@9594cdb
05/30/96 20:49:16 |
Joel Sherrill |
added code to test clock and time related functionality.
4.104.114.84.95
@7c55e06
05/30/96 20:48:33 |
Joel Sherrill |
Added nanoseconds constant
4.104.114.84.95
@5600661
05/30/96 20:48:10 |
Joel Sherrill |
First cut at implementing time, clock_gettime, clock_settime, …
4.104.114.84.95
@b169590e
05/30/96 20:34:46 |
Joel Sherrill |
added dummy versions of kill and getpid which assert(0) so that …
4.104.114.84.95
@53fd6e2
05/30/96 19:29:01 |
Joel Sherrill |
Eric Norum sent in new versions of the inline assembly macros which
do …
4.104.114.84.95
@a96a713
05/30/96 14:01:33 |
Joel Sherrill |
tests now specify whether they are using rtems initialization tasks
or …
4.104.114.84.95
@be1c11ed
05/29/96 22:48:26 |
Joel Sherrill |
tests now specify whether using posix initialization threads table
or …
4.104.114.84.95
@dd32d883
05/29/96 22:46:05 |
Joel Sherrill |
posix initialization threads table was misnamed "posix initialization …
4.104.114.84.95
@7f72217e
05/29/96 21:27:26 |
Joel Sherrill |
comment clean up
4.104.114.84.95
@2a98af84
05/29/96 21:02:20 |
Joel Sherrill |
types.c: spacing
psignal.c: kill recognizes SIGABRT and exits to …
4.104.114.84.95
@5240c71c
05/29/96 20:58:45 |
Joel Sherrill |
fixed support for posix initialization threads table
4.104.114.84.95
@2197a2e1
05/29/96 20:56:57 |
Joel Sherrill |
simple version of test which shows pthread_create, pthread_exit, and …
4.104.114.84.95
@cfcfdf0
05/29/96 20:55:05 |
Joel Sherrill |
added pthread_exit
first posix thread ran
4.104.114.84.95
@5e0efa2b
05/29/96 20:50:52 |
Joel Sherrill |
cleaned up spacing and parentheses
4.104.114.84.95
@d835a35
05/29/96 19:28:15 |
Joel Sherrill |
spacing
4.104.114.84.95
@ece8c9a
05/29/96 19:28:01 |
Joel Sherrill |
first cut at pthread_create
4.104.114.84.95
@9c877c0d
05/29/96 18:46:46 |
Joel Sherrill |
addressed minimum stack size attribute.
There is a potential problem …
4.104.114.84.95
@98849f44
05/29/96 16:55:05 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@613cff6
05/29/96 16:54:52 |
Joel Sherrill |
removed all ifdef's on NOT_IMPLEMENTED.
4.104.114.84.95
@e941ea13
05/29/96 16:54:24 |
Joel Sherrill |
added entry point for posix initialization threads to the posix …
4.104.114.84.95
@d9a0689e
05/29/96 16:07:21 |
Joel Sherrill |
Addressed RTEMS API initialization tasks table in a system without …
4.104.114.84.95
@0252200
05/29/96 16:06:47 |
Joel Sherrill |
Gutted test of rtems api calls and added comments to indicate what the …
4.104.114.84.95
@99f9dffa
05/29/96 16:05:28 |
Joel Sherrill |
Added default POSIX API configuration table.
4.104.114.84.95
@019bce7
05/29/96 16:05:06 |
Joel Sherrill |
It is now not an error to have 0 RTEMS initialization tasks since you …
4.104.114.84.95
@974ff40
05/29/96 16:04:31 |
Joel Sherrill |
renamed signal.c to psignal.c to avoid naming problems.
added mp …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@c6fa38c0
05/28/96 19:29:51 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@7640525
05/28/96 19:29:02 |
Joel Sherrill |
added enumerated constant for the POSIX API as an error source
4.104.114.84.95
@5a18e04
05/28/96 19:28:32 |
Joel Sherrill |
added initial set of api extension callouts
4.104.114.84.95
@962c9b65
05/28/96 16:33:11 |
Joel Sherrill |
new file
4.104.114.84.95
@47d6b140
05/28/96 16:32:55 |
Joel Sherrill |
commented out interrupt support
4.104.114.84.95
@da33d26
05/28/96 16:18:34 |
Joel Sherrill |
added ifndef's for the POSIX maximum field in the POSIX api …
4.104.114.84.95
@d4b44877
05/28/96 16:17:01 |
Joel Sherrill |
added posix api initialization call to init.c
deleted a blank line in …
4.104.114.84.95
@8165b48f
05/28/96 16:16:28 |
Joel Sherrill |
comment cleanup
4.104.114.84.95
@52d9e4d1
05/28/96 16:16:11 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@2eba45d
05/28/96 14:16:45 |
Joel Sherrill |
made posix configuration information conditional so configurations …
4.104.114.84.95
@4b06db75
05/28/96 13:25:15 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@cb96372
05/28/96 13:24:58 |
Joel Sherrill |
changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@3320e52
05/24/96 22:58:15 |
Joel Sherrill |
new file
4.104.114.84.95
@87a2a74
05/24/96 22:56:23 |
Joel Sherrill |
changed version to 3.5.17
4.104.114.84.95
@28fa54d9
05/24/96 20:34:49 |
Joel Sherrill |
added Motorola MVME147 BSP submitted by Dominique le Campion …
4.104.114.84.95
@94bac464
05/24/96 19:35:25 |
Joel Sherrill |
new file
4.104.114.84.95
@6d12f59
05/24/96 19:34:05 |
Joel Sherrill |
updates from Tony Bennett to correct calling sequences.
4.104.114.84.95
@86fc81e
05/24/96 19:33:36 |
Joel Sherrill |
new files
4.104.114.84.95
@568ebf3
05/24/96 19:32:37 |
Joel Sherrill |
updates to fix typos
4.104.114.84.95
@abd604a
05/24/96 14:25:49 |
Mark.Johannes |
new file
4.104.114.84.95
@6481405e
05/24/96 14:16:24 |
Joel Sherrill |
added use of sporadic server scheduling parameters
4.104.114.84.95
@8442b4c7
05/24/96 14:05:02 |
Joel Sherrill |
new files
4.104.114.84.95
@13fcfde
05/23/96 22:34:18 |
Joel Sherrill |
clean up on DELAYTIMER_MAX
4.104.114.84.95
@8a318cd
05/23/96 22:23:44 |
Joel Sherrill |
new files
4.104.114.84.95
@3a9fc7d
05/23/96 21:51:54 |
Joel Sherrill |
unused variable
4.104.114.84.95
@73c5da6a
05/23/96 21:51:53 |
Joel Sherrill |
new files
4.104.114.84.95
@7303eea
05/23/96 21:23:12 |
Joel Sherrill |
new files
4.104.114.84.95
@1b297b4a
05/23/96 21:10:12 |
Joel Sherrill |
new files
4.104.114.84.95
@d1d7e807
05/23/96 20:43:04 |
Joel Sherrill |
new files
4.104.114.84.95
@a1c86cbe
05/23/96 20:37:09 |
Joel Sherrill |
new files
4.104.114.84.95
@3d135eea
05/23/96 19:56:49 |
Joel Sherrill |
cleanup
4.104.114.84.95
@d3fed0a3
05/23/96 19:54:08 |
Joel Sherrill |
new files
4.104.114.84.95
@02bfc56
05/23/96 19:31:54 |
Joel Sherrill |
cleanup status vs. result
4.104.114.84.95
@318ac69
05/23/96 19:23:54 |
Joel Sherrill |
new files
4.104.114.84.95
@7af3a828
05/23/96 19:09:21 |
Joel Sherrill |
new files
4.104.114.84.95
@f2cb4ac
05/23/96 19:04:18 |
Joel Sherrill |
new files
4.104.114.84.95
@57fc51c
05/23/96 18:55:32 |
Joel Sherrill |
new files
4.104.114.84.95
@41e7a1d8
05/23/96 18:43:59 |
Joel Sherrill |
new files
4.104.114.84.95
@9854e336
05/23/96 18:08:15 |
Joel Sherrill |
updated to reflect more constants and feature macros
4.104.114.84.95
@8b2ecf85
05/23/96 15:37:38 |
Joel Sherrill |
4.104.114.84.95
@64b976a
05/23/96 15:36:46 |
Joel Sherrill |
added code to insure that delay is always non-zero
4.104.114.84.95
@a6aded4f
05/23/96 15:36:08 |
Joel Sherrill |
updates from tony bennett
4.104.114.84.95
@0553a3a
05/23/96 15:35:56 |
Joel Sherrill |
added as example of how to do a bsp which is not in this tree.
4.104.114.84.95
@a5f56a43
05/23/96 15:35:32 |
Joel Sherrill |
4.104.114.84.95
@859f17ce
05/23/96 15:35:26 |
Joel Sherrill |
invoke thread stack free routine instead of Workspace free.
4.104.114.84.95
@d196e48
05/23/96 15:34:54 |
Joel Sherrill |
updates from Tony Bennett.
Broke the setjmp/longjmp pair in the …
4.104.114.84.95
@2328475
05/22/96 22:39:47 |
Joel Sherrill |
created posix test suite with test of header files
4.104.114.84.95
@ef006c1
05/22/96 22:34:18 |
Joel Sherrill |
Modified to correct variables which defined the range of object …
4.104.114.84.95
@f4719d5a
05/22/96 22:32:39 |
Joel Sherrill |
These files have been modified in the initial pass at getting the …
4.104.114.84.95
@05195890
05/22/96 22:31:51 |
Joel Sherrill |
4.104.114.84.95
@4e684a31
05/10/96 20:24:07 |
Joel Sherrill |
added posix test directory
4.104.114.84.95
@92262ab
05/10/96 20:23:27 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@3e7b167
05/08/96 21:55:41 |
Joel Sherrill |
updated to remove workaround for bug in binutils 2.5.2 ld now that we …
4.104.114.84.95
@1c964ffa
05/08/96 21:53:50 |
Joel Sherrill |
4.104.114.84.95
@bf6661e
05/02/96 14:39:07 |
Joel Sherrill |
Updated version to 3.5.15.
4.104.114.84.95
@996a9cb4
05/01/96 15:25:33 |
Joel Sherrill |
Updates from Eric Norum.
4.104.114.84.95
@dce1c1a1
05/01/96 15:24:37 |
Joel Sherrill |
Updates from Eric Norum to use the mcpu32 flags and fix comments.
4.104.114.84.95
@a412622
04/24/96 21:21:14 |
Joel Sherrill |
changed version number to 3.5.14
4.104.114.84.95
@11532ca
04/24/96 20:05:52 |
Joel Sherrill |
Hacked so gld will accept this so we can purge the aout toolset. This …
4.104.114.84.95
@1543932
04/24/96 17:36:35 |
Joel Sherrill |
added comment regarding stack alignment issues to thread stack …
4.104.114.84.95
@d2d6467
04/22/96 23:58:40 |
Joel Sherrill |
Lowered number of messages created to reduce burden on workspace.
4.104.114.84.95
@8389628
04/22/96 16:53:46 |
Joel Sherrill |
4.104.114.84.95
@5a36154a
04/22/96 16:53:05 |
Joel Sherrill |
addition of optional user provided stack allocator means that we can …
4.104.114.84.95
@1f94ed6b
04/22/96 16:50:17 |
Joel Sherrill |
Updates from Tony Bennett.
4.104.114.84.95
@34f3d17
04/22/96 16:49:53 |
Joel Sherrill |
Updates from Tony Bennett. rtems_environp removed among other minor …
4.104.114.84.95
@f5674938
04/22/96 16:49:25 |
Joel Sherrill |
Fixed so now supports more than 16 nodes. Tested for up to 24 nodes …
4.104.114.84.95
@8faca06
04/22/96 16:46:36 |
Joel Sherrill |
thread.c: added support for optional user provided stack allocator
4.104.114.84.95
@6365f81
04/22/96 16:46:00 |
Joel Sherrill |
made initialization routine a regular subroutine
4.104.114.84.95
@a155b3c
04/22/96 16:45:47 |
Joel Sherrill |
interr.h: added stack allocater error code
wkspace.h: made …
4.104.114.84.95
@cc4c1fe4
04/22/96 16:44:54 |
Joel Sherrill |
added stack allocation fields to the cpu table
updates from Tony …
4.104.114.84.95
@96981e3a
04/22/96 16:44:04 |
Joel Sherrill |
4.104.114.84.95
@9a1ccb3
04/22/96 16:43:44 |
Joel Sherrill |
added CPU_M68K_EXTB_L …
4.104.114.84.95
@f581163a
04/22/96 16:30:30 |
Joel Sherrill |
4.104.114.84.95
