@8739322
07/25/98 17:17:46 |
Joel Sherrill |
Added ns16550_set_attributes.
4.104.114.84.95
@b636d56
07/25/98 17:17:36 |
Joel Sherrill |
Corrected spacing and added a comment.
4.104.114.84.95
@ccfa60b
07/25/98 17:17:05 |
Joel Sherrill |
Updated to reflect set attributes.
4.104.114.84.95
@70a9451
07/25/98 16:53:21 |
Joel Sherrill |
Rewrote NS16550 TX interrupt processing to use termios for the buffer …
4.104.114.84.95
@adedb057
07/25/98 16:52:17 |
Joel Sherrill |
Removed TX ring buffer.
4.104.114.84.95
@cb27f05
07/25/98 16:52:00 |
Joel Sherrill |
Changed variable to hold received data to unsigned.
4.104.114.84.95
@dfb16ce
07/25/98 16:20:33 |
Joel Sherrill |
Added constants for z85c30_enable_interrupts.
4.104.114.84.95
@04c5ac7
07/25/98 16:20:14 |
Joel Sherrill |
Removed z85c30_flush().
Reworked transmit interrupt processing to …
4.104.114.84.95
@c1da250
07/25/98 16:18:46 |
Joel Sherrill |
Changed comment on TxBuffer?.
4.104.114.84.95
@b070d69a
07/25/98 16:18:27 |
Joel Sherrill |
Removed mc68681_flush and corrected spacing.
4.104.114.84.95
@f600da3f
07/25/98 16:17:33 |
Joel Sherrill |
Added information on Chris Johns' suggestion to use pointers …
4.104.114.84.95
@3d2c161
07/25/98 16:16:10 |
Joel Sherrill |
Removed "if 0" used to switch between serial ports.
4.104.114.84.95
@da8ac60a
07/25/98 16:02:21 |
Joel Sherrill |
New file.
4.104.114.84.95
@c68b990
07/25/98 14:51:57 |
Joel Sherrill |
Changed to utilize return status from …
4.104.114.84.95
@a3c9f0d
07/25/98 14:50:07 |
Joel Sherrill |
Moved console.c to libbsp/shared.
4.104.114.84.95
@f246caf
07/25/98 14:13:34 |
Joel Sherrill |
Interrupts were incorrectly managed with a disable/disable pair rather …
4.104.114.84.95
@bf21172
07/24/98 18:30:50 |
Joel Sherrill |
changed version to 980724
4.104.114.84.95
@03c0961
07/24/98 16:18:39 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…>:
Here's a small …
4.104.114.84.95
@dbab462
07/24/98 16:09:51 |
Joel Sherrill |
Patch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@1501809
07/23/98 22:13:46 |
Joel Sherrill |
changed version to 980723
4.104.114.84.95
@dbaf51a
07/23/98 22:13:10 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
Here is a patch …
4.104.114.84.95
@67a2288
07/23/98 22:02:34 |
Joel Sherrill |
Patch from Eric VALETTE <valette@…>:
Here is a …
4.104.114.84.95
@73452854
07/23/98 20:04:55 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Here is a pure …
4.104.114.84.95
@c91e032
07/23/98 19:32:01 |
Joel Sherrill |
Removed consolex from build list. This file should be obsoleted by …
4.104.114.84.95
@92fc5a5d
07/21/98 13:59:12 |
Joel Sherrill |
Fix from Chris Johns <ccj@…>. Comments:
Mask interrupts …
4.104.114.84.95
@bced36d
07/18/98 18:44:12 |
Joel Sherrill |
Changed so we could test interrupts on port 3.
4.104.114.84.95
@c14a619
07/18/98 18:35:34 |
Joel Sherrill |
Removed use of data port for z8530.
Move some code around.
4.104.114.84.95
@3652929e
07/18/98 18:35:07 |
Joel Sherrill |
Tested all four ports. MC68681 …
4.104.114.84.95
@91f16d5
07/18/98 18:34:04 |
Joel Sherrill |
New file
4.104.114.84.95
@a4d34dd2
07/18/98 17:47:50 |
Joel Sherrill |
Added z85c30 specific probe routine to decide what the clock rate was. …
4.104.114.84.95
@f8a5d54e
07/18/98 17:46:33 |
Joel Sherrill |
Addresses for SCC were wrong. A and B ports were swapped.
Deleted …
4.104.114.84.95
@c53e1df4
07/18/98 16:56:16 |
Joel Sherrill |
Swapped RX and TX since doing this makes the lights blink on the …
4.104.114.84.95
@fe05ec5e
07/18/98 16:11:13 |
Joel Sherrill |
Added RS-422 converter information and cable building information.
4.104.114.84.95
@cc3d33ac
07/18/98 15:34:03 |
Joel Sherrill |
Added information on the MC68681.
4.104.114.84.95
@f7d6e57
07/18/98 15:24:14 |
Joel Sherrill |
Added background and setup to add section on RS-422.
4.104.114.84.95
@f77670be
07/18/98 15:23:56 |
Joel Sherrill |
Reworked to removed dependency on DY-4 CSS ROM monitor interface.
4.104.114.84.95
@e286479
07/18/98 15:23:24 |
Joel Sherrill |
Removed css_iface.
4.104.114.84.95
@6d4062f
07/18/98 15:22:54 |
Joel Sherrill |
Removed. We are no longer dependent on DY-4 CSS interface code.
4.104.114.84.95
@cce1200e
07/18/98 15:19:28 |
Joel Sherrill |
New file.
4.104.114.84.95
@4555bc1e
07/17/98 22:34:54 |
Joel Sherrill |
Initialized tty->refcount to 0. When (for whatever reason) malloc() …
4.104.114.84.95
@f95d2b53
07/17/98 15:49:12 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>. Comments:
4.104.114.84.95
@8123c635
07/17/98 15:43:42 |
Joel Sherrill |
Added scitab directory.
4.104.114.84.95
@a56e475f
07/17/98 15:42:39 |
Joel Sherrill |
Turned stack checker on.
4.104.114.84.95
@bdba552f
07/17/98 15:19:04 |
Joel Sherrill |
Patch fromalf Corsepius <corsepiu@…>:
4.104.114.84.95
@fa21a843
07/17/98 15:17:29 |
Joel Sherrill |
New files from Ralf Corsepius <corsepiu@…>. His …
4.104.114.84.95
@6e65840
07/17/98 13:05:03 |
Joel Sherrill |
Patch from Dario Alcocer <alcocer@…>. His comments:
4.104.114.84.95
@16d0e63
07/16/98 00:16:22 |
Joel Sherrill |
Corrected header files.
4.104.114.84.95
@a6f441b
07/16/98 00:16:11 |
Joel Sherrill |
Minor corrections for typos to get it to compile.
4.104.114.84.95
@dd5d2f04
07/16/98 00:03:01 |
Joel Sherrill |
Split default baud rate table into its own file. This shrinks the …
4.104.114.84.95
@4a11d8c
07/15/98 23:58:08 |
Joel Sherrill |
Fixed typo in which last port did not get switched to default
register …
4.104.114.84.95
@849dc107
07/15/98 23:57:41 |
Joel Sherrill |
Fixed typos.
4.104.114.84.95
@670d037
07/15/98 23:55:04 |
Joel Sherrill |
Switched to usign the default z8530 and mc68681 register access routines.
4.104.114.84.95
@8414c033
07/15/98 23:54:24 |
Joel Sherrill |
Added default z85c30 register access routines.
4.104.114.84.95
@cce9322
07/15/98 23:54:08 |
Joel Sherrill |
Added default mc68681 register access routines.
4.104.114.84.95
@991a1ab4
07/15/98 23:21:55 |
Joel Sherrill |
Added check for proper deviceType to interrupt processing code.
4.104.114.84.95
@efaf85fa
07/15/98 23:21:30 |
Joel Sherrill |
Added interrupt mask and interrupt status register bit constants.
4.104.114.84.95
@49370cd
07/15/98 23:20:50 |
Joel Sherrill |
4.104.114.84.95
@198d851
07/15/98 23:20:33 |
Joel Sherrill |
Switched from driver's own buffering to using termios. This …
4.104.114.84.95
@27a66bd
07/15/98 23:15:49 |
Joel Sherrill |
Added information on the deviceType field.
4.104.114.84.95
@66f95fc
07/15/98 23:15:32 |
Joel Sherrill |
4.104.114.84.95
@8a2e9c41
07/15/98 21:43:28 |
Joel Sherrill |
Added SCV64_Get_Interrupt_Enable().
Added proper headers to routines.
4.104.114.84.95
@d0cff6dc
07/15/98 21:43:00 |
Joel Sherrill |
4.104.114.84.95
@38e717f
07/15/98 21:42:26 |
Joel Sherrill |
Added chip type identifier field. This was necessary because a single …
4.104.114.84.95
@c0573d7
07/15/98 21:40:42 |
Joel Sherrill |
Added comment to remove use of TxBuffer? ring buffer in all libchip …
4.104.114.84.95
@0f61336
07/15/98 19:28:29 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@a69f0ad9
07/15/98 19:20:20 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@100a4e5
07/15/98 19:19:14 |
Joel Sherrill |
Masked out interrupts not being used prior to processing the status …
4.104.114.84.95
@6c45da17
07/15/98 19:12:11 |
Joel Sherrill |
Added routine to return interrupt mask. Added comments.
4.104.114.84.95
@01e54b8
07/15/98 14:06:37 |
Joel Sherrill |
Added scv64 subdirectory.
4.104.114.84.95
@e49ef37c
07/15/98 14:06:08 |
Joel Sherrill |
Switched to SCV64.
4.104.114.84.95
@8f563b9b
07/15/98 14:05:51 |
Joel Sherrill |
Added CSCV64 functions and addresses.
4.104.114.84.95
@30a3f76
07/15/98 14:04:31 |
Joel Sherrill |
Switched from polling to interrupts and in the process added a …
4.104.114.84.95
@437b5a7d
07/15/98 14:00:23 |
Joel Sherrill |
4.104.114.84.95
@090a3511
07/15/98 14:00:09 |
Joel Sherrill |
New files.
4.104.114.84.95
@be8cbbf
07/15/98 13:58:23 |
Joel Sherrill |
Switched deviceOutputUsesInterrupts to TRUE so output would be …
4.104.114.84.95
@e283140c
07/15/98 13:53:58 |
Joel Sherrill |
Switched to "deviceOutput = TRUE" which made device output use interrupts.
4.104.114.84.95
@5b8c1b7
07/11/98 14:23:53 |
Joel Sherrill |
Yet another EXEEXT patch. This one is from Ralf Corsepius …
4.104.114.84.95
@3a447c3
07/10/98 19:05:20 |
Joel Sherrill |
changed version to 980710
4.104.114.84.95
@dbfa3148
07/10/98 15:43:18 |
Joel Sherrill |
Patch from Quality Quorum <qqi@…>. Comments:
4.104.114.84.95
@cc8a388a
07/10/98 14:13:59 |
Joel Sherrill |
4.104.114.84.95
@fb32356b
07/09/98 23:32:07 |
Joel Sherrill |
Added set attributes routine but did not hook it in to the table.
4.104.114.84.95
@abd8c82
07/09/98 23:31:48 |
Joel Sherrill |
Added new files.
4.104.114.84.95
@31cad72c
07/09/98 23:31:26 |
Joel Sherrill |
Renamed so we could have one file per routine.
4.104.114.84.95
@064b9be
07/09/98 23:30:32 |
Joel Sherrill |
Switched to shared default probe routine.
4.104.114.84.95
@693b5b88
07/09/98 23:30:02 |
Joel Sherrill |
Switched to default probe routine.
4.104.114.84.95
@61ff7ac8
07/09/98 23:29:33 |
Joel Sherrill |
Added new baud rate to number function and default serial probe …
4.104.114.84.95
@11c6a92d
07/09/98 22:59:32 |
Joel Sherrill |
Commented out the system call invocation since we don't know what …
4.104.114.84.95
@a6e36dff
07/09/98 22:59:13 |
Joel Sherrill |
Removed call back to exit() since that has already been called.
4.104.114.84.95
@e78c474b
07/09/98 22:21:54 |
Joel Sherrill |
Added proper handling of extended baud rate table selection at boot …
4.104.114.84.95
@2c5ea01
07/09/98 22:16:27 |
Joel Sherrill |
Properly handle extended baud rate set commands.
Temporarily "if 0" …
4.104.114.84.95
@e3c59dd
07/09/98 22:11:49 |
Joel Sherrill |
Corrected definition of MC68681_RX_BUFFER.
4.104.114.84.95
@2ba0a0c2
07/09/98 18:50:13 |
Joel Sherrill |
Corrected z85c30 address and clock constants.
4.104.114.84.95
@459c1d2
07/09/98 18:49:49 |
Joel Sherrill |
Added board specific baud rate table and set driver function table
to …
4.104.114.84.95
@2d8e51aa
07/09/98 18:45:28 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all data and routines …
4.104.114.84.95
@b2ec38c8
07/09/98 18:44:10 |
Joel Sherrill |
Removed commented out line.
4.104.114.84.95
@8f6f641e
07/09/98 18:41:49 |
Joel Sherrill |
Added sersupp.c.
4.104.114.84.95
@d94d47b3
07/09/98 18:41:33 |
Joel Sherrill |
New files to contain generally needed serial driver support routines.
4.104.114.84.95
@37e8259
07/09/98 18:40:27 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all routines and data global …
4.104.114.84.95
@8b2492f
07/09/98 18:39:50 |
Joel Sherrill |
Added support for the Extended Baud Rate set control found in the
Exar …
4.104.114.84.95
@27045a82
07/09/98 18:38:18 |
Joel Sherrill |
Changed static to NS16550_STATIC to make all routines and data global …
4.104.114.84.95
