# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 06/03/24 13:39:12 Fri, 08 Apr 2016 12:03:47 GMT Daniel Hellstrom [a7cc0da9] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fix stscfg cfg TimeCode Int clr Without this patch ... Thu, 07 Apr 2016 08:02:55 GMT Daniel Hellstrom [0d31dcc] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: split DMA sem into RX and TX sem By introducing a ... Thu, 07 Apr 2016 07:36:37 GMT Daniel Hellstrom [7701c37] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: coding style fix Wed, 30 Mar 2016 12:29:52 GMT Daniel Hellstrom [77856f6] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: allow user controlled DMA intr The user has ... Tue, 29 Mar 2016 12:59:59 GMT Daniel Hellstrom [1ef9caa2] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: support for reading tx/rx DMA queue * Add support ... Wed, 23 Mar 2016 09:45:26 GMT Daniel Hellstrom [eb5a42f6] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fixed device/dma closing The user is now ... Wed, 23 Mar 2016 08:57:10 GMT Daniel Hellstrom [36c3fbbd] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) leon, grspw_pkt: coding style fixups Tue, 22 Mar 2016 15:41:51 GMT Daniel Hellstrom [9cb7e5d] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fixed and improved RX/TX wait Tue, 22 Mar 2016 15:07:51 GMT Daniel Hellstrom [57e1f4c3] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fixed error return path in dma_open Tue, 22 Mar 2016 14:51:13 GMT Daniel Hellstrom [ac7da5bc] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Manual handling of link status events Added ... Tue, 22 Mar 2016 14:37:36 GMT Daniel Hellstrom [49cf776e] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: added link_ctrl options Improved the link error ... Tue, 22 Mar 2016 12:59:56 GMT Daniel Hellstrom [fad4324d] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: added grspw_link_status_clr() to API Tue, 22 Mar 2016 10:42:10 GMT Daniel Hellstrom [c442647f] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: code style clean-ups Mon, 21 Mar 2016 14:02:58 GMT Daniel Hellstrom [61cc024a] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: start/reset must take RS and IP into account Mon, 21 Mar 2016 12:50:27 GMT Daniel Hellstrom [b109add] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) leon: Fix ambapp_bus OCCAN device registeration order NOTE that ... Tue, 27 Oct 2015 11:41:50 GMT Martin Aberg [6ecad1d] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Preserve DMA address enable at start. The EN bit ... Tue, 20 Oct 2015 09:25:06 GMT Martin Aberg [a48bfc0f] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) leon, grspw_pkt: Fixed txpkt flag for link error There was a mixup ... Tue, 30 Jun 2015 13:00:51 GMT Martin Aberg [3395ca99] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Fixed parameter check in grspw_dma_open() Mon, 13 Apr 2015 07:01:54 GMT Daniel Hellstrom [4431f7d] * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) leon, gr1553b: RT status words register declarations fix The fix ... Fri, 02 Jan 2015 12:18:33 GMT Daniel Hellstrom [d745297] * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) leon, gr1553b: comment cleanup Fri, 02 Jan 2015 12:16:10 GMT Daniel Hellstrom [be66bbc1] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) leon, grspw: rxPktSize must set DMA RX max length Thu, 02 Mar 2017 15:53:45 GMT Sebastian Huber [c0dafd7b] * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Use at most 2GiB of RAM Thu, 02 Mar 2017 14:25:34 GMT Sebastian Huber [d3f60af] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Adjust workspace according to FDT Thu, 02 Mar 2017 14:20:52 GMT Sebastian Huber [35136d3] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq.inc (modified) bsp/qoriq: Use -O2 Thu, 02 Mar 2017 14:20:19 GMT Sebastian Huber [62f16ad] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq.inc (modified) bsp/qoriq: Enable linker garbage collection Thu, 02 Mar 2017 14:17:35 GMT Sebastian Huber [891b834f] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Do not overwrite configured baud Thu, 02 Mar 2017 10:57:28 GMT Sebastian Huber [805d7213] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) powerpc: Fix warnings Thu, 02 Mar 2017 10:54:58 GMT Sebastian Huber [09dab28d] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) powerpc: Fix interrupt thread dispatch Update #2751. Wed, 01 Mar 2017 10:31:57 GMT Sebastian Huber [08d85992] * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/shared/showbats.c (modified) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) bsps/powerpc: Fix warnings Tue, 21 Feb 2017 14:25:03 GMT Sebastian Huber [3398602] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add rtems_interrupt_server_request_submit() This function may be ... Wed, 22 Feb 2017 08:01:40 GMT Sebastian Huber [11f0d52] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (modified) bsp/xilinx-zynq: Add interrupt support to UART Tue, 21 Feb 2017 09:30:30 GMT Sebastian Huber [6b2fcc4] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/console-config.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/debug-console.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspreset.c (modified) bsp/xilinx-zynq: Use new Termios device driver Wed, 15 Feb 2017 12:41:02 GMT Sebastian Huber [7318e7db] * c/src/lib/libbsp/arm/lpc24xx/ssp/ssp.c (modified) bsp/lpc24xx: Remove debug output Wed, 15 Feb 2017 12:39:02 GMT Sebastian Huber [6afeeda] * c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/probeMemEnd.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) bsps/powerpc: Fix warnings Wed, 15 Feb 2017 12:28:02 GMT Sebastian Huber [f6f764c1] * c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/generic_clear_hberrs.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) bsps/powerpc: Fix warnings Wed, 15 Feb 2017 12:14:40 GMT Sebastian Huber [32292d5d] * c/src/lib/libcpu/powerpc/mpc83xx/gtm/gtm.c (modified) bsps/powerpc: Fix warning Wed, 15 Feb 2017 11:57:56 GMT Sebastian Huber [bc744618] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsps/sparc: Fix warnings Wed, 15 Feb 2017 10:12:40 GMT Sebastian Huber [444cb5c] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Fix prototype Wed, 15 Feb 2017 10:09:50 GMT Sebastian Huber [73f8d93] * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/shared/src/stack.c (modified) bsps/powerpc: Fix warnings Mon, 30 Jan 2017 10:33:31 GMT Christian Mauderer [180107e9] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/startup/armv7m-cpucounter.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) bsps/arm: Fix Cortex-M DWT CPU counter. It is necessary to enable ... Tue, 24 Jan 2017 14:40:31 GMT Kevin Kirspel [b43c2e8] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) Adding ARM VFP V2 support Mon, 23 Jan 2017 07:06:41 GMT Sebastian Huber [2711914f] * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libmisc/shell/main_pci.c (modified) Use Update #2803. Mon, 23 Jan 2017 13:51:27 GMT Kevin Kirspel [2f8f951b] * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) bsp/lpc32xx: Fix interrupt controller suppport Enable/Disable ... Fri, 20 Jan 2017 14:29:00 GMT Sebastian Huber [7fbd72c] * c/src/libchip/i2c/spi-sd-card.c (modified) libchip: Really fix high capacity detection Update #2239. Fri, 20 Jan 2017 13:21:29 GMT Sebastian Huber [e8606d5b] * c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c (modified) bsp/beatnik: Remove superfluous check Close #2874. Thu, 19 Jan 2017 20:37:13 GMT Gedare Bloom [21267897] * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (modified) raspberrypi: fix math inside of sizeof Move the subtraction of 1 ... Thu, 19 Jan 2017 20:34:18 GMT Gedare Bloom [70e8abf] * c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c (modified) raspberrypi: use signed int for return variable Closes #2873. Thu, 19 Jan 2017 17:58:44 GMT Gedare Bloom [3f09d635] * c/src/lib/libbsp/arm/smdk2410/smc/smc.c (modified) smdk2410: delete unused variables Closes #2868. Tue, 17 Jan 2017 23:57:43 GMT Joel Sherrill [e397122c] * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) m68k/mcf5225x/*/mc525x5-testsuite.tcfg: Add cdtest Tue, 17 Jan 2017 23:56:53 GMT Joel Sherrill [900f9857] * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) m68k/mcf52235/*/mc52235-testsuite.tcfg: Add cdtest Tue, 17 Jan 2017 23:56:19 GMT Joel Sherrill [96ba863] * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) arm/lpc32xx/*/lpc32xx_mzx_stage_1-testsuite.tcfg: Add dl05 Tue, 17 Jan 2017 18:39:26 GMT Joel Sherrill [79ec730] * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554-testsuite.tcfg (modified) powerpc/mpc55xxevb/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:06:12 GMT Joel Sherrill [09f6666] * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) m68k/mcf5225x/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:05:49 GMT Joel Sherrill [dd14b45] * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332-testsuite.tcfg (modified) m68k/mrm332/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:05:39 GMT Joel Sherrill [ba61311e] * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) m68k/mcf52235/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:04:54 GMT Joel Sherrill [ddb28127] * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4-testsuite.tcfg (modified) arm/stm32f4/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:04:33 GMT Joel Sherrill [9c834d1] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) arm/lpc24xx/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:04:13 GMT Joel Sherrill [ed1dcd2] * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) arm/lpc32xx/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:03:56 GMT Joel Sherrill [2414497f] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) arm/lpc176x/*.tcfg: Add fsjffs2gc01 to excluded tests Tue, 17 Jan 2017 14:03:31 GMT Joel Sherrill [6c42040] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) arm/lm3s69xx/*.tcfg: Add fsjffs2gc01 to excluded tests Thu, 12 Jan 2017 22:12:51 GMT Joel Sherrill [1fcdd639] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/m68k/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/or1k/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset Mon, 16 Jan 2017 12:13:36 GMT Sebastian Huber [2a583a00] * c/src/lib/libbsp/arm/atsam/include/sc16is752.h (modified) atsam: Fix SC16IS752 documentation Thu, 12 Jan 2017 15:36:26 GMT Christian Spindeldreier [a1e4e3bf] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: Interrupt Handler Uses Wrong Events closes #2796. Tue, 15 Nov 2016 16:37:59 GMT Joel Sherrill [48a7fa3] * Makefile.am (modified) * Makefile.maint (modified) * bootstrap (modified) * c/src/lib/libbsp/bfin/acinclude.m4 (modified) * configure.ac (modified) * doc/Makefile.am (deleted) * doc/README (deleted) * doc/TODO (deleted) * doc/acinclude.m4 (deleted) * doc/ada_user/Makefile.am (deleted) * doc/ada_user/ada_user.texi (deleted) * doc/ada_user/example.texi (deleted) * doc/ada_user/stamp-vti (deleted) * doc/ada_user/version.texi (deleted) * doc/bsp_howto/BSPInitFlowchart-49.eps (deleted) * doc/bsp_howto/BSPInitFlowchart-49.png (deleted) * doc/bsp_howto/Developer-User-Timeline.eps (deleted) * doc/bsp_howto/Developer-User-Timeline.png (deleted) * doc/bsp_howto/Makefile.am (deleted) * doc/bsp_howto/TERMIOSFlow.eps (deleted) * doc/bsp_howto/TERMIOSFlow.png (deleted) * doc/bsp_howto/adaintr.t (deleted) * doc/bsp_howto/analog.t (deleted) * doc/bsp_howto/ata.t (deleted) * doc/bsp_howto/bsp_howto.texi (deleted) * doc/bsp_howto/clock.t (deleted) * doc/bsp_howto/console.t (deleted) * doc/bsp_howto/discrete.t (deleted) * doc/bsp_howto/framebuffer.t (deleted) * doc/bsp_howto/ide-ctrl.t (deleted) * doc/bsp_howto/init.t (deleted) * doc/bsp_howto/intro.t (deleted) * doc/bsp_howto/linkcmds.t (deleted) * doc/bsp_howto/makefiles.t (deleted) * doc/bsp_howto/nvmem.t (deleted) * doc/bsp_howto/rtc.t (deleted) * doc/bsp_howto/shmsupp.t (deleted) * doc/bsp_howto/stamp-vti (deleted) * doc/bsp_howto/support.t (deleted) * doc/bsp_howto/target.t (deleted) * doc/bsp_howto/timer.t (deleted) * doc/bsp_howto/version.texi (deleted) * doc/common/cpright.texi (deleted) * doc/common/opengroup_manpage_acknowledgement.texi (deleted) * doc/common/opengroup_preface_acknowledgement.texi (deleted) * doc/common/rtems.texi.in (deleted) * doc/common/setup.texi (deleted) * doc/common/treedef.tex (deleted) * doc/common/wksheets.t (deleted) * doc/configure.ac (deleted) * doc/cpu_supplement/Makefile.am (deleted) * doc/cpu_supplement/arm.t (deleted) * doc/cpu_supplement/bfin.t (deleted) * doc/cpu_supplement/cpu_supplement.texi (deleted) * doc/cpu_supplement/epiphany.t (deleted) * doc/cpu_supplement/general.t (deleted) * doc/cpu_supplement/i386.t (deleted) * doc/cpu_supplement/lm32.t (deleted) * doc/cpu_supplement/m32c.t (deleted) * doc/cpu_supplement/m68k.t (deleted) * doc/cpu_supplement/microblaze.t (deleted) * doc/cpu_supplement/mips.t (deleted) * doc/cpu_supplement/nios2.t (deleted) * doc/cpu_supplement/or1k.t (deleted) * doc/cpu_supplement/powerpc.t (deleted) * doc/cpu_supplement/preface.texi (deleted) * doc/cpu_supplement/sh.t (deleted) * doc/cpu_supplement/sparc.t (deleted) * doc/cpu_supplement/sparc64.t (deleted) * doc/cpu_supplement/stamp-vti (deleted) * doc/cpu_supplement/v850.t (deleted) * doc/cpu_supplement/version.texi (deleted) * doc/develenv/Makefile.am (deleted) * doc/develenv/develenv.texi (deleted) * doc/develenv/direct.t (deleted) * doc/develenv/intro.texi (deleted) * doc/develenv/sample.t (deleted) * doc/develenv/stamp-vti (deleted) * doc/develenv/utils.t (deleted) * doc/develenv/version.texi (deleted) * doc/filesystem/Makefile.am (deleted) * doc/filesystem/filesystem.texi (deleted) * doc/filesystem/fsrequirements.t (deleted) * doc/filesystem/imfs.t (deleted) * doc/filesystem/init.t (deleted) * doc/filesystem/miniimfs.t (deleted) * doc/filesystem/mounting.t (deleted) * doc/filesystem/patheval.t (deleted) * doc/filesystem/preface.texi (deleted) * doc/filesystem/stamp-vti (deleted) * doc/filesystem/syscalls.t (deleted) * doc/filesystem/tftp.t (deleted) * doc/filesystem/version.texi (deleted) * doc/images/dir-arrow.gif (deleted) * doc/images/dvi.gif (deleted) * doc/images/missing-arrow.gif (deleted) * doc/images/next-arrow.gif (deleted) * doc/images/oaronly.jpg (deleted) * doc/images/pdf.gif (deleted) * doc/images/pdf1.gif (deleted) * doc/images/prev-arrow.gif (deleted) * doc/images/ps.gif (deleted) * doc/images/rtems_logo.jpg (deleted) * doc/images/up-arrow.gif (deleted) * doc/index.html.in (deleted) * doc/main.am (deleted) * doc/networking/Makefile.am (deleted) * doc/networking/PCIreg.eps (deleted) * doc/networking/PCIreg.jpg (deleted) * doc/networking/PCIreg.txt (deleted) * doc/networking/decdriver.t (deleted) * doc/networking/driver.t (deleted) * doc/networking/networkapp.t (deleted) * doc/networking/networkflow.eps (deleted) * doc/networking/networkflow.jpg (deleted) * doc/networking/networkflow.png (deleted) * doc/networking/networkflow.txt (deleted) * doc/networking/networking.texi (deleted) * doc/networking/networktasks.t (deleted) * doc/networking/preface.texi (deleted) * doc/networking/recvbd.eps (deleted) * doc/networking/recvbd.jpg (deleted) * doc/networking/recvbd.txt (deleted) * doc/networking/servers.t (deleted) * doc/networking/stamp-vti (deleted) * doc/networking/testing.t (deleted) * doc/networking/version.texi (deleted) * doc/new_chapters/Makefile.am (deleted) * doc/new_chapters/STATUS (deleted) * doc/new_chapters/TODO (deleted) * doc/new_chapters/error.t (deleted) * doc/new_chapters/gen_section (deleted) * doc/new_chapters/monitor.t (deleted) * doc/new_chapters/new_chapters.texi (deleted) * doc/new_chapters/stamp-vti (deleted) * doc/new_chapters/version.texi (deleted) * doc/porting/Makefile.am (deleted) * doc/porting/codetuning.t (deleted) * doc/porting/cpuinit.t (deleted) * doc/porting/cpumodels.t (deleted) * doc/porting/developtools.t (deleted) * doc/porting/idlethread.t (deleted) * doc/porting/interrupts.t (deleted) * doc/porting/miscellaneous.t (deleted) * doc/porting/porting.texi (deleted) * doc/porting/preface.texi (deleted) * doc/porting/prioritybitmap.t (deleted) * doc/porting/sourcecode.t (deleted) * doc/porting/stamp-vti (deleted) * doc/porting/taskcontext.t (deleted) * doc/porting/version.texi (deleted) * doc/posix1003.1/Makefile.am (deleted) * doc/posix1003.1/ch01.t (deleted) * doc/posix1003.1/ch02.t (deleted) * doc/posix1003.1/ch03.t (deleted) * doc/posix1003.1/ch04.t (deleted) * doc/posix1003.1/ch05.t (deleted) * doc/posix1003.1/ch06.t (deleted) * doc/posix1003.1/ch07.t (deleted) * doc/posix1003.1/ch08.t (deleted) * doc/posix1003.1/ch09.t (deleted) * doc/posix1003.1/ch10.t (deleted) * doc/posix1003.1/ch11.t (deleted) * doc/posix1003.1/ch12.t (deleted) * doc/posix1003.1/ch13.t (deleted) * doc/posix1003.1/ch14.t (deleted) * doc/posix1003.1/ch15.t (deleted) * doc/posix1003.1/ch16.t (deleted) * doc/posix1003.1/ch17.t (deleted) * doc/posix1003.1/ch18.t (deleted) * doc/posix1003.1/compliance_list (deleted) * doc/posix1003.1/posix1003_1.texi (deleted) * doc/posix1003.1/preface.texi (deleted) * doc/posix1003.1/stamp-vti (deleted) * doc/posix1003.1/summarize (deleted) * doc/posix1003.1/version.texi (deleted) * doc/posix_users/Makefile.am (deleted) * doc/posix_users/cancel.t (deleted) * doc/posix_users/clock.t (deleted) * doc/posix_users/cond.t (deleted) * doc/posix_users/cspecific.t (deleted) * doc/posix_users/device.t (deleted) * doc/posix_users/files.t (deleted) * doc/posix_users/gen_size_report (deleted) * doc/posix_users/io.t (deleted) * doc/posix_users/key.t (deleted) * doc/posix_users/libc.t (deleted) * doc/posix_users/libm.t (deleted) * doc/posix_users/memorymgmt.t (deleted) * doc/posix_users/message.t (deleted) * doc/posix_users/mutex.t (deleted) * doc/posix_users/posix_users.texi (deleted) * doc/posix_users/preface.texi (deleted) * doc/posix_users/procenv.t (deleted) * doc/posix_users/process.t (deleted) * doc/posix_users/sched.t (deleted) * doc/posix_users/semaphores.t (deleted) * doc/posix_users/signal.t (deleted) * doc/posix_users/stamp-vti (deleted) * doc/posix_users/status.t (deleted) * doc/posix_users/systemdb.t (deleted) * doc/posix_users/thread.t (deleted) * doc/posix_users/timer.t (deleted) * doc/posix_users/version.texi (deleted) * doc/project.am (deleted) * doc/relnotes/Makefile.am (deleted) * doc/relnotes/install.texi (deleted) * doc/relnotes/intro.texi (deleted) * doc/relnotes/probrep.texi (deleted) * doc/relnotes/relnotes.texi (deleted) * doc/relnotes/stamp-vti (deleted) * doc/relnotes/status.texi (deleted) * doc/relnotes/version.texi (deleted) * doc/setup.def (deleted) * doc/shell/Makefile.am (deleted) * doc/shell/confinit.t (deleted) * doc/shell/file.t (deleted) * doc/shell/general.t (deleted) * doc/shell/memory.t (deleted) * doc/shell/network.t (deleted) * doc/shell/preface.texi (deleted) * doc/shell/rtems.t (deleted) * doc/shell/shell.texi (deleted) * doc/shell/stamp-vti (deleted) * doc/shell/version.texi (deleted) * doc/started/Makefile.am (deleted) * doc/started/buildc.t (deleted) * doc/started/buildrt.t (deleted) * doc/started/intro.t (deleted) * doc/started/nextstep.t (deleted) * doc/started/nt.t (deleted) * doc/started/pictures/bit_ada.jpg (deleted) * doc/started/pictures/bit_ada.vsd (deleted) * doc/started/pictures/bit_c.jpg (deleted) * doc/started/pictures/bit_c.vsd (deleted) * doc/started/pictures/scfile10.jpg (deleted) * doc/started/pictures/scfile10.vsd (deleted) * doc/started/pictures/scfile11.jpg (deleted) * doc/started/pictures/scfile11.vsd (deleted) * doc/started/pictures/scfile12.jpg (deleted) * doc/started/pictures/scfile12.vsd (deleted) * doc/started/pictures/scfile13.jpg (deleted) * doc/started/pictures/scfile13.vsd (deleted) * doc/started/pictures/scsfile1.jpg (deleted) * doc/started/pictures/scsfile1.vsd (deleted) * doc/started/pictures/scsfile2.jpg (deleted) * doc/started/pictures/scsfile2.vsd (deleted) * doc/started/pictures/scsfile3.jpg (deleted) * doc/started/pictures/scsfile3.vsd (deleted) * doc/started/pictures/scsfile4.jpg (deleted) * doc/started/pictures/scsfile4.vsd (deleted) * doc/started/pictures/scsfile5.jpg (deleted) * doc/started/pictures/scsfile5.vsd (deleted) * doc/started/pictures/scsfile6.jpg (deleted) * doc/started/pictures/scsfile6.vsd (deleted) * doc/started/pictures/scsfile7.jpg (deleted) * doc/started/pictures/scsfile7.vsd (deleted) * doc/started/pictures/scsfile8.jpg (deleted) * doc/started/pictures/scsfile8.vsd (deleted) * doc/started/pictures/scsfile9.jpg (deleted) * doc/started/pictures/scsfile9.vsd (deleted) * doc/started/pictures/sfile12c.jpg (deleted) * doc/started/pictures/sfile12c.vsd (deleted) * doc/started/require.t (deleted) * doc/started/sample.t (deleted) * doc/started/stamp-vti (deleted) * doc/started/started.texi (deleted) * doc/started/version.texi (deleted) * doc/texi2any_init.in (deleted) * doc/texi2html_init.in (deleted) * doc/tools/Makefile.am (deleted) * doc/tools/bmenu/Makefile.am (deleted) * doc/tools/bmenu/address.h (deleted) * doc/tools/bmenu/base.h (deleted) * doc/tools/bmenu/bmenu2.c (deleted) * doc/tools/bmenu/chain.c (deleted) * doc/tools/bmenu/chain.h (deleted) * doc/tools/bmenu/chain.inl (deleted) * doc/tools/bmenu/system.h (deleted) * doc/tools/configure.ac (deleted) * doc/tools/word-replace2 (deleted) * doc/user/Makefile.am (deleted) * doc/user/ObjectId-16Bits.eps (deleted) * doc/user/ObjectId-16Bits.png (deleted) * doc/user/ObjectId-32Bits.eps (deleted) * doc/user/ObjectId-32Bits.png (deleted) * doc/user/barrier.t (deleted) * doc/user/bsp.t (deleted) * doc/user/c_user.texi (deleted) * doc/user/cbs.t (deleted) * doc/user/chains.t (deleted) * doc/user/clock.t (deleted) * doc/user/concepts.t (deleted) * doc/user/conf.t (deleted) * doc/user/cpuuse.t (deleted) * doc/user/datatypes.t (deleted) * doc/user/dirstat.t (deleted) * doc/user/dpmem.t (deleted) * doc/user/event.t (deleted) * doc/user/example.texi (deleted) * doc/user/fatal.t (deleted) * doc/user/glossary.texi (deleted) * doc/user/init.t (deleted) * doc/user/intr.t (deleted) * doc/user/io.t (deleted) * doc/user/libpci.t (deleted) * doc/user/linkersets.t (deleted) * doc/user/mp.t (deleted) * doc/user/msg.t (deleted) * doc/user/object.t (deleted) * doc/user/overview.t (deleted) * doc/user/part.t (deleted) * doc/user/preface.texi (deleted) * doc/user/rbtree.t (deleted) * doc/user/region.t (deleted) * doc/user/rtemsarc.png (deleted) * doc/user/rtemsarc.txt (deleted) * doc/user/rtemspie.eps (deleted) * doc/user/rtemspie.png (deleted) * doc/user/rtemspie.txt (deleted) * doc/user/rtmon.t (deleted) * doc/user/schedule.t (deleted) * doc/user/sem.t (deleted) * doc/user/semaphore_attributes.eps (deleted) * doc/user/semaphore_attributes.png (deleted) * doc/user/signal.t (deleted) * doc/user/smp.t (deleted) * doc/user/stackchk.t (deleted) * doc/user/stamp-vti (deleted) * doc/user/states.eps (deleted) * doc/user/states.png (deleted) * doc/user/states.txt (deleted) * doc/user/task.t (deleted) * doc/user/timer.t (deleted) * doc/user/timespec.t (deleted) * doc/user/userext.t (deleted) * doc/user/version.texi (deleted) * texinfo.tex (deleted) Remove texinfo format documentation. Replaced by Sphinx formatted ... Tue, 20 Dec 2016 09:30:05 GMT Sebastian Huber [81af80e5] * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/start/crtnn.S (moved) Rename *.s to *.S Consistently use *.S for assembler files. Close ... Tue, 20 Dec 2016 07:49:32 GMT Sebastian Huber [71f29c12] * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmad.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/afe_dma.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/dac_dma.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/spi_dma.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/twid.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/uart_dma.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/usart_dma.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmad.c (modified) bsp/atsam: Use standard XDMA throughout Fri, 16 Dec 2016 12:05:34 GMT Sebastian Huber [4aba8d79] * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi_dma.c (modified) bsp/atsam: Use standard XDMA for QSPI support Thu, 15 Dec 2016 14:37:00 GMT Sebastian Huber [08f1d2f7] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/include/sc16is752.h (added) * c/src/lib/libbsp/arm/atsam/preinstall.am (modified) * c/src/lib/libbsp/arm/atsam/spi/sc16is752.c (added) bsp/atsam: Add SC16IS752 support Thu, 15 Dec 2016 14:03:56 GMT Sebastian Huber [a5c56af] * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pio.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pio_it.c (modified) bsp/atsam: Move interrupt setup to PIO_Configure() Thu, 15 Dec 2016 13:55:45 GMT Sebastian Huber [a4936b5] * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/pio_it.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pio_it.c (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/atsam: System initialization for PIO IRQs Thu, 15 Dec 2016 12:27:17 GMT Sebastian Huber [8eb5fbb6] * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmad.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmad.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsamv: Move XDMAD instance out of SPI driver Use system ... Thu, 15 Dec 2016 08:56:12 GMT Sebastian Huber [d1c771c] * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmad.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmad.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/atsam: Move XDMA IRQ handler to XDMA module The XDMA is shared ... Thu, 15 Dec 2016 05:15:13 GMT Sebastian Huber [cb59276] * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h (modified) bsp/atsam: Use _Assert() instead of assert() Thu, 15 Dec 2016 05:12:46 GMT Sebastian Huber [fd12159] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmac.c (deleted) bsp/atsam: Use inline functions for XDMA access Wed, 14 Dec 2016 10:52:01 GMT Sebastian Huber [8dd83d3] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Optimize SPI interrupt Wed, 14 Dec 2016 10:42:28 GMT Sebastian Huber [9686c614] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Simplify SPI transfer status Wed, 14 Dec 2016 08:41:30 GMT Sebastian Huber [de7c171] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Reduce context switches for SPI transf Wed, 14 Dec 2016 07:32:02 GMT Sebastian Huber [b52513b] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Optimize SPI DMA transfer setup Wed, 14 Dec 2016 07:06:14 GMT Sebastian Huber [f104bd3] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Simplify SPI DMA transfer setup Wed, 14 Dec 2016 07:00:56 GMT Sebastian Huber [49b6931] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Simplify SPI DMA initialization Wed, 14 Dec 2016 06:46:18 GMT Sebastian Huber [d0452eb] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Simplify SPI interrupt handler Wed, 14 Dec 2016 06:44:34 GMT Sebastian Huber [c78928f] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Remove superfluous irq field Wed, 14 Dec 2016 06:43:25 GMT Sebastian Huber [9035630f] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Remove duplicate SPI register field Wed, 14 Dec 2016 06:37:49 GMT Sebastian Huber [62e1e0ff] * c/src/lib/libbsp/arm/atsam/include/atsam-spi.h (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_init.c (modified) bsp/atsam: Simplify SPI initialization Wed, 14 Dec 2016 06:25:49 GMT Sebastian Huber [3afa95b] * c/src/lib/libbsp/arm/atsam/include/atsam-spi.h (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Hide details of SPI driver Wed, 14 Dec 2016 06:18:11 GMT Sebastian Huber [1505eca5] * c/src/lib/libbsp/arm/atsam/include/atsam-spi.h (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_init.c (modified) bsp/atsam: Align SPI API with PIO_Configure() Tue, 13 Dec 2016 14:49:09 GMT Sebastian Huber [5dd02e9] * c/src/lib/libbsp/arm/atsam/include/atsam-spi.h (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Avoid to power on/off the SPI module Tue, 13 Dec 2016 14:18:00 GMT Sebastian Huber [f74e2959] * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Speed up SPI DMA transfer start Tue, 13 Dec 2016 13:28:57 GMT Sebastian Huber [0396f60] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Optimize transfer setup checks Tue, 13 Dec 2016 13:28:32 GMT Sebastian Huber [3417070d] * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: No timeout for SPI DMA transfers Wed, 07 Dec 2016 06:20:38 GMT Chris Johns [c6eead1] * c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg (deleted) * cpukit/libdl/Makefile.am (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-allocator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-unwind-dw2.c (added) * cpukit/libdl/rtl-unwind-dw2.h (added) * cpukit/libdl/rtl-unwind.h (added) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl04/init.c (modified) * testsuites/libtests/dl05/dl-cpp.cpp (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl05/dl-load.h (modified) * testsuites/libtests/dl05/dl-o5.cpp (modified) * testsuites/libtests/dl05/dl05.scn (modified) * testsuites/libtests/dl05/init.c (modified) libdl: Add C++ exception support to loaded modules. This has been ... Fri, 09 Dec 2016 09:49:49 GMT Sebastian Huber [6a9282d] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspclean.c (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/include/default-initial-extension.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testextension.c (modified) * cpukit/score/include/rtems/score/userext.h (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) Rename is_internal to always_set_to_false Update #2825. Thu, 08 Dec 2016 15:41:30 GMT Sebastian Huber [b6606e8] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatal2.c (deleted) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spfatal02/testcase.h (modified) * testsuites/sptests/spfatal03/testcase.h (modified) * testsuites/sptests/spfatal04/testcase.h (modified) * testsuites/sptests/spfatal05/testcase.h (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/testcase.h (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal13/testcase.h (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal17/testcase.h (modified) * testsuites/sptests/spfatal18/testcase.h (modified) * testsuites/sptests/spfatal19/testcase.h (modified) * testsuites/sptests/spfatal20/testcase.h (modified) * testsuites/sptests/spfatal24/testcase.h (modified) * testsuites/sptests/spfatal25/testcase.h (modified) * testsuites/sptests/spfatal27/testcase.h (modified) * testsuites/sptests/spfatal28/testcase.h (modified) * testsuites/sptests/spfatal29/testcase.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove fatal is internal indicator The fatal is internal ... Mon, 05 Dec 2016 03:53:54 GMT Chris Johns [28fda62] * c/src/lib/libbsp/arm/atsam/make/custom/atsamv-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx_ea_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx_plx800_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ncs_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg (modified) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/hurricane/make/custom/hurricane-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938-testsuite.tcfg (modified) * c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5668g-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_app-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_boot-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_0-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_1-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_p1020rdb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t2080rdb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/gensh1/make/custom/gensh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/gensh2/make/custom/gensh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4-testsuite.tcfg (modified) * c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg (added) * testsuites/automake/compile.am (modified) * testsuites/automake/test-subdirs.am (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/testdata/disable-intrcritical-tests.tcfg (modified) * testsuites/testdata/disable-jffs2-tests.tcfg (modified) * testsuites/testdata/disable-mrfs-tests.tcfg (modified) * testsuites/testdata/dltests-broken-on-this-bsp.tcfg (modified) * testsuites/testdata/require-tick-isr.tcfg (modified) * tools/build/rtems-test-check (modified) testsuite: Add test states to the testsuit configuration files. ... Fri, 02 Dec 2016 12:10:31 GMT Sebastian Huber [f65dcc71] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) score: Fix ARM and PowerPC context initialization Update #2751. Tue, 29 Nov 2016 22:19:05 GMT Chris Johns [e629076] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * cpukit/libdebugger/rtems-debugger-arm.c (modified) libdebugger: Build for ARM's without a CP15. Tue, 15 Nov 2016 18:19:39 GMT Joel Sherrill [de7b174e] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg (deleted) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) Remove sparc/sis BSP. closes #2810. Thu, 24 Nov 2016 22:45:35 GMT Chris Johns [8fd465e] * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspreset.c (modified) arm/zynq: Wait for the UART TX FIFO to empty on reset. Tue, 22 Nov 2016 09:13:27 GMT Sebastian Huber [6a1b9e4] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Optimize _ISR_Handler() Use _Thread_Do_dispatch() instead of ... Fri, 25 Nov 2016 18:21:44 GMT Martin Erik Werner [9bf9068] * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) or1k: Avoid multiple iterations over cache Previously, if the cache ...
