# # ChangeLog for c/src/libchip in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 06:27:59 Fri, 09 Jun 2017 05:54:45 GMT Sebastian Huber [6081ef3] * c/src/libchip/network/if_fxp.c (modified) if_fxp: Include missing Fix format warnings. Tue, 06 Jun 2017 09:08:16 GMT Sebastian Huber [787f51f] * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/libchip/network/i82586.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) Do not include in kernel-space Update #2833. Tue, 06 Jun 2017 06:03:45 GMT Sebastian Huber [93531e9b] * c/src/libchip/serial/mc68681.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/sys/_termios.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios03/init.c (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/libtests/termios09/init.c (modified) Move RTEMS-specific Termios API content Remove obsolete support for ... Wed, 07 Jun 2017 05:22:38 GMT Sebastian Huber [cf54965] * c/src/libchip/network/i82586.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) network: Include missing Update #2833. Sun, 07 May 2017 21:13:24 GMT Phong Pham [f219adc] * c/src/libchip/serial/ns16550_p.h (modified) missing a couple register names + a #ifndef_ASM__ around serial.h ... Fri, 21 Apr 2017 01:52:09 GMT Joel Sherrill [8ed5889f] * c/src/libchip/network/elnk.c (modified) elnk.c: Fix printf() format warnings Fri, 21 Apr 2017 01:49:07 GMT Joel Sherrill [9f55bfb] * c/src/libchip/network/elnk.c (modified) elnk.c: rtems_elnk_driver_attach() prototype added Fri, 21 Apr 2017 01:47:34 GMT Joel Sherrill [814bd025] * c/src/libchip/network/elnk.c (modified) elnk.c: Make elnk_txDaemon() static to fix warning Fri, 21 Apr 2017 01:44:49 GMT Joel Sherrill [8477652] * c/src/libchip/network/if_fxp.c (modified) if_fxp.c: Add prototype of rtems_fxp_attach() Fri, 21 Apr 2017 01:43:04 GMT Joel Sherrill [169d6f6e] * c/src/libchip/network/if_fxp.c (modified) if_fxp.c: Remove unused variable Fri, 21 Apr 2017 01:40:51 GMT Joel Sherrill [fc91f51] * c/src/libchip/network/dec21140.c (modified) dec21140.c: Add prototype of dec21140_txDaemon() Fri, 21 Apr 2017 01:38:42 GMT Joel Sherrill [5ce0489] * c/src/libchip/network/dec21140.c (modified) dec21140.c: Fix printk() warnings Fri, 21 Apr 2017 01:36:49 GMT Joel Sherrill [40d0a468] * c/src/libchip/network/dec21140.c (modified) dec21140.c: Include to eliminate warnings Fri, 21 Apr 2017 01:27:32 GMT Joel Sherrill [bedd927] * c/src/libchip/network/dec21140.c (modified) dec21140.c: Fix PRIxx formatter Sat, 08 Apr 2017 10:28:46 GMT Cillian O'Donnell [52597b9] * c/src/libchip/network/dec21140.c (modified) libchip/network/dec21140.c: Use inttypes.h to fix 1 warning. Mon, 03 Apr 2017 10:51:51 GMT Sebastian Huber [1301468] * c/src/lib/libbsp/arm/atsam/console/console.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) bsps: Fix baud settings Update #2897. Tue, 21 Mar 2017 19:39:48 GMT Kevin Kirspel [1c6926c1] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2400.h (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2410.h (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c (modified) * c/src/lib/libcpu/sh/sh7032/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/z85c30.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/sys/_termios.h (added) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/include/sys/ttydefaults.h (added) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfmakeraw.c (modified) * cpukit/libcsupport/src/cfmakesane.c (added) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/cfsetspeed.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2index.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/preinstall.am (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.scn (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) * testsuites/libtests/termios02/termios02.scn (modified) * testsuites/libtests/termios03/termios03.scn (modified) * testsuites/libtests/termios04/termios04.scn (modified) * testsuites/libtests/termios05/termios05.scn (modified) * testsuites/libtests/termios06/init.c (modified) * testsuites/libtests/termios06/termios06.scn (modified) * testsuites/libtests/termios07/termios07.scn (modified) * testsuites/libtests/termios08/termios08.scn (modified) * tools/cpu/sh/sci.c (modified) termios: Synchronize with latest FreeBSD headers Adding modified ... Mon, 13 Mar 2017 15:41:53 GMT Joel Sherrill [17d1aa7] * c/src/libchip/serial/mc68681.c (modified) libchip/serial/mc68681.c: Add error check This was spotted by ... Mon, 23 Jan 2017 07:06:41 GMT Sebastian Huber [2711914f] * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libmisc/shell/main_pci.c (modified) Use Update #2803. Fri, 20 Jan 2017 14:29:00 GMT Sebastian Huber [7fbd72c] * c/src/libchip/i2c/spi-sd-card.c (modified) libchip: Really fix high capacity detection Update #2239. Fri, 09 Dec 2016 09:49:49 GMT Sebastian Huber [6a9282d] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspclean.c (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/include/default-initial-extension.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testextension.c (modified) * cpukit/score/include/rtems/score/userext.h (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) Rename is_internal to always_set_to_false Update #2825. Wed, 12 Oct 2016 08:15:29 GMT Pavel Pisa [dfcec559] * c/src/libchip/network/if_fxp.c (modified) libchip/network/if_fxp.c: do not use rtems_interrupt_disable. The ... Tue, 20 Sep 2016 22:14:45 GMT Pavel Pisa [4d3c866] * c/src/libchip/network/if_fxp.c (modified) * c/src/libchip/network/if_fxpvar.h (modified) classic networking: adapt FXP driver to work with actual PCI and IRQ ... Thu, 04 Aug 2016 21:32:06 GMT Pavel Pisa [8c83cbc] * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/if_dc.c (modified) * c/src/libchip/network/if_fxp.c (modified) classic networking: do not reference BSP_irq_enabled_at_i8259s which ... Tue, 21 Jun 2016 11:12:31 GMT Sebastian Huber [ede1a41] * c/src/lib/libbsp/shared/src/irq-default-handler.c (modified) * c/src/libchip/rtc/ds1375.c (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/print.h (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libdrvmgr/drvmgr_translate_check.c (modified) * cpukit/libfs/src/devfs/devfs_show.c (modified) * cpukit/libfs/src/jffs2/include/linux/kernel-rtems.h (modified) * cpukit/libmisc/mouse/mouse_parser.c (modified) * cpukit/libmisc/mouse/serial_mouse.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/sptests/spprintk/init.c (modified) * testsuites/support/include/buffer_test_io.h (modified) Make rtems/print.h independent of rtems/bspIo.h Fri, 17 Jun 2016 06:06:56 GMT Sebastian Huber [16706b72] * c/src/libchip/shmdr/dump.c (modified) bsps: Fix printk() format warning Fri, 17 Jun 2016 06:04:25 GMT Sebastian Huber [305231bd] * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) bsps: Fix MPCI_Fatal() prototype Close #2742. Fri, 22 Apr 2016 01:12:46 GMT Joel Sherrill [381b120] * c/src/libchip/shmdr/send.c (modified) libchip/shmdr/send.c: Fix warning and clean up Fri, 22 Apr 2016 01:12:36 GMT Joel Sherrill [82cb100a] * c/src/libchip/shmdr/poll.c (modified) libchip/shmdr/poll.c: Fix warning and clean up Tue, 31 May 2016 08:25:25 GMT Sebastian Huber [dd2c57d4] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (deleted) * c/src/libchip/Makefile.am (modified) * c/src/libchip/network/README.dwmac (deleted) * c/src/libchip/network/dwmac-1000-core.c (deleted) * c/src/libchip/network/dwmac-1000-dma.c (deleted) * c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c (deleted) * c/src/libchip/network/dwmac-common.h (deleted) * c/src/libchip/network/dwmac-core.c (deleted) * c/src/libchip/network/dwmac-core.h (deleted) * c/src/libchip/network/dwmac-desc-com.c (deleted) * c/src/libchip/network/dwmac-desc-com.h (deleted) * c/src/libchip/network/dwmac-desc-enh.c (deleted) * c/src/libchip/network/dwmac-desc.h (deleted) * c/src/libchip/network/dwmac-regs.h (deleted) * c/src/libchip/network/dwmac.c (deleted) * c/src/libchip/network/dwmac.h (deleted) * c/src/libchip/preinstall.am (modified) libchip: Remove dwmac network interface driver The network ... Wed, 18 May 2016 06:06:54 GMT Sebastian Huber [24713163] * c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/dpram.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Rename _ISR_Disable() and _ISR_Enable() Rename ... Wed, 20 Apr 2016 07:12:07 GMT Chris Johns [8ce75671] * c/src/libchip/serial/ns16550.c (modified) ibchip/ns16550: Minor optimisation. Fri, 06 May 2016 20:08:47 GMT Martin Galvan [b4d7d5d] * c/src/libchip/network/sonic.c (modified) sonic.c: Fix warning on gcc 6 GCC 6.0 previews give the following ... Wed, 02 Mar 2016 19:25:13 GMT Joel Sherrill [12c9dc8f] * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.h (deleted) * c/src/libchip/network/if_fxp.c (modified) pc386: Eliminate pcibios.h and begin removal obsolete PCI BIOS API ... Sat, 14 Mar 2015 16:01:06 GMT Joel Sherrill [be277dd] * c/src/libchip/network/if_fxp.c (modified) libchip/network/if_fxp.c: Do not use rtems_clock_get() Sat, 14 Mar 2015 16:00:39 GMT Joel Sherrill [296b0247] * c/src/libchip/i2c/spi-memdrv.c (modified) libchip/i2c/spi-memdrv.c: Do not use rtems_clock_get() Thu, 05 Mar 2015 09:05:49 GMT Sebastian Huber [5155069] * c/src/libchip/serial/ns16550.c (modified) libchip/serial: Fix warning Fri, 23 Jan 2015 10:24:01 GMT Sebastian Huber [2f16001] * c/src/libchip/i2c/spi-sd-card.c (modified) libchip: Fix high capacity detection for MMC Close #2239. Wed, 19 Nov 2014 20:32:51 GMT Josh Oguin [aed6e1d] * c/src/libchip/serial/z85c30.c (modified) libchip/serial/z85c30.c: Remove redundant assignment This was ... Wed, 19 Nov 2014 20:28:08 GMT Josh Oguin [02958c5e] * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) libchip/serial/ns16550* and z8530*: Assert on baud number to avoid ... Wed, 19 Nov 2014 20:26:58 GMT Josh Oguin [0ad1e80] * c/src/libchip/display/disp_hcms29xx.c (modified) libchip/display/disp_hcms29xx.c: Remove useless variable and check ... Fri, 21 Nov 2014 07:49:57 GMT Sebastian Huber [11925eef] * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/pppd/pppd.h (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio03/init.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/sptests/sp48/init.c (modified) * testsuites/sptests/sp63/init.c (modified) Delete or rename MIN/MAX macros and defines Include ... Thu, 09 Oct 2014 20:35:10 GMT Joel Sherrill [ef4c461] * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/nds/block/block.c (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/coproc/coproc.c (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/irq/irq.c (modified) * c/src/lib/libbsp/arm/nds/irq/irq.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/initSystem.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/video.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/preinstall.am (modified) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/reco.c (modified) * c/src/libchip/serial/ns16550.c (modified) arm/nds: Warning clean up This patch eliminates most of the ... Thu, 09 Oct 2014 15:43:14 GMT Joel Sherrill [6adacd89] * c/src/libchip/rtc/mc146818a.c (modified) libchip/rtc/mc146818a.c: Compiles again and clean up Thu, 09 Oct 2014 15:01:34 GMT Joel Sherrill [79f093b] * c/src/libchip/rtc/mc146818a.h (modified) * c/src/libchip/rtc/mc146818a_ioreg.c (modified) libchip/rtc/mc146818a*: Fix prototypes to use uintptr_t and fix set ... Tue, 07 Oct 2014 09:37:55 GMT Sebastian Huber [8a9bdc5] * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.h (modified) libchip/serial: Task driven mode for NS16550 Tue, 07 Oct 2014 13:42:47 GMT Sebastian Huber [2fd3e65f] * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.h (modified) libchip/serial: Fix NS16550 for pppstart() Call ... Tue, 07 Oct 2014 06:29:16 GMT Sebastian Huber [6ec438e] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-1.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-2.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-3.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/arm/lpc32xx/include/hsu.h (added) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/serial/ns16550-context.c (added) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/ns16550_p.h (modified) libchip/serial: Add alternative NS16550 driver Use the Termios ... Fri, 05 Sep 2014 07:12:34 GMT Sebastian Huber [ddf8d12] * c/src/libchip/network/dwmac-desc-enh.c (modified) libchip/dwmac: Use RTEMS_DEVOLATILE() Fri, 29 Aug 2014 02:48:01 GMT Chris Johns [59990cc] * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/csb336/preinstall.am (modified) * c/src/lib/libbsp/arm/csb337/preinstall.am (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/gba/preinstall.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/preinstall.am (modified) * c/src/lib/libbsp/arm/gumstix/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/rtl22xx/preinstall.am (modified) * c/src/lib/libbsp/arm/smdk2410/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/avr/avrtest/preinstall.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/preinstall.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/preinstall.am (modified) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (modified) * c/src/lib/libbsp/h8300/h8sim/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/preinstall.am (modified) * c/src/lib/libbsp/lm32/milkymist/preinstall.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/preinstall.am (modified) * c/src/lib/libbsp/m32r/m32rsim/preinstall.am (modified) * c/src/lib/libbsp/m68k/av5282/preinstall.am (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68360/preinstall.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/preinstall.am (modified) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf52235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5329/preinstall.am (modified) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme136/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (modified) * c/src/lib/libbsp/m68k/ods68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/sim68000/preinstall.am (modified) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (modified) * c/src/lib/libbsp/mips/genmongoosev/preinstall.am (modified) * c/src/lib/libbsp/mips/hurricane/preinstall.am (modified) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (modified) * c/src/lib/libbsp/mips/malta/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (modified) * c/src/lib/libbsp/powerpc/beatnik/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh4/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc64/niagara/preinstall.am (modified) * c/src/lib/libbsp/sparc64/usiii/preinstall.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/preinstall.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/bfin/preinstall.am (modified) * c/src/lib/libcpu/lm32/preinstall.am (modified) * c/src/lib/libcpu/mips/preinstall.am (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/sparc64/preinstall.am (modified) * c/src/libchip/preinstall.am (modified) * c/src/librtems++/preinstall.am (modified) * cpukit/ftpd/preinstall.am (modified) * cpukit/libfs/src/nfsclient/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/pppd/preinstall.am (modified) * cpukit/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/bfin/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m32r/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sparc64/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate all preinstall.am files. With this patch the ... Fri, 22 Aug 2014 06:53:10 GMT Christian Mauderer [d5f5432] * c/src/lib/libbsp/arm/altera-cyclone-v/README (modified) * c/src/libchip/network/dwmac-common.h (modified) * c/src/libchip/network/dwmac.c (modified) * c/src/libchip/network/dwmac.h (modified) libchip/dwmac: Make PHY address user configurable This patch allows ... Tue, 27 May 2014 09:42:44 GMT Daniel Hellstrom [a20c114] * c/src/libchip/network/greth.c (modified) GRETH: remove TCP/UDP HW checksum generation The GRETH doesn't ... Wed, 30 Apr 2014 08:13:07 GMT Ralf Kirchner [b0e83e12] * c/src/libchip/network/dwmac.c (modified) libchip: Add asserts to dwmac driver Wed, 30 Apr 2014 08:07:20 GMT Ralf Kirchner [64bc102] * c/src/libchip/network/dwmac.c (modified) libchip: Correct netstats message for dwmac driver Wed, 16 Apr 2014 12:22:42 GMT Ralf Kirchner [a38d4a37] * c/src/libchip/network/dwmac.c (modified) libchip: Correct error handling in dwmac driver By fault an ... Thu, 10 Apr 2014 15:06:14 GMT Ralf Kirchner [1613a01b] * c/src/libchip/network/dwmac-1000-dma.c (modified) * c/src/libchip/network/dwmac-core.c (modified) * c/src/libchip/network/dwmac-core.h (modified) * c/src/libchip/network/dwmac.c (modified) libchip: Reduce tx interrupts Reduce number of packet transmitted ... Thu, 10 Apr 2014 15:03:54 GMT Ralf Kirchner [f28b8d45] * c/src/libchip/network/dwmac-desc-enh.c (modified) libchip: Cleanup Thu, 10 Apr 2014 15:02:40 GMT Ralf Kirchner [18fe64a2] * c/src/libchip/network/dwmac.c (modified) libchip: Improve handling of DMA suspends Reset the corresponding ... Tue, 15 Apr 2014 11:33:42 GMT Sebastian Huber [598f39cd] * c/src/libchip/serial/ns16550.c (modified) libchip: SMP support for NS16550 Mon, 31 Mar 2014 16:30:44 GMT Sebastian Huber [8118b670] * c/src/libchip/network/dwmac-desc-enh.c (modified) libchip: Avoid __DEVOLATILE() Mon, 31 Mar 2014 06:39:59 GMT Pavel Pisa [3c21ad7] * c/src/libchip/i2c/spi-sd-card.c (modified) SPI SD-Card: adapt common driver code to block devices core API changes. Thu, 13 Mar 2014 13:35:43 GMT Daniel Cederman [e4b50853] * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) * c/src/libchip/network/greth.c (modified) greth: Make local functions static, remove overflow and correct ... Thu, 13 Mar 2014 13:28:46 GMT Daniel Cederman [5130248e] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c (modified) * c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) * c/src/libchip/network/smc91111.c (modified) * c/src/libchip/network/smc91111exp.h (modified) smc91111: Move driver attach prototype to header file. Also signal ... Thu, 20 Mar 2014 21:10:47 GMT Chris Johns [c499856] * c/src/ada-tests/mptests/mp01/config_base.h (modified) * c/src/ada-tests/mptests/mp01/mp01.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp01/node1/config.h (modified) * c/src/ada-tests/mptests/mp01/node1/mp01_node1.adb (modified) * c/src/ada-tests/mptests/mp01/node2/config.h (modified) * c/src/ada-tests/mptests/mp01/node2/mp01_node2.adb (modified) * c/src/ada-tests/mptests/mp02/config_base.h (modified) * c/src/ada-tests/mptests/mp02/mptest.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/node1/config.h (modified) * c/src/ada-tests/mptests/mp02/node1/mp02_node1.adb (modified) * c/src/ada-tests/mptests/mp02/node2/config.h (modified) * c/src/ada-tests/mptests/mp02/node2/mp02_node2.adb (modified) * c/src/ada-tests/mptests/mp03/config_base.h (modified) * c/src/ada-tests/mptests/mp03/mptest.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/node1/config.h (modified) * c/src/ada-tests/mptests/mp03/node1/mp03_node1.adb (modified) * c/src/ada-tests/mptests/mp03/node2/config.h (modified) * c/src/ada-tests/mptests/mp03/node2/mp03_node2.adb (modified) * c/src/ada-tests/mptests/mp04/config_base.h (modified) * c/src/ada-tests/mptests/mp04/mptest.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/node1/config.h (modified) * c/src/ada-tests/mptests/mp04/node1/mp04_node1.adb (modified) * c/src/ada-tests/mptests/mp04/node2/config.h (modified) * c/src/ada-tests/mptests/mp04/node2/mp04_node2.adb (modified) * c/src/ada-tests/mptests/mp05/config_base.h (modified) * c/src/ada-tests/mptests/mp05/mptest.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/node1/config.h (modified) * c/src/ada-tests/mptests/mp05/node1/mp05_node1.adb (modified) * c/src/ada-tests/mptests/mp05/node2/config.h (modified) * c/src/ada-tests/mptests/mp05/node2/mp05_node2.adb (modified) * c/src/ada-tests/mptests/mp06/config_base.h (modified) * c/src/ada-tests/mptests/mp06/mptest.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/node1/config.h (modified) * c/src/ada-tests/mptests/mp06/node1/mp06_node1.adb (modified) * c/src/ada-tests/mptests/mp06/node2/config.h (modified) * c/src/ada-tests/mptests/mp06/node2/mp06_node2.adb (modified) * c/src/ada-tests/mptests/mp07/config_base.h (modified) * c/src/ada-tests/mptests/mp07/mptest.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/node1/config.h (modified) * c/src/ada-tests/mptests/mp07/node1/mp07_node1.adb (modified) * c/src/ada-tests/mptests/mp07/node2/config.h (modified) * c/src/ada-tests/mptests/mp07/node2/mp07_node2.adb (modified) * c/src/ada-tests/mptests/mp08/config_base.h (modified) * c/src/ada-tests/mptests/mp08/mptest.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/node1/config.h (modified) * c/src/ada-tests/mptests/mp08/node1/mp08_node1.adb (modified) * c/src/ada-tests/mptests/mp08/node2/config.h (modified) * c/src/ada-tests/mptests/mp08/node2/mp08_node2.adb (modified) * c/src/ada-tests/mptests/mp09/config_base.h (modified) * c/src/ada-tests/mptests/mp09/mptest.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/node1/config.h (modified) * c/src/ada-tests/mptests/mp09/node1/mp09_node1.adb (modified) * c/src/ada-tests/mptests/mp09/node2/config.h (modified) * c/src/ada-tests/mptests/mp09/node2/mp09_node2.adb (modified) * c/src/ada-tests/mptests/mp10/config_base.h (modified) * c/src/ada-tests/mptests/mp10/mptest.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/node1/config.h (modified) * c/src/ada-tests/mptests/mp10/node1/mp10_node1.adb (modified) * c/src/ada-tests/mptests/mp10/node2/config.h (modified) * c/src/ada-tests/mptests/mp10/node2/mp10_node2.adb (modified) * c/src/ada-tests/mptests/mp11/config_base.h (modified) * c/src/ada-tests/mptests/mp11/mptest.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/node1/config.h (modified) * c/src/ada-tests/mptests/mp11/node1/mp11_node1.adb (modified) * c/src/ada-tests/mptests/mp11/node2/config.h (modified) * c/src/ada-tests/mptests/mp11/node2/mp11_node2.adb (modified) * c/src/ada-tests/mptests/mp12/config_base.h (modified) * c/src/ada-tests/mptests/mp12/mptest.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/node1/config.h (modified) * c/src/ada-tests/mptests/mp12/node1/mp12_node1.adb (modified) * c/src/ada-tests/mptests/mp12/node2/config.h (modified) * c/src/ada-tests/mptests/mp12/node2/mp12_node2.adb (modified) * c/src/ada-tests/mptests/mp13/config_base.h (modified) * c/src/ada-tests/mptests/mp13/mptest.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/node1/config.h (modified) * c/src/ada-tests/mptests/mp13/node1/mp13_node1.adb (modified) * c/src/ada-tests/mptests/mp13/node2/config.h (modified) * c/src/ada-tests/mptests/mp13/node2/mp13_node2.adb (modified) * c/src/ada-tests/mptests/mp14/config_base.h (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/node1/config.h (modified) * c/src/ada-tests/mptests/mp14/node1/mp14_node1.adb (modified) * c/src/ada-tests/mptests/mp14/node2/config.h (modified) * c/src/ada-tests/mptests/mp14/node2/mp14_node2.adb (modified) * c/src/ada-tests/samples/base_mp/config.h (modified) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_sp/base_sp.adb (modified) * c/src/ada-tests/samples/base_sp/config.h (modified) * c/src/ada-tests/samples/base_sp/sptest.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/hello/config.h (modified) * c/src/ada-tests/samples/hello/hello.adb (modified) * c/src/ada-tests/samples/hello/sptest.adb (modified) * c/src/ada-tests/samples/hello/sptest.ads (modified) * c/src/ada-tests/samples/nsecs/config.h (modified) * c/src/ada-tests/samples/nsecs/nsecs.adb (modified) * c/src/ada-tests/samples/nsecs/sptest.adb (modified) * c/src/ada-tests/samples/nsecs/sptest.ads (modified) * c/src/ada-tests/samples/ticker/config.h (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/samples/ticker/ticker.adb (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.ads (modified) * c/src/ada-tests/sptests/sp02/config.h (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/config.h (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/config.h (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/config.h (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/config.h (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/config.h (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/config.h (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/config.h (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/config.h (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/config.h (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/config.h (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/config.h (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/config.h (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/config.h (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/config.h (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/config.h (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/config.h (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/config.h (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/config.h (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/config.h (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spname01/config.h (modified) * c/src/ada-tests/sptests/spname01/spname01.adb (modified) * c/src/ada-tests/sptests/spname01/sptest.adb (modified) * c/src/ada-tests/sptests/spname01/sptest.ads (modified) * c/src/ada-tests/support/address_io.adb (modified) * c/src/ada-tests/support/address_io.ads (modified) * c/src/ada-tests/support/float_io.ads (modified) * c/src/ada-tests/support/fp.inc (modified) * c/src/ada-tests/support/integer.inc (modified) * c/src/ada-tests/support/rtems_calling_overhead.ads (modified) * c/src/ada-tests/support/status_io.ads (modified) * c/src/ada-tests/support/test_support.adb (modified) * c/src/ada-tests/support/test_support.ads (modified) * c/src/ada-tests/support/time_test_support.adb (modified) * c/src/ada-tests/support/time_test_support.ads (modified) * c/src/ada-tests/support/timer_driver.adb (modified) * c/src/ada-tests/support/timer_driver.ads (modified) * c/src/ada-tests/support/unsigned32_io.ads (modified) * c/src/ada-tests/tmtests/tm01/config.h (modified) * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm02/config.h (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/config.h (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/config.h (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/config.h (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/config.h (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/config.h (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/config.h (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/config.h (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/config.h (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/config.h (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/config.h (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/config.h (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/config.h (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/config.h (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/config.h (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/config.h (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/config.h (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/config.h (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/config.h (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/config.h (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/config.h (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/config.h (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/config.h (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/config.h (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/config.h (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/config.h (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/config.h (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/config.h (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) * c/src/ada/rtems-barrier.adb (modified) * c/src/ada/rtems-barrier.ads (modified) * c/src/ada/rtems-clock.adb (modified) * c/src/ada/rtems-clock.ads (modified) * c/src/ada/rtems-cpu_usage.ads (modified) * c/src/ada/rtems-debug.adb (modified) * c/src/ada/rtems-debug.ads (modified) * c/src/ada/rtems-event.adb (modified) * c/src/ada/rtems-event.ads (modified) * c/src/ada/rtems-extension.adb (modified) * c/src/ada/rtems-extension.ads (modified) * c/src/ada/rtems-fatal.adb (modified) * c/src/ada/rtems-fatal.ads (modified) * c/src/ada/rtems-interrupt.ads (modified) * c/src/ada/rtems-io.adb (modified) * c/src/ada/rtems-io.ads (modified) * c/src/ada/rtems-message_queue.adb (modified) * c/src/ada/rtems-message_queue.ads (modified) * c/src/ada/rtems-multiprocessing.adb (modified) * c/src/ada/rtems-multiprocessing.ads (modified) * c/src/ada/rtems-object.adb (modified) * c/src/ada/rtems-object.ads (modified) * c/src/ada/rtems-partition.adb (modified) * c/src/ada/rtems-partition.ads (modified) * c/src/ada/rtems-port.adb (modified) * c/src/ada/rtems-port.ads (modified) * c/src/ada/rtems-rate_monotonic.adb (modified) * c/src/ada/rtems-rate_monotonic.ads (modified) * c/src/ada/rtems-region.adb (modified) * c/src/ada/rtems-region.ads (modified) * c/src/ada/rtems-semaphore.adb (modified) * c/src/ada/rtems-semaphore.ads (modified) * c/src/ada/rtems-signal.adb (modified) * c/src/ada/rtems-signal.ads (modified) * c/src/ada/rtems-stack_checker.ads (modified) * c/src/ada/rtems-tasks.adb (modified) * c/src/ada/rtems-tasks.ads (modified) * c/src/ada/rtems-timer.adb (modified) * c/src/ada/rtems-timer.ads (modified) * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/irq.h (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/tm27.h (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.h (modified) * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb336/startup/memmap.c (modified) * c/src/lib/libbsp/arm/csb337/console/fbcons.c (modified) * c/src/lib/libbsp/arm/csb337/console/uarts.c (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/sed1356.h (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/startup/memmap.c (modified) * c/src/lib/libbsp/arm/csb337/startup/umonsupp.c (modified) * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/ep7312.h (modified) * c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.h (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/timer/timer.c (modified) * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/gba/console/conio.c (modified) * c/src/lib/libbsp/arm/gba/console/console.c (modified) * c/src/lib/libbsp/arm/gba/console/defaultfont.h (modified) * c/src/lib/libbsp/arm/gba/include/arm_mode_bits.h (modified) * c/src/lib/libbsp/arm/gba/include/asm_macros.h (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/include/conio.h (modified) * c/src/lib/libbsp/arm/gba/include/gba.h (modified) * c/src/lib/libbsp/arm/gba/include/gba_registers.h (modified) * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/irq/irq.h (modified) * c/src/lib/libbsp/arm/gba/start/start.S (modified) * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gba/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gba/timer/timer.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/console/console-io.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/irq.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gp32/console/uart.c (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/start/start.S (modified) * c/src/lib/libbsp/arm/gp32/startup/bspidle.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gp32/startup/memmap.c (modified) * c/src/lib/libbsp/arm/gumstix/console/uarts.c (modified) * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/tm27.h (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/io.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/lm3s69xx.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/ssi.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/syscon.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/uart.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/ssi/ssi.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstarthook.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/io.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/syscon.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-1.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-2.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-3.c (modified) * c/src/lib/libbsp/arm/lpc24xx/i2c/i2c-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/i2c/i2c.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/dma.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/i2c.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/io.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lcd.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-ethernet-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc17xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/ssp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/start-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq-dispatch.c (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/bspidle.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/dma-copy.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/lcd.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/ssp/ssp.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/fb-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-dynamic.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-static.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-mpu.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-pinsel.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/arm/lpc32xx/include/boot.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/emc.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/i2c.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-ethernet-config.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/mmu.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/nand-mlc.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/tm27.h (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/boot.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/emc.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/idle-thread.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-erase-block-safe.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-read-blocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-write-blocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-select.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/nds/block/block.c (modified) * c/src/lib/libbsp/arm/nds/clock/clock.c (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/my_ipc.h (modified) * c/src/lib/libbsp/arm/nds/include/types.h (modified) * c/src/lib/libbsp/arm/nds/irq/irq.c (modified) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/nds/sound/sound.c (modified) * c/src/lib/libbsp/arm/nds/sound/sound.h (modified) * c/src/lib/libbsp/arm/nds/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/timer/timer.c (modified) * c/src/lib/libbsp/arm/nds/tools/runtest (modified) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.h (modified) * c/src/lib/libbsp/arm/nds/wifi/compat.c (modified) * c/src/lib/libbsp/arm/nds/wifi/compat.h (modified) * c/src/lib/libbsp/arm/nds/wifi/wifi.c (modified) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/usart.c (modified) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/include/irq.h (modified) * c/src/lib/libbsp/arm/raspberrypi/include/mmu.h (modified) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (modified) * c/src/lib/libbsp/arm/raspberrypi/include/usart.h (modified) * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/fb-config.c (modified) * c/src/lib/libbsp/arm/rtl22xx/README (modified) * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (modified) * c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c (modified) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl011.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl050.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/include/armv7m-irq.h (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq-dispatch.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-clock.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-irq.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-tm27.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl011-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl050-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl050.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl111-fb.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl111-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-dma.h (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-emc.h (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-i2s.h (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-lcd.h (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-timer.h (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) * c/src/lib/libbsp/arm/shared/mminit.c (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/bsp-start-memcpy.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv4 (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv7m (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/smdk2410/startup/memmap.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (modified) * c/src/lib/libbsp/arm/stm32f4/i2c/i2c-config.c (modified) * c/src/lib/libbsp/arm/stm32f4/i2c/i2c.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/i2c.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/io.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/irq.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32_i2c.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32_usart.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_gpio.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/usart.h (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstarthook.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/io.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/rcc.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/start-config-io.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/console-config.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/tm27.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c (modified) * c/src/lib/libbsp/avr/avrtest/console/console-io.c (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/console/console.c (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/cplb.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/tm27.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/console/console.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/network/networkconfig.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/eZKit533/console/console-io.c (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/cplb.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/tm27.h (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c (modified) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/startup/h8bdinstallirq.c (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/clock/todcfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_select.c (modified) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (modified) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.h (modified) * c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/kbd_parser.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (modified) * c/src/lib/libbsp/i386/pc386/console/rtd316.h (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse_config.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.h (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/crt.h (modified) * c/src/lib/libbsp/i386/pc386/include/tm27.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/bspcmdline.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspreset.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/shared/comm/gdb_glue.c (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/i386/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/coverhd.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/tm27.h (modified) * c/src/lib/libbsp/lm32/milkymist/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/include/system_conf.h (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/clock.h (modified) * c/src/lib/libbsp/lm32/shared/console/console.c (modified) * c/src/lib/libbsp/lm32/shared/console/uart.c (modified) * c/src/lib/libbsp/lm32/shared/console/uart.h (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/lm32-debug.S (modified) * c/src/lib/libbsp/lm32/shared/include/irq.h (modified) * c/src/lib/libbsp/lm32/shared/irq/irq.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ac97/ac97.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ac97/milkymist_ac97.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_buttons/buttons.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_buttons/milkymist_buttons.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/clock.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/uart.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/uart.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_dmx/dmx.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_dmx/milkymist_dmx.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_flash/flash.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_flash/milkymist_flash.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_gpio/gpio.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_gpio/milkymist_gpio.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ir/ir.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_ir/milkymist_ir.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/milkymist_memcard.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_midi/midi.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_midi/milkymist_midi.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_pfpu/milkymist_pfpu.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_pfpu/pfpu.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_tmu/milkymist_tmu.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_tmu/tmu.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/comloc.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/milkymist_usbinput.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/usbinput.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/milkymist_versions.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/versions.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_video/milkymist_video.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_video/video.c (modified) * c/src/lib/libbsp/lm32/shared/start/start.S (modified) * c/src/lib/libbsp/lm32/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/lm32/shared/timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/dp83848phy.h (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/console/console-io.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/startup/bspstart.c (modified) * c/src/lib/libbsp/m32r/m32rsim/console/console-io.c (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/tm27.h (modified) * c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c (modified) * c/src/lib/libbsp/m68k/av5282/include/tm27.h (modified) * c/src/lib/libbsp/m68k/av5282/start/start.S (modified) * c/src/lib/libbsp/m68k/av5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/csb360/console/console-io.c (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/tm27.h (modified) * c/src/lib/libbsp/m68k/csb360/start/start.S (modified) * c/src/lib/libbsp/m68k/csb360/startup/init5272.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/tm27.h (modified) * c/src/lib/libbsp/m68k/gen68360/spi/m360_spi.c (modified) * c/src/lib/libbsp/m68k/gen68360/spi/m360_spi.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/README (modified) * c/src/lib/libbsp/m68k/genmcf548x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/irq.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/tm27.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/irq/intc-icr-init-values.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/network/network.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/start/start.S (modified) * c/src/lib/libbsp/m68k/genmcf548x/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/startup/init548x.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/startup/linkcmds.COBRA5475 (modified) * c/src/lib/libbsp/m68k/genmcf548x/startup/linkcmds.m5484FireEngine (modified) * c/src/lib/libbsp/m68k/genmcf548x/startup/linkcmds.m5484FireEngine.flash (modified) * c/src/lib/libbsp/m68k/genmcf548x/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mcf5206elite/README (modified) * c/src/lib/libbsp/m68k/mcf5206elite/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/i2c/i2c.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/i2c/i2cdrv.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/ds1307.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/i2c.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/i2cdrv.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/nvram.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/nvram/nvram.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/gdbinit (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds.flash (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tod/todcfg.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/runtest (modified) * c/src/lib/libbsp/m68k/mcf52235/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf52235/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf52235/startup/bspgetcpuclockspeed.c (modified) * c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf52235/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/debugio.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5235/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf5235/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspgetcpuclockspeed.c (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/mcf5329/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mcf5329/start/start.S (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mcf5329/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mrm332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/start/start.S (modified) * c/src/lib/libbsp/m68k/mrm332/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/start_c.c (modified) * c/src/lib/libbsp/m68k/mrm332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme162/tod/tod.c (modified) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.h (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/tm27.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/shared/bspspuriousinit.c (modified) * c/src/lib/libbsp/m68k/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/m68k/shared/m68000spurious.c (modified) * c/src/lib/libbsp/m68k/shared/mvme/mvme16x_hw.h (modified) * c/src/lib/libbsp/m68k/shared/start/start.S (modified) * c/src/lib/libbsp/m68k/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/m68k/sim68000/console/conscfg.c (modified) * c/src/lib/libbsp/m68k/sim68000/console/debugio.c (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/tm27.h (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/start/start.S (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspreset.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/init5282.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/uC5282/timer/timer.c (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/csb350/console/console-io.c (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/include/irq.h (modified) * c/src/lib/libbsp/mips/csb350/include/tm27.h (modified) * c/src/lib/libbsp/mips/csb350/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/csb350/network/network.c (modified) * c/src/lib/libbsp/mips/csb350/start/start.S (modified) * c/src/lib/libbsp/mips/csb350/startup/bspreset.c (modified) * c/src/lib/libbsp/mips/csb350/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/irq.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/tm27.h (modified) * c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/timer.c (modified) * c/src/lib/libbsp/mips/hurricane/clock/ckinit.c (modified) * c/src/lib/libbsp/mips/hurricane/console/console.c (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/coverhd.h (modified) * c/src/lib/libbsp/mips/hurricane/include/irq.h (modified) * c/src/lib/libbsp/mips/hurricane/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/usc.S (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/console/console-io.c (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/irq.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/tm27.h (modified) * c/src/lib/libbsp/mips/jmr3904/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/jmr3904/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/jmr3904/timer/timer.c (modified) * c/src/lib/libbsp/mips/jmr3904/tools/runtest.in (modified) * c/src/lib/libbsp/mips/malta/console/conscfg.c (modified) * c/src/lib/libbsp/mips/malta/console/printk_support.c (modified) * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) * c/src/lib/libbsp/mips/malta/include/irq.h (modified) * c/src/lib/libbsp/mips/malta/include/pci.h (modified) * c/src/lib/libbsp/mips/malta/irq/interruptmask.c (modified) * c/src/lib/libbsp/mips/malta/irq/maxvectors.c (modified) * c/src/lib/libbsp/mips/malta/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/malta/pci/pci.c (modified) * c/src/lib/libbsp/mips/malta/pci/pcifinddevice.c (modified) * c/src/lib/libbsp/mips/malta/pci/pcilistdevices.c (modified) * c/src/lib/libbsp/mips/malta/startup/bspreset.c (modified) * c/src/lib/libbsp/mips/malta/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/malta/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/malta/startup/simple_access.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/console/console-io.c (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/irq.h (modified) * c/src/lib/libbsp/mips/rbtx4925/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/console/console-io.c (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/irq.h (modified) * c/src/lib/libbsp/mips/rbtx4938/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/irq/exception.S (modified) * c/src/lib/libbsp/mips/shared/irq/i8259.c (modified) * c/src/lib/libbsp/mips/shared/irq/i8259.h (modified) * c/src/lib/libbsp/mips/shared/irq/interruptmask.c (modified) * c/src/lib/libbsp/mips/shared/irq/interruptmask_TX49.c (modified) * c/src/lib/libbsp/mips/shared/irq/irq.c (modified) * c/src/lib/libbsp/mips/shared/irq/maxvectors.c (modified) * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (modified) * c/src/lib/libbsp/moxie/moxiesim/console/console-io.c (modified) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) * c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/start/crtnn.s (modified) * c/src/lib/libbsp/nios2/nios2_iss/start/start.S (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/main.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/setvec.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/powerpc/beatnik/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/beatnik/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/config.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/console.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/init68360.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/m68360.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ep1a/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c (modified) * c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.h (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2cdrv.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.h (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata-dma-pio-single.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata-instance.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/idecfg.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/ata.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bestcomm.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bestcomm_ops.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/i2c.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/i2cdrv.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/irq.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/mpc5200.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/mscan-base.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan-base.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan_int.h (modified) * c/src/lib/libbsp/powerpc/gen5200/network_5200/network.c (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/m93cxx.h (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.h (modified) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c (modified) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.h (modified) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bestcomm.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/uboot_support.c (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.h (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/irq.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/tsec-config.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bsprestart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/uboot_support.c (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/haleakala/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/haleakala/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c.nocache (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/mmutlbtab.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-generic.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/console-esci.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/console-generic.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/console-linflex.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/smsc9218i.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/start/start.S (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/get-system-clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/idle-thread.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/restart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/sd-card-init.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-cache.S (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-prologue.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-watchdog.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/lock.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/qemuppc/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/intercom.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/mmu.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/qoriq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/tsec-config.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/u-boot-config.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/network/if_intercom.c (modified) * c/src/lib/libbsp/powerpc/qoriq/network/network.c (modified) * c/src/lib/libbsp/powerpc/qoriq/rtc/rtc-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/intercom-mpci.c (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/intercom.c (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/lock.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolebsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/no_pic.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/exception.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/head.S (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/lib.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/mm.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/consoleIo.h (modified) * c/src/lib/libbsp/powerpc/shared/console/inch.c (modified) * c/src/lib/libbsp/powerpc/shared/console/keyboard.h (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/include/start.h (modified) * c/src/lib/libbsp/powerpc/shared/include/tictac.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.h (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (modified) * c/src/lib/libbsp/powerpc/shared/showbats.c (modified) * c/src/lib/libbsp/powerpc/shared/src/bsp-start-zero.S (modified) * c/src/lib/libbsp/powerpc/shared/src/memcpy.c (modified) * c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c (modified) * c/src/lib/libbsp/powerpc/shared/src/tictac.c (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspidle.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/zerobss.c (modified) * c/src/lib/libbsp/powerpc/shared/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) * c/src/lib/libbsp/powerpc/shared/uboot_getenv.c (modified) * c/src/lib/libbsp/powerpc/ss555/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/ss555/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/ss555/start/start.S (modified) * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ss555/startup/iss555.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/include/irq.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/8xx_immap.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/irq.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/tqm.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_fec.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_scc.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/mmutlbtab.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex/network/xiltemac.c (modified) * c/src/lib/libbsp/powerpc/virtex/network/xiltemac.h (modified) * c/src/lib/libbsp/powerpc/virtex/start/start.S (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh1/start/start.S (modified) * c/src/lib/libbsp/sh/gensh1/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/console/config.c (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/start/start.ram (modified) * c/src/lib/libbsp/sh/gensh2/start/start.rom (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/console/console.c (modified) * c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/sdram.h (modified) * c/src/lib/libbsp/sh/gensh4/include/tm27.h (modified) * c/src/lib/libbsp/sh/gensh4/start/start.S (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom2ram (modified) * c/src/lib/libbsp/sh/shared/bsphwinit.c (modified) * c/src/lib/libbsp/sh/shared/console.c (modified) * c/src/lib/libbsp/sh/shared/setvec.c (modified) * c/src/lib/libbsp/sh/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/start/start.S (modified) * c/src/lib/libbsp/sh/shsim/trap34/console-io.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bspinit.c (modified) * c/src/lib/libbsp/shared/bsppost.c (modified) * c/src/lib/libbsp/shared/bsppredriverhook.c (modified) * c/src/lib/libbsp/shared/bsppretaskinghook.c (modified) * c/src/lib/libbsp/shared/bspreset.c (modified) * c/src/lib/libbsp/shared/bspreset_loop.c (modified) * c/src/lib/libbsp/shared/bspstart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/shared/console-output-char.c (modified) * c/src/lib/libbsp/shared/console-polled.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_control.c (modified) * c/src/lib/libbsp/shared/console_private.h (modified) * c/src/lib/libbsp/shared/console_read.c (modified) * c/src/lib/libbsp/shared/console_select.c (modified) * c/src/lib/libbsp/shared/console_select_simple.c (modified) * c/src/lib/libbsp/shared/console_write.c (modified) * c/src/lib/libbsp/shared/cpucounterdiff.c (modified) * c/src/lib/libbsp/shared/cpucounterread.c (modified) * c/src/lib/libbsp/shared/dummy_printk_support.c (modified) * c/src/lib/libbsp/shared/get-serial-mouse-ps2.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/shared/include/coverhd.h (modified) * c/src/lib/libbsp/shared/include/default-initial-extension.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/include/irq-info.h (modified) * c/src/lib/libbsp/shared/include/irq.h (modified) * c/src/lib/libbsp/shared/include/mm.h (modified) * c/src/lib/libbsp/shared/include/stackalloc.h (modified) * c/src/lib/libbsp/shared/include/tm27.h (modified) * c/src/lib/libbsp/shared/include/u-boot.h (modified) * c/src/lib/libbsp/shared/include/uart-output-char.h (modified) * c/src/lib/libbsp/shared/include/utility.h (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shared/setvec.c (modified) * c/src/lib/libbsp/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/shared/src/bsp-uboot-board-info.c (modified) * c/src/lib/libbsp/shared/src/irq-default-handler.c (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/shared/src/irq-info.c (modified) * c/src/lib/libbsp/shared/src/irq-legacy.c (modified) * c/src/lib/libbsp/shared/src/irq-server.c (modified) * c/src/lib/libbsp/shared/src/irq-shell.c (modified) * c/src/lib/libbsp/shared/src/stackalloc.c (modified) * c/src/lib/libbsp/shared/src/uart-output-char.c (modified) * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libbsp/shared/tod.h (modified) * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * c/src/lib/libbsp/shared/umon/umon.h (modified) * c/src/lib/libbsp/shared/umon/umoncons.c (modified) * c/src/lib/libbsp/shared/umon/umonrtemsglue.c (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/erc32/include/tm27.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspdelay.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspidle.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/erc32mec.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon2/cchip/cchip.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) * c/src/lib/libbsp/sparc/leon2/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon2/include/tm27.h (modified) * c/src/lib/libbsp/sparc/leon2/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bspdelay.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bspidle.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/leon2/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/amba.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/include/cache_.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/include/tm27.h (modified) * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon3/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspdelay.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspidle.S (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspreset.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/eirq.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/leon3/timer/timer.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553brm.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c (modified) * c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm.h (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) * c/src/lib/libbsp/sparc/shared/include/grlib.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw_pci.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h (modified) * c/src/lib/libbsp/sparc/shared/include/i2cmst.h (modified) * c/src/lib/libbsp/sparc/shared/include/occan.h (modified) * c/src/lib/libbsp/sparc/shared/include/occan_pci.h (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/sparc/shared/startup/early_malloc.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/tm27.h (modified) * c/src/lib/libbsp/sparc64/niagara/start/bspinit.S (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/console/conscfg.c (modified) * c/src/lib/libbsp/sparc64/shared/include/asm.h (modified) * c/src/lib/libbsp/sparc64/shared/include/traptable.h (modified) * c/src/lib/libbsp/sparc64/shared/start/trap_table.S (modified) * c/src/lib/libbsp/sparc64/shared/startup/bsppredriverhook.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/tm27.h (modified) * c/src/lib/libbsp/sparc64/usiii/start/bspinit.S (modified) * c/src/lib/libbsp/v850/gdbv850sim/console/console-io.c (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/startup/bspreset.c (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_dbgu.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_emac.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_gpio.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_mem.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_pmc.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/at91rm9200_usart.h (modified) * c/src/lib/libcpu/arm/at91rm9200/include/bits.h (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.h (modified) * c/src/lib/libcpu/arm/at91rm9200/pmc/pmc.c (modified) * c/src/lib/libcpu/arm/at91rm9200/timer/timer.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/lpc22xx/include/lpc22xx.h (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.h (modified) * c/src/lib/libcpu/arm/lpc22xx/timer/timer.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/include/mc9328mxl.h (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.h (modified) * c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c (modified) * c/src/lib/libcpu/arm/pxa255/include/ffuart.h (modified) * c/src/lib/libcpu/arm/pxa255/include/pxa255.h (modified) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S (modified) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.h (modified) * c/src/lib/libcpu/arm/pxa255/pmc/pmc.c (modified) * c/src/lib/libcpu/arm/pxa255/timer/timer.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/timer/timer.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) * c/src/lib/libcpu/arm/shared/include/cache_.h (modified) * c/src/lib/libcpu/bfin/bf52x/include/bf52x.h (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.h (modified) * c/src/lib/libcpu/bfin/cache/cache.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * c/src/lib/libcpu/bfin/clock/tod.h (modified) * c/src/lib/libcpu/bfin/include/bf533.h (modified) * c/src/lib/libcpu/bfin/include/bf537.h (modified) * c/src/lib/libcpu/bfin/include/cecRegs.h (modified) * c/src/lib/libcpu/bfin/include/coreTimerRegs.h (modified) * c/src/lib/libcpu/bfin/include/dmaRegs.h (modified) * c/src/lib/libcpu/bfin/include/ebiuRegs.h (modified) * c/src/lib/libcpu/bfin/include/ethernetRegs.h (modified) * c/src/lib/libcpu/bfin/include/gpioRegs.h (modified) * c/src/lib/libcpu/bfin/include/memoryRegs.h (modified) * c/src/lib/libcpu/bfin/include/mmuRegs.h (modified) * c/src/lib/libcpu/bfin/include/ppiRegs.h (modified) * c/src/lib/libcpu/bfin/include/rtcRegs.h (modified) * c/src/lib/libcpu/bfin/include/sicRegs.h (modified) * c/src/lib/libcpu/bfin/include/spiRegs.h (modified) * c/src/lib/libcpu/bfin/include/sportRegs.h (modified) * c/src/lib/libcpu/bfin/include/timerRegs.h (modified) * c/src/lib/libcpu/bfin/include/twiRegs.h (modified) * c/src/lib/libcpu/bfin/include/uartRegs.h (modified) * c/src/lib/libcpu/bfin/include/wdogRegs.h (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.h (modified) * c/src/lib/libcpu/bfin/mmu/mmu.c (modified) * c/src/lib/libcpu/bfin/mmu/mmu.h (modified) * c/src/lib/libcpu/bfin/network/ethernet.c (modified) * c/src/lib/libcpu/bfin/network/ethernet.h (modified) * c/src/lib/libcpu/bfin/serial/spi.c (modified) * c/src/lib/libcpu/bfin/serial/spi.h (modified) * c/src/lib/libcpu/bfin/serial/twi.c (modified) * c/src/lib/libcpu/bfin/serial/twi.h (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/bfin/serial/uart.h (modified) * c/src/lib/libcpu/bfin/timer/timer.c (modified) * c/src/lib/libcpu/i386/byteorder.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/cpuModel.S (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/idtr.S (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c (modified) * c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c (modified) * c/src/lib/libcpu/m68k/mcf5206/include/mcf5206e.h (modified) * c/src/lib/libcpu/m68k/mcf5206/include/mcfmbus.h (modified) * c/src/lib/libcpu/m68k/mcf5206/include/mcfuart.h (modified) * c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S (modified) * c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c (modified) * c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c (modified) * c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c (modified) * c/src/lib/libcpu/m68k/mcf5272/include/mcf5272.h (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S (modified) * c/src/lib/libcpu/m68k/mcf548x/include/mcf548x.h (modified) * c/src/lib/libcpu/m68k/mcf548x/mcdma/mcdma_glue.c (modified) * c/src/lib/libcpu/m68k/mcf548x/mcdma/mcdma_glue.h (modified) * c/src/lib/libcpu/m68k/shared/misc/m68kidle.c (modified) * c/src/lib/libcpu/mips/au1x00/include/au1x00.h (modified) * c/src/lib/libcpu/mips/au1x00/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c (modified) * c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/rm52xx/include/rm5231.h (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.S (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.h (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips/tx39/include/tx3904.h (modified) * c/src/lib/libcpu/mips/tx49/include/tx4925.h (modified) * c/src/lib/libcpu/mips/tx49/include/tx4938.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/dspi/dspi.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/emios/emios.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/fec/fec.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/dspi.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/edma.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/emios.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/esci.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/reg-defs.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-edma.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-mmu.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/siu.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/watchdog.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/misc/copy.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/siu/siu.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/include/console.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/include/mpc5xx.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.h (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/brg.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/include/cpm.h (modified) * c/src/lib/libcpu/powerpc/mpc8260/include/mmu.h (modified) * c/src/lib/libcpu/powerpc/mpc8260/mmu/mmu.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/gtm/gtm.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/gtm.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/spi/mpc83xx_spidrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/spi/mpc83xx_spidrv.h (modified) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/include/cpm.h (modified) * c/src/lib/libcpu/powerpc/mpc8xx/include/mmu.h (modified) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/mmu.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq_supp.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/nested_irq_test.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc-code-copy.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_alignment.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_naked.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_test.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/debugmod.h (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * c/src/lib/libcpu/powerpc/shared/include/byteorder.h (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) * c/src/lib/libcpu/powerpc/shared/include/io.h (modified) * c/src/lib/libcpu/powerpc/shared/include/mmu.h (modified) * c/src/lib/libcpu/powerpc/shared/include/page.h (modified) * c/src/lib/libcpu/powerpc/shared/include/pgtable.h (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * c/src/lib/libcpu/powerpc/shared/include/spr.h (modified) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7032/delay/delay.c (modified) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (modified) * c/src/lib/libcpu/sh/sh7032/include/ispsh7032.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_sci.h (modified) * c/src/lib/libcpu/sh/sh7032/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7045/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (modified) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/ispsh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sci_termios.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_sci.h (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/ispsh7045.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7750/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/iosh7750.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/ipl.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/ispsh7750.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/sh4_regs.h (modified) * c/src/lib/libcpu/sh/sh7750/include/rtems/score/sh7750_regs.h (modified) * c/src/lib/libcpu/sh/sh7750/include/sh/sh4uart.h (modified) * c/src/lib/libcpu/sh/sh7750/sci/console.c (modified) * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/ispsh7750.c (modified) * c/src/lib/libcpu/sh/sh7750/timer/timer.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/ispshgdb.c (modified) * c/src/lib/libcpu/shared/include/cache.h (modified) * c/src/lib/libcpu/shared/src/cache_aligned_malloc.c (modified) * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/access/access_le.c (modified) * c/src/lib/libcpu/sparc/include/libcpu/access.h (modified) * c/src/lib/libcpu/sparc/include/libcpu/byteorder.h (modified) * c/src/lib/libcpu/sparc64/shared/interrupts/installisrentries.c (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/libchip/display/disp_fonts.h (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) * c/src/libchip/display/disp_hcms29xx.h (modified) * c/src/libchip/display/font_hcms29xx.c (modified) * c/src/libchip/display/font_hcms29xx.h (modified) * c/src/libchip/i2c/i2c-sc620.c (modified) * c/src/libchip/i2c/i2c-sc620.h (modified) * c/src/libchip/i2c/spi-flash-m25p40.c (modified) * c/src/libchip/i2c/spi-flash-m25p40.h (modified) * c/src/libchip/i2c/spi-fram-fm25l256.c (modified) * c/src/libchip/i2c/spi-fram-fm25l256.h (modified) * c/src/libchip/i2c/spi-memdrv.c (modified) * c/src/libchip/i2c/spi-memdrv.h (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/i2c/spi-sd-card.h (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata.h (modified) * c/src/libchip/ide/ata_internal.h (modified) * c/src/libchip/ide/ata_util.c (modified) * c/src/libchip/ide/ide_controller.c (modified) * c/src/libchip/ide/ide_ctrl.h (modified) * c/src/libchip/ide/ide_ctrl_cfg.h (modified) * c/src/libchip/ide/ide_ctrl_io.h (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/cs8900.h (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/greth.c (modified) * c/src/libchip/network/greth.h (modified) * c/src/libchip/network/open_eth.c (modified) * c/src/libchip/network/sonic.c (modified) * c/src/libchip/network/sonic.h (modified) * c/src/libchip/rtc/icm7170.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/icm7170_reg.c (modified) * c/src/libchip/rtc/icm7170_reg2.c (modified) * c/src/libchip/rtc/icm7170_reg4.c (modified) * c/src/libchip/rtc/icm7170_reg8.c (modified) * c/src/libchip/rtc/m48t08.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/m48t08_reg.c (modified) * c/src/libchip/rtc/m48t08_reg2.c (modified) * c/src/libchip/rtc/m48t08_reg4.c (modified) * c/src/libchip/rtc/m48t08_reg8.c (modified) * c/src/libchip/rtc/mc146818a.c (modified) * c/src/libchip/rtc/mc146818a.h (modified) * c/src/libchip/rtc/mc146818a_ioreg.c (modified) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtcprobe.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_reg.c (modified) * c/src/libchip/serial/mc68681_reg2.c (modified) * c/src/libchip/serial/mc68681_reg4.c (modified) * c/src/libchip/serial/mc68681_reg8.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.h (modified) * c/src/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/librtems++/include/rtems++/rtemsEvent.h (modified) * c/src/librtems++/include/rtems++/rtemsInterrupt.h (modified) * c/src/librtems++/include/rtems++/rtemsMessageQueue.h (modified) * c/src/librtems++/include/rtems++/rtemsSemaphore.h (modified) * c/src/librtems++/include/rtems++/rtemsStatusCode.h (modified) * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * c/src/librtems++/include/rtems++/rtemsTaskMode.h (modified) * c/src/librtems++/include/rtems++/rtemsTimer.h (modified) * c/src/librtems++/src/rtemsEvent.cc (modified) * c/src/librtems++/src/rtemsInterrupt.cc (modified) * c/src/librtems++/src/rtemsMessageQueue.cc (modified) * c/src/librtems++/src/rtemsSemaphore.cc (modified) * c/src/librtems++/src/rtemsStatusCode.cc (modified) * c/src/librtems++/src/rtemsTask.cc (modified) * c/src/librtems++/src/rtemsTimer.cc (modified) * c/src/support/version.c (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/btimer.h (modified) * cpukit/include/rtems/concat.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/include/rtems/media.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/include/rtems/sparse-disk.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/media-desc.c (modified) * cpukit/libblock/src/media-dev-ident.c (modified) * cpukit/libblock/src/media-path.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libblock/src/sparse-disk.c (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/rtc.h (modified) * cpukit/libcsupport/include/rtems/deviceio.h (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/rtems/watchdogdrv.h (modified) * cpukit/libcsupport/include/spurious.h (modified) * cpukit/libcsupport/include/sys/statvfs.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/sys/utsname.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/__assert.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/_calloc_r.c (modified) * cpukit/libcsupport/src/_free_r.c (modified) * cpukit/libcsupport/src/_malloc_r.c (modified) * cpukit/libcsupport/src/_realloc_r.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/assoclocalbyname.c (modified) * cpukit/libcsupport/src/assocremotebylocalbitfield.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/cfsetspeed.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/clonenode.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libcsupport/src/dup.c (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/freenode.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getchark.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/getrusage.c (modified) * cpukit/libcsupport/src/getuid.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/isatty.c (modified) * cpukit/libcsupport/src/isatty_r.c (modified) * cpukit/libcsupport/src/kill_noposix.c (modified) * cpukit/libcsupport/src/lchown.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_exit.c (modified) * cpukit/libcsupport/src/libio_helper_null.c (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/malloc_dirtier.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/malloc_report_statistics.c (modified) * cpukit/libcsupport/src/malloc_report_statistics_plugin.c (modified) * cpukit/libcsupport/src/malloc_statistics_helpers.c (modified) * cpukit/libcsupport/src/malloc_walk.c (modified) * cpukit/libcsupport/src/mallocfreespace.c (modified) * cpukit/libcsupport/src/mallocgetheapptr.c (modified) * cpukit/libcsupport/src/mallocinfo.c (modified) * cpukit/libcsupport/src/mallocsetheapptr.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/mkfifo.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount-mgr.c (modified) * cpukit/libcsupport/src/mount-mktgt.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libcsupport/src/newlibc_init.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/libcsupport/src/pathconf.c (modified) * cpukit/libcsupport/src/pipe.c (modified) * cpukit/libcsupport/src/posix_memalign.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/rtems_malloc.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libcsupport/src/rtems_putc.c (modified) * cpukit/libcsupport/src/setegid.c (modified) * cpukit/libcsupport/src/seteuid.c (modified) * cpukit/libcsupport/src/setuid.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_deviceio.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/sup_fs_next_token.c (modified) * cpukit/libcsupport/src/sup_fs_node_type.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcgetpgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2index.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_num2baud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libcsupport/src/termiosinitialize.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libcsupport/src/utimes.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libcsupport/src/write_r.c (modified) * cpukit/libcsupport/src/writev.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_chown.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_close.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fchmod.c (modified) * cpukit/libfs/src/defaults/default_fcntl.c (modified) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fsmount.c (modified) * cpukit/libfs/src/defaults/default_fstat.c (modified) * cpukit/libfs/src/defaults/default_fsunmount.c (modified) * cpukit/libfs/src/defaults/default_fsync.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_ioctl.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_link.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_mknod.c (modified) * cpukit/libfs/src/defaults/default_mount.c (modified) * cpukit/libfs/src/defaults/default_node_type.c (modified) * cpukit/libfs/src/defaults/default_open.c (modified) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) * cpukit/libfs/src/defaults/default_read.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/defaults/default_readv.c (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_rmnod.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_unmount.c (modified) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/defaults/default_write.c (modified) * cpukit/libfs/src/defaults/default_writev.c (modified) * cpukit/libfs/src/devfs/devclose.c (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_mknod.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (modified) * cpukit/libfs/src/devfs/devfs_show.c (modified) * cpukit/libfs/src/devfs/devioctl.c (modified) * cpukit/libfs/src/devfs/devopen.c (modified) * cpukit/libfs/src/devfs/devread.c (modified) * cpukit/libfs/src/devfs/devstat.c (modified) * cpukit/libfs/src/devfs/devwrite.c (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.h (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv_default.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_rmnod.c (modified) * cpukit/libfs/src/dosfs/msdos_statvfs.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/include/linux/kernel-rtems.h (modified) * cpukit/libfs/src/jffs2/include/rtems/jffs2.h (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libfs/src/pipe/pipe.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block-pos.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-data.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system-fwd.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.h (modified) * cpukit/libfs/src/rfs/rtems-rfs.h (modified) * cpukit/libgnat/ada_intrsupp.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline.h (modified) * cpukit/libmisc/bspcmdline/bspcmdline_get.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparam.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/devnull/devnull.c (modified) * cpukit/libmisc/devnull/devnull.h (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/devnull/devzero.h (modified) * cpukit/libmisc/dummy/dummy-networking.c (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) * cpukit/libmisc/dumpbuf/dumpbuf.h (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/mouse/serial_mouse.c (modified) * cpukit/libmisc/mouse/serial_mouse.h (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) * cpukit/libmisc/shell/cat_file.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/fdisk.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cat.c (modified) * cpukit/libmisc/shell/main_cd.c (modified) * cpukit/libmisc/shell/main_chdir.c (modified) * cpukit/libmisc/shell/main_chmod.c (modified) * cpukit/libmisc/shell/main_chroot.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_debugrfs.c (modified) * cpukit/libmisc/shell/main_df.c (modified) * cpukit/libmisc/shell/main_dir.c (modified) * cpukit/libmisc/shell/main_exit.c (modified) * cpukit/libmisc/shell/main_halt.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_lsof.c (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/libmisc/shell/main_mdump.c (modified) * cpukit/libmisc/shell/main_medit.c (modified) * cpukit/libmisc/shell/main_mfill.c (modified) * cpukit/libmisc/shell/main_mkdir.c (modified) * cpukit/libmisc/shell/main_mkrfs.c (modified) * cpukit/libmisc/shell/main_mmove.c (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/main_netstats.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_rmdir.c (modified) * cpukit/libmisc/shell/main_route.c (modified) * cpukit/libmisc/shell/main_rtc.c (modified) * cpukit/libmisc/shell/main_sleep.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_umask.c (modified) * cpukit/libmisc/shell/main_unmount.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/libmisc/shell/print_heapinfo.c (modified) * cpukit/libmisc/shell/shell-wait-for-input.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shell_getchar.c (modified) * cpukit/libmisc/shell/shell_getprompt.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/shell/shell_script.c (modified) * cpukit/libmisc/shell/shellconfig.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/write_file.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/stringto/stringto.h (modified) * cpukit/libmisc/stringto/stringtodouble.c (modified) * cpukit/libmisc/stringto/stringtofloat.c (modified) * cpukit/libmisc/stringto/stringtoint.c (modified) * cpukit/libmisc/stringto/stringtolong.c (modified) * cpukit/libmisc/stringto/stringtolongdouble.c (modified) * cpukit/libmisc/stringto/stringtolonglong.c (modified) * cpukit/libmisc/stringto/stringtopointer.c (modified) * cpukit/libmisc/stringto/stringtounsignedchar.c (modified) * cpukit/libmisc/stringto/stringtounsignedint.c (modified) * cpukit/libmisc/stringto/stringtounsignedlong.c (modified) * cpukit/libmisc/stringto/stringtounsignedlonglong.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/libmisc/untar/untar.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libqos/qreslib.h (modified) * cpukit/posix/include/aio.h (modified) * cpukit/posix/include/mqueue.h (modified) * cpukit/posix/include/rtems/posix/aio_misc.h (modified) * cpukit/posix/include/rtems/posix/barrier.h (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/cancel.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/priorityimpl.h (modified) * cpukit/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/include/rtems/posix/ptimer.h (modified) * cpukit/posix/include/rtems/posix/rwlock.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/include/rtems/posix/sigset.h (modified) * cpukit/posix/include/rtems/posix/spinlock.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/time.h (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (modified) * cpukit/posix/include/semaphore.h (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/adjtime.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_error.c (modified) * cpukit/posix/src/aio_fsync.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_return.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/barrierattrgetpshared.c (modified) * cpukit/posix/src/barrierattrinit.c (modified) * cpukit/posix/src/barrierattrsetpshared.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/canceleval.c (modified) * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetenableattr.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksetenableattr.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/execl.c (modified) * cpukit/posix/src/execle.c (modified) * cpukit/posix/src/execlp.c (modified) * cpukit/posix/src/execv.c (modified) * cpukit/posix/src/execve.c (modified) * cpukit/posix/src/execvp.c (modified) * cpukit/posix/src/fork.c (modified) * cpukit/posix/src/getitimer.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pbarrier.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarriertranslatereturncode.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/prwlock.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktranslatereturncode.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspin.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinlocktranslatereturncode.c (modified) * cpukit/posix/src/pspintrylock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/psxnametoid.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/pthreadattrcompare.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetguardsize.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstack.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetguardsize.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstack.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/posix/src/rwlockattrgetpshared.c (modified) * cpukit/posix/src/rwlockattrinit.c (modified) * cpukit/posix/src/rwlockattrsetpshared.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/posix/src/sched_getprioritymin.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/posix/src/semaphore.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphoretranslatereturncode.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/setitimer.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timerdelete.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timerinserthelper.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/posix/src/vfork.c (modified) * cpukit/posix/src/wait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/pppd/rtemspppd.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/asrimpl.h (modified) * cpukit/rtems/include/rtems/rtems/atomic.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/attrimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/cache.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventimpl.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/modesimpl.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/optionsimpl.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalimpl.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/statusimpl.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierdata.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barriertranslatereturncode.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettickssinceboot.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdata.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventdata.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/eventtimeout.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/intrcatch.c (modified) * cpukit/rtems/src/modes.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgdata.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdata.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondata.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondata.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectapimaximumclass.c (modified) * cpukit/rtems/src/rtemsobjectapiminimumclass.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/rtemstimerdata.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdata.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/status.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdata.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskself.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskvariable_invoke_dtor.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/rtems/src/workspace.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/cbs.h (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/counter.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/extensionimpl.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/include/rtems/profiling.h (modified) * cpukit/sapi/include/rtems/rbheap.h (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/include/rtems/test.h (modified) * cpukit/sapi/include/rtems/timespec.h (modified) * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainsmp.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondata.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatal2.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/getversionstring.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioclose.c (modified) * cpukit/sapi/src/iocontrol.c (modified) * cpukit/sapi/src/iodata.c (modified) * cpukit/sapi/src/ioinitialize.c (modified) * cpukit/sapi/src/ioopen.c (modified) * cpukit/sapi/src/ioread.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/iounregisterdriver.c (modified) * cpukit/sapi/src/iowrite.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/sapi/src/testbeginend.c (modified) * cpukit/sapi/src/testextension.c (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-context-restore.c (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-handler.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-set.c (modified) * cpukit/score/cpu/arm/armv7m-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/arm/rtems/score/types.h (modified) * cpukit/score/cpu/avr/avr-exception-frame-print.c (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/score/avr.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/avr/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/avr/rtems/score/types.h (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/bfin/rtems/bfin/bf52x.h (modified) * cpukit/score/cpu/bfin/rtems/bfin/bf533.h (modified) * cpukit/score/cpu/bfin/rtems/bfin/bfin.h (modified) * cpukit/score/cpu/bfin/rtems/score/bfin.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/bfin/rtems/score/types.h (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/h8300/h8300-exception-frame-print.c (modified) * cpukit/score/cpu/h8300/rtems/asm.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/h8300/rtems/score/h8300.h (modified) * cpukit/score/cpu/h8300/rtems/score/types.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/rtems/score/idtr.h (modified) * cpukit/score/cpu/i386/rtems/score/interrupts.h (modified) * cpukit/score/cpu/i386/rtems/score/registers.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/lm32/rtems/score/lm32.h (modified) * cpukit/score/cpu/lm32/rtems/score/types.h (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/context_switch.S (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m32c/rtems/score/m32c.h (modified) * cpukit/score/cpu/m32c/rtems/score/types.h (modified) * cpukit/score/cpu/m32r/context_init.c (modified) * cpukit/score/cpu/m32r/context_switch.S (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/cpu_asm.c (modified) * cpukit/score/cpu/m32r/m32r-exception-frame-print.c (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m32r/rtems/score/m32r.h (modified) * cpukit/score/cpu/m32r/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/cpu_asm.S (modified) * cpukit/score/cpu/moxie/moxie-exception-frame-print.c (modified) * cpukit/score/cpu/moxie/rtems/asm.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/moxie/rtems/score/moxie.h (modified) * cpukit/score/cpu/moxie/rtems/score/types.h (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-context-switch.S (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-fatal-halt.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-initialize-vectors.c (modified) * cpukit/score/cpu/nios2/nios2-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-install-raw-handler.c (modified) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-count-zeros.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/types.h (modified) * cpukit/score/cpu/sh/context.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/asm.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sh/rtems/score/sh_io.h (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/sparc-counter.c (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/v850/cpu.c (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/v850/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/v850/rtems/score/types.h (modified) * cpukit/score/cpu/v850/rtems/score/v850.h (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/atomic.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/chainimpl.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/corebarrier.h (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/corerwlock.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/corespinlock.h (modified) * cpukit/score/include/rtems/score/corespinlockimpl.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/include/rtems/score/freechain.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/heapimpl.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mpciimpl.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/prioritybitmap.h (modified) * cpukit/score/include/rtems/score/prioritybitmapimpl.h (modified) * cpukit/score/include/rtems/score/profiling.h (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/include/rtems/score/smpbarrier.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/stackimpl.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/include/rtems/score/threadsync.h (modified) * cpukit/score/include/rtems/score/timespec.h (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (modified) * cpukit/score/include/rtems/score/tls.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/seterr.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/apimutex.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/chainappend.c (modified) * cpukit/score/src/chainappendempty.c (modified) * cpukit/score/src/chainextract.c (modified) * cpukit/score/src/chainget.c (modified) * cpukit/score/src/chaingetempty.c (modified) * cpukit/score/src/chaininsert.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/chainprependempty.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexflush.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexseizeintr.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/corerwlocktimeout.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coresemflush.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/corespinlock.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptimetimespec.c (modified) * cpukit/score/src/coretodsecondssinceepoch.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/debugisownerofallocator.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectapimaximumclass.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetinfoid.c (modified) * cpukit/score/src/objectgetisr.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapinit.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/prioritybitmap.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsallocate.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbscreateserver.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaultallocatefree.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/schedulerdefaultstartidle.c (modified) * cpukit/score/src/schedulerdefaulttick.c (modified) * cpukit/score/src/schedulerdefaultupdate.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfallocate.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfenqueue.c (modified) * cpukit/score/src/scheduleredfenqueuefirst.c (modified) * cpukit/score/src/scheduleredfextract.c (modified) * cpukit/score/src/scheduleredffree.c (modified) * cpukit/score/src/scheduleredfprioritycompare.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfschedule.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfupdate.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerpriorityallocate.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerpriorityenqueue.c (modified) * cpukit/score/src/schedulerpriorityenqueuefirst.c (modified) * cpukit/score/src/schedulerpriorityextract.c (modified) * cpukit/score/src/schedulerpriorityfree.c (modified) * cpukit/score/src/schedulerpriorityprioritycompare.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityupdate.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimple.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimpleenqueue.c (modified) * cpukit/score/src/schedulersimpleenqueuefirst.c (modified) * cpukit/score/src/schedulersimpleextract.c (modified) * cpukit/score/src/schedulersimplereadyqueueenqueue.c (modified) * cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadblockingoperationcancel.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddisabledispatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadenabledispatch.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqfirstpriority.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqprocesstimeout.c (modified) * cpukit/score/src/threadqrequeue.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/ts64addto.c (modified) * cpukit/score/src/ts64divide.c (modified) * cpukit/score/src/ts64dividebyinteger.c (modified) * cpukit/score/src/ts64equalto.c (modified) * cpukit/score/src/ts64getnanoseconds.c (modified) * cpukit/score/src/ts64getseconds.c (modified) * cpukit/score/src/ts64lessthan.c (modified) * cpukit/score/src/ts64set.c (modified) * cpukit/score/src/ts64settozero.c (modified) * cpukit/score/src/ts64subtract.c (modified) * cpukit/score/src/ts64toticks.c (modified) * cpukit/score/src/ts64totimespec.c (modified) * cpukit/score/src/ts64totimeval.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdogadjusttochain.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogreport.c (modified) * cpukit/score/src/watchdogreportchain.c (modified) * cpukit/score/src/watchdogtickle.c (modified) * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/check_passwd.c (modified) * cpukit/telnetd/telnetd.c (modified) * cpukit/telnetd/telnetd.h (modified) * doc/HELP.html (modified) * doc/common/cpright.texi (modified) * doc/common/rtems.texi.in (modified) * doc/index.html.in (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/status.texi (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/texi2any_init.in (modified) * doc/texi2html_init.in (modified) * testsuites/fstests/fsbdpart01/fsbdpart01.doc (modified) * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc (modified) * testsuites/fstests/fsdosfsformat01/init.c (modified) * testsuites/fstests/fsdosfsname01/create_files.cs (modified) * testsuites/fstests/fsdosfsname01/create_image.sh (modified) * testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h (modified) * testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/fsdosfssync01/fsdosfssync01.doc (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/fstests/fserror/fserror.doc (modified) * testsuites/fstests/fserror/test.c (modified) * testsuites/fstests/fsfpathconf/fsfpathconf.doc (modified) * testsuites/fstests/fsfpathconf/test.c (modified) * testsuites/fstests/fsfseeko01/init.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/fslink/fslink.doc (modified) * testsuites/fstests/fslink/test.c (modified) * testsuites/fstests/fsnofs01/fsnofs01.doc (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/fstests/fspatheval/patheval.doc (modified) * testsuites/fstests/fspatheval/test.c (modified) * testsuites/fstests/fspermission/fspermission.doc (modified) * testsuites/fstests/fspermission/test.c (modified) * testsuites/fstests/fsrdwr/fsrdwr.doc (modified) * testsuites/fstests/fsrdwr/init.c (modified) * testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) * testsuites/fstests/fsrofs01/init.c (modified) * testsuites/fstests/fsstatvfs/fsstatvfs.doc (modified) * testsuites/fstests/fsstatvfs/test.c (modified) * testsuites/fstests/fssymlink/fssymlink.doc (modified) * testsuites/fstests/fssymlink/test.c (modified) * testsuites/fstests/fstime/fstime.doc (modified) * testsuites/fstests/fstime/test.c (modified) * testsuites/fstests/imfs_support/fs_config.h (modified) * testsuites/fstests/imfs_support/fs_support.c (modified) * testsuites/fstests/jffs2_support/fs_config.h (modified) * testsuites/fstests/jffs2_support/fs_support.c (modified) * testsuites/fstests/mdosfs_support/fs_config.h (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mimfs_support/fs_config.h (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_support/fs_config.h (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/fstests/support/fstest.h (modified) * testsuites/fstests/support/fstest_support.c (modified) * testsuites/fstests/support/fstest_support.h (modified) * testsuites/fstests/support/ramdisk_support.c (modified) * testsuites/fstests/support/ramdisk_support.h (modified) * testsuites/libtests/block01/block01.doc (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/block02.doc (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/block03.doc (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/block04.doc (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/block05.doc (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/block06.doc (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/block07.doc (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block08/Makefile.am (modified) * testsuites/libtests/block08/bdbuf_test1_1.c (modified) * testsuites/libtests/block08/bdbuf_test1_2.c (modified) * testsuites/libtests/block08/bdbuf_test1_3.c (modified) * testsuites/libtests/block08/bdbuf_test1_4.c (modified) * testsuites/libtests/block08/bdbuf_test1_5.c (modified) * testsuites/libtests/block08/bdbuf_test2_1.c (modified) * testsuites/libtests/block08/bdbuf_test2_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_1.c (modified) * testsuites/libtests/block08/bdbuf_test3_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_3.c (modified) * testsuites/libtests/block08/bdbuf_test4_1.c (modified) * testsuites/libtests/block08/bdbuf_test4_2.c (modified) * testsuites/libtests/block08/bdbuf_test4_3.c (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/libtests/block08/init.c (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/block09.doc (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/block10.doc (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) * testsuites/libtests/block16/init.c (modified) * testsuites/libtests/block17/init.c (modified) * testsuites/libtests/bspcmdline01/bspcmdline01.doc (modified) * testsuites/libtests/bspcmdline01/init.c (modified) * testsuites/libtests/complex/complex.doc (modified) * testsuites/libtests/complex/init.c (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/devfs01/devfs01.doc (modified) * testsuites/libtests/devfs01/init.c (modified) * testsuites/libtests/devfs02/devfs02.doc (modified) * testsuites/libtests/devfs02/init.c (modified) * testsuites/libtests/devfs03/devfs03.doc (modified) * testsuites/libtests/devfs03/init.c (modified) * testsuites/libtests/devfs04/devfs04.doc (modified) * testsuites/libtests/devfs04/init.c (modified) * testsuites/libtests/devfs04/test_driver.c (modified) * testsuites/libtests/devfs04/test_driver.h (modified) * testsuites/libtests/deviceio01/deviceio01.doc (modified) * testsuites/libtests/deviceio01/init.c (modified) * testsuites/libtests/deviceio01/test_driver.c (modified) * testsuites/libtests/deviceio01/test_driver.h (modified) * testsuites/libtests/devnullfatal01/devnullfatal01.doc (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/libtests/dumpbuf01/dumpbuf01.doc (modified) * testsuites/libtests/dumpbuf01/init.c (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/flashdisk01/flashdisk01.doc (modified) * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/flashdisk01/test-file-system.c (modified) * testsuites/libtests/flashdisk01/test-file-system.h (modified) * testsuites/libtests/ftp01/ftp01.doc (modified) * testsuites/libtests/ftp01/init.c (modified) * testsuites/libtests/gxx01/gxx01.doc (modified) * testsuites/libtests/gxx01/init.c (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/libtests/heapwalk/system.h (modified) * testsuites/libtests/malloc02/init.c (modified) * testsuites/libtests/malloc02/malloc02.doc (modified) * testsuites/libtests/malloc03/init.c (modified) * testsuites/libtests/malloc03/malloc03.doc (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/libtests/malloc04/malloc04.doc (modified) * testsuites/libtests/malloc05/init.c (modified) * testsuites/libtests/malloc05/malloc05.doc (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/math/init.c (modified) * testsuites/libtests/mathf/init.c (modified) * testsuites/libtests/mathl/init.c (modified) * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/mghttpd01/init.c (modified) * testsuites/libtests/mghttpd01/test-http-client.c (modified) * testsuites/libtests/mghttpd01/test-http-client.h (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/monitor.doc (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/monitor02/init.c (modified) * testsuites/libtests/monitor02/monitor02.doc (modified) * testsuites/libtests/monitor02/system.h (modified) * testsuites/libtests/mouse01/init.c (modified) * testsuites/libtests/mouse01/mouse01.doc (modified) * testsuites/libtests/mouse01/msmouse.c (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/putenvtest/putenvtest.doc (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/libtests/rbheap01/rbheap.doc (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtems++/rtems++.doc (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/sparsedisk01/init.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/stackchk.doc (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/libtests/stackchk01/init.c (modified) * testsuites/libtests/stackchk01/stackchk01.doc (modified) * testsuites/libtests/stringto01/init.c (modified) * testsuites/libtests/stringto01/stringto01.doc (modified) * testsuites/libtests/stringto01/stringto_test_template.h (modified) * testsuites/libtests/syscall01/init.c (modified) * testsuites/libtests/syscall01/syscall01.doc (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar01/tar01.doc (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.doc (modified) * testsuites/libtests/tar03/init.c (modified) * testsuites/libtests/tar03/tar03.doc (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.doc (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) * testsuites/libtests/termios01/termios_testdriver.h (modified) * testsuites/libtests/termios02/init.c (modified) * testsuites/libtests/termios02/termios02.doc (modified) * testsuites/libtests/termios03/init.c (modified) * testsuites/libtests/termios03/termios03.doc (modified) * testsuites/libtests/termios03/termios_testdriver_polled.c (modified) * testsuites/libtests/termios03/termios_testdriver_polled.h (modified) * testsuites/libtests/termios04/init.c (modified) * testsuites/libtests/termios04/termios04.doc (modified) * testsuites/libtests/termios04/termios_testdriver_intr.c (modified) * testsuites/libtests/termios04/termios_testdriver_intr.h (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/libtests/termios05/termios05.doc (modified) * testsuites/libtests/termios05/termios_testdriver_taskdriven.c (modified) * testsuites/libtests/termios05/termios_testdriver_taskdriven.h (modified) * testsuites/libtests/termios06/init.c (modified) * testsuites/libtests/termios06/termios06.doc (modified) * testsuites/libtests/termios06/test_pppd.c (modified) * testsuites/libtests/termios07/init.c (modified) * testsuites/libtests/termios07/termios07.doc (modified) * testsuites/libtests/termios08/init.c (modified) * testsuites/libtests/termios08/termios08.doc (modified) * testsuites/libtests/tztest/init.c (modified) * testsuites/libtests/uid01/init.c (modified) * testsuites/libtests/uid01/msmouse.c (modified) * testsuites/libtests/uid01/serial_mouse_config.c (modified) * testsuites/libtests/uid01/uid01.doc (modified) * testsuites/libtests/utf8proc01/init.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/mp01-node1.doc (modified) * testsuites/mptests/mp01/node2/mp01-node2.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/mp02-node1.doc (modified) * testsuites/mptests/mp02/node2/mp02-node2.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/mp03-node1.doc (modified) * testsuites/mptests/mp03/node2/mp03-node2.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/mp04-node1.doc (modified) * testsuites/mptests/mp04/node2/mp04-node2.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/mp05-node1.doc (modified) * testsuites/mptests/mp05/node2/mp05-node2.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/mp06-node1.doc (modified) * testsuites/mptests/mp06/node2/mp06-node2.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/mp07-node1.doc (modified) * testsuites/mptests/mp07/node2/mp07-node2.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/mp08-node1.doc (modified) * testsuites/mptests/mp08/node2/mp08-node2.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09-node1.doc (modified) * testsuites/mptests/mp09/node2/mp09-node2.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/mp10-node1.doc (modified) * testsuites/mptests/mp10/node2/mp10-node2.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/mp11-node1.doc (modified) * testsuites/mptests/mp11/node2/mp11-node2.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/mp12-node1.doc (modified) * testsuites/mptests/mp12/node2/mp12-node2.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/mp13-node1.doc (modified) * testsuites/mptests/mp13/node2/mp13-node2.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/mp14-node1.doc (modified) * testsuites/mptests/mp14/node2/mp14-node2.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/include/pmacros.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/psx01.doc (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/psx03.doc (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/psx05.doc (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/psx06.doc (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/psx07.doc (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/psx08.doc (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task1.c (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx08/task3.c (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/psx09.doc (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtests/psx14/init.c (modified) * testsuites/psxtests/psx14/psx14.doc (modified) * testsuites/psxtests/psx14/system.h (modified) * testsuites/psxtests/psx15/init.c (modified) * testsuites/psxtests/psx16/init.c (modified) * testsuites/psxtests/psx16/psx16.doc (modified) * testsuites/psxtests/psxaio01/init.c (modified) * testsuites/psxtests/psxaio01/system.h (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio02/system.h (modified) * testsuites/psxtests/psxaio03/init.c (modified) * testsuites/psxtests/psxaio03/system.h (modified) * testsuites/psxtests/psxalarm01/init.c (modified) * testsuites/psxtests/psxalarm01/psxalarm01.doc (modified) * testsuites/psxtests/psxautoinit01/init.c (modified) * testsuites/psxtests/psxautoinit02/init.c (modified) * testsuites/psxtests/psxautoinit02/psxautoinit02.doc (modified) * testsuites/psxtests/psxbarrier01/main.c (modified) * testsuites/psxtests/psxbarrier01/test.c (modified) * testsuites/psxtests/psxcancel/init.c (modified) * testsuites/psxtests/psxcancel/psxcancel.doc (modified) * testsuites/psxtests/psxcancel01/init.c (modified) * testsuites/psxtests/psxcancel01/psxcancel01.doc (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psxclassic01/init.c (modified) * testsuites/psxtests/psxclassic01/psxclassic01.doc (modified) * testsuites/psxtests/psxcleanup/psxcleanup.c (modified) * testsuites/psxtests/psxcleanup/psxcleanup.doc (modified) * testsuites/psxtests/psxcleanup/system.h (modified) * testsuites/psxtests/psxcleanup01/init.c (modified) * testsuites/psxtests/psxcleanup01/psxcleanup01.doc (modified) * testsuites/psxtests/psxclock/init.c (modified) * testsuites/psxtests/psxclock/psxclock.doc (modified) * testsuites/psxtests/psxcond01/init.c (modified) * testsuites/psxtests/psxcond01/psxcond01.doc (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxconfig01/psxconfig01.doc (modified) * testsuites/psxtests/psxeintr_join/init.c (modified) * testsuites/psxtests/psxeintr_join/psxeintr_join.doc (modified) * testsuites/psxtests/psxenosys/init.c (modified) * testsuites/psxtests/psxenosys/psxenosys.doc (modified) * testsuites/psxtests/psxenosys/system.h (modified) * testsuites/psxtests/psxfatal01/psxfatal01.doc (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/psxtests/psxfchx01/init.c (modified) * testsuites/psxtests/psxfchx01/psxfchx01.doc (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxfile01/test_cat.c (modified) * testsuites/psxtests/psxfile01/test_extend.c (modified) * testsuites/psxtests/psxfile01/test_write.c (modified) * testsuites/psxtests/psxfile02/init.c (modified) * testsuites/psxtests/psxfile02/psxfile02.doc (modified) * testsuites/psxtests/psxfilelock01/init.c (modified) * testsuites/psxtests/psxfilelock01/psxfilelock01.doc (modified) * testsuites/psxtests/psxgetattrnp01/init.c (modified) * testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.doc (modified) * testsuites/psxtests/psxgetrusage01/init.c (modified) * testsuites/psxtests/psxgetrusage01/psxgetrusage01.doc (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/pthread37.c (modified) * testsuites/psxtests/psxhdrs/pthread38.c (modified) * testsuites/psxtests/psxhdrs/pthread39.c (modified) * testsuites/psxtests/psxhdrs/pthread40.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/signal23.c (modified) * testsuites/psxtests/psxhdrs/sync01.c (modified) * testsuites/psxtests/psxhdrs/sync02.c (modified) * testsuites/psxtests/psxhdrs/sync03.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/psxtests/psxhdrs/timer07.c (modified) * testsuites/psxtests/psxid01/init.c (modified) * testsuites/psxtests/psxid01/psxid01.doc (modified) * testsuites/psxtests/psximfs01/init.c (modified) * testsuites/psxtests/psximfs01/psximfs01.doc (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psximfs02/psximfs02.doc (modified) * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/psxtests/psxintrcritical01/psxintrcritical01.doc (modified) * testsuites/psxtests/psxitimer/init.c (modified) * testsuites/psxtests/psxkey01/init.c (modified) * testsuites/psxtests/psxkey01/system.h (modified) * testsuites/psxtests/psxkey02/init.c (modified) * testsuites/psxtests/psxkey02/psxkey02.doc (modified) * testsuites/psxtests/psxkey03/init.c (modified) * testsuites/psxtests/psxkey03/psxkey03.doc (modified) * testsuites/psxtests/psxkey04/init.c (modified) * testsuites/psxtests/psxkey04/psxkey04.doc (modified) * testsuites/psxtests/psxkey05/init.c (modified) * testsuites/psxtests/psxkey05/psxkey05.doc (modified) * testsuites/psxtests/psxkey06/init.c (modified) * testsuites/psxtests/psxkey06/psxkey06.doc (modified) * testsuites/psxtests/psxkey07/init.c (modified) * testsuites/psxtests/psxkey07/psxkey07.doc (modified) * testsuites/psxtests/psxkey08/init.c (modified) * testsuites/psxtests/psxkey08/psxkey08.doc (modified) * testsuites/psxtests/psxkey09/init.c (modified) * testsuites/psxtests/psxkey09/psxkey09.doc (modified) * testsuites/psxtests/psxkey10/init.c (modified) * testsuites/psxtests/psxkey10/psxkey10.doc (modified) * testsuites/psxtests/psxmount/test.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxmsgq02/init.c (modified) * testsuites/psxtests/psxmsgq02/system.h (modified) * testsuites/psxtests/psxmsgq03/init.c (modified) * testsuites/psxtests/psxmsgq03/psxmsgq03.doc (modified) * testsuites/psxtests/psxmsgq03/system.h (modified) * testsuites/psxtests/psxmsgq04/init.c (modified) * testsuites/psxtests/psxmsgq04/psxmsgq04.doc (modified) * testsuites/psxtests/psxmutexattr01/init.c (modified) * testsuites/psxtests/psxmutexattr01/psxmutexattr01.doc (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/psxtests/psxobj01/psxobj01.doc (modified) * testsuites/psxtests/psxonce01/init.c (modified) * testsuites/psxtests/psxonce01/psxonce01.doc (modified) * testsuites/psxtests/psxonce01/system.h (modified) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd01/psxpasswd01.doc (modified) * testsuites/psxtests/psxpasswd02/init.c (modified) * testsuites/psxtests/psxpasswd02/psxpasswd02.doc (modified) * testsuites/psxtests/psxpipe01/init.c (modified) * testsuites/psxtests/psxpipe01/psxpipe01.doc (modified) * testsuites/psxtests/psxrdwrv/main.c (modified) * testsuites/psxtests/psxrdwrv/test.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) * testsuites/psxtests/psxrwlock01/main.c (modified) * testsuites/psxtests/psxrwlock01/test.c (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/psxtests/psxsignal01/init.c (modified) * testsuites/psxtests/psxsignal01/system.h (modified) * testsuites/psxtests/psxsignal01/task1.c (modified) * testsuites/psxtests/psxsignal02/init.c (modified) * testsuites/psxtests/psxsignal02/psxsignal02.doc (modified) * testsuites/psxtests/psxsignal03/init.c (modified) * testsuites/psxtests/psxsignal03/psxsignal03.doc (modified) * testsuites/psxtests/psxsignal04/psxsignal04.doc (modified) * testsuites/psxtests/psxsignal05/init.c (modified) * testsuites/psxtests/psxsignal05/psxsignal05.doc (modified) * testsuites/psxtests/psxsignal06/init.c (modified) * testsuites/psxtests/psxsignal06/psxsignal06.doc (modified) * testsuites/psxtests/psxspin01/main.c (modified) * testsuites/psxtests/psxspin01/psxspin01.doc (modified) * testsuites/psxtests/psxspin01/test.c (modified) * testsuites/psxtests/psxspin02/main.c (modified) * testsuites/psxtests/psxspin02/psxspin02.doc (modified) * testsuites/psxtests/psxspin02/test.c (modified) * testsuites/psxtests/psxstack01/init.c (modified) * testsuites/psxtests/psxstack01/psxstack01.doc (modified) * testsuites/psxtests/psxstack02/init.c (modified) * testsuites/psxtests/psxstack02/psxstack02.doc (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxsysconf/init.c (modified) * testsuites/psxtests/psxsysconf/system.h (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtime/psxtime.doc (modified) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/psxtests/psxtimer01/psxtimer.c (modified) * testsuites/psxtests/psxtimer01/system.h (modified) * testsuites/psxtests/psxtimer02/psxtimer.c (modified) * testsuites/psxtests/psxtimer02/system.h (modified) * testsuites/psxtests/psxtimes01/init.c (modified) * testsuites/psxtests/psxtimes01/psxtimes01.doc (modified) * testsuites/psxtests/psxualarm/init.c (modified) * testsuites/psxtests/psxualarm/system.h (modified) * testsuites/psxtests/psxusleep/init.c (modified) * testsuites/psxtests/psxusleep/psxusleep.doc (modified) * testsuites/psxtmtests/psxtmbarrier01/init.c (modified) * testsuites/psxtmtests/psxtmbarrier01/psxtmbarrier01.doc (modified) * testsuites/psxtmtests/psxtmbarrier02/init.c (modified) * testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.doc (modified) * testsuites/psxtmtests/psxtmbarrier03/init.c (modified) * testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.doc (modified) * testsuites/psxtmtests/psxtmbarrier04/init.c (modified) * testsuites/psxtmtests/psxtmbarrier04/psxtmbarrier04.doc (modified) * testsuites/psxtmtests/psxtmcond01/init.c (modified) * testsuites/psxtmtests/psxtmcond02/init.c (modified) * testsuites/psxtmtests/psxtmcond02/psxtmcond02.doc (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond03/psxtmcond03.doc (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond04/psxtmcond04.doc (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond05/psxtmcond05.doc (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond06/psxtmcond06.doc (modified) * testsuites/psxtmtests/psxtmcond07/init.c (modified) * testsuites/psxtmtests/psxtmcond07/psxtmcond07.doc (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmcond08/psxtmcond08.doc (modified) * testsuites/psxtmtests/psxtmcond09/psxtmcond09.doc (modified) * testsuites/psxtmtests/psxtmkey01/init.c (modified) * testsuites/psxtmtests/psxtmkey01/psxtmkey01.doc (modified) * testsuites/psxtmtests/psxtmkey02/init.c (modified) * testsuites/psxtmtests/psxtmkey02/psxtmkey02.doc (modified) * testsuites/psxtmtests/psxtmmq01/init.c (modified) * testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc (modified) * testsuites/psxtmtests/psxtmmutex01/init.c (modified) * testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.doc (modified) * testsuites/psxtmtests/psxtmmutex02/init.c (modified) * testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc (modified) * testsuites/psxtmtests/psxtmmutex03/init.c (modified) * testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.doc (modified) * testsuites/psxtmtests/psxtmmutex04/init.c (modified) * testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.doc (modified) * testsuites/psxtmtests/psxtmmutex05/init.c (modified) * testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.doc (modified) * testsuites/psxtmtests/psxtmmutex06/init.c (modified) * testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.doc (modified) * testsuites/psxtmtests/psxtmmutex07/init.c (modified) * testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.doc (modified) * testsuites/psxtmtests/psxtmnanosleep01/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc (modified) * testsuites/psxtmtests/psxtmnanosleep02/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc (modified) * testsuites/psxtmtests/psxtmrwlock01/init.c (modified) * testsuites/psxtmtests/psxtmrwlock01/psxtmrwlock01.doc (modified) * testsuites/psxtmtests/psxtmrwlock02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock02/psxtmrwlock02.doc (modified) * testsuites/psxtmtests/psxtmrwlock03/init.c (modified) * testsuites/psxtmtests/psxtmrwlock03/psxtmrwlock03.doc (modified) * testsuites/psxtmtests/psxtmrwlock04/init.c (modified) * testsuites/psxtmtests/psxtmrwlock04/psxtmrwlock04.doc (modified) * testsuites/psxtmtests/psxtmrwlock05/init.c (modified) * testsuites/psxtmtests/psxtmrwlock05/psxtmrwlock05.doc (modified) * testsuites/psxtmtests/psxtmrwlock06/init.c (modified) * testsuites/psxtmtests/psxtmrwlock06/psxtmrwlock06.doc (modified) * testsuites/psxtmtests/psxtmrwlock07/init.c (modified) * testsuites/psxtmtests/psxtmrwlock07/psxtmrwlock07.doc (modified) * testsuites/psxtmtests/psxtmsem01/init.c (modified) * testsuites/psxtmtests/psxtmsem01/psxtmsem01.doc (modified) * testsuites/psxtmtests/psxtmsem02/init.c (modified) * testsuites/psxtmtests/psxtmsem02/psxtmsem02.doc (modified) * testsuites/psxtmtests/psxtmsem03/init.c (modified) * testsuites/psxtmtests/psxtmsem03/psxtmsem03.doc (modified) * testsuites/psxtmtests/psxtmsem04/init.c (modified) * testsuites/psxtmtests/psxtmsem04/psxtmsem04.doc (modified) * testsuites/psxtmtests/psxtmsem05/init.c (modified) * testsuites/psxtmtests/psxtmsem05/psxtmsem05.doc (modified) * testsuites/psxtmtests/psxtmsleep01/init.c (modified) * testsuites/psxtmtests/psxtmsleep01/psxtmsleep01.doc (modified) * testsuites/psxtmtests/psxtmsleep02/init.c (modified) * testsuites/psxtmtests/psxtmsleep02/psxtmsleep02.doc (modified) * testsuites/psxtmtests/psxtmthread01/init.c (modified) * testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc (modified) * testsuites/psxtmtests/psxtmthread02/init.c (modified) * testsuites/psxtmtests/psxtmthread02/psxtmthread02.doc (modified) * testsuites/psxtmtests/psxtmthread03/init.c (modified) * testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc (modified) * testsuites/psxtmtests/psxtmthread04/init.c (modified) * testsuites/psxtmtests/psxtmthread04/psxtmthread04.doc (modified) * testsuites/psxtmtests/psxtmthread05/init.c (modified) * testsuites/psxtmtests/psxtmthread05/psxtmthread05.doc (modified) * testsuites/psxtmtests/psxtmthread06/init.c (modified) * testsuites/psxtmtests/psxtmthread06/psxtmthread06.doc (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/base_mp-node1.doc (modified) * testsuites/samples/base_mp/node2/base_mp-node2.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/capture/capture.doc (modified) * testsuites/samples/capture/init.c (modified) * testsuites/samples/capture/system.h (modified) * testsuites/samples/capture/test1.c (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/fileio/fileio.doc (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/iostream/init.cc (modified) * testsuites/samples/iostream/iostream.doc (modified) * testsuites/samples/iostream/system.h (modified) * testsuites/samples/loopback/init.c (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/minimum/minimum.doc (modified) * testsuites/samples/nsecs/empty.c (modified) * testsuites/samples/nsecs/init.c (modified) * testsuites/samples/nsecs/nsecs.doc (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/pppd/init.c (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/samples/unlimited/test2.c (modified) * testsuites/samples/unlimited/test3.c (modified) * testsuites/samples/unlimited/unlimited.doc (modified) * testsuites/smptests/README (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp01/smp01.doc (modified) * testsuites/smptests/smp01/system.h (modified) * testsuites/smptests/smp01/tasks.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp02/smp02.doc (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp02/tasks.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp03/smp03.doc (modified) * testsuites/smptests/smp03/system.h (modified) * testsuites/smptests/smp03/tasks.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp05/smp05.doc (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp07/smp07.doc (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp08/smp08.doc (modified) * testsuites/smptests/smp08/system.h (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smp09/smp09.doc (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smpaffinity01/smpaffinity01.doc (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smpmigration01/init.c (modified) * testsuites/smptests/smppsxaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity01/smppsxaffinity01.doc (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/smptests/smppsxaffinity02/smppsxaffinity02.doc (modified) * testsuites/smptests/smppsxsignal01/init.c (modified) * testsuites/smptests/smpschedule01/init.c (modified) * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpswitchextension01/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/buffered_io.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp10/init.c (modified) * testsuites/sptests/sp10/sp10.doc (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp18/init.c (modified) * testsuites/sptests/sp18/sp18.doc (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp2038/init.c (modified) * testsuites/sptests/sp2038/sp2038.doc (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/sp26/init.c (modified) * testsuites/sptests/sp26/sp26.doc (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp26/task1.c (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp27/sp27.doc (modified) * testsuites/sptests/sp27a/sp27a.doc (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/sp30/init.c (modified) * testsuites/sptests/sp30/resume.c (modified) * testsuites/sptests/sp30/sp30.doc (modified) * testsuites/sptests/sp30/system.h (modified) * testsuites/sptests/sp30/task1.c (modified) * testsuites/sptests/sp31/delay.c (modified) * testsuites/sptests/sp31/init.c (modified) * testsuites/sptests/sp31/prtime.c (modified) * testsuites/sptests/sp31/sp31.doc (modified) * testsuites/sptests/sp31/system.h (modified) * testsuites/sptests/sp31/task1.c (modified) * testsuites/sptests/sp32/init.c (modified) * testsuites/sptests/sp32/sp32.doc (modified) * testsuites/sptests/sp33/init.c (modified) * testsuites/sptests/sp33/sp33.doc (modified) * testsuites/sptests/sp34/changepri.c (modified) * testsuites/sptests/sp35/priinv.c (modified) * testsuites/sptests/sp36/strict_order_mut.c (modified) * testsuites/sptests/sp37/init.c (modified) * testsuites/sptests/sp37/sp37.doc (modified) * testsuites/sptests/sp37/system.h (modified) * testsuites/sptests/sp38/init.c (modified) * testsuites/sptests/sp38/sp38.doc (modified) * testsuites/sptests/sp38/system.h (modified) * testsuites/sptests/sp39/init.c (modified) * testsuites/sptests/sp39/sp39.doc (modified) * testsuites/sptests/sp39/system.h (modified) * testsuites/sptests/sp40/init.c (modified) * testsuites/sptests/sp40/sp40.doc (modified) * testsuites/sptests/sp41/init.c (modified) * testsuites/sptests/sp41/sp41.doc (modified) * testsuites/sptests/sp42/init.c (modified) * testsuites/sptests/sp42/sp42.doc (modified) * testsuites/sptests/sp43/init.c (modified) * testsuites/sptests/sp43/sp43.doc (modified) * testsuites/sptests/sp43/system.h (modified) * testsuites/sptests/sp44/sp44.doc (modified) * testsuites/sptests/sp45/init.c (modified) * testsuites/sptests/sp45/sp45.doc (modified) * testsuites/sptests/sp46/init.c (modified) * testsuites/sptests/sp46/sp46.doc (modified) * testsuites/sptests/sp47/sp47.doc (modified) * testsuites/sptests/sp48/init.c (modified) * testsuites/sptests/sp48/sp48.doc (modified) * testsuites/sptests/sp49/init.c (modified) * testsuites/sptests/sp49/sp49.doc (modified) * testsuites/sptests/sp50/init.c (modified) * testsuites/sptests/sp50/sp50.doc (modified) * testsuites/sptests/sp51/init.c (modified) * testsuites/sptests/sp51/sp51.doc (modified) * testsuites/sptests/sp52/init.c (modified) * testsuites/sptests/sp52/sp52.doc (modified) * testsuites/sptests/sp53/sp53.doc (modified) * testsuites/sptests/sp54/init.c (modified) * testsuites/sptests/sp54/sp54.doc (modified) * testsuites/sptests/sp55/init.c (modified) * testsuites/sptests/sp55/sp55.doc (modified) * testsuites/sptests/sp56/init.c (modified) * testsuites/sptests/sp56/sp56.doc (modified) * testsuites/sptests/sp57/init.c (modified) * testsuites/sptests/sp57/sp57.doc (modified) * testsuites/sptests/sp58/init.c (modified) * testsuites/sptests/sp58/sp58.doc (modified) * testsuites/sptests/sp59/init.c (modified) * testsuites/sptests/sp59/sp59.doc (modified) * testsuites/sptests/sp60/init.c (modified) * testsuites/sptests/sp60/sp60.doc (modified) * testsuites/sptests/sp62/init.c (modified) * testsuites/sptests/sp62/sp62.doc (modified) * testsuites/sptests/sp63/init.c (modified) * testsuites/sptests/sp63/sp63.doc (modified) * testsuites/sptests/sp64/init.c (modified) * testsuites/sptests/sp64/sp64.doc (modified) * testsuites/sptests/sp65/init.c (modified) * testsuites/sptests/sp65/sp65.doc (modified) * testsuites/sptests/sp66/sp66.doc (modified) * testsuites/sptests/sp67/init.c (modified) * testsuites/sptests/sp67/sp67.doc (modified) * testsuites/sptests/sp68/init.c (modified) * testsuites/sptests/sp68/sp68.doc (modified) * testsuites/sptests/sp69/init.c (modified) * testsuites/sptests/sp69/sp69.doc (modified) * testsuites/sptests/sp70/init.c (modified) * testsuites/sptests/sp70/sp70.doc (modified) * testsuites/sptests/sp71/init.c (modified) * testsuites/sptests/sp71/sp71.doc (modified) * testsuites/sptests/sp72/init.c (modified) * testsuites/sptests/sp72/sp72.doc (modified) * testsuites/sptests/sp73/init.c (modified) * testsuites/sptests/sp73/sp73.doc (modified) * testsuites/sptests/sp74/init.c (modified) * testsuites/sptests/sp74/sp74.doc (modified) * testsuites/sptests/sp75/init.c (modified) * testsuites/sptests/sp75/sp75.doc (modified) * testsuites/sptests/sp76/init.c (modified) * testsuites/sptests/sp76/sp76.doc (modified) * testsuites/sptests/sp77/init.c (modified) * testsuites/sptests/sp77/sp77.doc (modified) * testsuites/sptests/spassoc01/init.c (modified) * testsuites/sptests/spassoc01/spassoc01.doc (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcbssched01/init.c (modified) * testsuites/sptests/spcbssched01/spcbssched01.doc (modified) * testsuites/sptests/spcbssched01/system.h (modified) * testsuites/sptests/spcbssched01/task1.c (modified) * testsuites/sptests/spcbssched02/init.c (modified) * testsuites/sptests/spcbssched02/spcbssched02.doc (modified) * testsuites/sptests/spcbssched02/system.h (modified) * testsuites/sptests/spcbssched02/task_periodic.c (modified) * testsuites/sptests/spcbssched03/cbsparams.h (modified) * testsuites/sptests/spcbssched03/init.c (modified) * testsuites/sptests/spcbssched03/spcbssched03.doc (modified) * testsuites/sptests/spcbssched03/system.h (modified) * testsuites/sptests/spcbssched03/tasks_aperiodic.c (modified) * testsuites/sptests/spcbssched03/tasks_periodic.c (modified) * testsuites/sptests/spchain/init.c (modified) * testsuites/sptests/spchain/spchain.doc (modified) * testsuites/sptests/spclock_err02/init.c (modified) * testsuites/sptests/spclock_err02/spclock_err02.doc (modified) * testsuites/sptests/spclockget/init.c (modified) * testsuites/sptests/spclockget/spclockget.doc (modified) * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spcoverage/init.c (modified) * testsuites/sptests/spcoverage/spcoverage.doc (modified) * testsuites/sptests/spcpucounter01/init.c (modified) * testsuites/sptests/spcpuset01/spcpuset01.doc (modified) * testsuites/sptests/spcpuset01/system.h (modified) * testsuites/sptests/spedfsched01/init.c (modified) * testsuites/sptests/spedfsched01/system.h (modified) * testsuites/sptests/spedfsched01/task1.c (modified) * testsuites/sptests/spedfsched02/getall.c (modified) * testsuites/sptests/spedfsched02/init.c (modified) * testsuites/sptests/spedfsched02/spedfsched02.doc (modified) * testsuites/sptests/spedfsched02/system.h (modified) * testsuites/sptests/spedfsched02/task1.c (modified) * testsuites/sptests/spedfsched03/edfparams.h (modified) * testsuites/sptests/spedfsched03/init.c (modified) * testsuites/sptests/spedfsched03/spedfsched03.doc (modified) * testsuites/sptests/spedfsched03/system.h (modified) * testsuites/sptests/spedfsched03/tasks_aperiodic.c (modified) * testsuites/sptests/spedfsched03/tasks_periodic.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror01/sperror01.doc (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror02/sperror02.doc (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/sperror03/sperror03.doc (modified) * testsuites/sptests/speventsystem01/init.c (modified) * testsuites/sptests/speventtransient01/init.c (modified) * testsuites/sptests/spfatal01/spfatal01.doc (modified) * testsuites/sptests/spfatal02/spfatal02.doc (modified) * testsuites/sptests/spfatal03/spfatal03.doc (modified) * testsuites/sptests/spfatal03/testcase.h (modified) * testsuites/sptests/spfatal04/spfatal04.doc (modified) * testsuites/sptests/spfatal05/spfatal05.doc (modified) * testsuites/sptests/spfatal05/testcase.h (modified) * testsuites/sptests/spfatal06/spfatal06.doc (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/spfatal07.doc (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/spfatal08.doc (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/spfatal09.doc (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal10/spfatal10.doc (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/spfatal11.doc (modified) * testsuites/sptests/spfatal11/testcase.h (modified) * testsuites/sptests/spfatal12/spfatal12.doc (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal13/spfatal13.doc (modified) * testsuites/sptests/spfatal13/testcase.h (modified) * testsuites/sptests/spfatal14/spfatal14.doc (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spfatal15/spfatal15.doc (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spfatal16/spfatal16.doc (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal17/spfatal17.doc (modified) * testsuites/sptests/spfatal17/testcase.h (modified) * testsuites/sptests/spfatal18/spfatal18.doc (modified) * testsuites/sptests/spfatal18/testcase.h (modified) * testsuites/sptests/spfatal19/spfatal19.doc (modified) * testsuites/sptests/spfatal19/testcase.h (modified) * testsuites/sptests/spfatal20/spfatal20.doc (modified) * testsuites/sptests/spfatal20/testcase.h (modified) * testsuites/sptests/spfatal22/spfatal22.doc (modified) * testsuites/sptests/spfatal22/testcase.h (modified) * testsuites/sptests/spfatal24/spfatal24.doc (modified) * testsuites/sptests/spfatal24/testcase.h (modified) * testsuites/sptests/spfatal25/spfatal25.doc (modified) * testsuites/sptests/spfatal25/testcase.h (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/consume_sems.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spfifo01/init.c (modified) * testsuites/sptests/spfifo01/spfifo01.doc (modified) * testsuites/sptests/spfifo02/init.c (modified) * testsuites/sptests/spfifo02/spfifo02.doc (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo03/spfifo03.doc (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo04/spfifo04.doc (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/sptests/spfifo05/spfifo05.doc (modified) * testsuites/sptests/spfreechain01/init.c (modified) * testsuites/sptests/spfreechain01/spfreechain01.doc (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/spheapprot/spheapprot.doc (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical01/spintrcritical01.doc (modified) * testsuites/sptests/spintrcritical02/spintrcritical02.doc (modified) * testsuites/sptests/spintrcritical03/spintrcritical03.doc (modified) * testsuites/sptests/spintrcritical04/spintrcritical04.doc (modified) * testsuites/sptests/spintrcritical05/spintrcritical05.doc (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical06/spintrcritical06.doc (modified) * testsuites/sptests/spintrcritical07/spintrcritical07.doc (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical08/spintrcritical08.doc (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical09/spintrcritical09.doc (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical10/spintrcritical10.doc (modified) * testsuites/sptests/spintrcritical11/init.c (modified) * testsuites/sptests/spintrcritical11/spintrcritical11.doc (modified) * testsuites/sptests/spintrcritical12/spintrcritical12.doc (modified) * testsuites/sptests/spintrcritical13/init.c (modified) * testsuites/sptests/spintrcritical13/spintrcritical13.doc (modified) * testsuites/sptests/spintrcritical14/spintrcritical14.doc (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spintrcritical15/spintrcritical15.doc (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical16/spintrcritical16.doc (modified) * testsuites/sptests/spintrcritical17/init.c (modified) * testsuites/sptests/spintrcritical17/spintrcritical17.doc (modified) * testsuites/sptests/spintrcritical18/init.c (modified) * testsuites/sptests/spintrcritical19/init.c (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.h (modified) * testsuites/sptests/spmkdir/init.c (modified) * testsuites/sptests/spmountmgr01/init.c (modified) * testsuites/sptests/spmountmgr01/spmountmgr01.doc (modified) * testsuites/sptests/spnotepad01/init.c (modified) * testsuites/sptests/spnotepad01/spnotepad01.doc (modified) * testsuites/sptests/spnsext01/init.c (modified) * testsuites/sptests/spnsext01/spnsext01.doc (modified) * testsuites/sptests/spobjgetnext/init.c (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.doc (modified) * testsuites/sptests/spobjgetnext/system.h (modified) * testsuites/sptests/sppagesize/init.c (modified) * testsuites/sptests/sppagesize/sppagesize.doc (modified) * testsuites/sptests/sppartition_err01/init.c (modified) * testsuites/sptests/sppartition_err01/sppartition_err01.doc (modified) * testsuites/sptests/sppartition_err01/system.h (modified) * testsuites/sptests/spprintk/init.c (modified) * testsuites/sptests/spprintk/spprintk.doc (modified) * testsuites/sptests/spprivenv01/init.c (modified) * testsuites/sptests/spprivenv01/spprivenv01.doc (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spqreslib/init.c (modified) * testsuites/sptests/spqreslib/spqreslib.doc (modified) * testsuites/sptests/spqreslib/system.h (modified) * testsuites/sptests/spqreslib/task_periodic.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.doc (modified) * testsuites/sptests/spregion_err01/init.c (modified) * testsuites/sptests/spregion_err01/spregion_err01.doc (modified) * testsuites/sptests/spregion_err01/system.h (modified) * testsuites/sptests/spsem01/init.c (modified) * testsuites/sptests/spsem02/init.c (modified) * testsuites/sptests/spsimplesched01/init.c (modified) * testsuites/sptests/spsimplesched01/spsimplesched01.doc (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/spsimplesched02/spsimplesched02.doc (modified) * testsuites/sptests/spsimplesched03/init.c (modified) * testsuites/sptests/spsimplesched03/spsimplesched03.doc (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/spsize.doc (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/sptests/spstkalloc/init.c (modified) * testsuites/sptests/spstkalloc/spstkalloc.doc (modified) * testsuites/sptests/spstkalloc02/init.c (modified) * testsuites/sptests/spstkalloc02/spstkalloc02.doc (modified) * testsuites/sptests/spthreadq01/init.c (modified) * testsuites/sptests/spthreadq01/spthreadq01.doc (modified) * testsuites/sptests/sptimer_err01/init.c (modified) * testsuites/sptests/sptimer_err01/sptimer_err01.doc (modified) * testsuites/sptests/sptimer_err02/init.c (modified) * testsuites/sptests/sptimer_err02/sptimer_err02.doc (modified) * testsuites/sptests/sptimespec01/init.c (modified) * testsuites/sptests/sptimespec01/sptimespec01.doc (modified) * testsuites/sptests/sptls01/init.c (modified) * testsuites/sptests/sptls02/init.cc (modified) * testsuites/sptests/sptls03/init.c (modified) * testsuites/sptests/spwatchdog/delay.c (modified) * testsuites/sptests/spwatchdog/init.c (modified) * testsuites/sptests/spwatchdog/prtime.c (modified) * testsuites/sptests/spwatchdog/spwatchdog.doc (modified) * testsuites/sptests/spwatchdog/system.h (modified) * testsuites/sptests/spwatchdog/task1.c (modified) * testsuites/sptests/spwkspace/init.c (modified) * testsuites/sptests/spwkspace/spwkspace.doc (modified) * testsuites/support/include/test_support.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/support/include/tmtests_empty_function.h (modified) * testsuites/support/src/locked_print.c (modified) * testsuites/support/src/spin.c (modified) * testsuites/support/src/test_support.c (modified) * testsuites/support/src/tmtests_empty_function.c (modified) * testsuites/support/src/tmtests_support.c (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tm30/init.c (modified) * testsuites/tmtests/tm30/tm30.doc (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmcontext01/init.c (modified) * testsuites/tmtests/tmcontext01/plot.py (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/nios2/bridges.c (modified) * tools/cpu/nios2/bridges.h (modified) * tools/cpu/nios2/clocks.c (modified) * tools/cpu/nios2/clocks.h (modified) * tools/cpu/nios2/devices.c (modified) * tools/cpu/nios2/devices.h (modified) * tools/cpu/nios2/linkcmds.c (modified) * tools/cpu/nios2/linkcmds.h (modified) * tools/cpu/nios2/memory.c (modified) * tools/cpu/nios2/memory.h (modified) * tools/cpu/nios2/nios2gen.c (modified) * tools/cpu/nios2/output.c (modified) * tools/cpu/nios2/output.h (modified) * tools/cpu/nios2/ptf.c (modified) * tools/cpu/nios2/ptf.h (modified) Change all references of rtems.com to rtems.org. Fri, 14 Mar 2014 14:06:43 GMT Ralf Kirchner [5dc268f9] * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/libchip/network/dwmac.c (modified) libchip: Relax buffer counts and add fatal error Fri, 14 Mar 2014 07:42:31 GMT Sebastian Huber [ebb6a8d] * c/src/libchip/network/dwmac.c (modified) libchip: Include BSP options definition Thu, 13 Mar 2014 15:45:40 GMT Sebastian Huber [9a8bf95b] * c/src/libchip/network/dwmac.c (modified) libchip: Check interrupt extension availability Thu, 13 Mar 2014 15:41:46 GMT Sebastian Huber [062f9532] * c/src/libchip/network/dwmac-desc.h (modified) * c/src/libchip/network/dwmac-regs.h (modified) libchip: Avoid Mon, 17 Feb 2014 14:43:53 GMT Ralf Kirchner [4953b724] * c/src/libchip/Makefile.am (modified) * c/src/libchip/network/README.dwmac (added) * c/src/libchip/network/dwmac-1000-core.c (added) * c/src/libchip/network/dwmac-1000-dma.c (added) * c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c (added) * c/src/libchip/network/dwmac-common.h (added) * c/src/libchip/network/dwmac-core.c (added) * c/src/libchip/network/dwmac-core.h (added) * c/src/libchip/network/dwmac-desc-com.c (added) * c/src/libchip/network/dwmac-desc-com.h (added) * c/src/libchip/network/dwmac-desc-enh.c (added) * c/src/libchip/network/dwmac-desc.h (added) * c/src/libchip/network/dwmac-regs.h (added) * c/src/libchip/network/dwmac.c (added) * c/src/libchip/network/dwmac.h (added) * c/src/libchip/preinstall.am (modified) libchip: Add dwmac 10/100/1000 network driver Mon, 10 Mar 2014 07:15:37 GMT Sebastian Huber [ae88aa7] * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/src/chainsmp.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/sptests/spchain/init.c (modified) sapi: Use one SMP lock for all chains This partially reverts commit ... Thu, 23 Jan 2014 14:59:25 GMT Sebastian Huber [e16a7ba] * c/src/libchip/serial/README.ns16550 (modified) libchip/serial: Documentation Tue, 08 Oct 2013 08:40:29 GMT Pavel Pisa [382f714] * c/src/libchip/i2c/spi-sd-card.c (modified) SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command. ... Mon, 26 Aug 2013 13:14:33 GMT Sebastian Huber [1215fd4] * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/src/chainsmp.c (added) * testsuites/libtests/block06/init.c (modified) * testsuites/sptests/spchain/init.c (modified) sapi: SMP support for chains Add ISR lock to chain control for ... Thu, 25 Jul 2013 13:10:11 GMT Sebastian Huber [88c74ab] * c/src/ada-tests/support/init.c (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/lm32/shared/startup/bspstart.c (modified) * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/open_eth.c (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetenableattr.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksetenableattr.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettickssinceboot.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/inline/rtems/score/tod.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptimetimespec.c (modified) * cpukit/score/src/coretodmsecstoticks.c (deleted) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/coretodusectoticks.c (deleted) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/ts64toticks.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psxclock/init.c (modified) * testsuites/samples/nsecs/init.c (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/spcbssched01/task1.c (modified) * testsuites/sptests/spedfsched01/task1.c (modified) score: Merge tod implementation into one file Delete ... Wed, 24 Jul 2013 09:09:23 GMT Sebastian Huber [39046f7] * c/src/lib/libbsp/m68k/mcf5206elite/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/vpd.c (modified) * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/libchip/rtc/ds1375.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/z85c30.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/rtems_malloc.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/inline/rtems/score/sysstate.inl (deleted) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetisr.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddisabledispatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/spfatal23/testcase.h (modified) score: Merge sysstate API into one file Tue, 23 Jul 2013 11:32:58 GMT Sebastian Huber [7660e8b3] * c/src/libchip/flash/am29lv160.c (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/rtc/ds1375.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/malloc_dirtier.c (modified) * cpukit/libcsupport/src/malloc_statistics_helpers.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_df.c (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/libmisc/shell/main_netstats.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/telnetd/des.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/libtests/mghttpd01/test-http-client.c (modified) Include missing Tue, 16 Jul 2013 12:39:59 GMT Sebastian Huber [7306578] * c/src/lib/libbsp/shared/console_private.h (modified) * c/src/lib/libbsp/shared/console_select_simple.c (modified) * c/src/libchip/serial/serial.h (modified) bsps/serial: Move bsp_console_select() declaration Tue, 16 Jul 2013 15:11:51 GMT Sebastian Huber [85d2e4b] * c/src/libchip/ide/ata.c (modified) libchip/ata: Remove dead code Tue, 09 Jul 2013 16:15:57 GMT Joel Sherrill [48a22ed] * c/src/libchip/serial/ns16550.c (modified) libchip ns16550.c: Improve comment Fri, 28 Jun 2013 19:26:11 GMT Sebastian Huber [e310dcd] * c/src/libchip/serial/serial.h (modified) libchip/serial: Add const qualifier Thu, 20 Jun 2013 09:03:45 GMT Sebastian Huber [f97f46ce] * c/src/libchip/serial/ns16550.c (modified) libchip/serial: Fix warning Sun, 16 Jun 2013 13:40:03 GMT Jiri Gaisler [45fecbb6] * c/src/libchip/network/greth.c (modified) greth: do not advertise 1000M capability if MAC does not support it. Sun, 16 Jun 2013 13:28:20 GMT Jiri Gaisler [1bdc6d1] * c/src/libchip/network/greth.c (modified) greth: prefer full duplex if available Mon, 10 Jun 2013 12:11:07 GMT Sebastian Huber [15f3a91] * c/src/libchip/serial/ns16550.c (modified) libchip: Use Termios API change for NS16550 This avoids a race ... Mon, 10 Jun 2013 12:07:13 GMT Sebastian Huber [6896ca2] * c/src/libchip/serial/ns16550.c (modified) libchip: Delete superfluous assignments Mon, 08 Apr 2013 14:12:20 GMT Sebastian Huber [65cd5e9] * c/src/libchip/serial/ns16550_p.h (modified) libchip/serial: Fix warnings Fri, 01 Mar 2013 15:29:20 GMT Sebastian Huber [e2b4891] * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/serial/mc68681.h (modified) libchip: Fix prototypes Thu, 28 Feb 2013 17:08:50 GMT Andreas Heinig [aa314cf] * c/src/libchip/rtc/icm7170_reg.c (modified) * c/src/libchip/rtc/m48t08_reg.c (modified) * c/src/libchip/rtc/mc146818a.c (modified) libchip/rtc: Fixed 19 compiler warnings Wed, 27 Feb 2013 13:38:57 GMT Andreas Heinig [f806289] * c/src/libchip/serial/mc68681_reg.c (modified) libchip/serial: Fixed warnings Wed, 27 Feb 2013 14:57:06 GMT Andreas Heinig [c6902a8] * c/src/libchip/network/i82586.c (modified) libchip/network: Fixed warning Fri, 08 Feb 2013 15:58:52 GMT Sebastian Huber [5455f23a] * c/src/libchip/Makefile.am (modified) * c/src/libchip/preinstall.am (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/ns16550_p.h (modified) libchip/serial: Make NS16550 handler public This allows derived ... Fri, 08 Feb 2013 12:39:59 GMT Sebastian Huber [c8bd3cd] * c/src/lib/libbsp/arm/csb337/console/fbcons.c (modified) * c/src/lib/libbsp/arm/csb337/console/uarts.c (modified) * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) * c/src/lib/libbsp/arm/gp32/console/uart.c (modified) * c/src/lib/libbsp/arm/gumstix/console/uarts.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/uart.h (modified) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/usart.h (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/config.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) * c/src/lib/libbsp/sh/gensh2/console/config.c (modified) * c/src/lib/libbsp/shared/umon/umoncons.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc64/shared/console/conscfg.c (modified) * c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.h (modified) libchip/serial: Add const qualifier Fri, 08 Feb 2013 12:43:47 GMT Sebastian Huber [e4933743] * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) libchip/serial: Fix warnings Fri, 08 Feb 2013 12:42:02 GMT Sebastian Huber [49f65bef] * c/src/libchip/serial/ns16550.c (modified) libchip/serial: Fix warnings Fri, 08 Feb 2013 10:58:37 GMT Sebastian Huber [d2a4f158] * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_p.h (modified) libchip/serial: Fix warnings Wed, 09 Jan 2013 13:31:20 GMT Sebastian Huber [fb070e05] * c/src/libchip/Makefile.am (modified) * c/src/libchip/i2c/i2c-sc620.c (added) * c/src/libchip/i2c/i2c-sc620.h (added) * c/src/libchip/preinstall.am (modified) libchip: Add I2C SEMTECH SC620 octal LED driver Wed, 31 Oct 2012 10:54:39 GMT Sebastian Huber [9f0a68c] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) libblock: Block device transfer request API change Add and use ... Tue, 30 Oct 2012 16:42:17 GMT Sebastian Huber [26e90fb1] * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb337/network/network.c (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) * c/src/lib/libbsp/arm/nds/wifi/wifi.c (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/m68k/av5282/network/network.c (modified) * c/src/lib/libbsp/m68k/csb360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68302/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5235/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5329/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/mips/csb350/network/network.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/if_xxx_rtems.c (modified) * c/src/lib/libbsp/powerpc/gen5200/network_5200/network.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/network.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/network/tsec.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_fec.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_scc.c (modified) * c/src/lib/libbsp/powerpc/virtex/network/xiltemac.c (modified) * c/src/lib/libcpu/bfin/network/ethernet.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/greth.c (modified) * c/src/libchip/network/i82586.c (modified) * c/src/libchip/network/if_dc.c (modified) * c/src/libchip/network/if_fxp.c (modified) * c/src/libchip/network/open_eth.c (modified) * c/src/libchip/network/smc91111.c (modified) * c/src/libchip/network/sonic.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) libnetworking: Use system events Add reserved system events ... Thu, 18 Oct 2012 13:24:39 GMT Ralf Corsépius [64d6f19] * c/src/libchip/display/disp_hcms29xx.c (modified) Eliminate unused var 'digit'. Thu, 18 Oct 2012 13:23:32 GMT Ralf Corsépius [b52630c] * c/src/libchip/network/open_eth.c (modified) Make open_eth_txDaemon static.
