Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @062f6705   12/13/06 02:21:10 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a7529ced   12/13/06 02:20:29 Ralf Corsepius Require RTEMS_AMPOLISH. 4.104.114.84.95
(edit) @4db0f6f3   12/13/06 02:19:13 Ralf Corsepius Remove RTEMS_AMPOLISH. 4.104.114.84.95
(edit) @ff01b21f   12/13/06 02:18:46 Ralf Corsepius Require AM_MAINTAINER_MODE. 4.104.114.84.95
(edit) @6b1e9217   12/12/06 14:48:05 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @f1d96dbd   12/12/06 14:47:57 Ralf Corsepius Add RTEMS_AMPOLISH3. 4.104.114.84.95
(edit) @34e7be2   12/12/06 10:43:30 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0b933d6a   12/12/06 10:26:29 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ec76139c   12/12/06 10:26:18 Ralf Corsepius Use uint32_t instead of unsigned32. 4.104.114.84.95
(edit) @4ce019ce   12/12/06 10:24:26 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1408ea8d   12/12/06 10:24:16 Ralf Corsepius Use uint32_t instead of rtems_unsigned32/unsigned32. 4.104.114.84.95
(edit) @b8e42a76   12/12/06 10:22:18 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @fcb0cd46   12/02/06 06:06:55 Ralf Corsepius 2006-12-02 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @fe6f68c   11/30/06 16:05:50 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @43ea369   11/30/06 02:28:49 strauman * vmeUniverse/vmeTsi148.h: user now must define a symbol for the … 4.104.114.84.95
(edit) @c73ba8b5   11/20/06 05:51:08 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @f6670ed1   11/20/06 05:50:22 Ralf Corsepius 2006-11-20 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d17f2b5   11/20/06 05:47:35 Ralf Corsepius 2006-11-20 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @76ce226   11/17/06 23:08:55 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @3ca2768   11/17/06 22:46:31 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * timer/timer.c: Update … 4.104.114.84.95
(edit) @d89bfb3   11/17/06 22:46:22 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * runtest.in: Change … 4.104.114.84.95
(edit) @3664346e   11/17/06 22:44:10 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * clock_driver_stub.c, … 4.104.114.84.95
(edit) @ad19e3c   11/17/06 22:42:54 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * psim, psim-gdb, … 4.104.114.84.95
(edit) @248b6a4   11/17/06 22:42:18 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * runtest: Change … 4.104.114.84.95
(edit) @461c9167   11/17/06 22:41:41 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * clock/clockdrv.c: Add … 4.104.114.84.95
(edit) @9824dafe   11/16/06 16:31:38 Joel Sherrill 2006-11-16 Joel Sherrill <joel@…> * shared/bspstart.c, … 4.104.114.84.95
(edit) @29d1fce   11/16/06 16:31:36 Joel Sherrill 2006-11-16 Joel Sherrill <joel@…> * clock/ckinit.c, … 4.104.114.84.95
(edit) @2d4b256   11/16/06 16:31:34 Joel Sherrill 2006-11-16 Joel Sherrill <joel@…> * clock/ckinit.c: Use … 4.104.114.84.95
(edit) @74b09f1   11/16/06 16:31:32 Joel Sherrill 2006-11-16 Joel Sherrill <joel@…> * clock/ckinit.c, … 4.104.114.84.95
(edit) @aa4369c   11/15/06 15:24:01 Joel Sherrill 2006-11-15 Joel Sherrill <joel@…> * Makefile.am: Merge … 4.104.114.84.95
(edit) @920fb9c   11/15/06 15:21:24 Joel Sherrill 2006-11-15 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @9b86dabd   11/15/06 15:21:12 Joel Sherrill 2006-11-15 Joel Sherrill <joel@…> * Makefile.am, … 4.104.114.84.95
(edit) @66d973ff   11/15/06 15:20:05 Joel Sherrill 2006-11-15 Joel Sherrill <joel@…> * bootcard.c: Merge … 4.104.114.84.95
(edit) @3b6c332   11/15/06 14:35:56 Ralf Corsepius 2006-11-15 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @498057d   11/15/06 14:35:15 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @4b02af0   11/15/06 14:34:44 Ralf Corsepius Add RTEMS_AMPOLISH3. 4.104.114.84.95
(edit) @633bae4   11/15/06 14:34:23 Ralf Corsepius Pick up ampolish3 from ac_aux_dir. 4.104.114.84.95
(edit) @d4e28828   11/15/06 14:34:00 Ralf Corsepius AC_PREREQ(2.60). Remove checks for AMPOLISH3. 4.104.114.84.95
(edit) @7a00d74e   11/15/06 14:33:30 Ralf Corsepius Remove RTEMS_AMPOLISH3. 4.104.114.84.95
(edit) @64d01b9   11/15/06 11:03:09 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @e4a0c4e   11/15/06 09:55:27 Ralf Corsepius 2006-11-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @7198611   11/15/06 09:47:09 Ralf Corsepius 2006-11-15 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @f8235c07   11/15/06 06:29:07 Ralf Corsepius 2006-11-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @78897bc   11/11/06 05:12:05 Ralf Corsepius 2006-11-11 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @21a7c424   11/11/06 05:09:26 Ralf Corsepius 2006-11-10 Alain Schaefer <alani@…> * startup/linkcmds: Put … 4.104.114.84.95
(edit) @e1d578d8   11/01/06 16:06:03 Joel Sherrill 2006-11-01 Joel Sherrill <joel@…> * bsp_specs: Fix typo. 4.104.114.84.95
(edit) @550d13e   10/30/06 22:23:46 Joel Sherrill 2006-10-30 Joel Sherrill <joel@…> * startup/rtems-ctor.cc: … 4.104.114.84.95
(edit) @842a8fe1   10/30/06 16:56:10 Joel Sherrill 2006-10-30 Joel Sherrill <joel@…> * .cvsignore: New file. 4.104.114.84.95
(edit) @b174ee8   10/30/06 16:53:54 Joel Sherrill 2006-10-30 Joel Sherrill <joel@…> * bsp_specs: Add crti, … 4.104.114.84.95
(edit) @7ced9142   10/26/06 13:47:07 Joel Sherrill 2006-10-26 Joel Sherrill <joel@…> * configure, … 4.104.114.84.95
(edit) @f6f79332   10/24/06 20:25:23 Joel Sherrill 2006-10-24 Joel Sherrill <joel@…> * shared/start/start.S: … 4.104.114.84.95
(edit) @c959c32   10/24/06 20:24:44 Joel Sherrill 2006-10-24 Joel Sherrill <joel@…> * include/bsp.h: … 4.104.114.84.95
(edit) @1e28c89c   10/24/06 20:21:24 Joel Sherrill 2006-10-24 Alain Schaefer <alani@…> * configure.ac, … 4.104.114.84.95
(edit) @bb932d4   10/23/06 19:39:05 Joel Sherrill 2006-10-23 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @8d41236   10/23/06 19:38:12 Joel Sherrill 2006-10-23 Joel Sherrill <joel@…> * bfin/ChangeLog, … 4.104.114.84.95
(edit) @04cc8d1   10/20/06 06:21:46 Ralf Corsepius New. 4.104.114.84.95
(edit) @bcadcc84   10/20/06 06:15:12 Ralf Corsepius Remove (bogus). 4.104.114.84.95
(edit) @24029b2   10/19/06 19:20:50 Joel Sherrill Fix comment. 4.104.114.84.95
(edit) @e307735   10/19/06 19:18:20 Joel Sherrill 2006-10-19 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @9a60096b   10/19/06 19:16:20 Joel Sherrill 2006-10-19 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @98339b8c   10/19/06 19:16:19 Joel Sherrill 2006-10-19 Joel Sherrill <joel@…> * gdbstub/rtems-stub-glue.c: 4.104.114.84.95
(edit) @104ff62   10/18/06 11:56:36 Ralf Corsepius 2006-10-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @9b5e72b   10/18/06 03:37:19 Ralf Corsepius 2006-10-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @6436036c   10/17/06 17:12:18 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * LICENSE: … 4.104.114.84.95
(edit) @4f5e472   10/17/06 17:09:33 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d6a6cff2   10/17/06 17:06:38 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2e28876   10/17/06 15:49:31 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @57357d9   10/17/06 08:58:44 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @ba2c04f   10/17/06 07:38:02 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @11c60096   10/17/06 06:35:01 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @754610f   10/17/06 06:21:56 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @2c278a4   10/17/06 02:42:28 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1af911b8   10/17/06 02:40:57 Ralf Corsepius Convert to utf-8. 4.104.114.84.95
(edit) @748bc60   10/17/06 02:35:27 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ca97282   10/17/06 02:35:11 Ralf Corsepius Convert to utf-8 4.104.114.84.95
(edit) @0c8c5e3f   10/17/06 02:30:21 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @36e0d53   10/17/06 02:25:26 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @372b8414   10/15/06 05:59:35 Ralf Corsepius Convert to utf-8. 4.104.114.84.95
(edit) @e0987b9d   10/15/06 05:59:17 Ralf Corsepius 2006-10-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @47ebb84   10/15/06 05:53:42 Ralf Corsepius 2006-10-15 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @e6a07e14   10/15/06 05:53:22 Ralf Corsepius Convert to utf-8 4.104.114.84.95
(edit) @2e4524e5   09/14/06 16:20:55 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @c69885a5   09/14/06 15:50:54 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @7323ad0   09/13/06 11:22:13 Ralf Corsepius 2006-09-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c4a0ecf   09/13/06 08:20:37 Ralf Corsepius 2006-09-13 Ralf Corsepius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @21d30494   09/11/06 21:47:05 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @6094c1a   09/11/06 21:46:47 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @158f87b0   09/11/06 21:45:23 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @c5feb602   09/11/06 21:44:06 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * include/mpc5200.h, … 4.104.114.84.95
(edit) @b18803f   09/11/06 21:43:59 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @da2fc6c0   09/11/06 21:43:56 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * console/console.c, … 4.104.114.84.95
(edit) @1883c87   09/11/06 21:43:45 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * console/console.c, … 4.104.114.84.95
(edit) @0b1cb769   09/11/06 21:43:36 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * startup/init5282.c: … 4.104.114.84.95
(edit) @c6fda81   09/11/06 21:43:30 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * console/fb_vga.c, … 4.104.114.84.95
(edit) @126694fa   09/11/06 21:43:24 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @5e14d89   09/11/06 21:41:56 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @cb66894   09/11/06 12:14:53 Chris Johns Remove extra CRLF. 4.104.114.84.95
(edit) @b52f628   09/11/06 12:00:59 Chris Johns Remove extra CRLF. 4.104.114.84.95
(edit) @8f1e4948   09/11/06 11:52:08 Chris Johns Remove extra CRLF. 4.104.114.84.95
(edit) @662c157   09/04/06 23:29:29 strauman * startup/bspstart.c, start/start.S: Since the crude memory … 4.104.114.84.95
