# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 13:50:28 Mon, 17 May 1999 22:58:30 GMT Joel Sherrill [c06d8f64] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semcreate.c (added) * c/src/exec/rtems/src/semdelete.c (added) * c/src/exec/rtems/src/semident.c (added) * c/src/exec/rtems/src/semobtain.c (added) * c/src/exec/rtems/src/semrelease.c (added) * c/src/exec/rtems/src/semtranslatereturncode.c (added) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (added) * cpukit/rtems/src/semdelete.c (added) * cpukit/rtems/src/semident.c (added) * cpukit/rtems/src/semobtain.c (added) * cpukit/rtems/src/semrelease.c (added) * cpukit/rtems/src/semtranslatereturncode.c (added) Split the Semaphore Manager into one routine per file. Mon, 17 May 1999 22:56:13 GMT Joel Sherrill [a2d0f39] * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) Moved some MP routines to semmp.c. Mon, 17 May 1999 22:53:34 GMT Joel Sherrill [3270ca6] * c/src/exec/rtems/src/msg.c (modified) * cpukit/rtems/src/msg.c (modified) Forgot to actually remove the routines. :) Mon, 17 May 1999 22:52:59 GMT Joel Sherrill [1e1b3e00] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/msgqallocate.c (added) * c/src/exec/rtems/src/msgqbroadcast.c (added) * c/src/exec/rtems/src/msgqcreate.c (added) * c/src/exec/rtems/src/msgqdelete.c (added) * c/src/exec/rtems/src/msgqflush.c (added) * c/src/exec/rtems/src/msgqgetnumberpending.c (added) * c/src/exec/rtems/src/msgqident.c (added) * c/src/exec/rtems/src/msgqreceive.c (added) * c/src/exec/rtems/src/msgqsend.c (added) * c/src/exec/rtems/src/msgqsubmit.c (added) * c/src/exec/rtems/src/msgqtranslatereturncode.c (added) * c/src/exec/rtems/src/msgqurgent.c (added) * cpukit/rtems/src/msgqallocate.c (added) * cpukit/rtems/src/msgqbroadcast.c (added) * cpukit/rtems/src/msgqcreate.c (added) * cpukit/rtems/src/msgqdelete.c (added) * cpukit/rtems/src/msgqflush.c (added) * cpukit/rtems/src/msgqgetnumberpending.c (added) * cpukit/rtems/src/msgqident.c (added) * cpukit/rtems/src/msgqreceive.c (added) * cpukit/rtems/src/msgqsend.c (added) * cpukit/rtems/src/msgqsubmit.c (added) * cpukit/rtems/src/msgqtranslatereturncode.c (added) * cpukit/rtems/src/msgqurgent.c (added) Split Message Manager into one routine per file. Mon, 17 May 1999 22:46:01 GMT Joel Sherrill [ef22ab2] * c/src/exec/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgmp.c (modified) Moved an MP routine from msg.c to here. Mon, 17 May 1999 22:45:47 GMT Joel Sherrill [86cb89f] * c/src/exec/rtems/src/msg.c (modified) * cpukit/rtems/src/msg.c (modified) Cleaned up some multiprocessing issues. Mon, 17 May 1999 22:42:47 GMT Joel Sherrill [bd83f47] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/clockget.c (added) * c/src/exec/rtems/src/clockset.c (added) * c/src/exec/rtems/src/clocktick.c (added) * c/src/exec/rtems/src/rtclock.c (modified) * cpukit/rtems/src/clockget.c (added) * cpukit/rtems/src/clockset.c (added) * cpukit/rtems/src/clocktick.c (added) * cpukit/rtems/src/rtclock.c (modified) Split Clock Manager into one routine per file. Mon, 17 May 1999 22:39:20 GMT Joel Sherrill [5aa64518] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regioncreate.c (added) * c/src/exec/rtems/src/regiondelete.c (added) * c/src/exec/rtems/src/regionextend.c (added) * c/src/exec/rtems/src/regiongetsegment.c (added) * c/src/exec/rtems/src/regiongetsegmentsize.c (added) * c/src/exec/rtems/src/regionident.c (added) * c/src/exec/rtems/src/regionreturnsegment.c (added) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (added) * cpukit/rtems/src/regiondelete.c (added) * cpukit/rtems/src/regionextend.c (added) * cpukit/rtems/src/regiongetsegment.c (added) * cpukit/rtems/src/regiongetsegmentsize.c (added) * cpukit/rtems/src/regionident.c (added) * cpukit/rtems/src/regionreturnsegment.c (added) Split Region Manager into one routine per file. Mon, 17 May 1999 22:19:29 GMT Joel Sherrill [1178b8c] * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) Splitting the Thread Handler forced the inclusion of more prototypes. Mon, 17 May 1999 22:16:52 GMT Joel Sherrill [2f831ac] * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/sapi/src/entrytable.c (added) Moved _Entry_Table to its own file to avoid having every RTEMS ... Mon, 17 May 1999 22:15:56 GMT Joel Sherrill [d7851582] * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (added) * c/src/tests/samples/minimum/init.c (added) * c/src/tests/samples/minimum/minimum.doc (added) * c/src/tests/samples/minimum/minimum.scn (added) * testsuites/samples/minimum/init.c (added) * testsuites/samples/minimum/minimum.doc (added) * testsuites/samples/minimum/minimum.scn (added) Added simple test to find minimum code size of executive with this ... Mon, 17 May 1999 21:02:16 GMT Joel Sherrill [c4d69e2] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/taskcreate.c (added) * c/src/exec/rtems/src/taskdelete.c (added) * c/src/exec/rtems/src/taskgetnote.c (added) * c/src/exec/rtems/src/taskident.c (added) * c/src/exec/rtems/src/taskinitusers.c (added) * c/src/exec/rtems/src/taskmode.c (added) * c/src/exec/rtems/src/taskrestart.c (added) * c/src/exec/rtems/src/taskresume.c (added) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/tasksetnote.c (added) * c/src/exec/rtems/src/tasksetpriority.c (added) * c/src/exec/rtems/src/taskstart.c (added) * c/src/exec/rtems/src/tasksuspend.c (added) * c/src/exec/rtems/src/taskwakeafter.c (added) * c/src/exec/rtems/src/taskwakewhen.c (added) * cpukit/rtems/src/taskcreate.c (added) * cpukit/rtems/src/taskdelete.c (added) * cpukit/rtems/src/taskgetnote.c (added) * cpukit/rtems/src/taskident.c (added) * cpukit/rtems/src/taskinitusers.c (added) * cpukit/rtems/src/taskmode.c (added) * cpukit/rtems/src/taskrestart.c (added) * cpukit/rtems/src/taskresume.c (added) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (added) * cpukit/rtems/src/tasksetpriority.c (added) * cpukit/rtems/src/taskstart.c (added) * cpukit/rtems/src/tasksuspend.c (added) * cpukit/rtems/src/taskwakeafter.c (added) * cpukit/rtems/src/taskwakewhen.c (added) Split Task Manager into multiple files. Eventually this effort will ... Mon, 17 May 1999 20:41:13 GMT Joel Sherrill [05df0a8] * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadchangepriority.c (added) * c/src/exec/score/src/threadclearstate.c (added) * c/src/exec/score/src/threadclose.c (added) * c/src/exec/score/src/threadcreateidle.c (added) * c/src/exec/score/src/threaddelayended.c (added) * c/src/exec/score/src/threaddispatch.c (added) * c/src/exec/score/src/threadevaluatemode.c (added) * c/src/exec/score/src/threadget.c (added) * c/src/exec/score/src/threadhandler.c (added) * c/src/exec/score/src/threadidlebody.c (added) * c/src/exec/score/src/threadinitialize.c (added) * c/src/exec/score/src/threadloadenv.c (added) * c/src/exec/score/src/threadready.c (added) * c/src/exec/score/src/threadresettimeslice.c (added) * c/src/exec/score/src/threadrestart.c (added) * c/src/exec/score/src/threadsetpriority.c (added) * c/src/exec/score/src/threadsetstate.c (added) * c/src/exec/score/src/threadsettransient.c (added) * c/src/exec/score/src/threadstackallocate.c (added) * c/src/exec/score/src/threadstackfree.c (added) * c/src/exec/score/src/threadstart.c (added) * c/src/exec/score/src/threadstartmultitasking.c (added) * c/src/exec/score/src/threadtickletimeslice.c (added) * c/src/exec/score/src/threadyieldprocessor.c (added) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (added) * cpukit/score/src/threadclearstate.c (added) * cpukit/score/src/threadclose.c (added) * cpukit/score/src/threadcreateidle.c (added) * cpukit/score/src/threaddelayended.c (added) * cpukit/score/src/threaddispatch.c (added) * cpukit/score/src/threadevaluatemode.c (added) * cpukit/score/src/threadget.c (added) * cpukit/score/src/threadhandler.c (added) * cpukit/score/src/threadidlebody.c (added) * cpukit/score/src/threadinitialize.c (added) * cpukit/score/src/threadloadenv.c (added) * cpukit/score/src/threadready.c (added) * cpukit/score/src/threadresettimeslice.c (added) * cpukit/score/src/threadrestart.c (added) * cpukit/score/src/threadsetpriority.c (added) * cpukit/score/src/threadsetstate.c (added) * cpukit/score/src/threadsettransient.c (added) * cpukit/score/src/threadstackallocate.c (added) * cpukit/score/src/threadstackfree.c (added) * cpukit/score/src/threadstart.c (added) * cpukit/score/src/threadstartmultitasking.c (added) * cpukit/score/src/threadtickletimeslice.c (added) * cpukit/score/src/threadyieldprocessor.c (added) Thread Handler split into multiple files. Eventually, as RTEMS is ... Mon, 17 May 1999 15:45:15 GMT Joel Sherrill [a238cc9] * c/src/exec/libnetworking/kern/uipc_domain.c (modified) * c/src/exec/libnetworking/kern/uipc_mbuf.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/kern/uipc_domain.c (modified) * c/src/lib/libnetworking/kern/uipc_mbuf.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/kern/uipc_domain.c (modified) * c/src/libnetworking/kern/uipc_mbuf.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) Patch from D. V. Henkel-Wallace to remove compiler ... Mon, 17 May 1999 15:28:52 GMT Joel Sherrill [577c4080] * c/src/exec/rtems/src/region.c (modified) * cpukit/rtems/src/region.c (modified) Patch from D. V. Henkel-Wallace : Here's a tiny ... Fri, 14 May 1999 16:25:15 GMT Joel Sherrill [fcf17a4] * c/src/tests/samples/cdtest/main.cc (modified) * testsuites/samples/cdtest/main.cc (modified) Added testing for C++ exceptions from Rosimildo DaSilva ... Fri, 14 May 1999 16:23:42 GMT Joel Sherrill [44dd8a61] * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (added) * c/src/lib/libbsp/i386/pc386/3c509/3c509.h (added) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (added) * c/src/lib/libbsp/i386/pc386/3c509/elink.c (added) * c/src/lib/libbsp/i386/pc386/3c509/elink.h (added) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) Added 3COM 3C509 driver from Rosimildo DaSilva . Fri, 14 May 1999 15:31:07 GMT Joel Sherrill [c5881fc1] * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) Enabled compilation of rtems_servers at request of Jake Janovetz ... Fri, 14 May 1999 14:43:53 GMT Joel Sherrill [a0b94685] * c/src/exec/posix/src/mutex.c (modified) * cpukit/posix/src/mutex.c (modified) Removed check for initialized ID at request of Rosimildo DaSilva ... Tue, 11 May 1999 16:30:51 GMT Joel Sherrill [4c5080ed] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) Fix based on bug report from Jay Kulpinski ... Tue, 11 May 1999 15:15:03 GMT Joel Sherrill [ddd22e5] * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) Patch from Erik Ivanenko to correct 32 ... Fri, 07 May 1999 17:09:20 GMT Joel Sherrill [5a909149] * c/src/exec/posix/src/time.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * cpukit/posix/src/time.c (modified) * cpukit/rtems/src/tasks.c (modified) Made all calls to _Thread_Yield_processor consistent in how they are ... Fri, 07 May 1999 16:36:29 GMT Joel Sherrill [16775a5] * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/sapi/include/confdefs.h (modified) Patch from Jiri Gaisler to allow stacksize ... Fri, 07 May 1999 16:31:08 GMT Joel Sherrill [07001360] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added rules to handle alternate suffixes for C++ files. Fri, 07 May 1999 16:30:44 GMT Joel Sherrill [acb644a6] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/lib/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Error reporting fixed by Jennifer. Fri, 07 May 1999 16:29:54 GMT Joel Sherrill [c34aaae7] * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (modified) Bug fix from Gunter Magin : in ... Fri, 07 May 1999 16:28:43 GMT Joel Sherrill [b06279d] * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (modified) Bug fix from Gunter Magin : in ... Wed, 28 Apr 1999 13:59:11 GMT Joel Sherrill [8846bbd] * c/src/lib/libbsp/i386/pc386/dec21140/dec21140.c (modified) Patch from Emmanuel Raguet : I have made ... Tue, 27 Apr 1999 17:31:39 GMT Joel Sherrill [cfcb5a2] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to corrent a miscount in ... Mon, 26 Apr 1999 18:22:08 GMT Joel Sherrill [c7aa9d6] * c/src/exec/posix/include/devctl.h (modified) * c/src/exec/posix/include/intr.h (modified) * c/src/exec/posix/include/mqueue.h (modified) * c/src/exec/posix/include/pthread.h (modified) * c/src/exec/posix/include/sched.h (modified) * c/src/exec/posix/include/semaphore.h (modified) * c/src/exec/posix/include/unistd.h (modified) * cpukit/posix/include/devctl.h (modified) * cpukit/posix/include/intr.h (modified) * cpukit/posix/include/mqueue.h (modified) * cpukit/posix/include/sched.h (modified) * cpukit/posix/include/semaphore.h (modified) Repairing damage and recovering changes including C++ wrappers.. Mon, 26 Apr 1999 18:04:46 GMT Joel Sherrill [c8cfdcfe] * c/src/exec/posix/include/aio.h (modified) * cpukit/posix/include/aio.h (modified) Recovered changes since CVS file was corrupted. Mon, 26 Apr 1999 17:35:57 GMT Joel Sherrill [8b8204a1] * VERSION (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 19990426 Fri, 23 Apr 1999 16:37:54 GMT Joel Sherrill [0b28bd9c] * VERSION (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 19990423 Fri, 23 Apr 1999 16:35:11 GMT Joel Sherrill [16a384cf] * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/README (added) * c/src/lib/libbsp/i386/ts_386ex/bsp_specs (added) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/clock/ckinit.c (added) * c/src/lib/libbsp/i386/ts_386ex/clock/rtc.c (added) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (added) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (added) * c/src/lib/libbsp/i386/ts_386ex/include/coverhd.h (added) * c/src/lib/libbsp/i386/ts_386ex/include/wd80x3.h (added) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/network/ne2000.c (added) * c/src/lib/libbsp/i386/ts_386ex/start/80386ex.h (added) * c/src/lib/libbsp/i386/ts_386ex/start/80386ex.inc (added) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/start/macros.inc (added) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (added) * c/src/lib/libbsp/i386/ts_386ex/start/ts_1325.inc (added) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/startup/README (added) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (added) * c/src/lib/libbsp/i386/ts_386ex/startup/linkcmds (added) * c/src/lib/libbsp/i386/ts_386ex/startup/setvec.c (added) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/timer/timer.c (added) * c/src/lib/libbsp/i386/ts_386ex/timer/timerisr.S (added) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/README (added) * c/src/lib/libbsp/i386/ts_386ex/tools/coff2bin (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/loader.com (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/loader_hybrid_com.asm (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/ts1325.inc (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.ts_386ex (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/i386_ports.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/i386_ports.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-button.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-button.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-led.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-led.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-parallel.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-parallel.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325_test.adb (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (added) * make/custom/ts_386ex.cfg (added) New BSP from Tony R. Ambardar from the University ... Thu, 22 Apr 1999 21:13:23 GMT Joel Sherrill [933388ae] * c/src/exec/libcsupport/src/lstat.c (added) * c/src/exec/libcsupport/src/stat.c (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/lstat.c (added) * c/src/lib/libc/stat.c (modified) * cpukit/libcsupport/src/lstat.c (added) * cpukit/libcsupport/src/stat.c (modified) Added lstat(). Mon, 19 Apr 1999 21:02:31 GMT Joel Sherrill [c2463d9] * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) Intel i960HA support submitted by Jimen Ching ... Mon, 19 Apr 1999 17:30:02 GMT Joel Sherrill [b56206a] * c/src/exec/score/src/Unlimited.txt (added) * cpukit/score/src/Unlimited.txt (added) Unlimited objects patch design document. Submitted by Chris Johns ... Mon, 19 Apr 1999 17:17:41 GMT Joel Sherrill [4186b3b] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/sys/ioccom.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/sys/ioccom.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Changed ioctl() prototype to be more like Linux/POSIX than BSD to ... Mon, 19 Apr 1999 15:54:03 GMT Joel Sherrill [df3e78a] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) The default action for real-time signals is supposed to be ... Mon, 19 Apr 1999 15:37:36 GMT Joel Sherrill [1059abcd] * c/build-tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Regenerated. Mon, 19 Apr 1999 15:36:21 GMT Joel Sherrill [7807b30e] * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) Direct .gcc_exc section to ram to eliminate the warning Ralf ... Mon, 19 Apr 1999 15:27:20 GMT Joel Sherrill [11f84b3c] * c/src/libchip/network/Makefile.in (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) After discussion with Eric Norum , I added ... Mon, 19 Apr 1999 15:27:19 GMT Joel Sherrill [7cdf7fc1] * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) After discussion with Eric Norum , I added ... Mon, 19 Apr 1999 14:41:23 GMT Joel Sherrill [db047f1] * c/src/lib/libcpu/i386/cpu.h (modified) Patch from Erik Ivanenko to eliminate a ... Mon, 19 Apr 1999 13:25:50 GMT Joel Sherrill [82307a11] * c/src/lib/librdbg/i386/Makefile.in (added) * c/src/lib/librdbg/i386/pc386/Makefile.in (added) * c/src/librdbg/src/i386/Makefile.in (added) * c/src/librdbg/src/i386/any/Makefile.in (added) * c/src/librdbg/src/i386/pc386/Makefile.in (added) New files. Mon, 19 Apr 1999 13:20:15 GMT Joel Sherrill [5dc30fb] * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) Patch from Ralf Corsepius to add scitabs.c ... Mon, 19 Apr 1999 13:19:14 GMT Joel Sherrill [196094eb] * Makefile.in (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/acpolish (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/update/acpolish (modified) Patch from Ralf Corsepius : This one ... Mon, 19 Apr 1999 13:11:13 GMT Joel Sherrill [9572c41] * c/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/remdeb.x (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/remdeb.x (modified) * make/custom/force386.cfg (modified) * make/custom/i386ex.cfg (modified) Patch from Ralf Corsepius : This is an ... Mon, 19 Apr 1999 13:06:07 GMT Joel Sherrill [60e6a0f] * c/src/lib/libcpu/i386/cpu.h (modified) Fixed some spacing issues. Fri, 16 Apr 1999 18:23:48 GMT Joel Sherrill [6b7ab9bf] * README.configure (modified) * aclocal.m4 (modified) * aclocal/enable-gmake-print.m4 (deleted) * c/src/make/directory.cfg (modified) * c/update-tools/cipolish (modified) * configure (modified) * configure.in (modified) * make/Templates/Makefile.inc.in (modified) * make/directory.cfg (modified) * make/main.cfg (modified) * make/target.cfg.in (modified) * tools/update/cipolish (modified) Patch from Ralf Corsepius : FYI: I am ... Fri, 16 Apr 1999 18:17:31 GMT Joel Sherrill [c00fa38] * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) Patch from Ralf Corsepius : 2) ... Fri, 16 Apr 1999 18:15:08 GMT Joel Sherrill [98d051f] * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) Patch from Ralf Corsepius : 1) ... Fri, 16 Apr 1999 18:08:27 GMT Joel Sherrill [4a22e7a] * c/src/lib/libbsp/mips/p4000/startup/linkcmds (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/linkcmds (modified) Corrected to reflect new way of doing mips constructors. Fri, 16 Apr 1999 18:08:09 GMT Joel Sherrill [2a4791f] * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) Added .eh_fram and .gcc_exc sections. Thu, 15 Apr 1999 19:01:32 GMT Joel Sherrill [d006519b] * c/src/exec/libcsupport/src/link.c (modified) * c/src/exec/libcsupport/src/unlink.c (modified) * c/src/lib/libc/link.c (modified) * c/src/lib/libc/unlink.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/unlink.c (modified) Added reentrant versions. Thu, 15 Apr 1999 18:58:43 GMT Joel Sherrill [a68e6b9] * c/src/exec/libcsupport/src/utsname.c (modified) * c/src/exec/posix/src/utsname.c (modified) * c/src/lib/libc/utsname.c (modified) * cpukit/libcsupport/src/utsname.c (modified) Updated version string. Thu, 15 Apr 1999 18:58:27 GMT Joel Sherrill [2df1974] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) Added include of rtems/posix/cancel.h. Thu, 15 Apr 1999 18:58:02 GMT Joel Sherrill [da41ecbc] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) Removed alarm(), killinfo() and pause() because they are now in their ... Thu, 15 Apr 1999 18:57:31 GMT Joel Sherrill [93994fdb] * c/src/exec/posix/src/mqueue.c (modified) * c/src/exec/posix/src/semaphore.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/semaphore.c (modified) Now compiles and is included in normal build even though it is ... Thu, 15 Apr 1999 18:57:02 GMT Joel Sherrill [0f4e074] * c/src/exec/posix/src/killinfo.c (modified) * cpukit/posix/src/killinfo.c (modified) Cleaned up. Thu, 15 Apr 1999 18:56:42 GMT Joel Sherrill [3afecf8] * c/src/exec/posix/src/aio.c (modified) * c/src/exec/posix/src/cancel.c (modified) * cpukit/posix/src/aio.c (modified) * cpukit/posix/src/cancel.c (modified) Now compiles and is included in normal build even though it is untested. Thu, 15 Apr 1999 18:55:55 GMT Joel Sherrill [3090760] * c/src/exec/posix/src/Makefile.in (modified) Now compile files that previously existed but were not built because ... Thu, 15 Apr 1999 18:55:14 GMT Joel Sherrill [24a9af6] * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) Now install header files that existed but were not previously installed. Thu, 15 Apr 1999 18:54:40 GMT Joel Sherrill [8a2943aa] * c/src/exec/posix/include/wrap/Makefile.in (modified) Now install some header files that existed but were not previously ... Thu, 15 Apr 1999 18:54:16 GMT Joel Sherrill [053acd70] * c/src/exec/posix/include/sys/Makefile.in (modified) Now install utsname.h. Thu, 15 Apr 1999 18:54:01 GMT Joel Sherrill [d0f53fe] * c/src/exec/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) Enabled cancellation information in POSIX API thread extension structure. Thu, 15 Apr 1999 18:53:35 GMT Joel Sherrill [02d46fa] * c/src/exec/posix/include/rtems/posix/seterr.h (modified) Added set_errno_and_return_minus_one_cast. Thu, 15 Apr 1999 18:53:22 GMT Joel Sherrill [39daf58] * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) Added in some header files that existed but were not previously ... Wed, 14 Apr 1999 22:33:30 GMT Joel Sherrill [3c87bb9c] * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Minor corrections from Jay Kulpinski . ... Wed, 14 Apr 1999 18:18:03 GMT Joel Sherrill [2b28307] * c/src/lib/libmisc/untar/untar.c (modified) * c/src/libmisc/untar/untar.c (modified) * cpukit/libmisc/untar/untar.c (modified) Bug report from Ralf on UNIX port where the S_IR* constants were not ... Tue, 13 Apr 1999 22:50:24 GMT Joel Sherrill [76e5fe8a] * c/src/lib/libbsp/powerpc/papyrus/dlentry/dlentry.S (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/flashentry.S (modified) Bug fix from Brendan Simon with fix ... Mon, 12 Apr 1999 20:27:14 GMT Joel Sherrill [6e27f588] * c/src/lib/libbsp/Makefile.in (modified) * make/custom/mvme162.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/ppcn_60x.cfg (modified) Patch from Ralf Corsepius : Installing ... Mon, 12 Apr 1999 20:24:56 GMT Joel Sherrill [82f490f] * aclocal.m4 (modified) * aclocal/enable-tests.m4 (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/posix/src/ptimer.c (modified) * configure (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/ptimer.c (modified) Patch from Ralf Corsepius to correct the ... Mon, 12 Apr 1999 15:41:33 GMT Joel Sherrill [8cdb582] * aclocal.m4 (modified) * aclocal/rtems-top.m4 (modified) * autogen (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/aclocal.m4 (modified) * c/build-tools/configure (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/generic/aclocal.m4 (modified) * c/src/exec/score/tools/generic/configure (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/aclocal.m4 (modified) * c/src/exec/score/tools/hppa1.1/configure (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/sh/aclocal.m4 (modified) * c/src/exec/score/tools/sh/configure (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/score/tools/unix/aclocal.m4 (modified) * c/src/exec/score/tools/unix/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * c/update-tools/Makefile.am (added) * c/update-tools/Makefile.in (modified) * c/update-tools/aclocal.m4 (added) * c/update-tools/configure.in (added) * configure (modified) * configure.in (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/update/Makefile.am (added) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (added) * tools/update/configure.in (added) Patch from Ralf Corsepius : This patch ... Mon, 12 Apr 1999 15:36:07 GMT Joel Sherrill [d115315] * c/src/exec/posix/src/ptimer.c (modified) * cpukit/posix/src/ptimer.c (modified) Added line to initialize timer_max. Mon, 12 Apr 1999 15:21:43 GMT Joel Sherrill [63b96b9] * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) Addressed this bug report: Date: Mon, 12 Apr 1999 00:38:04 +0000 ... Wed, 07 Apr 1999 20:56:47 GMT Joel Sherrill [5907192] * VERSION (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 19990407 Wed, 07 Apr 1999 15:57:05 GMT Joel Sherrill [3084de2] * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/mpc821.h (added) * c/src/exec/score/cpu/powerpc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc821/README (added) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (added) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc821/include/console.h (added) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc821/timer/timer.c (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/README (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/align_h.S (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/vectors.S (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/vectors.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) MPC821 support and PPC patches from Andrew Bray ... Tue, 06 Apr 1999 22:07:36 GMT Joel Sherrill [3c0e80c3] * c/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) Patch from Ralf Corsepius to preinstall ... Tue, 06 Apr 1999 22:04:08 GMT Joel Sherrill [5cf555e1] * c/src/tests/psxtests/psxstat/psxstat.scn (modified) * testsuites/psxtests/psxstat/psxstat.scn (modified) Corrections by Jennifer. Tue, 06 Apr 1999 21:45:06 GMT Joel Sherrill [b08d3ed9] * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (added) * c/src/lib/libmisc/untar/untar.c (added) * c/src/lib/libmisc/untar/untar.h (added) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (added) * c/src/libmisc/untar/untar.c (added) * c/src/libmisc/untar/untar.h (added) * c/src/libmisc/wrapup/Makefile.in (modified) * cpukit/libmisc/untar/untar.c (added) * cpukit/libmisc/untar/untar.h (added) Untar support submitted by Jake Janovetz . Tue, 06 Apr 1999 20:39:17 GMT Joel Sherrill [01a9d941] * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/helas403/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) Patch from Andrew Bray : In your various ... Tue, 06 Apr 1999 20:27:45 GMT Joel Sherrill [676b504] * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) Patch from Eric Norum : I'd like to make ... Tue, 06 Apr 1999 15:45:21 GMT Joel Sherrill [e53c4a3] * c/src/exec/posix/include/limits.h (deleted) * c/src/exec/posix/include/wrap/Makefile.in (modified) Cleaning up unused files. Fri, 02 Apr 1999 14:39:19 GMT Joel Sherrill [85e24a3] * c/src/lib/libnetworking/rtems_servers/ftpd.c (modified) * c/src/lib/libnetworking/rtems_servers/ftpd.h (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_servers/ftpd.h (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/ftpd/ftpd.h (modified) Patch from Emmanuel Rauget (raguet@crf.canon.fr) to add a htons on ... Thu, 01 Apr 1999 16:58:06 GMT Joel Sherrill [f72dd2a] * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * configure (modified) * configure.in (modified) * testsuites/tools/generic/Makefile.am (modified) Patch from Ralf Corsepius to address ... Thu, 01 Apr 1999 16:36:22 GMT Joel Sherrill [517660f1] * c/src/exec/libnetworking/machine/in_cksum.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/machine/in_cksum.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/machine/in_cksum.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Moved sparc specific version of in_cksum_hdr to an inline routine ... Thu, 01 Apr 1999 16:20:03 GMT Joel Sherrill [5eb7da97] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Disable IXON by default based on comment from Eric Norum ... Thu, 01 Apr 1999 15:51:14 GMT Joel Sherrill [656dabf] * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) Removed warning. Wed, 31 Mar 1999 23:56:34 GMT Joel Sherrill [414e1b3] * VERSION (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 19990331 Wed, 31 Mar 1999 23:36:18 GMT Joel Sherrill [77a0067] * VERSION (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 199900331 Wed, 31 Mar 1999 23:35:22 GMT Joel Sherrill [18040d3] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Patch from Thomas Doerfler to add flow control: ... Wed, 31 Mar 1999 23:29:19 GMT Joel Sherrill [ecab6a39] * c/build-tools/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/aclocal.m4 (modified) * c/src/exec/score/tools/hppa1.1/configure (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/sh/aclocal.m4 (modified) * c/src/exec/score/tools/sh/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/stamp-h.in (modified) * tools/build/Makefile.in (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) Regenerated. Wed, 31 Mar 1999 23:27:03 GMT Joel Sherrill [79800f9] * c/src/lib/libbsp/mips/p4000/start/start.S (modified) * c/src/lib/libbsp/mips64orion/p4000/start/start.S (modified) * c/src/lib/start/mips64orion/idt_csu.S (modified) Fixed include file paths. Wed, 31 Mar 1999 23:25:53 GMT Joel Sherrill [c08f283] * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Fixed typo so applications would link. Wed, 31 Mar 1999 23:24:57 GMT Jennifer Averett [ec2328ee] * c/src/exec/libcsupport/src/mknod.c (modified) * c/src/exec/libfs/src/imfs/imfs_getchild.c (modified) * c/src/exec/libfs/src/imfs/imfs_mknod.c (modified) * c/src/lib/libc/imfs_getchild.c (modified) * c/src/lib/libc/imfs_mknod.c (modified) * c/src/lib/libc/mknod.c (modified) * c/src/libfs/src/imfs/imfs_getchild.c (modified) * c/src/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) Removed asserts that shouldn't be called and commented case where ... Wed, 31 Mar 1999 23:24:51 GMT Joel Sherrill [8cc57f6] * c/src/exec/score/cpu/m68k/rtems.S (modified) Modified to be valid m68k code on all CPU models. Wed, 31 Mar 1999 23:23:52 GMT Jennifer Averett [f719ef1] * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/lib/libc/fcntl.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) Corrected return value. Wed, 31 Mar 1999 23:22:42 GMT Jennifer Averett [3f06c298] * c/src/tests/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) Added prints for calls into the file system. Added O_EXCL for an ... Wed, 31 Mar 1999 23:21:19 GMT Joel Sherrill [73b943bc] * c/src/exec/score/cpu/mips/cpu_asm.h (moved) * c/src/exec/score/cpu/mips/idtcpu.h (moved) * c/src/exec/score/cpu/mips/idtmon.h (moved) * c/src/exec/score/cpu/mips/iregdef.h (moved) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (added) * c/src/exec/score/cpu/mips64orion/idtcpu.h (added) * c/src/exec/score/cpu/mips64orion/idtmon.h (added) * c/src/exec/score/cpu/mips64orion/iregdef.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/lib/libbsp/mips/p4000/console/led.S (modified) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/led.S (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/idttlb.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/inittlb.c (modified) * c/src/lib/libcpu/mips/clock/clock.S (modified) * c/src/lib/libcpu/mips/timer/gettime.S (modified) * c/src/lib/libcpu/mips64orion/clock/clock.S (modified) * c/src/lib/libcpu/mips64orion/timer/gettime.S (modified) * cpukit/score/cpu/mips/idtcpu.h (added) * cpukit/score/cpu/mips/iregdef.h (added) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (added) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (added) * cpukit/score/cpu/mips64orion/cpu_asm.h (added) * cpukit/score/cpu/mips64orion/idtcpu.h (added) * cpukit/score/cpu/mips64orion/idtmon.h (added) * cpukit/score/cpu/mips64orion/iregdef.h (added) Fixed paths to include files so this will build.
