Search:
Login
Preferences
About Trac
Register
Forgot your password?
API
Wiki
Timeline
Roadmap
View Tickets
Search
Context Navigation
View Latest Revision
source:
src
libchip
Revision Log Mode:
Stop on copy
Follow copies
Show only adds and deletes
View log starting at
and back to
Show at most
revisions per page.
Show full log messages
Legend:
Added
Modified
Copied or renamed
Diff
Rev
Age
Author
Log Message
(edit)
@e4acf68
06/22/98 09:59:22
Joel Sherrill
Added comments and corrected spacing.
4.10
4.11
4.8
4.9
5
(edit)
@aa0da6b
06/22/98 09:56:09
Joel Sherrill
Added a comment and cleaned up spacing
4.10
4.11
4.8
4.9
5
(edit)
@cd58d82
06/22/98 09:28:03
Joel Sherrill
Initial version of these files.
4.10
4.11
4.8
4.9
5
(edit)
@ee3b242b
06/13/98 16:03:57
Joel Sherrill
Initial incarnation of libchip compiles.
4.10
4.11
4.8
4.9
5
(edit)
@0737710
06/13/98 15:48:25
Joel Sherrill
Base code from ppcn_60x BSP
4.10
4.11
4.8
4.9
5
(edit)
@3ec7bfc
03/24/98 16:24:39
Joel Sherrill
Rename hppa1_1 to hppa1.1 and switched to using
XXX
macros for the …
4.10
4.11
4.8
4.9
5
(edit)
@60b791ad
02/17/98 23:46:28
Joel Sherrill
updated copyright to 1998
4.10
4.11
4.8
4.9
5
(edit)
@98e4ebf5
10/08/97 15:45:54
Joel Sherrill
Fixed typo in the pointer to the license terms.
4.10
4.11
4.8
4.9
5
(edit)
@4ef9e99
08/04/97 21:58:00
Joel Sherrill
First attempt at values for PPC
4.10
4.11
4.8
4.9
5
(edit)
@03f2154e
04/22/97 17:20:27
Joel Sherrill
headers updated to reflect new style copyright notice as part of …
4.10
4.11
4.8
4.9
5
(edit)
@3d07c8b
09/08/96 16:24:13
Joel Sherrill
added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE
4.10
4.11
4.8
4.9
5
(edit)
@64b976a
05/23/96 15:36:46
Joel Sherrill
added code to insure that delay is always non-zero
4.10
4.11
4.8
4.9
5
(edit)
@f5674938
04/22/96 16:49:25
Joel Sherrill
Fixed so now supports more than 16 nodes. Tested for up to 24 nodes …
4.10
4.11
4.8
4.9
5
(edit)
@c64e4ed4
01/15/96 21:50:28
Joel Sherrill
updates from Tony Bennett for PA and UNIX ports
4.10
4.11
4.8
4.9
5
(edit)
@11290355
09/29/95 17:19:16
Joel Sherrill
all targets compile .. tony's patches in place
4.10
4.11
4.8
4.9
5
(edit)
@37f4c2d
09/27/95 20:53:58
Joel Sherrill
Modified UNIX simulator port so all references to native unix stuff is …
4.10
4.11
4.8
4.9
5
(edit)
@5e9b32b
09/26/95 19:27:15
Joel Sherrill
posix support initially added
4.10
4.11
4.8
4.9
5
(edit)
@18c5378
09/22/95 15:35:48
Joel Sherrill
moving files around and adding the exec/wrapup directory
4.10
4.11
4.8
4.9
5
(edit)
@3a4ae6c
09/11/95 19:35:39
Joel Sherrill
The word "RTEMS" almost completely removed from the core. …
4.10
4.11
4.8
4.9
5
(edit)
@3235ad9
08/23/95 19:30:23
Joel Sherrill
Support for variable length names added to Object Handler. This …
4.10
4.11
4.8
4.9
5
(edit)
@b06e68ef
08/17/95 19:51:51
Joel Sherrill
Numerous miscellaneous features incorporated from Tony Bennett …
4.10
4.11
4.8
4.9
5
(edit)
@12f86efd
08/11/95 14:23:49
Joel Sherrill
minor clean up -- switched to memset for zero'ing SHM
4.10
4.11
4.8
4.9
5
(edit)
@88d594a
05/24/95 21:39:42
Joel Sherrill
Fully tested on all in-house targets
4.10
4.11
4.8
4.9
5
(add)
@ac7d5ef0
05/11/95 17:39:37
Joel Sherrill
Initial revision
4.10
4.11
4.8
4.9
5
Note:
See
TracRevisionLog
for help on using the revision log.
Download in other formats:
RSS Feed
ChangeLog
