@94a86c40
01/10/00 15:18:20 |
Joel Sherrill |
Per suggestions of Eric Valette <valette@…> and Jay …
4.104.114.84.95
@6e7b6ca
01/10/00 15:03:28 |
Joel Sherrill |
Fixed unterminated comment spotted by eagle eye Ralf Corsepius …
4.104.114.84.95
@bc2f04f
01/10/00 14:50:45 |
Joel Sherrill |
Patch rtems-rc-20000104-13.diff from Ralf Corsepius …
4.104.114.84.95
@5fa14794
01/10/00 14:31:16 |
Joel Sherrill |
Patch rtems-rc-20000104-11.diff from Ralf Corsepius …
4.104.114.84.95
@7068e246
01/10/00 14:29:44 |
Joel Sherrill |
Patch rtems-rc-20000104-10.diff from Ralf Corsepius …
4.104.114.84.95
@53ab4823
01/10/00 14:23:56 |
Joel Sherrill |
Patch rtems-rc-20000104-9.diff from Ralf Corsepius …
4.104.114.84.95
@4200321a
01/10/00 14:17:28 |
Joel Sherrill |
Patch rtems-rc-20000104-7.diff from Ralf Corsepius …
4.104.114.84.95
@1597ab4a
01/10/00 14:17:27 |
Joel Sherrill |
Patch rtems-rc-20000104-8.diff from Ralf Corsepius …
4.104.114.84.95
@59909bf
01/10/00 14:09:12 |
Joel Sherrill |
Patch rtems-rc-20000104-6.diff from Ralf Corsepius …
4.104.114.84.95
@d0a8b4b8
01/10/00 14:07:00 |
Joel Sherrill |
Patch rtems-rc-20000104-4.diff from Ralf Corsepius …
4.104.114.84.95
@82f1f6d
01/10/00 14:06:59 |
Joel Sherrill |
4.104.114.84.95
@0cbfa283
01/10/00 14:04:50 |
Joel Sherrill |
4.104.114.84.95
@1e562da6
01/10/00 14:04:49 |
Joel Sherrill |
Patch rtems-rc-20000104-5.diff from Ralf Corsepius …
4.104.114.84.95
@49e05f41
01/10/00 14:03:32 |
Joel Sherrill |
4.104.114.84.95
@10726095
01/10/00 13:59:35 |
Joel Sherrill |
Patch rtems-rc-20000104-3.diff from Ralf Corsepius …
4.104.114.84.95
@94608578
01/10/00 13:56:35 |
Joel Sherrill |
Patch rtems-rc-20000104-2.diff from Ralf Corsepius …
4.104.114.84.95
@338f1dc
01/10/00 13:26:00 |
Joel Sherrill |
Patch from Eric Valette <valette@…> that makes sure the …
4.104.114.84.95
@1d54d3b
01/07/00 20:39:45 |
Joel Sherrill |
Renaming mcp750 to motorola_shared since that is the basis for both …
4.104.114.84.95
@35d9acb3
01/07/00 18:52:14 |
Joel Sherrill |
Patch from John M. Mills <jmills@…> to correct the baseline …
4.104.114.84.95
@09e0df6
01/07/00 14:54:59 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> that corrects a …
4.104.114.84.95
@c3538f3
01/07/00 14:52:48 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> which corrects the …
4.104.114.84.95
@0ff37e68
01/07/00 14:47:02 |
Joel Sherrill |
Patch rtems-rc-20000104-0.diff from Ralf Corsepius …
4.104.114.84.95
@98c875a1
01/06/00 22:44:27 |
Joel Sherrill |
Initialize the attributes structure. Random data was causing the test …
4.104.114.84.95
@89184f9
01/06/00 15:31:24 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@bd177b7b
01/06/00 15:20:53 |
Joel Sherrill |
Fixed comment.
4.104.114.84.95
@0312d81f
01/05/00 23:01:05 |
Joel Sherrill |
Fixed comment thanks to John M. Mills <jmills@…>.
4.104.114.84.95
@5870ac55
01/05/00 22:19:21 |
Joel Sherrill |
Added support for simple binary semaphores in addition to the high …
4.104.114.84.95
@5283cc82
01/05/00 22:15:47 |
Joel Sherrill |
Updated to reflect a time that had previously been left out due to
an …
4.104.114.84.95
@27f09663
01/05/00 22:15:16 |
Joel Sherrill |
Screen updated since test runs.
4.104.114.84.95
@4bcbf89c
01/05/00 22:14:42 |
Joel Sherrill |
Was not actually installing the test.
4.104.114.84.95
@28adcfd
01/05/00 22:14:09 |
Joel Sherrill |
Added message priority parameter returned by core support routine.
4.104.114.84.95
@c0d405ca
01/05/00 22:13:15 |
Joel Sherrill |
Added new message priority parameter as returned by core support routine.
4.104.114.84.95
@fc20c53
01/05/00 22:09:36 |
Joel Sherrill |
Increased stack space.
4.104.114.84.95
@f49aaf18
01/05/00 22:06:30 |
Joel Sherrill |
Updated to reflect change in object class numbering due to ITRON API …
4.104.114.84.95
@280c4ca
01/05/00 22:03:44 |
Joel Sherrill |
Corrected test and screen to reflect implementation working.
4.104.114.84.95
@5cffd64
01/05/00 22:03:27 |
Joel Sherrill |
Changed screen to reflect change in object class numbers with ITRON …
4.104.114.84.95
@3a8b95e
01/05/00 21:32:57 |
Joel Sherrill |
Spacing corrected.
4.104.114.84.95
@54a5ee7
01/05/00 20:51:45 |
Joel Sherrill |
Corrected so header message is printed.
4.104.114.84.95
@66fe6be6
01/05/00 18:40:20 |
Joel Sherrill |
patch from Eric Norum <eric@…> as follows:
At the …
4.104.114.84.95
@69405459
01/05/00 18:40:14 |
Joel Sherrill |
Patch from Eric Norum <eric@…> as follows:
At the …
4.104.114.84.95
@db6ec79e
01/05/00 18:30:09 |
Joel Sherrill |
Fixed recursive release for mutexes with nesting allowed.
4.104.114.84.95
@f388d36
01/05/00 18:17:01 |
Joel Sherrill |
Now print strings -- not error numbers.
4.104.114.84.95
@99e7ab89
01/05/00 17:21:12 |
Jennifer.Averett |
+ Added tests for open, close, unlink, and send.
4.104.114.84.95
@b302d527
01/05/00 17:20:07 |
Jennifer.Averett |
+ Added return priority from message seize.
+ Changed priority to be …
4.104.114.84.95
@466b8882
01/05/00 17:18:51 |
Jennifer.Averett |
Added the recording of the submit type.
4.104.114.84.95
@58243b4
01/05/00 17:18:08 |
Jennifer.Averett |
+ Added return of the message priority.
4.104.114.84.95
@65800393
01/05/00 17:16:48 |
Jennifer.Averett |
Added priority conversion between POSIX and core.
4.104.114.84.95
@c5858ef
01/05/00 17:16:02 |
Jennifer.Averett |
Added priority conversion between POSIX and core priorities.
4.104.114.84.95
@3ebd4c1
01/05/00 17:13:50 |
Jennifer.Averett |
+ Changed priority to the POSIX priority type.
+ Added priority …
4.104.114.84.95
@fcd0c90
01/05/00 17:11:36 |
Jennifer.Averett |
+ Added check for reading from a write only queue.
+ Added ability to …
4.104.114.84.95
@cecd206
01/05/00 17:09:36 |
Jennifer.Averett |
+ Added check for name greater than PATH_MAX.
4.104.114.84.95
@e015106
01/05/00 17:08:56 |
Jennifer.Averett |
+ Changed to resonable default values for maxmsg and msgsize.
+ Added …
4.104.114.84.95
@f602eeb
01/05/00 17:07:52 |
Jennifer.Averett |
Added mqueuetranslatereturncode.c.
4.104.114.84.95
@864ac98
01/05/00 17:06:45 |
Jennifer.Averett |
Added routines to translate to and from the core message queue return …
4.104.114.84.95
@590eb87
01/04/00 17:08:16 |
Joel Sherrill |
Added this file to contain an example program.
4.104.114.84.95
@bfded728
01/04/00 14:16:00 |
Joel Sherrill |
Fixed warnings.
4.104.114.84.95
@36155ebb
01/04/00 14:03:38 |
Joel Sherrill |
Removed warning.
4.104.114.84.95
@a148f56
01/04/00 14:00:38 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@1dfc188e
01/04/00 13:58:47 |
Joel Sherrill |
Removed unitialized variable warning.
4.104.114.84.95
@afe8c1b6
01/04/00 13:49:05 |
Joel Sherrill |
Added shared version of this file.
4.104.114.84.95
@7b0ff008
01/04/00 13:48:48 |
Joel Sherrill |
Made to compile again.
4.104.114.84.95
@393be8e
01/03/00 20:43:29 |
Joel Sherrill |
Fixed path to shared/include/coverhd.h.
4.104.114.84.95
@0173ab8
01/03/00 18:28:36 |
Joel Sherrill |
Comments added and some messages translated from Polish.
4.104.114.84.95
@0af1b73f
01/03/00 17:27:06 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
In another attempt to …
4.104.114.84.95
@110136a
01/03/00 16:53:07 |
Joel Sherrill |
Updated times.
4.104.114.84.95
@e065e8ae
01/03/00 16:52:50 |
Joel Sherrill |
Increased stack size to 4K per Eric Norum.
4.104.114.84.95
@205d5645
01/03/00 16:44:04 |
Joel Sherrill |
Patch from John Mills <jmills@…> to correct some cut and paste …
4.104.114.84.95
@6b7cf9f
01/03/00 15:39:06 |
Joel Sherrill |
Patch rtems-rc-19991203-12.diff from Ralf Corsepius …
4.104.114.84.95
@b84176b
01/03/00 15:36:18 |
Joel Sherrill |
Do not explicitly list pieces from libcpu used.
4.104.114.84.95
@32f19fb3
01/03/00 14:38:47 |
Joel Sherrill |
Share align_h.S from ppc403. VPATH was not picking it up. Discovered …
4.104.114.84.95
@e07b6868
01/03/00 14:14:37 |
Joel Sherrill |
Added tm27 stuff.
4.104.114.84.95
@db941670
01/03/00 14:14:24 |
Joel Sherrill |
Added define to trip items that are private to tm27 in bsp.h.
4.104.114.84.95
@95273a6
01/03/00 14:06:42 |
Joel Sherrill |
Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric …
4.104.114.84.95
@d5c4681e
01/03/00 14:04:22 |
Joel Sherrill |
Use shared coverhd.h.
4.104.114.84.95
@20385957
01/03/00 14:01:02 |
Joel Sherrill |
Increased minimum stack size so all tests will run.
4.104.114.84.95
@6eb3e68
12/23/99 22:12:15 |
Jennifer.Averett |
+ Tests added for mq_open, mq_close, and mq_unlink
4.104.114.84.95
@2e97c01
12/23/99 22:11:01 |
Jennifer.Averett |
+ Added routine to remove from namespace.
4.104.114.84.95
@afebb3f
12/23/99 22:10:13 |
Jennifer.Averett |
4.104.114.84.95
@7fbef786
12/23/99 22:09:36 |
Jennifer.Averett |
+ Debugged.
4.104.114.84.95
@8f12d069
12/23/99 22:08:43 |
Jennifer.Averett |
+ Filled in routine.
4.104.114.84.95
@96d4aea
12/23/99 22:07:43 |
Jennifer.Averett |
+ Initial debug
4.104.114.84.95
@d4548d1
12/23/99 22:07:11 |
Jennifer.Averett |
+ Made work
+ Added checks for valid attribute maxmsg and msgsize
4.104.114.84.95
@e1786ee3
12/23/99 22:05:25 |
Jennifer.Averett |
+ Fixed errno response to match the POSIX manual.
4.104.114.84.95
@2116e33
12/21/99 20:29:57 |
Joel Sherrill |
Reverted the delay logic.
4.104.114.84.95
@ed46b47
12/21/99 20:29:40 |
Joel Sherrill |
Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to …
4.104.114.84.95
@56018097
12/21/99 20:28:13 |
Joel Sherrill |
Now use coverhd.h out of the libbsp/shared directory.
4.104.114.84.95
@0d6f0b4
12/21/99 20:10:04 |
Joel Sherrill |
Now use shared coverhd.h
4.104.114.84.95
@5d807b5
12/21/99 17:06:31 |
Joel Sherrill |
New files.
4.104.114.84.95
@a3ba9f98
12/21/99 17:05:15 |
Joel Sherrill |
New file.
4.104.114.84.95
@8437abd4
12/21/99 16:56:31 |
Joel Sherrill |
Removed as part of moving this driver to libchip.
4.104.114.84.95
@400c552
12/21/99 16:20:38 |
Joel Sherrill |
Removing Makefile.in and adding Makefile.am. These were missed in …
4.104.114.84.95
@fb16fed
12/21/99 15:25:05 |
Joel Sherrill |
Patch rtems-rc-19991203-10.diff from Ralf Corsepius …
4.104.114.84.95
@9ba1f0a
12/21/99 15:04:48 |
Joel Sherrill |
Patch rtems-rc-19991203-9.diff from Ralf Corsepius …
4.104.114.84.95
@369ef189
12/21/99 15:00:49 |
Joel Sherrill |
Patch rtems-rc-19991203-7.diff from Ralf Corsepius …
4.104.114.84.95
@35d7b15
12/21/99 14:41:43 |
Joel Sherrill |
4.104.114.84.95
@5bce35b
12/21/99 14:37:31 |
Joel Sherrill |
Made prototype of ChapReceiveSuccess? and ChapReceiveFailure? match.
4.104.114.84.95
@0fe48346
12/21/99 14:34:30 |
Joel Sherrill |
4.104.114.84.95
@db3e0108
12/21/99 14:32:00 |
Joel Sherrill |
Patch rtems-rc-19991203-6.diff from Ralf Corsepius …
4.104.114.84.95
@8b91282
12/21/99 14:27:52 |
Joel Sherrill |
Patch rtems-rc-19991203-5.diff from Ralf Corsepius …
4.104.114.84.95
@3ad7602e
12/20/99 15:21:31 |
Joel Sherrill |
Modifications to avoid having the size of the Buffer_addresses array …
4.104.114.84.95
