@2a333f9
05/27/99 15:46:34 |
Joel Sherrill |
Disabled running size_rtems until all file splitting is finished.
4.104.114.84.95
@7398901
05/27/99 15:46:00 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@326378bf
05/27/99 15:44:20 |
Joel Sherrill |
Corrected so rtems.o is built and installed on all targets.
4.104.114.84.95
@82d11f87
05/27/99 15:43:32 |
Joel Sherrill |
Corrected macro names.
4.104.114.84.95
@da47e4a9
05/26/99 14:00:48 |
Joel Sherrill |
Initiated updating this to reflect split up.
4.104.114.84.95
@0aeda88
05/20/99 16:16:44 |
Joel Sherrill |
Renamed to rtemstimer.c to avoid conflict with timer drivers in EVERY …
4.104.114.84.95
@8bbaf3b
05/20/99 13:32:54 |
Joel Sherrill |
Removed all post 4.0 changes.
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@fbec4a1
05/18/99 17:33:52 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@0090c1a
05/18/99 17:31:27 |
Joel Sherrill |
Spacing correction.
4.104.114.84.95
@0995b6f
05/17/99 23:48:34 |
Joel Sherrill |
Reworked to avoid pulling in the jump point entry in EVERY executable.
4.104.114.84.95
@9180f63
05/17/99 23:26:50 |
Joel Sherrill |
Fixed some typos.
4.104.114.84.95
@c9973bb
05/17/99 23:22:45 |
Joel Sherrill |
Split Interrupt Manager into one routine per file.
4.104.114.84.95
@0123e3b
05/17/99 23:20:52 |
Joel Sherrill |
Split Signal Manager into one routine per file.
4.104.114.84.95
@1dc030f
05/17/99 23:18:20 |
Joel Sherrill |
Dual-Ported Memory Manager split into one routine per file.
4.104.114.84.95
@842db5f3
05/17/99 23:15:20 |
Joel Sherrill |
Split Partition Manager into one routine per file.
4.104.114.84.95
@be47df9
05/17/99 23:10:36 |
Joel Sherrill |
Split Timer Manager into one routine per file.
4.104.114.84.95
@cc2bc302
05/17/99 23:06:03 |
Joel Sherrill |
Split Event Manager into one routine per file.
4.104.114.84.95
@5f9b3db
05/17/99 23:03:07 |
Joel Sherrill |
Split Rate Monotonic Manager into one routine per file.
4.104.114.84.95
@c06d8f64
05/17/99 22:58:30 |
Joel Sherrill |
Split the Semaphore Manager into one routine per file.
4.104.114.84.95
@a2d0f39
05/17/99 22:56:13 |
Joel Sherrill |
Moved some MP routines to semmp.c.
4.104.114.84.95
@3270ca6
05/17/99 22:53:34 |
Joel Sherrill |
Forgot to actually remove the routines. :)
4.104.114.84.95
@1e1b3e00
05/17/99 22:52:59 |
Joel Sherrill |
Split Message Manager into one routine per file.
4.104.114.84.95
@ef22ab2
05/17/99 22:46:01 |
Joel Sherrill |
Moved an MP routine from msg.c to here.
4.104.114.84.95
@86cb89f
05/17/99 22:45:47 |
Joel Sherrill |
Cleaned up some multiprocessing issues.
4.104.114.84.95
@bd83f47
05/17/99 22:42:47 |
Joel Sherrill |
Split Clock Manager into one routine per file.
4.104.114.84.95
@5aa64518
05/17/99 22:39:20 |
Joel Sherrill |
Split Region Manager into one routine per file.
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@2f831ac
05/17/99 22:16:52 |
Joel Sherrill |
Moved _Entry_Table to its own file to avoid having every RTEMS …
4.104.114.84.95
@d7851582
05/17/99 22:15:56 |
Joel Sherrill |
Added simple test to find minimum code size of executive with this BSP …
4.104.114.84.95
@c4d69e2
05/17/99 21:02:16 |
Joel Sherrill |
Split Task Manager into multiple files. Eventually this effort will …
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@a238cc9
05/17/99 15:45:15 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to remove compiler …
4.104.114.84.95
@577c4080
05/17/99 15:28:52 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…>:
Here's a tiny …
4.104.114.84.95
@fcf17a4
05/14/99 16:25:15 |
Joel Sherrill |
Added testing for C++ exceptions from Rosimildo DaSilva? …
4.104.114.84.95
@44dd8a61
05/14/99 16:23:42 |
Joel Sherrill |
Added 3COM 3C509 driver from Rosimildo DaSilva? <rdasilva@…>.
4.104.114.84.95
@c5881fc1
05/14/99 15:31:07 |
Joel Sherrill |
Enabled compilation of rtems_servers at request of Jake Janovetz …
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@4c5080ed
05/11/99 16:30:51 |
Joel Sherrill |
Fix based on bug report from Jay Kulpinski <jskulpin@…> …
4.104.114.84.95
@ddd22e5
05/11/99 15:15:03 |
Joel Sherrill |
Patch from Erik Ivanenko <erik.ivanenko@…> to correct 32 bit …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@07001360
05/07/99 16:31:08 |
Joel Sherrill |
Added rules to handle alternate suffixes for C++ files.
4.104.114.84.95
@acb644a6
05/07/99 16:30:44 |
Joel Sherrill |
Error reporting fixed by Jennifer.
4.104.114.84.95
@c34aaae7
05/07/99 16:29:54 |
Joel Sherrill |
Bug fix from Gunter Magin <magin@@skil.camelot.de>:
in …
4.104.114.84.95
@b06279d
05/07/99 16:28:43 |
Joel Sherrill |
Bug fix from Gunter Magin <magin@…>:
in …
4.104.114.84.95
@8846bbd
04/28/99 13:59:11 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
I have made …
4.104.114.84.95
@cfcb5a2
04/27/99 17:31:39 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to corrent a miscount in …
4.104.114.84.95
@c7aa9d6
04/26/99 18:22:08 |
Joel Sherrill |
Repairing damage and recovering changes including C++ wrappers..
4.104.114.84.95
@c8cfdcfe
04/26/99 18:04:46 |
Joel Sherrill |
Recovered changes since CVS file was corrupted.
4.104.114.84.95
@8b8204a1
04/26/99 17:35:57 |
Joel Sherrill |
changed version to 19990426
4.104.114.84.95
@0b28bd9c
04/23/99 16:37:54 |
Joel Sherrill |
changed version to 19990423
4.104.114.84.95
@16a384cf
04/23/99 16:35:11 |
Joel Sherrill |
New BSP from Tony R. Ambardar <tonya@…> from the
University …
4.104.114.84.95
@933388ae
04/22/99 21:13:23 |
Joel Sherrill |
Added lstat().
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
@4186b3b
04/19/99 17:17:41 |
Joel Sherrill |
Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease …
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@1059abcd
04/19/99 15:37:36 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@7807b30e
04/19/99 15:36:21 |
Joel Sherrill |
Direct .gcc_exc section to ram to eliminate the warning Ralf Corsepius …
4.104.114.84.95
@11f84b3c
04/19/99 15:27:20 |
Joel Sherrill |
After discussion with Eric Norum <eric@…>,
I added …
4.104.114.84.95
@7cdf7fc1
04/19/99 15:27:19 |
Joel Sherrill |
I added …
4.104.114.84.95
@db047f1
04/19/99 14:41:23 |
Joel Sherrill |
Patch from Erik Ivanenko <erik.ivanenko@…> to eliminate a …
4.104.114.84.95
@82307a11
04/19/99 13:25:50 |
Joel Sherrill |
New files.
4.104.114.84.95
@5dc30fb
04/19/99 13:20:15 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to add scitabs.c …
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
This one is …
4.104.114.84.95
@9572c41
04/19/99 13:11:13 |
Joel Sherrill |
This is an …
4.104.114.84.95
@60e6a0f
04/19/99 13:06:07 |
Joel Sherrill |
Fixed some spacing issues.
4.104.114.84.95
@6b7ab9bf
04/16/99 18:23:48 |
Joel Sherrill |
FYI: I am …
4.104.114.84.95
@c00fa38
04/16/99 18:17:31 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@@faw.uni-ulm.de>:
2) …
4.104.114.84.95
@98d051f
04/16/99 18:15:08 |
Joel Sherrill |
1) …
4.104.114.84.95
@4a22e7a
04/16/99 18:08:27 |
Joel Sherrill |
Corrected to reflect new way of doing mips constructors.
4.104.114.84.95
@2a4791f
04/16/99 18:08:09 |
Joel Sherrill |
Added .eh_fram and .gcc_exc sections.
4.104.114.84.95
@d006519b
04/15/99 19:01:32 |
Joel Sherrill |
Added reentrant versions.
4.104.114.84.95
@a68e6b9
04/15/99 18:58:43 |
Joel Sherrill |
Updated version string.
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
@93994fdb
04/15/99 18:57:31 |
Joel Sherrill |
Now compiles and is included in normal build even though it is …
4.104.114.84.95
@0f4e074
04/15/99 18:57:02 |
Joel Sherrill |
Cleaned up.
4.104.114.84.95
@3afecf8
04/15/99 18:56:42 |
Joel Sherrill |
Now compiles and is included in normal build even though it is untested.
4.104.114.84.95
@3090760
04/15/99 18:55:55 |
Joel Sherrill |
Now compile files that previously existed but were not built because …
4.104.114.84.95
@24a9af6
04/15/99 18:55:14 |
Joel Sherrill |
Now install header files that existed but were not previously installed.
4.104.114.84.95
@8a2943aa
04/15/99 18:54:40 |
Joel Sherrill |
Now install some header files that existed but were not previously …
4.104.114.84.95
@053acd70
04/15/99 18:54:16 |
Joel Sherrill |
Now install utsname.h.
4.104.114.84.95
@d0f53fe
04/15/99 18:54:01 |
Joel Sherrill |
Enabled cancellation information in POSIX API thread extension structure.
4.104.114.84.95
@02d46fa
04/15/99 18:53:35 |
Joel Sherrill |
Added set_errno_and_return_minus_one_cast.
4.104.114.84.95
@39daf58
04/15/99 18:53:22 |
Joel Sherrill |
Added in some header files that existed but were not previously installed.
4.104.114.84.95
@3c87bb9c
04/14/99 22:33:30 |
Joel Sherrill |
Minor corrections from Jay Kulpinski <jskulpin@…>.
4.104.114.84.95
@2b28307
04/14/99 18:18:03 |
Joel Sherrill |
Bug report from Ralf on UNIX port where the S_IR* constants were not …
4.104.114.84.95
@76e5fe8a
04/13/99 22:50:24 |
Joel Sherrill |
Bug fix from Brendan Simon <brendan@…> with fix …
4.104.114.84.95
@6e27f588
04/12/99 20:27:14 |
Joel Sherrill |
Installing of …
4.104.114.84.95
@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@8cdb582
04/12/99 15:41:33 |
Joel Sherrill |
This patch …
4.104.114.84.95
@d115315
04/12/99 15:36:07 |
Joel Sherrill |
Added line to initialize timer_max.
4.104.114.84.95
@63b96b9
04/12/99 15:21:43 |
Joel Sherrill |
Addressed this bug report:
Date: Mon, 12 Apr 1999 00:38:04 +0000 …
4.104.114.84.95
@5907192
04/07/99 20:56:47 |
Joel Sherrill |
changed version to 19990407
4.104.114.84.95
@3084de2
04/07/99 15:57:05 |
Joel Sherrill |
MPC821 support and PPC patches from Andrew Bray …
4.104.114.84.95
@3c0e80c3
04/06/99 22:07:36 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to preinstall
all …
4.104.114.84.95
@5cf555e1
04/06/99 22:04:08 |
Joel Sherrill |
Corrections by Jennifer.
4.104.114.84.95
@b08d3ed9
04/06/99 21:45:06 |
Joel Sherrill |
Untar support submitted by Jake Janovetz <janovetz@…>.
4.104.114.84.95
