@605b4b64
04/19/12 13:21:24 |
Daniel Hellstrom |
LEON3: debugputs removed pointless isinit code, invoked only once
4.115
@5903484
04/19/12 13:21:23 |
Daniel Hellstrom |
LEON3: debugputs added printk mem buffer when no UART present
4.115
@62694fd
04/19/12 13:46:10 |
Daniel Hellstrom |
LEON3: add console interrupt mode support
The comment in configure.ac …
4.115
@07557c8
04/19/12 13:21:21 |
Daniel Hellstrom |
LEON3: add console attributes such as parity and baudrate
4.115
@6845f80
04/19/12 13:21:20 |
Daniel Hellstrom |
LEON3: console, lower bus utilization waiting for UART TX ready
4.115
@7a01a888
04/17/12 14:25:42 |
Daniel Hellstrom |
LEON: updated drivers to use new AMBAPP Layer
The drivers are updated …
4.115
@fc6f872
04/17/12 14:25:41 |
Daniel Hellstrom |
LEON3: Network initialization code updated to new AMBAPP layer
4.115
@ddf0d60
04/17/12 14:25:40 |
Daniel Hellstrom |
LEON3: updated console driver for new AMBAPP layer
Signed-off-by: …
4.115
@1f7cfbe3
04/17/12 14:25:39 |
Daniel Hellstrom |
LEON2: clock driver use new AMBAPP layer
Signed-off-by: Daniel …
4.115
@9ea65119
04/17/12 14:25:38 |
Daniel Hellstrom |
LEON: updated AMBA PnP API
The old layer had some …
4.115
@e99dbaa
04/16/12 23:35:25 |
Gedare Bloom |
no_cpu: replace no_cpu_isr with rtems_isr
4.115
@a114011d
04/16/12 02:28:14 |
Gedare Bloom |
lm32: use shared setvec.c
4.115
@06d34af
04/16/12 02:26:41 |
Gedare Bloom |
m68k: use shared setvec.c
4.115
@416f1efb
04/16/12 02:23:59 |
Gedare Bloom |
lm32: replace lm32_isr with rtems_isr
4.115
@1fec9e0
04/16/12 02:22:36 |
Gedare Bloom |
m68k: replace m68k_isr with rtems_isr
4.115
@7be19f8
04/15/12 19:15:22 |
Sebastian Huber |
bsp/stm32f4: API changes
4.115
@228ece9
04/12/12 19:27:56 |
Sebastian Huber |
bsp/stm32f4: Add IO and RCC
4.115
@7afcb26
04/10/12 19:12:23 |
Daniel Hellstrom |
PR2052: LEON3: fix open_eth interrupt initialization bug
Fixed a bug …
4.115
@e230fb4
03/29/12 19:23:14 |
Sebastian Huber |
bsp/stm32f4: New BSP
4.115
@d8f05c83
03/26/12 16:41:45 |
Sebastian Huber |
bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY
4.115
@5ea637ed
03/26/12 16:40:31 |
Sebastian Huber |
bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT
4.115
@1aebb70
04/07/12 17:07:04 |
Sebastian Huber |
bsps: Update due to API changes
4.115
@7499b84
04/05/12 15:23:17 |
Daniel Hellstrom |
GRETH: use shared-irq service instead of BSP specific set_vec()
The …
4.115
@0f04edd
04/05/12 15:23:16 |
Daniel Hellstrom |
SMC91111: updated to use shared IRQ service
4.115
@c500cbc
04/06/12 14:09:35 |
Joel Sherrill |
LEON3 - Fix spacing
4.115
@3722ff5a
04/05/12 15:23:21 |
Daniel Hellstrom |
LEON3: added IRQAMP support
4.115
@684b54a
04/05/12 15:23:20 |
Daniel Hellstrom |
LEON3: halt boot if IRQ controller not found
4.115
@95518e59
04/06/12 10:05:07 |
Daniel Hellstrom |
SPARC BSPs: implemented shared-irq using libbsp/shared layer
The …
4.115
@e60e862
04/05/12 15:23:19 |
Daniel Hellstrom |
LEON3: console use register pointers instead of UART indexes
4.115
@4b557617
04/05/12 15:23:18 |
Daniel Hellstrom |
LEON3: cleanup console UART indexing handling
The UART indexing was …
4.115
@a36d1b4
04/04/12 17:21:15 |
Jennifer Averett |
Add MIPS/Malta BSP.
4.115
@0c0181d
04/04/12 13:39:46 |
Jennifer Averett |
PR 1993 - Convert MIPS to PIC IRQ model
4.115
@eb6362dc
04/03/12 15:11:10 |
Sebastian Huber |
bsp/mpc55xx: Add and use chip features
Add defines MPC55XX_HAS_SIU …
4.115
@ba56882c
04/02/12 12:07:52 |
Sebastian Huber |
bsp/tqm8xx: Install header file <bsp/irq-info.h>
4.115
@270fa1e
04/02/12 12:07:10 |
Sebastian Huber |
bsp/qemuppc: Install header file <bsp/irq-info.h>
4.115
@b0b32b8
04/02/12 11:37:31 |
Sebastian Huber |
bsps: Fix for clock driver
Do not use the e300 core decrementer …
4.115
@c988f180
04/02/12 09:59:36 |
Sebastian Huber |
bsp/gen83xx: Fix console driver configuration
4.115
@15fde68c
04/02/12 09:59:06 |
Sebastian Huber |
bsp/gen83xx: Removed file
4.115
@06b6a03
04/02/12 09:48:30 |
Sebastian Huber |
bsp/gen83xx: Regenerate
4.115
@8bb00ac
04/02/12 09:32:11 |
Sebastian Huber |
bsps: More accurate PowerPC clock driver
The clock driver used …
4.115
@1bb72a9
04/02/12 09:06:34 |
Sebastian Huber |
bsp/gen83xx: Support cache BSP options
4.115
@a3db5ff4
04/02/12 09:05:29 |
Sebastian Huber |
bsp/gen83xx: Support for MPC830X
4.115
@31ea3109
04/02/12 09:04:44 |
Sebastian Huber |
bsp/gen83xx: Add sections for BSD support
4.115
@73f1b303
04/02/12 08:59:17 |
Sebastian Huber |
bsp/gen83xx: Install new header file
4.115
@69237c16
04/02/12 08:58:50 |
Sebastian Huber |
bsp/virtex5: Regenerate
4.115
@16a8616
03/30/12 15:03:43 |
Ric Claus |
Add Virtex4 and Virtex5 BSPs
This commit covers at least PR2020, …
4.115
@0b095f76
03/30/12 13:41:15 |
Jennifer Averett |
Resolve link problems with psim irq-server
Add IRQ support components …
4.115
@97f82fc
03/30/12 13:38:14 |
Jennifer Averett |
4.115
@8d0913b8
03/29/12 20:53:16 |
Joel Sherrill |
PC386 - Add files missed in previous commit
4.115
@2cc30b0d
03/29/12 20:28:13 |
Joel Sherrill |
PC386 Add RTD316 and Exar 17D15x multi-port serial card support
4.115
@2cee553
03/29/12 11:52:16 |
Daniel Hellstrom |
LEON3: various cleanups in leon.h
Removed old LEON2 definitions never …
4.115
@226771c
03/29/12 11:52:14 |
Daniel Hellstrom |
LEON3: IRQ index mask was bad, but always shifted out anyway
4.115
@4fa6be9
03/29/12 11:52:13 |
Daniel Hellstrom |
LEON3: clock timer indexing should be consequent
Signed-off-by: …
4.115
@752f876e
03/29/12 17:07:30 |
Jennifer Averett |
Address Conflicts:
c/src/lib/libbsp/powerpc/psim/startup/linkcmds
4.115
@0729e2a7
03/28/12 08:49:27 |
Daniel Hellstrom |
SPARC: bsp_early_malloc() routine for startup memory allocation
If …
4.115
@b9d8cd33
03/29/12 11:52:12 |
Daniel Hellstrom |
SMC91111: remove old unused LEON2/LEON3 intialization code
4.115
@d0dbcf8
03/29/12 11:52:11 |
Daniel Hellstrom |
LEON3: fix GRETH interrupt initialization bug
Fixed a bug where the …
4.115
@e6f327c
03/29/12 11:52:10 |
Daniel Hellstrom |
GRETH: removed the use of rtems_set_clock() in auto-nego timeout
4.115
@39671330
12/02/11 09:53:35 |
Daniel Hellstrom |
GRETH: added support for non-snooping GRETH 10/100 systems
When data …
4.115
@a73884e9
03/24/12 21:56:37 |
Sebastian Huber |
bsp/lm3s69xx: Reflect new Qemu patch
4.115
@bd0fb473
03/24/12 21:53:07 |
Sebastian Huber |
bsps: Shared ARMv7-M interrupt support
4.115
@0f31fddc
03/24/12 21:01:08 |
Sebastian Huber |
bsps: Add shared default IRQ handler
4.115
@b2ee4d5f
03/24/12 20:04:40 |
Sebastian Huber |
bsp/lm3s69xx: Format
4.115
@954393ca
03/24/12 19:57:21 |
Sebastian Huber |
bsp/lm3s69xx: Use shared timer stub driver
4.115
@1ed238e
03/24/12 19:55:40 |
Sebastian Huber |
bsp/lm3s69xx: Use shared start.S
4.115
@34c61517
03/24/12 19:14:27 |
Sebastian Huber |
bsps: Shared ARMv7-M clock driver
4.115
@3c0e7f9b
03/24/12 19:06:49 |
Sebastian Huber |
bsp/lm3s69xx: New Qemu patch
4.115
@5cc813f
03/24/12 16:33:22 |
Sebastian Huber |
bsps: Provide optional prototype
4.115
@e8adc8e3
03/24/12 15:59:25 |
Sebastian Huber |
bsp/lpc24xx: Use proper clock value
4.115
@f3cdf279
03/24/12 15:58:31 |
Sebastian Huber |
bsp/lpc24xx: More CAN pin definitions
4.115
@67b1ce4
02/06/12 14:15:49 |
Daniel Hellstrom |
SMC91111: ERC32 was never supported by driver
Moved the intelligence …
4.115
@f636ba64
02/06/12 14:15:48 |
Daniel Hellstrom |
shared-irq: add support for custom BSP vector verification
4.115
@b4dfce9b
02/06/12 14:15:47 |
Daniel Hellstrom |
LEON3: spurious trap handler print out trap in hex instead
4.115
@80d01b3c
02/08/12 14:57:03 |
Daniel Hellstrom |
SPARC: added libcpu lowlevel access and byteorder routines/definitions …
4.115
@7e664023
03/16/12 13:23:43 |
Jennifer Averett |
Added irq server and link commands for new libbsd support.
4.115
@67baf60
03/14/12 17:06:13 |
Gedare Bloom |
PR2041: sparc64: vector number not included in CPU_Interrupt_frame
4.115
@4868c771
03/14/12 15:45:26 |
Sebastian Huber |
bsp/lpc24xx: New BSP variant
4.115
@2563410
03/13/12 08:22:11 |
Sebastian Huber |
Filesystem: Rename defines
o Removed RTEMS_LIBIO_PERMS_SEARCH.
o …
4.115
@4116fce6
02/24/12 16:39:27 |
Sebastian Huber |
Filesystem: New defaults fsync_h and fdatasync_h
New defaults …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@0bda8b4
03/09/12 16:28:39 |
Joel Sherrill |
Add missing BSD sections.
4.115
@c5a6e617
03/09/12 14:47:32 |
Sebastian Huber |
bsp/gen5200: Fix FPU initialization
The change of the MSR[FP] status …
4.115
@3bd4656
03/09/12 14:46:07 |
Sebastian Huber |
bsp/gen5200: Reflect clocks of new BRS5L hardware
4.115
@314d327
03/06/12 14:36:49 |
Joel Sherrill |
Merge branch 'master' of ssh://git.rtems.org/data/git/rtems
4.115
@47a45e5c
03/06/12 14:25:39 |
werner |
Milkymist - Increase SOFTUSB_PMEM_SIZE to 8 KB
We increased PMEM to 8 …
4.115
@dc1a3b9
03/03/12 21:02:33 |
Sebastien Bourdeauducq |
PR 2032: Milkymist USB: Ioctl interface for loading USB firmware
4.115
@f0d2261
03/03/12 20:50:53 |
Xiangfu Liu <xiangfu at sharism dot cc> |
PR2029: Milkymist VGA: adjust video timings
Slightly adjust video …
4.115
@f7bb9f9
02/29/12 16:08:44 |
werner |
PR2028: Milkymist USB: forward MIDI messages.
Forward MIDI messages …
4.115
@19d18f23
02/23/12 18:09:55 |
Joel Sherrill |
Fix typo in comment.
4.115
@8f7f6ca
02/23/12 16:43:58 |
Jennifer Averett |
Merge remote-tracking branch 'upstream/master'
4.115
@4f1173bc
02/23/12 16:40:33 |
Jennifer Averett |
Avoid NULL dereference in printk() before libchip console initialized
4.115
@8d8f363
02/21/12 15:24:37 |
Sebastian Huber |
LPC32XX: Typo
4.115
@39e8aa9
02/17/12 20:28:19 |
Joel Sherrill |
PR 2015 - LEON3: make SHM driver configurable using weak
PR 2015/bsps …
4.115
@e1ebfebf
02/11/12 20:15:06 |
Sebastian Huber |
Patches for Qemu 1.0.50
4.115
@14ee5a1e
02/11/12 20:10:12 |
Sebastian Huber |
Support for NXP LPC1700 family
4.115
@1f8771d2
02/07/12 21:11:50 |
Sebastian Huber |
Use proper ARMv7-M compiler flags.
4.115
@d6f947e
02/07/12 21:09:45 |
Sebastian Huber |
ARMv7-M Systick API change
4.115
@034b041
02/07/12 21:13:04 |
Sebastian Huber |
Fixed bug intoduced due to API changes.
4.115
@3b18c26
02/11/12 19:35:53 |
Wendell P Silva |
PR 2017/bsps - Update due to API changes
4.115
@5d443559
02/02/12 22:57:42 |
Joel Sherrill |
PR 1991/cpukit - attr.c (really mode code) warning rework
This PR was …
4.115
