# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/18/24 20:14:16 Fri, 03 Jul 2020 07:15:50 GMT Sebastian Huber [70b803b5] * bsps/powerpc/mpc55xxevb/config/mpc5566evb_spe-testsuite.tcfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5566evb_spe.cfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc55xx.inc (modified) * bsps/powerpc/mpc55xxevb/config/mpc55xx_spe.inc (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu-testsuite.tcfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu.cfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_app-testsuite.tcfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_app.cfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_boot-testsuite.tcfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_boot.cfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674f_rsm6-testsuite.tcfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674f_rsm6.cfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb_spe-testsuite.tcfg (deleted) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb_spe.cfg (deleted) * bsps/powerpc/mpc55xxevb/config/phycore_mpc5554.cfg (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb_spe (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_dpu (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_app (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_boot (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6 (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (deleted) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb_spe (deleted) * bsps/powerpc/qoriq/config/qoriq.inc (modified) * bsps/powerpc/t32mppc/config/t32mppc.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) bsps/powerpc: Remove SPE enabled variants The PowerPC SPE support ... Tue, 30 Jun 2020 07:19:08 GMT Sebastian Huber [37c36de] * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * rtems-bsps (modified) * testsuites/aclocal/version.m4 (modified) Change version to RTEMS 6 Update #4020. Sun, 31 May 2020 14:22:57 GMT Jan Sommer [208cd6b] * bsps/i386/include/bsp/smp-imps.h (modified) * bsps/i386/pc386/include/bsp.h (modified) * bsps/i386/pc386/start/bspsmp.c (added) * bsps/i386/pc386/start/getcpuid.c (deleted) * bsps/i386/pc386/start/smp-imps.c (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) bsps/pc386: Separate smp API functions. Makes smpfatal08 link Sun, 31 May 2020 14:22:52 GMT Jan Sommer [f99b1f0] * bsps/i386/pc386/start/smp-imps.c (modified) * bsps/i386/pc386/start/start16.S (deleted) * bsps/i386/pc386/start/startAP.S (added) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) bsp/pc386: Turn start16.S into a startAP.S start16.S is now only ... Sun, 31 May 2020 14:22:51 GMT Jan Sommer [a2b7ab03] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) bsp/pc386: Fix Makefile for building with SMP Mon, 30 Mar 2020 14:38:22 GMT Christian Mauderer [01219541] * bsps/arm/imx/include/arm/freescale/imx/imx_ccmvar.h (modified) * bsps/arm/imx/spi/imx-ecspi.c (modified) * bsps/arm/imx/start/ccm.c (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: Add an extra ecspi clock. Some imx chips or boards don't ... Thu, 19 Mar 2020 20:55:26 GMT Joel Sherrill [37e7cc5] * bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm1136jfs.cfg (deleted) * bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm1136js.cfg (deleted) * bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm7tdmi.cfg (deleted) * bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm920.cfg (deleted) * bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/armcortexa9.cfg (deleted) * bsps/arm/gdbarmsim/console/console-io.c (deleted) * bsps/arm/gdbarmsim/headers.am (deleted) * bsps/arm/gdbarmsim/include/bsp.h (deleted) * bsps/arm/gdbarmsim/include/bsp/irq.h (deleted) * bsps/arm/gdbarmsim/include/bsp/swi.h (deleted) * bsps/arm/gdbarmsim/include/tm27.h (deleted) * bsps/arm/gdbarmsim/irq/irq-dispatch.c (deleted) * bsps/arm/gdbarmsim/irq/irq.c (deleted) * bsps/arm/gdbarmsim/start/bsp_specs (deleted) * bsps/arm/gdbarmsim/start/bspreset.c (deleted) * bsps/arm/gdbarmsim/start/bspstart.c (deleted) * bsps/arm/gdbarmsim/start/bspstarthooks.c (deleted) * bsps/arm/gdbarmsim/start/linkcmds (deleted) * bsps/arm/gdbarmsim/start/syscalls.c (deleted) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (deleted) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (deleted) gdbarmsim: Remove Closes #3611. Fri, 13 Mar 2020 14:13:30 GMT Sebastian Huber [aa2d5d93] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) bsp/virtex: Remove duplicate include Wed, 12 Feb 2020 07:53:35 GMT Sebastian Huber [b900f507] * bsps/arm/shared/serial/zynq-uart-polled.c (added) * bsps/arm/shared/serial/zynq-uart.c (modified) * bsps/arm/xilinx-zynq/console/console-config.c (modified) * bsps/arm/xilinx-zynq/console/console-init.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) arm/xilinx-zynq: Split console driver files This avoids to pull in ... Tue, 04 Feb 2020 14:26:31 GMT Sebastian Huber [2d07ce6] * bsps/shared/start/bootcard.c (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memorydirtyfreeareas.c (added) * testsuites/sptests/sp54/init.c (modified) config: Add CONFIGURE_DIRTY_MEMORY Replace the BSP_DIRTY_MEMORY BSP ... Sat, 04 Jan 2020 19:50:46 GMT G S Niteesh [362cf319] * bsps/arm/raspberrypi/console/console-config.c (modified) * bsps/arm/raspberrypi/console/console_select.c (deleted) * bsps/arm/raspberrypi/console/fbcons.c (modified) * bsps/arm/raspberrypi/console/usart.c (deleted) * bsps/arm/raspberrypi/include/bsp.h (modified) * bsps/arm/raspberrypi/include/bsp/fbcons.h (modified) * bsps/arm/raspberrypi/include/bsp/raspberrypi.h (modified) * bsps/arm/raspberrypi/include/bsp/usart.h (modified) * bsps/arm/raspberrypi/start/bspstart.c (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsp/raspberrypi: Updated the console API. Replaces the legacy ... Fri, 03 Jan 2020 03:26:14 GMT G S Niteesh [eca25ef] * bsps/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) bsp/raspberrypi: Enable FDT support. This commit adds FDT support ... Fri, 27 Dec 2019 21:08:12 GMT Christian Mauderer [f1f6cd95] * bsps/arm/raspberrypi/include/bsp/vc.h (modified) * bsps/arm/raspberrypi/start/bspgetworkarea.c (deleted) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/mm_config_table.c (deleted) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsp/raspberrypi: Fix size of work area. The BSP tried to get the ... Thu, 05 Dec 2019 06:51:12 GMT Sebastian Huber [1380c822] * bsps/arm/xen/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/xen/configure.ac (modified) bsp/xen: Use BSP options for all linkcmds vars Update #3818. Wed, 04 Dec 2019 14:29:33 GMT Jeff Kubascik [4c30acf] * bsps/arm/xen/config/xen_virtual.cfg (added) * bsps/arm/xen/console/console.c (added) * bsps/arm/xen/headers.am (added) * bsps/arm/xen/include/bsp.h (added) * bsps/arm/xen/include/bsp/irq.h (added) * bsps/arm/xen/include/tm27.h (added) * bsps/arm/xen/start/bsp_specs (added) * bsps/arm/xen/start/bspstart.c (added) * bsps/arm/xen/start/bspstarthooks.c (added) * bsps/arm/xen/start/bspstartmmu.c (added) * bsps/arm/xen/start/linkcmds.in (added) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/xen/Makefile.am (added) * c/src/lib/libbsp/arm/xen/configure.ac (added) bsp/xen: Create BSP Create the Xen BSP for Xen on ARM. Tue, 19 Nov 2019 14:22:14 GMT Sebastian Huber [a52d6174] * bsps/arm/imx/start/linkcmds (moved) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx7: Rename linker command file This BSP family uses only one ... Tue, 19 Nov 2019 13:49:43 GMT Sebastian Huber [af321aa] * bsps/arm/altera-cyclone-v/start/linkcmds (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) bsp/altcycv_devkit: Rename linker command file This BSP family uses ... Fri, 15 Nov 2019 06:38:28 GMT Sebastian Huber [75d9e79f] * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) bsp/lpc32xx: Remove unused TESTS_USE_PRINTK Update #3818. Fri, 15 Nov 2019 06:09:04 GMT Sebastian Huber [b882b07] * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * testsuites/libtests/capture01/init.c (modified) * testsuites/libtests/capture01/test1.c (modified) Remove BSP_SMALL_MEMORY BSP option Use the test state configuration ... Fri, 15 Nov 2019 06:05:11 GMT Sebastian Huber [9c601b00] * c/src/lib/libbsp/i386/pc386/configure.ac (modified) bsp/i386: Remove unused BSP_HAS_SMP Update #3818. Thu, 14 Nov 2019 14:03:08 GMT Sebastian Huber [41ab50e4] * bsps/powerpc/t32mppc/start/linkcmds (moved) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) bsp/t32mppc: Rename linker command file This BSP family uses only ... Thu, 14 Nov 2019 14:02:03 GMT Sebastian Huber [bc28b65] * bsps/arm/beagle/start/linkcmds (moved) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) bsp/beagle: Rename linker command file This BSP family uses only ... Thu, 14 Nov 2019 10:11:46 GMT Sebastian Huber [5a1bc179] * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Remove bogus Automake conditional Update #3785. Thu, 14 Nov 2019 09:28:06 GMT Sebastian Huber [984d7443] * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) bsp/gumstix: Remove ON_SKYEYE Automake conditional It is fine to ... Thu, 14 Nov 2019 08:36:56 GMT Sebastian Huber [90d6a094] * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) arm/stm32f4: Fix typo Mon, 28 Oct 2019 09:15:28 GMT Sebastian Huber [f9648ba] * bsps/arm/include/bsp/arm-cp15-start.h (modified) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (modified) * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) bsps/arm: Add support for small pages MMU The small page MMU ... Mon, 28 Oct 2019 08:59:22 GMT Sebastian Huber [37e9aa6] * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (modified) bsp/xilinx-zynqmp: Fix linkcmds config Bug was introduced by commit ... Wed, 23 Oct 2019 11:43:17 GMT Hesham Almatary [f462bcb] * bsps/riscv/shared/start/linkcmds.base.in (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/griscv/configure.ac (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) riscv: Address differences in the linkerscript between GNU LD and ... Wed, 23 Oct 2019 11:37:12 GMT Hesham Almatary [ca82ded7] * bsps/riscv/shared/start/linkcmds.base.in (moved) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) riscv: Generate linkcmds.base from the shared linkcmds.base.in This ... Wed, 23 Oct 2019 12:16:47 GMT Sebastian Huber [d2efc968] * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Simplify linkcmds config Use NULL-pointer ... Wed, 23 Oct 2019 12:11:17 GMT Sebastian Huber [8c66f1aa] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Simplify configure.ac Wed, 23 Oct 2019 12:03:39 GMT Sebastian Huber [1e1afa37] * bsps/arm/xilinx-zynqmp/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (modified) bsp/xilinx-zynqmp: Simplify linkcmds config Do all calculations in ... Wed, 23 Oct 2019 11:55:00 GMT Sebastian Huber [4ecab58] * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (modified) bsp/xilinx-zynqmp: Simplify configure.ac Use NULL-pointer ... Tue, 22 Oct 2019 10:20:05 GMT Pragnesh Patel [a7f5e42c] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/config/frdme310arty.cfg (added) * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/console/fe310-uart.c (added) * bsps/riscv/riscv/include/bsp/fe310-uart.h (added) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/start/bspstart.c (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) riscv: add freedom E310 Arty A7 bsp Added support for Sifive ... Tue, 01 Oct 2019 06:54:20 GMT Sebastian Huber [be3d6974] * bsps/sparc/erc32/start/bspsmp.c (added) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) bsp/erc32: Improve pseudo-SMP support Add support for ... Tue, 06 Aug 2019 10:00:56 GMT Chris Johns [a4d7e4ce] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/arm/raspberrypi/start/bspstart.c (modified) * bsps/arm/raspberrypi/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) arm/raspberry: Set the workspace based on the mailbox version. - ... Tue, 25 Jun 2019 11:16:27 GMT Chris Johns [7d4f74e] * bsps/arm/beagle/start/bspdebug.c (added) * bsps/arm/beagle/start/bspdebug.h (added) * bsps/arm/beagle/start/bspstart.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) arm/beagle: Add libdebugger support. - Port the jbang code from C++ ... Fri, 26 Jul 2019 06:12:20 GMT Sebastian Huber [1e6380b] * bsps/arm/shared/start/bsp-start-in-hyp-support.S (deleted) * bsps/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsps/arm: Move HYP to SVC change to start.S This fixes the ... Fri, 26 Jul 2019 05:59:27 GMT Sebastian Huber [0ee2125] * bsps/arm/shared/start/bsp-start-init-registers.S (deleted) * bsps/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) bsps/arm: Move register init to start.S This makes it easier to ... Wed, 17 Jul 2019 12:19:04 GMT Chris Johns [270c5df5] * c/src/make/Makefile.am (modified) * c/src/make/Makefile.inc.in (modified) * make/custom/default.cfg (modified) * make/main.cfg (modified) Makefile.inc: Add support for staged builds. - Allow the RTEMS_ROOT ... Tue, 18 Jun 2019 10:52:53 GMT Sebastian Huber [a67b9b06] * bsps/arm/atsam/include/bsp/power.h (modified) * bsps/arm/atsam/start/power-wait.c (added) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) atsam: Add ATSAM_POWER_WAIT_MODE Sat, 11 May 2019 12:57:39 GMT Sebastian Huber [45d0659] * bsps/bfin/TLL6527M/include/bsp/irq.h (added) * bsps/bfin/bf537Stamp/include/bsp/irq.h (added) * bsps/bfin/eZKit533/include/bsp/irq.h (added) * bsps/include/bsp/irq-default.h (added) * bsps/lm32/lm32_evr/include/bsp/irq.h (added) * bsps/lm32/milkymist/include/bsp/irq.h (added) * bsps/m68k/av5282/include/bsp/irq.h (added) * bsps/m68k/csb360/include/bsp/irq.h (added) * bsps/m68k/gen68340/include/bsp/irq.h (added) * bsps/m68k/gen68360/include/bsp/irq.h (added) * bsps/m68k/mcf5206elite/include/bsp/irq.h (added) * bsps/m68k/mcf52235/include/bsp/irq.h (added) * bsps/m68k/mcf5225x/include/bsp/irq.h (added) * bsps/m68k/mcf5235/include/bsp/irq.h (added) * bsps/m68k/mcf5329/include/bsp/irq.h (added) * bsps/m68k/mrm332/include/bsp/irq.h (added) * bsps/m68k/mvme147/include/bsp/irq.h (added) * bsps/m68k/mvme147s/include/bsp/irq.h (added) * bsps/m68k/mvme162/include/bsp/irq.h (added) * bsps/m68k/mvme167/include/bsp/irq.h (added) * bsps/m68k/uC5282/include/bsp/irq.h (added) * bsps/moxie/moxiesim/include/bsp/irq.h (added) * bsps/nios2/nios2_iss/include/bsp/irq.h (added) * bsps/no_cpu/no_bsp/include/bsp/irq.h (added) * bsps/powerpc/beatnik/include/bsp/irq.h (modified) * bsps/powerpc/haleakala/include/bsp/irq.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (modified) * bsps/powerpc/mvme3100/include/bsp/irq.h (modified) * bsps/powerpc/mvme5500/include/bsp/irq.h (modified) * bsps/powerpc/ss555/include/bsp/irq.h (modified) * bsps/powerpc/virtex4/include/bsp/irq.h (modified) * bsps/powerpc/virtex5/include/bsp/irq.h (modified) * bsps/sh/gensh1/include/bsp/irq.h (added) * bsps/sh/gensh2/include/bsp/irq.h (added) * bsps/sh/gensh4/include/bsp/irq.h (added) * bsps/sh/shsim/include/bsp/irq.h (added) * bsps/shared/irq-default-sources.am (added) * bsps/shared/irq/irq-default.c (added) * bsps/sparc64/niagara/include/bsp/irq.h (added) * bsps/sparc64/usiii/include/bsp/irq.h (added) * bsps/v850/gdbv850sim/include/bsp/irq.h (added) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Always build generic interrupt support This makes it possible ... Wed, 08 May 2019 11:09:05 GMT Sebastian Huber [271b8a6] * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) bsp/lpc24xx: Remove obsolete BSP optinons Update #3725. Fri, 12 Apr 2019 06:02:16 GMT Sebastian Huber [5cc313b] * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR Remove this BSP option. Wed, 10 Apr 2019 23:38:55 GMT Jeff Kubascik [77f9a1b] * bsps/arm/xilinx-zynqmp/README (modified) * bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp.inc (moved) * bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_ultra96.cfg (added) * bsps/arm/xilinx-zynqmp/console/console-config.c (modified) * bsps/arm/xilinx-zynqmp/headers.am (modified) * bsps/arm/xilinx-zynqmp/include/bsp.h (modified) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynqmp/include/tm27.h (modified) * bsps/arm/xilinx-zynqmp/start/bspreset.c (modified) * bsps/arm/xilinx-zynqmp/start/bspsmp.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstart.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstarthooks.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstartmmu.c (modified) * bsps/arm/xilinx-zynqmp/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (modified) bsp/xilinx-zynqmp: Implement Ultra96 target Modifications to get ... Wed, 10 Apr 2019 23:38:54 GMT Jeff Kubascik [677d5167] * bsps/arm/xilinx-zynqmp/README (added) * bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc (added) * bsps/arm/xilinx-zynqmp/console/console-config.c (added) * bsps/arm/xilinx-zynqmp/headers.am (added) * bsps/arm/xilinx-zynqmp/include/bsp.h (added) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (added) * bsps/arm/xilinx-zynqmp/include/tm27.h (added) * bsps/arm/xilinx-zynqmp/start/bsp_specs (added) * bsps/arm/xilinx-zynqmp/start/bspreset.c (added) * bsps/arm/xilinx-zynqmp/start/bspsmp.c (added) * bsps/arm/xilinx-zynqmp/start/bspstart.c (added) * bsps/arm/xilinx-zynqmp/start/bspstarthooks.c (added) * bsps/arm/xilinx-zynqmp/start/bspstartmmu.c (added) * bsps/arm/xilinx-zynqmp/start/linkcmds.in (added) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (added) * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (added) bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP Source files were ... Wed, 10 Apr 2019 23:38:53 GMT Jeff Kubascik [b004430] * bsps/arm/headers.am (modified) * bsps/arm/include/bsp/zynq-uart-regs.h (moved) * bsps/arm/include/bsp/zynq-uart.h (moved) * bsps/arm/shared/serial/zynq-uart.c (moved) * bsps/arm/xilinx-zynq/headers.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) bsp/zynq-uart: Move Zynq UART driver to shared directory This ... Mon, 25 Feb 2019 06:07:19 GMT Sebastian Huber [007d4e12] * bsps/arm/lpc24xx/i2c/i2c-config.c (deleted) * bsps/arm/lpc24xx/i2c/i2c.c (modified) * bsps/arm/lpc24xx/include/bsp/i2c.h (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) bsp/lpc24xx: Convert I2C driver to Linux API Change license to ... Wed, 27 Feb 2019 10:43:49 GMT Sebastian Huber [262cb534] * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_qspi.h (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) bsp/altera-cyclone-v: Move header file This gets rid of a special ... Mon, 25 Feb 2019 22:30:09 GMT Pierre-Louis Garnier [ecf62845] * bsps/arm/beagle/headers.am (modified) * bsps/arm/beagle/include/bsp.h (modified) * bsps/arm/beagle/include/bsp/spi.h (added) * bsps/arm/beagle/spi/spi.c (added) * bsps/arm/include/libcpu/am335x.h (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) arm/beagle: SPI driver Mon, 18 Feb 2019 07:24:37 GMT Sebastian Huber [af80b0a] * bsps/arm/altera-cyclone-v/include/bsp.h (modified) * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) bsp/altera-cyclone-v: Use FDT for clock frequency Fri, 15 Feb 2019 11:07:23 GMT Sebastian Huber [43fbb50f] * bsps/arm/altera-cyclone-v/include/bsp.h (modified) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) bsp/altera-cyclone-v: Make FDT support optional Fri, 18 Jan 2019 11:37:55 GMT Jiri Gaisler [d3d4e77] * bsps/riscv/griscv/clock/clockdrv.c (added) * bsps/riscv/griscv/config/griscv.cfg (added) * bsps/riscv/griscv/console/console.c (added) * bsps/riscv/griscv/console/printk_support.c (added) * bsps/riscv/griscv/headers.am (added) * bsps/riscv/griscv/include/amba.h (added) * bsps/riscv/griscv/include/bsp.h (added) * bsps/riscv/griscv/include/bsp/irq.h (added) * bsps/riscv/griscv/include/tm27.h (added) * bsps/riscv/griscv/irq/irq.c (added) * bsps/riscv/griscv/start/amba.c (added) * bsps/riscv/griscv/start/bsp_fatal_halt.c (added) * bsps/riscv/griscv/start/bsp_specs (added) * bsps/riscv/griscv/start/bspsmp.c (added) * bsps/riscv/griscv/start/bspstart.c (added) * bsps/riscv/griscv/start/linkcmds.in (added) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/shared/start/linkcmds.base (moved) * bsps/riscv/shared/start/start.S (moved) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (added) * c/src/lib/libbsp/riscv/griscv/configure.ac (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: add griscv bsp Update #3678. Sat, 22 Dec 2018 17:31:04 GMT Sebastian Huber [7eb606d3] * bsps/shared/grlib-sources.am (added) * bsps/shared/grlib/1553/b1553brm.c (moved) * bsps/shared/grlib/1553/b1553rt.c (moved) * bsps/shared/grlib/1553/gr1553b.c (moved) * bsps/shared/grlib/1553/gr1553bc.c (moved) * bsps/shared/grlib/1553/gr1553bm.c (moved) * bsps/shared/grlib/1553/gr1553rt.c (moved) * bsps/shared/grlib/amba/ahbstat.c (moved) * bsps/shared/grlib/amba/ambapp.c (moved) * bsps/shared/grlib/amba/ambapp_alloc.c (moved) * bsps/shared/grlib/amba/ambapp_count.c (moved) * bsps/shared/grlib/amba/ambapp_depth.c (moved) * bsps/shared/grlib/amba/ambapp_find_by_idx.c (moved) * bsps/shared/grlib/amba/ambapp_freq.c (moved) * bsps/shared/grlib/amba/ambapp_names.c (moved) * bsps/shared/grlib/amba/ambapp_old.c (moved) * bsps/shared/grlib/amba/ambapp_parent.c (moved) * bsps/shared/grlib/amba/ambapp_show.c (moved) * bsps/shared/grlib/analog/gradcdac.c (moved) * bsps/shared/grlib/ascs/grascs.c (moved) * bsps/shared/grlib/btimer/gptimer.c (moved) * bsps/shared/grlib/btimer/tlib.c (moved) * bsps/shared/grlib/btimer/tlib_ckinit.c (moved) * bsps/shared/grlib/can/canmux.c (moved) * bsps/shared/grlib/can/grcan.c (moved) * bsps/shared/grlib/can/occan.c (moved) * bsps/shared/grlib/can/satcan.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c (moved) * bsps/shared/grlib/drvmgr/get_resarray_count.c (moved) * bsps/shared/grlib/gpio/gpiolib.c (moved) * bsps/shared/grlib/gpio/grgpio.c (moved) * bsps/shared/grlib/i2c/i2cmst.c (moved) * bsps/shared/grlib/iommu/griommu.c (moved) * bsps/shared/grlib/irq/genirq.c (moved) * bsps/shared/grlib/l2c/l2c.c (moved) * bsps/shared/grlib/mem/mctrl.c (moved) * bsps/shared/grlib/net/README (moved) * bsps/shared/grlib/net/greth.c (moved) * bsps/shared/grlib/net/network_interface_add.c (moved) * bsps/shared/grlib/pci/gr_701.c (moved) * bsps/shared/grlib/pci/gr_rasta_adcdac.c (moved) * bsps/shared/grlib/pci/gr_rasta_io.c (moved) * bsps/shared/grlib/pci/gr_rasta_spw_router.c (moved) * bsps/shared/grlib/pci/gr_rasta_tmtc.c (moved) * bsps/shared/grlib/pci/gr_tmtc_1553.c (moved) * bsps/shared/grlib/pci/grpci.c (moved) * bsps/shared/grlib/pci/grpci2.c (moved) * bsps/shared/grlib/pci/grpci2dma.c (moved) * bsps/shared/grlib/pci/pcif.c (moved) * bsps/shared/grlib/pwm/grpwm.c (moved) * bsps/shared/grlib/scrub/memscrub.c (moved) * bsps/shared/grlib/slink/grslink.c (moved) * bsps/shared/grlib/spi/spictrl.c (moved) * bsps/shared/grlib/spw/grspw.c (moved) * bsps/shared/grlib/spw/grspw_pkt.c (moved) * bsps/shared/grlib/spw/grspw_router.c (moved) * bsps/shared/grlib/spw/spwtdp.c (moved) * bsps/shared/grlib/stat/l4stat.c (moved) * bsps/shared/grlib/time/grctm.c (moved) * bsps/shared/grlib/time/spwcuc.c (moved) * bsps/shared/grlib/tmtc/grtc.c (moved) * bsps/shared/grlib/tmtc/grtm.c (moved) * bsps/shared/grlib/uart/apbuart_cons.c (moved) * bsps/shared/grlib/uart/apbuart_polled.c (moved) * bsps/shared/grlib/uart/apbuart_termios.c (moved) * bsps/shared/grlib/uart/cons.c (moved) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) grlib: Move source files Update #3678. Fri, 21 Dec 2018 07:39:33 GMT Sebastian Huber [41a557bc] * bsps/arm/shared/cache/cache-cp15.c (modified) * bsps/arm/shared/cache/cache-v7ar-disable-data.S (added) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) bsps/arm: Add ARMv7-AR disable data cache Close #3667. Thu, 13 Dec 2018 08:39:20 GMT Sebastian Huber [6b0a729b] * ampolish3 (deleted) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-ampolish.m4 (deleted) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * cpukit/aclocal/rtems-ampolish.m4 (deleted) * cpukit/configure.ac (modified) build: Remove ampolish3 Update #3254. Thu, 03 May 2018 11:03:27 GMT Sebastian Huber [0a1f5df9] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * bsps/shared/dev/cpucounter/cpucounterdiff.c (deleted) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/sparc-counter.c (deleted) Simplify _CPU_Counter_difference() In order to simplify the use of ... Fri, 16 Nov 2018 07:55:30 GMT Sebastian Huber [5f5bbd1] * bsps/x86_64/amd64/start/linkcmds (modified) * bsps/x86_64/amd64/start/start.S (added) * bsps/x86_64/amd64/start/start.c (deleted) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) bsps/x86_64: Use interrupt stack for init stack Update #3459. Thu, 15 Nov 2018 19:47:22 GMT Sebastian Huber [84e59b7c] * bsps/powerpc/gen5200/start/start.S (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/haleakala/start/start.S (moved) * bsps/powerpc/mpc8260ads/start/start.S (modified) * bsps/powerpc/mvme3100/start/start.S (modified) * bsps/powerpc/mvme5500/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/shared/start/start.S (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/virtex/start/start.S (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) bsps/powerpc: Use interrupt stack for init stack Move start.o to ... Thu, 08 Nov 2018 15:21:48 GMT Sebastian Huber [bfcf1473] * bsps/m32c/m32cbsp/README (deleted) * bsps/m32c/m32cbsp/btimer/btimer.c (deleted) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (deleted) * bsps/m32c/m32cbsp/config/m32csim.cfg (deleted) * bsps/m32c/m32cbsp/console/console-io.c (deleted) * bsps/m32c/m32cbsp/console/syscalls.S (deleted) * bsps/m32c/m32cbsp/doxygen.h (deleted) * bsps/m32c/m32cbsp/headers.am (deleted) * bsps/m32c/m32cbsp/include/bsp.h (deleted) * bsps/m32c/m32cbsp/include/tm27.h (deleted) * bsps/m32c/m32cbsp/start/bsp_specs (deleted) * bsps/m32c/m32cbsp/start/bspstart.c (deleted) * bsps/m32c/m32cbsp/start/crtn.S (deleted) * bsps/m32c/m32cbsp/start/linkcmds (deleted) * bsps/m32c/m32cbsp/start/start.S (deleted) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/m32c/Makefile.am (deleted) * c/src/lib/libbsp/m32c/acinclude.m4 (deleted) * c/src/lib/libbsp/m32c/configure.ac (deleted) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (deleted) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (deleted) * cpukit/Makefile.am (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/score/cpu/m32c/context_init.c (deleted) * cpukit/score/cpu/m32c/context_switch.S (deleted) * cpukit/score/cpu/m32c/cpu.c (deleted) * cpukit/score/cpu/m32c/headers.am (deleted) * cpukit/score/cpu/m32c/include/rtems/asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/m32c.h (deleted) * cpukit/score/cpu/m32c/include/varvects.h (deleted) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (deleted) * cpukit/score/cpu/m32c/varvects.S (deleted) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptimer_err02/init.c (modified) m32c: Remove this target Update #3599. Wed, 07 Nov 2018 10:08:50 GMT Sebastian Huber [2faea99] * bsps/arm/realview-pbx-a9/console/console-config.c (modified) * bsps/arm/realview-pbx-a9/console/console-polled.c (added) * bsps/arm/realview-pbx-a9/include/bsp/console.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) bsp/realview-pbx-a9: Fix printk() support Avoid dependencies on the ... Wed, 24 Oct 2018 08:17:58 GMT Sebastian Huber [01595a4] * bsps/arm/imx/start/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx: Adjust workspace according to device tree Mon, 24 Sep 2018 14:32:49 GMT Joel Sherrill [b4043ea] * c/src/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) check-networking.m4: Disable legacy stack for x86_64 and epiphany ... Mon, 15 Oct 2018 05:22:42 GMT Sebastian Huber [fb12215] * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) build: Remove specialized CPPFLAGS Close #3375. Sat, 06 Oct 2018 08:59:10 GMT Sebastian Huber [477bca2] * automake/local.am (deleted) * c/src/Makefile.am (modified) * c/src/automake/local.am (deleted) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/x86_64/Makefile.am (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * c/src/make/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/local.am (deleted) * cpukit/score/cpu/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/ada/Makefile.am (modified) * testsuites/ada/mptests/Makefile.am (modified) * testsuites/ada/mptests/mp01/Makefile.am (modified) * testsuites/ada/mptests/mp01/node1/Makefile.am (modified) * testsuites/ada/mptests/mp01/node2/Makefile.am (modified) * testsuites/ada/mptests/mp03/Makefile.am (modified) * testsuites/ada/mptests/mp03/node1/Makefile.am (modified) * testsuites/ada/mptests/mp03/node2/Makefile.am (modified) * testsuites/ada/mptests/mp04/Makefile.am (modified) * testsuites/ada/mptests/mp04/node1/Makefile.am (modified) * testsuites/ada/mptests/mp04/node2/Makefile.am (modified) * testsuites/ada/mptests/mp05/Makefile.am (modified) * testsuites/ada/mptests/mp05/node1/Makefile.am (modified) * testsuites/ada/mptests/mp05/node2/Makefile.am (modified) * testsuites/ada/mptests/mp06/Makefile.am (modified) * testsuites/ada/mptests/mp06/node1/Makefile.am (modified) * testsuites/ada/mptests/mp06/node2/Makefile.am (modified) * testsuites/ada/mptests/mp07/Makefile.am (modified) * testsuites/ada/mptests/mp07/node1/Makefile.am (modified) * testsuites/ada/mptests/mp07/node2/Makefile.am (modified) * testsuites/ada/mptests/mp08/Makefile.am (modified) * testsuites/ada/mptests/mp08/node1/Makefile.am (modified) * testsuites/ada/mptests/mp08/node2/Makefile.am (modified) * testsuites/ada/mptests/mp09/Makefile.am (modified) * testsuites/ada/mptests/mp09/node1/Makefile.am (modified) * testsuites/ada/mptests/mp09/node2/Makefile.am (modified) * testsuites/ada/mptests/mp10/Makefile.am (modified) * testsuites/ada/mptests/mp10/node1/Makefile.am (modified) * testsuites/ada/mptests/mp10/node2/Makefile.am (modified) * testsuites/ada/mptests/mp11/Makefile.am (modified) * testsuites/ada/mptests/mp11/node1/Makefile.am (modified) * testsuites/ada/mptests/mp11/node2/Makefile.am (modified) * testsuites/ada/mptests/mp12/Makefile.am (modified) * testsuites/ada/mptests/mp12/node1/Makefile.am (modified) * testsuites/ada/mptests/mp12/node2/Makefile.am (modified) * testsuites/ada/mptests/mp13/Makefile.am (modified) * testsuites/ada/mptests/mp13/node1/Makefile.am (modified) * testsuites/ada/mptests/mp13/node2/Makefile.am (modified) * testsuites/ada/mptests/mp14/Makefile.am (modified) * testsuites/ada/mptests/mp14/node1/Makefile.am (modified) * testsuites/ada/mptests/mp14/node2/Makefile.am (modified) * testsuites/ada/samples/Makefile.am (modified) * testsuites/ada/samples/base_mp/Makefile.am (modified) * testsuites/ada/samples/base_mp/node1/Makefile.am (modified) * testsuites/ada/samples/base_mp/node2/Makefile.am (modified) * testsuites/ada/samples/base_sp/Makefile.am (modified) * testsuites/ada/samples/hello/Makefile.am (modified) * testsuites/ada/samples/nsecs/Makefile.am (modified) * testsuites/ada/samples/ticker/Makefile.am (modified) * testsuites/ada/sptests/Makefile.am (modified) * testsuites/ada/sptests/sp01/Makefile.am (modified) * testsuites/ada/sptests/sp02/Makefile.am (modified) * testsuites/ada/sptests/sp03/Makefile.am (modified) * testsuites/ada/sptests/sp04/Makefile.am (modified) * testsuites/ada/sptests/sp05/Makefile.am (modified) * testsuites/ada/sptests/sp06/Makefile.am (modified) * testsuites/ada/sptests/sp07/Makefile.am (modified) * testsuites/ada/sptests/sp08/Makefile.am (modified) * testsuites/ada/sptests/sp09/Makefile.am (modified) * testsuites/ada/sptests/sp11/Makefile.am (modified) * testsuites/ada/sptests/sp12/Makefile.am (modified) * testsuites/ada/sptests/sp13/Makefile.am (modified) * testsuites/ada/sptests/sp14/Makefile.am (modified) * testsuites/ada/sptests/sp15/Makefile.am (modified) * testsuites/ada/sptests/sp16/Makefile.am (modified) * testsuites/ada/sptests/sp17/Makefile.am (modified) * testsuites/ada/sptests/sp19/Makefile.am (modified) * testsuites/ada/sptests/sp20/Makefile.am (modified) * testsuites/ada/sptests/sp22/Makefile.am (modified) * testsuites/ada/sptests/sp23/Makefile.am (modified) * testsuites/ada/sptests/sp24/Makefile.am (modified) * testsuites/ada/sptests/sp25/Makefile.am (modified) * testsuites/ada/sptests/spatcb01/Makefile.am (modified) * testsuites/ada/sptests/spname01/Makefile.am (modified) * testsuites/ada/support/Makefile.am (modified) * testsuites/ada/tmtests/Makefile.am (modified) * testsuites/ada/tmtests/tm01/Makefile.am (modified) * testsuites/ada/tmtests/tm02/Makefile.am (modified) * testsuites/ada/tmtests/tm03/Makefile.am (modified) * testsuites/ada/tmtests/tm04/Makefile.am (modified) * testsuites/ada/tmtests/tm05/Makefile.am (modified) * testsuites/ada/tmtests/tm06/Makefile.am (modified) * testsuites/ada/tmtests/tm07/Makefile.am (modified) * testsuites/ada/tmtests/tm08/Makefile.am (modified) * testsuites/ada/tmtests/tm09/Makefile.am (modified) * testsuites/ada/tmtests/tm10/Makefile.am (modified) * testsuites/ada/tmtests/tm11/Makefile.am (modified) * testsuites/ada/tmtests/tm12/Makefile.am (modified) * testsuites/ada/tmtests/tm13/Makefile.am (modified) * testsuites/ada/tmtests/tm14/Makefile.am (modified) * testsuites/ada/tmtests/tm15/Makefile.am (modified) * testsuites/ada/tmtests/tm16/Makefile.am (modified) * testsuites/ada/tmtests/tm17/Makefile.am (modified) * testsuites/ada/tmtests/tm18/Makefile.am (modified) * testsuites/ada/tmtests/tm19/Makefile.am (modified) * testsuites/ada/tmtests/tm20/Makefile.am (modified) * testsuites/ada/tmtests/tm21/Makefile.am (modified) * testsuites/ada/tmtests/tm22/Makefile.am (modified) * testsuites/ada/tmtests/tm23/Makefile.am (modified) * testsuites/ada/tmtests/tm24/Makefile.am (modified) * testsuites/ada/tmtests/tm25/Makefile.am (modified) * testsuites/ada/tmtests/tm28/Makefile.am (modified) * testsuites/ada/tmtests/tm29/Makefile.am (modified) * testsuites/ada/tmtests/tmck/Makefile.am (modified) * testsuites/ada/tmtests/tmoverhd/Makefile.am (modified) * testsuites/automake/local.am (deleted) * testsuites/benchmarks/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/mp01/Makefile.am (modified) * testsuites/mptests/mp03/Makefile.am (modified) * testsuites/mptests/mp04/Makefile.am (modified) * testsuites/mptests/mp05/Makefile.am (modified) * testsuites/mptests/mp06/Makefile.am (modified) * testsuites/mptests/mp07/Makefile.am (modified) * testsuites/mptests/mp08/Makefile.am (modified) * testsuites/mptests/mp09/Makefile.am (modified) * testsuites/mptests/mp10/Makefile.am (modified) * testsuites/mptests/mp11/Makefile.am (modified) * testsuites/mptests/mp12/Makefile.am (modified) * testsuites/mptests/mp13/Makefile.am (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/rhealstone/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) build: Remove local.am Fri, 21 Jul 2017 12:18:50 GMT Javier Jalle [6dc0b5f] * bsps/sparc/headers.am (modified) * bsps/sparc/include/bsp/spwtdp.h (added) * bsps/sparc/include/drvmgr/ambapp_bus.h (modified) * bsps/sparc/shared/spw/spwtdp.c (added) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) leon, spwtdp: Initial driver commit Tue, 11 Sep 2018 04:25:26 GMT Sebastian Huber [2d17e88] * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) bsps/mips: Remove unused command line defines Update #3375. Fri, 21 Sep 2018 05:38:23 GMT Sebastian Huber [69a24c3] * bsps/arm/imx/start/ccm.c (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: Add imx_ccm_sdhci_hz() Update #3525. Wed, 07 Feb 2018 11:35:33 GMT Jacob Hansen [5cbc9c5] * c/src/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/gcc-specs.m4 (added) * testsuites/aclocal/prog-cc.m4 (modified) clang: Keep -qrtems and -B for compilers without -specs support ... Mon, 17 Sep 2018 06:28:29 GMT Sebastian Huber [62cb39d7] * bsps/powerpc/tqm8xx/dev/clock.c (deleted) * bsps/powerpc/tqm8xx/dev/console-generic.c (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Remove unused files Close #3513. Wed, 12 Sep 2018 09:47:19 GMT Sebastian Huber [d22147e] * bsps/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Convert console to new Termios API Update #3513. Fri, 31 Aug 2018 05:44:53 GMT Sebastian Huber [fad3f79b] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/include/bsp.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/virtex/include/bsp.h (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN Remove the ... Wed, 29 Aug 2018 17:51:50 GMT Joel Sherrill [66e78854] * bsps/sparc64/shared/helenos/boot/generic/string.c (deleted) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) Remove bsps/sparc64/shared/helenos/boot/generic/string.c Mon, 13 Aug 2018 10:55:34 GMT Amaan Cheval [bc731313] * bsps/x86_64/amd64/clock/clock.c (added) * bsps/x86_64/amd64/headers.am (modified) * bsps/x86_64/amd64/include/apic.h (added) * bsps/x86_64/amd64/include/clock.h (added) * bsps/x86_64/amd64/include/pic.h (added) * bsps/x86_64/amd64/interrupts/pic.c (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add APIC timer based clock driver The APIC timer is ... Mon, 13 Aug 2018 10:50:38 GMT Amaan Cheval [6869321] * bsps/x86_64/amd64/interrupts/idt.c (added) * bsps/x86_64/amd64/interrupts/isr_handler.S (added) * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/headers.am (modified) * bsps/x86_64/include/bsp/irq.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/idt.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) bsps/x86_64: Add support for RTEMS interrupts Updates #2898. Mon, 13 Aug 2018 10:33:12 GMT Amaan Cheval [4544749e] * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/amd64/start/page.c (added) * bsps/x86_64/headers.am (added) * bsps/x86_64/include/libcpu/page.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add paging support with 1GiB super pages Updates #2898. Thu, 09 Aug 2018 07:20:33 GMT Sebastian Huber [f4424cfb] * bsps/sparc/include/bsp/apbuart.h (modified) * bsps/sparc/include/bsp/apbuart_termios.h (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (added) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move polled APBUART functions This reduces the ... Fri, 03 Aug 2018 12:03:39 GMT Sebastian Huber [32ccc01] * bsps/shared/irq-sources.am (modified) * bsps/shared/irq/irq-generic.c (modified) * bsps/shared/irq/irq-lock.c (added) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) bsps: Fix the generic IRQ support The genmcf548x partly uses is own ... Tue, 24 Jul 2018 08:10:12 GMT Sebastian Huber [6552ba8] * bsps/riscv/riscv/btimer/btimer.c (deleted) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Use CPU counter btimer Update #3433. Fri, 20 Jul 2018 11:11:04 GMT Sebastian Huber [447fd89] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspsmp.c (added) * bsps/riscv/riscv/start/bspstart.c (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Add basic SMP startup Update #3433. Thu, 19 Jul 2018 13:12:11 GMT Sebastian Huber [f5fd8eb] * bsps/riscv/include/bsp/linker-symbols.h (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsps/riscv: Update linker-symbols.h Update #3433. Thu, 19 Jul 2018 12:06:10 GMT Sebastian Huber [791d9ac5] * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Disable HTIF support by default The HTIF is a legacy ... Thu, 19 Jul 2018 10:11:19 GMT Sebastian Huber [8db3f0e] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/include/bsp/linker-symbols.h (modified) * bsps/riscv/riscv/btimer/btimer.c (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspstart.c (moved) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Rework exception handling Remove ... Mon, 09 Jul 2018 11:12:57 GMT Amaan Cheval [cf811a4] * bsps/x86_64/amd64/console/console.c (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) x86_64/console: Add NS16550 polled console driver This addition ... Mon, 09 Jul 2018 11:12:56 GMT Amaan Cheval [76c03152] * bsps/x86_64/amd64/config/amd64.cfg (added) * bsps/x86_64/amd64/console/console.c (added) * bsps/x86_64/amd64/headers.am (added) * bsps/x86_64/amd64/include/bsp.h (added) * bsps/x86_64/amd64/include/start.h (added) * bsps/x86_64/amd64/include/tm27.h (added) * bsps/x86_64/amd64/start/bsp_specs (added) * bsps/x86_64/amd64/start/bspstart.c (added) * bsps/x86_64/amd64/start/linkcmds (added) * bsps/x86_64/amd64/start/start.c (added) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/x86_64/Makefile.am (added) * c/src/lib/libbsp/x86_64/acinclude.m4 (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (added) * c/src/lib/libbsp/x86_64/amd64/configure.ac (added) * c/src/lib/libbsp/x86_64/configure.ac (added) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/x86_64/Makefile.am (added) * cpukit/score/cpu/x86_64/cpu.c (added) * cpukit/score/cpu/x86_64/headers.am (added) * cpukit/score/cpu/x86_64/include/machine/elf_machdep.h (added) * cpukit/score/cpu/x86_64/include/rtems/asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (added) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (added) bsp/x86_64: Minimal bootable BSP Current state: - Basic context ... Fri, 06 Jul 2018 09:20:31 GMT Sebastian Huber [1a19239] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/console/console-config.c (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add console support for NS16550 devices Update #3433. Mon, 25 Jun 2018 06:44:16 GMT Sebastian Huber [1232cd46] * bsps/riscv/riscv/console/console-config.c (added) * bsps/riscv/riscv/console/htif.c (moved) * bsps/riscv/riscv/include/dev/serial/htif.h (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add device tree support for console Update #3433. Fri, 22 Jun 2018 06:01:48 GMT Sebastian Huber [fe2cd01b] * bsps/riscv/riscv/include/bsp.h (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add device tree support Update #3433. Fri, 11 May 2018 04:54:59 GMT Sebastian Huber [2086948a] * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * testsuites/smptests/smpfatal08/init.c (modified) riscv: Add dummy SMP support Update #3433. Fri, 11 May 2018 04:25:47 GMT Sebastian Huber [853c5ef] * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) build: Enable RISC-V SMP build Update #3433. Fri, 22 Jun 2018 05:51:08 GMT Sebastian Huber [16d905f] * bsps/riscv/riscv/start/linkcmds.in (moved) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add BSP options to define RAM region Update #3433. Fri, 22 Jun 2018 05:35:27 GMT Sebastian Huber [37a1fc2] * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Remove unused BSP options Update #3433. Fri, 22 Jun 2018 05:06:57 GMT Sebastian Huber [6f5d88a] * bsps/riscv/riscv/btimer/btimer.c (moved) * bsps/riscv/riscv/clock/clockdrv.c (moved) * bsps/riscv/riscv/config/rv32i.cfg (moved) * bsps/riscv/riscv/config/rv32iac.cfg (moved) * bsps/riscv/riscv/config/rv32im.cfg (moved) * bsps/riscv/riscv/config/rv32imac.cfg (moved) * bsps/riscv/riscv/config/rv32imafc.cfg (moved) * bsps/riscv/riscv/config/rv64imac.cfg (moved) * bsps/riscv/riscv/config/rv64imafdc.cfg (moved) * bsps/riscv/riscv/console/console-io.c (moved) * bsps/riscv/riscv/headers.am (added) * bsps/riscv/riscv/include/bsp.h (moved) * bsps/riscv/riscv/include/bsp/irq.h (moved) * bsps/riscv/riscv/include/tm27.h (moved) * bsps/riscv/riscv/irq/irq.c (moved) * bsps/riscv/riscv/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv/start/bsp_specs (moved) * bsps/riscv/riscv/start/linkcmds (moved) * bsps/riscv/riscv/start/linkcmds.base (moved) * bsps/riscv/riscv/start/start.S (moved) * bsps/riscv/riscv_generic/headers.am (deleted) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (moved) * c/src/lib/libbsp/riscv/riscv/configure.ac (moved) bsp/riscv_generic: Rename to "riscv" Update #3433. Tue, 29 May 2018 07:14:24 GMT Sebastian Huber [9e3bb45] * bsps/riscv/riscv_generic/console/console-io.c (modified) * bsps/riscv/riscv_generic/start/linkcmds (modified) * bsps/riscv/riscv_generic/start/linkcmds.base (added) * bsps/riscv/riscv_generic/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) bsp/riscv_generic: New linker command file This linker command file ... Tue, 19 Jun 2018 07:09:51 GMT Sebastian Huber [511dc4b] * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (deleted) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (deleted) * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/imx/start/linkcmds.imx7 (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/raspberrypi/start/bspsmp.c (modified) * bsps/arm/raspberrypi/start/linkcmds (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (deleted) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (deleted) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/malta/start/start.S (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/mips/shared/irq/exception.S (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/include/bsp.h (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/include/bsp.h (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/include/bsp.h (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv_generic/start/start.S (modified) * bsps/sh/gensh1/include/bsp.h (modified) * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/include/bsp.h (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/include/bsp.h (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shared/start/bspstart.c (modified) * bsps/sh/shsim/include/bsp.h (modified) * bsps/sh/shsim/start/cpu_asm.c (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpuasm.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spsize/size.c (modified) Rework initialization and interrupt stack support Statically ... Tue, 22 May 2018 06:52:13 GMT Sebastian Huber [762fa62] * bsps/arm/include/bsp/clock-armv7m.h (added) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) arm: Simplify CPU counter support Use the standard ARMv7-M systick ... Wed, 23 May 2018 12:17:25 GMT Sebastian Huber [65f868c] * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * bsps/arm/include/bsp/arm-a9mpcore-clock.h (modified) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/lpc24xx/start/system-clocks.c (modified) * bsps/arm/lpc32xx/start/bspstart.c (modified) * bsps/arm/realview-pbx-a9/start/bspstart.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * bsps/arm/tms570/cpucounter/cpucounterread.c (modified) * bsps/arm/xilinx-zynq/start/bspstart.c (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/shared/dev/cpucounter/cpucounterfrequency.c (added) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (added) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) Add _CPU_Counter_frequency() Add rtems_counter_frequency() API ... Fri, 15 Jun 2018 06:18:26 GMT Sebastian Huber [bac8d934] * Makefile.am (modified) * c/src/make/README (modified) * c/src/make/host.cfg.in (modified) * configure.ac (modified) * tools/build/Makefile.am (deleted) * tools/build/README (deleted) * tools/build/config.h.in (deleted) * tools/build/configure.ac (deleted) * tools/build/install-if-change.in (deleted) tools: Remove install-if-change program The last installed tool in ... Fri, 15 Jun 2018 06:05:27 GMT Sebastian Huber [6fb0223] * c/src/make/configure.ac (modified) make: Remove obsolete AC_SUBST() Fri, 15 Jun 2018 05:53:42 GMT Sebastian Huber [5ff9547a] * c/src/make/README (modified) make: Remove CFLAGS_DEBUG_OPTIMIZE_V Do not document ...
