# # ChangeLog for c/src/make in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 21:27:52 Wed, 11 Feb 1998 22:13:46 GMT Joel Sherrill [a858910] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/Templates/Makefile.leaf (modified) * make/compilers/gcc-target-default.cfg (modified) Incorporated Ralf Corsepius' idea for new -q flags to properly ... Fri, 23 Jan 1998 17:45:05 GMT Joel Sherrill [2936b425] * Makefile.in (modified) * c/build-tools/eolstrip.c (modified) * c/build-tools/packhex.c (modified) * c/build-tools/src/eolstrip.c (modified) * c/build-tools/src/packhex.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/error.c (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/include/rtems++/rtemsInterrupt.h (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/lib/libmisc/monitor/mon-symbols.c (modified) * c/src/lib/librtems++/rtemsMessageQueue.cc (modified) * c/src/lib/librtems++/rtemsSemaphore.cc (modified) * c/src/lib/librtems++/rtemsTask.cc (modified) * c/src/lib/librtems++/rtemsTimer.cc (modified) * c/src/libmisc/error/error.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * c/src/librtems++/include/rtems++/rtemsInterrupt.h (modified) * c/src/librtems++/src/rtemsMessageQueue.cc (modified) * c/src/librtems++/src/rtemsSemaphore.cc (modified) * c/src/librtems++/src/rtemsTask.cc (modified) * c/src/librtems++/src/rtemsTimer.cc (modified) * c/src/make/directory.cfg (modified) * c/src/tests/samples/cdtest/main.cc (modified) * c/src/tests/samples/paranoia/paranoia.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/Solaris-posix.cfg (modified) * make/directory.cfg (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/paranoia/paranoia.c (modified) * tools/build/eolstrip.c (modified) * tools/build/packhex.c (modified) * tools/build/src/eolstrip.c (modified) * tools/build/src/packhex.c (modified) Solaris port updates from Chris Johns Tue, 20 Jan 1998 19:30:30 GMT Joel Sherrill [bffb938] * c/src/make/README (added) * c/src/make/compilers/gcc-target-default.cfg (added) * c/src/make/directory.cfg (added) * c/src/make/host.cfg.in (added) * c/src/make/lib.cfg (added) * make/Makefile.in (added) * make/README (added) * make/Templates/Makefile.dir (added) * make/Templates/Makefile.inc.in (added) * make/Templates/Makefile.leaf (added) * make/Templates/Makefile.lib (added) * make/compilers/gcc-no_bsp.cfg (added) * make/compilers/gcc-portsw.cfg (added) * make/compilers/gcc-target-default.cfg (added) * make/custom/HPUX9-posix.cfg (added) * make/custom/Linux-posix.cfg (added) * make/custom/Solaris-posix.cfg (added) * make/custom/cvme961.cfg (added) * make/custom/default.cfg (added) * make/custom/dmv152.cfg (added) * make/custom/efi332.cfg (added) * make/custom/efi68k.cfg (added) * make/custom/erc32.cfg (added) * make/custom/force386.cfg (added) * make/custom/gen68302.cfg (added) * make/custom/gen68360.cfg (added) * make/custom/gen68360_040.cfg (added) * make/custom/gensh1.cfg (added) * make/custom/go32.cfg (added) * make/custom/go32_p5.cfg (added) * make/custom/i386ex.cfg (added) * make/custom/idp.cfg (added) * make/custom/mvme136.cfg (added) * make/custom/mvme147.cfg (added) * make/custom/mvme147s.cfg (added) * make/custom/mvme162.cfg (added) * make/custom/mvme162lx.cfg (added) * make/custom/no_bsp.cfg (added) * make/custom/ods68302.cfg (added) * make/custom/p4000.cfg (added) * make/custom/p4600.cfg (added) * make/custom/p4650.cfg (added) * make/custom/papyrus.cfg (added) * make/custom/pc386.cfg (added) * make/custom/portsw.cfg (added) * make/custom/posix.cfg (added) * make/custom/simhppa.cfg (added) * make/directory.cfg (added) * make/host.cfg.in (added) * make/leaf.cfg (added) * make/lib.cfg (added) * make/main.cfg (added) * make/target.cfg.in (added) Removed PROJECT_HOME and CONFIG_DIR variables.
