# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 02:15:11 Mon, 11 May 1998 17:39:59 GMT Joel Sherrill [c4638fff] * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/_execve.c (added) new file to support execv family support in newlib Mon, 11 May 1998 17:39:38 GMT Joel Sherrill [d37ea462] * c/src/lib/libc/syscalls.c (modified) execv*() now comes from newlib. Mon, 04 May 1998 12:41:42 GMT Joel Sherrill [47d1f5d8] * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/system.h (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/system.h (modified) Fixed prototype of Fatal_Extension. Fixed interface to cofndefs.h ... Mon, 04 May 1998 12:41:07 GMT Joel Sherrill [161e1b3f] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/termios.c (modified) Patch from Eric Norum to switch to termios callback structure, add ... Mon, 04 May 1998 12:40:21 GMT Joel Sherrill [55951bc] * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) Switched to termios callback structure. Mon, 04 May 1998 12:40:09 GMT Joel Sherrill [f35abd4] * c/src/lib/libbsp/powerpc/papyrus/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Corrected and added sections to link cleanly under powerpc-rtems (ELF). Mon, 04 May 1998 12:39:21 GMT Joel Sherrill [f69d686] * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) Removed warning for unnecessary reference to start as entry point. Mon, 04 May 1998 12:38:53 GMT Joel Sherrill [36a14a96] * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) Patch from Eric Norum to switch to termios callback structure and ... Mon, 04 May 1998 12:37:35 GMT Joel Sherrill [5ee559ac] * c/src/lib/libbsp/i386/force386/startup/linkcmds (modified) Corrected and added sections to link cleanly under i386-rtemself. Mon, 04 May 1998 12:36:59 GMT Joel Sherrill [b77b2674] * c/src/exec/score/cpu/sh/sh.h (modified) fixed swap of unsigned16 Mon, 04 May 1998 12:35:22 GMT Joel Sherrill [10b3c9b] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Added default value for CONFIGURE_MAXIMUM_POSIX_THREADS since it is ... Sat, 02 May 1998 12:12:14 GMT Joel Sherrill [3e367452] * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) removed warning for implicit declaration of idtsim__exit() Sat, 02 May 1998 12:11:23 GMT Joel Sherrill [36aba21] * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) removed warning for implicit declaration of resolve() Sat, 02 May 1998 12:10:18 GMT Joel Sherrill [269707e6] * c/src/lib/libbsp/m68k/ods68302/startup/trace.c (modified) removed warning for `#ifdef' argument starts with a digit Sat, 02 May 1998 12:09:11 GMT Joel Sherrill [17f57736] * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/start332/start332.c (modified) * c/src/lib/libbsp/m68k/efi68k/start/start.c (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/start68k.c (modified) removed warning for implicit declaration of boot_card() Thu, 30 Apr 1998 16:48:40 GMT Joel Sherrill [d74daf9] * c/src/exec/score/cpu/i386/i386.h (modified) Fixed case where wrong variable was used. Thu, 30 Apr 1998 14:14:12 GMT Joel Sherrill [990f857] * c/src/tests/tools/Makefile.in (added) botched file -- removed from repository and readded Thu, 30 Apr 1998 11:43:19 GMT Joel Sherrill [2e34f4ad] * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) Removed tripling of workspace API when POSIX API is enabled. ... Thu, 30 Apr 1998 11:41:57 GMT Joel Sherrill [ba05e31] * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) Added wildcard to switch for monitor and termios. Thu, 30 Apr 1998 11:41:09 GMT Joel Sherrill [b7be9c30] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Removed redundant "* 1024" which exploded the size of the workspace. Thu, 30 Apr 1998 11:40:28 GMT Joel Sherrill [a524c00] * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Added sections and redirected some to RAM to avoid warnings. Thu, 30 Apr 1998 11:40:07 GMT Joel Sherrill [1ca488b] * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) Added sections to remove warnings Thu, 30 Apr 1998 10:46:52 GMT Joel Sherrill [c719991] * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) moved tools to bsp directory Wed, 29 Apr 1998 18:41:53 GMT Joel Sherrill [2993cd3f] * c/src/tests/tools/generic/difftest (modified) Added support for debug variants on tests. Mon, 27 Apr 1998 18:42:04 GMT Joel Sherrill [96d56b3] * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (deleted) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * make/custom/pc386.cfg (modified) Update from Pedro Romano . Mon, 27 Apr 1998 18:18:13 GMT Joel Sherrill [0c508af] * c/src/exec/score/cpu/i386/i386.h (modified) Added I386_HAS_BSWAP cpu model feature flag so swap u32 could take ... Mon, 27 Apr 1998 16:10:16 GMT Joel Sherrill [b0aba4c4] * c/src/exec/score/cpu/a29k/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i960/i960.h (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sh/sh.h (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) Added swap of unsigned16 Mon, 27 Apr 1998 15:30:59 GMT Joel Sherrill [eac9871] * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) Fixed spelling errors. Mon, 27 Apr 1998 15:28:43 GMT Joel Sherrill [0153d180] * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) Fixed trace bit manipulation per requests from Eric Norum and Chris ... Mon, 27 Apr 1998 15:14:30 GMT Joel Sherrill [baa876a4] * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/check.c (modified) Cosmetic fix from Eric Norum: This makes the headings line up ... Mon, 27 Apr 1998 14:39:51 GMT Joel Sherrill [edbb81d0] * c/src/lib/libc/newlibif.c (modified) Removed redundant implementation of tcgetattr and tcsetattr. Mon, 27 Apr 1998 14:20:25 GMT Joel Sherrill [21c1513] * c/src/make/host.cfg.in (modified) * make/host.cfg.in (modified) Fixed bad CVS Id string. Removed unnecessary definition of "ED". Mon, 27 Apr 1998 14:19:54 GMT Joel Sherrill [36848ce] * c/src/lib/start/sh/start.s (modified) Clean up patch from Ralf Corsepius. Mon, 27 Apr 1998 14:19:25 GMT Joel Sherrill [cf59d56b] * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) Fix from Ralf Corsepius: use a wildcard rule instead of ... Mon, 27 Apr 1998 14:18:38 GMT Joel Sherrill [008faafd] * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) Added shared directory. Mon, 27 Apr 1998 14:18:11 GMT Joel Sherrill [7e2cc64] * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) Removed extra (bad) CVS Id string. Mon, 27 Apr 1998 14:17:52 GMT Joel Sherrill [0a3a3ae6] * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) Fixed CVS Id string and removed bogus comment. Mon, 27 Apr 1998 14:17:16 GMT Joel Sherrill [6b52fe5] * c/src/lib/libbsp/shared/bsplibc.c (modified) Fix from Ralf Corsepius: + adding #include to fix ... Mon, 27 Apr 1998 14:16:29 GMT Joel Sherrill [72aa8cf] * c/src/exec/score/cpu/a29k/amd.ah (modified) * cpukit/score/cpu/a29k/amd.ah (modified) Fixed CVS Id Mon, 27 Apr 1998 13:51:23 GMT Joel Sherrill [9a993ed5] * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/tmtests/tm09/system.h (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/tmtests/tm09/system.h (modified) Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory ... Mon, 27 Apr 1998 13:51:02 GMT Joel Sherrill [6ce14e7] * c/src/tests/psxtests/psx10/psx10.scn (modified) * testsuites/psxtests/psx10/psx10.scn (modified) Fixed screen to match actual output. Mon, 27 Apr 1998 13:49:42 GMT Joel Sherrill [308aed9b] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Added numerous entries to make the memory calculation more accurate: ... Mon, 27 Apr 1998 13:46:45 GMT Joel Sherrill [20fff72] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) Moved POSIX_signals_Siginfo_node structure definition to ... Mon, 27 Apr 1998 13:46:18 GMT Joel Sherrill [9f0dfea] * c/src/exec/posix/headers/psignal.h (modified) * c/src/exec/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/include/rtems/posix/psignal.h (modified) Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid ... Mon, 27 Apr 1998 13:44:54 GMT Joel Sherrill [39b3d87] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) Reset the pthread attributes structure so the proper error would be ... Sat, 18 Apr 1998 17:26:41 GMT Joel Sherrill [0903597f] * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) psim now runs in both debug and non-debug mode. Sat, 18 Apr 1998 17:25:35 GMT Joel Sherrill [4955afc] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) rtems_libio_number_iops is now defined in confdefs.h so the maximum ... Sat, 18 Apr 1998 17:24:56 GMT Joel Sherrill [43908825] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Changed to account for libio's maximum_semaphores as well as its ... Sat, 18 Apr 1998 17:24:04 GMT Joel Sherrill [b25d3d03] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) Changed version number so script will work. Wed, 15 Apr 1998 22:16:43 GMT Joel Sherrill [edffc054] * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/check.c (modified) Fixed so this would compile without warning. Wed, 15 Apr 1998 22:16:22 GMT Joel Sherrill [8a1636d] * c/src/exec/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) Added bh, ch, dh, bl, cl, and dl register macros. Wed, 15 Apr 1998 22:09:28 GMT Joel Sherrill [70ad028] * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) update from Eric Norum Wed, 15 Apr 1998 22:09:17 GMT Joel Sherrill [c0daf807] * c/src/lib/libbsp/shared/bsplibc.c (added) New file created by extracting common initialization from every BSP's ... Wed, 15 Apr 1998 20:50:31 GMT Joel Sherrill [bd9c3d1] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/include/bsp.h (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/main.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/sapi/include/confdefs.h (modified) Numerous changes which in total greatly reduced the amount of source ... Wed, 15 Apr 1998 15:13:01 GMT Joel Sherrill [b6394ae] * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/README (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.s (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) Transitioned to shared bsp_libc_init() and cleaned up comments. Wed, 15 Apr 1998 15:09:38 GMT Joel Sherrill [d07d3eec] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) Initial sets of user extensions now have memory allocated on the fly ... Wed, 15 Apr 1998 15:08:49 GMT Joel Sherrill [71f4beb] * c/src/lib/libmisc/stackchk/README (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/lib/libmisc/stackchk/stackchk.h (modified) * c/src/libmisc/stackchk/README (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/stackchk/README (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) Stack check now initialized as part of initial extension set. Wed, 15 Apr 1998 00:10:03 GMT Joel Sherrill [9b64c2d5] * c/src/ada/rtems.ads (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * cpukit/ada/rtems.ads (modified) * doc/user/conf.t (modified) Per suggestion from Eric Norum, went from one initial extension set ... Wed, 15 Apr 1998 00:02:10 GMT Joel Sherrill [0451b44] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) Per suggestion from Eric Norum, went from one initial extension set ... Tue, 14 Apr 1998 23:00:33 GMT Joel Sherrill [7780978] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to ralf-980414 Tue, 14 Apr 1998 22:56:31 GMT Joel Sherrill [01a4990] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Account for interrupt stack space Tue, 14 Apr 1998 22:44:49 GMT Joel Sherrill [4381e50] * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/Linux-posix.cfg (modified) Ralf Corsepius suggested a way to get rid of UNIX compiler files and ... Tue, 14 Apr 1998 21:32:12 GMT Joel Sherrill [c244a9ee] * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) Stack checker extension now accounted for in confdefs.h Tue, 14 Apr 1998 21:30:10 GMT Joel Sherrill [ab97da95] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Added stack checker extension Tue, 14 Apr 1998 20:54:26 GMT Joel Sherrill [3b89891] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * cpukit/sapi/include/confdefs.h (modified) Now accounts for region used by RTEMS malloc and extension used by ... Tue, 14 Apr 1998 20:52:31 GMT Joel Sherrill [7a75c323] * c/src/lib/libbsp/shared/main.c (modified) Removed recursive call to exit Tue, 14 Apr 1998 20:52:15 GMT Joel Sherrill [9c329a5c] * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspclean.c (added) Moved bspclean from assembly to C and made exit act properly. Tue, 14 Apr 1998 20:29:35 GMT Joel Sherrill [c8bc6e45] * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim (added) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) new file Tue, 14 Apr 1998 19:56:25 GMT Joel Sherrill [e6e5e47] * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) Removed delay macro Tue, 14 Apr 1998 19:54:24 GMT Joel Sherrill [993e1b5] * c/src/exec/score/cpu/powerpc/README (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.s (modified) * c/src/exec/score/cpu/powerpc/irq_stub.s (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) * c/src/exec/score/cpu/powerpc/ppctypes.h (modified) * c/src/exec/score/cpu/powerpc/rtems.s (modified) Refreshing effort from Avenger. Tue, 14 Apr 1998 19:54:04 GMT Joel Sherrill [a34ab1b2] * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) removed shmsupp Tue, 14 Apr 1998 19:53:16 GMT Joel Sherrill [22764c0c] * c/src/lib/libbsp/Makefile.in (modified) Corrected comment Tue, 14 Apr 1998 19:49:13 GMT Joel Sherrill [8961188] * c/src/lib/libbsp/powerpc/psim/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/README (added) * c/src/lib/libbsp/powerpc/psim/bsp_specs (added) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/clock/clock.c (added) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/console/console.c (added) * c/src/lib/libbsp/powerpc/psim/console/consupp.s (added) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (added) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/README (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/lock.c (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/mpisr.c (added) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/start/startsim.s (added) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/startsim/startsim.s (added) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/psim/startup/device-tree (added) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/psim/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/timer/timer.c (added) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/tools/runtest (added) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/psim/vectors/README (added) * c/src/lib/libbsp/powerpc/psim/vectors/align_h.s (added) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.s (added) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (added) new files Mon, 06 Apr 1998 21:41:50 GMT Joel Sherrill [7ff01ac] * c/src/lib/libmisc/monitor/mon-monitor.c (modified) * c/src/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) Increased stack space of the monitor task. Mon, 06 Apr 1998 20:29:58 GMT Joel Sherrill [45111d77] * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) Increased stack size so test would run in debug mode. Mon, 06 Apr 1998 15:57:58 GMT Joel Sherrill [c796ea9] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libc/syscalls.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) More stuff removed as a result of using newlib's isatty() ... Fri, 03 Apr 1998 18:46:16 GMT Joel Sherrill [5fafa0e] * c/src/make/directory.cfg (modified) * make/directory.cfg (modified) Added test so the build procedure would stop if a directory did not ... Fri, 03 Apr 1998 18:45:42 GMT Joel Sherrill [b82c957] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/newlibif.c (modified) * c/src/lib/libc/syscalls.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) Removed isatty() since we are now using newlib's implementation as a ... Fri, 03 Apr 1998 18:44:44 GMT Joel Sherrill [a456074d] * c/src/exec/posix/base/aio.h (modified) * c/src/exec/posix/base/unistd.h (modified) * c/src/exec/posix/include/aio.h (modified) * c/src/exec/posix/include/unistd.h (modified) * cpukit/posix/include/aio.h (modified) Made these have real constants. Tue, 31 Mar 1998 16:59:07 GMT Joel Sherrill [9a355cb] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0-beta2 Tue, 31 Mar 1998 14:19:27 GMT Joel Sherrill [5e34bf4] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) Added "sigemptyset()" call to insure that the memcmp() would work. ... Mon, 30 Mar 1998 14:03:04 GMT Joel Sherrill [c895f42a] * c/src/tests/samples/Makefile.in (modified) Were looking at the wrong C++ variable. Mon, 30 Mar 1998 14:01:19 GMT Joel Sherrill [8f95b5f] * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/bsppost.c (added) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) Moved bsp_postdriver_hook() to a shared file and made it a common ... Mon, 30 Mar 1998 13:59:07 GMT Joel Sherrill [6937fd82] * c/src/lib/libbsp/i386/go32/bsp_specs (modified) Renamed crt0.o to crt0_go32.o to avoid build problems. Mon, 30 Mar 1998 13:42:13 GMT Joel Sherrill [33442772] * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/start/80386ex.h (added) * c/src/lib/libbsp/i386/i386ex/start/80386ex.inc (added) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/start/macros.inc (added) * c/src/lib/libbsp/i386/i386ex/start/start.s (added) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/README (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) Update from "erik.ivanenko" . Also ... Fri, 27 Mar 1998 21:08:59 GMT Joel Sherrill [ece79bb1] * c/src/lib/libc/syscalls.c (modified) GO32 does not have sockets. Fri, 27 Mar 1998 19:42:58 GMT Joel Sherrill [a30359bb] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) Changed int to unsigned32 to match cpu.h. Fri, 27 Mar 1998 16:34:25 GMT Joel Sherrill [3973e40] * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/lib/libc/__gettod.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) Should have included before checking for ifdef RTEMS_UNIX. ... Thu, 26 Mar 1998 12:39:49 GMT Joel Sherrill [3cc03ac] * c/src/tests/samples/Makefile.in (modified) HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. Wed, 25 Mar 1998 19:02:37 GMT Joel Sherrill [5e0fbcc] * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) Moved memcpy to newlib/libc/machine/m68k Wed, 25 Mar 1998 18:46:47 GMT Joel Sherrill [c80add4] * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) * cpukit/score/cpu/m68k/cpu.c (modified) m68k software interrupt stack support from Chris Johns and Eric Norum. Wed, 25 Mar 1998 14:14:46 GMT Joel Sherrill [c4e09029] * c/src/lib/start/sh/start.s (modified) Corrected argument passing. Wed, 25 Mar 1998 14:00:41 GMT Joel Sherrill [85047f02] * c/src/lib/libbsp/shared/main.c (modified) Corrected definition of main and boot_card to be more ANSI compliant. Wed, 25 Mar 1998 13:59:55 GMT Joel Sherrill [0f26250] * c/src/lib/start/sh/start.s (modified) Corrected invocation of boot_card(). Tue, 24 Mar 1998 20:53:48 GMT Joel Sherrill [ddf142d] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) Added _XOPEN_SOURCE definition to allow use of UNIX IPC. Tue, 24 Mar 1998 19:14:47 GMT Joel Sherrill [abbd5b1] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0-beta1 Tue, 24 Mar 1998 17:13:03 GMT Joel Sherrill [bdac86b5] * c/src/exec/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) Real definition for the beginning of the data section per Eric ... Tue, 24 Mar 1998 17:10:44 GMT Joel Sherrill [72b397a] * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) Corrected register constraints per suggestion from Thomas Doerfler, ... Tue, 24 Mar 1998 16:33:32 GMT Joel Sherrill [d662fef8] * c/src/exec/score/cpu/i960/i960.h (modified) More cpu model flags converted to using cpp predefines. Tue, 24 Mar 1998 16:24:39 GMT Joel Sherrill [3ec7bfc] * README.configure (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/start/README (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/tests/samples/cdtest/main.cc (modified) * c/src/tests/sptests/spsize/size.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/simhppa.cfg (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/sptests/spsize/size.c (modified) Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for ...
