# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 17:05:16 Wed, 16 Mar 2016 00:36:26 GMT Joel Sherrill [78c9fe8] * c/src/lib/libbsp/arm/atsam/make/custom/atsamv-testsuite.tcfg (modified) atsamv-testsuite.tcfg: Add more tests Tue, 15 Mar 2016 13:29:15 GMT Sebastian Huber [5a0b27ed] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) bsp/leon3: Clock driver workaround for GR712RC Tue, 15 Mar 2016 07:15:53 GMT Sebastian Huber [057154e] * c/src/lib/libbsp/powerpc/beatnik/startup/linkcmds (deleted) bsp/beatnik: Delete unused linkcmds file Mon, 14 Mar 2016 09:55:57 GMT Sebastian Huber [734118d9] * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) bsp/qoriq: Fix interrupt numbers Fri, 11 Mar 2016 22:07:35 GMT Joel Sherrill [5e368e84] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg (modified) pc386: Fix linker usage issues with -r and function sections closes ... Fri, 11 Mar 2016 20:13:48 GMT Joel Sherrill [83a116b] * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) lm32/shared/.../ckinit.c: Fix typo so fast idle on simulator is enabled Thu, 10 Mar 2016 23:59:01 GMT Joel Sherrill [a29aa21] * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850sim.inc (modified) * c/src/lib/libbsp/v850/gdbv850sim/startup/linkcmds (modified) v850/gdbv850sim: Add per-section compilation and linking support ... Thu, 10 Mar 2016 23:43:44 GMT Joel Sherrill [2533e79] * c/src/lib/libbsp/sparc64/usiii/make/custom/usiii.cfg (modified) sparc64/usiii: Add per-section compilation and linking support ... Thu, 10 Mar 2016 23:37:55 GMT Joel Sherrill [e3fdbc06] * c/src/lib/libbsp/sparc64/niagara/make/custom/niagara.cfg (modified) sparc64/niagara: Add per-section compilation and linking support ... Thu, 10 Mar 2016 23:22:59 GMT Joel Sherrill [45e5623] * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) powerpc/motorola_powerpc: Add per-section compilation and linking ... Thu, 10 Mar 2016 23:09:20 GMT Joel Sherrill [f34c41a] * c/src/lib/libbsp/sh/shsim/make/custom/simsh1.cfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2.cfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e.cfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4.cfg (modified) sh/simsh: Add per-section compilation and linking support updates ... Thu, 10 Mar 2016 23:03:49 GMT Joel Sherrill [dd642034] * c/src/lib/libbsp/sh/gensh4/make/custom/gensh4.cfg (modified) sh/gensh4: Add per-section compilation and linking support updates ... Thu, 10 Mar 2016 22:49:33 GMT Joel Sherrill [5d75bb6b] * c/src/lib/libbsp/sh/gensh2/make/custom/gensh2.cfg (modified) sh/gensh2: Add per-section compilation and linking support updates ... Thu, 10 Mar 2016 22:46:02 GMT Joel Sherrill [fd9ea74] * c/src/lib/libbsp/sh/gensh1/make/custom/gensh1.cfg (modified) sh/gensh1: Add per-section compilation and linking support updates ... Thu, 10 Mar 2016 22:28:12 GMT Joel Sherrill [e1768fdd] * c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg (modified) or1k/generic_or1k: Add per-section compilation and linking support ... Thu, 10 Mar 2016 22:22:49 GMT Joel Sherrill [14926616] * c/src/lib/libbsp/no_cpu/no_bsp/make/custom/no_bsp.cfg (modified) no_bsp.cfg: Add hints for CFLAGS and LDFLAGS updates #2577. Thu, 10 Mar 2016 22:21:20 GMT Joel Sherrill [1909efdb] * c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg (modified) nios2/nios2_iss: Add per-section compilation and linking support ... Thu, 10 Mar 2016 22:12:27 GMT Joel Sherrill [7d80eea] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim.cfg (modified) m32csim.cfg: GCC PR37665 is fixed but there is still a compiler ... Thu, 10 Mar 2016 22:08:29 GMT Joel Sherrill [4a199a9] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim.cfg (modified) m32c/m32csim: Add per-section compilation and linking support ... Thu, 10 Mar 2016 22:04:31 GMT Joel Sherrill [5758838] * c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg (modified) lm32/lm32_evr: Add per-section compilation and linking support ... Thu, 10 Mar 2016 21:58:08 GMT Joel Sherrill [f953a85] * c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg (modified) lm32/lm32_evr: Add per-section compilation and linking support ... Thu, 10 Mar 2016 21:48:49 GMT Joel Sherrill [f6b798a6] * c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg (modified) pc386.cfg: Add disabled per-function-sections updates #2638. Thu, 10 Mar 2016 21:09:24 GMT Joel Sherrill [22e8c5a3] * c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg (modified) epiphany/epiphany_sim: Add per-section compilation and linking ... Thu, 10 Mar 2016 20:36:25 GMT Joel Sherrill [74ad76a] * c/src/lib/libbsp/bfin/TLL6527M/make/custom/TLL6527M.cfg (modified) bfin/TLL6527M: Add per-section compilation and linking support ... Thu, 10 Mar 2016 20:25:36 GMT Joel Sherrill [32a4aea5] * c/src/lib/libbsp/bfin/bf537Stamp/make/custom/bf537Stamp.cfg (modified) bfin/bf537Stamp: Add per-section compilation and linking support ... Thu, 10 Mar 2016 20:21:40 GMT Joel Sherrill [9008c77] * c/src/lib/libbsp/bfin/eZKit533/make/custom/eZKit533.cfg (modified) bfin/eZKit533: Add per-section compilation and linking support ... Thu, 10 Mar 2016 20:12:53 GMT Joel Sherrill [5460722] * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq.inc (modified) arm/xilinx_zynq: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:35:14 GMT Joel Sherrill [9d431a0] * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc (modified) arm/tms570: Add per-section compilation and linking support updates ... Thu, 10 Mar 2016 19:29:22 GMT Joel Sherrill [a006671a] * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4.cfg (modified) arm/stm32f4: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:25:13 GMT Joel Sherrill [e354ef11] * c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg (modified) arm/smdk2410: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:16:30 GMT Joel Sherrill [5fd3cc07] * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx.cfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t.cfg (modified) arm/rtl22xx: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:08:26 GMT Joel Sherrill [07252899] * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (modified) arm/realview_pbx_a9_qemu: Add per-section compilation and linking ... Thu, 10 Mar 2016 18:31:37 GMT Joel Sherrill [fa9c057] * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc (modified) arm/raspberrypi: Add per-section compilation and linking suppo ... Thu, 10 Mar 2016 18:13:57 GMT Joel Sherrill [7276954] * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc (modified) arm/lpc32xx: Add per-section compilation and linking suppo updates ... Thu, 10 Mar 2016 17:39:54 GMT Joel Sherrill [bfc87114] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc (modified) arm/lpc24xx (lpc40xx variants) Add per-section compilation and ... Thu, 10 Mar 2016 17:13:29 GMT Joel Sherrill [55159ee9] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx.inc (modified) arm/lpc24xx (lpc24xx variants) Add per-section compilation and ... Thu, 10 Mar 2016 00:51:30 GMT Joel Sherrill [8467c31] * c/src/lib/libbsp/arm/atsam/make/custom/atsamv-testsuite.tcfg (added) atsamv-testsuite.tcfg: new file] Thu, 10 Mar 2016 15:36:16 GMT Joel Sherrill [4e059db8] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx.inc (modified) arm/lpc24xx (lpc17xx variants): Add per-section compilation and ... Wed, 09 Mar 2016 21:45:44 GMT Joel Sherrill [9430052] * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c (deleted) powerpc/mvme5500: Use shared pci_find_device() Wed, 09 Mar 2016 21:30:24 GMT Joel Sherrill [81df701a] * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/include/pci.h (modified) * c/src/lib/libbsp/mips/malta/pci/pcifinddevice.c (deleted) * c/src/lib/libbsp/mips/malta/pci/pcilistdevices.c (deleted) mips/malta: Use shared pci_find_device() and removed unused ... Wed, 09 Mar 2016 18:48:39 GMT Joel Sherrill [22bbb9f1] * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/shared/console.c (modified) pc386: Add --disable-com1-com4 boot argument Wed, 09 Mar 2016 17:25:38 GMT Joel Sherrill [efbf6c9] * c/src/lib/libbsp/shared/console.c (modified) libbsp/shared/console.c: Clean up memory allocation for per device data Wed, 09 Mar 2016 17:25:13 GMT Joel Sherrill [6db5ea03] * c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c (modified) pc386/startup/bsp_fatal_halt.c: Fix noreturn does return warning Wed, 09 Mar 2016 17:24:33 GMT Joel Sherrill [2e516dd4] * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) pc386/startup/bspstart.c: Reformat and cleanup file header Fri, 04 Mar 2016 21:40:49 GMT Joel Sherrill [356b2c23] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (added) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) pc386: Add PCI UART support Fri, 04 Mar 2016 19:21:02 GMT Joel Sherrill [0ac1538] * c/src/lib/libbsp/shared/console_private.h (modified) console_private.h: Improve comment for vt_ioctl() Fri, 04 Mar 2016 19:20:38 GMT Joel Sherrill [36627387] * c/src/lib/libbsp/shared/console_private.h (modified) console_private.h: Remove prototypes for non-existent methods ... Thu, 10 Mar 2016 16:33:27 GMT Joel Sherrill [c3c57b1] * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_private.h (modified) pc386: Improve boot command arguments for console/printk device ... Thu, 03 Mar 2016 16:36:24 GMT Joel Sherrill [f770fcb] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/shared/pci/pci_io.c (added) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) * c/src/lib/libbsp/shared/pci/pci_bus_count.c (added) * c/src/lib/libbsp/shared/pci/pci_find_device.c (added) Add shared PCI support and enhance pc386 to support non-legacy PCI ... Thu, 03 Mar 2016 15:23:47 GMT Joel Sherrill [36717645] * c/src/lib/libbsp/i386/pc386/configure.ac (modified) pc386/configure.ac: Delete incorrect and unused AM_CONDITIONAL Wed, 02 Mar 2016 19:31:45 GMT Joel Sherrill [3b697232] * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) i386/shared/pci/pcibios.c: Remove unused pcib_find_by_class() Wed, 02 Mar 2016 19:30:27 GMT Joel Sherrill [8ce16a4] * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) i386/shared/pci/pcibios.c: Remove unused pcib_special_cycle() Wed, 02 Mar 2016 19:25:13 GMT Joel Sherrill [12c9dc8f] * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.h (deleted) * c/src/libchip/network/if_fxp.c (modified) pc386: Eliminate pcibios.h and begin removal obsolete PCI BIOS API ... Fri, 04 Mar 2016 14:13:45 GMT Sebastian Huber [9f5754b5] * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) bsps: Avoid Giant lock in simulator clock driver Update #2555. Thu, 18 Feb 2016 07:36:16 GMT Sebastian Huber [90d8567] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/kern_tc.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/watchdogtick.c (modified) score: Distribute clock tick to all online CPUs Update #2554. Thu, 03 Mar 2016 21:40:17 GMT Gedare Bloom [daa303d] * c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c (modified) pc386: adjust assembly in bsp_fatal_halt Sat, 23 Jan 2016 19:06:22 GMT Joel Sherrill [328bd35] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/i386/cache.c (modified) * c/src/lib/libcpu/i386/cpu.h (deleted) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/i386/page.h (added) * c/src/lib/libcpu/i386/preinstall.am (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: refactor libcpu/cpu.h into rtems/score/i386.h Fixes #2515. Fri, 08 Jan 2016 21:54:20 GMT Gedare Bloom [3267f95] * c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/interrupts.h (modified) i386: prepare for paravirtualized interrupts Fri, 08 Jan 2016 21:28:45 GMT Gedare Bloom [505dc61] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c (added) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: relocate fatal halt to bsp layer Fri, 08 Jan 2016 17:15:46 GMT Gedare Bloom [fd05a05] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspidle.S (added) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: move idle thread into BSP layer Sat, 23 Jan 2016 01:58:33 GMT Joel Sherrill [e56266c] * c/src/support/version.c (modified) version.c: Add space so printing is neater Tue, 01 Mar 2016 18:46:18 GMT Joel Sherrill [3f5e0961] * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/README (modified) * c/src/lib/libbsp/arm/smdk2410/console/uart.c (added) * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/arm/smdk2410/preinstall.am (modified) * c/src/lib/libbsp/arm/smdk2410/smc/smc.c (added) * c/src/lib/libbsp/arm/smdk2410/smc/smc.h (added) * c/src/lib/libbsp/arm/smdk2410/start/start.S (added) * c/src/lib/libbsp/arm/smdk2410/startup/bspidle.c (added) * c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c (added) * c/src/lib/libbsp/arm/smdk2410/startup/memmap.c (modified) smdk2410: Resurrect missing gp32 files When the gp32 BSP was ... Thu, 03 Mar 2016 08:49:15 GMT Sebastian Huber [cc1add7b] * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) bsps: Delete empty Clock_driver_support_at_tick() Wed, 02 Mar 2016 12:32:44 GMT Sebastian Huber [73de9393] * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_p1020rdb (modified) bsp/qoriq: Do not touch MMU config for SMP start Assume that the ... Thu, 03 Mar 2016 08:08:08 GMT Sebastian Huber [e468ba5] * c/src/lib/libbsp/powerpc/qoriq/include/u-boot-config.h (modified) * c/src/lib/libbsp/shared/src/bsp-uboot-board-info.c (modified) U-Boot: Flush data cache after bdinfo copy Sat, 27 Feb 2016 23:19:33 GMT Martin Galvan [8c5c53f4] * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) am335x irq handling improvement This patch makes the following ... Mon, 22 Feb 2016 06:04:17 GMT Sebastian Huber [c466c62] * c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg (modified) bsp/leon3: Use -mcpu=leon3 machine option Due to GCC configuration ... Fri, 19 Feb 2016 18:24:03 GMT punitvara [42989d6] * c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c (modified) arm: Fixed typo in file bbb-gpio.c This patch fixes typo ... Sat, 06 Feb 2016 16:24:54 GMT Joel Sherrill [e41d8ce] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg (modified) arm/.../lpc1768_embed.cfg: Disable per function sections updates #2576. Sat, 06 Feb 2016 16:22:12 GMT Joel Sherrill [8755f2a] * c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg (modified) m68k/.../uC5282.cfg: Disable per function sections updates #2575. Sat, 06 Feb 2016 16:19:46 GMT Joel Sherrill [aaa21b1] * c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg (modified) powerpc/.../ss555.cfg: Correct ticket number in comment Sat, 06 Feb 2016 16:18:57 GMT Joel Sherrill [c99c702] * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg (modified) m68k/.../mcf5225x.cfg: Correct ticket number in comment Sat, 06 Feb 2016 16:18:41 GMT Joel Sherrill [406b3b7] * c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg (modified) powerpc/.../qemuppc.cfg: Correct ticket number in comment Sat, 06 Feb 2016 16:17:59 GMT Joel Sherrill [6564bd2] * c/src/lib/libbsp/powerpc/mpc8260ads/make/custom/mpc8260ads.cfg (modified) powerpc/.../mpc8260ads.cfg: Correct ticket number in comment Sat, 06 Feb 2016 16:17:02 GMT Joel Sherrill [a3687b5c] * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg (modified) m68k/.../mrm332.cfg: Correct ticket number in comment Sat, 06 Feb 2016 16:14:56 GMT Joel Sherrill [fb81d367] * c/src/lib/libbsp/m68k/gen68360/make/custom/gen68360.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/gen68360_040.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/pgh360.cfg (modified) m68k/gen68360/.../*.cfg: Correct ticket number in comment Sat, 06 Feb 2016 16:06:06 GMT Joel Sherrill [96cfad6d] * c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg (modified) m68k/.../av5282.cfg: Disable per function sections updates #2574. Sat, 06 Feb 2016 16:03:48 GMT Joel Sherrill [50ae9957] * c/src/lib/libbsp/m68k/gen68340/make/custom/gen68340.cfg (modified) m68k/.../gen68340.cfg: Disable per function sections updates #2573. Sat, 06 Feb 2016 16:00:53 GMT Joel Sherrill [1c3dd579] * c/src/lib/libbsp/m68k/mcf5206elite/make/custom/mcf5206elite.cfg (modified) m68k/.../mcf5206elite.cfg: Disable per function sections updates #2572. Sat, 06 Feb 2016 15:58:55 GMT Joel Sherrill [6a1cbb74] * c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg (modified) m68k/.../mcf5235.cfg: Disable per function sections updates #2571. Sat, 06 Feb 2016 15:57:46 GMT Joel Sherrill [7cd9f934] * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg (modified) m68k/.../mcf52235.cfg: Disable per function sections updates #2570. Sat, 06 Feb 2016 15:55:20 GMT Joel Sherrill [78fd1ec1] * c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg (modified) m68k/.../mcf5329.cfg: Disable per function sections updates #2569. Sat, 06 Feb 2016 15:51:48 GMT Joel Sherrill [ea791d5] * c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg (modified) m68k/.../mcf5329.cfg: Disable per function sections updates #2569. Sat, 06 Feb 2016 15:45:40 GMT Joel Sherrill [123e2ec] * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg (modified) m68k/.../mcf5225x.cfg: Disable per function sections updates #2568. Sat, 06 Feb 2016 15:43:17 GMT Joel Sherrill [303429f] * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg (modified) m68k/.../mrm332.cfg: Disable per function sections updates #2567. Sat, 06 Feb 2016 15:40:58 GMT Joel Sherrill [6184b572] * c/src/lib/libbsp/m68k/gen68360/make/custom/gen68360.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/gen68360_040.cfg (modified) * c/src/lib/libbsp/m68k/gen68360/make/custom/pgh360.cfg (modified) m68k/gen68360/.../*.cfg: Disable per function sections updates #2566. Sat, 06 Feb 2016 15:35:21 GMT Joel Sherrill [068b3125] * c/src/lib/libbsp/powerpc/mpc8260ads/make/custom/mpc8260ads.cfg (modified) powerpc/.../mpc8260ads.cfg: Disable per function sections updates #2565. Sat, 06 Feb 2016 14:53:30 GMT Joel Sherrill [8926fad] * c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg (modified) powerpc/.../qemuppc.cfg: Disable per function sections updates #2564. Sat, 06 Feb 2016 14:50:26 GMT Joel Sherrill [72d8e64c] * c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg (modified) powerpc/.../ss555.cfg: Disable per function sections. updates #2563. Fri, 05 Feb 2016 13:51:48 GMT Joel Sherrill [c5ce9c3c] * c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg (modified) powerpc/.../haleakala.cfg: Disable per function sections. updates #2561. Tue, 26 Jan 2016 10:16:56 GMT Sebastian Huber [3bc12a8f] * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apiext.h (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/apiext.c (deleted) * cpukit/score/src/threaddispatch.c (modified) * testsuites/sptests/spsize/size.c (modified) Delete unused API extensions Tue, 26 Jan 2016 09:11:48 GMT Sebastian Huber [8ca372e] * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/sptables.h (deleted) * cpukit/sapi/preinstall.am (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/mpciimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/src/mpci.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) Use linker set for MPCI initialization Update #2408. Mon, 25 Jan 2016 21:03:00 GMT Sebastian Huber [ca4602e] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (deleted) * c/src/lib/libbsp/shared/bsppost.c (deleted) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/libio_helper_null.c (deleted) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) Use linker set for libio initialization Update #2408. Wed, 27 Jan 2016 06:33:50 GMT Sebastian Huber [ab8e821] * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) bsps/powerpc: Fix startup Do work area initialization after ... Tue, 26 Jan 2016 10:54:21 GMT Sebastian Huber [b501fcf] * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) bsps/sparc: Fix link-time error Fix for commit ... Tue, 26 Jan 2016 06:16:52 GMT Sebastian Huber [47190194] * c/src/lib/libbsp/shared/bspdriverlevelhook.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c (modified) * cpukit/Makefile.am (modified) * cpukit/preinstall.am (modified) drvmgr: Remove dupl bsp_driver_level_hook() decl Mon, 25 Jan 2016 09:20:28 GMT Sebastian Huber [a8865f8] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) score: Introduce CPU_CACHE_LINE_BYTES Add CPU_CACHE_LINE_BYTES for ... Sun, 24 Jan 2016 17:48:27 GMT Joel Sherrill [449905a8] * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/shared/start/start.S (modified) m68k/mvme*: switch to shared linkcmds.base updates #2542. Sun, 24 Jan 2016 23:43:58 GMT Ralph Holmes [0aeeca42] * c/src/lib/libbsp/powerpc/gen83xx/make/custom/gen83xx.inc (modified) powerpc/gen83xx: Add per-section compilation and linking support. ... Sun, 24 Jan 2016 16:55:49 GMT Ralph Holmes [8c7c891] * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc55xx.inc (modified) powerpc/mpc55xxevb: Add per-section compilation and linking support. ...
