# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 06/15/24 20:32:05 Sat, 21 May 2016 01:10:06 GMT Pavel Pisa [4c59eebf] * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (modified) arm/raspberrypi: cmdline enhancement and early access workaround. ... Tue, 31 May 2016 08:25:25 GMT Sebastian Huber [dd2c57d4] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (deleted) * c/src/libchip/Makefile.am (modified) * c/src/libchip/network/README.dwmac (deleted) * c/src/libchip/network/dwmac-1000-core.c (deleted) * c/src/libchip/network/dwmac-1000-dma.c (deleted) * c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c (deleted) * c/src/libchip/network/dwmac-common.h (deleted) * c/src/libchip/network/dwmac-core.c (deleted) * c/src/libchip/network/dwmac-core.h (deleted) * c/src/libchip/network/dwmac-desc-com.c (deleted) * c/src/libchip/network/dwmac-desc-com.h (deleted) * c/src/libchip/network/dwmac-desc-enh.c (deleted) * c/src/libchip/network/dwmac-desc.h (deleted) * c/src/libchip/network/dwmac-regs.h (deleted) * c/src/libchip/network/dwmac.c (deleted) * c/src/libchip/network/dwmac.h (deleted) * c/src/libchip/preinstall.am (modified) libchip: Remove dwmac network interface driver The network ... Tue, 12 Apr 2016 05:30:38 GMT Sebastian Huber [a9cff51b] * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_t2080rdb (modified) bsp/qoriq: Fix nocache region placement Avoid memory waste due to ... Tue, 31 May 2016 07:12:43 GMT Sebastian Huber [0546e65e] * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) bsps: Add defines for some linker subsections The GNU ld sort by ... Tue, 31 May 2016 07:10:24 GMT Sebastian Huber [ccda9459] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps: Sort some sections first by alignment This helps to avoid ... Mon, 23 May 2016 05:27:34 GMT Chris Johns [8f9d07bb] * c/src/lib/libbsp/shared/src/irq-default-handler.c (modified) bsp/shared: Fix printk warnings. Mon, 23 May 2016 05:24:34 GMT Chris Johns [1503c1c3] * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) i386/pc386: Fix printk formatting warnings. Fri, 20 May 2016 08:39:50 GMT Chris Johns [24d0ee57] * c/src/lib/libbsp/shared/include/irq-info.h (modified) * c/src/lib/libbsp/shared/src/irq-info.c (modified) * c/src/lib/libbsp/shared/src/irq-shell.c (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/print.h (added) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/print_fprintf.c (added) * cpukit/libcsupport/src/print_printf.c (added) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/fb/mw_uid.h (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_top.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testbeginend.c (modified) * cpukit/libmisc/testsupport/testextension.c (modified) * cpukit/preinstall.am (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/sapi/include/rtems/profiling.h (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/score/src/cpusetprintsupport.c (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block08/init.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/capture01/init.c (modified) * testsuites/libtests/complex/init.c (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/math/init.c (modified) * testsuites/libtests/mathf/init.c (modified) * testsuites/libtests/mathl/init.c (modified) * testsuites/libtests/mouse01/init.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/uid01/init.c (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/samples/capture/init.c (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spprintk/init.c (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/support/include/test_support.h (modified) * testsuites/support/src/locked_print.c (modified) cpukit, testsuite: Add rtems_printf and rtems_printer support. This ... Wed, 18 May 2016 06:06:54 GMT Sebastian Huber [24713163] * c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/dpram.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Rename _ISR_Disable() and _ISR_Enable() Rename ... Wed, 18 May 2016 06:03:05 GMT Sebastian Huber [4b04cb61] * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadhandler.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) score: Rename _ISR_Disable_without_giant() Rename ... Tue, 17 May 2016 13:57:48 GMT Sebastian Huber [d2bacb6c] * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: _Thread_Dispatch_increment_disable_level() Avoid ... Thu, 19 May 2016 09:36:15 GMT Pavel Pisa [8830bfe6] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (added) arm/raspberrypi: add cmdline support for rpi bsp. Wed, 12 Aug 2015 22:05:34 GMT YANG Qiao [54c197a] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/vc.h (added) * c/src/lib/libbsp/arm/raspberrypi/misc/vc.c (added) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) arm/raspberrypi: add VideoCore frame buffer control support Wed, 12 Aug 2015 22:04:33 GMT YANG Qiao [33e39d31] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) arm/raspberrypi: add VideoCore mailbox support read and write Thu, 19 May 2016 08:34:18 GMT Pavel Pisa [1258229] * c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c (modified) arm/raspberrypi: add locking around GPIO pin function selection. ... Thu, 19 May 2016 08:29:28 GMT Pavel Pisa [4b62192f] * c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c (modified) * c/src/lib/libbsp/arm/raspberrypi/include/rpi-gpio.h (modified) arm/raspberrypi: correct GPIO pin function selection. Original ... Thu, 19 May 2016 08:24:46 GMT Pavel Pisa [e706a9d] * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) arm/raspberrypi: ensure that RTEMS application image can be started ... Thu, 19 May 2016 08:21:01 GMT Pavel Pisa [6fbc692] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: CP15 support for flush prefetch buffer and table base control. Sat, 07 May 2016 04:28:45 GMT Chris Johns [c3fd48d0] * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) i386/pc386: Clean out removed functions. Fri, 06 May 2016 22:18:28 GMT Chris Johns [8cb397b2] * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) i386/pc386: Add x86 debug register support for hardware break points. Fri, 06 May 2016 22:17:51 GMT Chris Johns [fc138a10] * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) i386/pc386: EOI the master and slave for slave IRQ signals. Fri, 06 May 2016 22:16:49 GMT Chris Johns [02ef5d9] * c/src/lib/libbsp/i386/pc386/ide/idecfg.c (modified) i386/pc386: Add --ide-disable boot command line option. Fri, 06 May 2016 07:55:29 GMT Chris Johns [93fb8797] * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/elcr.c (added) * c/src/lib/libbsp/i386/shared/irq/elcr.h (added) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) i386/pc386: Fix interrupt support. Fix the interrupt and stop the ... Fri, 06 May 2016 07:52:08 GMT Chris Johns [292dbff] * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) i386/pc386: Fix printk with the console changes. Fri, 06 May 2016 07:51:26 GMT Chris Johns [beefa112] * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) bsp/pc386: Use irq-generic. Fri, 06 May 2016 07:44:22 GMT Chris Johns [b61f58f] * c/src/lib/libbsp/shared/bspclean.c (modified) bsp/shared: Print the exception stack frame before the shut down ... Fri, 06 May 2016 07:40:22 GMT Chris Johns [43f18a1] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) bsp/shared: Add bsp_interrupt_handler_is_empty. Wed, 20 Apr 2016 07:12:07 GMT Chris Johns [8ce75671] * c/src/libchip/serial/ns16550.c (modified) ibchip/ns16550: Minor optimisation. Wed, 20 Apr 2016 04:49:32 GMT Chris Johns [03ad2a5a] * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (modified) i386/pc386: Add IO and memory support to PCI UART devices. Use the ... Fri, 08 Apr 2016 08:39:38 GMT Chris Johns [014292a1] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/README (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/i386/pc386/console/gdb_select.c (added) * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bspimpl.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_private.h (modified) i386/pc386: Add support for the gdb stub to use available console ... Mon, 09 May 2016 11:04:39 GMT Sebastian Huber [f57f513d] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/portal.c (added) bsp/qoriq: Add portal clear functions Thu, 28 Apr 2016 08:19:54 GMT Sebastian Huber [c70f9d1] * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Set M and G bits in ENTRY_DEV_CACHED() Set M and G MMU ... Fri, 06 May 2016 20:08:47 GMT Martin Galvan [b4d7d5d] * c/src/libchip/network/sonic.c (modified) sonic.c: Fix warning on gcc 6 GCC 6.0 previews give the following ... Tue, 03 May 2016 05:38:19 GMT Sebastian Huber [1d40d81b] * c/src/ada/rtems-tasks.adb (modified) * c/src/ada/rtems-tasks.ads (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariable_invoke_dtor.c (deleted) * cpukit/rtems/src/taskvariableadd.c (deleted) * cpukit/rtems/src/taskvariabledelete.c (deleted) * cpukit/rtems/src/taskvariableget.c (deleted) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp28/Makefile.am (deleted) * testsuites/sptests/sp28/init.c (deleted) * testsuites/sptests/sp28/sp28.doc (deleted) * testsuites/sptests/sp28/sp28.scn (deleted) rtems: Remove task variables Update #2494. Update #2555. Tue, 03 May 2016 04:47:21 GMT Sebastian Huber [159b637] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) bsp/mvme5500: Use thread local variable Use thread local variable ... Thu, 28 Apr 2016 08:27:51 GMT Sebastian Huber [0000791] * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) bsp/qoriq: Add and use qoriq_reset_qman_and_bman() Thu, 28 Apr 2016 08:22:03 GMT Sebastian Huber [ddc12de] * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) bsp/qoriq: Add DCFG to memory map Fri, 22 Apr 2016 12:03:43 GMT Sebastian Huber [d8f4689] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (added) * c/src/lib/libbsp/powerpc/qoriq/startup/restart.S (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/qoriq: Add bsp_restart() Fri, 22 Apr 2016 11:34:09 GMT Sebastian Huber [2816c84a] * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) bsp/qoriq: Use IPI_INDEX throughout Fri, 22 Apr 2016 11:32:52 GMT Sebastian Huber [9b1f338d] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Add qoriq_start_spin_table_addr[] Make the U-Boot start ... Fri, 22 Apr 2016 11:11:15 GMT Sebastian Huber [2c68a47e] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) bsp/qoriq: Add qoriq_tlb1_invalidate_all_by_ts() Generalize ... Fri, 22 Apr 2016 11:09:39 GMT Sebastian Huber [582e4272] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/l1cache.S (added) bsp/qoriq: Move L1 cache invalidate function Fri, 22 Apr 2016 08:28:00 GMT Sebastian Huber [0ac0632] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Do not reset time base We may use this as an entropy source. Fri, 22 Apr 2016 11:02:55 GMT Sebastian Huber [178180aa] * c/src/lib/libbsp/shared/src/bsp-fdt.c (modified) bsps: Copy FDT only if source != destination Fri, 22 Apr 2016 12:10:47 GMT Sebastian Huber [d35e6dde] * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add FSL_EIS_TENSR, etc. defines Thu, 21 Apr 2016 10:37:25 GMT Sebastian Huber [c287dc0] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/l2cache.S (added) bsp/qoriq: Flush and invalidate all L2 caches Thu, 21 Apr 2016 09:39:28 GMT Sebastian Huber [6a46d99] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Optionally initialize register HID0 Enable the L2MMU ... Sat, 16 Apr 2016 13:01:47 GMT Pavel Pisa [b752f945] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) i386/pc386: reimplemented check for unused EDID entry in fb_vesa.c to ... Tue, 22 Mar 2016 22:13:30 GMT Joel Sherrill [e65c45c] * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada/rtems-clock.adb (modified) * c/src/ada/rtems-clock.ads (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/src/clockget.c (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclockget/Makefile.am (deleted) * testsuites/sptests/spclockget/init.c (deleted) * testsuites/sptests/spclockget/spclockget.doc (deleted) * testsuites/sptests/spclockget/spclockget.scn (deleted) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) Obsolete rtems_clock_get() directive. This service was marked as ... Thu, 14 Apr 2016 05:57:38 GMT Sebastian Huber [a12724f9] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) bsp/qoriq: Fix MMU initialization for e6500 In case a hypervisor ... Fri, 01 Apr 2016 06:33:29 GMT Sebastian Huber [d2c8693] * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) bsp/atsam: Fix mbuf allocation Wed, 23 Mar 2016 15:37:09 GMT Sebastian Huber [2803314e] * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) bsp/leon3: Remove dead code Tue, 16 Feb 2016 13:11:09 GMT Alexander Krutwig [fb29ca55] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/include/bsp.h (modified) * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (added) bsp/atsam: Add network interface driver Tue, 22 Mar 2016 07:34:16 GMT Sebastian Huber [0bd49f1] * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c (modified) * c/src/lib/libbsp/arm/atsam/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram (modified) bsp/atsam: Add nocache region support Tue, 22 Mar 2016 07:29:59 GMT Sebastian Huber [935e9c7d] * c/src/lib/libbsp/arm/atsam/configure.ac (modified) bsp/atsam: Fix sizes of internal SRAM Wed, 30 Mar 2016 04:51:46 GMT Chris Johns [0a2f5bdd] * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) bsp/pc386: Fix --console=/--printk= argument parsing. Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [d33ab82] * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) v850/gdbv850sim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [f7e2ceb] * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) sparc64/usiii/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [c412142] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) sparc64/niagara/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [23e5746] * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) sparc/erc32/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [be13774] * c/src/lib/libbsp/sh/shared/console.c (modified) sh/shared/console.c: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [64f3cf8a] * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) sh/gensh2/startup/hw_init.c: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [09a21c5] * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) powerpc/virtex5/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [bea9a25] * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) powerpc/virtex4/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [c9705f0] * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) powerpc/virtex/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [d379a629] * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) powerpc/qemuppc/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [c5ecb95] * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) powerpc/psim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [bf820a6f] * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) powerpc/haleakala/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [ff9f426] * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) moxie/moxiesim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [7054fccf] * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) mips/rbtx4938/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [fd29877] * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) mips/rbtx4925/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [fd437ab] * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) mips/malta/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [aafd818] * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) mips/jmr3904/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [bbea36c] * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) mips/hurricane/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [241c1b8] * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) mips/csb350/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [482fdd55] * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) m68k/uC5282/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [6d27f69] * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) m68k/mvme167/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [2816b1af] * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) m68k/mvme162/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [1d1b6f7a] * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) m68k/mvme147s/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [68a5bfcc] * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) m68k/mvme147/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [ce019f3d] * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) m68k/mvme147/console/console.c: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [228942f5] * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) m68k/mrm332/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [8400f688] * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) m68k/mcf5329/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [6515040] * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) m68k/mcf5235/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [c3db9091] * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) m68k/mcf5225x/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [3cf6de58] * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) m68k/mcf52235/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [9bbf6cd3] * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) m68k/mcf5206elite/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [d931d28f] * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) m68k/genmcf548x/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [f68a6ec2] * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) m68k/gen68360/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [5e96a582] * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) m68k/gen68340/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [cbc20686] * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) m68k/csb360/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [aeefcc7] * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) m68k/av5282/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [3f39a77] * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) m32c/m32cbsp/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [96a7d06] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) i386/pc386/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [02f4c11] * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) arm/smdk2410/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [85fe6d04] * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) arm/rtl22xx/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [734d62e5] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) arm/gdbarmsim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [93acba9] * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) arm/edb7312/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [cf99f21] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) arm/csb336/include/bsp.h: Do not include Wed, 30 Mar 2016 14:10:53 GMT Joel Sherrill [c30d6686] * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) powerpc/gen5200/include/bsp.h: Remove unnecessary include of ...
