# # ChangeLog for c/src/tests/itrontests/itrontask01/itrontask01.doc in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 12:44:38 Fri, 12 Nov 1999 14:49:47 GMT Joel Sherrill [3136f5c9] * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/itrontask01.scn (modified) * c/src/tests/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/itrontask01.scn (modified) * testsuites/itrontests/itrontask01/task1.c (modified) Test name changed to reflect placement after merger. Increased ... Wed, 10 Nov 1999 22:15:42 GMT Joel Sherrill [713b2ea] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/init.c (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/itrontask02.doc (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * c/src/tests/itrontests/itrontask03/itrontask03.scn (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * testsuites/itrontests/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/itrontask02.doc (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itrontask03/itrontask03.scn (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/system.h (modified) General cleanup. Test documentation improved. The message buffer ... Tue, 09 Nov 1999 23:27:05 GMT Joel Sherrill [e099180] * c/src/tests/itrontests/itronhello/itronhello.doc (added) * c/src/tests/itrontests/itronhello/itronhello.scn (added) * c/src/tests/itrontests/itronmbf01/itronmbf01.doc (added) * c/src/tests/itrontests/itronmbf01/itronmbf01.scn (added) * c/src/tests/itrontests/itronsem01/itronsem01.doc (added) * c/src/tests/itrontests/itronsem01/itronsem01.scn (added) * c/src/tests/itrontests/itrontask01/Makefile.in (added) * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (added) * c/src/tests/itrontests/itrontask01/itrontask01.scn (added) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask01/task1.c (added) * c/src/tests/itrontests/itrontask02/Makefile.in (added) * c/src/tests/itrontests/itrontask02/init.c (added) * c/src/tests/itrontests/itrontask02/itrontask02.doc (added) * c/src/tests/itrontests/itrontask02/itrontask02.scn (added) * c/src/tests/itrontests/itrontask02/preempt.c (added) * c/src/tests/itrontests/itrontask02/system.h (added) * c/src/tests/itrontests/itrontask03/Makefile.in (added) * c/src/tests/itrontests/itrontask03/init.c (added) * c/src/tests/itrontests/itrontask03/itrontask03.doc (added) * c/src/tests/itrontests/itrontask03/itrontask03.scn (added) * c/src/tests/itrontests/itrontask03/preempt.c (added) * c/src/tests/itrontests/itrontask03/spinit.c (added) * c/src/tests/itrontests/itrontask03/system.h (added) * c/src/tests/itrontests/itrontask03/task1.c (added) * c/src/tests/itrontests/itrontask03/task2.c (added) * c/src/tests/itrontests/itrontask03/task3.c (added) * c/src/tests/itrontests/itrontask04/Makefile.in (added) * c/src/tests/itrontests/itrontask04/init.c (added) * c/src/tests/itrontests/itrontask04/itrontask04.doc (added) * c/src/tests/itrontests/itrontask04/itrontask04.scn (added) * c/src/tests/itrontests/itrontask04/system.h (added) * c/src/tests/itrontests/itrontask04/task1.c (added) * c/src/tests/itrontests/itrontask04/task2.c (added) * c/src/tests/itrontests/itrontask04/task3.c (added) * testsuites/itrontests/itronhello/itronhello.doc (added) * testsuites/itrontests/itronhello/itronhello.scn (added) * testsuites/itrontests/itronmbf01/itronmbf01.doc (added) * testsuites/itrontests/itronmbf01/itronmbf01.scn (added) * testsuites/itrontests/itronsem01/itronsem01.doc (added) * testsuites/itrontests/itronsem01/itronsem01.scn (added) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (added) * testsuites/itrontests/itrontask01/itrontask01.scn (added) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (added) * testsuites/itrontests/itrontask02/init.c (added) * testsuites/itrontests/itrontask02/itrontask02.doc (added) * testsuites/itrontests/itrontask02/itrontask02.scn (added) * testsuites/itrontests/itrontask02/system.h (added) * testsuites/itrontests/itrontask03/init.c (added) * testsuites/itrontests/itrontask03/itrontask03.doc (added) * testsuites/itrontests/itrontask03/itrontask03.scn (added) * testsuites/itrontests/itrontask03/preempt.c (added) * testsuites/itrontests/itrontask03/system.h (added) * testsuites/itrontests/itrontask03/task1.c (added) * testsuites/itrontests/itrontask03/task2.c (added) * testsuites/itrontests/itrontask03/task3.c (added) * testsuites/itrontests/itrontask04/init.c (added) * testsuites/itrontests/itrontask04/itrontask04.doc (added) * testsuites/itrontests/itrontask04/itrontask04.scn (added) * testsuites/itrontests/itrontask04/system.h (added) * testsuites/itrontests/itrontask04/task1.c (added) * testsuites/itrontests/itrontask04/task2.c (added) * testsuites/itrontests/itrontask04/task3.c (added) Merged tests from Task group.
