@a36d1b4
04/04/12 17:21:15 |
Jennifer Averett |
Add MIPS/Malta BSP.
4.115
@0c0181d
04/04/12 13:39:46 |
Jennifer Averett |
PR 1993 - Convert MIPS to PIC IRQ model
4.115
@eb6362dc
04/03/12 15:11:10 |
Sebastian Huber |
bsp/mpc55xx: Add and use chip features
Add defines MPC55XX_HAS_SIU …
4.115
@ba56882c
04/02/12 12:07:52 |
Sebastian Huber |
bsp/tqm8xx: Install header file <bsp/irq-info.h>
4.115
@270fa1e
04/02/12 12:07:10 |
Sebastian Huber |
bsp/qemuppc: Install header file <bsp/irq-info.h>
4.115
@b0b32b8
04/02/12 11:37:31 |
Sebastian Huber |
bsps: Fix for clock driver
Do not use the e300 core decrementer …
4.115
@c988f180
04/02/12 09:59:36 |
Sebastian Huber |
bsp/gen83xx: Fix console driver configuration
4.115
@15fde68c
04/02/12 09:59:06 |
Sebastian Huber |
bsp/gen83xx: Removed file
4.115
@06b6a03
04/02/12 09:48:30 |
Sebastian Huber |
bsp/gen83xx: Regenerate
4.115
@8bb00ac
04/02/12 09:32:11 |
Sebastian Huber |
bsps: More accurate PowerPC clock driver
The clock driver used …
4.115
@1bb72a9
04/02/12 09:06:34 |
Sebastian Huber |
bsp/gen83xx: Support cache BSP options
4.115
@a3db5ff4
04/02/12 09:05:29 |
Sebastian Huber |
bsp/gen83xx: Support for MPC830X
4.115
@31ea3109
04/02/12 09:04:44 |
Sebastian Huber |
bsp/gen83xx: Add sections for BSD support
4.115
@73f1b303
04/02/12 08:59:17 |
Sebastian Huber |
bsp/gen83xx: Install new header file
4.115
@69237c16
04/02/12 08:58:50 |
Sebastian Huber |
bsp/virtex5: Regenerate
4.115
@16a8616
03/30/12 15:03:43 |
Ric Claus |
Add Virtex4 and Virtex5 BSPs
This commit covers at least PR2020, …
4.115
@0b095f76
03/30/12 13:41:15 |
Jennifer Averett |
Resolve link problems with psim irq-server
Add IRQ support components …
4.115
@97f82fc
03/30/12 13:38:14 |
Jennifer Averett |
4.115
@8d0913b8
03/29/12 20:53:16 |
Joel Sherrill |
PC386 - Add files missed in previous commit
4.115
@2cc30b0d
03/29/12 20:28:13 |
Joel Sherrill |
PC386 Add RTD316 and Exar 17D15x multi-port serial card support
4.115
@2cee553
03/29/12 11:52:16 |
Daniel Hellstrom |
LEON3: various cleanups in leon.h
Removed old LEON2 definitions never …
4.115
@226771c
03/29/12 11:52:14 |
Daniel Hellstrom |
LEON3: IRQ index mask was bad, but always shifted out anyway
4.115
@4fa6be9
03/29/12 11:52:13 |
Daniel Hellstrom |
LEON3: clock timer indexing should be consequent
Signed-off-by: …
4.115
@752f876e
03/29/12 17:07:30 |
Jennifer Averett |
Address Conflicts:
c/src/lib/libbsp/powerpc/psim/startup/linkcmds
4.115
@0729e2a7
03/28/12 08:49:27 |
Daniel Hellstrom |
SPARC: bsp_early_malloc() routine for startup memory allocation
If …
4.115
@b9d8cd33
03/29/12 11:52:12 |
Daniel Hellstrom |
SMC91111: remove old unused LEON2/LEON3 intialization code
4.115
@d0dbcf8
03/29/12 11:52:11 |
Daniel Hellstrom |
LEON3: fix GRETH interrupt initialization bug
Fixed a bug where the …
4.115
@e6f327c
03/29/12 11:52:10 |
Daniel Hellstrom |
GRETH: removed the use of rtems_set_clock() in auto-nego timeout
4.115
@39671330
12/02/11 09:53:35 |
Daniel Hellstrom |
GRETH: added support for non-snooping GRETH 10/100 systems
When data …
4.115
@a73884e9
03/24/12 21:56:37 |
Sebastian Huber |
bsp/lm3s69xx: Reflect new Qemu patch
4.115
@bd0fb473
03/24/12 21:53:07 |
Sebastian Huber |
bsps: Shared ARMv7-M interrupt support
4.115
@0f31fddc
03/24/12 21:01:08 |
Sebastian Huber |
bsps: Add shared default IRQ handler
4.115
@b2ee4d5f
03/24/12 20:04:40 |
Sebastian Huber |
bsp/lm3s69xx: Format
4.115
@954393ca
03/24/12 19:57:21 |
Sebastian Huber |
bsp/lm3s69xx: Use shared timer stub driver
4.115
@1ed238e
03/24/12 19:55:40 |
Sebastian Huber |
bsp/lm3s69xx: Use shared start.S
4.115
@34c61517
03/24/12 19:14:27 |
Sebastian Huber |
bsps: Shared ARMv7-M clock driver
4.115
@3c0e7f9b
03/24/12 19:06:49 |
Sebastian Huber |
bsp/lm3s69xx: New Qemu patch
4.115
@5cc813f
03/24/12 16:33:22 |
Sebastian Huber |
bsps: Provide optional prototype
4.115
@e8adc8e3
03/24/12 15:59:25 |
Sebastian Huber |
bsp/lpc24xx: Use proper clock value
4.115
@f3cdf279
03/24/12 15:58:31 |
Sebastian Huber |
bsp/lpc24xx: More CAN pin definitions
4.115
@67b1ce4
02/06/12 14:15:49 |
Daniel Hellstrom |
SMC91111: ERC32 was never supported by driver
Moved the intelligence …
4.115
@f636ba64
02/06/12 14:15:48 |
Daniel Hellstrom |
shared-irq: add support for custom BSP vector verification
4.115
@b4dfce9b
02/06/12 14:15:47 |
Daniel Hellstrom |
LEON3: spurious trap handler print out trap in hex instead
4.115
@80d01b3c
02/08/12 14:57:03 |
Daniel Hellstrom |
SPARC: added libcpu lowlevel access and byteorder routines/definitions …
4.115
@7e664023
03/16/12 13:23:43 |
Jennifer Averett |
Added irq server and link commands for new libbsd support.
4.115
@67baf60
03/14/12 17:06:13 |
Gedare Bloom |
PR2041: sparc64: vector number not included in CPU_Interrupt_frame
4.115
@4868c771
03/14/12 15:45:26 |
Sebastian Huber |
bsp/lpc24xx: New BSP variant
4.115
@2563410
03/13/12 08:22:11 |
Sebastian Huber |
Filesystem: Rename defines
o Removed RTEMS_LIBIO_PERMS_SEARCH.
o …
4.115
@4116fce6
02/24/12 16:39:27 |
Sebastian Huber |
Filesystem: New defaults fsync_h and fdatasync_h
New defaults …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@0bda8b4
03/09/12 16:28:39 |
Joel Sherrill |
Add missing BSD sections.
4.115
@c5a6e617
03/09/12 14:47:32 |
Sebastian Huber |
bsp/gen5200: Fix FPU initialization
The change of the MSR[FP] status …
4.115
@3bd4656
03/09/12 14:46:07 |
Sebastian Huber |
bsp/gen5200: Reflect clocks of new BRS5L hardware
4.115
@314d327
03/06/12 14:36:49 |
Joel Sherrill |
Merge branch 'master' of ssh://git.rtems.org/data/git/rtems
4.115
@47a45e5c
03/06/12 14:25:39 |
werner |
Milkymist - Increase SOFTUSB_PMEM_SIZE to 8 KB
We increased PMEM to 8 …
4.115
@dc1a3b9
03/03/12 21:02:33 |
Sebastien Bourdeauducq |
PR 2032: Milkymist USB: Ioctl interface for loading USB firmware
4.115
@f0d2261
03/03/12 20:50:53 |
Xiangfu Liu <xiangfu at sharism dot cc> |
PR2029: Milkymist VGA: adjust video timings
Slightly adjust video …
4.115
@f7bb9f9
02/29/12 16:08:44 |
werner |
PR2028: Milkymist USB: forward MIDI messages.
Forward MIDI messages …
4.115
@19d18f23
02/23/12 18:09:55 |
Joel Sherrill |
Fix typo in comment.
4.115
@8f7f6ca
02/23/12 16:43:58 |
Jennifer Averett |
Merge remote-tracking branch 'upstream/master'
4.115
@4f1173bc
02/23/12 16:40:33 |
Jennifer Averett |
Avoid NULL dereference in printk() before libchip console initialized
4.115
@8d8f363
02/21/12 15:24:37 |
Sebastian Huber |
LPC32XX: Typo
4.115
@39e8aa9
02/17/12 20:28:19 |
Joel Sherrill |
PR 2015 - LEON3: make SHM driver configurable using weak
PR 2015/bsps …
4.115
@e1ebfebf
02/11/12 20:15:06 |
Sebastian Huber |
Patches for Qemu 1.0.50
4.115
@14ee5a1e
02/11/12 20:10:12 |
Sebastian Huber |
Support for NXP LPC1700 family
4.115
@1f8771d2
02/07/12 21:11:50 |
Sebastian Huber |
Use proper ARMv7-M compiler flags.
4.115
@d6f947e
02/07/12 21:09:45 |
Sebastian Huber |
ARMv7-M Systick API change
4.115
@034b041
02/07/12 21:13:04 |
Sebastian Huber |
Fixed bug intoduced due to API changes.
4.115
@3b18c26
02/11/12 19:35:53 |
Wendell P Silva |
PR 2017/bsps - Update due to API changes
4.115
@5d443559
02/02/12 22:57:42 |
Joel Sherrill |
PR 1991/cpukit - attr.c (really mode code) warning rework
This PR was …
4.115
@c75430c
02/02/12 20:08:08 |
Joel Sherrill |
PR 1962/bsps - MVME162 Console Corrections and Improvements
4.115
@ce3caf87
02/02/12 20:07:09 |
Joel Sherrill |
4.115
@0f700ffc
02/02/12 19:06:26 |
Joel Sherrill |
PR 2011/networking - GRETH: performance improvements and one bugfix
4.115
@600bd1bb
02/02/12 19:05:24 |
Joel Sherrill |
PR 2011/networking GRETH: Moved print to remove potential deadlock
4.115
@2b2e409d
02/02/12 14:46:27 |
Daniel Hellstrom |
LEON3: change d-cache snoop detect implementation
PR 2010/bsps
The …
4.115
@735b0ca
02/02/12 17:00:49 |
Joel Sherrill |
White space correction.
4.115
@54a169db
02/02/12 14:46:26 |
Daniel Hellstrom |
LEON3: CPU index intialization moved to bspstart.c
PR 2009/bsps
All …
4.115
@6d79be5
02/02/12 14:46:22 |
Daniel Hellstrom |
LEON3: fix compiler warning in SHM driver
PR 2008/bsps
4.115
@2a68f53
02/02/12 14:46:23 |
Daniel Hellstrom |
LEON3BSP MP: may wake one more CPU than expected
The SHM code always …
4.115
@184a612e
02/02/12 14:17:25 |
Joel Sherrill |
Merge remote branch 'remotes/origin/gitignore'
4.115
@52694844
02/01/12 21:03:18 |
Joel Sherrill |
Improve comments on console select patch.
4.115
@d1887baf
02/01/12 21:02:03 |
Joel Sherrill |
4.115
@441b90e
02/01/12 20:32:28 |
Jennifer.Averett |
Correct run-time selection of console port.
This was broken by …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@34ce24e
02/01/12 16:49:55 |
Joel Sherrill |
Add minimal .gitignore files.
4.115
@41572c4
01/31/12 21:15:20 |
Joel Sherrill |
Fix spelling error and improve comment.
4.115
@77c2178
01/31/12 10:23:26 |
Sebastian Huber |
Fixed race condition during startup.
4.115
@7838411
01/26/12 08:57:57 |
Sebastian Huber |
Revert "Support custom Makefiles."
This reverts commit …
4.115
@f4491f94
01/26/12 08:57:19 |
Sebastian Huber |
Revert "Disable optimization."
4.115
@a762dc2
01/23/12 10:19:22 |
Sebastian Huber |
Support for MPC5643L.
Rework of the start sequence to reduce the …
4.115
@621e1c9b
01/11/12 13:32:49 |
Sebastian Huber |
4.115
@8ae88d7
01/11/12 13:15:52 |
Sebastian Huber |
4.115
@70fff65
12/14/11 19:23:49 |
Joel Sherrill |
2011-12-14 Joel Sherrill <joel.sherrilL@…>
* Makefile.am: …
4.115
@3007610
12/13/11 12:17:54 |
Ralf Corsepius |
2011-12-13 Ralf Corsépius <ralf.corsepius@…>
4.115
@fa011f35
12/13/11 12:00:13 |
Ralf Corsepius |
4.115
@a1a25ae
12/12/11 19:31:48 |
Gedare Bloom |
2011-12-12 Gedare Bloom <gedare@…>
PR bsps/1989
4.115
@8bc6b663
12/12/11 19:00:48 |
Gedare Bloom |
PR bsps/1988
4.115
@e17789bf
12/12/11 18:52:18 |
Gedare Bloom |
PR bsps/1988
4.115
@d71462b
12/10/11 05:53:03 |
Ralf Corsepius |
2011-12-10 Ralf Corsépius <ralf.corsepius@…>
* configure.ac …
4.115
@ac4f31c8
12/10/11 04:07:46 |
Ralf Corsepius |
4.115
