# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 04/18/24 02:51:58 Thu, 26 Feb 2015 20:31:27 GMT Martin Galvan [991fdb33] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S (added) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION This patch adds ... Mon, 23 Feb 2015 20:42:59 GMT Gedare Bloom [9d090fb7] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/start/bspinit.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/start/bspinit.S (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) sparc64: fix copyright notices. The sparc64 port had some incorrect ... Fri, 20 Feb 2015 13:08:01 GMT Martin Galvan [dc9aaf7] * c/src/lib/libbsp/arm/shared/start/start.S (modified) ARM: Support VFP-D16 This patch allows the existing FPU code to ... Mon, 16 Feb 2015 10:55:03 GMT Sebastian Huber [c34f94f7] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/shared/bspsmp.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) score: Add _CPU_SMP_Prepare_start_multitasking() Update #2268. Wed, 11 Feb 2015 23:36:34 GMT Joel Sherrill [5640dd5] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01 Wed, 11 Feb 2015 23:34:44 GMT Joel Sherrill [79b45a1] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) lpc1768_mbed-testsuite.tcfg: Add ftp01 Sun, 08 Feb 2015 18:43:09 GMT Sebastian Huber [a9df916] * c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (deleted) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (deleted) * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsimfsconfig01/Makefile.am (added) * testsuites/fstests/fsimfsconfig01/fsimfsconfig01.doc (added) * testsuites/fstests/fsimfsconfig01/fsimfsconfig01.scn (added) * testsuites/fstests/fsimfsconfig01/init.c (added) * testsuites/fstests/fsimfsconfig02/Makefile.am (added) * testsuites/fstests/fsimfsconfig02/fsimfsconfig02.doc (added) * testsuites/fstests/fsimfsconfig02/fsimfsconfig02.scn (added) * testsuites/fstests/fsimfsconfig02/init.c (added) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/libtests/tar03/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/iostream/system.h (modified) * testsuites/sptests/sp47/init.c (modified) * testsuites/sptests/sp48/init.c (modified) IMFS: Add fine grained configuration Remove miniIMFS. Statically ... Wed, 04 Feb 2015 09:33:17 GMT Daniel Cederman [5efbb66] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) grspw: Fix typos Fri, 09 Jan 2015 08:03:59 GMT Daniel Cederman [0c94a46] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/irq/bsp_isr_handler.c (added) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) bsp/sparc: Move BSP_ISR_handler to a separate file and rename it ... Mon, 09 Feb 2015 14:37:00 GMT Sebastian Huber [eb77534] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_fsmount.c (deleted) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Filesystem: Delete unused fsmountme_h handler Wed, 04 Feb 2015 17:20:27 GMT Pavel Pisa [cf4dfc1] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) arm/tms570: sci context has to be writable because it holds state ... Wed, 28 Jan 2015 04:04:26 GMT Nick Withers [d11b711] * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) bsps/powerpc: Fix a clock driver PowerPC Book E: Account for an ... Wed, 14 Jan 2015 22:23:53 GMT Joel Sherrill [296846a] * c/src/lib/libbsp/m68k/mcf5206elite/include/i2c.h (modified) mcf5206elite/include/i2c.h: Fix spelling error Wed, 14 Jan 2015 22:23:16 GMT Joel Sherrill [b1dcae0] * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) stm32f4/.../stm32f105rc-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:59 GMT Joel Sherrill [3d345508] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:41 GMT Joel Sherrill [b302880e] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc24xx/.../lpc2362-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:26 GMT Joel Sherrill [05eaca8] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:09 GMT Joel Sherrill [c1c45f5] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more tests Fri, 23 Jan 2015 13:49:36 GMT Sebastian Huber [e6a7896f] * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (modified) bsp/altera-cyclone-v: Use proper free function Fri, 23 Jan 2015 11:55:02 GMT Sebastian Huber [2a0923c5] * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (modified) bsps/sparc: Use calloc() Close #2242. Fri, 23 Jan 2015 10:31:54 GMT Sebastian Huber [f63e9a3] * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) bsps/powerpc: Fix switch statement in CPU ident Close #2237. Fri, 23 Jan 2015 10:24:01 GMT Sebastian Huber [2f16001] * c/src/libchip/i2c/spi-sd-card.c (modified) libchip: Fix high capacity detection for MMC Close #2239. Mon, 16 Dec 2013 19:36:18 GMT javamonn [2486c492] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) grspw: descriptor tables no longer statically allocated Sun, 21 Dec 2014 19:12:28 GMT Sebastian Huber [c625a641] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/sup_fs_node_type.c (deleted) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_node_type.c (deleted) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (deleted) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (deleted) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (deleted) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) Filesystem: Delete node type operation Use the fstat handler instead. Tue, 20 Jan 2015 13:01:50 GMT Sebastian Huber [60d39b66] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix AltiVec VSCR save/restore Wed, 14 Jan 2015 19:07:59 GMT Sebastian Huber [f1c044d] * c/src/lib/libbsp/powerpc/shared/src/bsp-start-zero.S (modified) bsps/powerpc: Fix conditional compilation Wed, 14 Jan 2015 06:53:00 GMT Sebastian Huber [6042fdb7] * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tod/todcfg.c (modified) bsp/mcf5206elite: Remove inlude in This prevents a ... Tue, 13 Jan 2015 21:40:31 GMT Joel Sherrill [85dbf52] * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) libcpu/powerpc/mpc6xx/mmu/bat.c: Now compiles with gcc 5.x Tue, 13 Jan 2015 10:38:18 GMT Sebastian Huber [f2e6c3e] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/mmu.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t2080rdb.cfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb.cfg (added) * c/src/lib/libbsp/powerpc/qoriq/network/network.c (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_t2080rdb (added) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_t4240rdb (added) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu.c (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/qoriq: Add T2080RDB and T4240RDB variants Tue, 23 Dec 2014 13:18:06 GMT Sebastian Huber [3e2647a7] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: AltiVec and FPU context support Add AltiVec and FPU ... Fri, 19 Dec 2014 12:05:00 GMT Sebastian Huber [c279d0a3] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) bsps/powerpc: Use e500 exc categories for e6500 This is not ... Sat, 10 Jan 2015 19:04:06 GMT Anthony Green [5139d21] * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/start/start.S (modified) moxiesim: Add conditional logic to handle old and new gas syntax Tue, 23 Dec 2014 11:27:53 GMT Sebastian Huber [2e19bfd] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use PPC_HAS_FPU Provide floating point context support ... Tue, 23 Dec 2014 10:38:34 GMT Sebastian Huber [7c16e1a5] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Set PPC_DEFAULT_CACHE_LINE_SIZE for e6500 Tue, 23 Dec 2014 10:34:40 GMT Sebastian Huber [84d3b9b0] * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Use PPC_DEFAULT_CACHE_LINE_SIZE Use it for the default ... Mon, 22 Dec 2014 10:46:17 GMT Sebastian Huber [bb7bd148] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use alternate time base for CPU counter Mon, 22 Dec 2014 09:14:10 GMT Sebastian Huber [691cc20] * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) bsp/qoriq: Fix nanoseconds extension Mon, 22 Dec 2014 06:43:19 GMT Sebastian Huber [a532301c] * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) bsp/qoriq: Increase MAS0[ESEL] width Fri, 19 Dec 2014 12:06:39 GMT Sebastian Huber [0e05095a] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/include/mmu.h (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu.c (modified) bsp/qoriq: Add MAS7 support for MMU This enables usage of the full ... Tue, 23 Dec 2014 08:53:43 GMT Sebastian Huber [71b611d] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: ppc_exc_initialize_interrupt_stack() Tue, 23 Dec 2014 07:30:40 GMT Sebastian Huber [7bad672] * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsps/powerpc: Add TMR access macros Mon, 22 Dec 2014 10:33:13 GMT Sebastian Huber [c32a128] * c/src/lib/libcpu/powerpc/shared/src/cache_.h (modified) bsps/powerpc: Add cache size functions Mon, 22 Dec 2014 09:31:49 GMT Sebastian Huber [7d26f60] * c/src/lib/libcpu/powerpc/shared/src/cache_.h (modified) bsps/powerpc: Delete C pre-processor warning Do not warn about not ... Fri, 19 Dec 2014 11:13:41 GMT Sebastian Huber [494df99f] * c/src/lib/libbsp/powerpc/shared/src/bsp-start-zero.S (modified) bsps/powerpc: Support for 64 byte cache lines Fri, 19 Dec 2014 11:12:08 GMT Sebastian Huber [5175ac6a] * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) bsps/powerpc: Support a cache alignment of 64 Give the BSP the ... Fri, 19 Dec 2014 11:11:06 GMT Sebastian Huber [f6660bfb] * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) bsps/powerpc: Support e6500 indentification Mon, 22 Dec 2014 06:26:19 GMT Sebastian Huber [06251bb] * c/src/lib/libbsp/shared/src/bsp-uboot-board-info.c (modified) bsps/u-boot: Add optional text and data sections Fri, 19 Dec 2014 08:00:18 GMT Sebastian Huber [b79f98f] * c/src/lib/libbsp/powerpc/shared/include/u-boot-generic-board-info.h (added) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) * c/src/lib/libbsp/shared/include/u-boot.h (modified) bsps/u-boot: Update due to API changes Fri, 19 Dec 2014 11:07:23 GMT Sebastian Huber [fca58924] * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) bsps/mpc83xx: Fix warnings Tue, 23 Dec 2014 07:28:24 GMT Sebastian Huber [2a4f9d7] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) smp: Add and use _SMP_Should_start_processor() Sun, 14 Dec 2014 22:27:06 GMT Joel Sherrill [7cdabc49] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_edison.c (added) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/make/custom/edison.cfg (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspreset.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) pc386: Add Edison base support The current support for the Edison ... Sun, 14 Dec 2014 22:02:42 GMT Joel Sherrill [1ae7baf] * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) clock_driver_simidle.c: Add BSP_CLOCK_DRIVER_DELAY This allows the ... Sun, 14 Dec 2014 22:45:08 GMT Joel Sherrill [0a36af04] * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) pc386: Add BSP_ENABLE_COM1_COM4 BSP option This allows the support ... Thu, 11 Dec 2014 21:16:34 GMT Joel Sherrill [93546b8] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) pc386: Add BSP_ENABLE_IDE BSP option This allows the IDE support to ... Thu, 11 Dec 2014 20:49:49 GMT Joel Sherrill [607c854] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) pc386: Add BSP_ENABLE_VGA BSP option This allows the VGA and ... Thu, 27 Nov 2014 06:39:36 GMT Nick Withers [2d5c486] * c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/gti2c.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/rtemscompat.h (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pci_interface.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.inl (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) * c/src/lib/libcpu/powerpc/shared/include/io.h (modified) Use fixed-width C99 types for PowerPC in_be16() and co. Also use ... Wed, 24 Dec 2014 03:27:25 GMT Till Strauman [2573e69] * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) pc386: scan all functions of multi-function PCI devices The ... Wed, 17 Dec 2014 07:13:46 GMT Sebastian Huber [481054e0] * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) bsp/moxiesim: Add cache manager implementation Close #2220. Mon, 15 Dec 2014 12:35:26 GMT Ben Gras [1e587f7d] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/shared/console_control.c (modified) * c/src/lib/libbsp/shared/console_read.c (modified) * c/src/lib/libbsp/shared/console_write.c (modified) bsp/beagle: Fix some warnings The extra includes in console_*.c are ... Mon, 15 Dec 2014 15:42:08 GMT Joel Sherrill [b2a78a3] * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) mcf5225x-testsuite.tcfg: Add fileio Mon, 15 Dec 2014 10:55:27 GMT Sebastian Huber [20aba89] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) bsp/mpc55xxevb: Fix warnings Mon, 15 Dec 2014 10:49:10 GMT Sebastian Huber [b7cd6d51] * c/src/lib/libbsp/powerpc/t32mppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) bsp/t32mppc: Fix warnings Mon, 15 Dec 2014 10:26:06 GMT Sebastian Huber [5063e1a] * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc55xx.inc (modified) * c/src/lib/libbsp/powerpc/t32mppc/make/custom/t32mppc.cfg (modified) bsps/powerpc: Disable SPE for soft-float variants Mon, 15 Dec 2014 06:40:04 GMT Sebastian Huber [3acc619] * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) bsp/lpc32xx: Fix memory map Fixes bug introduced with ... Fri, 12 Dec 2014 15:32:58 GMT Sebastian Huber [3cd3a260] * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/irq.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) bsp/mpc8xx: Fix warnings close #2211 Fri, 12 Dec 2014 14:29:59 GMT Sebastian Huber [3507f3f9] * c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) bsp/mpc8xx: Fix warnings close #2211 Mon, 08 Dec 2014 18:16:37 GMT Gedare Bloom [71d97c9] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) sparc64: put each copyright on one line Fri, 05 Dec 2014 10:07:02 GMT Sebastian Huber [4a3db517] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsps/sparc: Fix trap table initialization Fixes bug introduced with ... Thu, 04 Dec 2014 09:03:50 GMT Sebastian Huber [12072880] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/or1ksim/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/or1k/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Update bug report URL Thu, 04 Dec 2014 08:38:27 GMT Sebastian Huber [e870941] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/shared/bspinit.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/dummy/README (deleted) * cpukit/libmisc/dummy/default-configuration.c (added) * cpukit/libmisc/dummy/dummy.c (deleted) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/defaultconfig01/Makefile.am (added) * testsuites/libtests/defaultconfig01/defaultconfig01.doc (added) * testsuites/libtests/defaultconfig01/defaultconfig01.scn (added) * testsuites/libtests/defaultconfig01/init.c (added) libmisc: More useful default configuration The dummy.c was a ... Thu, 04 Dec 2014 17:21:11 GMT Ben Gras [13d9029] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) beagle bsp: disable watchdog on am335x On recent u-boots, the ... Wed, 03 Dec 2014 23:56:39 GMT Jan Dolezal [038e1dba] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: doxygen and comments related to VESA real mode framebuffer Wed, 03 Dec 2014 23:56:38 GMT Jan Dolezal [d78eac6] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) i386/pc386: cammelCase (struct and function names) to underscores, ... Thu, 04 Dec 2014 14:15:52 GMT Sebastian Huber [adc1dbeb] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsp/leon3: Fix trap table initialization Fixes bug introduced with ... Wed, 03 Dec 2014 10:35:52 GMT Daniel Hellstrom [dff1803] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * doc/cpu_supplement/sparc.t (modified) SPARC: optimize IRQ enable & disable * Coding style cleanups. * ... Tue, 02 Dec 2014 22:36:59 GMT Ben Gras [4081032] * c/src/lib/libbsp/i386/pc386/start/start.S (modified) pc386 bsp fix for default mode If USE_VBE_RM is 0, ... Thu, 30 Jan 2014 01:58:41 GMT Nick Withers [fa4fe456] * c/src/lib/libbsp/powerpc/shared/flash/flash.c (modified) Move the flash size probe into bankValidate() Previously, ... Sun, 23 Nov 2014 21:53:00 GMT Jiri Gaisler [2501814e] * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) sparc/leon2: LEON_Is_interrupt_masked for Leon2 in leon.h wrongly ... Sun, 23 Nov 2014 21:53:00 GMT Jiri Gaisler [291f30f] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) sparc/leon3: LEON_Is_interrupt_masked for Leon3 in leon.h wrongly ... Tue, 11 Nov 2014 14:18:01 GMT Daniel Hellstrom [0d3b5d47] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) SPARC: optimize window underflow trap Save five instructions on ... Wed, 28 May 2014 08:29:37 GMT Daniel Hellstrom [6930aa7f] * c/src/lib/libcpu/sparc/reg_win/window.S (modified) SPARC: optimize window overflow trap entry By using a optimized ... Tue, 27 May 2014 09:15:46 GMT Daniel Hellstrom [348d1812] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) SPARC: window overflow optimization I see no need for waiting the 3 ... Mon, 01 Dec 2014 03:55:23 GMT Chris Johns [dd309b1] * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/copyvectors.c (added) * c/src/lib/libbsp/m68k/mcf5235/startup/init5235.c (modified) m68k/mcf5235: GCC 4.9.2 generates invalid code for Init5235. Move ... Thu, 27 Nov 2014 13:03:34 GMT Sebastian Huber [3a8566b7] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/hwreg_vals.h (deleted) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) bsp/qoriq: Delete empty header file close #2062 Tue, 25 Nov 2014 07:40:20 GMT Sebastian Huber [cbc433c7] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/nocache-heap.h (deleted) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/mmu-config.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c (deleted) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (modified) * c/src/lib/libbsp/arm/csb336/startup/linkcmds (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb337 (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb637 (modified) * c/src/lib/libbsp/arm/edb7312/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gp32/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gumstix/startup/linkcmds (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s3749 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965_qemu (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm4f120 (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram_eth (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_ea_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_ea_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_plx800_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2362 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc23xx_tli800 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ea (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_ext (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_2 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) * c/src/lib/libbsp/arm/nds/startup/linkcmds (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/linkcmds (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/smdk2410/startup/linkcmds (modified) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f105rc (modified) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f4 (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in (modified) bsps/arm: Add .nocache section This section can be use to provide a ... Wed, 19 Nov 2014 20:32:51 GMT Josh Oguin [aed6e1d] * c/src/libchip/serial/z85c30.c (modified) libchip/serial/z85c30.c: Remove redundant assignment This was ... Wed, 19 Nov 2014 20:28:08 GMT Josh Oguin [02958c5e] * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) libchip/serial/ns16550* and z8530*: Assert on baud number to avoid ... Wed, 19 Nov 2014 20:26:58 GMT Josh Oguin [0ad1e80] * c/src/libchip/display/disp_hcms29xx.c (modified) libchip/display/disp_hcms29xx.c: Remove useless variable and check ... Wed, 19 Nov 2014 20:26:11 GMT Josh Oguin [61f8d668] * c/src/lib/libbsp/shared/bspinit.c (modified) libbsp/shared/bspinit.c: Document assumption of NULL returned Tue, 25 Nov 2014 13:58:13 GMT Sebastian Huber [7e5c9b89] * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/bfin/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/lm32/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/nios2/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/shared/src/cache_aligned_malloc.c (deleted) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc64/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/cachealignedalloc.c (added) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcache01/spcache01.doc (modified) * testsuites/sptests/spcache01/spcache01.scn (modified) rtems: Move rtems_cache_aligned_malloc() Make sure also the size is ... Tue, 25 Nov 2014 07:36:58 GMT Sebastian Huber [42fe0d3] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 avoid infinite loops Mon, 24 Nov 2014 08:44:50 GMT Sebastian Huber [55db0e5] * c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg (modified) bsp/ngmp: Use -muser-mode GCC option This option is necessary to ... Sun, 23 Nov 2014 15:48:17 GMT Joel Sherrill [b46a31e] * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) leon2: include not close #2113 Fri, 21 Nov 2014 19:11:57 GMT Joel Sherrill [ff1c613] * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405.c (modified) * c/src/lib/libbsp/powerpc/haleakala/network/network.c (modified) powerpc/haleakala: Fix warnings Fri, 21 Nov 2014 17:15:22 GMT Nigel Spon [502609c8] * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/include/mmu_405.h (added) * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405.c (added) * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405asm.S (added) * c/src/lib/libbsp/powerpc/haleakala/network/network.c (added) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405ex.h (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405gp.h (modified) powerpc/haleakala: Add network driver close 1405 Fri, 21 Nov 2014 07:49:57 GMT Sebastian Huber [11925eef] * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/pppd/pppd.h (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio03/init.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/sptests/sp48/init.c (modified) * testsuites/sptests/sp63/init.c (modified) Delete or rename MIN/MAX macros and defines Include ... Thu, 20 Nov 2014 16:05:02 GMT Gedare Bloom [280f4ecc] * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) autotools: regenerate preinstall.am for pc386 Thu, 20 Nov 2014 14:00:33 GMT Jan Dolezal [067da5c] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (added) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) i386/pc386: VESA based frame buffer utilizing real mode interrupt 10h Thu, 20 Nov 2014 14:00:32 GMT Jan Dolezal [c5a74946] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (added) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA ... Thu, 20 Nov 2014 14:00:31 GMT Jan Dolezal [586c86c7] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (added) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (added) i386/shared/realmode_int: real mode interrupt interface
