@5428b106
12/15/98 23:40:53 |
Joel Sherrill |
More automake preparation changes from Ralf Corsepius …
4.104.114.84.95
@0825f578
12/15/98 23:32:19 |
Joel Sherrill |
Moved around per Ralf Corsepius as preparation for automake
4.104.114.84.95
@ee44db3
12/15/98 22:02:28 |
Joel Sherrill |
Part II automake reorg by Ralf Corsepius
4.104.114.84.95
@7e22c7d
12/15/98 21:57:08 |
Joel Sherrill |
4.104.114.84.95
@afa3c8f
12/15/98 20:04:04 |
Joel Sherrill |
Added files as part of move
4.104.114.84.95
@9d5c22e3
12/15/98 19:56:41 |
Joel Sherrill |
Switched to use of ASM compilation conditional.
4.104.114.84.95
@7359911
12/15/98 19:40:27 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Some …
4.104.114.84.95
@2417b15
12/15/98 15:00:25 |
Joel Sherrill |
Changed reference from no_cpu to mips64orion.
4.104.114.84.95
@62184317
12/15/98 00:55:28 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to reorganize …
4.104.114.84.95
@063a19a
12/15/98 00:24:30 |
Joel Sherrill |
4.104.114.84.95
@0c291bc
12/14/98 23:58:22 |
Joel Sherrill |
Switch from .s to .S on include
4.104.114.84.95
@0162910
12/14/98 23:15:38 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to rename all
.s …
4.104.114.84.95
@1d9f198a
12/14/98 23:15:08 |
Joel Sherrill |
.s …
4.104.114.84.95
@e22d644
12/14/98 23:01:43 |
Joel Sherrill |
Corrected prototype to confirm to POSIX 1003.1b.
4.104.114.84.95
@b2e180b7
12/14/98 22:15:57 |
Joel Sherrill |
Renamed ASFLAGS to ASMFLAGS for consistency per suggestion from Ralf …
4.104.114.84.95
@cca4400
12/10/98 23:31:54 |
Joel Sherrill |
Merged Eric Norum's select patch that was based on 4.0 and resolved …
4.104.114.84.95
@6c980128
12/10/98 21:53:02 |
Joel Sherrill |
RDBG headers files ignored if not configured
4.104.114.84.95
@b1bc63b
12/10/98 21:52:36 |
Joel Sherrill |
Fixed conflict between patches
4.104.114.84.95
@a3d0b8a
12/10/98 19:42:29 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
4.104.114.84.95
@2ffe30d
12/07/98 17:45:48 |
Joel Sherrill |
This patch avoids a …
4.104.114.84.95
@91b1c8e6
12/07/98 17:42:52 |
Joel Sherrill |
RTEMS permits using …
4.104.114.84.95
@e203c04b
12/04/98 02:00:53 |
Joel Sherrill |
changed version to 19981203
4.104.114.84.95
@4721cf1
12/03/98 23:54:14 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> to add remote debug …
4.104.114.84.95
@cd155be
12/03/98 23:02:24 |
Joel Sherrill |
Removed spaces.
4.104.114.84.95
@41616f6
12/03/98 23:01:22 |
Joel Sherrill |
Changed to account for ownership only being tracked when a priority …
4.104.114.84.95
@6afa6e3
12/03/98 22:45:57 |
Jennifer.Averett |
Removed all M from the file.
4.104.114.84.95
@dc8acc14
12/03/98 22:45:45 |
Jennifer.Averett |
Added psx to the front of all test names.
4.104.114.84.95
@0422a7a5
12/03/98 22:42:13 |
Jennifer.Averett |
Removed all M from the scn file.
4.104.114.84.95
@c2f9b97
12/03/98 22:41:57 |
Jennifer.Averett |
Cleaned up test.
Updated scn files to match present expected test output.
4.104.114.84.95
@5b8e885d
12/03/98 22:41:33 |
Jennifer.Averett |
Added Comment that a result is valid at 4 or 5 seconds.
4.104.114.84.95
@fae441b
12/03/98 22:41:20 |
Jennifer.Averett |
4.104.114.84.95
@f98db20
12/03/98 22:41:01 |
Jennifer.Averett |
Renamed all directories to start with psx.
4.104.114.84.95
@b81eeb3
12/03/98 22:40:39 |
Jennifer.Averett |
Added a posix time test.
4.104.114.84.95
@a4e2f08
12/03/98 22:19:06 |
Jennifer.Averett |
Added imfs_fdatasync routine that gets called from both fdatasync and …
4.104.114.84.95
@49629bd8
12/03/98 22:17:46 |
Jennifer.Averett |
Added a imfs fdatasync routine that gets called for fdatasync and datasync.
4.104.114.84.95
@5822f43
12/03/98 22:17:26 |
Jennifer.Averett |
Added source for F_DUPFD.
4.104.114.84.95
@7a3878b
12/03/98 22:17:13 |
Jennifer.Averett |
Modifications for RTEMS_UNIX.
4.104.114.84.95
@af73d86f
12/03/98 22:16:55 |
Jennifer.Averett |
Added a imfs fdatasync routine that gets called for fdatasync and …
4.104.114.84.95
@146263fd
12/03/98 21:58:53 |
Joel Sherrill |
Modified to support test names longer than two characters plus the …
4.104.114.84.95
@012bb56
12/03/98 21:57:50 |
Joel Sherrill |
Insure that the same output occurs when multiprocessing is disabled.
4.104.114.84.95
@6b9450d
12/03/98 21:56:10 |
Joel Sherrill |
Moved cpuuse.h to rtems subdirectory.
4.104.114.84.95
@31bce9b
12/03/98 21:55:33 |
Joel Sherrill |
Moved stackchk.h to rtems subdirectory.
4.104.114.84.95
@347e40d6
12/03/98 21:54:30 |
Joel Sherrill |
Increased default amount of RAM.
4.104.114.84.95
@1aa9876
12/03/98 21:54:09 |
Joel Sherrill |
Removed reference to stackchk.h.
4.104.114.84.95
@478b86fa
12/03/98 21:53:42 |
Joel Sherrill |
Don't build libchip if we are targetting UNIX.
4.104.114.84.95
@ed0e74e
12/03/98 21:53:25 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@fdd9fe17
12/03/98 21:52:20 |
Joel Sherrill |
Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed.
4.104.114.84.95
@42b65db0
12/01/98 13:57:15 |
Joel Sherrill |
Removed reference to libpurify.
4.104.114.84.95
@bfc3533
12/01/98 13:56:46 |
Joel Sherrill |
Include files now installed as <rtems/*.h>.
4.104.114.84.95
@37de72b
12/01/98 13:56:18 |
Joel Sherrill |
Removed unused file.
4.104.114.84.95
@d1ee44e
11/23/98 19:39:45 |
Joel Sherrill |
New files added as part of file system infrastructure effort.
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@cd3fb80
11/23/98 18:58:48 |
Joel Sherrill |
Added new tests in support of the file system infrastructure.
4.104.114.84.95
@0895bdb
11/23/98 18:57:48 |
Joel Sherrill |
Added tests in support of the file system infrastructure.
4.104.114.84.95
@2a7920b
11/23/98 18:37:37 |
Joel Sherrill |
Removed.
4.104.114.84.95
@6e46f4e1
11/23/98 18:35:18 |
Joel Sherrill |
Upped the memory to 8 Mbytes.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@967f3aaa
11/23/98 16:38:28 |
Joel Sherrill |
Added networking.
4.104.114.84.95
@20ad9e9d
11/23/98 14:28:09 |
Joel Sherrill |
New network driver from Erik Ivanenko <erik.ivanenko@…>.
4.104.114.84.95
@8a9caa03
11/19/98 20:23:34 |
Joel Sherrill |
Renamed exception constants per requests from Erik Ivanenko …
4.104.114.84.95
@2e26bbd
11/19/98 20:09:01 |
Joel Sherrill |
Here is a …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@06fee20
10/29/98 22:25:53 |
Joel Sherrill |
changed version to 4.0.0-AFCC
4.104.114.84.95
@a47bd655
10/29/98 17:10:02 |
Joel Sherrill |
Cleanup.
4.104.114.84.95
@22fa5832
10/28/98 19:41:06 |
Joel Sherrill |
The RTEMS i386 stub …
4.104.114.84.95
@b4e3b2b
10/28/98 19:25:12 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>.
I just happened …
4.104.114.84.95
@692b9f7
10/28/98 19:17:16 |
Joel Sherrill |
Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along …
4.104.114.84.95
@e0713641
10/28/98 18:05:05 |
Joel Sherrill |
Removed per Eric Norum
4.104.114.84.95
@c19a4847
10/27/98 19:33:26 |
Joel Sherrill |
4.104.114.84.95
@1e4f7ec6
10/27/98 15:59:59 |
Joel Sherrill |
Spacing.
4.104.114.84.95
@f3e13a1e
10/26/98 23:31:02 |
Joel Sherrill |
Merged base line score603e BSP
4.104.114.84.95
@415ea6a
10/26/98 16:24:59 |
Joel Sherrill |
changed version to 4.0.0-beta4b
4.104.114.84.95
@db88957
10/26/98 16:18:58 |
Joel Sherrill |
Patches done in conjunction with Juan Zamorano Flores …
4.104.114.84.95
@c77b2ca
10/22/98 17:30:12 |
Joel Sherrill |
Typos spotted by Ian Lance Taylor <ian@…>.
4.104.114.84.95
@db538d8
10/22/98 17:28:38 |
Joel Sherrill |
Added missing .rodata and *(.gnu.linkonce.r*) section.
4.104.114.84.95
@6278b8b
10/22/98 17:27:14 |
Joel Sherrill |
I noticed that in the …
4.104.114.84.95
@396286a
10/22/98 16:23:45 |
Joel Sherrill |
Patch from Eric Norum.
4.104.114.84.95
@d3b34d2
10/22/98 16:15:40 |
Joel Sherrill |
Changed all of these to stubs.
4.104.114.84.95
@0a5e510
10/15/98 19:58:32 |
Joel Sherrill |
changed version to 4.0.0-beta4a
4.104.114.84.95
@39bc8fdf
10/15/98 18:47:09 |
Joel Sherrill |
Patch from Thomas Doerfler <td@…> to include the
ppc403 …
4.104.114.84.95
@4cfdf321
10/15/98 14:38:10 |
Joel Sherrill |
Uncommented the conditional stuff for "good gas 16 bit code".
4.104.114.84.95
@11cfb6f7
10/14/98 20:19:30 |
Joel Sherrill |
1. Rtems …
4.104.114.84.95
@0cd2bd96
10/13/98 18:04:16 |
Joel Sherrill |
Added rest of opendir family and made it compile.
4.104.114.84.95
@928395e
10/13/98 16:07:38 |
Joel Sherrill |
New files.
4.104.114.84.95
@714137ef
10/13/98 15:03:27 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct minor …
4.104.114.84.95
@fbd5320
10/13/98 14:59:35 |
Joel Sherrill |
Modified to avoid building certain files under UNIX.
4.104.114.84.95
@91356bcb
10/12/98 20:47:09 |
Joel Sherrill |
Typo which prevented baud rate changes from Thomas Doerfler …
4.104.114.84.95
@70b45c64
10/12/98 17:40:25 |
Joel Sherrill |
4.104.114.84.95
@22bb7cd1
10/12/98 17:28:33 |
Joel Sherrill |
New files.
4.104.114.84.95
@d2018142
10/12/98 17:23:28 |
Joel Sherrill |
Removed fork(), execv(), and wait() since they are now stubbed in the …
4.104.114.84.95
@f7f64f6
10/12/98 17:23:03 |
Joel Sherrill |
Added opendir and readdir.
4.104.114.84.95
@b19cb17
10/12/98 17:21:12 |
Joel Sherrill |
Added header files per request from Chris Johns to avoid problems
in …
4.104.114.84.95
@42c0b9ee
10/07/98 14:54:02 |
Joel Sherrill |
NEXT_GAS should have been NEW_GAS. Spotted by Emmanuel Raguet …
4.104.114.84.95
@5ee9068
10/06/98 21:45:33 |
Joel Sherrill |
changed version to 981006
4.104.114.84.95
@72640a3
10/06/98 20:56:13 |
Joel Sherrill |
Removed files pc386uart.h and pcibio.h from Makefile since they are …
4.104.114.84.95
@d171f8a8
10/06/98 20:55:28 |
Joel Sherrill |
Corrected assembly language to use constants instead of addresses. …
4.104.114.84.95
@dff5b40
10/06/98 20:54:36 |
Joel Sherrill |
Added missing field (idle_task_stack_size) to CPU Table.
4.104.114.84.95
@dc6763c8
10/06/98 13:02:51 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> to add networking …
4.104.114.84.95
@0ebbf66
10/05/98 22:36:06 |
Joel Sherrill |
Large patch from Erik Ivanenko <erik.ivanenko@…> which
moves …
4.104.114.84.95
@711a2a1
10/05/98 21:26:07 |
Joel Sherrill |
New file based on information from Eric Norum <eric@…>.
4.104.114.84.95
