@1203d38
12/06/13 15:57:55 |
cdesai |
powerpc: mbx8xx: move starup/start.S to start/start.S
4.115
@25026906
12/04/13 20:45:12 |
radustoma |
erc32: improve doxygen
Add doxygen to the bsp.h, tm27.h, erc32.h and …
4.115
@5b3dc68
12/04/13 20:51:21 |
Gedare Bloom |
leon3: fix doxygen description for bsp.h
4.115
@df217b0b
12/04/13 18:07:04 |
radustoma |
leon3: improve doxygen
Add doxygen to the bsp.h, tm27.h, amba.h and …
4.115
@3f8abd2
12/03/13 21:21:51 |
Daniel Ramirez |
sparc: refactored shared/start.S to shared/start/start.S
4.115
@ebd0844
12/03/13 20:41:45 |
Gedare Bloom |
leon2: fix typo in doxygen
4.115
@133f3cce
12/03/13 20:26:51 |
radustoma |
leon2: improve doxygen
Add doxygen to the cchip.c & leon_open_eth.c files.
4.115
@9f3057fc
12/03/13 05:11:39 |
Daniel Ramirez |
m68k: refactored shared/start.S to shared/start/start.S
4.115
@b9287a15
12/03/13 07:30:39 |
Daniel Ramirez |
libbsp: refactored sparc/shared/bspgetworkarea.c to …
4.115
@057c294
12/03/13 08:55:52 |
Sebastian Huber |
bsps/powerpc: Unconditionally clear reservations
4.115
@f339afb
12/03/13 08:51:13 |
Sebastian Huber |
bsp/qoriq: Use System V small-data area
4.115
@4b43051
12/02/13 16:07:29 |
cdesai |
powerpc: motorola: Move bspreset.c to startup/
* Move …
4.115
@8d830fae
12/02/13 20:07:35 |
radustoma |
leon2_doxygen_1
4.115
@d230d8e
11/30/13 20:51:35 |
radustoma |
sparc/leon3: Add doxygen.
4.115
@2d3eb23
11/30/13 15:28:28 |
Daniel Hellstrom |
sparc/shared/irq_asm.S: Get pointer to self per-CPU control
4.115
@2d6543d4
11/30/13 02:18:44 |
Daniel Ramirez |
doxygen: refactored doxygen in libbsp/arm/lpc32xx
This patch …
4.115
@98eb7e78
11/26/13 00:14:28 |
Daniel Ramirez |
raspberrypi doxygen refactoring
4.115
@22fa874a
11/24/13 15:46:00 |
cdesai |
powerpc/mpc55xxevb: Move bspworkarea.c to bspgetworkarea.c
Fixes …
4.115
@287fefe2
11/23/13 21:55:32 |
Daniel Ramirez |
mpc55xxevb: Move start.S to mpc55xxevb/start/start.S
4.115
@9660ad6
11/23/13 19:23:14 |
Daniel Ramirez |
beatnik: Move bsp_reset() to beatnik/startup/bspreset.c
4.115
@571216ac
11/23/13 14:21:03 |
cdesai |
powerpc/mpc55xxevb: Move bspworkareainit.c to bspgetworkarea.c
* Move …
4.115
@4abc4d1
11/23/13 08:57:28 |
cdesai |
powerpc/mpc55xxevb: Move startup/reset.c to startup/bspreset.c
4.115
@995eb4be
11/22/13 01:07:59 |
Daniel Ramirez |
gumstix: Move bsp_reset() to gumstix/startup/bspreset.c
4.115
@14876018
11/21/13 00:24:48 |
Daniel Ramirez |
select.h, rtems_select.c, nds select: Add restrict keyword
4.115
@39a4574
06/24/13 13:21:46 |
Sebastian Huber |
powerpc: Add r2 to CPU context
The r2 may be used for thread-local …
4.115
@52c3af1
11/14/13 23:26:12 |
Joel Sherrill |
sparc/../irq-shared.c: Fix compilation for SMP when not LEON3
4.115
@a3b1fcd
11/14/13 14:55:51 |
Sebastian Huber |
bsps/arm: Fix Cortex-A9 MPCore nanoseconds handler
4.115
@2c93c5a
11/11/13 09:30:50 |
Sebastian Huber |
bsp/realview-pbx-a9: Add Ethernet module memory
4.115
@12cbc37
11/12/13 09:29:50 |
Sebastian Huber |
bsp/ngmp: New BSP variant
4.115
@f204e31
11/12/13 09:28:54 |
Sebastian Huber |
bsp/leon3: Enable linker script variants
4.115
@19814000
11/12/13 09:33:07 |
Sebastian Huber |
bsp/leon3: Delete unused LEON_REG symbol
4.115
@ffc862c
09/17/13 11:08:49 |
Sebastian Huber |
bsp/realview-pbx-a9: Add NULL pointer protection
Qemu Git version …
4.115
@b3211b5a
10/31/13 14:23:23 |
Daniel Hellstrom |
SPARC BSPs: disable interrupts as early as possible
There is no point …
4.115
@82e11be2
10/31/13 14:23:21 |
Daniel Hellstrom |
LEON3 SMP: remove compiler warning from delay() declaration
4.115
@bedfe13
10/31/13 14:23:20 |
Daniel Hellstrom |
LEON3 SMP: CPU ack irq on trap vector entry execution
4.115
@e1b53274
10/31/13 14:23:19 |
Daniel Hellstrom |
LEON3_MP ISR: shared-IRQ setup overwrite SMP/MP ISR trap handler
4.115
@fbed79b
10/27/13 18:35:16 |
Sebastian Huber |
bsps/arm: Add ARMV7_CP15_START_DEFAULT_SECTIONS
4.115
@f074a4d
10/27/13 18:27:44 |
Sebastian Huber |
bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
Delete …
4.115
@f619250
10/27/13 18:13:47 |
Sebastian Huber |
bsps: Add simple console output char
4.115
@7ad725f2
10/14/13 13:34:58 |
Hesham Almatary |
Modify raspberrypi mm_config_table to map GPIO and registers.
Changes …
4.115
@09d0c96b
10/27/13 17:58:42 |
Sebastian Huber |
bsps/arm: Move some MMU bit settings
The function …
4.115
@0f874ee
10/27/13 17:51:53 |
Sebastian Huber |
bsps/arm: Init trans tbl with invalid entries
4.115
@24a6943
10/24/13 23:37:17 |
Joel Sherrill |
sparc all BSPs: Use function and data sections
This reduces the size …
4.115
@0255beaf
10/24/13 14:42:31 |
Christian.Mauderer |
bsp/stm32f4: Bugfix for I2C driver.
4.115
@c918737e
10/24/13 14:26:59 |
bsp/stm32f4: Add a simple I2C-driver.
4.115
@bb3f349
10/24/13 14:27:00 |
bsp/stm32f4: Bugfix for io-initialisation.
4.115
@c6f0efe2
10/24/13 14:17:35 |
bsp/stm32f4: Header for f10xxx EXTI.
4.115
@382f714
10/08/13 08:40:29 |
Pavel Pisa |
SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command.
4.115
@5ceefe1
09/28/13 08:08:25 |
Hesham Almatary |
Shared MMU initialization for ARM BSPs and RaspberryPi? MMU support
4.115
@0a9533fc
09/28/13 08:08:24 |
Hesham Almatary |
Add a new necessary definition needed for raspberrypi MMU support
The …
4.115
@ba2e98e6
09/30/13 17:08:38 |
Joel Sherrill |
libbsp/sparc/.../gnatcommon.c: Formatting
4.115
@d349636b
09/30/13 17:08:13 |
Joel Sherrill |
leon2/.../ckinit.c: Change get nanoseconds handler to static
4.115
@a15650d
09/30/13 17:07:35 |
Joel Sherrill |
mips/shared/.../clockdrv.c: Change get nanoseconds handler to static
4.115
@2dfdecd
09/30/13 17:07:07 |
Joel Sherrill |
uC5282/.../clock.c: Change get nanoseconds handler to static
4.115
@38905d70
09/23/13 13:28:48 |
Joel Sherrill |
leon3/bsppredriver.c: Add include file to warning
4.115
@4fab260d
09/23/13 13:24:32 |
Joel Sherrill |
libcpu/sparc/.../access_le.c: Add include file to fix warning
4.115
@876af7a
09/23/13 13:16:55 |
Joel Sherrill |
leon3/.../ckinit.c: Change get nanoseconds handler to static
4.115
@d2c5bff
09/22/13 15:51:36 |
Joel Sherrill |
leon3/.../ckinit.c: Fix missing prototype warnings
4.115
@6867055
09/22/13 15:51:19 |
Joel Sherrill |
libbsp/shared/bspinit.c: Fix missing prototype warnings
4.115
@4650678b
09/22/13 15:38:31 |
Joel Sherrill |
leon3/.../bspstart.c: Fix missing prototype warnings
4.115
@f07b0e65
09/22/13 14:41:49 |
Joel Sherrill |
sparc/.../grcan.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE
4.115
@c8707a3
09/21/13 21:25:06 |
Joel Sherrill |
leon3/console.c: Fix misisng prototype issues
4.115
@34b57d61
09/21/13 21:10:17 |
Joel Sherrill |
sparc/.../grcan.c: Fix multiple warnings
4.115
@e9da278
09/21/13 21:09:48 |
Joel Sherrill |
sparc/.../ambapp.h: Add ambapp_get_number_apbslv_devices() prototype
4.115
@ac19578
09/21/13 20:56:28 |
Joel Sherrill |
sparc/.../occan.c: Fix missing prototype warning
4.115
@110cc8c
09/21/13 20:55:40 |
Joel Sherrill |
sparc/.../ambapp.h: Add ambapp_get_number_ahbslv_devices() prototype
4.115
@946c391
09/21/13 20:48:45 |
Joel Sherrill |
sparc/../occan.c: Fix set but unused variable warning
4.115
@df74da0
09/21/13 20:38:48 |
Joel Sherrill |
sparc irq-shared.c: Fix unused variable warning
4.115
@1485a58
09/18/13 13:44:42 |
bsp/stm32f4: Add STM32F10XXX support.
4.115
@564860f
09/16/13 19:32:36 |
Joel Sherrill |
leon3/include/bsp.h: Fix spacing
4.115
@3d477da0
09/16/13 19:32:22 |
Joel Sherrill |
m68k/shared/start.S: Fix spacing
4.115
@f7308976
09/16/13 19:31:52 |
Joel Sherrill |
pc386/console/conscfg.c: Fix spacing
4.115
@38d94f56
09/16/13 19:31:28 |
Joel Sherrill |
raspberrypi.cfg: Remove CVS Id
4.115
@a44917e
09/16/13 07:27:32 |
Ric Claus |
bsps/arm: Fix exception entries
4.115
@f55215a
09/10/13 06:50:24 |
Sebastian Huber |
bsps: Fix cache manager support
4.115
@d157a4fd
09/04/13 12:03:47 |
Sebastian Huber |
bsps/arm: Fix ARM CP15 opcode for get functions
4.115
@0c47440
08/29/13 20:20:03 |
Karel Gardas |
bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad? board
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@d56f76a
08/26/13 11:00:53 |
Sebastian Huber |
bsps: Fix header includes
4.115
@3109857c
08/26/13 19:26:50 |
Joel Sherrill |
bsps: Add and use CLOCK_DRIVER_ISRS_PER_TICK_VALUE
pc386 set …
4.115
@2bd440e
08/22/13 12:18:14 |
Ric Claus |
bsp/xilinx-zynq: Add cache support
4.115
@c9b66f5
08/22/13 12:00:51 |
Ric Claus |
bsps/arm: Add more CP15 cache functions
4.115
@2a2f559
08/08/13 23:22:06 |
Pavel Pisa |
bsp/csb336: Memory map update and jump to start at image start …
4.115
@526f895
08/14/13 13:35:58 |
Karel Gardas |
bsp/lm3s69xx: add macros for UART CTS/RTS pin configuration
4.115
@d473dc0
08/14/13 11:26:41 |
Sebastian Huber |
bsps: Fix clock driver defines
4.115
@b7f2060
08/14/13 01:53:28 |
Chris Johns |
bsp: Fix CLOCK_DRIVER_USE_FAST_IDLE and CLOCK_DRIVER_ISRS_PER_TICK.
4.115
@c32c80e
08/13/13 12:43:54 |
Sebastian Huber |
bsps/arm: Use proper default priority for GIC
Some GIC …
4.115
@4e3b7e26
08/02/13 14:28:23 |
Sebastian Huber |
bsps/i386: SMP and per-CPU thread dispatch disable
Interrupt support …
4.115
@55b1aee4
08/02/13 07:05:29 |
Sebastian Huber |
bsps/i386: Revert most SMP related changes
The commit partially …
4.115
@f8ad6c6f
08/02/13 12:12:55 |
Sebastian Huber |
sparc: Make _CPU_ISR_Dispatch_disable per-CPU
This variable must be …
4.115
@88f6c4fc
08/02/13 12:06:52 |
Sebastian Huber |
sparc: Move _CPU_Context_switch(), etc.
Move the …
4.115
@8b077ca0
08/09/13 09:12:56 |
Sebastian Huber |
bsps/sparc: SMP and per-CPU thread dispatch disable
Interrupt support …
4.115
@849bb7a3
08/01/13 09:35:16 |
Sebastian Huber |
bsps/sparc: Revert most SMP related changes
As a side-effect the …
4.115
@c6c998b
08/01/13 14:36:55 |
Sebastian Huber |
bsps/powerpc: Per-CPU thread dispatch disable
Interrupt support for …
4.115
@d19cce29
08/05/13 12:54:11 |
Sebastian Huber |
score: Per-CPU thread dispatch disable level
Use a per-CPU thread …
4.115
@838d714
08/09/13 13:23:15 |
Sebastian Huber |
bsp/pc386: Provide local outb() for elink driver
4.115
@c31a7129
08/09/13 08:22:42 |
Chris Johns |
bsp/xilinx_zynq_zc706_smp: Add.
4.115
@efdda565
08/09/13 04:18:17 |
Nick Withers |
Use $(EXEEXT) [defaults to "exe"] to generate binaries
4.115
@98bcf4ff
08/08/13 23:23:14 |
Pavel Pisa |
bsp/csb336: implement bsp_interrupt_vector_enable/disable.
4.115
@e4b16ea9
08/08/13 23:21:15 |
Pavel Pisa |
bsp/csb336: Fix MMU _ttbl_base location to not overlap with exception …
4.115
