source: rtems/c/src/libchip
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @f246caf   07/25/98 14:13:34 Joel Sherrill Interrupts were incorrectly managed with a disable/disable pair rather … 4.104.114.84.95
(edit) @c14a619   07/18/98 18:35:34 Joel Sherrill Removed use of data port for z8530. Move some code around. 4.104.114.84.95
(edit) @16d0e63   07/16/98 00:16:22 Joel Sherrill Corrected header files. 4.104.114.84.95
(edit) @a6f441b   07/16/98 00:16:11 Joel Sherrill Minor corrections for typos to get it to compile. 4.104.114.84.95
(edit) @dd5d2f04   07/16/98 00:03:01 Joel Sherrill Split default baud rate table into its own file. This shrinks the … 4.104.114.84.95
(edit) @849dc107   07/15/98 23:57:41 Joel Sherrill Fixed typos. 4.104.114.84.95
(edit) @8414c033   07/15/98 23:54:24 Joel Sherrill Added default z85c30 register access routines. 4.104.114.84.95
(edit) @cce9322   07/15/98 23:54:08 Joel Sherrill Added default mc68681 register access routines. 4.104.114.84.95
(edit) @991a1ab4   07/15/98 23:21:55 Joel Sherrill Added check for proper deviceType to interrupt processing code. 4.104.114.84.95
(edit) @efaf85fa   07/15/98 23:21:30 Joel Sherrill Added interrupt mask and interrupt status register bit constants. … 4.104.114.84.95
(edit) @49370cd   07/15/98 23:20:50 Joel Sherrill Added default mc68681 register access routines. 4.104.114.84.95
(edit) @198d851   07/15/98 23:20:33 Joel Sherrill Switched from driver's own buffering to using termios. This … 4.104.114.84.95
(edit) @27a66bd   07/15/98 23:15:49 Joel Sherrill Added information on the deviceType field. 4.104.114.84.95
(edit) @66f95fc   07/15/98 23:15:32 Joel Sherrill Added default mc68681 register access routines. 4.104.114.84.95
(edit) @c0573d7   07/15/98 21:40:42 Joel Sherrill Added comment to remove use of TxBuffer? ring buffer in all libchip … 4.104.114.84.95
(edit) @be8cbbf   07/15/98 13:58:23 Joel Sherrill Switched deviceOutputUsesInterrupts to TRUE so output would be … 4.104.114.84.95
(edit) @e283140c   07/15/98 13:53:58 Joel Sherrill Switched to "deviceOutput = TRUE" which made device output use interrupts. 4.104.114.84.95
(edit) @fb32356b   07/09/98 23:32:07 Joel Sherrill Added set attributes routine but did not hook it in to the table. … 4.104.114.84.95
(edit) @abd8c82   07/09/98 23:31:48 Joel Sherrill Added new files. 4.104.114.84.95
(edit) @064b9be   07/09/98 23:30:32 Joel Sherrill Switched to shared default probe routine. 4.104.114.84.95
(edit) @693b5b88   07/09/98 23:30:02 Joel Sherrill Switched to default probe routine. 4.104.114.84.95
(edit) @61ff7ac8   07/09/98 23:29:33 Joel Sherrill Added new baud rate to number function and default serial probe … 4.104.114.84.95
(edit) @e78c474b   07/09/98 22:21:54 Joel Sherrill Added proper handling of extended baud rate table selection at boot … 4.104.114.84.95
(edit) @2c5ea01   07/09/98 22:16:27 Joel Sherrill Properly handle extended baud rate set commands. Temporarily "if 0" … 4.104.114.84.95
(edit) @e3c59dd   07/09/98 22:11:49 Joel Sherrill Corrected definition of MC68681_RX_BUFFER. 4.104.114.84.95
(edit) @2d8e51aa   07/09/98 18:45:28 Joel Sherrill Changed static to MC68681_STATIC to make all data and routines … 4.104.114.84.95
(edit) @b2ec38c8   07/09/98 18:44:10 Joel Sherrill Removed commented out line. 4.104.114.84.95
(edit) @8f6f641e   07/09/98 18:41:49 Joel Sherrill Added sersupp.c. 4.104.114.84.95
(edit) @d94d47b3   07/09/98 18:41:33 Joel Sherrill New files to contain generally needed serial driver support routines. 4.104.114.84.95
(edit) @37e8259   07/09/98 18:40:27 Joel Sherrill Changed static to MC68681_STATIC to make all routines and data global … 4.104.114.84.95
(edit) @8b2492f   07/09/98 18:39:50 Joel Sherrill Added support for the Extended Baud Rate set control found in the Exar … 4.104.114.84.95
(edit) @27045a82   07/09/98 18:38:18 Joel Sherrill Changed static to NS16550_STATIC to make all routines and data global … 4.104.114.84.95
(edit) @677a503   07/09/98 18:37:47 Joel Sherrill Changed static to Z85C30_STATIC so all data and routines could be … 4.104.114.84.95
(edit) @80b1c2f   07/09/98 18:36:19 Joel Sherrill Added information to README.mc68681. Created the basic README and the … 4.104.114.84.95
(edit) @5ae415b   07/05/98 11:04:31 Joel Sherrill Added include of termios.h. Also added a block of comments above the … 4.104.114.84.95
(edit) @4f0ffa57   06/23/98 17:42:46 Joel Sherrill Removed RTS and DTR handling code since the MC68681 seems to only have … 4.104.114.84.95
(edit) @ae21568c   06/23/98 17:40:00 Joel Sherrill New file describing mc68681 libchip driver. 4.104.114.84.95
(edit) @beaaf49f   06/23/98 16:02:52 Joel Sherrill Added numerous comments. 4.104.114.84.95
(edit) @a5d0c7c   06/23/98 15:54:33 Joel Sherrill Added concept of "mate" -- the other port on the same DUART. This is … 4.104.114.84.95
(edit) @b7ebcea3   06/23/98 14:59:26 Joel Sherrill Added close. 4.104.114.84.95
(edit) @25c3ff91   06/23/98 14:55:21 Joel Sherrill Added set attributes and written initialize and first open. 4.104.114.84.95
(edit) @790d421   06/23/98 14:54:42 Joel Sherrill Added more registers. 4.104.114.84.95
(edit) @9eef52b   06/23/98 14:54:30 Joel Sherrill Added set attributes prototype. 4.104.114.84.95
(edit) @8a2d4f2b   06/23/98 14:54:09 Joel Sherrill Added NULL entry for setAttributes. 4.104.114.84.95
(edit) @7deeb16   06/22/98 11:49:38 Joel Sherrill Added initial part of iniitialization. 4.104.114.84.95
(edit) @ab2dbd7   06/22/98 11:09:32 Joel Sherrill Added mc68681 stuff to the makefile. Added numerous constants to … 4.104.114.84.95
(edit) @36152b0e   06/22/98 11:08:16 Joel Sherrill Moved get and set register/data typedefs to this file. 4.104.114.84.95
(edit) @4cd4c5a   06/22/98 11:07:51 Joel Sherrill Moved set and get Register and Data type defininitions to serial.h. … 4.104.114.84.95
(edit) @58b1e95   06/22/98 10:34:34 Joel Sherrill Corrected spacing 4.104.114.84.95
(edit) @424e23ee   06/22/98 10:17:14 Joel Sherrill spacing changes 4.104.114.84.95
(edit) @e4acf68   06/22/98 09:59:22 Joel Sherrill Added comments and corrected spacing. 4.104.114.84.95
(edit) @aa0da6b   06/22/98 09:56:09 Joel Sherrill Added a comment and cleaned up spacing 4.104.114.84.95
(edit) @cd58d82   06/22/98 09:28:03 Joel Sherrill Initial version of these files. 4.104.114.84.95
(edit) @ee3b242b   06/13/98 16:03:57 Joel Sherrill Initial incarnation of libchip compiles. 4.104.114.84.95
(edit) @0737710   06/13/98 15:48:25 Joel Sherrill Base code from ppcn_60x BSP 4.104.114.84.95
(edit) @3ec7bfc   03/24/98 16:24:39 Joel Sherrill Rename hppa1_1 to hppa1.1 and switched to using XXX macros for the … 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @4ef9e99   08/04/97 21:58:00 Joel Sherrill First attempt at values for PPC 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @3d07c8b   09/08/96 16:24:13 Joel Sherrill added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE 4.104.114.84.95
(edit) @64b976a   05/23/96 15:36:46 Joel Sherrill added code to insure that delay is always non-zero 4.104.114.84.95
(edit) @f5674938   04/22/96 16:49:25 Joel Sherrill Fixed so now supports more than 16 nodes. Tested for up to 24 nodes … 4.104.114.84.95
(edit) @c64e4ed4   01/15/96 21:50:28 Joel Sherrill updates from Tony Bennett for PA and UNIX ports 4.104.114.84.95
(edit) @11290355   09/29/95 17:19:16 Joel Sherrill all targets compile .. tony's patches in place 4.104.114.84.95
(edit) @37f4c2d   09/27/95 20:53:58 Joel Sherrill Modified UNIX simulator port so all references to native unix stuff is … 4.104.114.84.95
(edit) @5e9b32b   09/26/95 19:27:15 Joel Sherrill posix support initially added 4.104.114.84.95
(edit) @18c5378   09/22/95 15:35:48 Joel Sherrill moving files around and adding the exec/wrapup directory 4.104.114.84.95
(edit) @3a4ae6c   09/11/95 19:35:39 Joel Sherrill The word "RTEMS" almost completely removed from the core. … 4.104.114.84.95
(edit) @3235ad9   08/23/95 19:30:23 Joel Sherrill Support for variable length names added to Object Handler. This … 4.104.114.84.95
(edit) @b06e68ef   08/17/95 19:51:51 Joel Sherrill Numerous miscellaneous features incorporated from Tony Bennett … 4.104.114.84.95
(edit) @12f86efd   08/11/95 14:23:49 Joel Sherrill minor clean up -- switched to memset for zero'ing SHM 4.104.114.84.95
(edit) @88d594a   05/24/95 21:39:42 Joel Sherrill Fully tested on all in-house targets 4.104.114.84.95
(add) @ac7d5ef0   05/11/95 17:39:37 Joel Sherrill Initial revision 4.104.114.84.95
