@a20190a4
11/16/99 16:15:05 |
Joel Sherrill |
Added test cases for uname().
4.104.114.84.95
@65a38bc
11/16/99 16:14:37 |
Joel Sherrill |
Web server uses the POSIX API. Therefor, it must be disabled when the …
4.104.114.84.95
@ce18601a
11/16/99 16:13:26 |
Joel Sherrill |
Removed start subdirectory and distributed contents to the appropriate …
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@88cb6b2
11/16/99 16:08:10 |
Joel Sherrill |
Added threadreset.c.
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
@c094542
11/16/99 16:07:17 |
Joel Sherrill |
Only check for System V IPC if multiprocessing is enabled. The unix …
4.104.114.84.95
@f4b76ab5
11/16/99 16:04:51 |
Joel Sherrill |
Fixed so can be included multiple times in the executive source.
4.104.114.84.95
@31473b7
11/16/99 16:03:21 |
Joel Sherrill |
Works now.
Removed times() since the version in the C Library support …
4.104.114.84.95
@165fe39
11/16/99 16:01:54 |
Joel Sherrill |
Return a reasonable error other than ENOSYS.
4.104.114.84.95
@7fec3b7a
11/16/99 16:01:32 |
Joel Sherrill |
Added call to _Watchdog_Remove to remove the sporadic timer. It was …
4.104.114.84.95
@2c0e896e
11/16/99 16:00:11 |
Joel Sherrill |
Moved utsname from "build for now" (unimplemented files) to the main …
4.104.114.84.95
@d280ce18
11/16/99 15:58:21 |
Joel Sherrill |
Comment fixed when adding prototype for …
4.104.114.84.95
@bd462d1
11/16/99 15:52:49 |
Joel Sherrill |
New file.
4.104.114.84.95
@d6c83529
11/16/99 15:48:11 |
Joel Sherrill |
Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius …
4.104.114.84.95
@fa3346f
11/16/99 15:41:58 |
Jennifer.Averett |
Modified file to match seen output.
4.104.114.84.95
@f9879915
11/16/99 15:41:29 |
Jennifer.Averett |
Modified output file to match seen output. Added comment to all ino …
4.104.114.84.95
@e9b00d7
11/16/99 15:40:40 |
Jennifer.Averett |
Removed compiler warning.
4.104.114.84.95
@d37aa444
11/16/99 15:39:08 |
Jennifer.Averett |
Changed asserts to tmmacros.
4.104.114.84.95
@2d82857
11/16/99 15:38:44 |
Jennifer.Averett |
Updated scn file to match new output. Left out unemplemented
parts as …
4.104.114.84.95
@47619951
11/16/99 15:33:10 |
Jennifer.Averett |
+ Changed ID to 1. ( Compilation error introduced by modifications. )
4.104.114.84.95
@1da9f4bd
11/16/99 15:30:04 |
Jennifer.Averett |
Modified scan file to match.
4.104.114.84.95
@817031f
11/16/99 15:28:03 |
Joel Sherrill |
New file.
4.104.114.84.95
@c7016198
11/16/99 15:27:52 |
Joel Sherrill |
Added.
4.104.114.84.95
@b88691c
11/16/99 15:26:29 |
Joel Sherrill |
Source and destination arguments to strncpy were swapped. This …
4.104.114.84.95
@c276c87
11/16/99 15:24:30 |
Joel Sherrill |
Added itron tests.
4.104.114.84.95
@3fb7b70b
11/16/99 14:39:56 |
Jennifer.Averett |
Changed to call tmmacros instead of assert.
4.104.114.84.95
@ac656f2d
11/16/99 14:15:56 |
Joel Sherrill |
Moved start code from lib/start to libbsp.
4.104.114.84.95
@25f705e
11/16/99 13:55:35 |
Joel Sherrill |
4.104.114.84.95
@1d04e16
11/16/99 13:45:51 |
Joel Sherrill |
4.104.114.84.95
@7f93f772
11/16/99 13:37:49 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@a7d988a
11/16/99 13:37:25 |
Joel Sherrill |
Minor changes since new Makefile.
4.104.114.84.95
@14dbf50
11/16/99 13:34:41 |
Joel Sherrill |
Added start subdirectory.
4.104.114.84.95
@1bcdb3f6
11/16/99 13:31:13 |
Joel Sherrill |
4.104.114.84.95
@80fd699
11/15/99 22:19:51 |
Joel Sherrill |
Removed nanosleep() since it is now in its own file.
4.104.114.84.95
@40aac29
11/15/99 21:37:56 |
Jennifer.Averett |
Returned third parameter for a NULL name to the objects open call.
4.104.114.84.95
@25789705
11/15/99 21:35:14 |
Jennifer.Averett |
+ Fixed files to consistantly use a case of the location after calls
4.104.114.84.95
@1ae60eb4
11/15/99 21:31:28 |
Jennifer.Averett |
+ Modified to use new Thread_Reset routine instead of the restart method.
4.104.114.84.95
@e672263
11/15/99 21:28:21 |
Jennifer.Averett |
Fixed verificaiton checks to call correct macro if dispatch is disabled.
4.104.114.84.95
@06380cfe
11/15/99 21:25:53 |
Jennifer.Averett |
+ Added check that a task could be sent to a dormant state
then …
4.104.114.84.95
@0f88857
11/15/99 21:19:58 |
Jennifer.Averett |
+ Changed preempt routine into two dummy tasks one that is in dormant
4.104.114.84.95
@9da0994
11/15/99 17:15:58 |
Joel Sherrill |
Split ITRON Message Buffer Manager into multiple files.
4.104.114.84.95
@fb27af76
11/15/99 16:39:01 |
Joel Sherrill |
Split ITRON semaphore manager into multiple files.
4.104.114.84.95
@afb11f8
11/12/99 22:00:10 |
Joel Sherrill |
+ Modified calls to use TSK_SLF for calls to self.
+ Modified calls to …
4.104.114.84.95
@624d7ca4
11/12/99 21:27:42 |
Joel Sherrill |
+ Added comments on paths tested.
4.104.114.84.95
@e8c902c
11/12/99 21:26:54 |
Joel Sherrill |
+ Added check for priority over 256.
+ Modified output to correctly …
4.104.114.84.95
@8ed3125d
11/12/99 21:24:56 |
Joel Sherrill |
Added comments for path's tested.
4.104.114.84.95
@d8f3f65b
11/12/99 21:23:34 |
Joel Sherrill |
+ Changed validation of the_thread to validation of location.
4.104.114.84.95
@2979c28
11/12/99 21:21:09 |
Joel Sherrill |
4.104.114.84.95
@3971537
11/12/99 21:20:04 |
Joel Sherrill |
4.104.114.84.95
@037a7b1
11/12/99 21:18:36 |
Joel Sherrill |
+ Moved error checks to before the disable dispatch where possible.
4.104.114.84.95
@0c5ab522
11/12/99 21:16:45 |
Joel Sherrill |
Added comment about the E_CTX error condition (Implementation dependent).
4.104.114.84.95
@c257429f
11/12/99 21:15:12 |
Joel Sherrill |
+ Moved error checks to before the dispatch disable where possible.
4.104.114.84.95
@2183b65
11/12/99 21:13:52 |
Joel Sherrill |
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) …
4.104.114.84.95
@ea6bfcb
11/12/99 21:12:27 |
Joel Sherrill |
4.104.114.84.95
@6af81435
11/12/99 15:54:48 |
Joel Sherrill |
Corrected so now actually indexes into the allocation block.
4.104.114.84.95
@1925ec9b
11/12/99 15:54:07 |
Joel Sherrill |
Corrected remaining references to struct rtems_task_variable_t since …
4.104.114.84.95
@a8d72dea
11/12/99 15:53:29 |
Joel Sherrill |
Removed unnecessary 3rd parameter.
4.104.114.84.95
@6bd132e5
11/12/99 15:37:09 |
Joel Sherrill |
New file.
4.104.114.84.95
@95bb279
11/12/99 14:54:13 |
Joel Sherrill |
Used typedef so all "struct rtems_task_variable_t" uses are now
just …
4.104.114.84.95
@884b460
11/12/99 14:52:36 |
Joel Sherrill |
Added per-task variable data stucture (rtems_task_variable_t), …
4.104.114.84.95
@f4771656
11/12/99 14:51:03 |
Joel Sherrill |
Test name changed to reflect placement after merger.
4.104.114.84.95
@ec0b5ce
11/12/99 14:50:42 |
Joel Sherrill |
Changed output …
4.104.114.84.95
@3136f5c9
11/12/99 14:49:47 |
Joel Sherrill |
Increased stack …
4.104.114.84.95
@5aa5560
11/12/99 14:38:19 |
Joel Sherrill |
Added per task variables based on patch from Eric Norum …
4.104.114.84.95
@3c49a508
11/12/99 14:15:50 |
Joel Sherrill |
Cleaned up style.
4.104.114.84.95
@3ad17f5
11/12/99 13:46:04 |
Joel Sherrill |
Removed redundant line.
4.104.114.84.95
@6977b38
11/12/99 13:45:39 |
Joel Sherrill |
Enabled after merging message buffer code.
4.104.114.84.95
@f9078d1
11/12/99 13:22:31 |
Joel Sherrill |
Added comment block and removed include of deleted file.
4.104.114.84.95
@d102810e
11/11/99 02:39:12 |
Joel Sherrill |
Updated.
4.104.114.84.95
@dc83752
11/11/99 02:23:26 |
Joel Sherrill |
Screen updated.
4.104.114.84.95
@458d4e66
11/11/99 02:23:04 |
Joel Sherrill |
Added new test sp28 to test the task variable directives.
4.104.114.84.95
@713b2ea
11/10/99 22:15:42 |
Joel Sherrill |
General cleanup. Test documentation improved. The message buffer …
4.104.114.84.95
@59d1127
11/10/99 22:14:26 |
Joel Sherrill |
Corrected to account for the way memory is divided up in …
4.104.114.84.95
@7d29dc7f
11/10/99 22:13:42 |
Joel Sherrill |
Added line to make sure HAS_ITRON_API is defined in Makefile.
4.104.114.84.95
@72719d2
11/10/99 20:37:01 |
Joel Sherrill |
Added call to _Thread_Enable_dispatch() and did some cleanup.
4.104.114.84.95
@74db82a
11/10/99 20:36:25 |
Joel Sherrill |
rtems_semaphore_flush test from Eric Norum <eric@…>.
4.104.114.84.95
@cbccd37
11/10/99 14:31:11 |
Joel Sherrill |
Patch from Eric Norum <eric@…> which includes:
Patches …
4.104.114.84.95
@442d0478
11/10/99 14:19:55 |
Joel Sherrill |
Combination of committing some new files which had been overlooked
and …
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
4.104.114.84.95
@dcc1f6b6
11/10/99 13:45:54 |
Joel Sherrill |
Added support for ITRON tests.
4.104.114.84.95
@bab5ba44
11/09/99 23:28:04 |
Joel Sherrill |
Added more tasking tests.
4.104.114.84.95
@e099180
11/09/99 23:27:05 |
Joel Sherrill |
Merged tests from Task group.
4.104.114.84.95
@3d67661
11/09/99 23:10:48 |
Joel Sherrill |
Added nesting count for suspend/resume.
4.104.114.84.95
@70e9af9
11/09/99 22:45:35 |
Joel Sherrill |
Changed B, H, and W variables to BVar, HVar, and WVar to avoid …
4.104.114.84.95
@e18ba7f
11/09/99 22:25:55 |
Joel Sherrill |
Commented out single letter type names since they conflict with …
4.104.114.84.95
@c73b8ac2
11/09/99 22:18:43 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@c8cad188
11/09/99 22:16:16 |
Joel Sherrill |
Removed.
4.104.114.84.95
@ad502d18
11/09/99 22:14:21 |
Joel Sherrill |
Renamed classes to avoid single letter class names.
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
4.104.114.84.95
@1007c3c
11/09/99 19:54:40 |
Joel Sherrill |
Fixed warning where initialized default POSIX API structure did
have …
4.104.114.84.95
@bd0b378
11/09/99 19:45:23 |
Joel Sherrill |
Removed unused variable warning.
4.104.114.84.95
@d55af6d
11/09/99 15:38:47 |
Joel Sherrill |
Now using libchip instead of local precursor to libchip. Untested.
4.104.114.84.95
@53b1847
11/09/99 13:40:57 |
Joel Sherrill |
Removed reaching "up and over" to install BSP header files.
4.104.114.84.95
@b440e57b
11/09/99 13:40:30 |
Joel Sherrill |
Added imfs_unixstub.c to satisfy linker problems on UNIX port.
4.104.114.84.95
@3fb8909a
11/09/99 13:39:42 |
Joel Sherrill |
sem_close was accidentally lost in the split.
4.104.114.84.95
@a8df60b
11/09/99 13:38:00 |
Joel Sherrill |
New test for POSIX Message Queues added.
4.104.114.84.95
@27eb3ec
11/09/99 13:36:26 |
Joel Sherrill |
New files.
4.104.114.84.95
@a0af97d
11/09/99 03:43:47 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to add NTP BOOTP support …
4.104.114.84.95
