# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 03/28/24 20:40:36 Mon, 03 Jan 2000 14:14:37 GMT Joel Sherrill [e07b6868] * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) Added tm27 stuff. Mon, 03 Jan 2000 14:14:24 GMT Joel Sherrill [db941670] * c/src/tests/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) Added define to trip items that are private to tm27 in bsp.h. Mon, 03 Jan 2000 14:06:42 GMT Joel Sherrill [95273a6] * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric ... Mon, 03 Jan 2000 14:04:22 GMT Joel Sherrill [d5c4681e] * c/src/lib/libbsp/bare/include/Makefile.am (modified) Use shared coverhd.h. Mon, 03 Jan 2000 14:01:02 GMT Joel Sherrill [20385957] * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) Increased minimum stack size so all tests will run. Thu, 23 Dec 1999 22:12:15 GMT Jennifer Averett [6eb3e68] * c/src/tests/psxtests/psxmsgq01/init.c (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) + Tests added for mq_open, mq_close, and mq_unlink Thu, 23 Dec 1999 22:11:01 GMT Jennifer Averett [2e97c01] * c/src/exec/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) + Added routine to remove from namespace. Thu, 23 Dec 1999 22:10:13 GMT Jennifer Averett [afebb3f] * c/src/exec/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) + Added check for name greater than PATH_MAX Thu, 23 Dec 1999 22:09:36 GMT Jennifer Averett [7fbef786] * c/src/exec/posix/src/mqueueopen.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) + Debugged. Thu, 23 Dec 1999 22:08:43 GMT Jennifer Averett [8f12d069] * c/src/exec/posix/src/mqueuenametoid.c (modified) * cpukit/posix/src/mqueuenametoid.c (modified) + Filled in routine. Thu, 23 Dec 1999 22:07:43 GMT Jennifer Averett [96d4aea] * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) + Initial debug Thu, 23 Dec 1999 22:07:11 GMT Jennifer Averett [d4548d1] * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) + Made work + Added checks for valid attribute maxmsg and msgsize + ... Thu, 23 Dec 1999 22:05:25 GMT Jennifer Averett [e1786ee3] * c/src/exec/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueueclose.c (modified) + Fixed errno response to match the POSIX manual. Tue, 21 Dec 1999 20:29:57 GMT Joel Sherrill [2116e33] * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) Reverted the delay logic. Tue, 21 Dec 1999 20:29:40 GMT Joel Sherrill [ed46b47] * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.h (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.h (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.h (modified) Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to ... Tue, 21 Dec 1999 20:28:13 GMT Joel Sherrill [56018097] * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) Now use coverhd.h out of the libbsp/shared directory. Tue, 21 Dec 1999 20:10:04 GMT Joel Sherrill [0d6f0b4] * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (deleted) * c/src/lib/libbsp/bare/include/coverhd.h (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (deleted) * c/src/lib/libbsp/i386/pc386/include/coverhd.h (deleted) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (deleted) * c/src/lib/libbsp/i960/rxgen960/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/dmv177/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/include/coverhd.h (deleted) * c/src/lib/libbsp/shared/include/coverhd.h (deleted) * c/src/lib/libbsp/unix/posix/include/coverhd.h (deleted) Now use shared coverhd.h Tue, 21 Dec 1999 17:06:31 GMT Joel Sherrill [5d807b5] * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c (added) New files. Tue, 21 Dec 1999 17:05:15 GMT Joel Sherrill [a3ba9f98] * c/src/lib/libbsp/powerpc/mcp750/README.MVME2300 (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.MVME2300 (added) * c/src/lib/libbsp/shared/include/coverhd.h (added) New file. Tue, 21 Dec 1999 16:56:31 GMT Joel Sherrill [8437abd4] * c/src/lib/libbsp/powerpc/shared/dec21140/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/shared/dec21140/dec21140.c (deleted) Removed as part of moving this driver to libchip. Tue, 21 Dec 1999 16:20:38 GMT Joel Sherrill [400c552] * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/boot/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/nvram/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/wrapup/Makefile.in (deleted) * c/src/lib/libcpu/hppa1.1/Makefile.am (added) * c/src/lib/libcpu/hppa1.1/Makefile.in (deleted) * c/src/lib/libcpu/hppa1.1/configure.in (added) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (added) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (deleted) * c/src/lib/libcpu/i386/Makefile.am (added) * c/src/lib/libcpu/i386/Makefile.in (deleted) * c/src/lib/libcpu/i386/configure.in (added) * c/src/lib/libcpu/m68k/Makefile.am (added) * c/src/lib/libcpu/m68k/Makefile.in (deleted) * c/src/lib/libcpu/m68k/configure.in (added) * c/src/lib/libcpu/m68k/m68040/Makefile.am (added) * c/src/lib/libcpu/m68k/m68040/Makefile.in (deleted) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (added) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (deleted) * c/src/lib/libcpu/mips/Makefile.am (added) * c/src/lib/libcpu/mips/configure.in (added) * c/src/lib/libcpu/mips64orion/Makefile.am (added) * c/src/lib/libcpu/mips64orion/Makefile.in (deleted) * c/src/lib/libcpu/mips64orion/configure.in (added) * c/src/lib/libcpu/powerpc/Makefile.am (added) * c/src/lib/libcpu/powerpc/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/configure.in (added) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (added) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/shared/Makefile.am (added) * c/src/lib/libcpu/powerpc/shared/Makefile.in (deleted) * c/src/lib/libcpu/sh/Makefile.am (added) * c/src/lib/libcpu/sh/Makefile.in (deleted) * c/src/lib/libcpu/sh/configure.in (added) * c/src/lib/libcpu/sh/sh7032/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (added) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7045/Makefile.am (added) * c/src/lib/libcpu/sh/sh7045/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (added) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (added) * c/src/lib/libcpu/sh/sh7045/include/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (added) * c/src/lib/libcpu/sh/sh7045/null/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (added) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.in (deleted) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (added) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.in (deleted) * c/src/lib/libcpu/sparc/Makefile.am (added) * c/src/lib/libcpu/sparc/Makefile.in (deleted) * c/src/lib/libcpu/sparc/configure.in (added) Removing Makefile.in and adding Makefile.am. These were missed in ... Tue, 21 Dec 1999 15:25:05 GMT Joel Sherrill [fb16fed] * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.in (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.in (modified) Patch rtems-rc-19991203-10.diff from Ralf Corsepius [9ba1f0a] * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) Patch rtems-rc-19991203-9.diff from Ralf Corsepius [369ef189] * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) Patch rtems-rc-19991203-7.diff from Ralf Corsepius [35d7b15] * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) Patch rtems-rc-19991203-7.diff from Ralf Corsepius [5bce35b] * c/src/libnetworking/pppd/chap.c (modified) * cpukit/pppd/chap.c (modified) Made prototype of ChapReceiveSuccess and ChapReceiveFailure match. Tue, 21 Dec 1999 14:34:30 GMT Joel Sherrill [0fe48346] * c/src/lib/libcpu/i386/wrapup/Makefile.in (deleted) * c/src/lib/libcpu/mips64orion/include/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (deleted) Patch rtems-rc-19991203-7.diff from Ralf Corsepius [db3e0108] * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/sapi/Makefile.am (modified) Patch rtems-rc-19991203-6.diff from Ralf Corsepius [8b91282] * c/src/exec/score/cpu/sh/rtems/score/iosh7045.h (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (modified) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * make/custom/gensh2.cfg (modified) Patch rtems-rc-19991203-5.diff from Ralf Corsepius [3ad7602e] * c/src/tests/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/task1.c (modified) Modifications to avoid having the size of the Buffer_addresses array ... Thu, 16 Dec 1999 14:30:34 GMT Joel Sherrill [947c27aa] * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) Spelling error corrected. Tue, 14 Dec 1999 13:30:50 GMT Joel Sherrill [f09ac268] * c/src/libchip/network/dec21140.c (modified) More warnings removed after email with Emmanuel Raguet. Mon, 13 Dec 1999 22:12:03 GMT Joel Sherrill [e8918ec] * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) Patch from Eric Norum to change to gen68360 clock ... Mon, 13 Dec 1999 22:10:45 GMT Joel Sherrill [c629812] * c/src/exec/libcsupport/src/ctermid.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libc/ctermid.c (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) Removed warnings. Mon, 13 Dec 1999 21:21:31 GMT Joel Sherrill [da8ae79b] * c/src/exec/libcsupport/src/getcwd.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libc/getcwd.c (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * cpukit/libcsupport/src/getcwd.c (modified) Warning removal patch from Philip A. Prindeville . Mon, 13 Dec 1999 20:35:09 GMT Joel Sherrill [1c98d28] * c/src/lib/libcpu/sh/sh7045/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) Patch rtems-19991203.sh2.diff from John M. Mills ... Mon, 13 Dec 1999 20:06:27 GMT Joel Sherrill [f9669ce5] * c/src/exec/score/cpu/sh/rtems/score/iosh7032.h (modified) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (modified) Patch from Silverio Diquigiovanni to correct ... Mon, 13 Dec 1999 19:20:38 GMT Joel Sherrill [fc0b91c] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Patch from Eric Norum to make the NTP handler a ... Mon, 13 Dec 1999 17:37:25 GMT Joel Sherrill [5dae90a] * c/src/lib/libbsp/bare/configure.in (added) * c/src/lib/libbsp/bsp.am (added) Patch rtems-rc-19991203-3.diff from Ralf Corsepius [6b79a071] * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) Patch from Jepsen Hans Peter to use ... Mon, 13 Dec 1999 17:03:37 GMT Joel Sherrill [809f4451] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Correction from Eric Norum for timeout in TFTP driver following bug ... Mon, 13 Dec 1999 16:29:01 GMT Joel Sherrill [9537e5e] * c/src/libnetworking/libc/Makefile.in (modified) Patch from Eric Norum to provide more network ... Mon, 13 Dec 1999 16:25:03 GMT Joel Sherrill [38b81b5] * c/src/libchip/network/dec21140.c (modified) Patch from Emmanuel Raguet to correct some ... Mon, 13 Dec 1999 16:16:44 GMT Joel Sherrill [4bdebdfe] * c/src/configure.in (modified) * c/src/wrapup/Makefile.am (modified) Patch rtems-rc-19991203-4.diff from Ralf Corsepius [ad0c286] * c/src/lib/libbsp/bare/Makefile.am (added) * c/src/lib/libbsp/bare/Makefile.in (deleted) * c/src/lib/libbsp/bare/include/Makefile.am (added) * c/src/lib/libbsp/bare/include/Makefile.in (deleted) Patch rtems-rc-19991203-3.diff from Ralf Corsepius [fa178d49] * aclocal/project-root.m4 (modified) * c/src/lib/libbsp/configure.in (modified) Patch rtems-rc-19991203-3.diff from Ralf Corsepius [d16faa2] * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) Patch rtems-rc-19991203-2.diff from Ralf Corsepius [7d91d72] * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/src/semcreate.c (modified) * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * c/src/exec/score/src/coremutexseize.c (modified) * c/src/exec/score/src/coremutexsurrender.c (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sp29/Makefile.am (added) * c/src/tests/sptests/sp29/init.c (added) * c/src/tests/sptests/sp29/sp29.doc (added) * c/src/tests/sptests/sp29/sp29.scn (added) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (added) * testsuites/sptests/sp29/init.c (added) * testsuites/sptests/sp29/sp29.doc (added) * testsuites/sptests/sp29/sp29.scn (added) First attempt at adding simple binary semaphore in addition to the ... Mon, 13 Dec 1999 14:50:09 GMT Joel Sherrill [e9067989] * c/src/tests/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/psx01.scn (modified) Corrected order of output. Mon, 13 Dec 1999 14:49:38 GMT Joel Sherrill [d9230ea] * c/src/exec/libcsupport/src/error.c (modified) * c/src/lib/libc/error.c (modified) * cpukit/libcsupport/src/error.c (modified) Added RTEMS_IO_ERROR. Mon, 13 Dec 1999 14:48:58 GMT Joel Sherrill [49be66d] * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) Now builds and installs properly. Mon, 06 Dec 1999 13:44:56 GMT Joel Sherrill [39e6bbe1] * c/src/librdbg/configure.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/i386/pc386/Makefile.am (deleted) * c/src/librdbg/src/i386/pc386/remdeb_f.x (deleted) Patch patches-rc-19991203-1.diff from Ralf Corsepius [a548c8a5] * c/src/libnetworking/pppd/modem_example/README (added) New file. Fri, 03 Dec 1999 15:46:17 GMT Joel Sherrill [76c356f] * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) Patch from Aleksey (Quality Quorum ) to change the ... Fri, 03 Dec 1999 15:44:28 GMT Joel Sherrill [1e4a7d4] * c/src/libnetworking/pppd/modem_example/16550.h (added) * c/src/libnetworking/pppd/modem_example/modem.c (added) * c/src/libnetworking/pppd/modem_example/modem.h (added) * c/src/libnetworking/pppd/modem_example/ppp.c (added) * c/src/libnetworking/pppd/modem_example/ppp.h (added) * c/src/libnetworking/pppd/modem_example/pppcompress.c (added) Modem example driver for ppp by Tomasz Domin of ... Fri, 03 Dec 1999 14:48:27 GMT Joel Sherrill [a1efd7a] * c/src/libchip/network/dec21140.c (modified) Made to compile on other CPU families. Fri, 03 Dec 1999 14:27:54 GMT Joel Sherrill [ae252c9] * c/src/libchip/network/Makefile.am (modified) Added dec21140 to Makefile.am. Fri, 03 Dec 1999 14:01:11 GMT Joel Sherrill [eb17041] * c/src/lib/libcpu/i386/cpuModel.S (modified) Removed warnings. Fri, 03 Dec 1999 13:53:01 GMT Joel Sherrill [ad9a21a] * c/src/lib/libbsp/powerpc/mcp750/README.OTHERBOARDS (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.OTHERBOARDS (added) New file. Fri, 03 Dec 1999 13:48:53 GMT Joel Sherrill [a0a6f67f] * c/src/lib/libbsp/powerpc/mcp750/times.mcp750 (modified) * c/src/lib/libbsp/powerpc/mcp750/times.mvme2307 (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mcp750 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mvme2307 (added) Added more timing information. Fri, 03 Dec 1999 13:46:13 GMT Joel Sherrill [5707fe9] * c/src/lib/libbsp/powerpc/mcp750/times.mcp750 (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mcp750 (added) New file based on information from . Fri, 03 Dec 1999 13:42:34 GMT Joel Sherrill [5a820308] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/README.dec21140 (added) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (deleted) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/README.dec21140 (added) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.dec21140 (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/libchip/network/README.dec21140 (added) * c/src/libchip/network/dec21140.c (moved) Modification from Emmanuel Raguet to merge the ... Fri, 03 Dec 1999 13:31:56 GMT Joel Sherrill [fc81cc9] * aclocal/check-bsp-cache.m4 (added) * c/src/exec/score/cpu/powerpc/configure.in (added) Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius ... Fri, 03 Dec 1999 13:25:00 GMT Joel Sherrill [4090ebe] * Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/score/cpu/configure.in (deleted) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/configure.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/init.c (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * testsuites/psxtests/psxsem01/init.c (modified) Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius ... Fri, 03 Dec 1999 13:14:08 GMT Joel Sherrill [5ea0bd37] * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) Patch from Rosimildo DaSilva for Cygwin to ... Thu, 02 Dec 1999 17:45:14 GMT Joel Sherrill [43283456] * c/src/exec/score/cpu/Makefile.am (added) * c/src/exec/score/cpu/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/Makefile.am (added) * c/src/exec/score/cpu/powerpc/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (added) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (added) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.in (deleted) * cpukit/score/cpu/Makefile.am (added) * cpukit/score/cpu/powerpc/Makefile.am (added) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Thu, 02 Dec 1999 17:34:50 GMT Joel Sherrill [e492f910] * c/src/tests/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) Jennifer added initial test code. Conditional'ed out until she has ... Thu, 02 Dec 1999 14:58:38 GMT Joel Sherrill [3a96054] * c/src/lib/libbsp/powerpc/mcp750/motorola/Makefile.in (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.in (added) * c/src/lib/libcpu/powerpc/shared/cpuIdent.c (added) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 14:31:19 GMT Joel Sherrill [acc25ee] * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.in (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/c_isr.inl (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.c (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.h (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu_asm.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.in (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/README (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/TODO (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/c_isr.inl (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.c (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.h (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu_asm.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/ppccache.c (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/rtems.S (added) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/console.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/console_reserve_resources.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/console_reserve_resources.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/bootloader/README (added) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (added) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/exception.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/head.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/lib.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/mm.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.h (added) * c/src/lib/libbsp/powerpc/shared/bootloader/ppcboot.lds (added) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.h (added) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/clock/p_clock.c (added) * c/src/lib/libbsp/powerpc/shared/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/console/console.c (moved) * c/src/lib/libbsp/powerpc/shared/console/consoleIo.h (added) * c/src/lib/libbsp/powerpc/shared/console/inch.c (added) * c/src/lib/libbsp/powerpc/shared/console/keyboard.h (added) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (added) * c/src/lib/libbsp/powerpc/shared/console/uart.c (added) * c/src/lib/libbsp/powerpc/shared/console/uart.h (added) * c/src/lib/libbsp/powerpc/shared/dec21140/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/dec21140/dec21140.c (added) * c/src/lib/libbsp/powerpc/shared/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (added) * c/src/lib/libbsp/powerpc/shared/include/nvram.h (added) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (added) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (added) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (added) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (added) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (added) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (added) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (added) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.h (added) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (added) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (added) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/residual/pnp.h (added) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (added) * c/src/lib/libbsp/powerpc/shared/residual/residual.h (added) * c/src/lib/libbsp/powerpc/shared/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/start/start.S (added) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.h (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors_init.c (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/c_isr.inl (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.c (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.h (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu_asm.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/README (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/TODO (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/c_isr.inl (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu_asm.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ppccache.c (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems.S (added) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/asm_utils.S (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.in (added) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (added) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.in (added) * c/src/lib/libcpu/powerpc/new_exception_processing/c_isr.inl (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.c (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.h (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/README (added) * c/src/lib/libcpu/powerpc/old-exceptions/TODO (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.in (added) * c/src/lib/libcpu/powerpc/old_exception_processing/README (added) * c/src/lib/libcpu/powerpc/old_exception_processing/TODO (added) * c/src/lib/libcpu/powerpc/old_exception_processing/c_isr.inl (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (added) * c/src/lib/libcpu/powerpc/old_exception_processing/ppccache.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/rtems.S (added) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme2307.cfg (modified) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 14:10:14 GMT Joel Sherrill [4cf56006] * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (deleted) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 14:00:01 GMT Joel Sherrill [e4ab88f] * c/src/exec/score/cpu/powerpc/mpc750/c_isr.inl (deleted) * c/src/exec/score/cpu/powerpc/mpc750/cpu.c (deleted) * c/src/exec/score/cpu/powerpc/mpc750/cpu.h (deleted) * c/src/exec/score/cpu/powerpc/mpc750/cpu_asm.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/README (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/bootldr.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/em86.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/em86real.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/exception.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/head.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/lib.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/misc.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/mm.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/pci.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/pci.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/ppcboot.lds (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/zlib.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/zlib.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/clock/p_clock.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/consoleIo.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/inch.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/keyboard.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/polled_io.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/uart.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/uart.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/dec21140/dec21140.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/bsp.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/nvram.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/i8259.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq_asm.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq_init.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/openpic/openpic.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/openpic/openpic.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/pci/pci.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/pci/pci.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/residual/pnp.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/residual/residual.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/residual/residual.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/start/start.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/startup/bspstart.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors_init.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/README (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/bootldr.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/em86.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/em86real.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/exception.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/head.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/lib.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/misc.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/mm.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/pci.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/pci.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/ppcboot.lds (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/zlib.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/zlib.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/p_clock.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/consoleIo.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/inch.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/keyboard.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/polled_io.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/uart.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/uart.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/dec21140/dec21140.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/nvram.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/i8259.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq_asm.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq_init.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/openpic.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/openpic.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/pci.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/pci.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/pnp.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/residual.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/residual.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/start.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspstart.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors_init.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/NOTES (deleted) * c/src/lib/libbsp/powerpc/mvme2307/README (deleted) * c/src/lib/libbsp/powerpc/mvme2307/boot/start.S (deleted) * c/src/lib/libbsp/powerpc/mvme2307/bsp_specs (deleted) * c/src/lib/libbsp/powerpc/mvme2307/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/clock/ckinit.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/console/console.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/console/printk.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/include/bsp.h (deleted) * c/src/lib/libbsp/powerpc/mvme2307/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/mvme2307/network/network.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/nvram/nvram.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/NOTES (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/interrupts.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/isa_interrupts.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/pci.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspclean.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspstart.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/linkcmds (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/main.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/setvec.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/timer/timer.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/times (deleted) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/clock/c_clock.c (deleted) * c/src/lib/libcpu/powerpc/mpc750/clock/c_clock.h (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/asm_utils.S (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/raw_exception.c (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/raw_exception.h (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/bat.c (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/bat.h (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/mmuAsm.S (deleted) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (deleted) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 13:54:30 GMT Joel Sherrill [5554279] * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/README (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/TODO (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/c_isr.inl (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.c (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.h (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/cpu_asm.S (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/irq_stub.S (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/ppccache.c (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/rtems.S (deleted) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Wed, 01 Dec 1999 16:00:38 GMT Joel Sherrill [5d3da15b] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Removed debugging printfs. Wed, 01 Dec 1999 15:54:17 GMT Joel Sherrill [017061c] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Patch from Eric Norum to fix a spot in the tftp ... Wed, 01 Dec 1999 15:05:26 GMT Joel Sherrill [955a9ba7] * c/src/exec/score/cpu/a29k/Makefile.am (added) * c/src/exec/score/cpu/a29k/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (added) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/hppa1.1/Makefile.am (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (added) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/i386/Makefile.am (added) * c/src/exec/score/cpu/i386/Makefile.in (deleted) * c/src/exec/score/cpu/i386/rtems/Makefile.am (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/mips/Makefile.am (added) * c/src/exec/score/cpu/mips/rtems/Makefile.am (added) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/Makefile.am (added) * c/src/exec/score/cpu/no_cpu/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (deleted) * cpukit/score/cpu/a29k/Makefile.am (added) * cpukit/score/cpu/hppa1.1/Makefile.am (added) * cpukit/score/cpu/i386/Makefile.am (added) * cpukit/score/cpu/mips/Makefile.am (added) * cpukit/score/cpu/mips64orion/Makefile.am (added) * cpukit/score/cpu/no_cpu/Makefile.am (added) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:46:02 GMT Joel Sherrill [1972b1e] * c/src/exec/score/cpu/a29k/configure.in (added) * c/src/exec/score/cpu/hppa1.1/configure.in (added) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/i386/configure.in (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/mips/configure.in (added) * c/src/exec/score/cpu/mips64orion/configure.in (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/configure.in (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (deleted) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:31:36 GMT Joel Sherrill [7656140] * c/src/exec/score/cpu/a29k/wrap/Makefile.in (deleted) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:22:12 GMT Joel Sherrill [ccf8925b] * c/src/exec/score/cpu/configure.in (modified) * c/src/exec/score/cpu/i960/Makefile.am (added) * c/src/exec/score/cpu/i960/Makefile.in (deleted) * c/src/exec/score/cpu/i960/configure.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.am (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/Makefile.am (added) * c/src/exec/score/cpu/m68k/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/configure.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/sh/Makefile.am (added) * c/src/exec/score/cpu/sh/Makefile.in (deleted) * c/src/exec/score/cpu/sh/configure.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.am (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/Makefile.am (added) * c/src/exec/score/cpu/sparc/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/configure.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/unix/Makefile.am (added) * c/src/exec/score/cpu/unix/Makefile.in (deleted) * c/src/exec/score/cpu/unix/configure.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.am (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (deleted) * cpukit/score/cpu/i960/Makefile.am (added) * cpukit/score/cpu/m68k/Makefile.am (added) * cpukit/score/cpu/sh/Makefile.am (added) * cpukit/score/cpu/sparc/Makefile.am (added) * cpukit/score/cpu/unix/Makefile.am (added) Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:12:58 GMT Joel Sherrill [4a3757f] * c/src/exec/score/cpu/i960/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (deleted) Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius ... Tue, 30 Nov 1999 22:14:28 GMT Joel Sherrill [42881534] * c/src/exec/libnetworking/net/if_ppp.h (added) * c/src/exec/libnetworking/net/ppp-comp.h (added) * c/src/libnetworking/net/if_ppp.h (added) * c/src/libnetworking/net/ppp-comp.h (added) * cpukit/libnetworking/net/if_ppp.h (added) * cpukit/libnetworking/net/ppp-comp.h (added) Added missing files from PPP port. Tue, 30 Nov 1999 22:12:50 GMT Joel Sherrill [d0950ad] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/net/ppp_defs.h (added) * c/src/exec/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/net/ppp_defs.h (added) * c/src/libnetworking/pppd/Makefile.in (added) * c/src/libnetworking/pppd/README (added) * c/src/libnetworking/pppd/STATUS (added) * c/src/libnetworking/pppd/auth.c (added) * c/src/libnetworking/pppd/cbcp.c (added) * c/src/libnetworking/pppd/cbcp.h (added) * c/src/libnetworking/pppd/ccp.c (added) * c/src/libnetworking/pppd/ccp.h (added) * c/src/libnetworking/pppd/chap.c (added) * c/src/libnetworking/pppd/chap.h (added) * c/src/libnetworking/pppd/chap_ms.c (added) * c/src/libnetworking/pppd/chap_ms.h (added) * c/src/libnetworking/pppd/chat.c (added) * c/src/libnetworking/pppd/demand.c (added) * c/src/libnetworking/pppd/fsm.c (added) * c/src/libnetworking/pppd/fsm.h (added) * c/src/libnetworking/pppd/ipcp.c (added) * c/src/libnetworking/pppd/ipcp.h (added) * c/src/libnetworking/pppd/ipxcp.c (added) * c/src/libnetworking/pppd/ipxcp.h (added) * c/src/libnetworking/pppd/lcp.c (added) * c/src/libnetworking/pppd/lcp.h (added) * c/src/libnetworking/pppd/magic.c (added) * c/src/libnetworking/pppd/magic.h (added) * c/src/libnetworking/pppd/main.c (added) * c/src/libnetworking/pppd/md4.c (added) * c/src/libnetworking/pppd/md4.h (added) * c/src/libnetworking/pppd/md5.c (added) * c/src/libnetworking/pppd/md5.h (added) * c/src/libnetworking/pppd/options.c (added) * c/src/libnetworking/pppd/patchlevel.h (added) * c/src/libnetworking/pppd/pathnames.h (added) * c/src/libnetworking/pppd/ppp_tty.c (added) * c/src/libnetworking/pppd/pppd.h (added) * c/src/libnetworking/pppd/rtems-ppp.c (added) * c/src/libnetworking/pppd/upap.c (added) * c/src/libnetworking/pppd/upap.h (added) * c/src/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/net/ppp_defs.h (added) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/pppd/README (added) * cpukit/pppd/STATUS (added) * cpukit/pppd/auth.c (added) * cpukit/pppd/cbcp.c (added) * cpukit/pppd/cbcp.h (added) * cpukit/pppd/ccp.c (added) * cpukit/pppd/ccp.h (added) * cpukit/pppd/chap.c (added) * cpukit/pppd/chap.h (added) * cpukit/pppd/chap_ms.c (added) * cpukit/pppd/chap_ms.h (added) * cpukit/pppd/chat.c (added) * cpukit/pppd/demand.c (added) * cpukit/pppd/fsm.c (added) * cpukit/pppd/fsm.h (added) * cpukit/pppd/ipcp.c (added) * cpukit/pppd/ipcp.h (added) * cpukit/pppd/ipxcp.c (added) * cpukit/pppd/ipxcp.h (added) * cpukit/pppd/lcp.c (added) * cpukit/pppd/lcp.h (added) * cpukit/pppd/magic.c (added) * cpukit/pppd/magic.h (added) * cpukit/pppd/md4.c (added) * cpukit/pppd/md4.h (added) * cpukit/pppd/md5.c (added) * cpukit/pppd/md5.h (added) * cpukit/pppd/options.c (added) * cpukit/pppd/patchlevel.h (added) * cpukit/pppd/pathnames.h (added) * cpukit/pppd/pppd.h (added) * cpukit/pppd/upap.c (added) * cpukit/pppd/upap.h (added) Added port of ppp-2.3.5 from Tomasz Domin of ComArch ... Tue, 30 Nov 1999 19:58:02 GMT Joel Sherrill [48bfd992] * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/cause_intr.c (moved) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/lock.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/shmdr/addlq.c (modified) * c/src/lib/libbsp/shmdr/cnvpkt.c (modified) * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/lib/libbsp/shmdr/fatal.c (modified) * c/src/lib/libbsp/shmdr/getlq.c (modified) * c/src/lib/libbsp/shmdr/getpkt.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/initlq.c (modified) * c/src/lib/libbsp/shmdr/intr.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/mpisr.c (modified) * c/src/lib/libbsp/shmdr/poll.c (modified) * c/src/lib/libbsp/shmdr/receive.c (modified) * c/src/lib/libbsp/shmdr/retpkt.c (modified) * c/src/lib/libbsp/shmdr/send.c (modified) * c/src/lib/libbsp/shmdr/setckvec.c (modified) * c/src/lib/libbsp/shmdr/shm.h (deleted) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/cause_intr.c (moved) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/setckvec.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h. ... Tue, 30 Nov 1999 16:52:21 GMT Joel Sherrill [1563d8c] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) Removed duplicate definition of rtems_filesystem_umask. Tue, 30 Nov 1999 14:43:46 GMT Joel Sherrill [1591a1aa] * c/src/librdbg/src/i386/any/Makefile.in (deleted) * c/src/librdbg/src/i386/pc386/Makefile.in (deleted) * c/src/librpc/src/Makefile.in (deleted) * c/src/librtems++/src/Makefile.in (deleted) * c/src/tests/mptests/mp04/node1/Makefile.in (deleted) * c/src/wrapup/Makefile.in (deleted) * scripts/aclocal.m4 (deleted) Uncommitted remains of a previous patch from Ralf Corsepius ... Tue, 30 Nov 1999 14:03:29 GMT Joel Sherrill [116e54ad] * c/src/librdbg/src/powerpc/mcp750/Makefile.am (added) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (added) * c/src/tests/itrontests/itronhello/Makefile.am (added) * c/src/tests/itrontests/itronhello/Makefile.in (deleted) * c/src/tests/itrontests/itronmbf01/Makefile.am (added) * c/src/tests/itrontests/itronmbf01/Makefile.in (deleted) * c/src/tests/itrontests/itronmbox01/Makefile.am (added) * c/src/tests/itrontests/itronmbox01/Makefile.in (deleted) * c/src/tests/itrontests/itronsem01/Makefile.am (added) * c/src/tests/itrontests/itronsem01/Makefile.in (deleted) * c/src/tests/itrontests/itrontask01/Makefile.am (added) * c/src/tests/itrontests/itrontask01/Makefile.in (deleted) * c/src/tests/itrontests/itrontask02/Makefile.am (added) * c/src/tests/itrontests/itrontask02/Makefile.in (deleted) * c/src/tests/itrontests/itrontask03/Makefile.am (added) * c/src/tests/itrontests/itrontask03/Makefile.in (deleted) * c/src/tests/itrontests/itrontask04/Makefile.am (added) * c/src/tests/itrontests/itrontask04/Makefile.in (deleted) * c/src/tests/itrontests/itrontests.am (added) * c/src/tests/itrontests/itrontime01/Makefile.am (added) * c/src/tests/itrontests/itrontime01/Makefile.in (deleted) * c/src/tests/mptests/mptests.am (added) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (added) * c/src/tests/tmitrontests/tmitronsem01/Makefile.in (deleted) * c/src/tests/tmitrontests/tmitrontests.am (added) * testsuites/itrontests/itronhello/Makefile.am (added) * testsuites/itrontests/itronmbf01/Makefile.am (added) * testsuites/itrontests/itronmbox01/Makefile.am (added) * testsuites/itrontests/itronsem01/Makefile.am (added) * testsuites/itrontests/itrontask01/Makefile.am (added) * testsuites/itrontests/itrontask02/Makefile.am (added) * testsuites/itrontests/itrontask03/Makefile.am (added) * testsuites/itrontests/itrontask04/Makefile.am (added) * testsuites/itrontests/itrontests.am (added) * testsuites/itrontests/itrontime01/Makefile.am (added) * testsuites/mptests/mptests.am (added) * testsuites/tmitrontests/tmitronsem01/Makefile.am (added) * testsuites/tmitrontests/tmitrontests.am (added) Uncommitted remains of a previous patch from Ralf Corsepius ... Tue, 30 Nov 1999 13:58:59 GMT Joel Sherrill [79f2e19] * c/src/lib/libbsp/powerpc/mcp750/console/console_reserve_resources.c (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/console_reserve_resources.c (added) Split from console.c to eliminate dependencies. Tue, 30 Nov 1999 13:46:28 GMT Joel Sherrill [e4b25c4] * c/src/exec/libcsupport/src/ttyname.c (modified) * c/src/exec/libcsupport/src/ttyname_r.c (modified) * c/src/lib/libc/ttyname.c (modified) * c/src/lib/libc/ttyname_r.c (modified) * cpukit/libcsupport/src/ttyname.c (modified) * cpukit/libcsupport/src/ttyname_r.c (modified) Corrected so they would compile with POSIX disabled. Mon, 29 Nov 1999 15:45:11 GMT Joel Sherrill [1d9a2fc] * c/make/configure.in (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/console.c (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/console.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * c/src/tests/Makefile.am (modified) * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.in (modified) * c/src/tests/itrontests/itronmbf01/Makefile.in (modified) * c/src/tests/itrontests/itronmbox01/Makefile.in (modified) * c/src/tests/itrontests/itronsem01/Makefile.in (modified) * c/src/tests/itrontests/itrontask01/Makefile.in (modified) * c/src/tests/itrontests/itrontask02/Makefile.in (modified) * c/src/tests/itrontests/itrontask03/Makefile.in (modified) * c/src/tests/itrontests/itrontask04/Makefile.in (modified) * c/src/tests/itrontests/itrontime01/Makefile.in (modified) * c/src/tests/mptests/Makefile.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (deleted) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/tmitrontests/Makefile.am (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/include/timesys.h (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.in (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * testsuites/Makefile.am (modified) * testsuites/itrontests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/tmitrontests/Makefile.am (modified) * testsuites/tmitrontests/include/timesys.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius [64f55e7] * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mutexmp.c (modified) * c/src/exec/posix/src/mutexsetprioceiling.c (modified) * c/src/exec/posix/src/mutexunlock.c (modified) * c/src/exec/posix/src/semaphoremp.c (modified) * c/src/exec/posix/src/sempost.c (modified) * c/src/exec/posix/src/semunlink.c (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mutexmp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/semaphoremp.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semunlink.c (modified) Made sure POSIX would build with MP enabled. Mon, 29 Nov 1999 15:10:30 GMT Joel Sherrill [3dfe0b27] * c/src/exec/libcsupport/src/mount.c (modified) * c/src/lib/libc/mount.c (modified) * cpukit/libcsupport/src/mount.c (modified) Fixed spacing. Wed, 24 Nov 1999 14:19:26 GMT Joel Sherrill [c4ea5efc] * c/src/tests/mptests/mp01/Makefile.am (added) * c/src/tests/mptests/mp01/Makefile.in (deleted) * c/src/tests/mptests/mp01/node1/Makefile.am (added) * c/src/tests/mptests/mp01/node1/Makefile.in (deleted) * c/src/tests/mptests/mp01/node2/Makefile.am (added) * c/src/tests/mptests/mp01/node2/Makefile.in (deleted) * c/src/tests/mptests/mp02/Makefile.am (added) * c/src/tests/mptests/mp02/Makefile.in (deleted) * c/src/tests/mptests/mp02/node1/Makefile.am (added) * c/src/tests/mptests/mp02/node1/Makefile.in (deleted) * c/src/tests/mptests/mp02/node2/Makefile.am (added) * c/src/tests/mptests/mp02/node2/Makefile.in (deleted) * c/src/tests/mptests/mp03/Makefile.am (added) * c/src/tests/mptests/mp03/Makefile.in (deleted) * c/src/tests/mptests/mp03/node1/Makefile.am (added) * c/src/tests/mptests/mp03/node1/Makefile.in (deleted) * c/src/tests/mptests/mp03/node2/Makefile.am (added) * c/src/tests/mptests/mp04/Makefile.am (added) * c/src/tests/mptests/mp04/Makefile.in (deleted) * c/src/tests/mptests/mp04/node1/Makefile.am (added) * c/src/tests/mptests/mp04/node2/Makefile.am (added) * c/src/tests/mptests/mp04/node2/Makefile.in (deleted) * c/src/tests/mptests/mp05/Makefile.am (added) * c/src/tests/mptests/mp05/Makefile.in (deleted) * c/src/tests/mptests/mp05/node1/Makefile.am (added) * c/src/tests/mptests/mp05/node1/Makefile.in (deleted) * c/src/tests/mptests/mp05/node2/Makefile.am (added) * c/src/tests/mptests/mp05/node2/Makefile.in (deleted) * c/src/tests/mptests/mp06/Makefile.am (added) * c/src/tests/mptests/mp06/Makefile.in (deleted) * c/src/tests/mptests/mp06/node1/Makefile.am (added) * c/src/tests/mptests/mp06/node1/Makefile.in (deleted) * c/src/tests/mptests/mp06/node2/Makefile.am (added) * c/src/tests/mptests/mp06/node2/Makefile.in (deleted) * c/src/tests/mptests/mp07/Makefile.am (added) * c/src/tests/mptests/mp07/Makefile.in (deleted) * c/src/tests/mptests/mp07/node1/Makefile.am (added) * c/src/tests/mptests/mp07/node1/Makefile.in (deleted) * c/src/tests/mptests/mp07/node2/Makefile.am (added) * c/src/tests/mptests/mp07/node2/Makefile.in (deleted) * c/src/tests/mptests/mp08/Makefile.am (added) * c/src/tests/mptests/mp08/Makefile.in (deleted) * c/src/tests/mptests/mp08/node1/Makefile.am (added) * c/src/tests/mptests/mp08/node1/Makefile.in (deleted) * c/src/tests/mptests/mp08/node2/Makefile.am (added) * c/src/tests/mptests/mp08/node2/Makefile.in (deleted) * c/src/tests/mptests/mp09/Makefile.am (added) * c/src/tests/mptests/mp09/Makefile.in (deleted) * c/src/tests/mptests/mp09/node1/Makefile.am (added) * c/src/tests/mptests/mp09/node1/Makefile.in (deleted) * c/src/tests/mptests/mp09/node2/Makefile.am (added) * c/src/tests/mptests/mp09/node2/Makefile.in (deleted) * c/src/tests/mptests/mp10/Makefile.am (added) * c/src/tests/mptests/mp10/Makefile.in (deleted) * c/src/tests/mptests/mp10/node1/Makefile.am (added) * c/src/tests/mptests/mp10/node1/Makefile.in (deleted) * c/src/tests/mptests/mp10/node2/Makefile.am (added) * c/src/tests/mptests/mp10/node2/Makefile.in (deleted) * c/src/tests/mptests/mp11/Makefile.am (added) * c/src/tests/mptests/mp11/Makefile.in (deleted) * c/src/tests/mptests/mp11/node1/Makefile.am (added) * c/src/tests/mptests/mp11/node1/Makefile.in (deleted) * c/src/tests/mptests/mp11/node2/Makefile.am (added) * c/src/tests/mptests/mp11/node2/Makefile.in (deleted) * c/src/tests/mptests/mp12/Makefile.am (added) * c/src/tests/mptests/mp12/Makefile.in (deleted) * c/src/tests/mptests/mp12/node1/Makefile.am (added) * c/src/tests/mptests/mp12/node1/Makefile.in (deleted) * c/src/tests/mptests/mp12/node2/Makefile.am (added) * c/src/tests/mptests/mp12/node2/Makefile.in (deleted) * c/src/tests/mptests/mp13/Makefile.am (added) * c/src/tests/mptests/mp13/Makefile.in (deleted) * c/src/tests/mptests/mp13/node1/Makefile.am (added) * c/src/tests/mptests/mp13/node1/Makefile.in (deleted) * c/src/tests/mptests/mp13/node2/Makefile.am (added) * c/src/tests/mptests/mp13/node2/Makefile.in (deleted) * c/src/tests/mptests/mp14/Makefile.am (added) * c/src/tests/mptests/mp14/Makefile.in (deleted) * c/src/tests/mptests/mp14/node1/Makefile.am (added) * c/src/tests/mptests/mp14/node1/Makefile.in (deleted) * c/src/tests/mptests/mp14/node2/Makefile.am (added) * c/src/tests/mptests/mp14/node2/Makefile.in (deleted) * testsuites/mptests/mp01/Makefile.am (added) * testsuites/mptests/mp01/node1/Makefile.am (added) * testsuites/mptests/mp01/node2/Makefile.am (added) * testsuites/mptests/mp02/Makefile.am (added) * testsuites/mptests/mp02/node1/Makefile.am (added) * testsuites/mptests/mp02/node2/Makefile.am (added) * testsuites/mptests/mp03/Makefile.am (added) * testsuites/mptests/mp03/node1/Makefile.am (added) * testsuites/mptests/mp03/node2/Makefile.am (added) * testsuites/mptests/mp04/Makefile.am (added) * testsuites/mptests/mp04/node1/Makefile.am (added) * testsuites/mptests/mp04/node2/Makefile.am (added) * testsuites/mptests/mp05/Makefile.am (added) * testsuites/mptests/mp05/node1/Makefile.am (added) * testsuites/mptests/mp05/node2/Makefile.am (added) * testsuites/mptests/mp06/Makefile.am (added) * testsuites/mptests/mp06/node1/Makefile.am (added) * testsuites/mptests/mp06/node2/Makefile.am (added) * testsuites/mptests/mp07/Makefile.am (added) * testsuites/mptests/mp07/node1/Makefile.am (added) * testsuites/mptests/mp07/node2/Makefile.am (added) * testsuites/mptests/mp08/Makefile.am (added) * testsuites/mptests/mp08/node1/Makefile.am (added) * testsuites/mptests/mp08/node2/Makefile.am (added) * testsuites/mptests/mp09/Makefile.am (added) * testsuites/mptests/mp09/node1/Makefile.am (added) * testsuites/mptests/mp09/node2/Makefile.am (added) * testsuites/mptests/mp10/Makefile.am (added) * testsuites/mptests/mp10/node1/Makefile.am (added) * testsuites/mptests/mp10/node2/Makefile.am (added) * testsuites/mptests/mp11/Makefile.am (added) * testsuites/mptests/mp11/node1/Makefile.am (added) * testsuites/mptests/mp11/node2/Makefile.am (added) * testsuites/mptests/mp12/Makefile.am (added) * testsuites/mptests/mp12/node1/Makefile.am (added) * testsuites/mptests/mp12/node2/Makefile.am (added) * testsuites/mptests/mp13/Makefile.am (added) * testsuites/mptests/mp13/node1/Makefile.am (added) * testsuites/mptests/mp13/node2/Makefile.am (added) * testsuites/mptests/mp14/Makefile.am (added) * testsuites/mptests/mp14/node1/Makefile.am (added) * testsuites/mptests/mp14/node2/Makefile.am (added) Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius [63bdbbd] * c/src/exec/score/cpu/a29k/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (added) * c/src/exec/score/cpu/i386/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (added) * c/src/exec/score/cpu/i960/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i960/wrap/Makefile.in (added) * c/src/exec/score/cpu/m68k/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (added) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (added) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (added) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (added) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (added) * c/src/exec/score/cpu/sh/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sh/wrap/Makefile.in (added) * c/src/exec/score/cpu/sparc/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (added) * c/src/exec/score/cpu/unix/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/unix/wrap/Makefile.in (added) Readding files mistakenly removed. Tue, 23 Nov 1999 15:53:09 GMT Joel Sherrill [49da88c] * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/sapi/Makefile.am (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/host.cfg.in (modified) Patch rtems-rc-19991117-16.diff from Ralf Corsepius [748cdca9] * c/src/exec/score/cpu/powerpc/Makefile.in (added) Readding Makefile.in's accidentally removed. Tue, 23 Nov 1999 14:54:42 GMT Joel Sherrill [3772e2c] * c/src/lib/libcpu/i386/cpu.h (modified) *** empty log message *** Tue, 23 Nov 1999 14:20:41 GMT Joel Sherrill [a1bcc6e9] * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/include/Makefile.am (moved) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/support/include/pmacros.h (deleted) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/include/Makefile.am (moved) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) Moved pmacros.h to include not support/include. Tue, 23 Nov 1999 14:16:15 GMT Joel Sherrill [f26a3ab5] * c/src/tests/support/stubdr/Makefile.am (added) * c/src/tests/support/stubdr/Makefile.in (deleted) * c/src/tests/support/wrapup/Makefile.am (added) * c/src/tests/support/wrapup/Makefile.in (deleted) Patch rtems-rc-19991117-15.diff from Ralf Corsepius [23e3f642] * automake/lib.am (added) * c/src/exec/librpc/src/Makefile.am (added) * c/src/librdbg/src/i386/any/Makefile.am (added) * c/src/librdbg/src/i386/pc386/Makefile.am (added) * c/src/librpc/src/Makefile.am (added) * c/src/librtems++/src/Makefile.am (added) * c/src/tests/samples/sample.am (added) * c/src/tests/sptests/spsize/size.scn (added) * c/src/tests/tmtests/tmtests.am (added) * c/src/wrapup/Makefile.am (added) * cpukit/librpc/src/Makefile.am (added) * testsuites/samples/sample.am (added) * testsuites/sptests/spsize/size.scn (added) * testsuites/tmtests/tmtests.am (added) Missed in previous automake conversion patches from Ralf Corsepius ... Tue, 23 Nov 1999 13:57:02 GMT Joel Sherrill [9f4868c] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/pc386.cfg (modified) * testsuites/psxtests/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) Miscellaneous patches from Ralf Corsepius ... Tue, 23 Nov 1999 13:52:59 GMT Joel Sherrill [d5b004b] * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) Patch from Ralf Corsepius to convert the ...
