Search:
Login
Preferences
About Trac
Register
Forgot your password?
API
Wiki
Timeline
Roadmap
View Tickets
Search
Context Navigation
View Latest Revision
source:
src
Revision Log Mode:
Stop on copy
Follow copies
Show only adds and deletes
View log starting at
and back to
Show at most
revisions per page.
Show full log messages
Legend:
Added
Modified
Copied or renamed
Diff
Rev
Age
Author
Log Message
(edit)
@c2c9c7e
05/27/98 19:26:09
Joel Sherrill
Added names for C++ compilers.
4.10
4.11
4.8
4.9
5
(edit)
@5dd4212
05/20/98 17:01:04
Joel Sherrill
Changed CPP rule per patch from Ralf Corsepius.
4.10
4.11
4.8
4.9
5
(edit)
@6ee6abb
05/18/98 16:38:38
Joel Sherrill
Added C++ rule. Added CROSS_TARGET conditionals so unix port can …
4.10
4.11
4.8
4.9
5
(edit)
@21c1513
04/27/98 14:20:25
Joel Sherrill
Fixed bad CVS Id string. Removed unnecessary definition of "ED".
4.10
4.11
4.8
4.9
5
(edit)
@5fafa0e
04/03/98 18:46:16
Joel Sherrill
Added test so the build procedure would stop if a directory did not …
4.10
4.11
4.8
4.9
5
(edit)
@d2865dce
03/16/98 13:52:11
Joel Sherrill
Fix from Chris Johns for inconsistent invocation of make.
4.10
4.11
4.8
4.9
5
(edit)
@ac61209b
02/17/98 19:16:18
Joel Sherrill
Added unused warning per discussion on rtems-snapshots list.
4.10
4.11
4.8
4.9
5
(edit)
@e81ef51
02/17/98 14:12:01
Joel Sherrill
Patch from Ralf Corsepius <corsepiu@…>: Yep, I have a …
4.10
4.11
4.8
4.9
5
(edit)
@a858910
02/11/98 22:13:46
Joel Sherrill
Incorporated Ralf Corsepius' idea for new -q flags to properly support …
4.10
4.11
4.8
4.9
5
(edit)
@2936b425
01/23/98 17:45:05
Joel Sherrill
Solaris port updates from Chris Johns
4.10
4.11
4.8
4.9
5
(add)
@bffb938
01/20/98 19:30:30
Joel Sherrill
Removed PROJECT_HOME and CONFIG_DIR variables.
4.10
4.11
4.8
4.9
5
Note:
See
TracRevisionLog
for help on using the revision log.
Download in other formats:
RSS Feed
ChangeLog
