Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @39234725   07/17/13 06:42:35 Ric Claus bsps/arm: Fix for top of the address space 4.115
(edit) @691e0ef   07/13/13 20:58:27 Ric Claus bsp/xilinx-zynq: Provide BSP variants 4.115
(edit) @51a58e0   07/16/13 12:40:19 Sebastian Huber bsp/xilinx-zynq: Use bsp_console_select() 4.115
(edit) @7306578   07/16/13 12:39:59 Sebastian Huber bsps/serial: Move bsp_console_select() declaration 4.115
(edit) @3ccaf3c   07/16/13 15:18:18 Sebastian Huber bsps: Use rtems_task_self() 4.115
(edit) @85d2e4b   07/16/13 15:11:51 Sebastian Huber libchip/ata: Remove dead code 4.115
(edit) @ad4ce28   07/15/13 12:39:28 Vipul Nayyar Updated legacy code in arm edb7312 4.115
(edit) @06adfae   07/15/13 07:52:45 Sebastian Huber bsps/arm: Disable alignment exceptions 4.115
(edit) @c8d78ee   07/02/13 08:37:13 Sebastian Huber bsp/mpc55xx: Add MPC5668G support 4.115
(edit) @583eb458   07/15/13 09:34:45 Vipul Nayyar bsp/rtl22xx: Use IRQ extensions API 4.115
(edit) @163e88a   07/12/13 17:03:57 Vipul Nayyar bsp/gumstix: Fix warnings 4.115
(edit) @9b6add4   07/12/13 11:34:17 Vipul Nayyar Updated Legacy code in arm gba 4.115
(edit) @5252822   07/11/13 08:06:35 Sebastian Huber bsps: Simplify bsp_generic_fatal() declaration 4.115
(edit) @79363a1   07/10/13 17:38:12 Joel Sherrill libbsp/shared/generic-fatal.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE … 4.115
(edit) @e183211b   07/10/13 14:57:24 Vipul Nayyar Updated Legacy code in arm gumstix 4.115
(edit) @893d669   07/10/13 14:52:28 Vipul Nayyar Updated Legacy code in arm edb7312 4.115
(edit) @26c093e   07/10/13 12:36:50 Sebastian Huber bsp/virtex: Use #if instead of #ifdef This allows … 4.115
(edit) @52e44630   07/10/13 07:54:01 Vipul Nayyar bsp/csb336: Use IRQ extensions API Fix warnings. 4.115
(edit) @48a22ed   07/09/13 16:15:57 Joel Sherrill libchip ns16550.c: Improve comment 4.115
(edit) @0a697dd9   07/09/13 09:24:27 Sebastian Huber bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS Add interrupt support … 4.115
(edit) @d168079   07/09/13 14:38:03 Sebastian Huber bsp/virtex: Use ppc_count_leading_zeros() Use … 4.115
(edit) @296b60d7   07/09/13 14:04:04 Sebastian Huber bsp/virtex: Fix interrupt handling Some modules like the XPS UART … 4.115
(edit) @4fe3ad2   07/09/13 14:37:32 Sebastian Huber bsps/powerpc: Add ppc_count_leading_zeros() 4.115
(edit) @6886a485   07/07/13 13:00:45 Vipul Nayyar bsp/csb337: Use IRQ extensions API Fix warnings. 4.115
(edit) @ad83ea0   07/07/13 12:43:17 Sebastian Huber mouse: Add shared bsp_get_serial_mouse_device() 4.115
(edit) @818edbd   07/02/13 13:16:33 Sebastian Huber bsp/mpc55xx: Update due to API changes Termios notifies now the … 4.115
(edit) @d91d50f   07/02/13 13:14:51 Sebastian Huber bsp/mpc55xx: Avoid integer overflow 4.115
(edit) @c97d3dd   07/02/13 13:13:54 Sebastian Huber bsp/mpc55xx: Round PLL divider up 4.115
(edit) @cd7db89   06/24/13 15:14:08 ralf.kirchner bsp/psim: Use EABI and System V small-data area 4.115
(edit) @3da02169   06/24/13 15:16:16 ralf.kirchner bsps/powerpc: Avoid placement in small-data area 4.115
(edit) @1b47871d   06/24/13 15:15:42 ralf.kirchner bsp/psim: Fix declaration It declares a symbol defined in the linker … 4.115
(edit) @3b645c1   06/28/13 19:26:59 Sebastian Huber bsps/arm: Add PL050 support 4.115
(edit) @c8312b3   06/23/13 12:39:47 Sebastian Huber bsps/arm: Add PL111 support 4.115
(edit) @e310dcd   06/28/13 19:26:11 Sebastian Huber libchip/serial: Add const qualifier 4.115
(edit) @311ba73   06/23/13 15:50:55 Sebastian Huber framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME 4.115
(edit) @98db96e   06/29/13 12:00:39 Sebastian Huber make: Use C flags for C++ as default In case a BSP selects special … 4.115
(edit) @40ce265   06/28/13 13:05:30 Sebastian Huber bsp/psim: Use plain symbol for PSIM This avoids a linker assertion … 4.115
(edit) @4800ffe   06/28/13 07:07:13 Sebastian Huber bsps/powerpc: Update debug sections 4.115
(edit) @ca59217   06/28/13 07:03:11 Sebastian Huber bsps/arm: Set vector base on all processors 4.115
(edit) @a3a4cd5   06/26/13 07:40:44 Sebastian Huber bsps/arm: Move input sections Move input sections to preserve order … 4.115
(edit) @56435e6   06/26/13 08:25:42 Sebastian Huber powerpc: Fix Altivec support Use the right context. 4.115
(edit) @4b83e8f1   06/21/13 07:59:27 Sebastian Huber bsps/arm: Fix set exception handler for ARMv7 4.115
(edit) @e18db9f   06/24/13 15:29:11 Sebastian Huber termios: Update due to API changes Termios notifies now the driver … 4.115
(edit) @1df348b   06/24/13 09:00:36 Sebastian Huber bsps/arm: Rename function Rename … 4.115
(edit) @e916b125   06/21/13 15:17:28 Sebastian Huber bsp/virtex: Use shared clock driver 4.115
(edit) @0110491   06/20/13 14:22:16 Sebastian Huber bsp/virtex: Add console devices only if present 4.115
(edit) @dbf62b3   06/20/13 14:20:43 Sebastian Huber bsp/virtex: Fix warnings 4.115
(edit) @c4cfc62   06/20/13 12:33:19 Sebastian Huber bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR This define is also present … 4.115
(edit) @dfb5805   06/20/13 12:32:12 Sebastian Huber bsp/virtex: Remove unused configure macros 4.115
(edit) @53dc697   06/18/13 14:42:25 Sebastian Huber bsp/virtex: Delete BSP_ask_for_reset and BSP_panic 4.115
(edit) @39c1534f   06/18/13 15:20:28 Sebastian Huber bsp/virtex: Use generic interrupt support 4.115
(edit) @894e93f   06/18/13 14:44:40 Sebastian Huber bsp/virtex: Fix header includes 4.115
(edit) @bee7612e   06/18/13 14:39:24 Sebastian Huber bsp/virtex: Move timer config to new file 4.115
(edit) @48ab8465   06/18/13 14:27:42 Sebastian Huber bsp/virtex: Do not use PPC403 TTY driver 4.115
(edit) @ad094f4   06/18/13 14:26:25 Sebastian Huber bsp/virtex: Fix warnings 4.115
(edit) @b45397fb   06/18/13 14:25:53 Sebastian Huber bsp/virtex: Delete bsp_XAssertHandler() 4.115
(edit) @ff538bbf   06/18/13 14:24:10 Sebastian Huber bsp/virtex: Delete unused variables 4.115
(edit) @0ba2736   06/18/13 14:12:56 Sebastian Huber bsp/virtex: Replace low-level BSP start code Use linkcmds.base. Use … 4.115
(edit) @546c1056   06/18/13 13:19:19 Sebastian Huber bsp/virtex: Rename file dlentry.S in start.S Use default bsp_specs file. 4.115
(edit) @509e0f3f   06/21/13 15:16:37 Sebastian Huber bsps/powerpc: Add PPC405 support for shared clock 4.115
(edit) @7d0e88f2   06/21/13 14:19:46 Sebastian Huber bsps/powerpc: Delete clock_4xx.c 4.115
(edit) @27b207a8   06/21/13 13:10:48 Sebastian Huber bsps: Delete bspreset_fatal.c Use bspreset_loop.c instead. This … 4.115
(edit) @f97f46ce   06/20/13 09:03:45 Sebastian Huber libchip/serial: Fix warning 4.115
(edit) @c9db7f9   06/18/13 15:47:41 Sebastian Huber bsps: Use CONSOLE_DEVICE_NAME 4.115
(edit) @a4bc725e   06/18/13 15:45:50 Sebastian Huber bsps: Remove debug output in shared console driver 4.115
(edit) @37220fac   06/20/13 10:00:29 Sebastian Huber bsps: Do not use printk() in shared console driver 4.115
(edit) @6307b1a   06/20/13 09:57:34 Sebastian Huber bsps: Add fatal errors for shared console driver 4.115
(edit) @ade27c6   06/20/13 09:44:04 Sebastian Huber bsps: Move bsp_generic_fatal_code to new file Add bsp_generic_fatal(). 4.115
(edit) @5f91272   06/20/13 09:17:23 Sebastian Huber bsps/powerpc: Delete bsp_exceptions_in_RAM Delete … 4.115
(edit) @cddb8f4   06/20/13 07:48:27 Ric Claus bsps/arm: Fix some GIC functions 4.115
(edit) @9a037da9   06/19/13 09:20:06 Sebastian Huber bsps/arm: Set vector base address if necessary 4.115
(edit) @45fecbb6   06/16/13 13:40:03 Jiri Gaisler greth: do not advertise 1000M capability if MAC does not support it. 4.115
(edit) @1bdc6d1   06/16/13 13:28:20 Jiri Gaisler greth: prefer full duplex if available 4.115
(edit) @cb6b9ba   06/19/13 10:57:54 Sebastian Huber bsp/xilinx-zynq: Use magic UART baud divisor Use a baud divisor … 4.115
(edit) @3f6a823   06/19/13 10:57:26 Sebastian Huber bsp/xilinx-zynq: Do not start transmitter break 4.115
(edit) @49bc9f81   06/18/13 07:18:21 Sebastian Huber bsp/xilinx-zynq: Use second UART for console This is in now line with … 4.115
(edit) @cf46db85   06/17/13 07:57:42 Sebastian Huber bsps: Provide simple console selection 4.115
(edit) @9f868a16   06/17/13 07:57:08 Sebastian Huber bsps: Add missing include 4.115
(edit) @edde99b   06/14/13 12:26:34 Sebastian Huber score: Rename rtems_smp_get_number_of_processors() Rename in … 4.115
(edit) @49cdf40   06/12/13 07:25:39 Sebastian Huber score: Add and use _Thread_Dispatch_is_enabled() Delete … 4.115
(edit) @15f3a91   06/10/13 12:11:07 Sebastian Huber libchip: Use Termios API change for NS16550 This avoids a race … 4.115
(edit) @6896ca2   06/10/13 12:07:13 Sebastian Huber libchip: Delete superfluous assignments 4.115
(edit) @aec0e195   06/10/13 08:10:43 Sebastian Huber configure: Documentation 4.115
(edit) @18e2fbe7   06/07/13 09:50:37 Sebastian Huber smp: Fix PowerPC context switch 4.115
(edit) @8bed603   06/03/13 08:03:44 Sebastian Huber bsp/lm3s69xx: Typos 4.115
(edit) @94c17af   06/03/13 08:03:10 Sebastian Huber bsp/qoriq: Add missing #ifdef RTEMS_SMP 4.115
(edit) @db42c079   05/31/13 11:59:47 Sebastian Huber bsps/arm: Add SMP support 4.115
(edit) @f2f211c5   05/31/13 11:59:34 Sebastian Huber smp: Add ARM support 4.115
(edit) @bd39add   05/31/13 08:08:43 Sebastian Huber bsp/qoriq: Add SMP support 4.115
(edit) @ffbeb6f   01/18/13 08:42:49 Sebastian Huber smp: Add PowerPC support 4.115
(edit) @e3be6915   05/27/13 15:31:46 Sebastian Huber score: Remove idle field of Per_CPU_Control This field is unused … 4.115
(edit) @17e09f8e   05/27/13 15:29:47 Sebastian Huber bsps: Use _Objects_Information_table Eliminate copy and paste. Use … 4.115
(edit) @5b391f85   05/31/13 08:00:07 Sebastian Huber bsps/arm: Use Write-Allocate cache for ARMv7 4.115
(edit) @1dcf5fe   05/31/13 07:59:27 Sebastian Huber bsps/arm: Merge ARMv7 MMU section definitions 4.115
(edit) @2f6108f9   05/28/13 08:58:19 Sebastian Huber smp: Simplify SMP initialization sequence Delete bsp_smp_wait_for(). … 4.115
(edit) @8cacceb   05/14/13 11:23:10 Sebastian Huber smp: Delete bsp_smp_secondary_cpu_initialize() Do not call … 4.115
(edit) @baf8f4d   05/14/13 08:12:52 Sebastian Huber smp: Simplify main CPU initialization Call _SMP_Handler_initialize() … 4.115
(edit) @9344677   05/21/13 13:58:12 Sebastian Huber bsp/qoriq: Avoid NULL pointer access 4.115
(edit) @9984acd   05/13/13 07:42:51 Sebastian Huber bsps/arm: Add CLOCK_DRIVER_USE_FAST_IDLE option 4.115
(edit) @0d671d70   05/27/13 10:43:53 Sebastian Huber bsps/arm: Move .fast_text section Move the .fast_text section after … 4.115
