# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 06/02/24 13:57:43 Tue, 15 Oct 1996 21:39:15 GMT Joel Sherrill [6c58b6f] * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) updated to format of 3.6.0 console drivers Tue, 15 Oct 1996 21:39:06 GMT Joel Sherrill [39cafa5] * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) updated to format of 3.6.0 clock drivers Tue, 15 Oct 1996 21:38:43 GMT Joel Sherrill [27f0d424] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) added support for cpu time used field in tcb Tue, 15 Oct 1996 21:38:33 GMT Joel Sherrill [f8c6333] * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) added cpu time used field to tcb Tue, 15 Oct 1996 21:01:55 GMT Joel Sherrill [60e2964] * c/src/lib/libbsp/i386/i386ex/README (added) new file Tue, 15 Oct 1996 21:00:41 GMT Joel Sherrill [d1dbcab9] * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) reference to Force CPU-386 removed. added standard comments about ... Tue, 15 Oct 1996 20:57:04 GMT Joel Sherrill [752cd8f] * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (added) * c/src/lib/libbsp/i386/i386ex/console/console.c (added) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (added) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (added) * c/src/lib/libbsp/i386/i386ex/startup/README (added) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (added) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (added) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (added) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (added) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (added) initial version from Erik Mon, 14 Oct 1996 19:17:37 GMT Joel Sherrill [2d0383b] * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) patches to erc32.h to correct handling of timer mirror from Jiri Gaisler. Tue, 01 Oct 1996 17:36:57 GMT Joel Sherrill [355c262c] * c/src/exec/score/cpu/i386/i386.h (modified) i386_nofp cpu model entry incorrectly had floating point enabled. Mon, 30 Sep 1996 20:16:05 GMT Joel Sherrill [93bea77] * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) changed INLINE to inline since INLINE is no longer defined by RTEMS Mon, 30 Sep 1996 20:15:01 GMT Joel Sherrill [855edec] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. Mon, 30 Sep 1996 20:14:27 GMT Joel Sherrill [8880e9c7] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version string to 3.6.0 Mon, 30 Sep 1996 20:14:08 GMT Joel Sherrill [348ba42] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) changed stack size of posix initialization threads to double the ... Fri, 27 Sep 1996 15:49:44 GMT Joel Sherrill [caf87fd7] * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) data and control addresses were swapped for channel a of the scc Wed, 18 Sep 1996 22:23:15 GMT Joel Sherrill [1f4f392a] * c/src/tests/psxtests/psx04/task1.c (added) * c/src/tests/psxtests/psx04/task2.c (added) * c/src/tests/psxtests/psx04/task3.c (added) * testsuites/psxtests/psx04/task1.c (added) * testsuites/psxtests/psx04/task2.c (added) * testsuites/psxtests/psx04/task3.c (added) new files Wed, 18 Sep 1996 21:13:10 GMT Joel Sherrill [0836603] * c/src/lib/libbsp/a29k/portsw/README (added) * c/src/lib/libbsp/a29k/portsw/console/concntl.h (added) * c/src/lib/libbsp/a29k/portsw/console/console.c (added) * c/src/lib/libbsp/a29k/portsw/console/serial.c (added) * c/src/lib/libbsp/a29k/portsw/console/serial.h (added) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (added) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (added) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (added) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (added) * c/src/lib/libbsp/a29k/portsw/startup/iface.c (added) * c/src/lib/libbsp/a29k/portsw/startup/main.c (added) * c/src/lib/libbsp/a29k/portsw/startup/ramlink (added) * c/src/lib/libbsp/a29k/portsw/startup/romlink (added) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (added) * c/src/lib/libbsp/a29k/portsw/times (added) new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Wed, 18 Sep 1996 21:07:37 GMT Joel Sherrill [7abd27b] * c/src/tests/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task1.c (modified) added cast Wed, 18 Sep 1996 21:07:14 GMT Joel Sherrill [c3e3d07] * c/src/tests/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/blow.c (modified) address arithmetic changed to be more portable Wed, 18 Sep 1996 21:06:49 GMT Joel Sherrill [4a5e651] * c/src/tests/libtests/malloctest/init.c (added) * c/src/tests/libtests/malloctest/system.h (added) * c/src/tests/libtests/malloctest/task1.c (added) * testsuites/libtests/malloctest/init.c (added) * testsuites/libtests/malloctest/system.h (added) * testsuites/libtests/malloctest/task1.c (added) new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Wed, 18 Sep 1996 20:56:35 GMT Joel Sherrill [d6b2bba] * c/src/lib/libbsp/a29k/portsw/start/amd.ah (added) * c/src/lib/libbsp/a29k/portsw/start/pswmacro.ah (added) * c/src/lib/libbsp/a29k/portsw/start/register.ah (added) * c/src/lib/start/a29k/amd.ah (added) * c/src/lib/start/a29k/crt0.s (added) * c/src/lib/start/a29k/pswmacro.ah (added) * c/src/lib/start/a29k/register.ah (added) * c/src/lib/start/a29k/register.s (added) new files submitted by Craig Lebakken (lebakken@minn.net) and ... Wed, 18 Sep 1996 20:55:53 GMT Joel Sherrill [5697c28] * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/check.c (modified) pointer arithmetic reworked to be more portable Wed, 18 Sep 1996 20:55:13 GMT Joel Sherrill [be95da0] * c/src/lib/libmisc/monitor/mon-driver.c (modified) * c/src/lib/libmisc/monitor/mon-extension.c (modified) * c/src/lib/libmisc/monitor/mon-itask.c (modified) * c/src/lib/libmisc/monitor/mon-manager.c (modified) * c/src/lib/libmisc/monitor/mon-monitor.c (modified) * c/src/lib/libmisc/monitor/mon-mpci.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-server.c (modified) * c/src/lib/libmisc/monitor/mon-task.c (modified) * c/src/lib/libmisc/monitor/monitor.h (modified) * c/src/libmisc/monitor/mon-driver.c (modified) * c/src/libmisc/monitor/mon-extension.c (modified) * c/src/libmisc/monitor/mon-itask.c (modified) * c/src/libmisc/monitor/mon-manager.c (modified) * c/src/libmisc/monitor/mon-monitor.c (modified) * c/src/libmisc/monitor/mon-mpci.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/monitor/mon-task.c (modified) * c/src/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-manager.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) casts added to numerous arguments, prototypes corrected, and proper ... Wed, 18 Sep 1996 20:54:05 GMT Joel Sherrill [0c35efe] * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/libcsupport/src/unixlibc.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/unixlibc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libcsupport/src/unixlibc.c (modified) dummy function added to satisfy ANSI Wed, 18 Sep 1996 20:53:35 GMT Joel Sherrill [5e9a594] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) modified to support non-GNU compilers and to use calloc rather than ... Wed, 18 Sep 1996 20:52:47 GMT Joel Sherrill [1f2d5df] * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/lib/libc/malloc.c (modified) * cpukit/libcsupport/src/malloc.c (modified) added malloc_walk miscellaneous corrections in casting. Wed, 18 Sep 1996 20:52:16 GMT Joel Sherrill [b1c215e] * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/libc/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) added prototype for malloc_walk Wed, 18 Sep 1996 20:51:48 GMT Joel Sherrill [94218b8] * c/src/exec/score/src/wkspace.c (modified) * cpukit/score/src/wkspace.c (modified) loop to clear workspace memory changed to use sizeof rather than ... Wed, 18 Sep 1996 20:50:58 GMT Joel Sherrill [56e0b88] * c/src/exec/score/src/object.c (modified) * cpukit/score/src/object.c (modified) corrected prototype of _Objects_Get_next Wed, 18 Sep 1996 20:50:27 GMT Joel Sherrill [3861130] * c/src/exec/score/src/heap.c (modified) * cpukit/score/src/heap.c (modified) uses address object rather than direct pointer arithmetic Wed, 18 Sep 1996 20:50:04 GMT Joel Sherrill [4944b5bf] * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/object.h (modified) OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than ... Wed, 18 Sep 1996 20:49:36 GMT Joel Sherrill [857c52f] * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof ... Wed, 18 Sep 1996 20:48:56 GMT Joel Sherrill [533f89f] * c/src/exec/score/headers/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) modified declaration of CORE_message_queue_Buffer_control to avoid ... Wed, 18 Sep 1996 20:47:39 GMT Joel Sherrill [2069773] * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) use address object to avoid direct pointer arithmetic Wed, 18 Sep 1996 20:47:31 GMT Joel Sherrill [d1193c7] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) corrected white space problems added CPU_STRUCTURE_ALIGNMENT to ... Wed, 18 Sep 1996 20:45:27 GMT Joel Sherrill [a4d97d94] * c/src/exec/score/cpu/a29k/a29k.h (added) * c/src/exec/score/cpu/a29k/a29ktypes.h (added) * c/src/exec/score/cpu/a29k/amd.ah (added) * c/src/exec/score/cpu/a29k/asm.h (added) * c/src/exec/score/cpu/a29k/cpu.c (added) * c/src/exec/score/cpu/a29k/cpu.h (added) * c/src/exec/score/cpu/a29k/cpu_asm.h (added) * c/src/exec/score/cpu/a29k/cpu_asm.s (added) * c/src/exec/score/cpu/a29k/pswmacro.ah (added) * c/src/exec/score/cpu/a29k/rtems.c (added) * cpukit/score/cpu/a29k/amd.ah (added) * cpukit/score/cpu/a29k/asm.h (added) * cpukit/score/cpu/a29k/cpu.c (added) * cpukit/score/cpu/a29k/pswmacro.ah (added) new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Wed, 18 Sep 1996 14:17:54 GMT Joel Sherrill [afe99c2] * c/src/lib/libbsp/m68k/mvme147s/README (added) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (added) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme147s/times (added) new file submitted by Dominique le Campion. Tue, 17 Sep 1996 21:38:59 GMT Joel Sherrill [cc51de91] * c/src/tests/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/system.h (modified) extended Task_id and Task_name arrays to avoid indexing past end of ... Tue, 17 Sep 1996 21:33:07 GMT Joel Sherrill [1d9d044] * c/src/exec/score/src/coremutex.c (modified) * cpukit/score/src/coremutex.c (modified) Reversed logic in conditional to correctly distinguish between FIFO ... Tue, 17 Sep 1996 21:31:30 GMT Joel Sherrill [41be2e8] * c/src/exec/posix/src/time.c (modified) * cpukit/posix/src/time.c (modified) added routine _POSIX_Timespec_subtract Tue, 17 Sep 1996 21:31:10 GMT Joel Sherrill [aa48536] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) Added code to insure that the post switch extension was executed and ... Tue, 17 Sep 1996 21:29:51 GMT Joel Sherrill [9093c3c] * c/src/exec/posix/src/cond.c (modified) * cpukit/posix/src/cond.c (modified) Corrected implementation of timed wait on condition variables. First ... Tue, 17 Sep 1996 21:26:25 GMT Joel Sherrill [ded66f8] * c/src/exec/posix/headers/time.h (modified) * c/src/exec/posix/include/rtems/posix/time.h (modified) * cpukit/posix/include/rtems/posix/time.h (modified) added prototype for _POSIX_Timespec_subtract Thu, 12 Sep 1996 20:41:27 GMT Mark Johannes [09093ee] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Fixed test to match change to pthread_cond_timedwait which now takes ... Wed, 11 Sep 1996 19:16:07 GMT Joel Sherrill [cda277f] * c/src/exec/score/cpu/mips/asm.h (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/idtcpu.h (modified) * c/src/exec/score/cpu/mips/idtmon.h (modified) * c/src/exec/score/cpu/mips/iregdef.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/asm.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/idtcpu.h (modified) * c/src/exec/score/cpu/mips64orion/idtmon.h (modified) * c/src/exec/score/cpu/mips64orion/iregdef.h (modified) * c/src/exec/score/cpu/mips64orion/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * cpukit/score/cpu/mips/asm.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/asm.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips64orion/asm.h (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/mips64orion/idtcpu.h (modified) * cpukit/score/cpu/mips64orion/idtmon.h (modified) * cpukit/score/cpu/mips64orion/iregdef.h (modified) added $Id$ to file headers cpu.h: added prototype for ... Wed, 11 Sep 1996 19:15:09 GMT Joel Sherrill [0971cd5] * c/src/lib/libbsp/mips/p4000/start/start.S (modified) * c/src/lib/libbsp/mips64orion/p4000/start/start.S (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/clock/clock.S (modified) * c/src/lib/libcpu/mips/clock/clock.h (modified) * c/src/lib/libcpu/mips/timer/gettime.S (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/clock/clock.S (modified) * c/src/lib/libcpu/mips64orion/clock/clock.h (modified) * c/src/lib/libcpu/mips64orion/timer/gettime.S (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/start/mips64orion/idt_csu.S (modified) added $ string to file header Wed, 11 Sep 1996 19:13:44 GMT Joel Sherrill [5bb00a8] * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/console/led.S (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/linkcmds (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/led.S (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/linkcmds (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) added $Id$ string to file header Wed, 11 Sep 1996 19:12:43 GMT Joel Sherrill [9c0d032] * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (added) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (added) * c/src/lib/libbsp/mips64orion/p4000/startup/idttlb.S (added) * c/src/lib/libbsp/mips64orion/p4000/startup/inittlb.c (added) new files Sun, 08 Sep 1996 16:24:43 GMT Joel Sherrill [b944007b] * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) added definition of EXT_INT5 Sun, 08 Sep 1996 16:24:13 GMT Joel Sherrill [3d07c8b] * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/libchip/shmdr/shm_driver.h (modified) added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE Sun, 08 Sep 1996 16:23:35 GMT Joel Sherrill [bdef2d8] * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) idtmem.S: changed reference to include files to correct location ... Sun, 08 Sep 1996 16:22:29 GMT Joel Sherrill [eaa34e7] * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (modified) changed reference to include files to correct location Sun, 08 Sep 1996 16:22:05 GMT Joel Sherrill [3335420] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it ... Sun, 08 Sep 1996 16:21:48 GMT Joel Sherrill [e7a36a9] * c/src/exec/posix/src/adasupp.c (modified) * cpukit/posix/src/adasupp.c (modified) Ada task stack size minimize is twice that for regular pthreads. Sun, 08 Sep 1996 16:21:16 GMT Joel Sherrill [ed5a518] * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would ... Fri, 06 Sep 1996 19:57:21 GMT Joel Sherrill [8445e57] * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) removed need for exceptbdr.h file Fri, 06 Sep 1996 18:11:41 GMT Joel Sherrill [f198c63] * c/src/exec/score/cpu/mips/asm.h (added) * c/src/exec/score/cpu/mips/cpu.c (added) * c/src/exec/score/cpu/mips/cpu_asm.S (added) * c/src/exec/score/cpu/mips/cpu_asm.h (added) * c/src/exec/score/cpu/mips/idtcpu.h (added) * c/src/exec/score/cpu/mips/idtmon.h (added) * c/src/exec/score/cpu/mips/iregdef.h (added) * c/src/exec/score/cpu/mips/rtems.c (added) * c/src/exec/score/cpu/mips64orion/asm.h (added) * c/src/exec/score/cpu/mips64orion/cpu.c (added) * c/src/exec/score/cpu/mips64orion/cpu.h (added) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (added) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (added) * c/src/exec/score/cpu/mips64orion/idtcpu.h (added) * c/src/exec/score/cpu/mips64orion/idtmon.h (added) * c/src/exec/score/cpu/mips64orion/iregdef.h (added) * c/src/exec/score/cpu/mips64orion/mips64orion.h (added) * c/src/exec/score/cpu/mips64orion/mipstypes.h (added) * c/src/exec/score/cpu/mips64orion/rtems.c (added) * c/src/lib/libbsp/mips/p4000/README (added) * c/src/lib/libbsp/mips/p4000/console/console.c (added) * c/src/lib/libbsp/mips/p4000/console/led.S (added) * c/src/lib/libbsp/mips/p4000/include/bsp.h (added) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (added) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips/p4000/start/start.S (added) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (added) * c/src/lib/libbsp/mips/p4000/startup/ghlinkcmds (added) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (added) * c/src/lib/libbsp/mips/p4000/startup/linkcmds (added) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (added) * c/src/lib/libbsp/mips/p4000/times (added) * c/src/lib/libbsp/mips64orion/p4000/README (added) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (added) * c/src/lib/libbsp/mips64orion/p4000/console/led.S (added) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (added) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips64orion/p4000/start/start.S (added) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (added) * c/src/lib/libbsp/mips64orion/p4000/startup/ghlinkcmds (added) * c/src/lib/libbsp/mips64orion/p4000/startup/idtmem.S (added) * c/src/lib/libbsp/mips64orion/p4000/startup/linkcmds (added) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (added) * c/src/lib/libbsp/mips64orion/p4000/times (added) * c/src/lib/libcpu/mips/clock/ckinit.c (added) * c/src/lib/libcpu/mips/clock/clock.S (added) * c/src/lib/libcpu/mips/clock/clock.h (added) * c/src/lib/libcpu/mips/timer/gettime.S (added) * c/src/lib/libcpu/mips/timer/timer.c (added) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (added) * c/src/lib/libcpu/mips64orion/clock/clock.S (added) * c/src/lib/libcpu/mips64orion/clock/clock.h (added) * c/src/lib/libcpu/mips64orion/timer/gettime.S (added) * c/src/lib/libcpu/mips64orion/timer/timer.c (added) * c/src/lib/start/mips64orion/idt_csu.S (added) * cpukit/score/cpu/mips/asm.h (added) * cpukit/score/cpu/mips/cpu.c (added) * cpukit/score/cpu/mips/cpu_asm.S (added) * cpukit/score/cpu/mips/idtcpu.h (added) * cpukit/score/cpu/mips/iregdef.h (added) * cpukit/score/cpu/mips/rtems/asm.h (added) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (added) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (added) * cpukit/score/cpu/mips64orion/asm.h (added) * cpukit/score/cpu/mips64orion/cpu.c (added) * cpukit/score/cpu/mips64orion/cpu_asm.S (added) * cpukit/score/cpu/mips64orion/cpu_asm.h (added) * cpukit/score/cpu/mips64orion/idtcpu.h (added) * cpukit/score/cpu/mips64orion/idtmon.h (added) * cpukit/score/cpu/mips64orion/iregdef.h (added) new file for MIPS port by Craig Lebakken (lebakken@minn.net) and ... Fri, 06 Sep 1996 15:17:39 GMT Joel Sherrill [2ffcc2ed] * c/src/tests/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/init.c (modified) modified test to take into account change in default value of ... Fri, 06 Sep 1996 15:16:19 GMT Joel Sherrill [7fea679b] * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/tod.inl (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/tod.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/src/coretod.c (modified) changed _TOD_Is_set from a function to a boolean variable Thu, 05 Sep 1996 20:45:05 GMT Joel Sherrill [65c421f] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) default thread attributes: default value for inheritsched changed ... Thu, 05 Sep 1996 20:41:10 GMT Joel Sherrill [297be5c] * c/src/exec/posix/src/mutex.c (modified) * cpukit/posix/src/mutex.c (modified) pthread_mutex_setprioceiling: fixed bug where returned priority was ... Thu, 05 Sep 1996 20:31:32 GMT Joel Sherrill [7e230f10] * c/src/tests/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task2.c (modified) added printf of status when not successful Thu, 05 Sep 1996 20:29:07 GMT Joel Sherrill [9a5cbef0] * c/src/exec/posix/src/time.c (modified) * cpukit/posix/src/time.c (modified) nanosleep: negative value for tv_sec is no longer an error. It now ... Thu, 05 Sep 1996 20:03:19 GMT Joel Sherrill [f254b93f] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) nanosleep no longer consider a negative value of tv_sec to be an ... Thu, 29 Aug 1996 16:39:01 GMT Joel Sherrill [62bf651f] * c/src/exec/posix/src/adasupp.c (added) * cpukit/posix/src/adasupp.c (added) new file to support GNU Ada. currently the only routine in this ... Tue, 27 Aug 1996 15:19:51 GMT Joel Sherrill [b5c04b6] * c/src/exec/posix/src/sched.c (modified) * cpukit/posix/src/sched.c (modified) fixed typo .. changed == to != Tue, 27 Aug 1996 15:19:33 GMT Joel Sherrill [5a234809] * c/src/exec/posix/src/cond.c (modified) * cpukit/posix/src/cond.c (modified) check that we were passed a valid mutex and ignore errors from the ... Fri, 23 Aug 1996 15:58:24 GMT Mark Johannes [e4cc4176] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Changed all EFAULTS to EINVALs Fri, 23 Aug 1996 15:56:50 GMT Mark Johannes [3adf786] * c/src/tests/psxtests/psx12/psx12.scn (modified) * testsuites/psxtests/psx12/psx12.scn (modified) filled in screen Fri, 23 Aug 1996 15:56:22 GMT Mark Johannes [237088c] * c/src/tests/psxtests/psx10/psx10.scn (added) * c/src/tests/psxtests/psx11/psx11.scn (modified) * testsuites/psxtests/psx10/psx10.scn (added) * testsuites/psxtests/psx11/psx11.scn (modified) Filled in screen Fri, 23 Aug 1996 15:55:02 GMT Mark Johannes [78f5dae] * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx02/psx02.scn (modified) * c/src/tests/psxtests/psx03/psx03.scn (modified) * c/src/tests/psxtests/psx04/psx04.scn (modified) * c/src/tests/psxtests/psx05/psx05.scn (modified) * c/src/tests/psxtests/psx06/psx06.scn (modified) * c/src/tests/psxtests/psx07/psx07.scn (modified) * c/src/tests/psxtests/psx08/psx08.scn (modified) * c/src/tests/psxtests/psx09/psx09.scn (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx02/psx02.scn (modified) * testsuites/psxtests/psx03/psx03.scn (modified) * testsuites/psxtests/psx04/psx04.scn (modified) * testsuites/psxtests/psx05/psx05.scn (modified) * testsuites/psxtests/psx06/psx06.scn (modified) * testsuites/psxtests/psx07/psx07.scn (modified) * testsuites/psxtests/psx08/psx08.scn (modified) * testsuites/psxtests/psx09/psx09.scn (modified) Filled in the screen Fri, 23 Aug 1996 15:50:53 GMT Mark Johannes [e2ceeca7] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) Added build_time statement to provide a tm for the test Fri, 23 Aug 1996 15:17:16 GMT Mark Johannes [257adba] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Changed test 5 to test 10 at bottom Fri, 23 Aug 1996 14:47:58 GMT Mark Johannes [0b710dbb] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) pthread_create: changed EINVAL for no more threads back to EAGAIN Thu, 22 Aug 1996 20:18:44 GMT Mark Johannes [df70c6b] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Commented out the EINVAL for mutex not acquired befor cond_wait call Wed, 21 Aug 1996 15:49:21 GMT Mark Johannes [6702bffc] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) updated to support ENOTSUP Tue, 20 Aug 1996 21:41:08 GMT Mark Johannes [256a462] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) Added Einval case for mutex not initialized Mon, 19 Aug 1996 15:30:25 GMT Mark Johannes [c5c5f8c] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) Changed all EFAULTs to EINVALs Mon, 19 Aug 1996 15:27:37 GMT Mark Johannes [02f041e] * c/src/exec/posix/src/mutex.c (modified) * cpukit/posix/src/mutex.c (modified) pthread_mutex_init: added error messages for NULL mutex and EBUSY Thu, 15 Aug 1996 21:09:02 GMT Joel Sherrill [cd3868cd] * c/src/exec/score/cpu/hppa1.1/cpu.c (modified) * c/src/exec/score/cpu/hppa1.1/hppa.h (modified) * cpukit/score/cpu/hppa1.1/cpu.c (modified) updates from Tony Bennett (tbennett@divnc.com) Thu, 15 Aug 1996 21:05:21 GMT Joel Sherrill [0600e86f] * c/src/exec/score/src/thread.c (modified) * cpukit/score/src/thread.c (modified) _Thread_Start_multitasking: added code to initialize the floating ... Thu, 15 Aug 1996 19:38:46 GMT Mark Johannes [9ac3e76] * c/src/exec/posix/src/mutex.c (modified) * cpukit/posix/src/mutex.c (modified) changed ENOMEM error message Thu, 15 Aug 1996 19:27:08 GMT Mark Johannes [7fb19bb] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) init: added tests for pthread_kill and kill errors. Thu, 15 Aug 1996 18:59:34 GMT Joel Sherrill [851b18d] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) changed error code Thu, 15 Aug 1996 18:59:00 GMT Joel Sherrill [fdf6917] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) changed error for too many threads to EAGAIN Thu, 15 Aug 1996 18:58:09 GMT Joel Sherrill [f3e19146] * c/src/exec/posix/src/time.c (modified) * cpukit/posix/src/time.c (modified) clock_gettime: changed assert condition to a standard error code ... Thu, 15 Aug 1996 18:57:07 GMT Joel Sherrill [b03ab630] * c/src/exec/posix/src/sched.c (modified) * cpukit/posix/src/sched.c (modified) sched_rr_get_interval: converted assert condition into a standard ... Thu, 15 Aug 1996 18:56:09 GMT Joel Sherrill [57dae56] * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) added constant to indicate there is no mutex associated with this ... Thu, 15 Aug 1996 16:29:00 GMT Mark Johannes [de45ddc] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO Thu, 15 Aug 1996 16:24:44 GMT Mark Johannes [948721c] * c/src/exec/posix/src/psignal.c (modified) * cpukit/posix/src/psignal.c (modified) pthread_kill: moved check for SA_SIGINFO to allow for validation of ... Thu, 15 Aug 1996 16:22:59 GMT Mark Johannes [48e685c] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) fixed typo for NOTSUP -> ENOTSUP Wed, 14 Aug 1996 20:25:57 GMT Joel Sherrill [fb7d080] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) pthread_mutex_init returns EAGAIN not ENOMEM when there are too many ... Wed, 14 Aug 1996 19:41:47 GMT Joel Sherrill [ac81b6ca] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added test cases for NULL being passed to pthread attribute get routines Wed, 14 Aug 1996 19:30:49 GMT Joel Sherrill [ff53a6d4] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added test case for pthread_attr_getscope being passed a NULL ... Wed, 14 Aug 1996 17:20:45 GMT Mark Johannes [4e63ae5] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) commented of ENOTSUP until fixed in newlib Wed, 14 Aug 1996 17:20:03 GMT Mark Johannes [aae1c932] * c/src/exec/posix/src/cond.c (modified) * cpukit/posix/src/cond.c (modified) pthread_cond_timedwait: added error cases for abstime Wed, 14 Aug 1996 17:19:03 GMT Mark Johannes [87c8fd09] * c/src/tests/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/system.h (modified) system.h: added task3 and changed condition variable config to 1 Wed, 14 Aug 1996 17:18:02 GMT Mark Johannes [b0c483ed] * c/src/tests/psxtests/psx10/task3.c (added) * testsuites/psxtests/psx10/task3.c (added) task3: added to test error case in Wait_support for lock on mutex Wed, 14 Aug 1996 17:16:14 GMT Mark Johannes [520949bf] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) init: added error case for wait timedwait, and wait support Wed, 14 Aug 1996 15:27:14 GMT Joel Sherrill [645fc954] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope Tue, 13 Aug 1996 21:32:49 GMT Mark Johannes [dce801d] * c/src/exec/posix/src/cond.c (modified) * cpukit/posix/src/cond.c (modified) pthread_cond_destroy: added enable dispatch to EBUSY case
