@a24c280
09/09/99 21:22:36 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Ralf Corsepius …
4.104.114.84.95
@e0c6f43
08/26/99 20:52:40 |
Joel Sherrill |
Comment cleanup from Eric Norum <eric@…>.
4.104.114.84.95
@72f9937b
08/23/99 18:48:07 |
Joel Sherrill |
Removed need for use of separate include/networking directory.
4.104.114.84.95
@48abdc31
08/23/99 14:58:16 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to readd the behavior where …
4.104.114.84.95
@1896a650
07/30/99 17:52:50 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The main topic …
4.104.114.84.95
@08b5f55
07/26/99 20:31:49 |
Joel Sherrill |
A bug in …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@09ea257c
07/12/99 15:52:35 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I get the following …
4.104.114.84.95
@937ab62c
06/15/99 22:16:30 |
Joel Sherrill |
After comments D. V. Henkel-Wallace <gumby@…>, the interface …
4.104.114.84.95
@a6f3cff
06/11/99 14:11:44 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
The select function …
4.104.114.84.95
@0643693
06/11/99 14:06:13 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix bug reported by
Ian …
4.104.114.84.95
@f74abcf7
05/28/99 18:21:25 |
Joel Sherrill |
Changes from Eric Norum to add a loop and limit on the length of time …
4.104.114.84.95
@403d7b18
05/28/99 16:09:00 |
Joel Sherrill |
Alignment corrected per Eric Norum's suggestion.
4.104.114.84.95
@11cdbeb
05/27/99 18:03:50 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to eliminate a panic when …
4.104.114.84.95
@8bbaf3b
05/20/99 13:32:54 |
Joel Sherrill |
Removed all post 4.0 changes.
4.104.114.84.95
@a238cc9
05/17/99 15:45:15 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to remove compiler …
4.104.114.84.95
@c5881fc1
05/14/99 15:31:07 |
Joel Sherrill |
Enabled compilation of rtems_servers at request of Jake Janovetz …
4.104.114.84.95
@acb644a6
05/07/99 16:30:44 |
Joel Sherrill |
Error reporting fixed by Jennifer.
4.104.114.84.95
@cfcb5a2
04/27/99 17:31:39 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to corrent a miscount in …
4.104.114.84.95
@4186b3b
04/19/99 17:17:41 |
Joel Sherrill |
Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease …
4.104.114.84.95
@11f84b3c
04/19/99 15:27:20 |
Joel Sherrill |
After discussion with Eric Norum <eric@…>,
I added …
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
This one is …
4.104.114.84.95
@85e24a3
04/02/99 14:39:19 |
Joel Sherrill |
Patch from Emmanuel Rauget (raguet@…) to add a htons on the …
4.104.114.84.95
@517660f1
04/01/99 16:36:22 |
Joel Sherrill |
Moved sparc specific version of in_cksum_hdr to an inline routine like …
4.104.114.84.95
@efa0baa5
03/31/99 20:51:07 |
Joel Sherrill |
Patch from Eric Norum <eric@…> which changed the exit …
4.104.114.84.95
@ceb06d96
03/30/99 17:43:51 |
Joel Sherrill |
Removed warning for `#ifdef' argument starts with punctuation.
4.104.114.84.95
@6a4096b
03/30/99 15:40:29 |
Joel Sherrill |
Patch to add shutdown() routine from Tony R. Ambardar <tonya@…>.
4.104.114.84.95
@e828c2dd
03/23/99 23:06:42 |
Joel Sherrill |
SPARC optimized version of IP checksum header routine. Submitted
by …
4.104.114.84.95
@b6f5f93
03/23/99 22:39:13 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to improve parsing of …
4.104.114.84.95
@d8ff793
03/19/99 22:27:02 |
Joel Sherrill |
Towards automake XI patch from Ralf Corsepius …
4.104.114.84.95
@af020036
03/19/99 21:51:58 |
Joel Sherrill |
Patch from Eric Norum <eric@…> that adds external
fcntl …
4.104.114.84.95
@1c0a186b
03/17/99 15:53:13 |
Joel Sherrill |
Temporarily took rtems_servers directory out of the build tree since …
4.104.114.84.95
@6d0e13c
03/16/99 01:51:53 |
Joel Sherrill |
Added ftpd server from Jake Janovetz <janovetz@…>.
4.104.114.84.95
@504a8c9d
03/16/99 01:51:40 |
Joel Sherrill |
Added rtems_servers directory.
4.104.114.84.95
@73f6236
03/01/99 22:40:08 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to eliminate external
IO …
4.104.114.84.95
@8548fe0
02/18/99 18:36:05 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@ecec2ba
02/05/99 00:29:23 |
Joel Sherrill |
Patch from Eric Norum to correct bug induced by select() patch.
4.104.114.84.95
@354b00bc
02/04/99 15:00:14 |
Joel Sherrill |
Added printf()'s that can be uncommented to trace MBUF operations. …
4.104.114.84.95
@83c7b00
02/04/99 14:59:42 |
Joel Sherrill |
Modifed to reflect transition from device driver to file system.
4.104.114.84.95
@d3c1060
02/04/99 14:58:01 |
Joel Sherrill |
Added debug printf()'s that are commented out. Uncommenting these …
4.104.114.84.95
@1564ca8
02/04/99 14:56:09 |
Joel Sherrill |
Added PowerPC specific header checksum code.
4.104.114.84.95
@8cce445
02/04/99 14:56:03 |
Joel Sherrill |
Added volatile to i386 …
4.104.114.84.95
@c1a37d3e
02/04/99 14:54:31 |
Joel Sherrill |
Debugged and now works except for handling of minor number.
4.104.114.84.95
@7c7fd4d
02/04/99 14:53:06 |
Joel Sherrill |
Modified to include comments on how to get TCPDEBUG turned on and …
4.104.114.84.95
@13e11f6
02/02/99 21:15:15 |
Joel Sherrill |
Added debug #define and commented it out.
4.104.114.84.95
@5d5f23b
02/02/99 21:15:02 |
Joel Sherrill |
Added PowerPC specific in_cksum file.
4.104.114.84.95
@9b9c4dfd
02/02/99 21:14:44 |
Joel Sherrill |
New file. Based on the i386 version.
4.104.114.84.95
@7b158663
01/31/99 20:50:49 |
Joel Sherrill |
Prepended macro variables with "_" to avoid name conflicts in expansions.
4.104.114.84.95
@cdf8a300
01/28/99 18:42:34 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to avoid dereferencing a …
4.104.114.84.95
@39ba9122
01/26/99 01:50:31 |
Joel Sherrill |
Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer …
4.104.114.84.95
@887618b0
01/26/99 01:49:56 |
Joel Sherrill |
Switched from printf() to puts().
4.104.114.84.95
@94b3ee13
01/21/99 22:25:43 |
Joel Sherrill |
Made to compile after hacking tftp driver into beginnings of a …
4.104.114.84.95
@a7c4314d
01/19/99 20:23:15 |
Joel Sherrill |
Added comments for changing to a filesystem
4.104.114.84.95
@eb0d7ae
01/04/99 16:35:31 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to use puts and have …
4.104.114.84.95
@88a0908
01/04/99 16:30:06 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to fix braces …
4.104.114.84.95
@60a2d689
01/04/99 16:28:49 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to make macro nest …
4.104.114.84.95
@cca4400
12/10/98 23:31:54 |
Joel Sherrill |
Merged Eric Norum's select patch that was based on 4.0 and resolved …
4.104.114.84.95
@a3d0b8a
12/10/98 19:42:29 |
Joel Sherrill |
4.104.114.84.95
@91b1c8e6
12/07/98 17:42:52 |
Joel Sherrill |
RTEMS permits using …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
1) Socket timeout …
4.104.114.84.95
@b19cb17
10/12/98 17:21:12 |
Joel Sherrill |
Added header files per request from Chris Johns to avoid problems
in …
4.104.114.84.95
@766ed7c
09/29/98 12:15:08 |
Joel Sherrill |
Remember the test …
4.104.114.84.95
@718dc95
09/21/98 00:46:00 |
Joel Sherrill |
Here's a patch to …
4.104.114.84.95
@7ddcfb8c
09/21/98 00:42:07 |
Joel Sherrill |
Patch from Eric Norum and David Fiddes to put ColdFire? support in
the …
4.104.114.84.95
@b3956369
09/11/98 13:12:04 |
Joel Sherrill |
Patch from "David J. Fiddes" <D.J@…>:
I've fixed …
4.104.114.84.95
@23cdd84c
09/10/98 12:43:00 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…> to make this compile
for …
4.104.114.84.95
@109b17f4
09/10/98 12:23:08 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix a cryptic error …
4.104.114.84.95
@4cf89a8
08/31/98 23:09:17 |
Joel Sherrill |
Fixed spacing. More comments from Eric Norum need to be addressed.
4.104.114.84.95
@d9d75fc
08/31/98 23:06:50 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
I have reworked …
4.104.114.84.95
@4de817d
08/21/98 18:14:27 |
Joel Sherrill |
Added i386 specific version of in_cksum.c and restructured the main …
4.104.114.84.95
@617a1a2d
08/21/98 17:37:01 |
Joel Sherrill |
Another missing piece. Thanks Eric.
4.104.114.84.95
@33679ec4
08/21/98 13:04:55 |
Joel Sherrill |
All warnings removed.
4.104.114.84.95
@c3a1c05
08/21/98 13:04:36 |
Joel Sherrill |
Removed networkconfig.h since it reflects target specific initialization.
4.104.114.84.95
@ab09043a
08/21/98 12:51:29 |
Joel Sherrill |
Fixed warning about pointer/integer conversion which turned out to be …
4.104.114.84.95
@28e7d7fa
08/20/98 22:04:22 |
Joel Sherrill |
Patches from Eric Norum
4.104.114.84.95
@96b39164
08/20/98 21:56:40 |
Joel Sherrill |
Added CVS Ids
4.104.114.84.95
@ff0f694d
08/20/98 21:47:37 |
Joel Sherrill |
Fixed many warnings.
4.104.114.84.95
@d9e6224
08/20/98 15:38:30 |
Joel Sherrill |
Temporarily leave strsep out of the build.
4.104.114.84.95
@4e1d5c6
08/20/98 15:38:15 |
Joel Sherrill |
Added missing file.
4.104.114.84.95
@3f098aed
08/20/98 14:37:17 |
Joel Sherrill |
FreeBSD stack compiles for the first time (except libc/strsep.c).
4.104.114.84.95
@c197b6c
08/20/98 12:54:04 |
Joel Sherrill |
Base files
4.104.114.84.95
@888497d
08/20/98 12:45:04 |
Joel Sherrill |
Base files
4.104.114.84.95
@f31f46d2
08/20/98 12:37:35 |
Joel Sherrill |
Base version.
4.104.114.84.95
@39e6e65a
08/19/98 21:32:28 |
Joel Sherrill |
Base files
4.104.114.84.95
