@b67f5bfb
08/08/96 12:35:20 |
Mark.Johannes |
_MPCI_Register_packet_processor: changed protoype first parameter type …
4.104.114.84.95
@6b722e2
08/08/96 12:32:50 |
Mark.Johannes |
_MPCI_Register_packet_processor: Changed prototype of fist parameter …
4.104.114.84.95
@3fd3da4
08/08/96 12:31:01 |
Mark.Johannes |
_MPCI_Register_packet_processor: changes first parameter type to …
4.104.114.84.95
@2014063
08/07/96 22:06:08 |
Joel Sherrill |
sporadic server debugged and working. This required minor changes in …
4.104.114.84.95
@ecc912f4
08/07/96 22:05:15 |
Joel Sherrill |
added more error cases to complete testing of pthread_equal when …
4.104.114.84.95
@42418a9
08/07/96 22:00:57 |
Joel Sherrill |
added test cases for ESRCH from pthread_join and pthread_detach
4.104.114.84.95
@84b03316
08/07/96 21:38:18 |
Joel Sherrill |
removed if 0 for basic sporadic server case accidentally left in.
4.104.114.84.95
@7e811af1
08/07/96 21:27:25 |
Joel Sherrill |
basic sporadic server test.
sporadic server with priority ceiling …
4.104.114.84.95
@a14684c3
08/07/96 20:58:59 |
Mark.Johannes |
_POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case
4.104.114.84.95
@cc757fe
08/07/96 20:57:28 |
Mark.Johannes |
_CORE_Mutex_seize: added checks for priority ceiling violation, also …
4.104.114.84.95
@c123a084
08/07/96 15:52:30 |
Joel Sherrill |
added complete test cases for pthread_attr_getschedparam, …
4.104.114.84.95
@4bab8e2d
08/06/96 17:45:12 |
Joel Sherrill |
get_errno: no longer needed by gnat runtime
4.104.114.84.95
@0f99198
08/06/96 16:26:11 |
Mark.Johannes |
_CORE_mutex_Seize: added change priority case if the mutex was obtained.
4.104.114.84.95
@a61f1a46
08/06/96 16:24:41 |
Joel Sherrill |
_POSIX_Threads_Delete_extension: reorder to eliminate use of local …
4.104.114.84.95
@06883e13
08/06/96 16:24:06 |
Mark.Johannes |
POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority
4.104.114.84.95
@b521ae2
08/06/96 16:23:09 |
Joel Sherrill |
pthread_getspecific: use local variable so references to tcb are …
4.104.114.84.95
@20de272
08/02/96 18:25:16 |
Joel Sherrill |
join/detach basic tests pass
4.104.114.84.95
@375f37d
08/02/96 16:46:56 |
Joel Sherrill |
removed unused prototypes
4.104.114.84.95
@870f2976
08/01/96 21:02:54 |
Joel Sherrill |
test successfully exercises all of pthread_attr_* set and get routines
4.104.114.84.95
@22b4b2e
08/01/96 19:24:57 |
Joel Sherrill |
added page delimiters for comment blocks
4.104.114.84.95
@16bae52
08/01/96 15:06:00 |
Joel Sherrill |
added 3 nops following write to wim since a restore following it is …
4.104.114.84.95
@c65a0cee
07/31/96 17:17:48 |
Joel Sherrill |
added key test
4.104.114.84.95
@adae080a
07/15/96 14:02:14 |
Mark.Johannes |
Fixed default vectors initialization, sigaction which had a redundant …
4.104.114.84.95
@69c9543
07/04/96 18:09:23 |
Joel Sherrill |
basic test cases passed
4.104.114.84.95
@ce78b894
07/04/96 17:38:55 |
Joel Sherrill |
added test case for timeout using pthread_mutex_timedlock
4.104.114.84.95
@c6d15c2
07/04/96 17:01:48 |
Joel Sherrill |
first test cases for mutex manager pass
4.104.114.84.95
@e21cf313
07/03/96 14:24:07 |
Joel Sherrill |
another attempt at the rtems_posix_api ifdef
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@5fc0dc1
07/03/96 14:19:09 |
Joel Sherrill |
changed version
4.104.114.84.95
@729c8f2e
07/02/96 18:14:52 |
Joel Sherrill |
updated for 3.5.17
4.104.114.84.95
@df8d1440
07/02/96 18:13:59 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@8d7a1d76
06/18/96 19:06:58 |
Joel Sherrill |
minor changes to insure the few posix-ish routines needed in non-posix …
4.104.114.84.95
@c486e917
06/18/96 19:06:19 |
Joel Sherrill |
changed reboot to a macro to avoid the "noreturn returns" warning.
4.104.114.84.95
@7d74395f
06/18/96 16:43:12 |
Joel Sherrill |
corrected typo
4.104.114.84.95
@f88310da
06/15/96 19:56:19 |
Joel Sherrill |
initial modifications to test sigtimedwait.
4.104.114.84.95
@108ef35
06/15/96 19:55:39 |
Joel Sherrill |
initial modifications to support sigtimedwait.
4.104.114.84.95
@7f13a932
06/14/96 15:49:31 |
Joel Sherrill |
fields for init threads stuff said tasks.
4.104.114.84.95
@9e28da4
06/13/96 22:16:47 |
Mark.Johannes |
sigtimedwait passes initial test cases of timeout and simple satisfaction.
4.104.114.84.95
@36197e53
06/13/96 22:16:08 |
Mark.Johannes |
first successful run. Has test cases for a simple sigtimedwait() …
4.104.114.84.95
@4334949
06/13/96 21:01:21 |
Mark.Johannes |
added maximum_queued_signals to _POSIX_Default_configuration
4.104.114.84.95
@eb0551f
06/13/96 20:47:31 |
Joel Sherrill |
added posix configuration parameter maximum_queued_signals.
4.104.114.84.95
@3a075f5
06/13/96 20:46:43 |
Joel Sherrill |
now passing maximum_queued_signals to posix signals manager initialization
4.104.114.84.95
@c53cfd0f
06/13/96 20:46:15 |
Joel Sherrill |
added queued signals and cleaned up setting of process wide signals so …
4.104.114.84.95
@25a882a6
06/13/96 20:45:38 |
Joel Sherrill |
config.h: added maximum_queued_signals.
psignal.h: fixed typo.
4.104.114.84.95
@022923e
06/13/96 16:45:51 |
Joel Sherrill |
Added _Thread_Do_post_task_switch_extension variable.
4.104.114.84.95
@728b5a7
06/13/96 16:45:11 |
Joel Sherrill |
Added a macro for "empty_line" which will go between test cases.
4.104.114.84.95
@ce0f7d95
06/13/96 16:44:46 |
Joel Sherrill |
Added more test cases for kill() and alarm(). kill() now can unblock …
4.104.114.84.95
@1b17790c
06/13/96 16:43:39 |
Joel Sherrill |
Added code so post context switch extensions can be run on every …
4.104.114.84.95
@e89f8cac
06/13/96 16:42:51 |
Joel Sherrill |
Added include so _POSIX_signals_Manager_initialization is prototyped.
4.104.114.84.95
@b85649c4
06/13/96 16:42:21 |
Joel Sherrill |
basic test cases for kill() and alarm().
kill() in particular needs …
4.104.114.84.95
@7fc3029
06/13/96 16:39:28 |
Joel Sherrill |
added prototype for manager initialization routine.
4.104.114.84.95
@1094754f
06/12/96 22:52:13 |
Joel Sherrill |
new files
4.104.114.84.95
@da4b6e8
06/12/96 22:50:03 |
Joel Sherrill |
use exit() from newlib by default.
4.104.114.84.95
@2e0ebd11
06/12/96 22:49:33 |
Joel Sherrill |
added initialization of posix signal manager.
4.104.114.84.95
@281ad52
06/12/96 22:49:14 |
Joel Sherrill |
basic kill() which send a signal to pthread_self() appears to work.
4.104.114.84.95
@4a1bc34b
06/12/96 17:45:34 |
Joel Sherrill |
added waiting for signal state.
4.104.114.84.95
@2291b71
06/12/96 17:45:01 |
Joel Sherrill |
initial implementation of blocking signal routines -- sigwait, …
4.104.114.84.95
@937808f5
06/11/96 22:55:39 |
Joel Sherrill |
added comment to make sure we add unblock of thread
4.104.114.84.95
@ea1a5bef
06/11/96 22:52:42 |
Joel Sherrill |
first attempt at adding algorithm to select the thread which will …
4.104.114.84.95
@20d099e
06/11/96 22:51:59 |
Joel Sherrill |
deleted field for signals_global_pending.
4.104.114.84.95
@699fe08a
06/11/96 20:46:13 |
Joel Sherrill |
Added test case which blocks a signal, sees what signals are pending, …
4.104.114.84.95
@c8f5ab5
06/11/96 20:43:55 |
Joel Sherrill |
tested blocking a signal, sending it to self, then unblocking it.
4.104.114.84.95
@fb39f19
06/11/96 16:04:25 |
Joel Sherrill |
modified to test pthread_kill() to self and pthread_kill() to a …
4.104.114.84.95
@12aeff91
06/11/96 16:03:15 |
Joel Sherrill |
Interruptible by signals state was added to the STATES_BLOCKED set. …
4.104.114.84.95
@98ed15e
06/11/96 16:01:37 |
Joel Sherrill |
Basic signal functionality appears to work. pthread_kill() can …
4.104.114.84.95
@d0baf81
06/11/96 16:00:06 |
Joel Sherrill |
new file.
4.104.114.84.95
@494740c
06/10/96 21:04:14 |
Joel Sherrill |
added psignal.h
4.104.114.84.95
@1ba858d
06/10/96 20:51:31 |
Joel Sherrill |
new files.
This test does a basic checkout of signals with a …
4.104.114.84.95
@1e608b0f
06/10/96 20:49:21 |
Joel Sherrill |
new file
4.104.114.84.95
@893103c
06/10/96 20:49:08 |
Joel Sherrill |
moved the time macros to pmacros.h.
4.104.114.84.95
@0f63c86
06/10/96 20:47:56 |
Joel Sherrill |
added code to _Thread_Clear_state to check if the state was not …
4.104.114.84.95
@fdec30b
06/10/96 20:47:23 |
Joel Sherrill |
first attempt at the routine which vectors signals.
4.104.114.84.95
@d03f192
06/10/96 20:46:36 |
Joel Sherrill |
4.104.114.84.95
@81daab3
06/07/96 15:22:19 |
Joel Sherrill |
added states for "join at exit" and "interruptible by signal"
4.104.114.84.95
@05ce4e09
06/07/96 15:21:27 |
Joel Sherrill |
changed code which set errno and then returned -1 to use the macro …
4.104.114.84.95
@fa03f08
06/07/96 15:20:55 |
Joel Sherrill |
new file
4.104.114.84.95
@895efd9
06/07/96 13:54:23 |
Joel Sherrill |
key destructor is now run at correct point in pthread_exit() sequence …
4.104.114.84.95
@fce2e9d
06/06/96 21:27:33 |
Joel Sherrill |
in newlib now
4.104.114.84.95
@0a359a7
06/06/96 19:16:20 |
Joel Sherrill |
added include of <sched.h> and fixed warnings
4.104.114.84.95
@782bdfd
06/06/96 19:09:27 |
Joel Sherrill |
Removed assert's from routines which return the error ENOSYS.
4.104.114.84.95
@09b1f1a
06/06/96 17:57:39 |
Joel Sherrill |
patch from Tony Bennett on the ifdef for O_NDELAY
4.104.114.84.95
@e754dd1d
06/06/96 17:54:37 |
Joel Sherrill |
process oriented scheduler routines now return ENOSYS
4.104.114.84.95
@5d9cb7e
06/06/96 17:24:44 |
Joel Sherrill |
removed timer_getoverrun() since it was also in ptimer.c
4.104.114.84.95
@0207c55
06/06/96 15:36:18 |
Joel Sherrill |
Made the implementation of pthread_equal conditional on RTEMS_DEBUG. …
4.104.114.84.95
@65a5c1b
06/06/96 15:32:49 |
Joel Sherrill |
completed pthread_setschedparam.
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@2f200c7
06/06/96 14:55:01 |
Joel Sherrill |
4.104.114.84.95
@624133c
06/06/96 14:53:12 |
Joel Sherrill |
added Sporadic Server support
4.104.114.84.95
@ed10d76
06/06/96 14:52:53 |
Joel Sherrill |
added Sporadic_timer field to support sporadic server
4.104.114.84.95
@7aa4671
06/05/96 21:12:06 |
Joel Sherrill |
added cpu_time_budget field to Thread_Control and removed the global …
4.104.114.84.95
@7169852
06/05/96 18:34:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@23305a25
06/05/96 14:46:04 |
Joel Sherrill |
added support for the api providing the thread stack area
4.104.114.84.95
@98162c35
06/05/96 14:45:45 |
Joel Sherrill |
added boolean to indicate whether or not the stack area was provided …
4.104.114.84.95
@9b4e549
06/05/96 14:45:05 |
Joel Sherrill |
renamed Schedule to schedparam in the posix api control information.
4.104.114.84.95
@7189a40
06/05/96 14:44:03 |
Joel Sherrill |
added comments to to document the definition of posix priority
and how …
4.104.114.84.95
@09c1e31d
06/05/96 14:43:52 |
Joel Sherrill |
added comments to priority.h to document the definition of posix …
4.104.114.84.95
@2c207d1f
06/04/96 20:36:37 |
Joel Sherrill |
make PTHREAD_SCOPE_SYSTEM an unsupported value for contentionscope.
4.104.114.84.95
@65911c32
06/04/96 19:50:15 |
Joel Sherrill |
made sure _Thread_Enable_dispatch is not invoked in cases
where …
4.104.114.84.95
@56bd4a36
06/04/96 19:48:08 |
Joel Sherrill |
made sure routines which called _Objects_Get also called …
4.104.114.84.95
@230a0dcb
06/04/96 19:44:16 |
Joel Sherrill |
added some of the required functionality to pthread_setschedparam and …
4.104.114.84.95
