 11:00:08 |
Sebastian Huber |
bsp/gen83xx: Disable interrupt nesting for br_uid
This is necessary …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@0034629
05/07/14 07:23:23 |
Sebastian Huber |
bsps/arm: Declare return types
4.115
@43ef7068
05/07/14 07:23:07 |
Sebastian Huber |
bsps: Fix BSP_INITIAL_EXTENSION
4.115
@053abcda
04/23/14 23:38:43 |
Joel Sherrill |
multiple BSPs: Remove BSP_SMALL_MEMORY
4.115
@c2ea0ea
05/06/14 12:44:17 |
Sebastian Huber |
bsp/gen83xx: Add BSP_USB_EHCI_MPC83XX_HAS_ULPI
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@b0e83e12
04/30/14 08:13:07 |
ralf.kirchner |
libchip: Add asserts to dwmac driver
4.115
@64bc102
04/30/14 08:07:20 |
ralf.kirchner |
libchip: Correct netstats message for dwmac driver
4.115
@bc9a71b
04/30/14 08:06:11 |
ralf.kirchner |
bsp/altera-cyclone-v: Move mbufs and network clusters to uncached RAM
4.115
@ff13e0b
04/30/14 08:06:10 |
ralf.kirchner |
bsp/altera-cyclone-v: Increase size of nocache region and nocache heap …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a16af0b3
04/29/14 07:39:08 |
Sebastian Huber |
bsps/mips: Delete unused files
The MIPS port defines …
4.115
@0b344f34
04/29/14 06:53:35 |
Sebastian Huber |
bsps/m32r: Fix bsp_specs
4.115
@ef26454
04/29/14 06:43:04 |
Sebastian Huber |
bsps/bfin: Fix bsp_specs
4.115
@6741427a
04/28/14 14:55:38 |
Sebastian Huber |
bsp/h8sim: Fix linker command file
4.115
@7c0bd74
04/22/14 08:15:39 |
Sebastian Huber |
sparc: Add _CPU_Get_current_per_CPU_control()
Use register g6 for the …
4.115
@b2ec2d15
04/22/14 05:46:56 |
Sebastian Huber |
sparc: Optimize context switch
The registers g2 through g4 are …
4.115
@f412e12
04/24/14 13:21:00 |
Joel Sherrill |
mcf52235/configure.ac: Delete junk line
4.115
@b74c9cf
04/23/14 04:31:55 |
Chris Johns |
bootstrap: Sort the contents of the prinstall.am files.
Sorting …
4.115
@1450de0
04/22/14 18:10:47 |
Joel Sherrill |
shsim: Correct linking for C++
4.115
@25c3208a
04/22/14 18:08:14 |
Joel Sherrill |
gensh4: Correct linking for C++
4.115
@851e643
04/22/14 18:07:56 |
Joel Sherrill |
gensh2: Correct linking for C++
4.115
@3191b42
04/22/14 18:07:44 |
Joel Sherrill |
gensh1: Correct linking for C++
4.115
@b6a2e57b
04/22/14 18:07:01 |
Joel Sherrill |
score603e: Add rtems_crti
4.115
@77737ad
04/22/14 18:06:08 |
Joel Sherrill |
ss555: Add rtems_crti/n
4.115
@812c9d6
04/22/14 15:44:20 |
Joel Sherrill |
sim68000/bsp_specs: Add crtbegin/end, crt[in]
4.115
@2f36f5a5
04/22/14 15:36:44 |
Joel Sherrill |
mpc8260ads: Add rtems_crti/n
4.115
@8c18adde
04/22/14 14:45:55 |
Joel Sherrill |
h8sim/bsp_specs: Add crtbegin/end, crt[in]
4.115
@d47904f
04/21/14 18:08:00 |
Joel Sherrill |
niagara/Makefile.am: Fix rule for start.o
4.115
@90bc4d03
04/21/14 14:07:51 |
Joel Sherrill |
libcpu/sh: Build cache stubs so apps usign cache API link
4.115
@614fefe
04/18/14 16:05:18 |
Joel Sherrill |
dummy_printk_support.c: Comment clean up
4.115
@a531683
04/18/14 15:52:21 |
Joel Sherrill |
shsim: Add printk() support and move all code to console subdirectory
4.115
@d60e760
04/22/14 07:45:39 |
Sebastian Huber |
bsps: Fix TLS support in linker command files
The TLS section symbols …
4.115
@e2782684
04/22/14 07:32:16 |
Sebastian Huber |
bsp/mbx8xx: Fix Makefile.am and bsp_specs
4.115
@e10574a
04/22/14 06:32:27 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
4.115
@d98eea0
04/17/14 09:27:23 |
ralf.kirchner |
bsp/arm: Cleanup L2 cache handling
4.115
@127634c
04/17/14 09:22:53 |
ralf.kirchner |
bsp/arm: Correct L2 cache enable method
4.115
@62fa1ea
04/17/14 09:19:48 |
ralf.kirchner |
bsp/arm: Add cache size methods
Add new methods which deliver the …
4.115
@1c62f74d
04/17/14 09:11:58 |
ralf.kirchner |
bsp/arm: Add L2 cache locking
This level 2 cache is a shared data and …
4.115
@bebcfa57
04/17/14 09:03:50 |
ralf.kirchner |
bsp/arm: Remove unused cache store methods
4.115
@db5a84d
04/17/14 08:59:47 |
ralf.kirchner |
bsp/arm: Correct cache misalignment handling
Correct misalignment …
4.115
@92e2757
04/17/14 08:37:10 |
ralf.kirchner |
bsp/arm: Correct L2 cache flushing
Correct misalignment handling and …
4.115
@cbd9e63
04/17/14 08:30:54 |
ralf.kirchner |
bsp/arm: Remove arm erratum 764369 from L2 cache
Arm erratum 764369 …
4.115
@9ee2ec5
04/17/14 07:43:30 |
ralf.kirchner |
bsp/arm: Consistenly same handling for flushing
It is importeant to …
4.115
@e331e69
04/16/14 14:07:13 |
ralf.kirchner |
bsp/arm: RTEMS_SMP to arm erratum 764369 detection
Move the RTEMS_SMP …
4.115
@707b6172
04/16/14 14:04:56 |
ralf.kirchner |
bsp/arm: Erratum 764369 after enabling SCU
Execute the SCU part of …
4.115
