Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @45fecbb6   06/16/13 13:40:03 Jiri Gaisler greth: do not advertise 1000M capability if MAC does not support it. 4.115
(edit) @1bdc6d1   06/16/13 13:28:20 Jiri Gaisler greth: prefer full duplex if available 4.115
(edit) @cb6b9ba   06/19/13 10:57:54 Sebastian Huber bsp/xilinx-zynq: Use magic UART baud divisor Use a baud divisor … 4.115
(edit) @3f6a823   06/19/13 10:57:26 Sebastian Huber bsp/xilinx-zynq: Do not start transmitter break 4.115
(edit) @49bc9f81   06/18/13 07:18:21 Sebastian Huber bsp/xilinx-zynq: Use second UART for console This is in now line with … 4.115
(edit) @cf46db85   06/17/13 07:57:42 Sebastian Huber bsps: Provide simple console selection 4.115
(edit) @9f868a16   06/17/13 07:57:08 Sebastian Huber bsps: Add missing include 4.115
(edit) @edde99b   06/14/13 12:26:34 Sebastian Huber score: Rename rtems_smp_get_number_of_processors() Rename in … 4.115
(edit) @49cdf40   06/12/13 07:25:39 Sebastian Huber score: Add and use _Thread_Dispatch_is_enabled() Delete … 4.115
(edit) @15f3a91   06/10/13 12:11:07 Sebastian Huber libchip: Use Termios API change for NS16550 This avoids a race … 4.115
(edit) @6896ca2   06/10/13 12:07:13 Sebastian Huber libchip: Delete superfluous assignments 4.115
(edit) @aec0e195   06/10/13 08:10:43 Sebastian Huber configure: Documentation 4.115
(edit) @18e2fbe7   06/07/13 09:50:37 Sebastian Huber smp: Fix PowerPC context switch 4.115
(edit) @8bed603   06/03/13 08:03:44 Sebastian Huber bsp/lm3s69xx: Typos 4.115
(edit) @94c17af   06/03/13 08:03:10 Sebastian Huber bsp/qoriq: Add missing #ifdef RTEMS_SMP 4.115
(edit) @db42c079   05/31/13 11:59:47 Sebastian Huber bsps/arm: Add SMP support 4.115
(edit) @f2f211c5   05/31/13 11:59:34 Sebastian Huber smp: Add ARM support 4.115
(edit) @bd39add   05/31/13 08:08:43 Sebastian Huber bsp/qoriq: Add SMP support 4.115
(edit) @ffbeb6f   01/18/13 08:42:49 Sebastian Huber smp: Add PowerPC support 4.115
(edit) @e3be6915   05/27/13 15:31:46 Sebastian Huber score: Remove idle field of Per_CPU_Control This field is unused … 4.115
(edit) @17e09f8e   05/27/13 15:29:47 Sebastian Huber bsps: Use _Objects_Information_table Eliminate copy and paste. Use … 4.115
(edit) @5b391f85   05/31/13 08:00:07 Sebastian Huber bsps/arm: Use Write-Allocate cache for ARMv7 4.115
(edit) @1dcf5fe   05/31/13 07:59:27 Sebastian Huber bsps/arm: Merge ARMv7 MMU section definitions 4.115
(edit) @2f6108f9   05/28/13 08:58:19 Sebastian Huber smp: Simplify SMP initialization sequence Delete bsp_smp_wait_for(). … 4.115
(edit) @8cacceb   05/14/13 11:23:10 Sebastian Huber smp: Delete bsp_smp_secondary_cpu_initialize() Do not call … 4.115
(edit) @baf8f4d   05/14/13 08:12:52 Sebastian Huber smp: Simplify main CPU initialization Call _SMP_Handler_initialize() … 4.115
(edit) @9344677   05/21/13 13:58:12 Sebastian Huber bsp/qoriq: Avoid NULL pointer access 4.115
(edit) @9984acd   05/13/13 07:42:51 Sebastian Huber bsps/arm: Add CLOCK_DRIVER_USE_FAST_IDLE option 4.115
(edit) @0d671d70   05/27/13 10:43:53 Sebastian Huber bsps/arm: Move .fast_text section Move the .fast_text section after … 4.115
(edit) @cab410f   05/21/13 12:19:24 Sebastian Huber bsps: Update due to linker changes In case the VMA and LMA regions … 4.115
(edit) @6c2eedc   05/13/13 11:37:06 Sebastian Huber smp: Add maximum_processors field to config Delete … 4.115
(edit) @5e45d36   05/15/13 15:46:37 dchabot Add c++ guard to header. 4.115
(edit) @cfd8d7a   05/08/13 07:30:31 Sebastian Huber arm: Support VFP-D32 and Neon 4.115
(edit) @a94d46c8   05/06/13 12:34:55 Sebastian Huber bsp/xilinx-zynq: New BSP 4.115
(edit) @12d182c4   05/06/13 12:01:10 Sebastian Huber bsps/arm: Fix register usage 4.115
(edit) @e37d57bc   05/06/13 08:59:07 Sebastian Huber bsps/arm: Add shared GIC tmtests/tm27 support 4.115
(edit) @33c98fd   05/06/13 08:20:26 Sebastian Huber bsps/arm: Remove superfluous parameter 4.115
(edit) @f2e9d0d   05/06/13 07:59:16 Sebastian Huber bsp/raspberrypi: Use shared start code 4.115
(edit) @86b79fb   05/06/13 07:54:02 Sebastian Huber bsp/lm3s69xx: Fix initialization value 4.115
(edit) @9bc1913e   05/05/13 22:02:07 eugen bsp/lm3s69xx: Use interrupts for UART receive This makes continuous … 4.115
(edit) @847e2cac   05/05/13 22:02:06 eugen bsp/lm3s69xx: More access macros for UART data register Add mask for … 4.115
(edit) @9159711   05/06/13 07:37:12 alan.cudmore bsp/raspberrypi: Enable unaligned access 4.115
(edit) @a91dc98b   04/26/13 13:06:32 Sebastian Huber bsp/realview-pbx-a9: New BSP 4.115
(edit) @9ce65803   05/02/13 11:37:30 Sebastian Huber bsps/arm: Copy vector table only if necessary 4.115
(edit) @27690ec3   05/02/13 11:36:03 Sebastian Huber bsps/arm: Move .vector section The .vector section contains … 4.115
(edit) @ecf7dd9   05/02/13 09:41:22 Sebastian Huber bsps/arm: Move CP15 start initialization 4.115
(edit) @fd51f7e   05/02/13 09:09:24 Sebastian Huber bsps/arm: Support ARMv7 VMSA sections and control 4.115
(edit) @88cf23f8   04/30/13 13:23:45 Sebastian Huber bsps/arm: Add arm_cp15_set_exception_handler() 4.115
(edit) @037e8ae5   05/02/13 15:42:20 Sebastian Huber bsps/arm: Add arm_cp15_set_trans*_table_entries() 4.115
(edit) @544615d   05/02/13 15:41:11 Sebastian Huber bsps/arm: Add arm_cp15_mmu_disable() 4.115
(edit) @d2d02961   05/02/13 15:40:45 Sebastian Huber bsps/arm: Add arm_cp15_get_min_cache_line_size() 4.115
(edit) @962e0fac   05/02/13 09:18:09 Sebastian Huber bsps/arm: Add and use bsp_translation_table_base 4.115
(edit) @fb0584f   05/03/13 08:39:26 Sebastian Huber bsps/arm: Move implementation to inline functions 4.115
(edit) @5aa4ed9   04/30/13 17:31:29 Joel Sherrill i386: PR2010: Remove pc386 BSPs using soft-float i386 soft-float is … 4.115
(edit) @024a572   04/29/13 07:28:58 Sebastian Huber bsp/mpc55xx: Avoid empty enum 4.115
(edit) @f22bba3   04/26/13 09:03:59 eugen bsp/lm3s69xx: New BSP variants Add support for LM3S3749. 4.115
(edit) @5fa0e5c5   04/24/13 12:37:50 Sebastian Huber libcsupport: Rename open_dev_console() Rename open_dev_console() to … 4.115
(edit) @a290fbe9   04/24/13 12:30:42 Sebastian Huber libcsupport: Make LibIO helper const Add and use rtems_libio_helper … 4.115
(edit) @62aa318   04/25/13 13:21:35 Sebastian Huber bsp/mpc55xx: Add MMU tag translate initializer 4.115
(edit) @92d8038   04/19/13 09:53:07 Sebastian Huber bsp/mpc5200: New BSP variant BRS6L 4.115
(edit) @7a44d06   04/19/13 12:17:09 Sebastian Huber bsp/mpc5200: Change SDRAM initialization Change SDRAM initialization … 4.115
(edit) @d4a4811   04/19/13 12:01:47 Sebastian Huber bsp/mpc5200: Set SDELAY register 4.115
(edit) @dbe6aae7   04/19/13 11:51:54 Sebastian Huber bsp/mpc5200: Move CSBOOTROM_VAL definition 4.115
(edit) @e79e904   04/19/13 11:50:34 Sebastian Huber bsp/mpc5200: Move comment 4.115
(edit) @6c094da   04/19/13 11:48:48 Sebastian Huber bsp/mpc5200: Change ADREN register defines 4.115
(edit) @2793778   04/19/13 11:00:14 Sebastian Huber bsp/mpc5200: Remove Erratum 342/339 comment 4.115
(edit) @be04e62   04/19/13 10:51:57 Sebastian Huber bsp/mpc5200: Set XLB timeout values 4.115
(edit) @5e920ceb   04/19/13 10:50:10 Sebastian Huber bsp/mpc5200: Do not initialize debug registers 4.115
(edit) @740abbd   04/17/13 13:57:20 Sebastian Huber bsp/mpc5200: Add and use enable_bat_4_to_7() 4.115
(edit) @d5587f9f   04/17/13 14:03:03 Sebastian Huber bsp/mpc5200: Fix cache handling 4.115
(edit) @47fb2fe   04/11/13 15:22:02 Sebastian Huber bsp/mpc5200: Add MPC5200_BOARD prefix 4.115
(edit) @76de8a8e   04/17/13 12:54:05 van.freenix D-cache clean&&invalidate for Tiny6410 4.115
(edit) @ef8e851   04/17/13 13:45:52 Sebastian Huber bsp/mpc55xx: Typo 4.115
(edit) @db21e1d   04/03/13 10:05:49 Sebastian Huber bsp/mpc55xx: eDMA API changes 4.115
(edit) @4e3deaf7   04/05/13 13:57:19 Sebastian Huber bsp/mpc55xx: Add alternative register layout 4.115
(edit) @db0ed4c5   04/08/13 08:43:42 Sebastian Huber bsp/mpc55xx: Add PCR index enumeration 4.115
(edit) @7806a2b5   04/05/13 14:05:30 Sebastian Huber bsp/mpc55xx: New define MPC55XX_PERIPHERAL_CLOCK 4.115
(edit) @15c7657   04/05/13 14:05:03 Sebastian Huber bsp/mpc55xx: Rename BSP option 4.115
(edit) @30158371   04/03/13 10:10:25 Sebastian Huber bsp/mpc55xx: New fatal errors 4.115
(edit) @055f1f4c   04/08/13 13:21:37 Sebastian Huber bsp/mpc55xx: Include <bsp/linker-symbols.h> 4.115
(edit) @087a29b4   04/08/13 14:13:18 Sebastian Huber bsp/mpc55xx: Fix warnings 4.115
(edit) @65cd5e9   04/08/13 14:12:20 Sebastian Huber libchip/serial: Fix warnings 4.115
(edit) @ab49921   04/08/13 14:13:02 Sebastian Huber bsps: Fix warnings 4.115
(edit) @602d5ba   04/08/13 14:11:02 Sebastian Huber bsps: Fix warnings 4.115
(edit) @5ab9b13   04/08/13 07:45:45 Sebastian Huber bsps/powerpc: Use proper type 4.115
(edit) @166d78f   04/08/13 07:45:09 Sebastian Huber bsp/gen5200: Fix syntax 4.115
(edit) @39586f6   04/03/13 04:24:32 Sebastian Huber bsp/lpc24xx: Fix register address 4.115
(edit) @dea6fb6   04/02/13 14:01:05 Sebastian Huber bsp/gen5200: Typo 4.115
(edit) @0841c07   04/02/13 13:58:40 Sebastian Huber bsp/gen5200: Elaborate option help message 4.115
(edit) @fa77ad4b   04/02/13 13:50:23 Sebastian Huber bsp/gen5200: Remove superfluous option definition 4.115
(edit) @aa11df6   03/28/13 08:25:07 Sebastian Huber bsp/gen5200: Use busy wait The usage of rtems_task_wake_after() is … 4.115
(edit) @d1e1df68   03/28/13 08:24:11 Sebastian Huber bsp/gen5200: Use fatal error instead of assert 4.115
(edit) @8ac62c4   03/26/13 15:01:10 Sebastian Huber bsps/arm: Add thread-local storage (TLS) sections 4.115
(edit) @c32b1ef   03/23/13 18:13:07 alan.cudmore bsp/raspberrypi: New BSP 4.115
(edit) @7b14e8b   03/21/13 09:46:03 Sebastian Huber bsp/mpc83xx: Add MPC83XX_NET*_INTERFACE_0_PHY_ADDR 4.115
(edit) @6457fb29   03/19/13 09:12:06 Sebastian Huber bsp/psim: Use shared linkcmds.base Several GCC tests faild due to the … 4.115
(edit) @df6818f9   03/18/13 14:24:00 Sebastian Huber bsps: Support DWARF extension 4.115
(edit) @c2015b44   03/14/13 10:54:31 Sebastian Huber bsp/edb7312: Improve output char The output char function used by … 4.115
(edit) @df3f0226   03/14/13 10:45:44 Sebastian Huber bsp/edb7312: Fix warnings 4.115
(edit) @faad192   03/11/13 16:54:34 Sebastian Huber mpc83xx: Add and use mpc83xx_reset() The inline version makes it … 4.115
