# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 07:46:46 Thu, 18 Sep 1997 16:01:52 GMT Joel Sherrill [6b4ca31] * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) Merged changes from Eric Norum: Enable 68360 watchdog. The ... Tue, 16 Sep 1997 13:08:58 GMT Joel Sherrill [a72e3dd] * c/src/lib/libmisc/README (modified) * c/src/libmisc/README (modified) * cpukit/libmisc/README (modified) updated Mon, 15 Sep 1997 19:01:33 GMT Joel Sherrill [fc4675f0] * c/src/lib/include/Makefile.in (modified) syslog added Mon, 15 Sep 1997 18:52:26 GMT Joel Sherrill [8f35817] * c/src/lib/libbsp/a29k/portsw/console/console.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/go32/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/efi332/console/console.c (modified) * c/src/lib/libbsp/m68k/efi68k/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) eliminated potential for overfilling buffer on read Wed, 03 Sep 1997 22:05:51 GMT Joel Sherrill [8d05346] * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) Fix from Eric Norum. Here is the comment: Enable SDMA ... Thu, 28 Aug 1997 22:23:10 GMT Joel Sherrill [ad9250cf] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Fixed IO Manager calls to remove an argument which was used in 3.2.1 ... Thu, 28 Aug 1997 21:54:59 GMT Joel Sherrill [e9932367] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/go32/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Switched to new style which does not require hackspecs.awk. Thu, 28 Aug 1997 13:59:41 GMT Joel Sherrill [7d352a49] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) Added RTEMS_IO_ERROR status code. Thu, 28 Aug 1997 13:57:29 GMT Joel Sherrill [b47be20] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) Added IO_Error status code and fixed No_Memory error number. Wed, 27 Aug 1997 20:34:23 GMT Joel Sherrill [d1b60f0] * c/src/tests/samples/paranoia/Makefile.in (modified) Corrected reference to LIBC_LIBM to work on all targets. Wed, 27 Aug 1997 20:33:49 GMT Joel Sherrill [3473f605] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) Added error numbers and changed default error code from 0 to -1 for ... Wed, 27 Aug 1997 20:33:11 GMT Joel Sherrill [f80faeb] * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) Modified to support the BSP family concept. Wed, 27 Aug 1997 20:31:34 GMT Joel Sherrill [49c2f589] * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) Modified to have correct address for vector table on multiple models. Tue, 26 Aug 1997 19:24:22 GMT Joel Sherrill [2d60095] * c/src/tests/libtests/rtems++/Init.cc (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtems++/Task1.cc (modified) * c/src/tests/libtests/rtems++/Task2.cc (modified) * c/src/tests/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) Patches from Chris Johns to clean up test. Tue, 26 Aug 1997 19:19:21 GMT Joel Sherrill [588a2382] * c/src/tests/samples/paranoia/Makefile.in (modified) removed -lm Tue, 26 Aug 1997 18:10:59 GMT Joel Sherrill [12a17af3] * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) Corrected to compile with egcs. Fri, 22 Aug 1997 19:19:07 GMT Joel Sherrill [e63e254e] * c/src/exec/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) Corrected bug per Katsutoshi Shibuya's report: The definition ... Fri, 22 Aug 1997 19:17:54 GMT Joel Sherrill [b57992a] * c/src/lib/libmisc/rtmonuse/rtmonuse.c (modified) * c/src/libmisc/rtmonuse/rtmonuse.c (modified) * cpukit/libmisc/rtmonuse/rtmonuse.c (modified) Removed assert condition when not initialized or there are 0 periods. Fri, 22 Aug 1997 19:17:09 GMT Joel Sherrill [b1459dc] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libc/newlibif.c (modified) * c/src/lib/libc/newlibifr.c (added) * cpukit/libcsupport/src/newlibc.c (modified) Moved reentrant wrappers into their own file. Fri, 22 Aug 1997 19:16:47 GMT Joel Sherrill [78d87bd] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) Fixed iop/memory leak bug reported by Dan Dickey. Fri, 22 Aug 1997 19:16:22 GMT Joel Sherrill [8affd6f1] * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) Removed redundant stanza. Fri, 22 Aug 1997 19:11:02 GMT Joel Sherrill [9b1f5678] * c/src/exec/posix/src/mutex.c (modified) * cpukit/posix/src/mutex.c (modified) Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. Fri, 22 Aug 1997 19:10:44 GMT Joel Sherrill [799a5b9] * c/src/exec/posix/inline/cond.inl (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) Added commit about missing support for condition initializer. Fri, 22 Aug 1997 13:08:56 GMT Joel Sherrill [2d997375] * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) start no longer a global symbol per Eric Norum's request. Also, ... Mon, 04 Aug 1997 22:22:59 GMT Joel Sherrill [d074e12] * c/src/lib/libbsp/m68k/idp/console/duart.c (modified) Switched to new version of mc68681.h Mon, 04 Aug 1997 22:22:31 GMT Joel Sherrill [19fd334] * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) moved mc68230.h from main include directory to motorola Mon, 04 Aug 1997 22:17:17 GMT Joel Sherrill [0789abef] * c/src/exec/libcsupport/include/motorola/mc68681.h (modified) * c/src/lib/include/motorola/mc68681.h (modified) * cpukit/libcsupport/include/motorola/mc68681.h (modified) new implementation of mc68681.h Mon, 04 Aug 1997 22:12:39 GMT Joel Sherrill [89a32784] * c/src/lib/include/Makefile.in (modified) Fixed type Mon, 04 Aug 1997 22:03:03 GMT Joel Sherrill [3dd8372] * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/unix/posix/include/coverhd.h (modified) Corrected typo Mon, 04 Aug 1997 21:59:14 GMT Joel Sherrill [a397c9c1] * c/src/lib/libcpu/powerpc/Makefile.in (modified) Corrected descent to a hardcoded directory and made it dependent on ... Mon, 04 Aug 1997 21:58:30 GMT Joel Sherrill [8bc9051] * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) Fixed typo and removed duplicated code Mon, 04 Aug 1997 21:58:00 GMT Joel Sherrill [4ef9e99] * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/libchip/shmdr/shm_driver.h (modified) First attempt at values for PPC Mon, 04 Aug 1997 21:57:06 GMT Joel Sherrill [50b5f9d] * c/src/lib/libbsp/m68k/mvme162/README (modified) Trying to support all models Mon, 04 Aug 1997 21:56:48 GMT Joel Sherrill [c74169bd] * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) Trying to support all models. Mon, 04 Aug 1997 21:56:00 GMT Joel Sherrill [c9647b3] * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) consolex built for all models. Mon, 04 Aug 1997 21:55:30 GMT Joel Sherrill [81d96577] * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) moved header files into the motorola and zilog subdirectories Mon, 04 Aug 1997 21:53:42 GMT Joel Sherrill [669123e1] * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) Correcting difference between mvme162lx and mvme162. All versions ... Mon, 04 Aug 1997 21:50:35 GMT Joel Sherrill [02d0880] * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) moved header files into the motorola and zilog subdirectories Mon, 04 Aug 1997 21:49:47 GMT Joel Sherrill [033ec54] * c/src/lib/libbsp/m68k/idp/console/duart.c (modified) Modified to reflect changes in mc68681.h header file. Mon, 04 Aug 1997 21:45:27 GMT Joel Sherrill [b739617] * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) Header files moved into zilog subdirectory. Mon, 04 Aug 1997 21:44:05 GMT Joel Sherrill [9b024884] * c/src/lib/include/Makefile.in (modified) Moved files into the zilog and motorola subdirectories. Mon, 04 Aug 1997 21:43:36 GMT Joel Sherrill [b61e6e1] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * cpukit/sapi/include/confdefs.h (modified) Added GNAT configuration parameters. Mon, 04 Aug 1997 21:39:07 GMT Joel Sherrill [28a4b1d] * c/src/exec/libcsupport/include/motorola/mc68230.h (added) * c/src/exec/libcsupport/include/motorola/mc68681.h (added) * c/src/exec/libcsupport/include/zilog/z8036.h (added) * c/src/exec/libcsupport/include/zilog/z8530.h (added) * c/src/exec/libcsupport/include/zilog/z8536.h (added) * c/src/lib/include/motorola/mc68230.h (added) * c/src/lib/include/motorola/mc68681.h (added) * c/src/lib/include/zilog/z8036.h (added) * c/src/lib/include/zilog/z8530.h (added) * c/src/lib/include/zilog/z8536.h (added) * cpukit/libcsupport/include/motorola/mc68230.h (added) * cpukit/libcsupport/include/motorola/mc68681.h (added) * cpukit/libcsupport/include/zilog/z8036.h (added) * cpukit/libcsupport/include/zilog/z8530.h (added) * cpukit/libcsupport/include/zilog/z8536.h (added) moved from main include directory Sat, 02 Aug 1997 17:55:09 GMT Joel Sherrill [b2fed481] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/attr.c (added) * c/src/exec/rtems/src/intrbody.c (added) * cpukit/rtems/src/attr.c (added) * cpukit/rtems/src/intrbody.c (added) Added these files to contain bodies for routines included in the API ... Fri, 01 Aug 1997 20:58:10 GMT Joel Sherrill [30e3029] * c/src/lib/Makefile.in (modified) Added conditional for KA9Q. Fri, 01 Aug 1997 20:57:21 GMT Joel Sherrill [1f581ec] * c/src/lib/libc/newlibif.c (modified) Added include of termios.h which was accidentally left out. Fri, 01 Aug 1997 20:56:36 GMT Joel Sherrill [bcbd75d4] * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) Added consolex to wrapup Fri, 01 Aug 1997 20:56:24 GMT Joel Sherrill [a7fcfd0] * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) Corrected typo. Fri, 01 Aug 1997 20:15:02 GMT Joel Sherrill [adf7b5c4] * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) Made to work. Fri, 01 Aug 1997 20:14:57 GMT Joel Sherrill [29a9e5d] * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) Removed warnings. Fri, 01 Aug 1997 18:12:11 GMT Joel Sherrill [9deb5b8b] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (added) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/sys/termios.h (added) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/README (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/consolex/README (added) * c/src/lib/libbsp/m68k/mvme162/consolex/cTest.c (added) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (added) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.h (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/newlibif.c (modified) * c/src/lib/libc/tcattr.c (added) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/termios.h (added) Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. ... Thu, 31 Jul 1997 22:13:29 GMT Joel Sherrill [0074691a] * c/ACKNOWLEDGEMENTS (modified) * c/src/lib/include/rtems++/rtemsEvent.h (added) * c/src/lib/include/rtems++/rtemsInterrupt.h (added) * c/src/lib/include/rtems++/rtemsMessageQueue.h (added) * c/src/lib/include/rtems++/rtemsSemaphore.h (added) * c/src/lib/include/rtems++/rtemsStatusCode.h (added) * c/src/lib/include/rtems++/rtemsTask.h (added) * c/src/lib/include/rtems++/rtemsTaskMode.h (added) * c/src/lib/include/rtems++/rtemsTimer.h (added) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/README (added) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (added) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/console/console.c (added) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/include/bare.h (added) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (added) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (added) * c/src/lib/libbsp/m68k/ods68302/include/crc.h (added) * c/src/lib/libbsp/m68k/ods68302/include/debugport.h (added) * c/src/lib/libbsp/m68k/ods68302/include/m68302scc.h (added) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/start/cpuboot.c (added) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (added) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (added) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/start302/cpuboot.c (added) * c/src/lib/libbsp/m68k/ods68302/start302/debugreset.S (added) * c/src/lib/libbsp/m68k/ods68302/start302/reset.S (added) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/crc.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/debugger (added) * c/src/lib/libbsp/m68k/ods68302/startup/debugport.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (added) * c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/rom (added) * c/src/lib/libbsp/m68k/ods68302/startup/trace.c (added) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (added) * c/src/lib/libbsp/m68k/ods68302/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (added) * c/src/lib/librtems++/Makefile.in (added) * c/src/lib/librtems++/README (added) * c/src/lib/librtems++/rtemsEvent.cc (added) * c/src/lib/librtems++/rtemsInterrupt.cc (added) * c/src/lib/librtems++/rtemsMessageQueue.cc (added) * c/src/lib/librtems++/rtemsSemaphore.cc (added) * c/src/lib/librtems++/rtemsStatusCode.cc (added) * c/src/lib/librtems++/rtemsTask.cc (added) * c/src/lib/librtems++/rtemsTimer.cc (added) * c/src/librtems++/README (added) * c/src/librtems++/include/rtems++/rtemsEvent.h (added) * c/src/librtems++/include/rtems++/rtemsInterrupt.h (added) * c/src/librtems++/include/rtems++/rtemsMessageQueue.h (added) * c/src/librtems++/include/rtems++/rtemsSemaphore.h (added) * c/src/librtems++/include/rtems++/rtemsStatusCode.h (added) * c/src/librtems++/include/rtems++/rtemsTask.h (added) * c/src/librtems++/include/rtems++/rtemsTaskMode.h (added) * c/src/librtems++/include/rtems++/rtemsTimer.h (added) * c/src/librtems++/src/Makefile.in (added) * c/src/librtems++/src/rtemsEvent.cc (added) * c/src/librtems++/src/rtemsInterrupt.cc (added) * c/src/librtems++/src/rtemsMessageQueue.cc (added) * c/src/librtems++/src/rtemsSemaphore.cc (added) * c/src/librtems++/src/rtemsStatusCode.cc (added) * c/src/librtems++/src/rtemsTask.cc (added) * c/src/librtems++/src/rtemsTimer.cc (added) * c/src/tests/libtests/rtems++/Init.cc (added) * c/src/tests/libtests/rtems++/Makefile.in (added) * c/src/tests/libtests/rtems++/System.h (added) * c/src/tests/libtests/rtems++/Task1.cc (added) * c/src/tests/libtests/rtems++/Task2.cc (added) * c/src/tests/libtests/rtems++/Task3.cc (added) * c/src/tests/libtests/rtems++/rtems++.doc (added) * c/src/tests/libtests/rtems++/rtems++.scn (added) * testsuites/libtests/rtems++/Init.cc (added) * testsuites/libtests/rtems++/System.h (added) * testsuites/libtests/rtems++/Task1.cc (added) * testsuites/libtests/rtems++/Task2.cc (added) * testsuites/libtests/rtems++/Task3.cc (added) * testsuites/libtests/rtems++/rtems++.doc (added) * testsuites/libtests/rtems++/rtems++.scn (added) Merged very large and much appreciated patch from Chris Johns ... Thu, 31 Jul 1997 22:04:17 GMT Joel Sherrill [91333c2] * Makefile.in (modified) * README.configure (modified) * c/Makefile.in (modified) * c/src/exec/score/cpu/m68k/m68302.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/cdtest/main.cc (modified) * configure (modified) * configure.in (modified) * cpukit/score/cpu/m68k/m68302.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68302.h (modified) * testsuites/samples/cdtest/main.cc (modified) Merged very large and much appreciated patch from Chris Johns ... Thu, 31 Jul 1997 19:48:23 GMT Joel Sherrill [13f09e6] * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/sp09.scn (modified) * c/src/tests/sptests/sp13/sp13.scn (modified) * c/src/tests/sptests/sp13/task1.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) * testsuites/sptests/sp13/sp13.scn (modified) * testsuites/sptests/sp13/task1.c (modified) Added support for rtems_message_queue_get_number_pending. Thu, 31 Jul 1997 19:01:42 GMT Joel Sherrill [e7d8b58] * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) Added rtems_message_queue_get_number_pending directive. Thu, 31 Jul 1997 19:01:05 GMT Joel Sherrill [a2fa8c25] * c/src/exec/posix/src/Makefile.in (modified) Added comment to indicate what the commented out C_PIECES indicated. Fri, 18 Jul 1997 15:05:05 GMT Joel Sherrill [e24e9b5] * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/timer.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) fixed typo Thu, 10 Jul 1997 20:24:00 GMT Joel Sherrill [bb566a02] * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.ads (modified) Reordered specs. Thu, 10 Jul 1997 20:23:27 GMT Joel Sherrill [0b172df9] * c/src/ada/rtems.adb (modified) * cpukit/ada/rtems.adb (modified) fixed milliseconds and microseconds to tick conversion routines. Thu, 10 Jul 1997 19:16:40 GMT Joel Sherrill [bf3a7a5a] * c/src/lib/libbsp/m68k/mvme162/README (modified) Added information on different MVME162 models. Thu, 10 Jul 1997 19:09:16 GMT Joel Sherrill [487c4f62] * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) Strip the trace bit from the SR register when dispatching a thread ... Wed, 09 Jul 1997 23:57:56 GMT Joel Sherrill [900a3ab1] * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (added) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (added) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (added) Repository damaged -- file re-added Wed, 09 Jul 1997 23:55:39 GMT Joel Sherrill [eb14a2ff] * c/src/exec/score/cpu/a29k/register.ah (added) * c/src/exec/score/cpu/a29k/sig.s (added) * cpukit/score/cpu/a29k/register.ah (added) Repository damaged -- files readded. Wed, 09 Jul 1997 23:52:08 GMT Joel Sherrill [a14d2af] * c/src/exec/posix/headers/config.h (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/src/pthread.c (modified) Changed name from entry to thread_entry to be more compatible with ... Wed, 09 Jul 1997 23:51:21 GMT Joel Sherrill [db17316] * c/src/tests/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen12.c (modified) Used macro instead of hard coded number. Wed, 09 Jul 1997 23:50:45 GMT Joel Sherrill [2a02b0a] * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) Added postswitch extension. Wed, 09 Jul 1997 23:50:28 GMT Joel Sherrill [b5fc21c] * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) Added post switch extension. Wed, 09 Jul 1997 23:46:59 GMT Joel Sherrill [2c5d78b] * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) Corrected typos and spacing. Wed, 09 Jul 1997 23:41:20 GMT Joel Sherrill [1d320bac] * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/round.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/util.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.s (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.s (modified) This code was in the tree but not actually being compiled. There ... Wed, 09 Jul 1997 23:33:08 GMT Joel Sherrill [8fabc273] * c/src/exec/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) Added sp, sfc, and fpcsr register defines. Wed, 04 Jun 1997 18:54:18 GMT Joel Sherrill [e7f86ef] * c/src/ada-tests/mptests/mp01/config.h (added) * c/src/ada-tests/mptests/mp01/mp01.adb (added) new file Tue, 03 Jun 1997 23:04:25 GMT Joel Sherrill [b42675f] * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) corrected name of test suite Tue, 03 Jun 1997 23:00:45 GMT Joel Sherrill [1e97a20] * c/src/ada-tests/samples/hello/hello.adb (modified) fixed comment Tue, 03 Jun 1997 22:58:48 GMT Joel Sherrill [9b3853a] * c/src/ada-tests/samples/ticker/sptest.ads (modified) Removed configuration information. Tue, 03 Jun 1997 22:57:58 GMT Joel Sherrill [430d81a] * c/src/ada-tests/samples/base_sp/base_sp.adb (added) * c/src/ada-tests/samples/base_sp/config.h (added) * c/src/ada-tests/samples/ticker/config.h (added) * c/src/ada-tests/samples/ticker/ticker.adb (added) new file Tue, 03 Jun 1997 22:54:45 GMT Joel Sherrill [08c192b] * c/src/ada-tests/samples/base_sp/sptest.ads (modified) Removed Configuration Information. Tue, 03 Jun 1997 22:52:39 GMT Joel Sherrill [8640cc99] * c/src/ada-tests/samples/hello/config.h (added) * c/src/ada-tests/samples/hello/hello.adb (added) new files. Tue, 03 Jun 1997 22:52:34 GMT Joel Sherrill [4fd88bc] * c/src/ada-tests/samples/hello/sptest.ads (modified) Removed configuration information. Tue, 03 Jun 1997 22:49:47 GMT Joel Sherrill [5d0f4a56] * c/src/ada-tests/support/rtems_calling_overhead.ads (added) * c/src/ada-tests/support/time_test_support.adb (added) * c/src/ada-tests/support/time_test_support.ads (added) * c/src/ada-tests/support/timer_driver.adb (added) * c/src/ada-tests/support/timer_driver.ads (added) new files Tue, 03 Jun 1997 22:49:19 GMT Joel Sherrill [7c498800] * c/src/ada-tests/tmtests/tmoverhd/README (added) new file. Tue, 03 Jun 1997 22:47:47 GMT Joel Sherrill [8ed37e3c] * c/src/ada-tests/tmtests/tmoverhd/config.h (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) corrected to compile with the new binding. Tue, 03 Jun 1997 22:40:57 GMT Joel Sherrill [1b141533] * c/src/ada-tests/tmtests/tmck/config.h (modified) Corrected for this test. Tue, 03 Jun 1997 22:39:55 GMT Joel Sherrill [2bef691] * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) Added correct contents Tue, 03 Jun 1997 22:38:10 GMT Joel Sherrill [5363249] * c/src/ada-tests/tmtests/tm26/README (added) * c/src/ada-tests/tmtests/tm26/tmtest.adp (added) * c/src/ada-tests/tmtests/tm27/README (added) * c/src/ada-tests/tmtests/tmck/config.h (added) new file Tue, 03 Jun 1997 22:22:52 GMT Joel Sherrill [2ef9d4a] * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) Corrected maximum number of messages to be non-zero Tue, 03 Jun 1997 22:21:18 GMT Joel Sherrill [6e98a517] * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) removed reference to Stub Device Driver Tue, 03 Jun 1997 22:18:54 GMT Joel Sherrill [f94917d7] * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) Replaced prototype for Last_Task which was accidentally removed when ... Tue, 03 Jun 1997 22:16:25 GMT Joel Sherrill [46063740] * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. Tue, 03 Jun 1997 22:11:55 GMT Joel Sherrill [e3b4ccd] * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) Fixed incorrect invocation of Message_Queue_Create Tue, 03 Jun 1997 22:10:18 GMT Joel Sherrill [79e0b6fd] * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) fixed typo which resulted in Message_Queue_Create being invoked ... Tue, 03 Jun 1997 22:08:59 GMT Joel Sherrill [688ecaa0] * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed calls to Message_Queue_Create to include maximum message size ... Tue, 03 Jun 1997 22:06:49 GMT Joel Sherrill [e17ffea] * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Changed to variable length messages. Tue, 03 Jun 1997 21:48:57 GMT Joel Sherrill [bc35a6ef] * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:46:18 GMT Joel Sherrill [1338cdb] * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:43:20 GMT Joel Sherrill [c7f646b5] * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed all references to Semaphore_Create to have the correct ... Tue, 03 Jun 1997 21:39:35 GMT Joel Sherrill [9db72b4] * c/src/ada-tests/tmtests/tm02/config.h (added) * c/src/ada-tests/tmtests/tm03/config.h (added) * c/src/ada-tests/tmtests/tm04/config.h (added) * c/src/ada-tests/tmtests/tm05/config.h (added) * c/src/ada-tests/tmtests/tm06/config.h (added) * c/src/ada-tests/tmtests/tm07/config.h (added) * c/src/ada-tests/tmtests/tm08/config.h (added) * c/src/ada-tests/tmtests/tm09/config.h (added) * c/src/ada-tests/tmtests/tm10/config.h (added) * c/src/ada-tests/tmtests/tm11/config.h (added) * c/src/ada-tests/tmtests/tm12/config.h (added) * c/src/ada-tests/tmtests/tm13/config.h (added) * c/src/ada-tests/tmtests/tm14/config.h (added) * c/src/ada-tests/tmtests/tm15/config.h (added) * c/src/ada-tests/tmtests/tm16/config.h (added) * c/src/ada-tests/tmtests/tm17/config.h (added) * c/src/ada-tests/tmtests/tm18/config.h (added) * c/src/ada-tests/tmtests/tm19/config.h (added) * c/src/ada-tests/tmtests/tm20/config.h (added) * c/src/ada-tests/tmtests/tm21/config.h (added) * c/src/ada-tests/tmtests/tm22/config.h (added) * c/src/ada-tests/tmtests/tm23/config.h (added) * c/src/ada-tests/tmtests/tm24/config.h (added) * c/src/ada-tests/tmtests/tm25/config.h (added) * c/src/ada-tests/tmtests/tm26/config.h (added) * c/src/ada-tests/tmtests/tm27/config.h (added) * c/src/ada-tests/tmtests/tm28/config.h (added) * c/src/ada-tests/tmtests/tm29/config.h (added) New file. Tue, 03 Jun 1997 21:27:16 GMT Joel Sherrill [4b067069] * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) new file Tue, 03 Jun 1997 20:24:11 GMT Joel Sherrill [b4be04e] * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Removed Configuration Table information. Tue, 03 Jun 1997 20:20:39 GMT Joel Sherrill [7b93a327] * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) Corrected call to Semaphore_Create to have the proper calling sequence Tue, 03 Jun 1997 20:20:23 GMT Joel Sherrill [b67e6ec] * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) Removed Configuration Table information
