# # ChangeLog for c/src in rtems # # Generated by Trac 1.2.1.dev0 # 06/15/24 22:02:19 Fri, 06 May 2016 07:52:08 GMT Chris Johns [292dbff] * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) i386/pc386: Fix printk with the console changes. Fri, 06 May 2016 07:51:26 GMT Chris Johns [beefa112] * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) bsp/pc386: Use irq-generic. Fri, 06 May 2016 07:44:22 GMT Chris Johns [b61f58f] * c/src/lib/libbsp/shared/bspclean.c (modified) bsp/shared: Print the exception stack frame before the shut down ... Fri, 06 May 2016 07:40:22 GMT Chris Johns [43f18a1] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) bsp/shared: Add bsp_interrupt_handler_is_empty. Wed, 20 Apr 2016 07:12:07 GMT Chris Johns [8ce75671] * c/src/libchip/serial/ns16550.c (modified) ibchip/ns16550: Minor optimisation. Wed, 20 Apr 2016 04:49:32 GMT Chris Johns [03ad2a5a] * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (modified) i386/pc386: Add IO and memory support to PCI UART devices. Use the ... Fri, 08 Apr 2016 08:39:38 GMT Chris Johns [014292a1] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/README (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/i386/pc386/console/gdb_select.c (added) * c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bspimpl.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_private.h (modified) i386/pc386: Add support for the gdb stub to use available console ... Mon, 09 May 2016 11:04:39 GMT Sebastian Huber [f57f513d] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/portal.c (added) bsp/qoriq: Add portal clear functions Thu, 28 Apr 2016 08:19:54 GMT Sebastian Huber [c70f9d1] * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Set M and G bits in ENTRY_DEV_CACHED() Set M and G MMU ... Fri, 06 May 2016 20:08:47 GMT Martin Galvan [b4d7d5d] * c/src/libchip/network/sonic.c (modified) sonic.c: Fix warning on gcc 6 GCC 6.0 previews give the following ... Tue, 03 May 2016 05:38:19 GMT Sebastian Huber [1d40d81b] * c/src/ada/rtems-tasks.adb (modified) * c/src/ada/rtems-tasks.ads (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariable_invoke_dtor.c (deleted) * cpukit/rtems/src/taskvariableadd.c (deleted) * cpukit/rtems/src/taskvariabledelete.c (deleted) * cpukit/rtems/src/taskvariableget.c (deleted) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp28/Makefile.am (deleted) * testsuites/sptests/sp28/init.c (deleted) * testsuites/sptests/sp28/sp28.doc (deleted) * testsuites/sptests/sp28/sp28.scn (deleted) rtems: Remove task variables Update #2494. Update #2555. Tue, 03 May 2016 04:47:21 GMT Sebastian Huber [159b637] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) bsp/mvme5500: Use thread local variable Use thread local variable ... Thu, 28 Apr 2016 08:27:51 GMT Sebastian Huber [0000791] * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) bsp/qoriq: Add and use qoriq_reset_qman_and_bman() Thu, 28 Apr 2016 08:22:03 GMT Sebastian Huber [ddc12de] * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) bsp/qoriq: Add DCFG to memory map Fri, 22 Apr 2016 12:03:43 GMT Sebastian Huber [d8f4689] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (added) * c/src/lib/libbsp/powerpc/qoriq/startup/restart.S (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/qoriq: Add bsp_restart() Fri, 22 Apr 2016 11:34:09 GMT Sebastian Huber [2816c84a] * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) bsp/qoriq: Use IPI_INDEX throughout Fri, 22 Apr 2016 11:32:52 GMT Sebastian Huber [9b1f338d] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Add qoriq_start_spin_table_addr[] Make the U-Boot start ... Fri, 22 Apr 2016 11:11:15 GMT Sebastian Huber [2c68a47e] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) bsp/qoriq: Add qoriq_tlb1_invalidate_all_by_ts() Generalize ... Fri, 22 Apr 2016 11:09:39 GMT Sebastian Huber [582e4272] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/l1cache.S (added) bsp/qoriq: Move L1 cache invalidate function Fri, 22 Apr 2016 08:28:00 GMT Sebastian Huber [0ac0632] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Do not reset time base We may use this as an entropy source. Fri, 22 Apr 2016 11:02:55 GMT Sebastian Huber [178180aa] * c/src/lib/libbsp/shared/src/bsp-fdt.c (modified) bsps: Copy FDT only if source != destination Fri, 22 Apr 2016 12:10:47 GMT Sebastian Huber [d35e6dde] * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add FSL_EIS_TENSR, etc. defines Thu, 21 Apr 2016 10:37:25 GMT Sebastian Huber [c287dc0] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/l2cache.S (added) bsp/qoriq: Flush and invalidate all L2 caches Thu, 21 Apr 2016 09:39:28 GMT Sebastian Huber [6a46d99] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Optionally initialize register HID0 Enable the L2MMU ... Sat, 16 Apr 2016 13:01:47 GMT Pavel Pisa [b752f945] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) i386/pc386: reimplemented check for unused EDID entry in fb_vesa.c to ... Tue, 22 Mar 2016 22:13:30 GMT Joel Sherrill [e65c45c] * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada/rtems-clock.adb (modified) * c/src/ada/rtems-clock.ads (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/src/clockget.c (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclockget/Makefile.am (deleted) * testsuites/sptests/spclockget/init.c (deleted) * testsuites/sptests/spclockget/spclockget.doc (deleted) * testsuites/sptests/spclockget/spclockget.scn (deleted) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) Obsolete rtems_clock_get() directive. This service was marked as ... Thu, 14 Apr 2016 05:57:38 GMT Sebastian Huber [a12724f9] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) bsp/qoriq: Fix MMU initialization for e6500 In case a hypervisor ... Fri, 01 Apr 2016 06:33:29 GMT Sebastian Huber [d2c8693] * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) bsp/atsam: Fix mbuf allocation Wed, 23 Mar 2016 15:37:09 GMT Sebastian Huber [2803314e] * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) bsp/leon3: Remove dead code Tue, 16 Feb 2016 13:11:09 GMT Alexander Krutwig [fb29ca55] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/include/bsp.h (modified) * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (added) bsp/atsam: Add network interface driver Tue, 22 Mar 2016 07:34:16 GMT Sebastian Huber [0bd49f1] * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c (modified) * c/src/lib/libbsp/arm/atsam/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram (modified) bsp/atsam: Add nocache region support Tue, 22 Mar 2016 07:29:59 GMT Sebastian Huber [935e9c7d] * c/src/lib/libbsp/arm/atsam/configure.ac (modified) bsp/atsam: Fix sizes of internal SRAM Wed, 30 Mar 2016 04:51:46 GMT Chris Johns [0a2f5bdd] * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) bsp/pc386: Fix --console=/--printk= argument parsing. Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [d33ab82] * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) v850/gdbv850sim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [f7e2ceb] * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) sparc64/usiii/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [c412142] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) sparc64/niagara/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:24 GMT Joel Sherrill [23e5746] * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) sparc/erc32/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [be13774] * c/src/lib/libbsp/sh/shared/console.c (modified) sh/shared/console.c: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [64f3cf8a] * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) sh/gensh2/startup/hw_init.c: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [09a21c5] * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) powerpc/virtex5/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [bea9a25] * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) powerpc/virtex4/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [c9705f0] * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) powerpc/virtex/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [d379a629] * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) powerpc/qemuppc/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [c5ecb95] * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) powerpc/psim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [bf820a6f] * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) powerpc/haleakala/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [ff9f426] * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) moxie/moxiesim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [7054fccf] * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) mips/rbtx4938/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [fd29877] * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) mips/rbtx4925/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [fd437ab] * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) mips/malta/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [aafd818] * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) mips/jmr3904/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [bbea36c] * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) mips/hurricane/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [241c1b8] * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) mips/csb350/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [482fdd55] * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) m68k/uC5282/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [6d27f69] * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) m68k/mvme167/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [2816b1af] * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) m68k/mvme162/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:23 GMT Joel Sherrill [1d1b6f7a] * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) m68k/mvme147s/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [68a5bfcc] * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) m68k/mvme147/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [ce019f3d] * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) m68k/mvme147/console/console.c: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [228942f5] * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) m68k/mrm332/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [8400f688] * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) m68k/mcf5329/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [6515040] * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) m68k/mcf5235/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [c3db9091] * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) m68k/mcf5225x/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [3cf6de58] * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) m68k/mcf52235/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [9bbf6cd3] * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) m68k/mcf5206elite/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [d931d28f] * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) m68k/genmcf548x/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [f68a6ec2] * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) m68k/gen68360/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [5e96a582] * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) m68k/gen68340/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [cbc20686] * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) m68k/csb360/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [aeefcc7] * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) m68k/av5282/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [3f39a77] * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) m32c/m32cbsp/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [96a7d06] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) i386/pc386/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [02f4c11] * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) arm/smdk2410/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [85fe6d04] * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) arm/rtl22xx/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [734d62e5] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) arm/gdbarmsim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [93acba9] * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) arm/edb7312/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [cf99f21] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) arm/csb336/include/bsp.h: Do not include Wed, 30 Mar 2016 14:10:53 GMT Joel Sherrill [c30d6686] * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) powerpc/gen5200/include/bsp.h: Remove unnecessary include of ... Wed, 30 Mar 2016 14:10:33 GMT Joel Sherrill [07d8f048] * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) m68k/mcf5206elite/include/bsp.h: Remove unnecessary include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [859fc2ba] * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) m68k/uC5282/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [6dde5d68] * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) m68k/mcf5329/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [aea1fc5] * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) m68k/mcf5235/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [4565fc6] * c/src/lib/libbsp/m68k/mcf5225x/console/debugio.c (modified) m68k/mcf5225x/console/debugio.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [66093623] * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) m68k/mcf5225x/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [a6e7c575] * c/src/lib/libbsp/m68k/mcf52235/console/debugio.c (modified) m68k/mcf52235/console/debugio.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:34 GMT Joel Sherrill [098a819e] * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) m68k/mcf52235/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:33 GMT Joel Sherrill [c08799e] * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) m68k/genmcf548x/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 19:05:33 GMT Joel Sherrill [00e8c344] * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) m68k/av5282/console/console.c: Remove unneeded include of ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [6ac64302] * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) v850/gdbv850sim: Remove include of from and ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [adb4fa4e] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) sparc/leon3: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [ba19d589] * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) sparc/leon2: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [7410546] * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) sparc/erc32: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [c531f6d] * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) sparc64/usiii: Remove include of from and ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [3e767ac] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) sparc64/niagara: Remove include of from and ... Tue, 29 Mar 2016 18:10:53 GMT Joel Sherrill [92902cf] * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) sh/shsim: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:52 GMT Joel Sherrill [2895f1ea] * c/src/lib/libbsp/sh/gensh4/console/console.c (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) sh/gensh4: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:52 GMT Joel Sherrill [6a0cdbe] * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) sh/gensh2: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:52 GMT Joel Sherrill [47fc739] * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) sh/gensh1: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:52 GMT Joel Sherrill [c228bd93] * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) powerpc/virtex5: Remove include of from and ... Tue, 29 Mar 2016 18:10:52 GMT Joel Sherrill [0b2ea32] * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) powerpc/virtex4: Remove include of from and ... Tue, 29 Mar 2016 18:10:52 GMT Joel Sherrill [ac0ecf27] * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) powerpc/virtex: Remove include of from and ...
