@fa3346f
11/16/99 15:41:58 |
Jennifer.Averett |
Modified file to match seen output.
4.104.114.84.95
@f9879915
11/16/99 15:41:29 |
Jennifer.Averett |
Modified output file to match seen output. Added comment to all ino …
4.104.114.84.95
@e9b00d7
11/16/99 15:40:40 |
Jennifer.Averett |
Removed compiler warning.
4.104.114.84.95
@d37aa444
11/16/99 15:39:08 |
Jennifer.Averett |
Changed asserts to tmmacros.
4.104.114.84.95
@2d82857
11/16/99 15:38:44 |
Jennifer.Averett |
Updated scn file to match new output. Left out unemplemented
parts as …
4.104.114.84.95
@47619951
11/16/99 15:33:10 |
Jennifer.Averett |
+ Changed ID to 1. ( Compilation error introduced by modifications. )
4.104.114.84.95
@1da9f4bd
11/16/99 15:30:04 |
Jennifer.Averett |
Modified scan file to match.
4.104.114.84.95
@c276c87
11/16/99 15:24:30 |
Joel Sherrill |
Added itron tests.
4.104.114.84.95
@3fb7b70b
11/16/99 14:39:56 |
Jennifer.Averett |
Changed to call tmmacros instead of assert.
4.104.114.84.95
@e672263
11/15/99 21:28:21 |
Jennifer.Averett |
Fixed verificaiton checks to call correct macro if dispatch is disabled.
4.104.114.84.95
@06380cfe
11/15/99 21:25:53 |
Jennifer.Averett |
+ Added check that a task could be sent to a dormant state
then …
4.104.114.84.95
@0f88857
11/15/99 21:19:58 |
Jennifer.Averett |
+ Changed preempt routine into two dummy tasks one that is in dormant
4.104.114.84.95
@afb11f8
11/12/99 22:00:10 |
Joel Sherrill |
+ Modified calls to use TSK_SLF for calls to self.
+ Modified calls to …
4.104.114.84.95
@624d7ca4
11/12/99 21:27:42 |
Joel Sherrill |
+ Added comments on paths tested.
4.104.114.84.95
@e8c902c
11/12/99 21:26:54 |
Joel Sherrill |
+ Added check for priority over 256.
+ Modified output to correctly …
4.104.114.84.95
@8ed3125d
11/12/99 21:24:56 |
Joel Sherrill |
Added comments for path's tested.
4.104.114.84.95
@f4771656
11/12/99 14:51:03 |
Joel Sherrill |
Test name changed to reflect placement after merger.
4.104.114.84.95
@ec0b5ce
11/12/99 14:50:42 |
Joel Sherrill |
Changed output …
4.104.114.84.95
@3136f5c9
11/12/99 14:49:47 |
Joel Sherrill |
Increased stack …
4.104.114.84.95
@6977b38
11/12/99 13:45:39 |
Joel Sherrill |
Enabled after merging message buffer code.
4.104.114.84.95
@f9078d1
11/12/99 13:22:31 |
Joel Sherrill |
Added comment block and removed include of deleted file.
4.104.114.84.95
@dc83752
11/11/99 02:23:26 |
Joel Sherrill |
Screen updated.
4.104.114.84.95
@458d4e66
11/11/99 02:23:04 |
Joel Sherrill |
Added new test sp28 to test the task variable directives.
4.104.114.84.95
@713b2ea
11/10/99 22:15:42 |
Joel Sherrill |
General cleanup. Test documentation improved. The message buffer …
4.104.114.84.95
@74db82a
11/10/99 20:36:25 |
Joel Sherrill |
rtems_semaphore_flush test from Eric Norum <eric@…>.
4.104.114.84.95
@442d0478
11/10/99 14:19:55 |
Joel Sherrill |
Combination of committing some new files which had been overlooked
and …
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@dcc1f6b6
11/10/99 13:45:54 |
Joel Sherrill |
Added support for ITRON tests.
4.104.114.84.95
@bab5ba44
11/09/99 23:28:04 |
Joel Sherrill |
Added more tasking tests.
4.104.114.84.95
@e099180
11/09/99 23:27:05 |
Joel Sherrill |
Merged tests from Task group.
4.104.114.84.95
@3d67661
11/09/99 23:10:48 |
Joel Sherrill |
Added nesting count for suspend/resume.
4.104.114.84.95
@70e9af9
11/09/99 22:45:35 |
Joel Sherrill |
Changed B, H, and W variables to BVar, HVar, and WVar to avoid …
4.104.114.84.95
@ad502d18
11/09/99 22:14:21 |
Joel Sherrill |
Renamed classes to avoid single letter class names.
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@a8df60b
11/09/99 13:38:00 |
Joel Sherrill |
New test for POSIX Message Queues added.
4.104.114.84.95
@27eb3ec
11/09/99 13:36:26 |
Joel Sherrill |
New files.
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@4c1b914
11/02/99 16:39:44 |
Joel Sherrill |
Minor changes to make the screen match a bit better.
4.104.114.84.95
@78edd44
11/02/99 16:38:19 |
Joel Sherrill |
Minor fixes to make screen match a bit better.
4.104.114.84.95
@3251b55
11/02/99 16:29:56 |
Joel Sherrill |
Added more proper checking of F_GETFL and F_SETFL.
Disabled test of …
4.104.114.84.95
@a49a7f3d
11/02/99 15:22:00 |
Joel Sherrill |
Backed out change that increased the minimum stack size since it
was …
4.104.114.84.95
@f59df6b2
11/02/99 15:19:43 |
Joel Sherrill |
Modified to use minimum stack size and reserve the necessary amount
of …
4.104.114.84.95
@2e3e407
11/01/99 20:21:17 |
Joel Sherrill |
Increased stack space for all initialization tasks in tmtests.
4.104.114.84.95
@5fe6b21a
11/01/99 20:14:35 |
Joel Sherrill |
Increased stack space of a task.
4.104.114.84.95
@328aa64c
11/01/99 20:11:24 |
Joel Sherrill |
Increased stack space of task 2.
4.104.114.84.95
@4443984
11/01/99 20:08:05 |
Joel Sherrill |
Increased stack space for a task.
4.104.114.84.95
@c42e6c72
11/01/99 20:06:02 |
Joel Sherrill |
Increased stack space for task 1.
4.104.114.84.95
@5c104e08
10/28/99 15:12:10 |
Joel Sherrill |
New test added - psxcancel. This is just a shell for now.
4.104.114.84.95
@2ca64b5
10/26/99 02:32:47 |
Joel Sherrill |
New ideas on test incorporated.
4.104.114.84.95
@4e69f5b7
10/25/99 15:55:58 |
Joel Sherrill |
Added notes for new test.
4.104.114.84.95
@1232196a
10/25/99 14:14:07 |
Joel Sherrill |
Added sp26 which tests the rtems_task_is_suspended directive.
4.104.114.84.95
@9060699
10/25/99 14:13:14 |
Joel Sherrill |
Modified to ease comparison of screen to target output.
4.104.114.84.95
@48296038
10/25/99 14:11:12 |
Joel Sherrill |
Modified to reflect test change where reinitialize mutex test case was …
4.104.114.84.95
@524767cb
10/25/99 14:10:38 |
Joel Sherrill |
Removed reinitialize mutex test case to reflect earlier code change in …
4.104.114.84.95
@d013d05
10/21/99 16:48:06 |
Joel Sherrill |
Increased stack size of initialization thread.
4.104.114.84.95
@1f350ef9
10/06/99 20:54:06 |
Joel Sherrill |
Removed aclocal.m4 generated from aclocal macros
4.104.114.84.95
@54eccb1a
10/06/99 20:52:34 |
Joel Sherrill |
Removed configure generated from configure.in
4.104.114.84.95
@7a81160
10/05/99 19:21:54 |
Joel Sherrill |
Removed ifdef on go32.
4.104.114.84.95
@4075af6f
10/05/99 13:49:54 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@7d96321
10/04/99 19:41:34 |
Joel Sherrill |
Modifications necessary to support testing of exitting a pthread from …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@b62a92c
10/04/99 18:20:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The patch below …
4.104.114.84.95
@4f021c0
10/04/99 17:33:23 |
Joel Sherrill |
Removed Makefile.in generated from Makefile.am
4.104.114.84.95
@e50e3eff
10/04/99 13:54:25 |
Joel Sherrill |
New test for getenv/putenv added by Joel.
4.104.114.84.95
@473b4e5
10/04/99 13:30:15 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@b808038
08/18/99 20:59:36 |
Joel Sherrill |
Reran and replaced screen after report from Gerwin Pfab …
4.104.114.84.95
@908436c1
08/10/99 15:38:09 |
Joel Sherrill |
New configuration files added by patch from
Ralf Corsepius …
4.104.114.84.95
@01be59d
08/10/99 15:08:58 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct a minor …
4.104.114.84.95
@3a8915e
08/06/99 17:55:25 |
Joel Sherrill |
Patch rtems-rc-19990709-6-diff from Ralf Corsepius …
4.104.114.84.95
@ae2ddb8
08/02/99 15:40:27 |
Joel Sherrill |
The patch …
4.104.114.84.95
@1896a650
07/30/99 17:52:50 |
Joel Sherrill |
The main topic …
4.104.114.84.95
@29e68b75
07/26/99 21:26:44 |
Joel Sherrill |
This patch is …
4.104.114.84.95
@08b5f55
07/26/99 20:31:49 |
Joel Sherrill |
A bug in …
4.104.114.84.95
@eb299afc
07/26/99 20:20:22 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
4.104.114.84.95
@10794a7
07/01/99 22:08:33 |
Joel Sherrill |
Modified to reflect change in calling sequence of mount().
4.104.114.84.95
@dbf969e
07/01/99 22:08:13 |
Joel Sherrill |
Test modified to reflect change in calling sequence of mount().
4.104.114.84.95
@8c92fa3
06/16/99 14:55:28 |
Joel Sherrill |
Patcg from Ralf Corsepius <corsepiu@…>:
-- configure …
4.104.114.84.95
@d2d22780
06/15/99 22:46:44 |
Joel Sherrill |
> When I run …
4.104.114.84.95
@15aa5ffb
06/14/99 18:54:24 |
Joel Sherrill |
Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius …
4.104.114.84.95
@c7115bb
05/28/99 16:10:29 |
Joel Sherrill |
Don't install this executable. It should only be built.
4.104.114.84.95
@fbec4a1
05/18/99 17:33:52 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@d7851582
05/17/99 22:15:56 |
Joel Sherrill |
Added simple test to find minimum code size of executive with this BSP …
4.104.114.84.95
@fcf17a4
05/14/99 16:25:15 |
Joel Sherrill |
Added testing for C++ exceptions from Rosimildo DaSilva? …
4.104.114.84.95
@1059abcd
04/19/99 15:37:36 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
This one is …
4.104.114.84.95
@8cdb582
04/12/99 15:41:33 |
Joel Sherrill |
This patch …
4.104.114.84.95
@5cf555e1
04/06/99 22:04:08 |
Joel Sherrill |
Corrections by Jennifer.
4.104.114.84.95
@f72dd2a
04/01/99 16:58:06 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to address …
4.104.114.84.95
@3f06c298
03/31/99 23:22:42 |
Jennifer.Averett |
Added prints for calls into the file system. Added O_EXCL for an open …
4.104.114.84.95
@912f74ae
03/31/99 23:20:43 |
Jennifer.Averett |
Modified file to match output.
4.104.114.84.95
@eaf0e8eb
03/29/99 18:06:00 |
Jennifer.Averett |
Correctd name length to account for new IMFS max name length of 32.
4.104.114.84.95
@1ed9d57
03/29/99 18:05:01 |
Jennifer.Averett |
Fixed expected return status from lseek to look for not failure (-1).
4.104.114.84.95
@2ada69a
03/29/99 17:59:46 |
Jennifer.Averett |
Changed expected status lseek to look for not failure (-1).
4.104.114.84.95
@244ecd9
03/24/99 23:14:36 |
Joel Sherrill |
These files were not added as part of a recent patch from
Ralf …
4.104.114.84.95
@9b8baa1
03/23/99 18:02:17 |
Joel Sherrill |
Automake II patch from Ralf Corsepius <corsepiu@…>. …
4.104.114.84.95
@d8ff793
03/19/99 22:27:02 |
Joel Sherrill |
Towards automake XI patch from Ralf Corsepius …
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
