@693b5b88
07/09/98 23:30:02 |
Joel Sherrill |
Switched to default probe routine.
4.104.114.84.95
@61ff7ac8
07/09/98 23:29:33 |
Joel Sherrill |
Added new baud rate to number function and default serial probe …
4.104.114.84.95
@e78c474b
07/09/98 22:21:54 |
Joel Sherrill |
Added proper handling of extended baud rate table selection at boot …
4.104.114.84.95
@2c5ea01
07/09/98 22:16:27 |
Joel Sherrill |
Properly handle extended baud rate set commands.
Temporarily "if 0" …
4.104.114.84.95
@e3c59dd
07/09/98 22:11:49 |
Joel Sherrill |
Corrected definition of MC68681_RX_BUFFER.
4.104.114.84.95
@2d8e51aa
07/09/98 18:45:28 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all data and routines …
4.104.114.84.95
@b2ec38c8
07/09/98 18:44:10 |
Joel Sherrill |
Removed commented out line.
4.104.114.84.95
@8f6f641e
07/09/98 18:41:49 |
Joel Sherrill |
Added sersupp.c.
4.104.114.84.95
@d94d47b3
07/09/98 18:41:33 |
Joel Sherrill |
New files to contain generally needed serial driver support routines.
4.104.114.84.95
@37e8259
07/09/98 18:40:27 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all routines and data global …
4.104.114.84.95
@8b2492f
07/09/98 18:39:50 |
Joel Sherrill |
Added support for the Extended Baud Rate set control found in the
Exar …
4.104.114.84.95
@27045a82
07/09/98 18:38:18 |
Joel Sherrill |
Changed static to NS16550_STATIC to make all routines and data global …
4.104.114.84.95
@677a503
07/09/98 18:37:47 |
Joel Sherrill |
Changed static to Z85C30_STATIC so all data and routines could be …
4.104.114.84.95
@80b1c2f
07/09/98 18:36:19 |
Joel Sherrill |
Added information to README.mc68681.
Created the basic README and the …
4.104.114.84.95
@5ae415b
07/05/98 11:04:31 |
Joel Sherrill |
Added include of termios.h.
Also added a block of comments above the …
4.104.114.84.95
@4f0ffa57
06/23/98 17:42:46 |
Joel Sherrill |
Removed RTS and DTR handling code since the MC68681 seems to only have …
4.104.114.84.95
@ae21568c
06/23/98 17:40:00 |
Joel Sherrill |
New file describing mc68681 libchip driver.
4.104.114.84.95
@beaaf49f
06/23/98 16:02:52 |
Joel Sherrill |
Added numerous comments.
4.104.114.84.95
@a5d0c7c
06/23/98 15:54:33 |
Joel Sherrill |
Added concept of "mate" -- the other port on the same DUART. This is …
4.104.114.84.95
@b7ebcea3
06/23/98 14:59:26 |
Joel Sherrill |
Added close.
4.104.114.84.95
@25c3ff91
06/23/98 14:55:21 |
Joel Sherrill |
Added set attributes and written initialize and first open.
4.104.114.84.95
@790d421
06/23/98 14:54:42 |
Joel Sherrill |
Added more registers.
4.104.114.84.95
@9eef52b
06/23/98 14:54:30 |
Joel Sherrill |
Added set attributes prototype.
4.104.114.84.95
@8a2d4f2b
06/23/98 14:54:09 |
Joel Sherrill |
Added NULL entry for setAttributes.
4.104.114.84.95
@7deeb16
06/22/98 11:49:38 |
Joel Sherrill |
Added initial part of iniitialization.
4.104.114.84.95
@ab2dbd7
06/22/98 11:09:32 |
Joel Sherrill |
Added mc68681 stuff to the makefile.
Added numerous constants to …
4.104.114.84.95
@36152b0e
06/22/98 11:08:16 |
Joel Sherrill |
Moved get and set register/data typedefs to this file.
4.104.114.84.95
@4cd4c5a
06/22/98 11:07:51 |
Joel Sherrill |
Moved set and get Register and Data type defininitions to serial.h.
4.104.114.84.95
@58b1e95
06/22/98 10:34:34 |
Joel Sherrill |
Corrected spacing
4.104.114.84.95
@424e23ee
06/22/98 10:17:14 |
Joel Sherrill |
spacing changes
4.104.114.84.95
@e4acf68
06/22/98 09:59:22 |
Joel Sherrill |
Added comments and corrected spacing.
4.104.114.84.95
@aa0da6b
06/22/98 09:56:09 |
Joel Sherrill |
Added a comment and cleaned up spacing
4.104.114.84.95
@cd58d82
06/22/98 09:28:03 |
Joel Sherrill |
Initial version of these files.
4.104.114.84.95
@ee3b242b
06/13/98 16:03:57 |
Joel Sherrill |
Initial incarnation of libchip compiles.
4.104.114.84.95
@0737710
06/13/98 15:48:25 |
Joel Sherrill |
Base code from ppcn_60x BSP
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@4ef9e99
08/04/97 21:58:00 |
Joel Sherrill |
First attempt at values for PPC
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@3d07c8b
09/08/96 16:24:13 |
Joel Sherrill |
added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE
4.104.114.84.95
@64b976a
05/23/96 15:36:46 |
Joel Sherrill |
added code to insure that delay is always non-zero
4.104.114.84.95
@f5674938
04/22/96 16:49:25 |
Joel Sherrill |
Fixed so now supports more than 16 nodes. Tested for up to 24 nodes …
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@11290355
09/29/95 17:19:16 |
Joel Sherrill |
all targets compile .. tony's patches in place
4.104.114.84.95
@37f4c2d
09/27/95 20:53:58 |
Joel Sherrill |
Modified UNIX simulator port so all references to native unix
stuff is …
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
@18c5378
09/22/95 15:35:48 |
Joel Sherrill |
moving files around and adding the exec/wrapup directory
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@3235ad9
08/23/95 19:30:23 |
Joel Sherrill |
Support for variable length names added to Object Handler. This …
4.104.114.84.95
@b06e68ef
08/17/95 19:51:51 |
Joel Sherrill |
Numerous miscellaneous features incorporated from Tony Bennett …
4.104.114.84.95
@12f86efd
08/11/95 14:23:49 |
Joel Sherrill |
minor clean up -- switched to memset for zero'ing SHM
4.104.114.84.95
@88d594a
05/24/95 21:39:42 |
Joel Sherrill |
Fully tested on all in-house targets
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
