# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/07/24 14:12:08 Sun, 13 Nov 2005 09:16:48 GMT Ralf Corsepius [8de9ae0] * c/src/automake/compile.am (modified) * c/src/automake/host.am (modified) * c/src/automake/local.am (modified) * c/src/automake/subdirs.am (modified) Remove depend. Sun, 13 Nov 2005 09:16:17 GMT Ralf Corsepius [d366255b] * c/src/ChangeLog (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 08:15:24 GMT Ralf Corsepius [3136ff03] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 05:38:34 GMT Ralf Corsepius [15ec224] * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/bsp_specs (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 05:17:24 GMT Ralf Corsepius [17e451a] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/bsp_specs (modified) 2005-11-13 Ralf Corsepius * ... Sat, 12 Nov 2005 07:21:23 GMT Ralf Corsepius [bf221c5] * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/bsp_specs (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/bsp_specs (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 07:08:33 GMT Ralf Corsepius [bcd0867d] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/bsp_specs (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 07:04:49 GMT Ralf Corsepius [b1a0917] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 05:26:25 GMT Ralf Corsepius [cea62b21] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) 2005-11-12 Ralf Corsepius * ... Fri, 11 Nov 2005 15:48:24 GMT Eric Norum [46fa1f64] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/README (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) Clean up UART2 pin setup. Protect pin setup code. Wed, 09 Nov 2005 17:23:35 GMT Eric Norum [0cf20a9] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) Need to install vme_am_defs.h. Wed, 09 Nov 2005 16:53:30 GMT Ralf Corsepius [ac3a37d7] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) 2005-11-09 Ralf Corsepius * ... Wed, 09 Nov 2005 16:51:26 GMT Ralf Corsepius [c29d03e9] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) 2005-11-09 Ralf Corsepius * ... Wed, 09 Nov 2005 16:38:33 GMT Eric Norum [d5b3fe52] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) Fix disagreement between GCCSPECS and GCC_SPECS. Wed, 09 Nov 2005 10:25:28 GMT Ralf Corsepius [3f74676] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2005-11-09 Ralf Corsepius * ... Tue, 08 Nov 2005 20:11:02 GMT Eric Norum [8e6835a5] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) Add code to set up pin assignments. Tue, 08 Nov 2005 14:34:23 GMT Ralf Corsepius [95cd708] * c/src/ChangeLog (modified) 2005-11-08 Ralf Corsepius * ... Tue, 08 Nov 2005 14:28:49 GMT Ralf Corsepius [1343b11d] * c/src/aclocal/env-rtemsbsp.m4 (modified) Remove RTEMS_BSP_SPECS. Remove GCC_SPECS. Tue, 08 Nov 2005 14:27:37 GMT Ralf Corsepius [1eeac702] * c/src/aclocal/prog-cc.m4 (modified) Add GCCSPECS Tue, 08 Nov 2005 14:27:17 GMT Ralf Corsepius [f455ae71] * c/src/automake/compile.am (modified) Remove GCCSPECS Tue, 08 Nov 2005 10:46:29 GMT Ralf Corsepius [347733c4] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) 2005-11-08 Ralf Corsepius * ... Tue, 08 Nov 2005 10:46:19 GMT Ralf Corsepius [b07b75f] * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) Remove obsolete types (*unsigned32). Mon, 07 Nov 2005 17:30:17 GMT Eric Norum [91c832b9] * c/src/lib/libbsp/m68k/uC5282/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/uC5282/start/start.S (modified) Remove assignation to U.S. Government. Mon, 07 Nov 2005 17:22:23 GMT Eric Norum [12b36efe] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/tm27.h (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/init5282.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/uC5282/timer/timer.c (modified) Assign copyright to OAR since all files descend from OAR's source. Mon, 07 Nov 2005 16:19:21 GMT Joel Sherrill [086c1c3] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * testsuites/ChangeLog (modified) Fixed formatting. Mon, 07 Nov 2005 15:36:31 GMT Joel Sherrill [fb08bd92] * c/src/lib/libbsp/powerpc/ChangeLog (modified) Repaired some changelog entries lost. Mon, 07 Nov 2005 06:26:45 GMT Ralf Corsepius [cb98129] * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 06:26:37 GMT Ralf Corsepius [71a7ed0] * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspstart.c (modified) Eliminate unsigned32. Mon, 07 Nov 2005 06:26:08 GMT Ralf Corsepius [8fd9e978] * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) Eliminate unsigned32, unsigned8. Mon, 07 Nov 2005 06:23:24 GMT Ralf Corsepius [e3996e2b] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 06:23:14 GMT Ralf Corsepius [9ab9f026] * c/src/lib/libbsp/m68k/av5282/network/network.c (modified) Several minor bug fixes. Mon, 07 Nov 2005 02:35:02 GMT Ralf Corsepius [e6d36b5] * c/src/lib/libcpu/powerpc/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 02:34:13 GMT Ralf Corsepius [fb6bc245] * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) Eliminate rtems_unsigned32. Mon, 07 Nov 2005 02:33:57 GMT Ralf Corsepius [0f8b4e9] * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) Eliminate unsigned32. Sun, 06 Nov 2005 09:16:14 GMT Ralf Corsepius [7880193] * c/src/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 09:15:50 GMT Ralf Corsepius [28fcdde] * c/src/libchip/i2c/i2c-2b-eeprom.c (modified) * c/src/libchip/rtc/mc146818a.h (modified) Eliminate obsolete types. Sun, 06 Nov 2005 08:32:36 GMT Ralf Corsepius [f2535df] * c/src/lib/libbsp/i386/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 08:32:13 GMT Ralf Corsepius [4d90b98e] * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) Reflect API changes. Sun, 06 Nov 2005 06:25:30 GMT Ralf Corsepius [1fdeb22] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 06:25:07 GMT Ralf Corsepius [3e21ecf] * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) Remove C++-style comments. Fri, 04 Nov 2005 18:10:25 GMT Ralf Corsepius [f6435d36] * c/src/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 18:09:59 GMT Ralf Corsepius [f82dabae] * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) Use libcpu/byteorder.h for i386. Fri, 04 Nov 2005 17:54:49 GMT Ralf Corsepius [830976c] * c/src/lib/libcpu/i386/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 17:54:37 GMT Ralf Corsepius [22d3aed] * c/src/lib/libcpu/i386/Makefile.am (modified) Add preinstall.am Fri, 04 Nov 2005 17:54:15 GMT Ralf Corsepius [08e2639] * c/src/lib/libcpu/i386/preinstall.am (added) New Fri, 04 Nov 2005 17:52:36 GMT Ralf Corsepius [4818350] * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 17:50:48 GMT Ralf Corsepius [ae5f7a08] * c/src/lib/libcpu/i386/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 17:50:34 GMT Ralf Corsepius [5acb4d0] * c/src/lib/libcpu/i386/byteorder.h (added) New. Fri, 04 Nov 2005 12:29:38 GMT Ralf Corsepius [47b5568] * c/src/lib/libcpu/powerpc/ChangeLog (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 12:29:17 GMT Ralf Corsepius [d04e891] * c/src/lib/libcpu/powerpc/shared/include/byteorder.h (modified) Remove __arch_swap (Unused). Fri, 04 Nov 2005 12:27:42 GMT Ralf Corsepius [0a708729] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/configure.ac (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 12:26:25 GMT Ralf Corsepius [4609200] * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 09:41:41 GMT Ralf Corsepius [03c4c16] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Cleanup. Fri, 04 Nov 2005 09:34:39 GMT Ralf Corsepius [8238048] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Merge new-exceptions/ChangeLog Fri, 04 Nov 2005 09:33:58 GMT Ralf Corsepius [b6a645da] * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (deleted) Remove (Merged into ../ChangeLog) Fri, 04 Nov 2005 09:19:44 GMT Ralf Corsepius [7634813] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Cleanup Fri, 04 Nov 2005 09:16:46 GMT Ralf Corsepius [751076a6] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Merge old-exceptions/ChangeLog Fri, 04 Nov 2005 09:15:20 GMT Ralf Corsepius [692d614] * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (deleted) Remove (Merged into ../ChangeLog) Fri, 04 Nov 2005 09:05:57 GMT Ralf Corsepius [d3b8db7b] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) 2005-11-04 Ralf Corsepius * ... Fri, 04 Nov 2005 08:17:56 GMT Till Straumann [784e792] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/shared/vmeUniverse/README.universe (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (added) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (added) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vme_am_defs.h (added) 2005-11-04 Till Straumann ... Fri, 04 Nov 2005 08:10:42 GMT Till Straumann [6d3ff66f] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/vme/vmeconfig.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/README (added) * c/src/lib/libbsp/powerpc/shared/vme/VME.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c (added) * c/src/lib/libbsp/powerpc/shared/vme/vmeconfig.c (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 06:30:38 GMT Ralf Corsepius [818fbd83] * c/src/libchip/Makefile.am (modified) Cosmetics Fri, 04 Nov 2005 06:28:01 GMT Ralf Corsepius [5a9022c3] * c/src/libchip/preinstall.am (modified) Regenerate. Fri, 04 Nov 2005 06:14:26 GMT Till Straumann [c4423933] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 04:03:31 GMT Till Straumann [94c31843] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 03:44:13 GMT Till Straumann [896cacf] * c/src/lib/libbsp/i386/ChangeLog (modified) Added reference to PR#832 Fri, 04 Nov 2005 03:43:10 GMT Till Straumann [758ee5c] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) corrected redundant PR number Fri, 04 Nov 2005 03:34:08 GMT Till Straumann [98afe31] * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (modified) * c/src/lib/libbsp/powerpc/shared/pci/pcifinddevice.c (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 03:31:10 GMT Till Straumann [cca22863] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 03:25:22 GMT Till Straumann [0de2f239] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) Added reference to PR#838 Fri, 04 Nov 2005 03:20:29 GMT Till Straumann [dc0f6585] * c/src/lib/libbsp/powerpc/shared/console/reboot.c (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) 2005-11-03 * ... Fri, 04 Nov 2005 01:39:45 GMT Till Straumann [8c9fffd] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c (added) 2005-11-03 * ... Fri, 04 Nov 2005 01:00:33 GMT Till Straumann [be45f8e] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) 2005-11-03 * Makefile.am, ... Fri, 04 Nov 2005 00:57:25 GMT Till Straumann [ab20575] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (added) * c/src/lib/libbsp/powerpc/shared/startup/zerobss.c (added) 2005-11-03 * ... Fri, 04 Nov 2005 00:23:28 GMT Till Straumann [f3173c0] * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (modified) 2005-11-03 * ... Thu, 03 Nov 2005 22:14:59 GMT Till Straumann [0ac68b0] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 22:13:43 GMT Till Straumann [b6e3ee54] * c/src/lib/libbsp/powerpc/shared/vectors/vectors.S (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:39:33 GMT Till Straumann [9a76deb5] * c/src/lib/libbsp/powerpc/ChangeLog (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:38:36 GMT Till Straumann [7e2dcde] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/start/preload.S (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/linkcmds (deleted) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:35:09 GMT Till Straumann [4ef2fd43] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/linkcmds (deleted) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:35:08 GMT Till Straumann [d45540a] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (added) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 19:14:54 GMT Till Straumann [e156c633] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 18:35:07 GMT Till Straumann [cc9073d] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) 2005-11-03 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 14:55:33 GMT Ralf Corsepius [ef9e015] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) 2005-11-03 Ralf Corsepius ... Thu, 03 Nov 2005 02:59:18 GMT Till Straumann [05a2cc4b] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 02:58:09 GMT Till Straumann [ebedf31] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 02:52:41 GMT Till Straumann [78111c3] * c/src/ChangeLog (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/i2c/i2c-2b-eeprom.c (added) * c/src/libchip/i2c/i2c-2b-eeprom.h (added) * c/src/libchip/i2c/i2c-ds1621.c (added) * c/src/libchip/i2c/i2c-ds1621.h (added) * c/src/libchip/preinstall.am (modified) * c/src/wrapup/Makefile.am (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 02:26:08 GMT Till Straumann [1b1b43cc] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.h (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 01:57:27 GMT Till Straumann [ec58ea04] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 01:54:59 GMT Till Straumann [912ab10e] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Wed, 02 Nov 2005 23:24:48 GMT Till Straumann [408bb71] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) 2005-11-02 straumanatslacdotstanford.edu * ChangeLog, ... Wed, 26 Oct 2005 16:42:47 GMT Ralf Corsepius [794c624] * c/src/ChangeLog (modified) changes Wed, 26 Oct 2005 16:41:59 GMT Ralf Corsepius [1e34f3f2] * c/src/libnetworking/Makefile.am (deleted) * c/src/libnetworking/pppd/Makefile.am (deleted) * c/src/libnetworking/pppd/README (deleted) * c/src/libnetworking/pppd/STATUS (deleted) * c/src/libnetworking/pppd/auth.c (deleted) * c/src/libnetworking/pppd/cbcp.c (deleted) * c/src/libnetworking/pppd/cbcp.h (deleted) * c/src/libnetworking/pppd/ccp.c (deleted) * c/src/libnetworking/pppd/ccp.h (deleted) * c/src/libnetworking/pppd/chap.c (deleted) * c/src/libnetworking/pppd/chap.h (deleted) * c/src/libnetworking/pppd/chap_ms.c (deleted) * c/src/libnetworking/pppd/chap_ms.h (deleted) * c/src/libnetworking/pppd/chat.c (deleted) * c/src/libnetworking/pppd/demand.c (deleted) * c/src/libnetworking/pppd/example/Makefile-user (deleted) * c/src/libnetworking/pppd/example/README (deleted) * c/src/libnetworking/pppd/example/init.c (deleted) * c/src/libnetworking/pppd/example/netconfig.h (deleted) * c/src/libnetworking/pppd/example/ppp.conf (deleted) * c/src/libnetworking/pppd/example/pppd.options (deleted) * c/src/libnetworking/pppd/example/pppdapp.c (deleted) * c/src/libnetworking/pppd/example/system.h (deleted) * c/src/libnetworking/pppd/fsm.c (deleted) * c/src/libnetworking/pppd/fsm.h (deleted) * c/src/libnetworking/pppd/ipcp.c (deleted) * c/src/libnetworking/pppd/ipcp.h (deleted) * c/src/libnetworking/pppd/ipxcp.c (deleted) * c/src/libnetworking/pppd/ipxcp.h (deleted) * c/src/libnetworking/pppd/lcp.c (deleted) * c/src/libnetworking/pppd/lcp.h (deleted) * c/src/libnetworking/pppd/magic.c (deleted) * c/src/libnetworking/pppd/magic.h (deleted) * c/src/libnetworking/pppd/md4.c (deleted) * c/src/libnetworking/pppd/md4.h (deleted) * c/src/libnetworking/pppd/md5.c (deleted) * c/src/libnetworking/pppd/md5.h (deleted) * c/src/libnetworking/pppd/options.c (deleted) * c/src/libnetworking/pppd/patchlevel.h (deleted) * c/src/libnetworking/pppd/pathnames.h (deleted) * c/src/libnetworking/pppd/pppd.8 (deleted) * c/src/libnetworking/pppd/pppd.h (deleted) * c/src/libnetworking/pppd/preinstall.am (deleted) * c/src/libnetworking/pppd/rtemsdialer.h (deleted) * c/src/libnetworking/pppd/rtemsmain.c (deleted) * c/src/libnetworking/pppd/rtemspppd.c (deleted) * c/src/libnetworking/pppd/rtemspppd.h (deleted) * c/src/libnetworking/pppd/sys-rtems.c (deleted) * c/src/libnetworking/pppd/upap.c (deleted) * c/src/libnetworking/pppd/upap.h (deleted) * c/src/libnetworking/pppd/utils.c (deleted) Remove (Moved to cpukit). Wed, 26 Oct 2005 16:37:50 GMT Ralf Corsepius [6555f10] * c/src/libnetworking/.cvsignore (deleted) * c/src/libnetworking/pppd/.cvsignore (deleted) Remove Wed, 26 Oct 2005 16:33:19 GMT Ralf Corsepius [330e08be] * c/src/ChangeLog (modified) 2005-10-26 Ralf Corsepius * ... Wed, 26 Oct 2005 16:32:59 GMT Ralf Corsepius [834467b] * c/src/configure.ac (modified) Remove libnetworking, libnetworking/pppd. Wed, 26 Oct 2005 16:30:49 GMT Ralf Corsepius [6028f94] * c/src/wrapup/Makefile.am (modified) Remove libpppd.a. Wed, 26 Oct 2005 14:56:58 GMT Eric Norum [21dd4cf8] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/README (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) Allow network to be locked at 100/Full. Wed, 26 Oct 2005 03:51:43 GMT Ralf Corsepius [a6c027cc] * c/src/libnetworking/pppd/preinstall.am (modified) Regenerate. Wed, 26 Oct 2005 03:39:38 GMT Ralf Corsepius [be52582] * c/src/ChangeLog (modified) 2005-10-26 Ralf Corsepius * ...
