@c7ff624c
07/25/03 06:35:06 |
Ralf Corsepius |
2003-07-25 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@ec463ac
07/10/03 08:07:50 |
Ralf Corsepius |
2003-07-10 Ralf Corsepius <corsepiu@…>
* configure.ac: …
4.104.114.84.95
@da35120d
12/11/02 17:58:37 |
Ralf Corsepius |
2002-12-11 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@1c36c3e4
12/10/02 08:40:39 |
Ralf Corsepius |
2002-12-10 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@973bf436
09/14/02 21:03:21 |
Joel Sherrill |
2002-09-14 Joel Sherrill <joel@…>
* serial/z85c30.c: …
4.104.114.84.95
@418c652
08/11/02 05:50:52 |
Ralf Corsepius |
2002-08-11 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@2f0a1dc1
08/10/02 04:05:20 |
Ralf Corsepius |
2002-08-10 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@657af74
03/28/02 00:49:32 |
Joel Sherrill |
2002-03-27 Ralf Corsepius <corsepiu@…>
* configure.ac: …
4.104.114.84.95
@4f7a0f4
10/12/01 21:02:29 |
Joel Sherrill |
2001-10-12 Joel Sherrill <joel@…>
* serial/z85c30.c: Fixed …
4.104.114.84.95
@e414566
09/28/01 13:35:05 |
Joel Sherrill |
2001-09-28 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@7e05b53
03/14/01 19:42:49 |
Joel Sherrill |
2001-03-14 Joel Sherrill <joel@…>
* serial/Makefile.am, …
4.104.114.84.95
@f010a5e
03/02/01 18:17:22 |
Joel Sherrill |
2001-03-01 Joel Sherrill <joel@…>
* network/cs8900.c, …
4.104.114.84.95
@d3795e3e
02/05/01 18:24:37 |
Joel Sherrill |
2001-02-03 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@1070c61
09/05/00 15:33:02 |
Joel Sherrill |
2000-09-04 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@9f4868c
11/23/99 13:57:02 |
Joel Sherrill |
Miscellaneous patches from Ralf Corsepius <corsepiu@…> …
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@235d9e0
10/05/99 20:59:53 |
Joel Sherrill |
Invalid value used for baud rate per bug report from
Jay Kulpinski …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@1896a650
07/30/99 17:52:50 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The main topic …
4.104.114.84.95
@08b5f55
07/26/99 20:31:49 |
Joel Sherrill |
A bug in …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
This one is …
4.104.114.84.95
@d8ff793
03/19/99 22:27:02 |
Joel Sherrill |
Towards automake XI patch from Ralf Corsepius …
4.104.114.84.95
@8548fe0
02/18/99 18:36:05 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@692b9f7
10/28/98 19:17:16 |
Joel Sherrill |
Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along …
4.104.114.84.95
@bfcf4cb3
09/11/98 23:35:09 |
Joel Sherrill |
Updates to tree to make it build with all desired changes and the …
4.104.114.84.95
@70502bc4
08/13/98 15:52:40 |
Joel Sherrill |
Don't disable the RX/TX on close in polled mode.
Fixed a comment.
4.104.114.84.95
@0eb85ae
08/05/98 23:57:35 |
Joel Sherrill |
Commented out the code which yields the CPU when the serial controller …
4.104.114.84.95
@192a1e0
07/30/98 19:51:03 |
Joel Sherrill |
New files.
4.104.114.84.95
@009c235
07/28/98 21:18:17 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@749c54e
07/25/98 17:22:58 |
Joel Sherrill |
Added comments and corrected spacing.
4.104.114.84.95
@cae0504
07/25/98 17:19:45 |
Joel Sherrill |
Corrected spacing and added headers.
4.104.114.84.95
@8739322
07/25/98 17:17:46 |
Joel Sherrill |
Added ns16550_set_attributes.
4.104.114.84.95
@b636d56
07/25/98 17:17:36 |
Joel Sherrill |
Corrected spacing and added a comment.
4.104.114.84.95
@ccfa60b
07/25/98 17:17:05 |
Joel Sherrill |
Updated to reflect set attributes.
4.104.114.84.95
@70a9451
07/25/98 16:53:21 |
Joel Sherrill |
Rewrote NS16550 TX interrupt processing to use termios for the buffer …
4.104.114.84.95
@adedb057
07/25/98 16:52:17 |
Joel Sherrill |
Removed TX ring buffer.
4.104.114.84.95
@cb27f05
07/25/98 16:52:00 |
Joel Sherrill |
Changed variable to hold received data to unsigned.
4.104.114.84.95
@dfb16ce
07/25/98 16:20:33 |
Joel Sherrill |
Added constants for z85c30_enable_interrupts.
4.104.114.84.95
@04c5ac7
07/25/98 16:20:14 |
Joel Sherrill |
Removed z85c30_flush().
Reworked transmit interrupt processing to …
4.104.114.84.95
@c1da250
07/25/98 16:18:46 |
Joel Sherrill |
Changed comment on TxBuffer?.
4.104.114.84.95
@b070d69a
07/25/98 16:18:27 |
Joel Sherrill |
Removed mc68681_flush and corrected spacing.
4.104.114.84.95
@f600da3f
07/25/98 16:17:33 |
Joel Sherrill |
Added information on Chris Johns' suggestion to use pointers …
4.104.114.84.95
@da8ac60a
07/25/98 16:02:21 |
Joel Sherrill |
New file.
4.104.114.84.95
@c68b990
07/25/98 14:51:57 |
Joel Sherrill |
Changed to utilize return status from …
4.104.114.84.95
@f246caf
07/25/98 14:13:34 |
Joel Sherrill |
Interrupts were incorrectly managed with a disable/disable pair rather …
4.104.114.84.95
@c14a619
07/18/98 18:35:34 |
Joel Sherrill |
Removed use of data port for z8530.
Move some code around.
4.104.114.84.95
@16d0e63
07/16/98 00:16:22 |
Joel Sherrill |
Corrected header files.
4.104.114.84.95
@a6f441b
07/16/98 00:16:11 |
Joel Sherrill |
Minor corrections for typos to get it to compile.
4.104.114.84.95
@dd5d2f04
07/16/98 00:03:01 |
Joel Sherrill |
Split default baud rate table into its own file. This shrinks the …
4.104.114.84.95
@849dc107
07/15/98 23:57:41 |
Joel Sherrill |
Fixed typos.
4.104.114.84.95
@8414c033
07/15/98 23:54:24 |
Joel Sherrill |
Added default z85c30 register access routines.
4.104.114.84.95
@cce9322
07/15/98 23:54:08 |
Joel Sherrill |
Added default mc68681 register access routines.
4.104.114.84.95
@991a1ab4
07/15/98 23:21:55 |
Joel Sherrill |
Added check for proper deviceType to interrupt processing code.
4.104.114.84.95
@efaf85fa
07/15/98 23:21:30 |
Joel Sherrill |
Added interrupt mask and interrupt status register bit constants.
4.104.114.84.95
@49370cd
07/15/98 23:20:50 |
Joel Sherrill |
4.104.114.84.95
@198d851
07/15/98 23:20:33 |
Joel Sherrill |
Switched from driver's own buffering to using termios. This …
4.104.114.84.95
@27a66bd
07/15/98 23:15:49 |
Joel Sherrill |
Added information on the deviceType field.
4.104.114.84.95
@66f95fc
07/15/98 23:15:32 |
Joel Sherrill |
4.104.114.84.95
@c0573d7
07/15/98 21:40:42 |
Joel Sherrill |
Added comment to remove use of TxBuffer? ring buffer in all libchip …
4.104.114.84.95
@be8cbbf
07/15/98 13:58:23 |
Joel Sherrill |
Switched deviceOutputUsesInterrupts to TRUE so output would be …
4.104.114.84.95
@e283140c
07/15/98 13:53:58 |
Joel Sherrill |
Switched to "deviceOutput = TRUE" which made device output use interrupts.
4.104.114.84.95
@fb32356b
07/09/98 23:32:07 |
Joel Sherrill |
Added set attributes routine but did not hook it in to the table.
4.104.114.84.95
@abd8c82
07/09/98 23:31:48 |
Joel Sherrill |
Added new files.
4.104.114.84.95
@064b9be
07/09/98 23:30:32 |
Joel Sherrill |
Switched to shared default probe routine.
4.104.114.84.95
@693b5b88
07/09/98 23:30:02 |
Joel Sherrill |
Switched to default probe routine.
4.104.114.84.95
@61ff7ac8
07/09/98 23:29:33 |
Joel Sherrill |
Added new baud rate to number function and default serial probe …
4.104.114.84.95
@e78c474b
07/09/98 22:21:54 |
Joel Sherrill |
Added proper handling of extended baud rate table selection at boot …
4.104.114.84.95
@2c5ea01
07/09/98 22:16:27 |
Joel Sherrill |
Properly handle extended baud rate set commands.
Temporarily "if 0" …
4.104.114.84.95
@e3c59dd
07/09/98 22:11:49 |
Joel Sherrill |
Corrected definition of MC68681_RX_BUFFER.
4.104.114.84.95
@2d8e51aa
07/09/98 18:45:28 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all data and routines …
4.104.114.84.95
@b2ec38c8
07/09/98 18:44:10 |
Joel Sherrill |
Removed commented out line.
4.104.114.84.95
@8f6f641e
07/09/98 18:41:49 |
Joel Sherrill |
Added sersupp.c.
4.104.114.84.95
@d94d47b3
07/09/98 18:41:33 |
Joel Sherrill |
New files to contain generally needed serial driver support routines.
4.104.114.84.95
@37e8259
07/09/98 18:40:27 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all routines and data global …
4.104.114.84.95
@8b2492f
07/09/98 18:39:50 |
Joel Sherrill |
Added support for the Extended Baud Rate set control found in the
Exar …
4.104.114.84.95
@27045a82
07/09/98 18:38:18 |
Joel Sherrill |
Changed static to NS16550_STATIC to make all routines and data global …
4.104.114.84.95
@677a503
07/09/98 18:37:47 |
Joel Sherrill |
Changed static to Z85C30_STATIC so all data and routines could be …
4.104.114.84.95
@80b1c2f
07/09/98 18:36:19 |
Joel Sherrill |
Added information to README.mc68681.
Created the basic README and the …
4.104.114.84.95
@5ae415b
07/05/98 11:04:31 |
Joel Sherrill |
Added include of termios.h.
Also added a block of comments above the …
4.104.114.84.95
@4f0ffa57
06/23/98 17:42:46 |
Joel Sherrill |
Removed RTS and DTR handling code since the MC68681 seems to only have …
4.104.114.84.95
@ae21568c
06/23/98 17:40:00 |
Joel Sherrill |
New file describing mc68681 libchip driver.
4.104.114.84.95
@beaaf49f
06/23/98 16:02:52 |
Joel Sherrill |
Added numerous comments.
4.104.114.84.95
@a5d0c7c
06/23/98 15:54:33 |
Joel Sherrill |
Added concept of "mate" -- the other port on the same DUART. This is …
4.104.114.84.95
@b7ebcea3
06/23/98 14:59:26 |
Joel Sherrill |
Added close.
4.104.114.84.95
@25c3ff91
06/23/98 14:55:21 |
Joel Sherrill |
Added set attributes and written initialize and first open.
4.104.114.84.95
@790d421
06/23/98 14:54:42 |
Joel Sherrill |
Added more registers.
4.104.114.84.95
@9eef52b
06/23/98 14:54:30 |
Joel Sherrill |
Added set attributes prototype.
4.104.114.84.95
@8a2d4f2b
06/23/98 14:54:09 |
Joel Sherrill |
Added NULL entry for setAttributes.
4.104.114.84.95
@7deeb16
06/22/98 11:49:38 |
Joel Sherrill |
Added initial part of iniitialization.
4.104.114.84.95
@ab2dbd7
06/22/98 11:09:32 |
Joel Sherrill |
Added mc68681 stuff to the makefile.
Added numerous constants to …
4.104.114.84.95
@36152b0e
06/22/98 11:08:16 |
Joel Sherrill |
Moved get and set register/data typedefs to this file.
4.104.114.84.95
@4cd4c5a
06/22/98 11:07:51 |
Joel Sherrill |
Moved set and get Register and Data type defininitions to serial.h.
4.104.114.84.95
@58b1e95
06/22/98 10:34:34 |
Joel Sherrill |
Corrected spacing
4.104.114.84.95
@424e23ee
06/22/98 10:17:14 |
Joel Sherrill |
spacing changes
4.104.114.84.95
