@1f350ef9
10/06/99 20:54:06 |
Joel Sherrill |
Removed aclocal.m4 generated from aclocal macros
4.104.114.84.95
@54eccb1a
10/06/99 20:52:34 |
Joel Sherrill |
Removed configure generated from configure.in
4.104.114.84.95
@7a81160
10/05/99 19:21:54 |
Joel Sherrill |
Removed ifdef on go32.
4.104.114.84.95
@4075af6f
10/05/99 13:49:54 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@7d96321
10/04/99 19:41:34 |
Joel Sherrill |
Modifications necessary to support testing of exitting a pthread from …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@b62a92c
10/04/99 18:20:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The patch below …
4.104.114.84.95
@4f021c0
10/04/99 17:33:23 |
Joel Sherrill |
Removed Makefile.in generated from Makefile.am
4.104.114.84.95
@e50e3eff
10/04/99 13:54:25 |
Joel Sherrill |
New test for getenv/putenv added by Joel.
4.104.114.84.95
@473b4e5
10/04/99 13:30:15 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@b808038
08/18/99 20:59:36 |
Joel Sherrill |
Reran and replaced screen after report from Gerwin Pfab …
4.104.114.84.95
@908436c1
08/10/99 15:38:09 |
Joel Sherrill |
New configuration files added by patch from
Ralf Corsepius …
4.104.114.84.95
@01be59d
08/10/99 15:08:58 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct a minor …
4.104.114.84.95
@3a8915e
08/06/99 17:55:25 |
Joel Sherrill |
Patch rtems-rc-19990709-6-diff from Ralf Corsepius …
4.104.114.84.95
@ae2ddb8
08/02/99 15:40:27 |
Joel Sherrill |
The patch …
4.104.114.84.95
@1896a650
07/30/99 17:52:50 |
Joel Sherrill |
The main topic …
4.104.114.84.95
@29e68b75
07/26/99 21:26:44 |
Joel Sherrill |
This patch is …
4.104.114.84.95
@08b5f55
07/26/99 20:31:49 |
Joel Sherrill |
A bug in …
4.104.114.84.95
@eb299afc
07/26/99 20:20:22 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
4.104.114.84.95
@10794a7
07/01/99 22:08:33 |
Joel Sherrill |
Modified to reflect change in calling sequence of mount().
4.104.114.84.95
@dbf969e
07/01/99 22:08:13 |
Joel Sherrill |
Test modified to reflect change in calling sequence of mount().
4.104.114.84.95
@8c92fa3
06/16/99 14:55:28 |
Joel Sherrill |
Patcg from Ralf Corsepius <corsepiu@…>:
-- configure …
4.104.114.84.95
@d2d22780
06/15/99 22:46:44 |
Joel Sherrill |
> When I run …
4.104.114.84.95
@15aa5ffb
06/14/99 18:54:24 |
Joel Sherrill |
Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius …
4.104.114.84.95
@c7115bb
05/28/99 16:10:29 |
Joel Sherrill |
Don't install this executable. It should only be built.
4.104.114.84.95
@fbec4a1
05/18/99 17:33:52 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@d7851582
05/17/99 22:15:56 |
Joel Sherrill |
Added simple test to find minimum code size of executive with this BSP …
4.104.114.84.95
@fcf17a4
05/14/99 16:25:15 |
Joel Sherrill |
Added testing for C++ exceptions from Rosimildo DaSilva? …
4.104.114.84.95
@1059abcd
04/19/99 15:37:36 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
This one is …
4.104.114.84.95
@8cdb582
04/12/99 15:41:33 |
Joel Sherrill |
This patch …
4.104.114.84.95
@5cf555e1
04/06/99 22:04:08 |
Joel Sherrill |
Corrections by Jennifer.
4.104.114.84.95
@f72dd2a
04/01/99 16:58:06 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to address …
4.104.114.84.95
@3f06c298
03/31/99 23:22:42 |
Jennifer.Averett |
Added prints for calls into the file system. Added O_EXCL for an open …
4.104.114.84.95
@912f74ae
03/31/99 23:20:43 |
Jennifer.Averett |
Modified file to match output.
4.104.114.84.95
@eaf0e8eb
03/29/99 18:06:00 |
Jennifer.Averett |
Correctd name length to account for new IMFS max name length of 32.
4.104.114.84.95
@1ed9d57
03/29/99 18:05:01 |
Jennifer.Averett |
Fixed expected return status from lseek to look for not failure (-1).
4.104.114.84.95
@2ada69a
03/29/99 17:59:46 |
Jennifer.Averett |
Changed expected status lseek to look for not failure (-1).
4.104.114.84.95
@244ecd9
03/24/99 23:14:36 |
Joel Sherrill |
These files were not added as part of a recent patch from
Ralf …
4.104.114.84.95
@9b8baa1
03/23/99 18:02:17 |
Joel Sherrill |
Automake II patch from Ralf Corsepius <corsepiu@…>. …
4.104.114.84.95
@d8ff793
03/19/99 22:27:02 |
Joel Sherrill |
Towards automake XI patch from Ralf Corsepius …
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@cda0c07
03/16/99 01:41:48 |
Joel Sherrill |
Commented out test case that no long works since addition of POSIX timers.
4.104.114.84.95
@8548fe0
02/18/99 18:36:05 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@386289b
02/10/99 17:07:54 |
Joel Sherrill |
Added this file.
4.104.114.84.95
@3234c27
02/10/99 17:06:53 |
Joel Sherrill |
Don't build spfatal since it won't run anyway.
4.104.114.84.95
@f93d996
02/10/99 17:06:27 |
Joel Sherrill |
Changed file name.
4.104.114.84.95
@cd792a86
02/03/99 22:12:28 |
Joel Sherrill |
Patch from John S Gwynne <jsg@…> for malloctest. His …
4.104.114.84.95
@c30d04d7
02/03/99 16:21:11 |
Joel Sherrill |
New test from Juan Zamorano Flores <jzamora@…> …
4.104.114.84.95
@657be8f5
02/03/99 16:20:38 |
Joel Sherrill |
New files from Juan Zamorano Flores <jzamora@…> …
4.104.114.84.95
@01a2e18
01/31/99 20:52:35 |
Joel Sherrill |
Removed unneeded include of libio_.h.
4.104.114.84.95
@0162910
12/14/98 23:15:38 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to rename all
.s …
4.104.114.84.95
@cd155be
12/03/98 23:02:24 |
Joel Sherrill |
Removed spaces.
4.104.114.84.95
@41616f6
12/03/98 23:01:22 |
Joel Sherrill |
Changed to account for ownership only being tracked when a priority …
4.104.114.84.95
@6afa6e3
12/03/98 22:45:57 |
Jennifer.Averett |
Removed all M from the file.
4.104.114.84.95
@dc8acc14
12/03/98 22:45:45 |
Jennifer.Averett |
Added psx to the front of all test names.
4.104.114.84.95
@0422a7a5
12/03/98 22:42:13 |
Jennifer.Averett |
Removed all M from the scn file.
4.104.114.84.95
@c2f9b97
12/03/98 22:41:57 |
Jennifer.Averett |
Cleaned up test.
Updated scn files to match present expected test output.
4.104.114.84.95
@5b8e885d
12/03/98 22:41:33 |
Jennifer.Averett |
Added Comment that a result is valid at 4 or 5 seconds.
4.104.114.84.95
@fae441b
12/03/98 22:41:20 |
Jennifer.Averett |
4.104.114.84.95
@f98db20
12/03/98 22:41:01 |
Jennifer.Averett |
Renamed all directories to start with psx.
4.104.114.84.95
@b81eeb3
12/03/98 22:40:39 |
Jennifer.Averett |
Added a posix time test.
4.104.114.84.95
@146263fd
12/03/98 21:58:53 |
Joel Sherrill |
Modified to support test names longer than two characters plus the …
4.104.114.84.95
@012bb56
12/03/98 21:57:50 |
Joel Sherrill |
Insure that the same output occurs when multiprocessing is disabled.
4.104.114.84.95
@6b9450d
12/03/98 21:56:10 |
Joel Sherrill |
Moved cpuuse.h to rtems subdirectory.
4.104.114.84.95
@bfc3533
12/01/98 13:56:46 |
Joel Sherrill |
Include files now installed as <rtems/*.h>.
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@cd3fb80
11/23/98 18:58:48 |
Joel Sherrill |
Added new tests in support of the file system infrastructure.
4.104.114.84.95
@0895bdb
11/23/98 18:57:48 |
Joel Sherrill |
Added tests in support of the file system infrastructure.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@711a2a1
10/05/98 21:26:07 |
Joel Sherrill |
New file based on information from Eric Norum <eric@…>.
4.104.114.84.95
@082fc2d
10/05/98 12:45:53 |
Joel Sherrill |
Fixed use of incorrect macro for minimum stack size.
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@92ef225
08/03/98 15:06:27 |
Joel Sherrill |
Under allcoated task stacks.
4.104.114.84.95
@93e3b8a3
08/01/98 15:01:59 |
Joel Sherrill |
Moved to network demos
4.104.114.84.95
@dbab462
07/24/98 16:09:51 |
Joel Sherrill |
Patch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@dbaf51a
07/23/98 22:13:10 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
Here is a patch …
4.104.114.84.95
@a56e475f
07/17/98 15:42:39 |
Joel Sherrill |
Turned stack checker on.
4.104.114.84.95
@9b413ea
06/12/98 20:55:21 |
Joel Sherrill |
Patch from Eric Norum to avoid printing from context switch user …
4.104.114.84.95
@2a53f31
06/09/98 15:23:38 |
Joel Sherrill |
Fixed comment block at the beginning of the file for a copyright date …
4.104.114.84.95
@47d1f5d8
05/04/98 12:41:42 |
Joel Sherrill |
Fixed prototype of Fatal_Extension.
Fixed interface to cofndefs.h for …
4.104.114.84.95
@990f857
04/30/98 14:14:12 |
Joel Sherrill |
botched file -- removed from repository and readded
4.104.114.84.95
@2993cd3f
04/29/98 18:41:53 |
Joel Sherrill |
Added support for debug variants on tests.
4.104.114.84.95
@9a993ed5
04/27/98 13:51:23 |
Joel Sherrill |
Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory …
4.104.114.84.95
@6ce14e7
04/27/98 13:51:02 |
Joel Sherrill |
Fixed screen to match actual output.
4.104.114.84.95
@39b3d87
04/27/98 13:44:54 |
Joel Sherrill |
Reset the pthread attributes structure so the proper error would be …
4.104.114.84.95
@d07d3eec
04/15/98 15:09:38 |
Joel Sherrill |
Initial sets of user extensions now have memory allocated on the fly …
4.104.114.84.95
@45111d77
04/06/98 20:29:58 |
Joel Sherrill |
Increased stack size so test would run in debug mode.
4.104.114.84.95
@c895f42a
03/30/98 14:03:04 |
Joel Sherrill |
Were looking at the wrong C++ variable.
4.104.114.84.95
@3cc03ac
03/26/98 12:39:49 |
Joel Sherrill |
HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS.
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@77bf1b1
03/21/98 15:37:43 |
Joel Sherrill |
Corrected typo in copyright notice.
4.104.114.84.95
@e25b7ee
03/03/98 20:43:14 |
Joel Sherrill |
Corrected to indicate test cases which were skipped.
4.104.114.84.95
@b1b4fd5a
02/20/98 19:59:41 |
Joel Sherrill |
Modified to reflect new restrictions on mutex being released.
4.104.114.84.95
@de76809
02/20/98 19:59:23 |
Joel Sherrill |
Removed extra line.
4.104.114.84.95
@2c45683
02/20/98 19:04:23 |
Joel Sherrill |
Increased stack space to let test run to completion.
4.104.114.84.95
@fde74a3
02/19/98 22:55:02 |
Joel Sherrill |
Increased stack space of tasks.
4.104.114.84.95
@6eba9b79
02/19/98 22:52:55 |
Joel Sherrill |
Increased stack size of initialization task.
4.104.114.84.95
