@14d55deb
04/13/15 09:12:04 |
Daniel Hellstrom |
DRVMGR: renamed info_dev to get_info_dev
4.115
@246fe22
04/13/15 09:07:54 |
Daniel Hellstrom |
DRVMGR: change name of freq_get to get_freq
4.115
@4a7d1026
04/13/15 08:25:52 |
Daniel Hellstrom |
sparc bsps: updated license to rtems.org
4.115
@159ee990
04/07/15 14:05:04 |
Daniel Hellstrom |
leon3,ngmp: cpucounter initialization use proper names
To be merged …
4.115
@5564b5a
04/07/15 14:04:13 |
Daniel Hellstrom |
leon3: timer config updated to use proper naming
To be merged with …
4.115
@9b292ea
04/07/15 12:31:22 |
Daniel Hellstrom |
LEON: converted LEON4-N2X to BSD header
4.115
@8b29637c
04/07/15 12:31:07 |
Daniel Hellstrom |
LEON: converted PCI peripherals to BSD header
4.115
@d5ca821
04/07/15 12:28:29 |
Daniel Hellstrom |
LEON: converted AT697,GRPCi,GRPCI2,PCIF to BSD header
4.115
@5823bae8
02/27/15 13:03:15 |
Daniel Hellstrom |
LEON: move driver headers to bsp/ directory
4.115
@445e253
02/06/15 09:07:19 |
Daniel Hellstrom |
MCTRL: fix build warnings in MCTRL driver
4.115
@dbfa7c98
02/11/15 11:56:03 |
Daniel Hellstrom |
AMBAPP GRLIB: fix build warnings
4.115
@62fb1778
02/11/15 11:55:32 |
Daniel Hellstrom |
LEON2: fix build warnings
4.115
@43613a90
02/11/15 11:54:57 |
Daniel Hellstrom |
AMBAPP_BUS: fix build warnings
4.115
@56662f5c
02/11/15 11:52:14 |
Daniel Hellstrom |
LEON CONS: fix build warnings
4.115
@103bbde
02/11/15 11:50:35 |
Daniel Hellstrom |
GR-TMTC-1553: fix build warnings
4.115
@dd8abfc
02/11/15 11:40:17 |
Daniel Hellstrom |
GR-RASTA-TMTC: fix build warnings
4.115
@90fd587
02/11/15 11:39:40 |
Daniel Hellstrom |
GR-RASTA-SPW-ROUTER: fix build warnings
4.115
@960aebf
02/11/15 11:39:04 |
Daniel Hellstrom |
GR-RASTA-IO: fix build warnings
4.115
@03037b4
02/11/15 11:38:22 |
Daniel Hellstrom |
GR-RASTA-ADCDAC: fix build warnings
4.115
@ef7a009
02/11/15 11:37:28 |
Daniel Hellstrom |
GR-LEON4-N2X: fix build warnings
4.115
@05a45c79
02/11/15 11:36:50 |
Daniel Hellstrom |
GR_701: fix build warnings
4.115
@cb64b862
02/11/15 11:35:53 |
Daniel Hellstrom |
GRGPIO: fix buld warnings
4.115
@c39de3c4
02/11/15 11:35:36 |
Daniel Hellstrom |
GPIOLIB: fix build warnings
4.115
@7bc74ed
02/11/15 11:34:48 |
Daniel Hellstrom |
GRADCDAC: fix build warnings
4.115
@0355ad4
02/11/15 11:34:02 |
Daniel Hellstrom |
GENIRQ: fix build warnings
4.115
@9d05c6df
02/11/15 11:32:22 |
Daniel Hellstrom |
GRPWM: fix build warnings
4.115
@126b25d
02/11/15 11:31:26 |
Daniel Hellstrom |
SPWCUC: fix build warnings
4.115
@8c6c53d
02/11/15 11:27:05 |
Daniel Hellstrom |
SPICTRL: fix build warnings
4.115
@9b90342
02/11/15 11:23:45 |
Daniel Hellstrom |
GRSPW router: fix build warnings
4.115
@b6292a0b
02/11/15 11:23:04 |
Daniel Hellstrom |
GRSPW_PKT: fix build warnings
4.115
@fd7eaa2
02/11/15 08:40:15 |
Daniel Hellstrom |
TLIB: fix build warnings
4.115
@6048035
02/11/15 08:39:48 |
Daniel Hellstrom |
TLIB Clock: fix build warnings
4.115
@a93b3aa4
02/11/15 08:37:50 |
Daniel Hellstrom |
GRASCS: fix build warnings
4.115
@3823f5c
02/11/15 08:20:40 |
Daniel Hellstrom |
GRCTM: fix build warnings
4.115
@60d392b7
02/11/15 08:19:53 |
Daniel Hellstrom |
GRTM: fix build warnings
4.115
@e21a5b0
02/11/15 08:18:53 |
Daniel Hellstrom |
GRTC: fix build warnings
4.115
@6657a3d
02/10/15 15:33:16 |
Daniel Hellstrom |
LEON: GRPCI2 driver warning fixes
4.115
@48191662
02/10/15 15:29:39 |
Daniel Hellstrom |
LEON: I2CMST driver warnings fixes
4.115
@c9f75435
02/10/15 15:28:55 |
Daniel Hellstrom |
LEON: OCCAN driver warnings fixes
4.115
@be815e78
02/10/15 15:28:19 |
Daniel Hellstrom |
LEON: B1553BRM driver warnings fixes
4.115
@44e514f
02/10/15 15:28:03 |
Daniel Hellstrom |
LEON: B1553RT driver warnings fixes
4.115
@3f38335b
02/10/15 15:05:38 |
Daniel Hellstrom |
LEON: added get_resarray_count() helper routine
4.115
@b787bead
02/10/15 08:23:48 |
Daniel Hellstrom |
GR1553B: fixed build warnings
4.115
@05ce8bd5
02/10/15 07:32:42 |
Daniel Hellstrom |
AT697PCI: fix build warnings
4.115
@e3c9937
02/18/15 14:34:39 |
Daniel Hellstrom |
GPTIMER: move ISR install from init1
To avoid install ISRs during …
4.115
@f37a3c2
02/06/15 10:10:17 |
Daniel Hellstrom |
GPTIMER: fix build warnings
4.115
@7a03ac29
02/06/15 08:59:13 |
Daniel Hellstrom |
APBUART_CONS: fix build warning
4.115
@d77b16d
02/06/15 08:27:08 |
Daniel Hellstrom |
4.115
@28950f0b
02/05/15 13:35:33 |
Daniel Hellstrom |
PCIF: fixed build warnings
4.115
@f407c51
02/05/15 13:31:42 |
Daniel Hellstrom |
GRPCI: fixed build warnings
4.115
@0d9bc25
02/05/15 08:52:00 |
Daniel Hellstrom |
GRSPW: fix build warnings
4.115
@b55aa49
02/05/15 07:07:15 |
Daniel Hellstrom |
LEON3: watchdog use common timer defines
4.115
@5ba49066
02/05/15 07:06:26 |
Daniel Hellstrom |
LEON3: export debug uart to console uart driver
4.115
@aedc9849
02/05/15 07:05:56 |
Daniel Hellstrom |
GRETH: fix build warnings with GCC-4.9
4.115
@bf6fe958
02/04/15 15:22:59 |
Daniel Hellstrom |
GPTIMER: avoid build warnings
4.115
@0fcd4b33
02/04/15 15:22:41 |
Daniel Hellstrom |
AHBSTAT: fix build warnings
4.115
@bb689e6
11/04/14 07:57:55 |
Daniel Hellstrom |
GRTM: fixed descriptor TS bit declaration
4.115
@5f4028b
11/04/14 07:52:39 |
Daniel Hellstrom |
GRSPW_PKT: grspw_status renamed in header
4.115
@e8f6005f
08/08/14 08:01:41 |
Daniel Hellstrom |
GR-RASTA-TMTC,rev1: add GRGPIO[0] register init
4.115
@fed905c8
08/08/14 07:59:36 |
Daniel Hellstrom |
B1553BRM: change the init of the RT legalization registers
4.115
@d2a94ab
05/02/14 12:28:44 |
Daniel Hellstrom |
GRSPW: added clock cycles after GRSPW reset
added clock cycles after …
4.115
@56fc7809
07/03/13 08:16:30 |
andreas |
GRSPW_PKT: Add support for Interrupt-codes
Update: Daniel Hellstrom …
4.115
@c119c0e
07/03/13 08:06:37 |
andreas |
GRSPW: Fix incorrect register defines - presently functionally …
4.115
@f1b1668
12/20/13 09:17:22 |
Daniel Hellstrom |
AMBAPP: updated PnP IDs database with SPWTDP
4.115
@fa12bb43
11/29/13 13:58:58 |
Daniel Hellstrom |
GRTIMER: added to GPTIMER driver
GRTIMER is compatible with GPTIMER, …
4.115
@9b8e04e2
10/22/13 10:03:41 |
Daniel Hellstrom |
GRETH: avoid hw generated UDP/TCP cksum generation
Hardware generated …
4.115
@80b9c8ac
12/20/13 13:03:10 |
Daniel Hellstrom |
GR-RASTA-IO: updated for new version
From this driver's point of view …
4.115
@fc76056e
12/20/13 13:01:12 |
Daniel Hellstrom |
GR-RASTA-TMTC: updated for new version
From this driver's point of …
4.115
@9d88008
12/18/13 15:42:16 |
Daniel Hellstrom |
AT697PCI: fix PCI cfg writes
4.115
@ddc4002
11/22/13 09:22:56 |
Daniel Hellstrom |
AT697 PCI: abort whhen a peripheral PCI system detected
4.115
@3c236cc
02/05/14 16:17:53 |
Daniel Hellstrom |
LEON PCI: fix for PCI host bridge driver CFG space access
4.115
@acf7047e
09/10/13 11:46:29 |
Daniel Hellstrom |
GPTIMER: timer probing must not be on timer0
Timers are identical …
4.115
@51347053
07/01/13 13:00:21 |
Daniel Hellstrom |
LEON PCI: host bridge driver support for probing dev0=AD16
Before the …
4.115
@d936c1a
06/03/13 12:12:08 |
Daniel Hellstrom |
APBUART: debug bit was cleared incorrectly
4.115
@ab907e8e
05/21/13 08:10:21 |
Daniel Hellstrom |
NGMP PCI: added support for NGMP prototype boards
4.115
@bc89145
02/11/15 13:39:34 |
Daniel Hellstrom |
LEON GRSPW: updated to new DRVMGR translation interface
4.115
@ffd8002d
05/08/13 12:41:13 |
Daniel Hellstrom |
GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device
4.115
@8aa446a
05/08/13 12:38:10 |
Daniel Hellstrom |
GRPCI2: updated register layout to newer specification
4.115
@ecbd577
04/30/13 07:49:32 |
Daniel Hellstrom |
AMBAPP: update AMBA PnP ID database
4.115
@175b9a64
04/24/13 15:36:44 |
Daniel Hellstrom |
GRPCI2: work-around for rev0 bug by limiting prefetching
4.115
@819de55b
03/18/13 07:29:39 |
Daniel Hellstrom |
PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performance
4.115
@37ac3b86
03/14/13 09:20:15 |
Daniel Hellstrom |
GRETH: cleaned up parts of PHY init code
4.115
@107c5aea
03/13/13 15:40:05 |
Daniel Hellstrom |
GRETH: changed the PHY initialization sequence
1. read_mii() now …
4.115
@a79c36ad
03/12/13 14:30:09 |
Daniel Hellstrom |
GRETH: forcing autonegotiation during PHY initialization
Looking at …
4.115
@bee7c46f
03/12/13 13:49:33 |
Daniel Hellstrom |
GRETH: updated worker Deamon thread name
The name was probably copied …
4.115
@552d4a9
03/06/13 14:08:31 |
Daniel Hellstrom |
GRPCI: initialize cache-line-size and latency timer
In some GRPCI …
4.115
@5dd83de
01/18/13 12:16:05 |
Daniel Hellstrom |
GRSPW: fixed SET_RMAPEN and SET_RMAPBUFDIS
Both ioctl commands …
4.115
@4d249b9f
11/19/12 16:41:15 |
Daniel Hellstrom |
GPTIMER: support separate & shared irq by clearing pending bit after ISR
4.115
@7ebc28cd
11/19/12 14:24:21 |
Daniel Hellstrom |
GPTIMER: Only probe pending bit on timer0
4.115
@b583cc5f
02/23/15 12:47:32 |
Daniel Hellstrom |
leon,gpiolib: add mask/unmask interrupt support
4.115
@949d0d6
09/25/12 13:26:00 |
arvid |
GRSPW: Make sure buffers are 64-bit aligned
This is to improve odds …
4.115
@18564f5
06/19/12 12:49:40 |
Daniel Hellstrom |
APBUART: fix GRMON -u support for older UARTs
4.115
@0f49c0e
06/19/12 06:50:11 |
Daniel Hellstrom |
GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA
This patch adds …
4.115
@16d6e42
06/19/12 06:34:37 |
Daniel Hellstrom |
LEON3: fixed nano seconds support in TLIB
The …
4.115
@f00fee8e
05/24/12 15:23:37 |
Daniel Hellstrom |
GRTM: fixed bug where transmitter start loop was optimized away
4.115
@e9378fa
05/16/12 11:17:11 |
Daniel Hellstrom |
GRPCI: fix target BAR1 initialization
4.115
@3bb4122
02/23/15 12:02:39 |
Daniel Hellstrom |
LEON: added new drivers to the LEON2/LEON3 BSPs
Most drivers use the …
4.115
@fe1aa9c0
12/21/11 12:21:49 |
Daniel Hellstrom |
LEON: added network device configuration helper function
4.115
@3681925
12/20/11 15:27:54 |
Daniel Hellstrom |
LEON: updated shared drivers to Driver Manger framework
Some bugfixes …
4.115
@e67b2b8d
12/20/11 14:58:05 |
Daniel Hellstrom |
LEON: updated and added PCI peripherals for LEON BSPs
The CCHIP …
4.115
