Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @063e4950   11/02/99 16:27:05 Joel Sherrill Added support for configuring base filesystem. First attempt at a … 4.104.114.84.95
(edit) @a504ced3   11/02/99 16:25:48 Joel Sherrill Install imfs.h so base filesystem can be configured or IMFS mounted by … 4.104.114.84.95
(edit) @19b74f31   11/02/99 16:25:05 Joel Sherrill Check for NULL being passed in. 4.104.114.84.95
(edit) @3fb2a8da   11/02/99 16:23:50 Joel Sherrill Fixed typo where memfile_handlers set twice and directory_handlers was … 4.104.114.84.95
(edit) @ac8adcf   11/02/99 16:22:58 Joel Sherrill Properly initialize location variable. 4.104.114.84.95
(edit) @c42bd452   11/02/99 16:05:41 Joel Sherrill Split console_reserve_resources into its own file to reduce … 4.104.114.84.95
(edit) @5d36b344   11/02/99 16:01:52 Joel Sherrill Fixed bug which resulted in misaligned object control structures being … 4.104.114.84.95
(edit) @32441ab7   11/02/99 16:00:37 Joel Sherrill Added a comment to indicate that if a task blocked on a priority based … 4.104.114.84.95
(edit) @2cd5444   11/02/99 15:58:39 Joel Sherrill Added code to allocate by index. This is the object ID style used by … 4.104.114.84.95
(edit) @8f0529f   11/02/99 15:58:09 Joel Sherrill Added maximum count detection logic. 4.104.114.84.95
(edit) @9693fdac   11/02/99 15:57:58 Joel Sherrill Added support for message priority as required by POSIX. 4.104.114.84.95
(edit) @af10d3ef   11/02/99 15:57:43 Joel Sherrill Corrected spacing. 4.104.114.84.95
(edit) @3f421dab   11/02/99 15:56:10 Joel Sherrill Added message queues and semaphores. 4.104.114.84.95
(edit) @be0fc099   11/02/99 15:55:34 Joel Sherrill Added CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES and … 4.104.114.84.95
(edit) @861e94d9   11/02/99 15:35:58 Joel Sherrill Added comment to make sure Classic API priority to Core priority is … 4.104.114.84.95
(edit) @3ba754e1   11/02/99 15:34:40 Joel Sherrill Added comments for _RTEMS_tasks_Create_extension, … 4.104.114.84.95
(edit) @b970c48   11/02/99 15:33:14 Joel Sherrill Added a case to support the core semaphore error returned when the … 4.104.114.84.95
(edit) @d80188eb   11/02/99 15:30:20 Joel Sherrill Added code to utilize the maximum_count attribute of core semaphores … 4.104.114.84.95
(edit) @fd882ee   11/02/99 15:29:47 Joel Sherrill Now much closer to working. 4.104.114.84.95
(edit) @26c828f   11/02/99 15:29:04 Joel Sherrill Added assert in case _Objects_Get_information fails since this should … 4.104.114.84.95
(edit) @2b95c07   11/02/99 15:28:02 Joel Sherrill Commented out lines causing warning. 4.104.114.84.95
(edit) @733a248   11/02/99 15:27:38 Joel Sherrill Added #define for SEM_FAILED. 4.104.114.84.95
(edit) @9d3a44b   11/02/99 15:27:20 Joel Sherrill Added include of <sys/siginfo.h>. 4.104.114.84.95
(edit) @f2422aa   11/02/99 15:26:46 Joel Sherrill Added message queues and semaphores. 4.104.114.84.95
(edit) @a49a7f3d   11/02/99 15:22:00 Joel Sherrill Backed out change that increased the minimum stack size since it was … 4.104.114.84.95
(edit) @f59df6b2   11/02/99 15:19:43 Joel Sherrill Modified to use minimum stack size and reserve the necessary amount of … 4.104.114.84.95
(edit) @dee8a51   11/01/99 21:34:04 Joel Sherrill Corrected wildcard to pickup CPU model dependent library pieces. 4.104.114.84.95
(edit) @43f7a90   11/01/99 20:58:23 Joel Sherrill Enabled configuring mini or full IMFS. 4.104.114.84.95
(edit) @0910a251   11/01/99 20:31:25 Joel Sherrill Added name to id support routine. 4.104.114.84.95
(edit) @2e3e407   11/01/99 20:21:17 Joel Sherrill Increased stack space for all initialization tasks in tmtests. 4.104.114.84.95
(edit) @5fe6b21a   11/01/99 20:14:35 Joel Sherrill Increased stack space of a task. 4.104.114.84.95
(edit) @328aa64c   11/01/99 20:11:24 Joel Sherrill Increased stack space of task 2. 4.104.114.84.95
(edit) @4443984   11/01/99 20:08:05 Joel Sherrill Increased stack space for a task. 4.104.114.84.95
(edit) @c42e6c72   11/01/99 20:06:02 Joel Sherrill Increased stack space for task 1. 4.104.114.84.95
(edit) @89b63972   11/01/99 18:02:44 Joel Sherrill Removed routines that had already been separated into their own files. 4.104.114.84.95
(edit) @92f69999   11/01/99 13:08:35 Joel Sherrill Removed all references to shared memory driver as it is not supported … 4.104.114.84.95
(edit) @a2504f7   11/01/99 13:07:56 Joel Sherrill Removed shmsupp directory as it is not really implemented. 4.104.114.84.95
(edit) @4c9d61e8   11/01/99 13:07:22 Joel Sherrill MVME2307 does not really include MP support. 4.104.114.84.95
(edit) @4a07d2b   10/29/99 15:19:13 Jennifer.Averett Moved the rmnod callback from the operations table to the handler table. 4.104.114.84.95
(edit) @4bde8072   10/29/99 14:28:39 Jennifer.Averett Joel added a table of mount entry requests to be processed during … 4.104.114.84.95
(edit) @7046cdd   10/28/99 16:01:41 Joel Sherrill Patch rtems-rc-19991011-3.diff from Ralf Corsepius. 4.104.114.84.95
(edit) @5c104e08   10/28/99 15:12:10 Joel Sherrill New test added - psxcancel. This is just a shell for now. 4.104.114.84.95
(edit) @b8d9f41   10/28/99 14:59:35 Joel Sherrill Added include of <sys/select.h> in attempt to remove compilation warning. 4.104.114.84.95
(edit) @be22768   10/28/99 14:50:43 Joel Sherrill Added use of rtems rather than LINUX for RTEMS configuration. 4.104.114.84.95
(edit) @c8b35b1b   10/28/99 13:36:26 Joel Sherrill Notes on what to do when merging a BSP. 4.104.114.84.95
(edit) @45544f0   10/27/99 20:50:57 Joel Sherrill Patch from Aleksey (Quality Quorum <qqi@…>) to increase … 4.104.114.84.95
(edit) @e4487b6   10/27/99 20:21:33 Joel Sherrill Modified to properly descend into the dummy directory. 4.104.114.84.95
(edit) @0f75a13   10/27/99 20:09:39 Joel Sherrill Fixed typo. 4.104.114.84.95
(edit) @b07e06a1   10/27/99 19:35:36 Joel Sherrill New files from Ralf Corsepius <corsepiu@…> which are a … 4.104.114.84.95
(edit) @3abbfdb   10/27/99 19:27:05 Joel Sherrill Added $(EXEEXT) in attempt to help Cygwin install process. 4.104.114.84.95
(edit) @2bdc1e98   10/27/99 18:54:14 Joel Sherrill Last cleanup to attempt to link. 4.104.114.84.95
(edit) @ae7325bd   10/27/99 17:25:53 Joel Sherrill rxgen960 now compiles -- may not link. 4.104.114.84.95
(edit) @2ea8df3   10/27/99 16:27:34 Joel Sherrill Added CVS Ids and a basic header. More header cleanup needed. 4.104.114.84.95
(edit) @f08a5596   10/27/99 16:26:00 Joel Sherrill Removed systbl.S save_systbl.c. They were unnecessary. 4.104.114.84.95
(edit) @8ac4213   10/27/99 16:21:49 Joel Sherrill Removed sctns.S. This file was obviously the output of the compiler. 4.104.114.84.95
(edit) @919822f   10/27/99 16:19:24 Joel Sherrill Replaced Makefile.in's with modified copies of cvme961 to get … 4.104.114.84.95
(edit) @d73a8649   10/27/99 15:58:26 Joel Sherrill Moved timerisr.s to timerisr.S per GNU conventions. 4.104.114.84.95
(edit) @ce644256   10/27/99 15:57:20 Joel Sherrill Moved systbl.s to systbl.S per GNU conventions. 4.104.114.84.95
(edit) @5ee66da   10/27/99 15:57:19 Joel Sherrill Moved sctns.s to sctns.S per GNU conventions. 4.104.114.84.95
(edit) @bf71be9e   10/27/99 15:57:17 Joel Sherrill Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. 4.104.114.84.95
(edit) @478c4b8   10/27/99 15:57:16 Joel Sherrill Moved ihandler.s to ihandler.S per GNU conventions. 4.104.114.84.95
(edit) @49b8c26   10/27/99 15:57:15 Joel Sherrill Moved asmstub.s to asmstub.S per GNU conventions. 4.104.114.84.95
(edit) @eb7f0f22   10/27/99 15:57:14 Joel Sherrill Moved asmfault.s to asmfault.S per GNU conventions. 4.104.114.84.95
(edit) @702c5f5   10/27/99 15:29:18 Joel Sherrill The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson … 4.104.114.84.95
(edit) @3f4b575   10/27/99 13:58:58 Joel Sherrill Warnings removed. Still don't know what to do about the pragma pack … 4.104.114.84.95
(edit) @c1cdaa0   10/27/99 12:50:33 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> and Eric Valette … 4.104.114.84.95
(edit) @7999174   10/26/99 21:51:20 Joel Sherrill New files created by split of old imfs_handlers.c. 4.104.114.84.95
(edit) @2fe47ff   10/26/99 21:51:07 Joel Sherrill Added include of libio.h so this would compile when posix is disabled. 4.104.114.84.95
(edit) @7ee88c16   10/26/99 20:30:20 Joel Sherrill Split console_reserve_resources to separate file to reduce code size. 4.104.114.84.95
(edit) @657e1bf6   10/26/99 20:17:13 Joel Sherrill Added initial cut at miniIMFS which leaves out memfile and directory … 4.104.114.84.95
(edit) @e54a7d33   10/26/99 16:22:55 Joel Sherrill Patch from Gerwin Pfab <pb@…> to leave dispatching … 4.104.114.84.95
(edit) @66a8c6f   10/26/99 15:21:01 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to fix a small bug … 4.104.114.84.95
(edit) @9a986282   10/26/99 14:39:57 Joel Sherrill Increased minimum stack size to ensure that there are no problems … 4.104.114.84.95
(edit) @cb50837d   10/26/99 14:29:53 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to add missing file … 4.104.114.84.95
(edit) @65a60cd   10/26/99 14:22:55 Joel Sherrill Removed all references to HOST_ARCH including the file gcc.cfg.in. … 4.104.114.84.95
(edit) @2782e69   10/26/99 12:39:24 Joel Sherrill idir=/opt/tmp/opt/rtems rdir=/opt/rtems cd $idir find . -type f | … 4.104.114.84.95
(edit) @a94521c   10/26/99 12:37:14 Joel Sherrill cat /tmp/j | while read f do rpm -qi $f 2>&1 | grep -v "is not ins" done 4.104.114.84.95
(edit) @dd04e32   10/26/99 02:58:06 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to move … 4.104.114.84.95
(edit) @3f06778e   10/26/99 02:49:21 Joel Sherrill cat /tmp/j | while read f do rpm -qi $f 2>&1 | grep -v "is not ins" done 4.104.114.84.95
(edit) @3330ecb   10/26/99 02:45:04 Joel Sherrill Patch rtems-rc-19991011-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @2ca64b5   10/26/99 02:32:47 Joel Sherrill New ideas on test incorporated. 4.104.114.84.95
(edit) @99826740   10/26/99 01:35:36 Joel Sherrill Modifications from Erik Ivanenko <erik.ivanenko@…> to add … 4.104.114.84.95
(edit) @f70598c7   10/26/99 01:34:42 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to fix some … 4.104.114.84.95
(edit) @8379ada7   10/25/99 16:09:45 Joel Sherrill Patch from Eric Norum <eric@…> to address the following … 4.104.114.84.95
(edit) @b6c868e   10/25/99 16:05:34 Joel Sherrill Patch from Charles-Antoine Gauthier <charles.gauthier@…> to … 4.104.114.84.95
(edit) @4e69f5b7   10/25/99 15:55:58 Joel Sherrill Added notes for new test. 4.104.114.84.95
(edit) @3eb75db3   10/25/99 14:52:19 Joel Sherrill tch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @1e57186   10/25/99 14:46:56 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @04df848   10/25/99 14:23:03 Jennifer.Averett Added code to correctly free any allocated space during the evaluation … 4.104.114.84.95
(edit) @1232196a   10/25/99 14:14:07 Joel Sherrill Added sp26 which tests the rtems_task_is_suspended directive. 4.104.114.84.95
(edit) @9060699   10/25/99 14:13:14 Joel Sherrill Modified to ease comparison of screen to target output. 4.104.114.84.95
(edit) @48296038   10/25/99 14:11:12 Joel Sherrill Modified to reflect test change where reinitialize mutex test case was … 4.104.114.84.95
(edit) @524767cb   10/25/99 14:10:38 Joel Sherrill Removed reinitialize mutex test case to reflect earlier code change in … 4.104.114.84.95
(edit) @c774a07e   10/25/99 14:09:46 Joel Sherrill Changed leading spaces to periods to ease comparing test output. 4.104.114.84.95
(edit) @538db54   10/25/99 14:09:13 Joel Sherrill Modified to produce correct output with new version of sis. 4.104.114.84.95
(edit) @61a4d81   10/21/99 19:36:29 Joel Sherrill Removed warning. 4.104.114.84.95
(edit) @d013d05   10/21/99 16:48:06 Joel Sherrill Increased stack size of initialization thread. 4.104.114.84.95
(edit) @e7264f07   10/21/99 16:44:24 Joel Sherrill Added rtems_semaphore_flush directive. 4.104.114.84.95
(edit) @9583f6e   10/21/99 16:41:59 Joel Sherrill Renamed CONFIGURE_POSIX_INIT_TASK_STACK_SIZE to … 4.104.114.84.95
(edit) @812f440   10/21/99 16:38:49 Joel Sherrill Fixed core dump caused when output parameter (otimer) was NULL. 4.104.114.84.95
