# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 16:53:07 Wed, 14 Dec 2011 10:28:18 GMT Daniel Hellstrom [31e4e25d] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/watchdog.h (added) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/timer/watchdog.c (added) LEON3: GPTIMER timer watchdog driver Last timer instance of GPTIMER ... Wed, 15 Apr 2015 15:02:44 GMT Joel Sherrill [cb02e8ac] * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/start/start.S (modified) bf537Stamp: Re-enable bsp_reset() Tue, 14 Apr 2015 15:08:37 GMT Joel Sherrill [74c4facd] * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (modified) tms570/startup/bspreset.c: Add include to fix warning Tue, 14 Apr 2015 20:01:53 GMT Joel Sherrill [1aaf2fb] * c/src/lib/libbsp/lm32/shared/startup/bspreset.c (added) lm32/shared/startup/bspreset.c: New file missed in previous commit Tue, 14 Apr 2015 15:22:35 GMT Hesham ALMatary [0a73de2] * c/src/lib/libbsp/or1k/or1ksim/configure.ac (modified) * c/src/lib/libbsp/or1k/or1ksim/console/uart.c (modified) * c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h (modified) or1ksim: Fix bug at UART driver. Fix some UART register addresses ... Fri, 10 Apr 2015 06:23:00 GMT Thomas Volgmann [a1d6f7a] * c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c (modified) bsp/altera-cyclone-v: Add RTC driver Tue, 07 Apr 2015 20:06:32 GMT Alan Cudmore [044c7d82] * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg (modified) Add hardware FPU flags for Raspberry Pi 2 BSP Sun, 05 Apr 2015 20:49:32 GMT Joel Sherrill [45491a88] * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr_gdbsim-testsuite.tcfg (added) * c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr_gdbsim.cfg (added) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) lm32 BSPs: Add lm32_evr variant for running on gdb. Lay groundwork ... Fri, 03 Apr 2015 21:18:40 GMT Joel Sherrill [d0307c8a] * c/src/lib/libbsp/or1k/or1ksim/make/custom/or1ksim-testsuite.tcfg (added) or1ksim-testsuite.tcfg: new file Fri, 03 Apr 2015 20:08:01 GMT Joel Sherrill [475ff0a7] * c/src/lib/libbsp/m68k/ods68302/make/custom/ods68302-testsuite.tcfg (modified) ods68302-testsuite.tcfg: Add fileio Fri, 03 Apr 2015 20:07:47 GMT Joel Sherrill [66016198] * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx-testsuite.tcfg (modified) rtl22xx-testsuite.tcfg: Add fileio Thu, 02 Apr 2015 06:31:09 GMT Sebastian Huber [aae6c21] * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) bsp/altera-cyclone-v: Fix define usage Wed, 01 Apr 2015 14:38:26 GMT Joel Sherrill [c966b4dc] * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4-testsuite.tcfg (modified) simsh*: Disable interrupt critical section tests These do not run ... Tue, 31 Mar 2015 22:45:52 GMT Joel Sherrill [ef3bcef] * c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904-testsuite.tcfg (added) jmr3904-testsuite.tcfg: New file Thu, 26 Mar 2015 20:16:38 GMT Martin Galvan [ec8f3cb] * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (modified) TMS570: Add board reset code to bsp_reset Thu, 26 Mar 2015 20:21:26 GMT Martin Galvan [89fffa6] * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (modified) TMS570: Enable FPU in makefile. Wed, 25 Mar 2015 09:55:32 GMT Sebastian Huber [8aa967c] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) bsp/altera-cyclone-v: Typo Sun, 22 Mar 2015 13:58:30 GMT Joel Sherrill [28a8206c] * c/src/lib/libbsp/moxie/moxiesim/make/custom/moxiesim-testsuite.tcfg (modified) moxie machine type not supported by rtems-syms. See #2213 updates #2313. Sat, 21 Mar 2015 19:42:55 GMT Joel Sherrill [36ad3c7] * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) mrm332/console/sci.c: Make routines static Sat, 21 Mar 2015 19:41:53 GMT Joel Sherrill [90f25440] * c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c (modified) nds/libnds/source/arm9/image.c: Add needed cast Sat, 21 Mar 2015 19:41:27 GMT Joel Sherrill [e2192d9f] * c/src/lib/libbsp/arm/nds/libnds/source/arm7/clock.c (modified) nds/libnds/source/arm7/clock.c: Avoid over indexing array Sat, 21 Mar 2015 19:40:42 GMT Joel Sherrill [e836c7c1] * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) lpc176x/console/console-config.c: Conditionalize code to avoid unused ... Fri, 20 Mar 2015 15:41:33 GMT Joel Sherrill [7a6c7fe3] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) m32csim-testsuite.tcfg: Add tests with data size issues Fri, 20 Mar 2015 15:41:13 GMT Joel Sherrill [8b5f911] * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg (modified) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg (modified) h8sim*-testsuite.tcfg: Add tests with data size issues Fri, 20 Mar 2015 15:40:35 GMT Joel Sherrill [14655d35] * c/src/lib/libbsp/avr/avrtest/make/custom/avrtest-testsuite.tcfg (modified) avrtest-testsuite.tcfg: Add tests with data size issues Thu, 19 Mar 2015 17:30:10 GMT Joel Sherrill [c69f236] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) m32cbsp: Disable jffs2 and mrfs tests Thu, 19 Mar 2015 17:29:57 GMT Joel Sherrill [83f11c2] * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg (modified) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg (modified) h8sim: Disable jffs2 and mrfs tests Thu, 19 Mar 2015 17:29:40 GMT Joel Sherrill [1d09732] * c/src/lib/libbsp/avr/avrtest/make/custom/avrtest-testsuite.tcfg (modified) avrtest: Disable jffs2 and mrfs tests Fri, 20 Mar 2015 13:09:26 GMT Sebastian Huber [d4edbdbc] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc176x/adc/adc.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/mbed-pinmap.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (modified) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc176x/pwmout/pwmout.c (modified) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/dlfcn-shell.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rap-shell.c (modified) * cpukit/libdl/rap-shell.h (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rap.h (modified) * cpukit/libdl/rtl-chain-iterator.c (modified) * cpukit/libdl/rtl-chain-iterator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-error.h (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-find-file.h (modified) * cpukit/libdl/rtl-fwd.h (modified) * cpukit/libdl/rtl-indirect-ptr.h (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-cache.h (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj-comp.h (modified) * cpukit/libdl/rtl-obj-fwd.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-shell.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-sym.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-trace.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unresolved.h (modified) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * testsuites/psxtests/psxclock01/init.c (modified) * testsuites/sptests/spclock_err01/delay.c (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spclock_err01/system.h (modified) * testsuites/sptests/spevent_err03/init.c (modified) * testsuites/sptests/spevent_err03/system.h (modified) * testsuites/sptests/spintr_err01/init.c (modified) * testsuites/sptests/spintr_err01/isr.c (modified) * testsuites/sptests/spintr_err01/system.h (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) * testsuites/sptests/spmsgq_err01/system.h (modified) * testsuites/sptests/spmsgq_err02/init.c (modified) * testsuites/sptests/spmsgq_err02/system.h (modified) * testsuites/sptests/spmsgq_err02/task3.c (modified) * testsuites/sptests/spport_err01/init.c (modified) * testsuites/sptests/spport_err01/system.h (modified) * testsuites/sptests/spratemon_err01/init.c (modified) * testsuites/sptests/spratemon_err01/screen10.c (modified) * testsuites/sptests/spratemon_err01/system.h (modified) * testsuites/sptests/spratemon_err01/task4.c (modified) * testsuites/sptests/spsem_err01/init.c (modified) * testsuites/sptests/spsem_err01/system.h (modified) * testsuites/sptests/spsem_err02/init.c (modified) * testsuites/sptests/spsem_err02/system.h (modified) * testsuites/sptests/spsem_err02/task2.c (modified) * testsuites/sptests/spsignal_err01/init.c (modified) * testsuites/sptests/spsignal_err01/isr.c (modified) * testsuites/sptests/spsignal_err01/system.h (modified) * testsuites/sptests/sptask_err01/init.c (modified) * testsuites/sptests/sptask_err01/system.h (modified) * testsuites/sptests/sptask_err01/task2.c (modified) * testsuites/sptests/sptask_err02/init.c (modified) * testsuites/sptests/sptask_err02/system.h (modified) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptask_err03/system.h (modified) * testsuites/sptests/sptask_err04/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) Replace www.rtems.com with www.rtems.org Wed, 11 Mar 2015 09:53:59 GMT Daniel Cederman [665928a] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) rtems: Use atomic operation with correct type Fri, 20 Mar 2015 08:45:02 GMT Sebastian Huber [9f34aa5] * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) bsp/rtl22xx: Add prefix due to name conflicts Close #2303. Wed, 11 Mar 2015 19:57:23 GMT Martin Galvan [7b35a36] * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/adc/adc.c (added) * c/src/lib/libbsp/arm/lpc176x/can/can.c (added) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/adc.h (added) * c/src/lib/libbsp/arm/lpc176x/include/can-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/can.h (added) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/mbed-pinmap.h (added) * c/src/lib/libbsp/arm/lpc176x/include/pwmout-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/pwmout.h (added) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc176x/pwmout/pwmout.c (added) * c/src/lib/libbsp/shared/include/uart-output-char.h (modified) Add CAN, PWM, ADC and UART1/2/3 support to the LPC176x BSP. This ... Tue, 17 Mar 2015 15:58:21 GMT Joel Sherrill [fb1a9ad] * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add tmfine01 Tue, 17 Mar 2015 15:58:21 GMT Joel Sherrill [d48d08c] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg: Add tmfine01 Tue, 17 Mar 2015 15:58:21 GMT Joel Sherrill [d10e331] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg: Add tmfine01 Tue, 17 Mar 2015 15:58:21 GMT Joel Sherrill [487642f] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ... Tue, 17 Mar 2015 15:58:21 GMT Joel Sherrill [77d558c] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg: Add tmfine01 Tue, 17 Mar 2015 15:58:20 GMT Joel Sherrill [13d5033] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg: Add tmfine01 Tue, 17 Mar 2015 15:58:20 GMT Joel Sherrill [a7c7bdc] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg: Add tmfine01 Sun, 15 Mar 2015 14:55:42 GMT Joel Sherrill [195efa43] * c/src/lib/libbsp/powerpc/shared/flash/intelFlash.c (modified) powerpc/shared/flash/intelFlash.c: Eliminate use of deprecated method Sun, 15 Mar 2015 02:17:20 GMT Joel Sherrill [38d91667] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) powerpc/mvme5500/vectors/exceptionhandler.c: Turn off deprecated ... Sat, 14 Mar 2015 16:01:06 GMT Joel Sherrill [be277dd] * c/src/libchip/network/if_fxp.c (modified) libchip/network/if_fxp.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 16:00:39 GMT Joel Sherrill [296b0247] * c/src/libchip/i2c/spi-memdrv.c (modified) libchip/i2c/spi-memdrv.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 16:00:20 GMT Joel Sherrill [24868ecb] * c/src/lib/libcpu/bfin/clock/rtc.c (modified) libcpu/bfin/clock/rtc.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 15:59:52 GMT Joel Sherrill [c1479edf] * c/src/lib/libbsp/powerpc/shared/flash/intelFlash.c (modified) powerpc/shared/flash/intelFlash.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 15:59:35 GMT Joel Sherrill [fe0eb1b] * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) score603e/tod/tod.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 15:57:55 GMT Joel Sherrill [05af8b9] * c/src/lib/libbsp/powerpc/beatnik/network/porting/if_xxx_rtems.c (modified) beatnik/network/porting/if_xxx_rtems.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 15:57:14 GMT Joel Sherrill [0cc35f0] * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) mvme167/network/network.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 15:56:43 GMT Joel Sherrill [8164ebd] * c/src/lib/libbsp/m68k/mvme162/tod/tod.c (modified) mvme162/tod/tod.c: Do not use rtems_clock_get() Tue, 17 Mar 2015 10:28:44 GMT Sebastian Huber [ac8339a] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (modified) bsp/mpc55xx: Fix flash settings Tue, 17 Mar 2015 07:54:39 GMT Sebastian Huber [8e10f62] * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) bsp/qoriq: Add register blocks for T variants Tue, 17 Mar 2015 07:48:47 GMT Sebastian Huber [093bfde] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) bsp/qoriq: Fix warning Mon, 16 Mar 2015 18:31:04 GMT Sebastian Huber [a2ba004] * c/src/lib/libbsp/powerpc/mbx8xx/console/console.c (modified) bsp/mbx8xx: Fix warnings Sun, 15 Mar 2015 16:04:06 GMT Alan Cudmore [71260b4] * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (modified) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg (modified) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc (added) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg (added) * c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c (modified) preliminary Raspberry Pi Model 2 support This patch adds a BSP ... Sun, 15 Mar 2015 09:12:29 GMT Sebastian Huber [91c250fc] * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) bsps/sparc: Fix linker section Sat, 14 Mar 2015 21:29:07 GMT Ben Gras [275a9bf] * c/src/lib/libbsp/bfin/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) Revert "autoconf changes" This reverts commit ... Sat, 14 Mar 2015 14:39:13 GMT Ben Gras [86204bde] * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) beagle bsp: delete TIMER_FREQ, TIMER_COUNT unused and poorly named ... Sat, 14 Mar 2015 15:06:14 GMT Ben Gras [dbe85952] * c/src/lib/libbsp/bfin/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) autoconf changes Thu, 12 Mar 2015 20:01:02 GMT Joel Sherrill [f1b4680] * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/start/start.S (modified) m32cbsp: Add bsp_reset() so the BSP exits Tue, 10 Mar 2015 22:07:24 GMT Joel Sherrill [78d5448] * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (modified) mvme147s: Install z8530.h This was missed when the file was moved. Fri, 06 Mar 2015 17:41:49 GMT Gedare Bloom [3ac68119] * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * doc/user/task.t (modified) * doc/user/userext.t (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/spnotepad01/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) cpukit: deprecate notepads Deprecate Classic API Notepads. Mark ... Mon, 09 Mar 2015 21:07:36 GMT Joel Sherrill [1aa7b8b] * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/shared/include/zilog/z8036.h (moved) * c/src/lib/libbsp/shared/include/zilog/z8530.h (moved) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/preinstall.am (modified) Move contents of libcsupport/include/zilog into libbsp/shared Only ... Mon, 09 Mar 2015 20:47:47 GMT Joel Sherrill [5bc6237] * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/motorola/mc68230.h (moved) * c/src/lib/libbsp/m68k/idp/include/motorola/mc68681.h (moved) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * cpukit/libcsupport/preinstall.am (modified) Move libcsupport/include/motorola/*.h to m68k/idp BSP These header ... Sun, 08 Mar 2015 23:00:07 GMT Joel Sherrill [9cc1892] * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) libcpu/powerpc/mpc8260/console-generic/console-generic.c: Include ... Sun, 08 Mar 2015 20:09:43 GMT Joel Sherrill [120af809] * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx.cfg (modified) rtl22xx.cfg: Remove -DNDEBUG flag Sun, 08 Mar 2015 20:09:26 GMT Joel Sherrill [058a92d] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg (modified) lpc1768_mbed.cfg: Remove -DNDEBUG flag Sun, 08 Mar 2015 19:56:09 GMT Joel Sherrill [500eb044] * c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg (modified) mvme136.cfg: Remove -DNDEBUG flag Sun, 08 Mar 2015 18:50:56 GMT Joel Sherrill [867a54a2] * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) gensh1/include/bsp.h: Add needed prototype Sun, 08 Mar 2015 18:50:33 GMT Joel Sherrill [52c56af0] * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) gensh4/include/bsp.h: Remove unused prototype and include Sat, 07 Mar 2015 22:24:40 GMT Joel Sherrill [a1148f36] * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) powerpc/shared/bootloader/pci.c: Remove warnings Sat, 07 Mar 2015 21:14:36 GMT Joel Sherrill [3159267] * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) shared/include/grcan.h: Add prototypes to fix warnings Fri, 06 Mar 2015 14:23:44 GMT Joel Sherrill [1ae60ae5] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg (modified) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554-testsuite.tcfg (modified) Add fsscandir01 variants as needed to more BSPs testsuite configuration Thu, 05 Mar 2015 16:09:15 GMT Joel Sherrill [dea43a0d] * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5668g-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_app-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb_spe-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_0-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_1-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_p1020rdb-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t2080rdb-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg (added) Temporarily ignore dl* tests on some PowerPC BSPs Some BSPs have ... Thu, 05 Mar 2015 15:51:40 GMT Joel Sherrill [7af34c13] * c/src/aclocal/check-networking.m4 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_boot-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554-testsuite.tcfg (modified) * cpukit/aclocal/check-networking.m4 (modified) Always disable networking for h8300 Wed, 04 Mar 2015 22:55:43 GMT Joel Sherrill [e516d45] * c/src/lib/libbsp/mips/hurricane/make/custom/hurricane-testsuite.tcfg (added) * c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925-testsuite.tcfg (added) * c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938-testsuite.tcfg (added) Temporarily disable libdl tests on some MIPS BSPSs These BSPs are ... Wed, 04 Mar 2015 20:49:08 GMT Joel Sherrill [683ebac] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) raspberrypi: Do not include default IRQ handler and BSP specific one ... Wed, 04 Mar 2015 20:01:52 GMT Joel Sherrill [a87e8b8d] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01 Wed, 04 Mar 2015 20:00:16 GMT Joel Sherrill [8f49dda] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.tcfg (deleted) lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk file This file ... Fri, 06 Mar 2015 16:35:40 GMT Joel Sherrill [cc69334f] * c/src/lib/libbsp/arm/lpc32xx/include/nand-mlc.h (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/capture/captureimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) Fix a number of minor Doxygen formatting issues Thu, 05 Mar 2015 13:54:09 GMT Sebastian Huber [5fca9ef] * c/src/lib/libbsp/shared/src/irq-server.c (modified) bsps: Use interrupt lock for interrupt server Thu, 05 Mar 2015 13:53:47 GMT Sebastian Huber [f3a57820] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) bsp/qoriq: Fix warning Thu, 05 Mar 2015 09:53:20 GMT Sebastian Huber [77510c7] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) * cpukit/configure.ac (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libmd/preinstall.am (modified) libmd: Disable SHA modules for m32c Close #2219. Thu, 05 Mar 2015 09:05:49 GMT Sebastian Huber [5155069] * c/src/libchip/serial/ns16550.c (modified) libchip/serial: Fix warning Thu, 05 Mar 2015 09:04:37 GMT Sebastian Huber [b4fa5a52] * c/src/lib/libbsp/shared/console-termios-init.c (modified) bsps: Fix warning Tue, 03 Mar 2015 15:17:26 GMT Joel Sherrill [e4154b8] * c/src/lib/libbsp/mips/csb350/start/start.S (modified) * c/src/lib/libbsp/mips/genmongoosev/start/start.S (modified) * c/src/lib/libbsp/mips/jmr3904/start/start.S (modified) * c/src/lib/libbsp/mips/malta/start/start.S (modified) mips BSPs: Remove .global for unprovided symbol closes 2253 Thu, 26 Feb 2015 20:31:27 GMT Martin Galvan [991fdb33] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S (added) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION This patch adds ... Mon, 23 Feb 2015 20:42:59 GMT Gedare Bloom [9d090fb7] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/start/bspinit.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/start/bspinit.S (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) sparc64: fix copyright notices. The sparc64 port had some incorrect ... Fri, 20 Feb 2015 13:08:01 GMT Martin Galvan [dc9aaf7] * c/src/lib/libbsp/arm/shared/start/start.S (modified) ARM: Support VFP-D16 This patch allows the existing FPU code to ... Mon, 16 Feb 2015 10:55:03 GMT Sebastian Huber [c34f94f7] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/shared/bspsmp.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) score: Add _CPU_SMP_Prepare_start_multitasking() Update #2268. Wed, 11 Feb 2015 23:36:34 GMT Joel Sherrill [5640dd5] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01 Wed, 11 Feb 2015 23:34:44 GMT Joel Sherrill [79b45a1] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) lpc1768_mbed-testsuite.tcfg: Add ftp01 Sun, 08 Feb 2015 18:43:09 GMT Sebastian Huber [a9df916] * c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (deleted) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (deleted) * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsimfsconfig01/Makefile.am (added) * testsuites/fstests/fsimfsconfig01/fsimfsconfig01.doc (added) * testsuites/fstests/fsimfsconfig01/fsimfsconfig01.scn (added) * testsuites/fstests/fsimfsconfig01/init.c (added) * testsuites/fstests/fsimfsconfig02/Makefile.am (added) * testsuites/fstests/fsimfsconfig02/fsimfsconfig02.doc (added) * testsuites/fstests/fsimfsconfig02/fsimfsconfig02.scn (added) * testsuites/fstests/fsimfsconfig02/init.c (added) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/libtests/tar03/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/iostream/system.h (modified) * testsuites/sptests/sp47/init.c (modified) * testsuites/sptests/sp48/init.c (modified) IMFS: Add fine grained configuration Remove miniIMFS. Statically ... Wed, 04 Feb 2015 09:33:17 GMT Daniel Cederman [5efbb66] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) grspw: Fix typos Fri, 09 Jan 2015 08:03:59 GMT Daniel Cederman [0c94a46] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/irq/bsp_isr_handler.c (added) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) bsp/sparc: Move BSP_ISR_handler to a separate file and rename it ... Mon, 09 Feb 2015 14:37:00 GMT Sebastian Huber [eb77534] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_fsmount.c (deleted) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Filesystem: Delete unused fsmountme_h handler Wed, 04 Feb 2015 17:20:27 GMT Pavel Pisa [cf4dfc1] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) arm/tms570: sci context has to be writable because it holds state ... Wed, 28 Jan 2015 04:04:26 GMT Nick Withers [d11b711] * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) bsps/powerpc: Fix a clock driver PowerPC Book E: Account for an ... Wed, 14 Jan 2015 22:23:53 GMT Joel Sherrill [296846a] * c/src/lib/libbsp/m68k/mcf5206elite/include/i2c.h (modified) mcf5206elite/include/i2c.h: Fix spelling error Wed, 14 Jan 2015 22:23:16 GMT Joel Sherrill [b1dcae0] * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) stm32f4/.../stm32f105rc-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:59 GMT Joel Sherrill [3d345508] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more tests
