Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/tests
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @2ca64b5   10/26/99 02:32:47 Joel Sherrill New ideas on test incorporated. 4.104.114.84.95
(edit) @4e69f5b7   10/25/99 15:55:58 Joel Sherrill Added notes for new test. 4.104.114.84.95
(edit) @1232196a   10/25/99 14:14:07 Joel Sherrill Added sp26 which tests the rtems_task_is_suspended directive. 4.104.114.84.95
(edit) @9060699   10/25/99 14:13:14 Joel Sherrill Modified to ease comparison of screen to target output. 4.104.114.84.95
(edit) @48296038   10/25/99 14:11:12 Joel Sherrill Modified to reflect test change where reinitialize mutex test case was … 4.104.114.84.95
(edit) @524767cb   10/25/99 14:10:38 Joel Sherrill Removed reinitialize mutex test case to reflect earlier code change in … 4.104.114.84.95
(edit) @d013d05   10/21/99 16:48:06 Joel Sherrill Increased stack size of initialization thread. 4.104.114.84.95
(edit) @1f350ef9   10/06/99 20:54:06 Joel Sherrill Removed aclocal.m4 generated from aclocal macros 4.104.114.84.95
(edit) @54eccb1a   10/06/99 20:52:34 Joel Sherrill Removed configure generated from configure.in 4.104.114.84.95
(edit) @7a81160   10/05/99 19:21:54 Joel Sherrill Removed ifdef on go32. 4.104.114.84.95
(edit) @4075af6f   10/05/99 13:49:54 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @7d96321   10/04/99 19:41:34 Joel Sherrill Modifications necessary to support testing of exitting a pthread from … 4.104.114.84.95
(edit) @811804fe   10/04/99 19:15:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make fix bug … 4.104.114.84.95
(edit) @b62a92c   10/04/99 18:20:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch below … 4.104.114.84.95
(edit) @4f021c0   10/04/99 17:33:23 Joel Sherrill Removed Makefile.in generated from Makefile.am 4.104.114.84.95
(edit) @e50e3eff   10/04/99 13:54:25 Joel Sherrill New test for getenv/putenv added by Joel. 4.104.114.84.95
(edit) @473b4e5   10/04/99 13:30:15 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @b808038   08/18/99 20:59:36 Joel Sherrill Reran and replaced screen after report from Gerwin Pfab … 4.104.114.84.95
(edit) @908436c1   08/10/99 15:38:09 Joel Sherrill New configuration files added by patch from Ralf Corsepius … 4.104.114.84.95
(edit) @01be59d   08/10/99 15:08:58 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to correct a minor … 4.104.114.84.95
(edit) @3a8915e   08/06/99 17:55:25 Joel Sherrill Patch rtems-rc-19990709-6-diff from Ralf Corsepius … 4.104.114.84.95
(edit) @ae2ddb8   08/02/99 15:40:27 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch … 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @29e68b75   07/26/99 21:26:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch is … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @eb299afc   07/26/99 20:20:22 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @10794a7   07/01/99 22:08:33 Joel Sherrill Modified to reflect change in calling sequence of mount(). 4.104.114.84.95
(edit) @dbf969e   07/01/99 22:08:13 Joel Sherrill Test modified to reflect change in calling sequence of mount(). 4.104.114.84.95
(edit) @8c92fa3   06/16/99 14:55:28 Joel Sherrill Patcg from Ralf Corsepius <corsepiu@…>: -- configure … 4.104.114.84.95
(edit) @d2d22780   06/15/99 22:46:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: > When I run … 4.104.114.84.95
(edit) @15aa5ffb   06/14/99 18:54:24 Joel Sherrill Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius … 4.104.114.84.95
(edit) @c7115bb   05/28/99 16:10:29 Joel Sherrill Don't install this executable. It should only be built. 4.104.114.84.95
(edit) @fbec4a1   05/18/99 17:33:52 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @d7851582   05/17/99 22:15:56 Joel Sherrill Added simple test to find minimum code size of executive with this BSP … 4.104.114.84.95
(edit) @fcf17a4   05/14/99 16:25:15 Joel Sherrill Added testing for C++ exceptions from Rosimildo DaSilva?4.104.114.84.95
(edit) @1059abcd   04/19/99 15:37:36 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @196094eb   04/19/99 13:19:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This one is … 4.104.114.84.95
(edit) @8cdb582   04/12/99 15:41:33 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch … 4.104.114.84.95
(edit) @5cf555e1   04/06/99 22:04:08 Joel Sherrill Corrections by Jennifer. 4.104.114.84.95
(edit) @f72dd2a   04/01/99 16:58:06 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to address … 4.104.114.84.95
(edit) @3f06c298   03/31/99 23:22:42 Jennifer.Averett Added prints for calls into the file system. Added O_EXCL for an open … 4.104.114.84.95
(edit) @912f74ae   03/31/99 23:20:43 Jennifer.Averett Modified file to match output. 4.104.114.84.95
(edit) @eaf0e8eb   03/29/99 18:06:00 Jennifer.Averett Correctd name length to account for new IMFS max name length of 32. 4.104.114.84.95
(edit) @1ed9d57   03/29/99 18:05:01 Jennifer.Averett Fixed expected return status from lseek to look for not failure (-1). 4.104.114.84.95
(edit) @2ada69a   03/29/99 17:59:46 Jennifer.Averett Changed expected status lseek to look for not failure (-1). 4.104.114.84.95
(edit) @244ecd9   03/24/99 23:14:36 Joel Sherrill These files were not added as part of a recent patch from Ralf … 4.104.114.84.95
(edit) @9b8baa1   03/23/99 18:02:17 Joel Sherrill Automake II patch from Ralf Corsepius <corsepiu@…>. … 4.104.114.84.95
(edit) @d8ff793   03/19/99 22:27:02 Joel Sherrill Towards automake XI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @f4a8ee1   03/17/99 16:01:03 Joel Sherrill Unlimited objects patch from Chris Johns <ccj@…>. Email … 4.104.114.84.95
(edit) @cda0c07   03/16/99 01:41:48 Joel Sherrill Commented out test case that no long works since addition of POSIX timers. 4.104.114.84.95
(edit) @8548fe0   02/18/99 18:36:05 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @386289b   02/10/99 17:07:54 Joel Sherrill Added this file. 4.104.114.84.95
(edit) @3234c27   02/10/99 17:06:53 Joel Sherrill Don't build spfatal since it won't run anyway. 4.104.114.84.95
(edit) @f93d996   02/10/99 17:06:27 Joel Sherrill Changed file name. 4.104.114.84.95
(edit) @cd792a86   02/03/99 22:12:28 Joel Sherrill Patch from John S Gwynne <jsg@…> for malloctest. His … 4.104.114.84.95
(edit) @c30d04d7   02/03/99 16:21:11 Joel Sherrill New test from Juan Zamorano Flores <jzamora@…> … 4.104.114.84.95
(edit) @657be8f5   02/03/99 16:20:38 Joel Sherrill New files from Juan Zamorano Flores <jzamora@…> … 4.104.114.84.95
(edit) @01a2e18   01/31/99 20:52:35 Joel Sherrill Removed unneeded include of libio_.h. 4.104.114.84.95
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @cd155be   12/03/98 23:02:24 Joel Sherrill Removed spaces. 4.104.114.84.95
(edit) @41616f6   12/03/98 23:01:22 Joel Sherrill Changed to account for ownership only being tracked when a priority … 4.104.114.84.95
(edit) @6afa6e3   12/03/98 22:45:57 Jennifer.Averett Removed all M from the file. 4.104.114.84.95
(edit) @dc8acc14   12/03/98 22:45:45 Jennifer.Averett Added psx to the front of all test names. 4.104.114.84.95
(edit) @0422a7a5   12/03/98 22:42:13 Jennifer.Averett Removed all M from the scn file. 4.104.114.84.95
(edit) @c2f9b97   12/03/98 22:41:57 Jennifer.Averett Cleaned up test. Updated scn files to match present expected test output. 4.104.114.84.95
(edit) @5b8e885d   12/03/98 22:41:33 Jennifer.Averett Added Comment that a result is valid at 4 or 5 seconds. 4.104.114.84.95
(edit) @fae441b   12/03/98 22:41:20 Jennifer.Averett Updated scn files to match present expected test output. 4.104.114.84.95
(edit) @f98db20   12/03/98 22:41:01 Jennifer.Averett Renamed all directories to start with psx. 4.104.114.84.95
(edit) @b81eeb3   12/03/98 22:40:39 Jennifer.Averett Added a posix time test. Renamed all directories to start with psx. 4.104.114.84.95
(edit) @146263fd   12/03/98 21:58:53 Joel Sherrill Modified to support test names longer than two characters plus the … 4.104.114.84.95
(edit) @012bb56   12/03/98 21:57:50 Joel Sherrill Insure that the same output occurs when multiprocessing is disabled. 4.104.114.84.95
(edit) @6b9450d   12/03/98 21:56:10 Joel Sherrill Moved cpuuse.h to rtems subdirectory. 4.104.114.84.95
(edit) @bfc3533   12/01/98 13:56:46 Joel Sherrill Include files now installed as <rtems/*.h>. 4.104.114.84.95
(edit) @07a3253d   11/23/98 19:07:58 Joel Sherrill Added base version of file system infrastructure. This includes a … 4.104.114.84.95
(edit) @cd3fb80   11/23/98 18:58:48 Joel Sherrill Added new tests in support of the file system infrastructure. 4.104.114.84.95
(edit) @0895bdb   11/23/98 18:57:48 Joel Sherrill Added tests in support of the file system infrastructure. 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @711a2a1   10/05/98 21:26:07 Joel Sherrill New file based on information from Eric Norum <eric@…>. 4.104.114.84.95
(edit) @082fc2d   10/05/98 12:45:53 Joel Sherrill Fixed use of incorrect macro for minimum stack size. 4.104.114.84.95
(edit) @ecc3fe3   09/23/98 16:41:00 Joel Sherrill IDLE task stack size now specified as a field in the CPU Table for all … 4.104.114.84.95
(edit) @92ef225   08/03/98 15:06:27 Joel Sherrill Under allcoated task stacks. 4.104.114.84.95
(edit) @93e3b8a3   08/01/98 15:01:59 Joel Sherrill Moved to network demos 4.104.114.84.95
(edit) @dbab462   07/24/98 16:09:51 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @dbaf51a   07/23/98 22:13:10 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: Here is a patch … 4.104.114.84.95
(edit) @a56e475f   07/17/98 15:42:39 Joel Sherrill Turned stack checker on. 4.104.114.84.95
(edit) @9b413ea   06/12/98 20:55:21 Joel Sherrill Patch from Eric Norum to avoid printing from context switch user … 4.104.114.84.95
(edit) @2a53f31   06/09/98 15:23:38 Joel Sherrill Fixed comment block at the beginning of the file for a copyright date … 4.104.114.84.95
(edit) @47d1f5d8   05/04/98 12:41:42 Joel Sherrill Fixed prototype of Fatal_Extension. Fixed interface to cofndefs.h for … 4.104.114.84.95
(edit) @990f857   04/30/98 14:14:12 Joel Sherrill botched file -- removed from repository and readded 4.104.114.84.95
(edit) @2993cd3f   04/29/98 18:41:53 Joel Sherrill Added support for debug variants on tests. 4.104.114.84.95
(edit) @9a993ed5   04/27/98 13:51:23 Joel Sherrill Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory … 4.104.114.84.95
(edit) @6ce14e7   04/27/98 13:51:02 Joel Sherrill Fixed screen to match actual output. 4.104.114.84.95
(edit) @39b3d87   04/27/98 13:44:54 Joel Sherrill Reset the pthread attributes structure so the proper error would be … 4.104.114.84.95
(edit) @d07d3eec   04/15/98 15:09:38 Joel Sherrill Initial sets of user extensions now have memory allocated on the fly … 4.104.114.84.95
(edit) @45111d77   04/06/98 20:29:58 Joel Sherrill Increased stack size so test would run in debug mode. 4.104.114.84.95
(edit) @c895f42a   03/30/98 14:03:04 Joel Sherrill Were looking at the wrong C++ variable. 4.104.114.84.95
(edit) @3cc03ac   03/26/98 12:39:49 Joel Sherrill HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. 4.104.114.84.95
(edit) @3ec7bfc   03/24/98 16:24:39 Joel Sherrill Rename hppa1_1 to hppa1.1 and switched to using XXX macros for the … 4.104.114.84.95
