Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/libnetworking
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @4dcd943   07/14/00 18:52:54 Joel Sherrill Changed name of static table versions to avoid conflict. 4.104.114.84.95
(edit) @e8fd633   06/30/00 12:38:25 Joel Sherrill Patch from Chris Johns <cjohns@…> so the web server … 4.104.114.84.95
(edit) @73e1db9   06/15/00 12:58:24 Joel Sherrill Moved <sys/cdefs.h> to lib/include so non-networking applications … 4.104.114.84.95
(edit) @730daa6   06/14/00 21:13:20 Joel Sherrill Moved <sys/cdefs.h> from libnetworking to lib/include so … 4.104.114.84.95
(edit) @9b05600   06/14/00 20:22:31 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @6f93bb4   06/14/00 17:18:18 Joel Sherrill Patch from Chris Johns <cjohns@…> to enhance network … 4.104.114.84.95
(edit) @edeed26   06/12/00 15:39:38 Joel Sherrill Merge lossage. Apparently the DOS/UNIX CRLF issue got lost. 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @a4460152   04/28/00 17:42:16 Joel Sherrill New files added on 4.5 branch. 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @70810dc   02/08/00 22:33:25 Joel Sherrill Patches rtems-rc-20000204-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4bf1801   02/03/00 13:21:38 Joel Sherrill Patches rtems-rc-20000118-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4a9b897   01/21/00 15:11:40 Joel Sherrill Patch from Eric Norum <eric@…> at the request of Jake … 4.104.114.84.95
(edit) @e570c761   01/21/00 14:49:31 Joel Sherrill Patch from Eric Norum <eric@…> to remove warnings. 4.104.114.84.95
(edit) @94a51f8b   01/14/00 18:50:19 Joel Sherrill Added -USTRICT_ANSI to remove MANY warnings since the BSD code is … 4.104.114.84.95
(edit) @19642e2c   01/10/00 21:22:23 Joel Sherrill Removed definition of USHRT_MAX to remove lots of redefinition warnings. 4.104.114.84.95
(edit) @0173ab8   01/03/00 18:28:36 Joel Sherrill Comments added and some messages translated from Polish. 4.104.114.84.95
(edit) @5bce35b   12/21/99 14:37:31 Joel Sherrill Made prototype of ChapReceiveSuccess? and ChapReceiveFailure? match. 4.104.114.84.95
(edit) @fc0b91c   12/13/99 19:20:38 Joel Sherrill Patch from Eric Norum <eric@…> to make the NTP handler a … 4.104.114.84.95
(edit) @809f4451   12/13/99 17:03:37 Joel Sherrill Correction from Eric Norum for timeout in TFTP driver following bug … 4.104.114.84.95
(edit) @9537e5e   12/13/99 16:29:01 Joel Sherrill Patch from Eric Norum <eric@…> to provide more network … 4.104.114.84.95
(edit) @a548c8a5   12/03/99 16:00:51 Joel Sherrill New file. 4.104.114.84.95
(edit) @1e4a7d4   12/03/99 15:44:28 Joel Sherrill Modem example driver for ppp by Tomasz Domin <dot@…> of … 4.104.114.84.95
(edit) @5d3da15b   12/01/99 16:00:38 Joel Sherrill Removed debugging printfs. 4.104.114.84.95
(edit) @017061c   12/01/99 15:54:17 Joel Sherrill Patch from Eric Norum <eric@…> to fix a spot in the tftp … 4.104.114.84.95
(edit) @42881534   11/30/99 22:14:28 Joel Sherrill Added missing files from PPP port. 4.104.114.84.95
(edit) @d0950ad   11/30/99 22:12:50 Joel Sherrill Added port of ppp-2.3.5 from Tomasz Domin <dot@…> of ComArch?4.104.114.84.95
(edit) @9f4868c   11/23/99 13:57:02 Joel Sherrill Miscellaneous patches from Ralf Corsepius <corsepiu@…> … 4.104.114.84.95
(edit) @2d8a4ed0   11/17/99 15:32:30 Joel Sherrill Conditionally take out the offensive pragma pack when on RTEMS in … 4.104.114.84.95
(edit) @65a38bc   11/16/99 16:14:37 Joel Sherrill Web server uses the POSIX API. Therefor, it must be disabled when the … 4.104.114.84.95
(edit) @cbccd37   11/10/99 14:31:11 Joel Sherrill Patch from Eric Norum <eric@…> which includes: Patches … 4.104.114.84.95
(edit) @a0af97d   11/09/99 03:43:47 Joel Sherrill Patch from Eric Norum <eric@…> to add NTP BOOTP support … 4.104.114.84.95
(edit) @b8d9f41   10/28/99 14:59:35 Joel Sherrill Added include of <sys/select.h> in attempt to remove compilation warning. 4.104.114.84.95
(edit) @be22768   10/28/99 14:50:43 Joel Sherrill Added use of rtems rather than LINUX for RTEMS configuration. 4.104.114.84.95
(edit) @3f4b575   10/27/99 13:58:58 Joel Sherrill Warnings removed. Still don't know what to do about the pragma pack … 4.104.114.84.95
(edit) @c1cdaa0   10/27/99 12:50:33 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> and Eric Valette … 4.104.114.84.95
(edit) @8379ada7   10/25/99 16:09:45 Joel Sherrill Patch from Eric Norum <eric@…> to address the following … 4.104.114.84.95
(edit) @1f350ef9   10/06/99 20:54:06 Joel Sherrill Removed aclocal.m4 generated from aclocal macros 4.104.114.84.95
(edit) @54eccb1a   10/06/99 20:52:34 Joel Sherrill Removed configure generated from configure.in 4.104.114.84.95
(edit) @1b821242   10/06/99 20:37:26 Joel Sherrill Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 … 4.104.114.84.95
(edit) @4075af6f   10/05/99 13:49:54 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @811804fe   10/04/99 19:15:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make fix bug … 4.104.114.84.95
(edit) @cc63e08   10/04/99 18:40:53 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make … 4.104.114.84.95
(edit) @b62a92c   10/04/99 18:20:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch below … 4.104.114.84.95
(edit) @4f021c0   10/04/99 17:33:23 Joel Sherrill Removed Makefile.in generated from Makefile.am 4.104.114.84.95
(edit) @6fca2f5   10/04/99 13:51:22 Joel Sherrill Patch from Eric Norum <eric@…>. Comments follow: The … 4.104.114.84.95
(edit) @473b4e5   10/04/99 13:30:15 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @a24c280   09/09/99 21:22:36 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @e0c6f43   08/26/99 20:52:40 Joel Sherrill Comment cleanup from Eric Norum <eric@…>. 4.104.114.84.95
(edit) @72f9937b   08/23/99 18:48:07 Joel Sherrill Removed need for use of separate include/networking directory. 4.104.114.84.95
(edit) @48abdc31   08/23/99 14:58:16 Joel Sherrill Patch from Eric Norum <eric@…> to readd the behavior where … 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @09ea257c   07/12/99 15:52:35 Joel Sherrill Patch from Eric Norum <eric@…>: I get the following … 4.104.114.84.95
(edit) @937ab62c   06/15/99 22:16:30 Joel Sherrill After comments D. V. Henkel-Wallace <gumby@…>, the interface … 4.104.114.84.95
(edit) @a6f3cff   06/11/99 14:11:44 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: The select function … 4.104.114.84.95
(edit) @0643693   06/11/99 14:06:13 Joel Sherrill Patch from Eric Norum <eric@…> to fix bug reported by Ian … 4.104.114.84.95
(edit) @f74abcf7   05/28/99 18:21:25 Joel Sherrill Changes from Eric Norum to add a loop and limit on the length of time … 4.104.114.84.95
(edit) @403d7b18   05/28/99 16:09:00 Joel Sherrill Alignment corrected per Eric Norum's suggestion. 4.104.114.84.95
(edit) @11cdbeb   05/27/99 18:03:50 Joel Sherrill Patch from Eric Norum <eric@…> to eliminate a panic when … 4.104.114.84.95
(edit) @8bbaf3b   05/20/99 13:32:54 Joel Sherrill Removed all post 4.0 changes. 4.104.114.84.95
(edit) @a238cc9   05/17/99 15:45:15 Joel Sherrill Patch from D. V. Henkel-Wallace <gumby@…> to remove compiler … 4.104.114.84.95
(edit) @c5881fc1   05/14/99 15:31:07 Joel Sherrill Enabled compilation of rtems_servers at request of Jake Janovetz … 4.104.114.84.95
(edit) @acb644a6   05/07/99 16:30:44 Joel Sherrill Error reporting fixed by Jennifer. 4.104.114.84.95
(edit) @cfcb5a2   04/27/99 17:31:39 Joel Sherrill Patch from Eric Norum <eric@…> to corrent a miscount in … 4.104.114.84.95
(edit) @4186b3b   04/19/99 17:17:41 Joel Sherrill Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease … 4.104.114.84.95
(edit) @11f84b3c   04/19/99 15:27:20 Joel Sherrill After discussion with Eric Norum <eric@…>, I added … 4.104.114.84.95
(edit) @196094eb   04/19/99 13:19:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This one is … 4.104.114.84.95
(edit) @85e24a3   04/02/99 14:39:19 Joel Sherrill Patch from Emmanuel Rauget (raguet@…) to add a htons on the … 4.104.114.84.95
(edit) @517660f1   04/01/99 16:36:22 Joel Sherrill Moved sparc specific version of in_cksum_hdr to an inline routine like … 4.104.114.84.95
(edit) @efa0baa5   03/31/99 20:51:07 Joel Sherrill Patch from Eric Norum <eric@…> which changed the exit … 4.104.114.84.95
(edit) @ceb06d96   03/30/99 17:43:51 Joel Sherrill Removed warning for `#ifdef' argument starts with punctuation. 4.104.114.84.95
(edit) @6a4096b   03/30/99 15:40:29 Joel Sherrill Patch to add shutdown() routine from Tony R. Ambardar <tonya@…>. 4.104.114.84.95
(edit) @e828c2dd   03/23/99 23:06:42 Joel Sherrill SPARC optimized version of IP checksum header routine. Submitted by … 4.104.114.84.95
(edit) @b6f5f93   03/23/99 22:39:13 Joel Sherrill Patch from Eric Norum <eric@…> to improve parsing of … 4.104.114.84.95
(edit) @d8ff793   03/19/99 22:27:02 Joel Sherrill Towards automake XI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @af020036   03/19/99 21:51:58 Joel Sherrill Patch from Eric Norum <eric@…> that adds external fcntl … 4.104.114.84.95
(edit) @1c0a186b   03/17/99 15:53:13 Joel Sherrill Temporarily took rtems_servers directory out of the build tree since … 4.104.114.84.95
(edit) @6d0e13c   03/16/99 01:51:53 Joel Sherrill Added ftpd server from Jake Janovetz <janovetz@…>. 4.104.114.84.95
(edit) @504a8c9d   03/16/99 01:51:40 Joel Sherrill Added rtems_servers directory. 4.104.114.84.95
(edit) @73f6236   03/01/99 22:40:08 Joel Sherrill Patch from Eric Norum <eric@…> to eliminate external IO … 4.104.114.84.95
(edit) @8548fe0   02/18/99 18:36:05 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @ecec2ba   02/05/99 00:29:23 Joel Sherrill Patch from Eric Norum to correct bug induced by select() patch. 4.104.114.84.95
(edit) @354b00bc   02/04/99 15:00:14 Joel Sherrill Added printf()'s that can be uncommented to trace MBUF operations. … 4.104.114.84.95
(edit) @83c7b00   02/04/99 14:59:42 Joel Sherrill Modifed to reflect transition from device driver to file system. 4.104.114.84.95
(edit) @d3c1060   02/04/99 14:58:01 Joel Sherrill Added debug printf()'s that are commented out. Uncommenting these … 4.104.114.84.95
(edit) @1564ca8   02/04/99 14:56:09 Joel Sherrill Added PowerPC specific header checksum code. 4.104.114.84.95
(edit) @8cce445   02/04/99 14:56:03 Joel Sherrill Added PowerPC specific header checksum code. Added volatile to i386 … 4.104.114.84.95
(edit) @c1a37d3e   02/04/99 14:54:31 Joel Sherrill Debugged and now works except for handling of minor number. 4.104.114.84.95
(edit) @7c7fd4d   02/04/99 14:53:06 Joel Sherrill Modified to include comments on how to get TCPDEBUG turned on and … 4.104.114.84.95
(edit) @13e11f6   02/02/99 21:15:15 Joel Sherrill Added debug #define and commented it out. 4.104.114.84.95
(edit) @5d5f23b   02/02/99 21:15:02 Joel Sherrill Added PowerPC specific in_cksum file. 4.104.114.84.95
(edit) @9b9c4dfd   02/02/99 21:14:44 Joel Sherrill New file. Based on the i386 version. 4.104.114.84.95
(edit) @7b158663   01/31/99 20:50:49 Joel Sherrill Prepended macro variables with "_" to avoid name conflicts in expansions. 4.104.114.84.95
(edit) @cdf8a300   01/28/99 18:42:34 Joel Sherrill Patch from Eric Norum <eric@…> to avoid dereferencing a … 4.104.114.84.95
(edit) @39ba9122   01/26/99 01:50:31 Joel Sherrill Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer … 4.104.114.84.95
(edit) @887618b0   01/26/99 01:49:56 Joel Sherrill Switched from printf() to puts(). 4.104.114.84.95
(edit) @94b3ee13   01/21/99 22:25:43 Joel Sherrill Made to compile after hacking tftp driver into beginnings of a … 4.104.114.84.95
