Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/tests
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @cd155be   12/03/98 23:02:24 Joel Sherrill Removed spaces. 4.104.114.84.95
(edit) @41616f6   12/03/98 23:01:22 Joel Sherrill Changed to account for ownership only being tracked when a priority … 4.104.114.84.95
(edit) @6afa6e3   12/03/98 22:45:57 Jennifer.Averett Removed all M from the file. 4.104.114.84.95
(edit) @dc8acc14   12/03/98 22:45:45 Jennifer.Averett Added psx to the front of all test names. 4.104.114.84.95
(edit) @0422a7a5   12/03/98 22:42:13 Jennifer.Averett Removed all M from the scn file. 4.104.114.84.95
(edit) @c2f9b97   12/03/98 22:41:57 Jennifer.Averett Cleaned up test. Updated scn files to match present expected test output. 4.104.114.84.95
(edit) @5b8e885d   12/03/98 22:41:33 Jennifer.Averett Added Comment that a result is valid at 4 or 5 seconds. 4.104.114.84.95
(edit) @fae441b   12/03/98 22:41:20 Jennifer.Averett Updated scn files to match present expected test output. 4.104.114.84.95
(edit) @f98db20   12/03/98 22:41:01 Jennifer.Averett Renamed all directories to start with psx. 4.104.114.84.95
(edit) @b81eeb3   12/03/98 22:40:39 Jennifer.Averett Added a posix time test. Renamed all directories to start with psx. 4.104.114.84.95
(edit) @146263fd   12/03/98 21:58:53 Joel Sherrill Modified to support test names longer than two characters plus the … 4.104.114.84.95
(edit) @012bb56   12/03/98 21:57:50 Joel Sherrill Insure that the same output occurs when multiprocessing is disabled. 4.104.114.84.95
(edit) @6b9450d   12/03/98 21:56:10 Joel Sherrill Moved cpuuse.h to rtems subdirectory. 4.104.114.84.95
(edit) @bfc3533   12/01/98 13:56:46 Joel Sherrill Include files now installed as <rtems/*.h>. 4.104.114.84.95
(edit) @07a3253d   11/23/98 19:07:58 Joel Sherrill Added base version of file system infrastructure. This includes a … 4.104.114.84.95
(edit) @cd3fb80   11/23/98 18:58:48 Joel Sherrill Added new tests in support of the file system infrastructure. 4.104.114.84.95
(edit) @0895bdb   11/23/98 18:57:48 Joel Sherrill Added tests in support of the file system infrastructure. 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @711a2a1   10/05/98 21:26:07 Joel Sherrill New file based on information from Eric Norum <eric@…>. 4.104.114.84.95
(edit) @082fc2d   10/05/98 12:45:53 Joel Sherrill Fixed use of incorrect macro for minimum stack size. 4.104.114.84.95
(edit) @ecc3fe3   09/23/98 16:41:00 Joel Sherrill IDLE task stack size now specified as a field in the CPU Table for all … 4.104.114.84.95
(edit) @92ef225   08/03/98 15:06:27 Joel Sherrill Under allcoated task stacks. 4.104.114.84.95
(edit) @93e3b8a3   08/01/98 15:01:59 Joel Sherrill Moved to network demos 4.104.114.84.95
(edit) @dbab462   07/24/98 16:09:51 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @dbaf51a   07/23/98 22:13:10 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: Here is a patch … 4.104.114.84.95
(edit) @a56e475f   07/17/98 15:42:39 Joel Sherrill Turned stack checker on. 4.104.114.84.95
(edit) @9b413ea   06/12/98 20:55:21 Joel Sherrill Patch from Eric Norum to avoid printing from context switch user … 4.104.114.84.95
(edit) @2a53f31   06/09/98 15:23:38 Joel Sherrill Fixed comment block at the beginning of the file for a copyright date … 4.104.114.84.95
(edit) @47d1f5d8   05/04/98 12:41:42 Joel Sherrill Fixed prototype of Fatal_Extension. Fixed interface to cofndefs.h for … 4.104.114.84.95
(edit) @990f857   04/30/98 14:14:12 Joel Sherrill botched file -- removed from repository and readded 4.104.114.84.95
(edit) @2993cd3f   04/29/98 18:41:53 Joel Sherrill Added support for debug variants on tests. 4.104.114.84.95
(edit) @9a993ed5   04/27/98 13:51:23 Joel Sherrill Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory … 4.104.114.84.95
(edit) @6ce14e7   04/27/98 13:51:02 Joel Sherrill Fixed screen to match actual output. 4.104.114.84.95
(edit) @39b3d87   04/27/98 13:44:54 Joel Sherrill Reset the pthread attributes structure so the proper error would be … 4.104.114.84.95
(edit) @d07d3eec   04/15/98 15:09:38 Joel Sherrill Initial sets of user extensions now have memory allocated on the fly … 4.104.114.84.95
(edit) @45111d77   04/06/98 20:29:58 Joel Sherrill Increased stack size so test would run in debug mode. 4.104.114.84.95
(edit) @c895f42a   03/30/98 14:03:04 Joel Sherrill Were looking at the wrong C++ variable. 4.104.114.84.95
(edit) @3cc03ac   03/26/98 12:39:49 Joel Sherrill HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. 4.104.114.84.95
(edit) @3ec7bfc   03/24/98 16:24:39 Joel Sherrill Rename hppa1_1 to hppa1.1 and switched to using XXX macros for the … 4.104.114.84.95
(edit) @77bf1b1   03/21/98 15:37:43 Joel Sherrill Corrected typo in copyright notice. 4.104.114.84.95
(edit) @e25b7ee   03/03/98 20:43:14 Joel Sherrill Corrected to indicate test cases which were skipped. 4.104.114.84.95
(edit) @b1b4fd5a   02/20/98 19:59:41 Joel Sherrill Modified to reflect new restrictions on mutex being released. 4.104.114.84.95
(edit) @de76809   02/20/98 19:59:23 Joel Sherrill Removed extra line. 4.104.114.84.95
(edit) @2c45683   02/20/98 19:04:23 Joel Sherrill Increased stack space to let test run to completion. 4.104.114.84.95
(edit) @fde74a3   02/19/98 22:55:02 Joel Sherrill Increased stack space of tasks. 4.104.114.84.95
(edit) @6eba9b79   02/19/98 22:52:55 Joel Sherrill Increased stack size of initialization task. 4.104.114.84.95
(edit) @2617b345   02/19/98 17:08:54 Joel Sherrill Restructured so all times are placed in variables and printed in batch … 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @33b304f   02/17/98 23:45:57 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @5c3511e   01/30/98 21:49:51 Joel Sherrill Big patch form Ralf Corsepius described in this email: Here is the … 4.104.114.84.95
(edit) @2936b425   01/23/98 17:45:05 Joel Sherrill Solaris port updates from Chris Johns 4.104.114.84.95
(edit) @cb5bfe4   01/20/98 19:41:09 Joel Sherrill Removed CONFIG_DIR and PROJECT_HOME directories. 4.104.114.84.95
(edit) @6f9c75c3   01/16/98 16:56:48 Joel Sherrill Ralf Corsepius reported a number of missing CVS Id's: > RTEMS is … 4.104.114.84.95
(edit) @674c900   12/10/97 16:58:00 Joel Sherrill Modified a lot of files to take a first cut at supporting building … 4.104.114.84.95
(edit) @f4cec63d   11/30/97 18:36:52 Joel Sherrill Since test suite Makefiles are not always generated, use wildcard to … 4.104.114.84.95
(edit) @61fc72c   11/18/97 22:33:32 Joel Sherrill Removed warning. 4.104.114.84.95
(edit) @91daf55   11/18/97 22:33:17 Joel Sherrill New file. 4.104.114.84.95
(edit) @514cf30   10/23/97 15:12:46 Joel Sherrill Added new test for termios style consoles from Eric Norum. 4.104.114.84.95
(edit) @3dbcece   10/21/97 18:41:36 Joel Sherrill Added test case for rtems_interrupt_catch checking that the pointer … 4.104.114.84.95
(edit) @d9fe8e2   10/09/97 20:21:43 Joel Sherrill Fixed some spacing. 4.104.114.84.95
(edit) @58e3dc79   10/08/97 18:25:30 Joel Sherrill Fix from Eric Norum so FPSP is installed before any FP code is … 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @a2016b99   10/08/97 14:42:08 Joel Sherrill Removed include directory at "build" point and the link of this … 4.104.114.84.95
(edit) @3a321e23   10/06/97 21:32:47 Joel Sherrill Fixed some weird line duplications. Thanks to Chris Johns. 4.104.114.84.95
(edit) @f37e656d   09/21/97 16:57:46 Joel Sherrill Added Monitor test. 4.104.114.84.95
(edit) @d1b60f0   08/27/97 20:34:23 Joel Sherrill Corrected reference to LIBC_LIBM to work on all targets. 4.104.114.84.95
(edit) @2d60095   08/26/97 19:24:22 Joel Sherrill Patches from Chris Johns to clean up test. 4.104.114.84.95
(edit) @588a2382   08/26/97 19:19:21 Joel Sherrill removed -lm 4.104.114.84.95
(edit) @0074691a   07/31/97 22:13:29 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @91333c2   07/31/97 22:04:17 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @13f09e6   07/31/97 19:48:23 Joel Sherrill Added support for rtems_message_queue_get_number_pending. 4.104.114.84.95
(edit) @db17316   07/09/97 23:51:21 Joel Sherrill Used macro instead of hard coded number. 4.104.114.84.95
(edit) @7346e5f   04/22/97 20:43:23 Joel Sherrill incorrect screen name for multiprocessing tests. 4.104.114.84.95
(edit) @e71ce071   04/22/97 17:47:16 Joel Sherrill updated with new license information per Tony Bennett. 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @1d61610   04/18/97 18:39:01 Joel Sherrill Modified to reflect change from 255 posix priority levels to 254. 4.104.114.84.95
(edit) @dda5cf4   04/18/97 17:50:01 Joel Sherrill Corrected incorrect settings for locations of psx and sp test screens. 4.104.114.84.95
(edit) @b1a4ca8   04/15/97 17:40:38 Joel Sherrill Added line to install test screens so difftest does not have to have a … 4.104.114.84.95
(edit) @6bcceb8   04/09/97 21:00:33 Joel Sherrill enabled floating point and fixed confdef reference to initialization … 4.104.114.84.95
(edit) @61a183a9   04/09/97 20:19:35 Joel Sherrill new test 4.104.114.84.95
(edit) @dfdaf4ac   04/09/97 20:19:22 Joel Sherrill added cpuuse and rtmonuse 4.104.114.84.95
(edit) @f8700f77   04/07/97 21:33:28 Joel Sherrill corrected printf specifications and added casts as necessary to … 4.104.114.84.95
(edit) @de4f281   04/07/97 21:31:59 Joel Sherrill added ifdef to avoid warning for unused variable. 4.104.114.84.95
(edit) @1c666fc   04/07/97 21:31:39 Joel Sherrill corrected integer only definitions of "FP CHECK" routines to eliminate … 4.104.114.84.95
(edit) @1c24fe7   04/02/97 16:27:05 Joel Sherrill corrected one of the references to an environment variable which is no … 4.104.114.84.95
(edit) @51f5d64c   04/02/97 16:26:39 Joel Sherrill corrected printf format to avoid warning 4.104.114.84.95
(edit) @892a536d   04/02/97 16:26:28 Joel Sherrill initialized variables or removed unused variables to remove warnings 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @9128179   03/08/97 03:53:59 Joel Sherrill added support for posix tests 4.104.114.84.95
(edit) @2a3d1fd   01/29/97 00:31:56 Joel Sherrill Made stopping for the pause an option which can be configured in the … 4.104.114.84.95
(edit) @d135fc52   01/08/97 16:22:22 Joel Sherrill _CPU_Trap_Table_area is now conditional based on whether or not the … 4.104.114.84.95
(edit) @1f4f392a   09/18/96 22:23:15 Joel Sherrill new files 4.104.114.84.95
(edit) @7abd27b   09/18/96 21:07:37 Joel Sherrill added cast 4.104.114.84.95
(edit) @c3e3d07   09/18/96 21:07:14 Joel Sherrill address arithmetic changed to be more portable 4.104.114.84.95
(edit) @4a5e651   09/18/96 21:06:49 Joel Sherrill new test submitted by Craig Lebakken (lebakken@…) and Derrick … 4.104.114.84.95
(edit) @cc51de91   09/17/96 21:38:59 Joel Sherrill extended Task_id and Task_name arrays to avoid indexing past end of array. 4.104.114.84.95
(edit) @09093ee   09/12/96 20:41:27 Mark.Johannes Fixed test to match change to pthread_cond_timedwait which now takes a … 4.104.114.84.95
(edit) @2ffcc2ed   09/06/96 15:17:39 Joel Sherrill modified test to take into account change in default value of … 4.104.114.84.95
(edit) @7e230f10   09/05/96 20:31:32 Joel Sherrill added printf of status when not successful 4.104.114.84.95
