# # ChangeLog for c/src/tests/samples/hello/Makefile.in in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 23:25:45 Fri, 06 Aug 1999 17:55:25 GMT Joel Sherrill [3a8915e] * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-rdbg.m4 (modified) * c/Makefile.am (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.in (modified) * make/Templates/Makefile.inc.in (deleted) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/update/acpolish (modified) Patch rtems-rc-19990709-6-diff from Ralf Corsepius [08b5f55] * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * tools/update/acpolish (modified) Patch from Ralf Corsepius : A bug in ... Mon, 26 Jul 1999 20:00:37 GMT Joel Sherrill [6693a68] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/tool-paths.m4 (modified) * aclocal/tool-prefix.m4 (modified) * autogen (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/rtems/sptables.h.in (added) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/README (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * c/src/tests/tools/generic/configure.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/sapi/include/rtems/sptables.h.in (moved) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/directory.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * make/target.cfg.in (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.am (modified) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) * tools/update/rtems-polish.sh (modified) This is part of a major patch from Ralf Corsepius [196094eb] * Makefile.in (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/acpolish (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/update/acpolish (modified) Patch from Ralf Corsepius : This one ... Fri, 19 Mar 1999 22:27:02 GMT Joel Sherrill [d8ff793] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * c/update-tools/acpolish (added) * configure.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/rtems.cfg (deleted) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/acpolish (added) Towards automake XI patch from Ralf Corsepius [8548fe0] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Part of the automake VI patch from Ralf Corsepius [5c3511e] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/base/Makefile.in (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/headers/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * configure.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.inc.in (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/target.cfg.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Big patch form Ralf Corsepius described in this email: Here is ... Tue, 20 Jan 1998 19:41:09 GMT Joel Sherrill [cb5bfe4] * c/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/base/Makefile.in (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/headers/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) Removed CONFIG_DIR and PROJECT_HOME directories. Wed, 10 Dec 1997 16:58:00 GMT Joel Sherrill [674c900] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/base/Makefile.in (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/headers/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * configure.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Modified a lot of files to take a first cut at supporting building ... Tue, 01 Apr 1997 23:07:52 GMT Joel Sherrill [254b4450] * Makefile.in (added) * README.configure (added) * c/Makefile.in (added) * c/build-tools/Makefile.in (added) * c/build-tools/os/Makefile.in (added) * c/build-tools/os/msdos/Makefile.in (added) * c/build-tools/scripts/Makefile.in (added) * c/build-tools/src/Makefile.in (added) * c/build-tools/src/unhex.c (modified) * c/build-tools/unhex.c (modified) * c/src/Makefile.in (added) * c/src/exec/Makefile.in (added) * c/src/exec/posix/Makefile.in (added) * c/src/exec/posix/base/Makefile.in (added) * c/src/exec/posix/headers/Makefile.in (added) * c/src/exec/posix/include/rtems/posix/Makefile.in (added) * c/src/exec/posix/include/sys/Makefile.in (added) * c/src/exec/posix/include/wrap/Makefile.in (added) * c/src/exec/posix/inline/Makefile.in (added) * c/src/exec/posix/inline/rtems/posix/Makefile.in (added) * c/src/exec/posix/macros/Makefile.in (added) * c/src/exec/posix/macros/rtems/posix/Makefile.in (added) * c/src/exec/posix/optman/Makefile.in (added) * c/src/exec/posix/src/Makefile.in (added) * c/src/exec/posix/sys/Makefile.in (added) * c/src/exec/rtems/Makefile.in (added) * c/src/exec/rtems/headers/Makefile.in (added) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (added) * c/src/exec/rtems/inline/Makefile.in (added) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (added) * c/src/exec/rtems/macros/Makefile.in (added) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (added) * c/src/exec/rtems/optman/Makefile.in (added) * c/src/exec/rtems/src/Makefile.in (added) * c/src/exec/sapi/Makefile.in (added) * c/src/exec/sapi/headers/Makefile.in (added) * c/src/exec/sapi/headers/README (added) * c/src/exec/sapi/include/rtems/Makefile.in (added) * c/src/exec/sapi/include/rtems/README (added) * c/src/exec/sapi/inline/Makefile.in (added) * c/src/exec/sapi/inline/rtems/Makefile.in (added) * c/src/exec/sapi/macros/Makefile.in (added) * c/src/exec/sapi/macros/rtems/Makefile.in (added) * c/src/exec/sapi/optman/Makefile.in (added) * c/src/exec/sapi/src/Makefile.in (added) * c/src/exec/score/Makefile.in (added) * c/src/exec/score/cpu/Makefile.in (added) * c/src/exec/score/cpu/a29k/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.in (added) * c/src/exec/score/cpu/i960/Makefile.in (added) * c/src/exec/score/cpu/m68k/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/Makefile.in (added) * c/src/exec/score/cpu/powerpc/Makefile.in (added) * c/src/exec/score/cpu/sparc/Makefile.in (added) * c/src/exec/score/cpu/unix/Makefile.in (added) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/cpu/unix/unix.h (modified) * c/src/exec/score/headers/Makefile.in (added) * c/src/exec/score/include/rtems/score/Makefile.in (added) * c/src/exec/score/inline/Makefile.in (added) * c/src/exec/score/inline/rtems/score/Makefile.in (added) * c/src/exec/score/macros/Makefile.in (added) * c/src/exec/score/macros/rtems/score/Makefile.in (added) * c/src/exec/score/src/Makefile.in (added) * c/src/exec/score/tools/Makefile.in (added) * c/src/exec/score/tools/generic/Makefile.in (added) * c/src/exec/score/tools/hppa1.1/Makefile.in (added) * c/src/exec/score/tools/unix/Makefile.in (added) * c/src/exec/wrapup/Makefile.in (added) * c/src/exec/wrapup/posix/Makefile.in (added) * c/src/exec/wrapup/rtems/Makefile.in (added) * c/src/lib/Makefile.in (added) * c/src/lib/include/Makefile.in (added) * c/src/lib/libbsp/Makefile.in (added) * c/src/lib/libbsp/a29k/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (added) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/start/start.s (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (added) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (added) * c/src/lib/libbsp/i386/Makefile.in (added) * c/src/lib/libbsp/i386/force386/Makefile.in (added) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (added) * c/src/lib/libbsp/i386/force386/console/Makefile.in (added) * c/src/lib/libbsp/i386/force386/include/Makefile.in (added) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (added) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (added) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (added) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (added) * c/src/lib/libbsp/i386/go32/Makefile.in (added) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (added) * c/src/lib/libbsp/i386/go32/console/Makefile.in (added) * c/src/lib/libbsp/i386/go32/include/Makefile.in (added) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (added) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (added) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (added) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (added) * c/src/lib/libbsp/i960/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (added) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (added) * c/src/lib/libbsp/mips/README (added) * c/src/lib/libbsp/mips64orion/Makefile.in (added) * c/src/lib/libbsp/mips64orion/README (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (added) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (added) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (added) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (added) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (added) * c/src/lib/libbsp/no_cpu/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (added) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (added) * c/src/lib/libbsp/powerpc/Makefile.in (added) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (added) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (added) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (added) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (added) * c/src/lib/libbsp/shmdr/Makefile.in (added) * c/src/lib/libbsp/sparc/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (added) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (added) * c/src/lib/libbsp/unix/Makefile.in (added) * c/src/lib/libbsp/unix/posix/Makefile.in (added) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (added) * c/src/lib/libbsp/unix/posix/console/Makefile.in (added) * c/src/lib/libbsp/unix/posix/include/Makefile.in (added) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (added) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (added) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (added) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (added) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (added) * c/src/lib/libc/Makefile.in (added) * c/src/lib/libcpu/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/milli/milli.s (added) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (added) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (added) * c/src/lib/libcpu/mips64orion/Makefile.in (added) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (added) * c/src/lib/libcpu/mips64orion/include/Makefile.in (added) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (added) * c/src/lib/libcpu/powerpc/Makefile.in (added) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (added) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (added) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (added) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (added) * c/src/lib/libcpu/sparc/Makefile.in (added) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (added) * c/src/lib/libmisc/Makefile.in (added) * c/src/lib/libmisc/assoc/Makefile.in (added) * c/src/lib/libmisc/error/Makefile.in (added) * c/src/lib/libmisc/monitor/Makefile.in (added) * c/src/lib/libmisc/stackchk/Makefile.in (added) * c/src/lib/libmisc/wrapup/Makefile.in (added) * c/src/lib/start/Makefile.in (added) * c/src/lib/start/a29k/Makefile.in (added) * c/src/lib/start/i960/Makefile.in (added) * c/src/lib/start/m68k/Makefile.in (added) * c/src/lib/start/mips64orion/Makefile.in (added) * c/src/lib/wrapup/Makefile.in (added) * c/src/libmisc/assoc/Makefile.in (added) * c/src/libmisc/error/Makefile.in (added) * c/src/libmisc/monitor/Makefile.in (added) * c/src/libmisc/stackchk/Makefile.in (added) * c/src/libmisc/wrapup/Makefile.in (added) * c/src/tests/Makefile.in (added) * c/src/tests/libtests/Makefile.in (added) * c/src/tests/libtests/malloctest/Makefile.in (added) * c/src/tests/libtests/stackchk/Makefile.in (added) * c/src/tests/mptests/Makefile.in (added) * c/src/tests/mptests/mp01/Makefile.in (added) * c/src/tests/mptests/mp01/node1/Makefile.in (added) * c/src/tests/mptests/mp01/node2/Makefile.in (added) * c/src/tests/mptests/mp02/Makefile.in (added) * c/src/tests/mptests/mp02/node1/Makefile.in (added) * c/src/tests/mptests/mp02/node2/Makefile.in (added) * c/src/tests/mptests/mp03/Makefile.in (added) * c/src/tests/mptests/mp03/node1/Makefile.in (added) * c/src/tests/mptests/mp03/node2/Makefile.in (added) * c/src/tests/mptests/mp04/Makefile.in (added) * c/src/tests/mptests/mp04/node1/Makefile.in (added) * c/src/tests/mptests/mp04/node2/Makefile.in (added) * c/src/tests/mptests/mp05/Makefile.in (added) * c/src/tests/mptests/mp05/node1/Makefile.in (added) * c/src/tests/mptests/mp05/node2/Makefile.in (added) * c/src/tests/mptests/mp06/Makefile.in (added) * c/src/tests/mptests/mp06/node1/Makefile.in (added) * c/src/tests/mptests/mp06/node2/Makefile.in (added) * c/src/tests/mptests/mp07/Makefile.in (added) * c/src/tests/mptests/mp07/node1/Makefile.in (added) * c/src/tests/mptests/mp07/node2/Makefile.in (added) * c/src/tests/mptests/mp08/Makefile.in (added) * c/src/tests/mptests/mp08/node1/Makefile.in (added) * c/src/tests/mptests/mp08/node2/Makefile.in (added) * c/src/tests/mptests/mp09/Makefile.in (added) * c/src/tests/mptests/mp09/node1/Makefile.in (added) * c/src/tests/mptests/mp09/node2/Makefile.in (added) * c/src/tests/mptests/mp10/Makefile.in (added) * c/src/tests/mptests/mp10/node1/Makefile.in (added) * c/src/tests/mptests/mp10/node2/Makefile.in (added) * c/src/tests/mptests/mp11/Makefile.in (added) * c/src/tests/mptests/mp11/node1/Makefile.in (added) * c/src/tests/mptests/mp11/node2/Makefile.in (added) * c/src/tests/mptests/mp12/Makefile.in (added) * c/src/tests/mptests/mp12/node1/Makefile.in (added) * c/src/tests/mptests/mp12/node2/Makefile.in (added) * c/src/tests/mptests/mp13/Makefile.in (added) * c/src/tests/mptests/mp13/node1/Makefile.in (added) * c/src/tests/mptests/mp13/node2/Makefile.in (added) * c/src/tests/mptests/mp14/Makefile.in (added) * c/src/tests/mptests/mp14/node1/Makefile.in (added) * c/src/tests/mptests/mp14/node2/Makefile.in (added) * c/src/tests/psxtests/Makefile.in (added) * c/src/tests/psxtests/psx01/Makefile.in (added) * c/src/tests/psxtests/psx02/Makefile.in (added) * c/src/tests/psxtests/psx03/Makefile.in (added) * c/src/tests/psxtests/psx04/Makefile.in (added) * c/src/tests/psxtests/psx05/Makefile.in (added) * c/src/tests/psxtests/psx06/Makefile.in (added) * c/src/tests/psxtests/psx07/Makefile.in (added) * c/src/tests/psxtests/psx08/Makefile.in (added) * c/src/tests/psxtests/psx09/Makefile.in (added) * c/src/tests/psxtests/psx10/Makefile.in (added) * c/src/tests/psxtests/psx11/Makefile.in (added) * c/src/tests/psxtests/psx12/Makefile.in (added) * c/src/tests/psxtests/psxhdrs/Makefile.in (added) * c/src/tests/psxtests/support/Makefile.in (added) * c/src/tests/psxtests/support/include/Makefile.in (added) * c/src/tests/samples/Makefile.in (added) * c/src/tests/samples/base_mp/Makefile.in (added) * c/src/tests/samples/base_mp/node1/Makefile.in (added) * c/src/tests/samples/base_mp/node2/Makefile.in (added) * c/src/tests/samples/base_sp/Makefile.in (added) * c/src/tests/samples/cdtest/Makefile.in (added) * c/src/tests/samples/hello/Makefile.in (added) * c/src/tests/samples/paranoia/Makefile.in (added) * c/src/tests/samples/ticker/Makefile.in (added) * c/src/tests/sptests/Makefile.in (added) * c/src/tests/sptests/sp01/Makefile.in (added) * c/src/tests/sptests/sp02/Makefile.in (added) * c/src/tests/sptests/sp03/Makefile.in (added) * c/src/tests/sptests/sp04/Makefile.in (added) * c/src/tests/sptests/sp05/Makefile.in (added) * c/src/tests/sptests/sp06/Makefile.in (added) * c/src/tests/sptests/sp07/Makefile.in (added) * c/src/tests/sptests/sp08/Makefile.in (added) * c/src/tests/sptests/sp09/Makefile.in (added) * c/src/tests/sptests/sp11/Makefile.in (added) * c/src/tests/sptests/sp12/Makefile.in (added) * c/src/tests/sptests/sp13/Makefile.in (added) * c/src/tests/sptests/sp14/Makefile.in (added) * c/src/tests/sptests/sp15/Makefile.in (added) * c/src/tests/sptests/sp16/Makefile.in (added) * c/src/tests/sptests/sp17/Makefile.in (added) * c/src/tests/sptests/sp19/Makefile.in (added) * c/src/tests/sptests/sp20/Makefile.in (added) * c/src/tests/sptests/sp21/Makefile.in (added) * c/src/tests/sptests/sp22/Makefile.in (added) * c/src/tests/sptests/sp23/Makefile.in (added) * c/src/tests/sptests/sp24/Makefile.in (added) * c/src/tests/sptests/sp25/Makefile.in (added) * c/src/tests/sptests/spfatal/Makefile.in (added) * c/src/tests/sptests/spsize/Makefile.in (added) * c/src/tests/support/Makefile.in (added) * c/src/tests/support/include/Makefile.in (added) * c/src/tests/support/stubdr/Makefile.in (added) * c/src/tests/support/wrapup/Makefile.in (added) * c/src/tests/tmtests/Makefile.in (added) * c/src/tests/tmtests/include/Makefile.in (added) * c/src/tests/tmtests/tm01/Makefile.in (added) * c/src/tests/tmtests/tm02/Makefile.in (added) * c/src/tests/tmtests/tm03/Makefile.in (added) * c/src/tests/tmtests/tm04/Makefile.in (added) * c/src/tests/tmtests/tm05/Makefile.in (added) * c/src/tests/tmtests/tm06/Makefile.in (added) * c/src/tests/tmtests/tm07/Makefile.in (added) * c/src/tests/tmtests/tm08/Makefile.in (added) * c/src/tests/tmtests/tm09/Makefile.in (added) * c/src/tests/tmtests/tm10/Makefile.in (added) * c/src/tests/tmtests/tm11/Makefile.in (added) * c/src/tests/tmtests/tm12/Makefile.in (added) * c/src/tests/tmtests/tm13/Makefile.in (added) * c/src/tests/tmtests/tm14/Makefile.in (added) * c/src/tests/tmtests/tm15/Makefile.in (added) * c/src/tests/tmtests/tm16/Makefile.in (added) * c/src/tests/tmtests/tm17/Makefile.in (added) * c/src/tests/tmtests/tm18/Makefile.in (added) * c/src/tests/tmtests/tm19/Makefile.in (added) * c/src/tests/tmtests/tm20/Makefile.in (added) * c/src/tests/tmtests/tm21/Makefile.in (added) * c/src/tests/tmtests/tm22/Makefile.in (added) * c/src/tests/tmtests/tm23/Makefile.in (added) * c/src/tests/tmtests/tm24/Makefile.in (added) * c/src/tests/tmtests/tm25/Makefile.in (added) * c/src/tests/tmtests/tm26/Makefile.in (added) * c/src/tests/tmtests/tm27/Makefile.in (added) * c/src/tests/tmtests/tm28/Makefile.in (added) * c/src/tests/tmtests/tm29/Makefile.in (added) * c/src/tests/tmtests/tmck/Makefile.in (added) * c/src/tests/tmtests/tmoverhd/Makefile.in (added) * c/src/tests/tools/generic/Makefile.in (added) * c/src/wrapup/Makefile.in (added) * c/update-tools/Makefile.in (added) * config.guess (added) * config.sub (added) * configure (added) * configure.in (added) * cpukit/sapi/include/rtems/README (added) * cpukit/score/cpu/unix/cpu.c (modified) * install-sh (added) * mkinstalldirs (added) * tools/build/Makefile.in (added) * tools/build/os/Makefile.in (added) * tools/build/os/msdos/Makefile.in (added) * tools/build/scripts/Makefile.in (added) * tools/build/src/Makefile.in (added) * tools/build/src/unhex.c (modified) * tools/build/unhex.c (modified) * tools/cpu/Makefile.in (added) * tools/cpu/generic/Makefile.in (added) * tools/cpu/unix/Makefile.in (added) * tools/update/Makefile.in (added) This set of changes is the build of what was required to convert to ...
