Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @5283cc82   01/05/00 22:15:47 Joel Sherrill Updated to reflect a time that had previously been left out due to an … 4.104.114.84.95
(edit) @27f09663   01/05/00 22:15:16 Joel Sherrill Screen updated since test runs. 4.104.114.84.95
(edit) @4bcbf89c   01/05/00 22:14:42 Joel Sherrill Was not actually installing the test. 4.104.114.84.95
(edit) @28adcfd   01/05/00 22:14:09 Joel Sherrill Added message priority parameter returned by core support routine. 4.104.114.84.95
(edit) @c0d405ca   01/05/00 22:13:15 Joel Sherrill Added new message priority parameter as returned by core support routine. 4.104.114.84.95
(edit) @fc20c53   01/05/00 22:09:36 Joel Sherrill Increased stack space. 4.104.114.84.95
(edit) @f49aaf18   01/05/00 22:06:30 Joel Sherrill Updated to reflect change in object class numbering due to ITRON API … 4.104.114.84.95
(edit) @280c4ca   01/05/00 22:03:44 Joel Sherrill Corrected test and screen to reflect implementation working. 4.104.114.84.95
(edit) @5cffd64   01/05/00 22:03:27 Joel Sherrill Changed screen to reflect change in object class numbers with ITRON … 4.104.114.84.95
(edit) @3a8b95e   01/05/00 21:32:57 Joel Sherrill Spacing corrected. 4.104.114.84.95
(edit) @54a5ee7   01/05/00 20:51:45 Joel Sherrill Corrected so header message is printed. 4.104.114.84.95
(edit) @66fe6be6   01/05/00 18:40:20 Joel Sherrill patch from Eric Norum <eric@…> as follows: At the … 4.104.114.84.95
(edit) @69405459   01/05/00 18:40:14 Joel Sherrill Patch from Eric Norum <eric@…> as follows: At the … 4.104.114.84.95
(edit) @db6ec79e   01/05/00 18:30:09 Joel Sherrill Fixed recursive release for mutexes with nesting allowed. 4.104.114.84.95
(edit) @f388d36   01/05/00 18:17:01 Joel Sherrill Now print strings -- not error numbers. 4.104.114.84.95
(edit) @99e7ab89   01/05/00 17:21:12 Jennifer.Averett + Added tests for open, close, unlink, and send. 4.104.114.84.95
(edit) @b302d527   01/05/00 17:20:07 Jennifer.Averett + Added return priority from message seize. + Changed priority to be … 4.104.114.84.95
(edit) @466b8882   01/05/00 17:18:51 Jennifer.Averett Added the recording of the submit type. 4.104.114.84.95
(edit) @58243b4   01/05/00 17:18:08 Jennifer.Averett + Added return of the message priority. 4.104.114.84.95
(edit) @65800393   01/05/00 17:16:48 Jennifer.Averett Added priority conversion between POSIX and core. 4.104.114.84.95
(edit) @c5858ef   01/05/00 17:16:02 Jennifer.Averett Added priority conversion between POSIX and core priorities. 4.104.114.84.95
(edit) @3ebd4c1   01/05/00 17:13:50 Jennifer.Averett + Changed priority to the POSIX priority type. + Added priority … 4.104.114.84.95
(edit) @fcd0c90   01/05/00 17:11:36 Jennifer.Averett + Added check for reading from a write only queue. + Added ability to … 4.104.114.84.95
(edit) @cecd206   01/05/00 17:09:36 Jennifer.Averett + Added check for name greater than PATH_MAX. 4.104.114.84.95
(edit) @e015106   01/05/00 17:08:56 Jennifer.Averett + Changed to resonable default values for maxmsg and msgsize. + Added … 4.104.114.84.95
(edit) @f602eeb   01/05/00 17:07:52 Jennifer.Averett Added mqueuetranslatereturncode.c. 4.104.114.84.95
(edit) @864ac98   01/05/00 17:06:45 Jennifer.Averett Added routines to translate to and from the core message queue return … 4.104.114.84.95
(edit) @590eb87   01/04/00 17:08:16 Joel Sherrill Added this file to contain an example program. 4.104.114.84.95
(edit) @bfded728   01/04/00 14:16:00 Joel Sherrill Fixed warnings. 4.104.114.84.95
(edit) @36155ebb   01/04/00 14:03:38 Joel Sherrill Removed warning. 4.104.114.84.95
(edit) @a148f56   01/04/00 14:00:38 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @1dfc188e   01/04/00 13:58:47 Joel Sherrill Removed unitialized variable warning. 4.104.114.84.95
(edit) @afe8c1b6   01/04/00 13:49:05 Joel Sherrill Added shared version of this file. 4.104.114.84.95
(edit) @7b0ff008   01/04/00 13:48:48 Joel Sherrill Made to compile again. 4.104.114.84.95
(edit) @393be8e   01/03/00 20:43:29 Joel Sherrill Fixed path to shared/include/coverhd.h. 4.104.114.84.95
(edit) @0173ab8   01/03/00 18:28:36 Joel Sherrill Comments added and some messages translated from Polish. 4.104.114.84.95
(edit) @0af1b73f   01/03/00 17:27:06 Joel Sherrill Patch from Eric Norum <eric@…>: In another attempt to … 4.104.114.84.95
(edit) @110136a   01/03/00 16:53:07 Joel Sherrill Updated times. 4.104.114.84.95
(edit) @e065e8ae   01/03/00 16:52:50 Joel Sherrill Increased stack size to 4K per Eric Norum. 4.104.114.84.95
(edit) @205d5645   01/03/00 16:44:04 Joel Sherrill Patch from John Mills <jmills@…> to correct some cut and paste … 4.104.114.84.95
(edit) @6b7cf9f   01/03/00 15:39:06 Joel Sherrill Patch rtems-rc-19991203-12.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @b84176b   01/03/00 15:36:18 Joel Sherrill Do not explicitly list pieces from libcpu used. 4.104.114.84.95
(edit) @32f19fb3   01/03/00 14:38:47 Joel Sherrill Share align_h.S from ppc403. VPATH was not picking it up. Discovered … 4.104.114.84.95
(edit) @e07b6868   01/03/00 14:14:37 Joel Sherrill Added tm27 stuff. 4.104.114.84.95
(edit) @db941670   01/03/00 14:14:24 Joel Sherrill Added define to trip items that are private to tm27 in bsp.h. 4.104.114.84.95
(edit) @95273a6   01/03/00 14:06:42 Joel Sherrill Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric … 4.104.114.84.95
(edit) @d5c4681e   01/03/00 14:04:22 Joel Sherrill Use shared coverhd.h. 4.104.114.84.95
(edit) @20385957   01/03/00 14:01:02 Joel Sherrill Increased minimum stack size so all tests will run. 4.104.114.84.95
(edit) @6eb3e68   12/23/99 22:12:15 Jennifer.Averett + Tests added for mq_open, mq_close, and mq_unlink 4.104.114.84.95
(edit) @2e97c01   12/23/99 22:11:01 Jennifer.Averett + Added routine to remove from namespace. 4.104.114.84.95
(edit) @afebb3f   12/23/99 22:10:13 Jennifer.Averett + Added check for name greater than PATH_MAX 4.104.114.84.95
(edit) @7fbef786   12/23/99 22:09:36 Jennifer.Averett + Debugged. 4.104.114.84.95
(edit) @8f12d069   12/23/99 22:08:43 Jennifer.Averett + Filled in routine. 4.104.114.84.95
(edit) @96d4aea   12/23/99 22:07:43 Jennifer.Averett + Initial debug 4.104.114.84.95
(edit) @d4548d1   12/23/99 22:07:11 Jennifer.Averett + Made work + Added checks for valid attribute maxmsg and msgsize + … 4.104.114.84.95
(edit) @e1786ee3   12/23/99 22:05:25 Jennifer.Averett + Fixed errno response to match the POSIX manual. 4.104.114.84.95
(edit) @2116e33   12/21/99 20:29:57 Joel Sherrill Reverted the delay logic. 4.104.114.84.95
(edit) @ed46b47   12/21/99 20:29:40 Joel Sherrill Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to … 4.104.114.84.95
(edit) @56018097   12/21/99 20:28:13 Joel Sherrill Now use coverhd.h out of the libbsp/shared directory. 4.104.114.84.95
(edit) @0d6f0b4   12/21/99 20:10:04 Joel Sherrill Now use shared coverhd.h 4.104.114.84.95
(edit) @5d807b5   12/21/99 17:06:31 Joel Sherrill New files. 4.104.114.84.95
(edit) @a3ba9f98   12/21/99 17:05:15 Joel Sherrill New file. 4.104.114.84.95
(edit) @8437abd4   12/21/99 16:56:31 Joel Sherrill Removed as part of moving this driver to libchip. 4.104.114.84.95
(edit) @400c552   12/21/99 16:20:38 Joel Sherrill Removing Makefile.in and adding Makefile.am. These were missed in … 4.104.114.84.95
(edit) @fb16fed   12/21/99 15:25:05 Joel Sherrill Patch rtems-rc-19991203-10.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @9ba1f0a   12/21/99 15:04:48 Joel Sherrill Patch rtems-rc-19991203-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @369ef189   12/21/99 15:00:49 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @35d7b15   12/21/99 14:41:43 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @5bce35b   12/21/99 14:37:31 Joel Sherrill Made prototype of ChapReceiveSuccess? and ChapReceiveFailure? match. 4.104.114.84.95
(edit) @0fe48346   12/21/99 14:34:30 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @db3e0108   12/21/99 14:32:00 Joel Sherrill Patch rtems-rc-19991203-6.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @8b91282   12/21/99 14:27:52 Joel Sherrill Patch rtems-rc-19991203-5.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @3ad7602e   12/20/99 15:21:31 Joel Sherrill Modifications to avoid having the size of the Buffer_addresses array … 4.104.114.84.95
(edit) @947c27aa   12/16/99 14:30:34 Joel Sherrill Spelling error corrected. 4.104.114.84.95
(edit) @f09ac268   12/14/99 13:30:50 Joel Sherrill More warnings removed after email with Emmanuel Raguet. 4.104.114.84.95
(edit) @e8918ec   12/13/99 22:12:03 Joel Sherrill Patch from Eric Norum <eric@…> to change to gen68360 clock … 4.104.114.84.95
(edit) @c629812   12/13/99 22:10:45 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @da8ae79b   12/13/99 21:21:31 Joel Sherrill Warning removal patch from Philip A. Prindeville <philipp@…>. 4.104.114.84.95
(edit) @1c98d28   12/13/99 20:35:09 Joel Sherrill Patch rtems-19991203.sh2.diff from John M. Mills <jmills@…> … 4.104.114.84.95
(edit) @f9669ce5   12/13/99 20:06:27 Joel Sherrill Patch from Silverio Diquigiovanni <silverio.di@…> to correct TPC … 4.104.114.84.95
(edit) @fc0b91c   12/13/99 19:20:38 Joel Sherrill Patch from Eric Norum <eric@…> to make the NTP handler a … 4.104.114.84.95
(edit) @5dae90a   12/13/99 17:37:25 Joel Sherrill Patch rtems-rc-19991203-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @6b79a071   12/13/99 17:22:18 Joel Sherrill Patch from Jepsen Hans Peter <hans_peter_jepsen@…> to use … 4.104.114.84.95
(edit) @809f4451   12/13/99 17:03:37 Joel Sherrill Correction from Eric Norum for timeout in TFTP driver following bug … 4.104.114.84.95
(edit) @9537e5e   12/13/99 16:29:01 Joel Sherrill Patch from Eric Norum <eric@…> to provide more network … 4.104.114.84.95
(edit) @38b81b5   12/13/99 16:25:03 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to correct some … 4.104.114.84.95
(edit) @4bdebdfe   12/13/99 16:16:44 Joel Sherrill Patch rtems-rc-19991203-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @ad0c286   12/13/99 16:02:57 Joel Sherrill Patch rtems-rc-19991203-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @fa178d49   12/13/99 15:57:41 Joel Sherrill Patch rtems-rc-19991203-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @d16faa2   12/13/99 15:54:23 Joel Sherrill Patch rtems-rc-19991203-2.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @7d91d72   12/13/99 15:29:20 Joel Sherrill First attempt at adding simple binary semaphore in addition to the … 4.104.114.84.95
(edit) @e9067989   12/13/99 14:50:09 Joel Sherrill Corrected order of output. 4.104.114.84.95
(edit) @d9230ea   12/13/99 14:49:38 Joel Sherrill Added RTEMS_IO_ERROR. 4.104.114.84.95
(edit) @49be66d   12/13/99 14:48:58 Joel Sherrill Now builds and installs properly. 4.104.114.84.95
(edit) @39e6bbe1   12/06/99 13:44:56 Joel Sherrill Patch patches-rc-19991203-1.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @a548c8a5   12/03/99 16:00:51 Joel Sherrill New file. 4.104.114.84.95
(edit) @76c356f   12/03/99 15:46:17 Joel Sherrill Patch from Aleksey (Quality Quorum <qqi@…>) to change the … 4.104.114.84.95
(edit) @1e4a7d4   12/03/99 15:44:28 Joel Sherrill Modem example driver for ppp by Tomasz Domin <dot@…> of … 4.104.114.84.95
(edit) @a1efd7a   12/03/99 14:48:27 Joel Sherrill Made to compile on other CPU families. 4.104.114.84.95
(edit) @ae252c9   12/03/99 14:27:54 Joel Sherrill Added dec21140 to Makefile.am. 4.104.114.84.95
