# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/06/24 02:36:10 Tue, 29 Nov 2005 18:47:05 GMT Till Straumann [8c6579b] * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (modified) - trivial correction in comment Tue, 22 Nov 2005 15:48:10 GMT Joel Sherrill [c2eeaaf] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Fixed format. Tue, 22 Nov 2005 03:21:26 GMT Ralf Corsepius [5367a6e] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) 2005-11-22 Ralf Corsepius * ... Tue, 22 Nov 2005 01:24:10 GMT Till Straumann [36c30fe2] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) 2005-11-21 Till Straumann * ... Mon, 21 Nov 2005 04:40:11 GMT Ralf Corsepius [2e6c877] * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp03/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp04/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp05/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp06/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp07/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp08/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp09/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp10/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp11/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp12/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp13/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp14/node2/Makefile.am (modified) Add dist_scn_DATA = *.scn. Sun, 20 Nov 2005 17:13:02 GMT Ralf Corsepius [b702c7d] * c/src/ada-tests/mptests/Makefile.am (modified) Re-add mp?? tests. Sun, 20 Nov 2005 17:12:45 GMT Ralf Corsepius [82f0ad1] * c/src/ada-tests/configure.ac (modified) Re-add mptests*Makefile.am. Sun, 20 Nov 2005 17:12:32 GMT Ralf Corsepius [e7d5d4b] * c/src/ada-tests/ChangeLog (modified) 2005-11-20 Ralf Corsepius * ... Sun, 20 Nov 2005 17:10:34 GMT Ralf Corsepius [0f4b25df] * c/src/ada-tests/.cvsignore (modified) * c/src/ada-tests/mptests/.cvsignore (modified) * c/src/ada-tests/mptests/mp01/.cvsignore (modified) * c/src/ada-tests/mptests/mp01/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp01/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp02/.cvsignore (modified) * c/src/ada-tests/mptests/mp02/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp02/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp03/.cvsignore (modified) * c/src/ada-tests/mptests/mp03/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp03/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp04/.cvsignore (modified) * c/src/ada-tests/mptests/mp04/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp04/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp05/.cvsignore (modified) * c/src/ada-tests/mptests/mp05/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp05/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp06/.cvsignore (modified) * c/src/ada-tests/mptests/mp06/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp06/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp07/.cvsignore (modified) * c/src/ada-tests/mptests/mp07/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp07/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp08/.cvsignore (modified) * c/src/ada-tests/mptests/mp08/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp08/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp09/.cvsignore (modified) * c/src/ada-tests/mptests/mp09/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp09/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp10/.cvsignore (modified) * c/src/ada-tests/mptests/mp10/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp10/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp11/.cvsignore (modified) * c/src/ada-tests/mptests/mp11/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp11/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp12/.cvsignore (modified) * c/src/ada-tests/mptests/mp12/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp12/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp13/.cvsignore (modified) * c/src/ada-tests/mptests/mp13/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp13/node2/.cvsignore (modified) * c/src/ada-tests/mptests/mp14/.cvsignore (modified) * c/src/ada-tests/mptests/mp14/node1/.cvsignore (modified) * c/src/ada-tests/mptests/mp14/node2/.cvsignore (modified) * c/src/ada-tests/samples/.cvsignore (modified) * c/src/ada-tests/samples/base_mp/.cvsignore (modified) * c/src/ada-tests/samples/base_mp/node1/.cvsignore (modified) * c/src/ada-tests/samples/base_mp/node2/.cvsignore (modified) * c/src/ada-tests/samples/base_sp/.cvsignore (modified) * c/src/ada-tests/samples/hello/.cvsignore (modified) * c/src/ada-tests/samples/ticker/.cvsignore (modified) * c/src/ada-tests/sptests/.cvsignore (modified) * c/src/ada-tests/sptests/sp01/.cvsignore (modified) * c/src/ada-tests/sptests/sp02/.cvsignore (modified) * c/src/ada-tests/sptests/sp03/.cvsignore (modified) * c/src/ada-tests/sptests/sp04/.cvsignore (modified) * c/src/ada-tests/sptests/sp05/.cvsignore (modified) * c/src/ada-tests/sptests/sp06/.cvsignore (modified) * c/src/ada-tests/sptests/sp07/.cvsignore (modified) * c/src/ada-tests/sptests/sp08/.cvsignore (modified) * c/src/ada-tests/sptests/sp09/.cvsignore (modified) * c/src/ada-tests/sptests/sp11/.cvsignore (modified) * c/src/ada-tests/sptests/sp12/.cvsignore (modified) * c/src/ada-tests/sptests/sp13/.cvsignore (modified) * c/src/ada-tests/sptests/sp14/.cvsignore (modified) * c/src/ada-tests/sptests/sp15/.cvsignore (modified) * c/src/ada-tests/sptests/sp16/.cvsignore (modified) * c/src/ada-tests/sptests/sp17/.cvsignore (modified) * c/src/ada-tests/sptests/sp19/.cvsignore (modified) * c/src/ada-tests/sptests/sp20/.cvsignore (modified) * c/src/ada-tests/sptests/sp21/.cvsignore (modified) * c/src/ada-tests/sptests/sp22/.cvsignore (modified) * c/src/ada-tests/sptests/sp23/.cvsignore (modified) * c/src/ada-tests/sptests/sp24/.cvsignore (modified) * c/src/ada-tests/sptests/sp25/.cvsignore (modified) * c/src/ada-tests/sptests/spsize/.cvsignore (modified) * c/src/ada-tests/support/.cvsignore (modified) * c/src/ada-tests/tmtests/.cvsignore (modified) * c/src/ada-tests/tmtests/tm01/.cvsignore (modified) * c/src/ada-tests/tmtests/tm02/.cvsignore (modified) * c/src/ada-tests/tmtests/tm03/.cvsignore (modified) * c/src/ada-tests/tmtests/tm04/.cvsignore (modified) * c/src/ada-tests/tmtests/tm05/.cvsignore (modified) * c/src/ada-tests/tmtests/tm06/.cvsignore (modified) * c/src/ada-tests/tmtests/tm07/.cvsignore (modified) * c/src/ada-tests/tmtests/tm08/.cvsignore (modified) * c/src/ada-tests/tmtests/tm09/.cvsignore (modified) * c/src/ada-tests/tmtests/tm10/.cvsignore (modified) * c/src/ada-tests/tmtests/tm11/.cvsignore (modified) * c/src/ada-tests/tmtests/tm12/.cvsignore (modified) * c/src/ada-tests/tmtests/tm13/.cvsignore (modified) * c/src/ada-tests/tmtests/tm14/.cvsignore (modified) * c/src/ada-tests/tmtests/tm15/.cvsignore (modified) * c/src/ada-tests/tmtests/tm16/.cvsignore (modified) * c/src/ada-tests/tmtests/tm17/.cvsignore (modified) * c/src/ada-tests/tmtests/tm18/.cvsignore (modified) * c/src/ada-tests/tmtests/tm19/.cvsignore (modified) * c/src/ada-tests/tmtests/tm20/.cvsignore (modified) * c/src/ada-tests/tmtests/tm21/.cvsignore (modified) * c/src/ada-tests/tmtests/tm22/.cvsignore (modified) * c/src/ada-tests/tmtests/tm23/.cvsignore (modified) * c/src/ada-tests/tmtests/tm24/.cvsignore (modified) * c/src/ada-tests/tmtests/tm25/.cvsignore (modified) * c/src/ada-tests/tmtests/tm28/.cvsignore (modified) * c/src/ada-tests/tmtests/tm29/.cvsignore (modified) * c/src/ada-tests/tmtests/tmck/.cvsignore (modified) * c/src/ada-tests/tmtests/tmoverhd/.cvsignore (modified) Regenerate. Sun, 20 Nov 2005 17:09:19 GMT Ralf Corsepius [8fdfc9f6] * c/src/ada-tests/Makefile.am (modified) Cleanup. Sun, 20 Nov 2005 17:08:04 GMT Ralf Corsepius [603b359] * c/src/ada-tests/mptests/mp02/Makefile.am (added) * c/src/ada-tests/mptests/mp02/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp02/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp03/Makefile.am (added) * c/src/ada-tests/mptests/mp03/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp03/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp04/Makefile.am (added) * c/src/ada-tests/mptests/mp04/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp04/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp05/Makefile.am (added) * c/src/ada-tests/mptests/mp05/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp05/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp06/Makefile.am (added) * c/src/ada-tests/mptests/mp06/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp06/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp07/Makefile.am (added) * c/src/ada-tests/mptests/mp07/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp07/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp08/Makefile.am (added) * c/src/ada-tests/mptests/mp08/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp08/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp09/Makefile.am (added) * c/src/ada-tests/mptests/mp09/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp09/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp10/Makefile.am (added) * c/src/ada-tests/mptests/mp10/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp10/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp11/Makefile.am (added) * c/src/ada-tests/mptests/mp11/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp11/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp12/Makefile.am (added) * c/src/ada-tests/mptests/mp12/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp12/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp13/Makefile.am (added) * c/src/ada-tests/mptests/mp13/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp13/node2/Makefile.am (added) * c/src/ada-tests/mptests/mp14/Makefile.am (added) * c/src/ada-tests/mptests/mp14/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp14/node2/Makefile.am (added) New. Sun, 20 Nov 2005 17:05:47 GMT Ralf Corsepius [5864602] * c/src/ada-tests/ChangeLog (modified) 2005-11-20 Ralf Corsepius * ... Sun, 20 Nov 2005 17:00:57 GMT Ralf Corsepius [b960faa6] * c/src/ada-tests/mptests/mp01/Makefile.am (modified) Cleanup. Sun, 20 Nov 2005 08:58:17 GMT Ralf Corsepius [d605c210] * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) Cleanup. Sun, 20 Nov 2005 08:56:07 GMT Ralf Corsepius [34771307] * c/src/ada-tests/mptests/mp01/node1/mp01.scn (deleted) * c/src/ada-tests/mptests/mp01/node2/mp01.scn (deleted) * c/src/ada-tests/mptests/mp02/node1/mp02.scn (deleted) * c/src/ada-tests/mptests/mp02/node2/mp02.scn (deleted) * c/src/ada-tests/mptests/mp03/node1/mp03.scn (deleted) * c/src/ada-tests/mptests/mp03/node2/mp03.scn (deleted) * c/src/ada-tests/mptests/mp04/node1/mp04.scn (deleted) * c/src/ada-tests/mptests/mp04/node2/mp04.scn (deleted) * c/src/ada-tests/mptests/mp05/node1/mp05.scn (deleted) * c/src/ada-tests/mptests/mp05/node2/mp05.scn (deleted) * c/src/ada-tests/mptests/mp06/node1/mp06.scn (deleted) * c/src/ada-tests/mptests/mp06/node2/mp06.scn (deleted) * c/src/ada-tests/mptests/mp07/node1/mp07.scn (deleted) * c/src/ada-tests/mptests/mp07/node2/mp07.scn (deleted) * c/src/ada-tests/mptests/mp08/node1/mp08.scn (deleted) * c/src/ada-tests/mptests/mp08/node2/mp08.scn (deleted) * c/src/ada-tests/mptests/mp09/node1/mp09.scn (deleted) * c/src/ada-tests/mptests/mp09/node2/mp09.scn (deleted) * c/src/ada-tests/mptests/mp10/node1/mp10.scn (deleted) * c/src/ada-tests/mptests/mp10/node2/mp10.scn (deleted) * c/src/ada-tests/mptests/mp11/node1/mp11.scn (deleted) * c/src/ada-tests/mptests/mp11/node2/mp11.scn (deleted) * c/src/ada-tests/mptests/mp12/node1/mp12.scn (deleted) * c/src/ada-tests/mptests/mp12/node2/mp12.scn (deleted) * c/src/ada-tests/mptests/mp13/node1/mp13.scn (deleted) * c/src/ada-tests/mptests/mp13/node2/mp13.scn (deleted) * c/src/ada-tests/mptests/mp14/node1/mp14.scn (deleted) * c/src/ada-tests/mptests/mp14/node2/mp14.scn (deleted) Remove. Sun, 20 Nov 2005 08:55:21 GMT Ralf Corsepius [1c9abf82] * c/src/ada-tests/mptests/mp01/node1/mp01-node1.scn (added) * c/src/ada-tests/mptests/mp01/node2/mp01-node2.scn (added) * c/src/ada-tests/mptests/mp02/node1/mp02-node1.scn (added) * c/src/ada-tests/mptests/mp02/node2/mp02-node2.scn (added) * c/src/ada-tests/mptests/mp03/node1/mp03-node1.scn (added) * c/src/ada-tests/mptests/mp03/node2/mp03-node2.scn (added) * c/src/ada-tests/mptests/mp04/node1/mp04-node1.scn (added) * c/src/ada-tests/mptests/mp04/node2/mp04-node2.scn (added) * c/src/ada-tests/mptests/mp05/node1/mp05-node1.scn (added) * c/src/ada-tests/mptests/mp05/node2/mp05-node2.scn (added) * c/src/ada-tests/mptests/mp06/node1/mp06-node1.scn (added) * c/src/ada-tests/mptests/mp06/node2/mp06-node2.scn (added) * c/src/ada-tests/mptests/mp07/node1/mp07-node1.scn (added) * c/src/ada-tests/mptests/mp07/node2/mp07-node2.scn (added) * c/src/ada-tests/mptests/mp08/node1/mp08-node1.scn (added) * c/src/ada-tests/mptests/mp08/node2/mp08-node2.scn (added) * c/src/ada-tests/mptests/mp09/node1/mp09-node1.scn (added) * c/src/ada-tests/mptests/mp09/node2/mp09-node2.scn (added) * c/src/ada-tests/mptests/mp10/node1/mp10-node1.scn (added) * c/src/ada-tests/mptests/mp10/node2/mp10-node2.scn (added) * c/src/ada-tests/mptests/mp11/node1/mp11-node1.scn (added) * c/src/ada-tests/mptests/mp11/node2/mp11-node2.scn (added) * c/src/ada-tests/mptests/mp12/node1/mp12-node1.scn (added) * c/src/ada-tests/mptests/mp12/node2/mp12-node2.scn (added) * c/src/ada-tests/mptests/mp13/node1/mp13-node1.scn (added) * c/src/ada-tests/mptests/mp13/node2/mp13-node2.scn (added) * c/src/ada-tests/mptests/mp14/node1/mp14-node1.scn (added) * c/src/ada-tests/mptests/mp14/node2/mp14-node2.scn (added) New. Sun, 20 Nov 2005 08:51:05 GMT Ralf Corsepius [c2cdd9d] * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) * c/src/ada-tests/samples/base_sp/Makefile.am (modified) * c/src/ada-tests/samples/hello/Makefile.am (modified) * c/src/ada-tests/samples/ticker/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp02/Makefile.am (modified) * c/src/ada-tests/sptests/sp03/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp05/Makefile.am (modified) * c/src/ada-tests/sptests/sp06/Makefile.am (modified) * c/src/ada-tests/sptests/sp07/Makefile.am (modified) * c/src/ada-tests/sptests/sp08/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp11/Makefile.am (modified) * c/src/ada-tests/sptests/sp12/Makefile.am (modified) * c/src/ada-tests/sptests/sp13/Makefile.am (modified) * c/src/ada-tests/sptests/sp14/Makefile.am (modified) * c/src/ada-tests/sptests/sp15/Makefile.am (modified) * c/src/ada-tests/sptests/sp16/Makefile.am (modified) * c/src/ada-tests/sptests/sp17/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp20/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/Makefile.am (modified) * c/src/ada-tests/sptests/sp22/Makefile.am (modified) * c/src/ada-tests/sptests/sp23/Makefile.am (modified) * c/src/ada-tests/sptests/sp24/Makefile.am (modified) * c/src/ada-tests/sptests/sp25/Makefile.am (modified) Add scndir. Install *.scn to scndir. Sun, 20 Nov 2005 08:49:38 GMT Ralf Corsepius [1471bd9] * c/src/ada-tests/ChangeLog (modified) 2005-11-20 Ralf Corsepius * ... Sun, 20 Nov 2005 08:44:02 GMT Ralf Corsepius [1245c44] * c/src/ada-tests/configure.ac (modified) Add rtems_ada_testsdir. Sun, 20 Nov 2005 08:33:40 GMT Ralf Corsepius [ef6b461] * c/src/ada-tests/ChangeLog (modified) 2005-11-20 Ralf Corsepius * ... Sun, 20 Nov 2005 08:33:24 GMT Ralf Corsepius [c31ac15e] * c/src/ada-tests/samples/base_mp/Makefile.am (modified) Remove references to *.scn. Sun, 20 Nov 2005 08:33:03 GMT Ralf Corsepius [6f9d34c] * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) Eliminate NODE. Sun, 20 Nov 2005 08:32:40 GMT Ralf Corsepius [da90bab4] * c/src/ada-tests/samples/base_mp/node1/base_mp-node1.scn (added) * c/src/ada-tests/samples/base_mp/node2/base_mp-node2.scn (added) New. Sun, 20 Nov 2005 08:32:20 GMT Ralf Corsepius [e0f6a78d] * c/src/ada-tests/samples/base_mp/node1/base_mp.scn (deleted) * c/src/ada-tests/samples/base_mp/node2/base_mp.scn (deleted) Remove. Sun, 20 Nov 2005 08:11:32 GMT Ralf Corsepius [436135fe] * c/src/ChangeLog (modified) 2005-11-20 Ralf Corsepius * ... Sun, 20 Nov 2005 08:11:17 GMT Ralf Corsepius [430a833d] * c/src/automake/compile.am (modified) Remove RTEMS_USE_GCC. Remove RTEMS_RELLDFLAGS. Sun, 20 Nov 2005 08:10:58 GMT Ralf Corsepius [546c41d0] * c/src/aclocal/prog-cc.m4 (modified) Remove RTEMS_USE_GCC. Add RTEMS_RELLDFLAGS. Sun, 20 Nov 2005 08:07:55 GMT Ralf Corsepius [a4a40dac] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2005-11-20 Ralf Corsepius * ... Sun, 20 Nov 2005 07:04:30 GMT Ralf Corsepius [d75e9b1] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) 2005-11-20 Ralf Corsepius * ... Thu, 17 Nov 2005 14:29:23 GMT Joel Sherrill [cb19f3f8] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) 2005-11-17 Joel Sherrill * ... Mon, 14 Nov 2005 05:42:10 GMT Ralf Corsepius [a0321355] * c/src/ChangeLog (modified) 2005-11-14 Ralf Corsepius * ... Mon, 14 Nov 2005 05:40:11 GMT Ralf Corsepius [750a686] * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/if_dc.c (modified) Reflect mii.h and if_media.h having moved. Mon, 14 Nov 2005 05:37:33 GMT Ralf Corsepius [c3eeb747] * c/src/libchip/preinstall.am (modified) Regenerate. Mon, 14 Nov 2005 05:36:25 GMT Ralf Corsepius [e7d0cafa] * c/src/libchip/Makefile.am (modified) Reflect having moved libchip/network/mii.h and ... Mon, 14 Nov 2005 05:35:03 GMT Ralf Corsepius [cdfdef4c] * c/src/libchip/network/if_media.h (deleted) * c/src/libchip/network/mii.h (deleted) Remove (Moved to cpukit). Sun, 13 Nov 2005 09:16:48 GMT Ralf Corsepius [8de9ae0] * c/src/automake/compile.am (modified) * c/src/automake/host.am (modified) * c/src/automake/local.am (modified) * c/src/automake/subdirs.am (modified) Remove depend. Sun, 13 Nov 2005 09:16:17 GMT Ralf Corsepius [d366255b] * c/src/ChangeLog (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 08:15:24 GMT Ralf Corsepius [3136ff03] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 05:38:34 GMT Ralf Corsepius [15ec224] * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/bsp_specs (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 05:17:24 GMT Ralf Corsepius [17e451a] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/bsp_specs (modified) 2005-11-13 Ralf Corsepius * ... Sat, 12 Nov 2005 07:21:23 GMT Ralf Corsepius [bf221c5] * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/bsp_specs (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/bsp_specs (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 07:08:33 GMT Ralf Corsepius [bcd0867d] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/bsp_specs (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 07:04:49 GMT Ralf Corsepius [b1a0917] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 05:26:25 GMT Ralf Corsepius [cea62b21] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) 2005-11-12 Ralf Corsepius * ... Fri, 11 Nov 2005 15:48:24 GMT Eric Norum [46fa1f64] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/README (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) Clean up UART2 pin setup. Protect pin setup code. Wed, 09 Nov 2005 17:23:35 GMT Eric Norum [0cf20a9] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) Need to install vme_am_defs.h. Wed, 09 Nov 2005 16:53:30 GMT Ralf Corsepius [ac3a37d7] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) 2005-11-09 Ralf Corsepius * ... Wed, 09 Nov 2005 16:51:26 GMT Ralf Corsepius [c29d03e9] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) 2005-11-09 Ralf Corsepius * ... Wed, 09 Nov 2005 16:38:33 GMT Eric Norum [d5b3fe52] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) Fix disagreement between GCCSPECS and GCC_SPECS. Wed, 09 Nov 2005 10:25:28 GMT Ralf Corsepius [3f74676] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2005-11-09 Ralf Corsepius * ... Tue, 08 Nov 2005 20:11:02 GMT Eric Norum [8e6835a5] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) Add code to set up pin assignments. Tue, 08 Nov 2005 14:34:23 GMT Ralf Corsepius [95cd708] * c/src/ChangeLog (modified) 2005-11-08 Ralf Corsepius * ... Tue, 08 Nov 2005 14:28:49 GMT Ralf Corsepius [1343b11d] * c/src/aclocal/env-rtemsbsp.m4 (modified) Remove RTEMS_BSP_SPECS. Remove GCC_SPECS. Tue, 08 Nov 2005 14:27:37 GMT Ralf Corsepius [1eeac702] * c/src/aclocal/prog-cc.m4 (modified) Add GCCSPECS Tue, 08 Nov 2005 14:27:17 GMT Ralf Corsepius [f455ae71] * c/src/automake/compile.am (modified) Remove GCCSPECS Tue, 08 Nov 2005 10:46:29 GMT Ralf Corsepius [347733c4] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) 2005-11-08 Ralf Corsepius * ... Tue, 08 Nov 2005 10:46:19 GMT Ralf Corsepius [b07b75f] * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) Remove obsolete types (*unsigned32). Mon, 07 Nov 2005 17:30:17 GMT Eric Norum [91c832b9] * c/src/lib/libbsp/m68k/uC5282/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/uC5282/start/start.S (modified) Remove assignation to U.S. Government. Mon, 07 Nov 2005 17:22:23 GMT Eric Norum [12b36efe] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/tm27.h (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/init5282.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/uC5282/timer/timer.c (modified) Assign copyright to OAR since all files descend from OAR's source. Mon, 07 Nov 2005 16:19:21 GMT Joel Sherrill [086c1c3] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * testsuites/ChangeLog (modified) Fixed formatting. Mon, 07 Nov 2005 15:36:31 GMT Joel Sherrill [fb08bd92] * c/src/lib/libbsp/powerpc/ChangeLog (modified) Repaired some changelog entries lost. Mon, 07 Nov 2005 06:26:45 GMT Ralf Corsepius [cb98129] * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 06:26:37 GMT Ralf Corsepius [71a7ed0] * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspstart.c (modified) Eliminate unsigned32. Mon, 07 Nov 2005 06:26:08 GMT Ralf Corsepius [8fd9e978] * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) Eliminate unsigned32, unsigned8. Mon, 07 Nov 2005 06:23:24 GMT Ralf Corsepius [e3996e2b] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 06:23:14 GMT Ralf Corsepius [9ab9f026] * c/src/lib/libbsp/m68k/av5282/network/network.c (modified) Several minor bug fixes. Mon, 07 Nov 2005 02:35:02 GMT Ralf Corsepius [e6d36b5] * c/src/lib/libcpu/powerpc/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 02:34:13 GMT Ralf Corsepius [fb6bc245] * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) Eliminate rtems_unsigned32. Mon, 07 Nov 2005 02:33:57 GMT Ralf Corsepius [0f8b4e9] * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) Eliminate unsigned32. Sun, 06 Nov 2005 09:16:14 GMT Ralf Corsepius [7880193] * c/src/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 09:15:50 GMT Ralf Corsepius [28fcdde] * c/src/libchip/i2c/i2c-2b-eeprom.c (modified) * c/src/libchip/rtc/mc146818a.h (modified) Eliminate obsolete types. Sun, 06 Nov 2005 08:32:36 GMT Ralf Corsepius [f2535df] * c/src/lib/libbsp/i386/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 08:32:13 GMT Ralf Corsepius [4d90b98e] * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) Reflect API changes. Sun, 06 Nov 2005 06:25:30 GMT Ralf Corsepius [1fdeb22] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 06:25:07 GMT Ralf Corsepius [3e21ecf] * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) Remove C++-style comments. Fri, 04 Nov 2005 18:10:25 GMT Ralf Corsepius [f6435d36] * c/src/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 18:09:59 GMT Ralf Corsepius [f82dabae] * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) Use libcpu/byteorder.h for i386. Fri, 04 Nov 2005 17:54:49 GMT Ralf Corsepius [830976c] * c/src/lib/libcpu/i386/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 17:54:37 GMT Ralf Corsepius [22d3aed] * c/src/lib/libcpu/i386/Makefile.am (modified) Add preinstall.am Fri, 04 Nov 2005 17:54:15 GMT Ralf Corsepius [08e2639] * c/src/lib/libcpu/i386/preinstall.am (added) New Fri, 04 Nov 2005 17:52:36 GMT Ralf Corsepius [4818350] * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 17:50:48 GMT Ralf Corsepius [ae5f7a08] * c/src/lib/libcpu/i386/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 17:50:34 GMT Ralf Corsepius [5acb4d0] * c/src/lib/libcpu/i386/byteorder.h (added) New. Fri, 04 Nov 2005 12:29:38 GMT Ralf Corsepius [47b5568] * c/src/lib/libcpu/powerpc/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 12:29:17 GMT Ralf Corsepius [d04e891] * c/src/lib/libcpu/powerpc/shared/include/byteorder.h (modified) Remove __arch_swap (Unused). Fri, 04 Nov 2005 12:27:42 GMT Ralf Corsepius [0a708729] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/configure.ac (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 12:26:25 GMT Ralf Corsepius [4609200] * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 09:41:41 GMT Ralf Corsepius [03c4c16] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Cleanup. Fri, 04 Nov 2005 09:34:39 GMT Ralf Corsepius [8238048] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Merge new-exceptions/ChangeLog Fri, 04 Nov 2005 09:33:58 GMT Ralf Corsepius [b6a645da] * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (deleted) Remove (Merged into ../ChangeLog) Fri, 04 Nov 2005 09:19:44 GMT Ralf Corsepius [7634813] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Cleanup Fri, 04 Nov 2005 09:16:46 GMT Ralf Corsepius [751076a6] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Merge old-exceptions/ChangeLog Fri, 04 Nov 2005 09:15:20 GMT Ralf Corsepius [692d614] * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (deleted) Remove (Merged into ../ChangeLog) Fri, 04 Nov 2005 09:05:57 GMT Ralf Corsepius [d3b8db7b] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 08:17:56 GMT Till Straumann [784e792] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/shared/vmeUniverse/README.universe (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (added) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (added) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vme_am_defs.h (added) 2005-11-04 Till Straumann ... Fri, 04 Nov 2005 08:10:42 GMT Till Straumann [6d3ff66f] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/vme/vmeconfig.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/README (added) * c/src/lib/libbsp/powerpc/shared/vme/VME.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c (added) * c/src/lib/libbsp/powerpc/shared/vme/vmeconfig.c (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 06:30:38 GMT Ralf Corsepius [818fbd83] * c/src/libchip/Makefile.am (modified) Cosmetics Fri, 04 Nov 2005 06:28:01 GMT Ralf Corsepius [5a9022c3] * c/src/libchip/preinstall.am (modified) Regenerate. Fri, 04 Nov 2005 06:14:26 GMT Till Straumann [c4423933] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 04:03:31 GMT Till Straumann [94c31843] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) 2005-11-03 Till Straumann ...
