# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 14:08:48 Mon, 12 Jun 2017 13:30:13 GMT Sebastian Huber [74a13c8] * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) bsp/beatnik: Fixes due to header file changes Update #2833. Fri, 09 Jun 2017 13:42:36 GMT Sebastian Huber [7b0c74ff] * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/tls.h (modified) i386: Support thread-local storage (TLS) Update #2468. Fri, 09 Jun 2017 05:55:16 GMT Sebastian Huber [f256685] * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) bsp/psim: Include missing Fri, 09 Jun 2017 05:54:45 GMT Sebastian Huber [6081ef3] * c/src/libchip/network/if_fxp.c (modified) if_fxp: Include missing Fix format warnings. Fri, 09 Jun 2017 05:25:02 GMT Sebastian Huber [32b4a0c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) Simplify TLS support in context switch There is no need to save the ... Tue, 06 Jun 2017 13:41:48 GMT Christian Mauderer [ce3ac00] * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) bsps/arm: Fix ARMv7-M interrupt suppport Enable/disable vector ... Tue, 06 Jun 2017 09:08:16 GMT Sebastian Huber [787f51f] * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/libchip/network/i82586.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) Do not include in kernel-space Update #2833. Tue, 06 Jun 2017 06:03:45 GMT Sebastian Huber [93531e9b] * c/src/libchip/serial/mc68681.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/sys/_termios.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios03/init.c (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/libtests/termios09/init.c (modified) Move RTEMS-specific Termios API content Remove obsolete support for ... Wed, 07 Jun 2017 05:22:38 GMT Sebastian Huber [cf54965] * c/src/libchip/network/i82586.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) network: Include missing Update #2833. Mon, 29 May 2017 10:09:34 GMT Sebastian Huber [3623c40] * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/sptests/Makefile.am (modified) * c/src/ada-tests/sptests/spatcb01/Makefile.am (added) * c/src/ada-tests/sptests/spatcb01/ada_spatcb01.scn (added) * c/src/ada-tests/sptests/spatcb01/config.h (added) * c/src/ada-tests/sptests/spatcb01/spatcb01.adb (added) ada-tests/spatcb01: New test Update #2289. Thu, 01 Jun 2017 17:04:05 GMT Sebastian Huber [7203b70] * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg (modified) bsp/motorola_powerpc: Fix for Binutils 2.28+ There are mismatched ... Thu, 01 Jun 2017 17:00:38 GMT Sebastian Huber [697a6ca] * c/src/lib/libbsp/powerpc/shared/bootloader/ppcboot.lds (modified) bsps/powerpc: Set output format in linker script Set the proper ... Sun, 07 May 2017 21:08:17 GMT Phong Pham [848007c] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) Add support for IBM PowerPC 750 chip. Closes #3015. Tue, 23 May 2017 09:34:45 GMT Sebastian Huber [afa5b89] * c/src/ada/rtems-tasks.ads (modified) ada: Remove task notepad support Update #2493. Tue, 23 May 2017 09:33:29 GMT Sebastian Huber [783fbce] * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada/rtems-clock.adb (modified) * c/src/ada/rtems-clock.ads (modified) ada: Update due to Clock Manager API changes Update #2676. Tue, 23 May 2017 09:32:21 GMT Sebastian Huber [9ff0f40] * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada/Makefile.am (modified) * c/src/ada/preinstall.am (modified) * c/src/ada/rtems-debug.adb (deleted) * c/src/ada/rtems-debug.ads (deleted) ada: Remove support Update #2477. Fri, 26 May 2017 00:35:17 GMT Chris Johns [7ec982bf] * c/src/automake/subdirs.am (modified) * cpukit/automake/subdirs.am (modified) * testsuites/Makefile.am (modified) * testsuites/automake/subdirs.am (modified) build-system: Fix the targets support for the parallel build. Thu, 25 May 2017 05:10:11 GMT Chris Johns [ff781cc] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) m32c/m32csim: Exclude linpack from the tests. Closes #3025. Sun, 14 May 2017 01:52:52 GMT Chris Johns [a748603] * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/automake/subdirs.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) build-system: Parallel build all subdirs. Tue, 23 May 2017 23:26:29 GMT Chris Johns [9935c23] * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) arm/tms570: Update preinstall.am after bootstrap. Mon, 31 Oct 2016 10:01:39 GMT Jacob Hansen [bc470d3c] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) sparc: only define start if it is different from SYM(start) The SYM ... Fri, 28 Oct 2016 14:05:56 GMT Jacob Hansen [8639685] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) sparc: Adjust assembly to improve compability with LLVM - All ... Thu, 11 May 2017 11:43:53 GMT Daniel Hellstrom [1ea73e2b] * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) leon, grtc: SMP support by using spin-locks Thu, 11 May 2017 10:54:46 GMT Daniel Hellstrom [818f10bc] * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) leon, grtc: updated overrun condition handling The following ... Wed, 10 May 2017 10:39:23 GMT Daniel Hellstrom [6fdded2c] * c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c (modified) leon, gr1553bm: SMP support by using spin-locks Wed, 10 May 2017 08:46:01 GMT Daniel Hellstrom [3feae3b] * c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c (modified) leon, gr1553bc: SMP support by using spin-locks Since DMA buffers ... Tue, 09 May 2017 14:00:56 GMT Daniel Hellstrom [84e4d10c] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (deleted) leon, apbuart: remove old RAW UART driver This driver was initially ... Tue, 09 May 2017 11:13:44 GMT Daniel Hellstrom [c92f402c] * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) leon, grtm: SMP support by using spin-locks Mon, 08 May 2017 14:10:14 GMT Daniel Hellstrom [f767fe74] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) leon, ahbstat: remove printf warnings Mon, 08 May 2017 12:58:41 GMT Daniel Hellstrom [ce76b9d2] * c/src/lib/libbsp/sparc/shared/pci/gr_701.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c (modified) leon, pci-peripherals: SMP support by spin-locks and updated genirq Fri, 05 May 2017 13:42:45 GMT Daniel Hellstrom [8670c464] * c/src/lib/libbsp/sparc/shared/include/genirq.h (modified) * c/src/lib/libbsp/sparc/shared/irq/genirq.c (modified) leon, genirq: SMP support for PCI peripherals The common interrupt ... Mon, 24 Apr 2017 14:39:49 GMT Martin Aberg [aa19873] * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) leon: allow SMP boot from any CPU Thu, 13 Apr 2017 12:12:31 GMT Martin Aberg [039edd2a] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: removed unused txerror, rxerror Thu, 13 Apr 2017 12:06:04 GMT Martin Aberg [ee078c21] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: fixed historical comment Tue, 11 Apr 2017 10:30:02 GMT Daniel Hellstrom [91541551] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: semaphore reset count required after flushing It is ... Tue, 11 Apr 2017 08:47:39 GMT Daniel Hellstrom [9855690] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: split hw_stop() into hw and sw stop this is to avoid ... Thu, 13 Apr 2017 12:08:50 GMT Martin Aberg [3a650d3b] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: RTEMS_NO_TIMEOUT on tx_sem Mon, 03 Apr 2017 11:27:49 GMT Martin Aberg [2d3d8f96] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: redesigned bus-off and AHB error handling When bus-off ... Thu, 09 Mar 2017 14:44:08 GMT Daniel Hellstrom [ca4c4164] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: updated device name and use it for ISR Thu, 26 Jan 2017 10:01:10 GMT Martin Aberg [05749690] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: fixed race on interrupt mask register There was a ... Thu, 26 Jan 2017 09:54:57 GMT Martin Aberg [5d367c56] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: unregister interrupt handler at close Mon, 13 Mar 2017 11:44:58 GMT Martin Aberg [c297060] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: protect statistics on copy to user Locking the stats ... Thu, 26 Jan 2017 09:52:31 GMT Martin Aberg [7b8a920] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: use RTEMS 4.12 SMP interrupt lock Tue, 24 Jan 2017 10:16:41 GMT Martin Aberg [bc40b4d] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: consistent indentation This commit does not contain ... Tue, 24 Jan 2017 09:00:07 GMT Martin Aberg [ad203e58] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: function based user interface This commit preserves ... Thu, 27 Apr 2017 11:14:53 GMT Martin Aberg [229c4249] * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) bsp/leon3: Cleaner namespace for LEON3 debug UART Prefix BSP ... Tue, 25 Apr 2017 07:10:03 GMT Daniel Hellstrom [011efee8] * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) leon, irq: single CPU SMP configuration does not need IPI ISR Tue, 25 Apr 2017 13:26:18 GMT Daniel Hellstrom [fa27fe5c] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: new option and change soft-reset logic for EDCL Mon, 24 Apr 2017 14:36:16 GMT Daniel Hellstrom [8ac070a] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: 10/100 modes should be assigned in fastest priority Mon, 24 Apr 2017 14:32:17 GMT Daniel Hellstrom [e6fbd26] * c/src/lib/libbsp/sparc/shared/include/greth.h (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: speed modes advertising now configurable Mon, 24 Apr 2017 13:10:41 GMT Daniel Hellstrom [12718134] * c/src/lib/libbsp/sparc/shared/include/greth.h (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: EDCL and DD is disabled during reset The EDCL and ... Sun, 07 May 2017 20:52:50 GMT Phong Pham [a9859d1] * c/src/lib/libbsp/shared/src/irq-generic.c (modified) interrupt vector indexing is assuming BSP_INTERRUPT_VECTOR_MIN = 0 ... Sun, 07 May 2017 21:13:24 GMT Phong Pham [f219adc] * c/src/libchip/serial/ns16550_p.h (modified) missing a couple register names + a #ifndef_ASM__ around serial.h ... Thu, 11 May 2017 07:53:05 GMT Sebastian Huber [0e494170] * c/src/lib/libbsp/arm/shared/include/arm-gic.h (modified) bsps/arm: Fix bit field offset in GIC support Update #3002. Thu, 13 Apr 2017 19:23:28 GMT Daniel Hellstrom [430949aa] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: let Gbit full duplex override half Thu, 13 Apr 2017 12:57:01 GMT Daniel Hellstrom [998e34ad] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: SMP support by using spin-lock protection Tue, 11 Apr 2017 11:55:02 GMT Martin Aberg [8927c0f] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: offset intnum with subtimer index If separate ... Mon, 10 Apr 2017 17:07:04 GMT Martin Aberg [256e083f] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: fixed probing separate interrupts Probing of ... Wed, 08 Mar 2017 11:59:07 GMT Javier Jalle [6234abe] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l4stat.h (added) * c/src/lib/libbsp/sparc/shared/stat/l4stat.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l4stat: Initial driver commit Tue, 07 Mar 2017 11:50:48 GMT Javier Jalle [21b3319f] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added L4STAT driver to ambapp ids Mon, 06 Mar 2017 12:08:04 GMT Martin Aberg [a8595605] * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) leon, occan: Converted disable/enable to SMP locks This commit ... Thu, 19 Jan 2017 17:57:58 GMT Martin Aberg [c609ccea] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) leon, ahbstat: Use RTEMS 4.12 SMP interrupt lock Wed, 15 Mar 2017 13:38:21 GMT Javier Jalle [c241236] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * c/src/lib/libbsp/sparc/shared/include/memscrub.h (added) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, memscrub: add GR740 memory scrubber driver Wed, 15 Mar 2017 14:04:33 GMT Javier Jalle [d79429f] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/griommu.h (added) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, griommu: add GR740 IOMMU driver The driver is limited to the ... Wed, 15 Feb 2017 15:51:33 GMT Javier Jalle [3e948cc] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added GRIOMMU driver to ambapp ids Tue, 21 Feb 2017 08:14:46 GMT Javier Jalle [dfa86338] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l2c.h (added) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l2cache: add GR740 L2-Cache driver Wed, 15 Mar 2017 13:58:04 GMT Javier Jalle [d24ed54] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added L2CACHE driver to ambapp ids Thu, 09 Feb 2017 13:09:17 GMT Javier Jalle [93c5e63] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/grpci2dma.h (added) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (added) leon, grpci2dma: add GR740 PCI DMA driver Wed, 15 Feb 2017 10:14:13 GMT Javier Jalle [31ba1f21] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: prepare for GRPCI2DMA driver Wed, 15 Feb 2017 10:09:23 GMT Javier Jalle [8e45d55] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: Make driver SMP safe Fri, 17 Mar 2017 13:44:25 GMT Daniel Hellstrom [9631e5a9] * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (modified) leon, ambapp: updated AMBA PnP IDs and names database Tue, 14 Mar 2017 16:46:12 GMT Martin Aberg [e5e44bdb] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Wait for shift register on close Do not disable ... Tue, 14 Mar 2017 16:27:57 GMT Martin Aberg [6860ddb] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Optimized RX processing in ISR Limit the number of ... Mon, 13 Mar 2017 09:53:47 GMT Martin Aberg [3df6710] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: support termios task driven mode The APBUART control ... Fri, 10 Mar 2017 14:32:38 GMT Martin Aberg [f164a294] * c/src/lib/libbsp/sparc/shared/include/cons.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) leon, apbuart: Inherit HW parameters on sysconsole The cons layer ... Fri, 10 Mar 2017 13:03:11 GMT Martin Aberg [6e2e1299] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Assign proper device name Always assign a ... Thu, 09 Mar 2017 17:51:47 GMT Martin Aberg [1fefc719] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: RX delayed interrupt Utilize the APBUART RX delayed ... Wed, 01 Feb 2017 15:48:51 GMT Martin Aberg [fd9fb21] * c/src/lib/libbsp/sparc/shared/include/cons.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) leon, cons: drvmgr cons interface uses new TERMIOS LEON driver ... Mon, 06 Mar 2017 10:14:23 GMT Martin Aberg [7cb93250] * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) leon, apbuart: added register defines: FIFO, delay int The FIFOs ... Thu, 23 Feb 2017 15:33:21 GMT Martin Aberg [f600458d] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) leon, clock: new driver manager clock driver - Compatible with SMP ... Mon, 10 Apr 2017 12:52:16 GMT Daniel Hellstrom [78e56096] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, tlib: added timer width mask information Fri, 07 Apr 2017 06:31:48 GMT Daniel Hellstrom [ae203e0d] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp_bus: IRQ affinity for on-chip AMBAPP bus Tue, 31 Jan 2017 09:13:41 GMT Javier Jalle [61788e76] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libpci/pci/ids_extra.h (modified) * cpukit/libpci/pci_bus.h (modified) leon, GR-CPCI-GR740: Added peripheral PCI driver Sat, 29 Apr 2017 13:20:28 GMT Pavel Pisa [0e6542fb] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/tms570lc4357-pins.h (added) bsp/tms570: include package balls and PINMMR registers mapping for ... Wed, 26 Apr 2017 15:53:56 GMT Joel Sherrill [61568e6] * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (modified) virtex5/startup/dummy_console.c: Use and ... Wed, 26 Apr 2017 15:50:08 GMT Joel Sherrill [c0ea829] * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (modified) virtex4/startup/dummy_console.c: Use and ... Wed, 26 Apr 2017 01:01:10 GMT Joel Sherrill [ab77827] * c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c (modified) or1k/generic_or1k/irq/irq.c: Include and fix ... Tue, 25 Apr 2017 16:42:18 GMT Joel Sherrill [7db09923] * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (modified) * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number ... Mon, 24 Apr 2017 17:00:15 GMT Joel Sherrill [485222e] * c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c (modified) genmcf548x/irq/irq.c: Fix incompatible pointer warning Mon, 24 Apr 2017 16:18:03 GMT Joel Sherrill [0d01cdd6] * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) sh/sh7750/sci/sh4uart.c: ix misleading indentation warning Mon, 24 Apr 2017 16:17:41 GMT Joel Sherrill [646df54c] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) powerpc/new-exceptions/bspsupport/ppc_exc_print.c: Fix printf() ... Mon, 24 Apr 2017 16:17:12 GMT Joel Sherrill [2808c26] * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) powerpc/mpc5xx/console-generic/console-generic.c: Use updated struct ... Mon, 24 Apr 2017 16:16:37 GMT Joel Sherrill [3ed2cf60] * c/src/lib/libbsp/sparc/leon2/console/debugputs.c (modified) leon2/console/debugputs.c: Fix misleading indentation warning Mon, 24 Apr 2017 16:15:53 GMT Joel Sherrill [fd48b43] * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (modified) virtex5/startup/dummy_console.c: Fix no prototype warning Mon, 24 Apr 2017 16:15:44 GMT Joel Sherrill [9beada51] * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (modified) virtex4/startup/dummy_console.c: Fix no prototype warning Mon, 24 Apr 2017 16:15:18 GMT Joel Sherrill [523b4fb] * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) mcf5235/console/console.c: Fix indentation and add braces Mon, 24 Apr 2017 01:35:05 GMT Joel Sherrill [5e899b5] * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) sparc64/shared/helenos/boot/sparc64/loader/main.c: Fix printf() ... Mon, 24 Apr 2017 01:34:42 GMT Joel Sherrill [436008c] * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) sparc64/shared/clock/ckinit.c: Include Mon, 24 Apr 2017 01:17:54 GMT Joel Sherrill [38d0a94] * c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c (modified) shared/drvmgr/leon2_amba_bus.c: Include Mon, 24 Apr 2017 01:05:53 GMT Joel Sherrill [5796c21] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) shared/startup/panic.c: Fix printf() format warnings
