Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/libchip/network
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @6ffb0748   08/18/08 10:48:55 Ralf Corsepius Add missing prototype. 4.104.114.95
(edit) @142025c   08/18/08 07:22:23 Ralf Corsepius Add missing prototypes. 4.104.114.95
(edit) @9d7fa71   11/26/07 22:25:53 Joel Sherrill 2007-11-26 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @b00e693   09/17/07 14:10:57 Joel Sherrill 2007-09-17 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @24af51c5   09/14/07 14:58:23 Joel Sherrill 2007-09-14 Daron Chabot <djc915@…> * … 4.104.114.84.95
(edit) @324e311   09/13/07 19:29:13 Joel Sherrill 2007-09-13 Daniel Hellstrom <daniel@…> * … 4.104.114.84.95
(edit) @2a2b206   09/12/07 15:41:43 Joel Sherrill 2007-09-12 Daniel Hellstrom <daniel@…> * … 4.104.114.84.95
(edit) @050249d   09/07/07 15:01:15 Joel Sherrill 2007-09-07 Daniel Hellstrom <daniel@…> * … 4.104.114.84.95
(edit) @6542918f   04/01/07 04:00:10 Ralf Corsepius i386-specific adjustments to pci-API changes. 4.104.114.84.95
(edit) @71cfbb8f   04/01/07 03:20:09 Ralf Corsepius powerpc-specific adjustments to pci-API changes. 4.104.114.84.95
(edit) @ec09d84   03/31/07 01:18:37 Ralf Corsepius 2007-03-31 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @bd5a6589   03/30/07 07:44:53 Ralf Corsepius Use ioctl_command_t as ioctl argument. 4.104.114.84.95
(edit) @d6236b41   03/13/07 11:26:54 Joel Sherrill 2007-03-13 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @2697be56   03/12/07 11:19:21 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @41a1c334   02/06/07 10:28:13 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @bd20bc8   12/14/06 07:24:39 Ralf Corsepius Use ioctl_command_t as ioctl argument. 4.104.114.84.95
(edit) @76ce226   11/17/06 23:08:55 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @6094c1a   09/11/06 21:46:47 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @8f1e4948   09/11/06 11:52:08 Chris Johns Remove extra CRLF. 4.104.114.84.95
(edit) @7f247f3   09/04/06 13:00:15 Joel Sherrill 2006-09-04 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @ac5b81c3   09/01/06 21:20:47 Joel Sherrill 2006-09-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @a612b50   09/01/06 15:39:00 Joel Sherrill 2006-09-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @81d914d8   07/11/06 14:15:22 Joel Sherrill 2006-07-11 Jerry Needell <jerry.needell@…> * … 4.104.114.84.95
(edit) @7f7298c4   02/23/06 21:05:16 WENorum Changes from Daron Chabot 4.104.114.84.95
(edit) @3157972   01/12/06 14:37:49 WENorum Replace illegal lvalue casts with explicit increments. 4.104.114.84.95
(edit) @2be6d66b   01/12/06 06:13:03 Ralf Corsepius 2006-01-12 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @104df63   01/09/06 15:44:11 Ralf Corsepius 2006-01-09 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @9d8ad28   01/09/06 15:41:42 Ralf Corsepius 2006-01-09 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @750a686   11/14/05 05:40:11 Ralf Corsepius Reflect mii.h and if_media.h having moved. 4.104.114.84.95
(edit) @cdfdef4c   11/14/05 05:35:03 Ralf Corsepius Remove (Moved to cpukit). 4.104.114.84.95
(edit) @f82dabae   11/04/05 18:09:59 Ralf Corsepius Use libcpu/byteorder.h for i386. 4.104.114.84.95
(edit) @cc2fcc1   10/20/05 18:38:26 WENorum Numerous changes and cleanups to support MVME2100. 4.104.114.84.95
(edit) @c140041b   09/19/05 03:46:17 Ralf Corsepius Include <errno.h> instead of <sys/errno.h>. 4.104.114.84.95
(edit) @213810b3   08/22/05 13:31:30 Joel Sherrill 2005-08-18 Karel Gardas <kgardas@…> * … 4.104.114.84.95
(edit) @bb72ff9   07/18/05 15:42:24 Joel Sherrill 2005-07-18 Karel Gardas <kgardas@…> * … 4.104.114.84.95
(edit) @9c5873b7   06/17/05 14:32:23 Joel Sherrill 2005-06-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @af28e68e   06/16/05 20:09:36 Joel Sherrill 2005-06-16 Daron Chabot <daron@…> * … 4.104.114.84.95
(edit) @a4ce29f   05/17/05 15:15:07 Jennifer.Averett 2005-05-17 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @e11bf43   05/06/05 20:13:44 Jennifer.Averett 2005-05-06 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @0fd3092   05/06/05 20:06:17 Jennifer.Averett 2005-05-06 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @a8e1959   05/04/05 19:38:49 Jennifer.Averett 2005-05-04 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @a9cd3a9   05/04/05 17:35:44 Joel Sherrill 2005-05-04 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @48b8259   05/03/05 14:42:48 Jennifer.Averett 2005-05-03 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @b7acc4ad   05/02/05 16:24:10 Jennifer.Averett 2005-05-02 Jennifer Averett <jennifer.averett@…> * … 4.104.114.84.95
(edit) @ce7d49bc   04/28/05 17:25:08 Joel Sherrill 2005-04-28 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @bb9e843   03/14/05 21:45:03 Joel Sherrill 2005-03-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @160b6b0   03/04/05 21:49:38 Joel Sherrill 2005-03-04 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @55243362   11/29/04 17:06:12 WENorum Add another module ID code. 4.104.114.84.95
(edit) @ac8f462   11/10/04 23:53:09 Joel Sherrill 2004-11-10 Richard Campbell <richard.campbell@…> * … 4.104.114.84.95
(edit) @bb5b4048   10/25/04 13:50:39 WENorum Install working version of ether_sprintf(). 4.104.114.84.95
(edit) @a51d024   10/11/04 15:04:06 WENorum Add line suggested by "Eugene Denisov" <dea@…>. Prevents … 4.104.114.84.95
(edit) @efab64d   10/11/04 09:09:41 Ralf Corsepius 2004-10-11 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @cd38196f   09/27/04 17:34:00 Joel Sherrill 2004-04-09 Greg Menke <gregory.menke@…> PR … 4.104.114.84.95
(edit) @2a757a8   07/25/04 14:31:24 Joel Sherrill 2004-07-25 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @1402d56a   05/21/04 15:18:14 Joel Sherrill 2004-05-21 Till Strauman <strauman@…> * … 4.104.114.84.95
(edit) @593bc32   04/22/04 04:44:29 Ralf Corsepius 2004-04-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @a3d3d9a   04/20/04 10:43:39 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @c8e8f119   04/20/04 10:35:31 Ralf Corsepius 2004-04-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @73b5bd5d   04/15/04 13:33:58 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @509fec9c   03/31/04 11:18:37 Ralf Corsepius 2004-03-31 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @cdcef7e6   03/23/04 12:24:54 Ralf Corsepius 2004-03-23 Ralf Corsepius <ralf_corsepius@…> PR/589 rtems * … 4.104.114.84.95
(edit) @ee4f57d   03/23/04 09:59:52 Ralf Corsepius 2004-03-23 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @528da1c   03/14/04 01:28:34 Chris Johns Updated the BSP example code. 4.104.114.84.95
(edit) @00bf7745   03/14/04 01:28:08 Chris Johns Changes made to support the DIMMPC. This is a pc396 target with IO … 4.104.114.84.95
(edit) @27192b8   03/14/04 01:26:07 Chris Johns The CS8900 driver is documented in the cs8900.h header file. 4.104.114.84.95
(edit) @51b9899   03/09/04 10:08:33 Ralf Corsepius 2004-03-09 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @afd00b05   03/08/04 03:17:16 Ralf Corsepius Unused 4.104.114.84.95
(edit) @845e4f3   03/05/04 18:12:33 Joel Sherrill 2004-03-05 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @fcc61f10   12/02/03 07:48:54 Ralf Corsepius 2003-12-02 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @ad2b936   12/02/03 04:46:03 Ralf Corsepius 2003-12-02 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @5a550a3b   12/01/03 07:02:50 Ralf Corsepius 2003-12-01 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @547c1673   10/21/03 04:28:20 Ralf Corsepius 2003-10-21 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @94365d9   09/04/03 18:53:19 Joel Sherrill 2003-09-04 Joel Sherrill <joel@…> * ide/ata.c, ide/ata.h, … 4.104.114.84.95
(edit) @398ed76   09/03/03 13:29:15 Joel Sherrill 2003-09-03 Jiri Gaisler <jiri@…> PR 477/networking * … 4.104.114.84.95
(edit) @c25d902   08/20/03 16:04:48 Joel Sherrill 2003-08-20 Joel Sherrill <joel@…> * network/cs8900.c: … 4.104.114.84.95
(edit) @5c0064d   08/16/03 12:25:08 Ralf Corsepius 2003-08-16 Ralf Corsepius <corsepiu@…> Makefile.am: … 4.104.114.84.95
(edit) @c7ff624c   07/25/03 06:35:06 Ralf Corsepius 2003-07-25 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @754ca59b   07/25/03 06:31:14 Ralf Corsepius 2003-07-25 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3584398a   07/18/03 15:52:26 Joel Sherrill 2003-07-18 Greg Menke <gregory.menke@…> PR 429/bsps … 4.104.114.84.95
(edit) @ec463ac   07/10/03 08:07:50 Ralf Corsepius 2003-07-10 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @96e62937   06/30/03 18:14:09 Joel Sherrill 2003-06-30 Greg Menke <gregory.menke@…> * … 4.104.114.84.95
(edit) @0098b7aa   06/13/03 18:23:03 Joel Sherrill 2003-06-13 Greg Menke <gregory.menke@…> * … 4.104.114.84.95
(edit) @01b6ca9   06/13/03 17:43:11 Joel Sherrill 2003-06-13 Greg Menke <gregory.menke@…> PR 405/bsps PR … 4.104.114.84.95
(edit) @9f9ba59   02/20/03 21:17:29 Joel Sherrill 2003-02-20 Till Straumann <strauman@…> PR … 4.104.114.84.95
(edit) @da35120d   12/11/02 17:58:37 Ralf Corsepius 2002-12-11 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @1c36c3e4   12/10/02 08:40:39 Ralf Corsepius 2002-12-10 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @aae96a2   11/13/02 15:34:39 Joel Sherrill 2002-11-13 Jay Monkman <jtm@…> * network/cs8900.c: … 4.104.114.84.95
(edit) @c22aeb4   10/31/02 20:13:18 Joel Sherrill 2002-10-31 Joel Sherrill <joel@…> * network/dec21140.c: … 4.104.114.84.95
(edit) @a2117cd6   09/07/02 23:09:47 Joel Sherrill 2002-09-07 Chris Johns <ccj@…> * network/Makefile.am, … 4.104.114.84.95
(edit) @418c652   08/11/02 05:50:52 Ralf Corsepius 2002-08-11 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @2b947a4   07/16/02 22:37:13 Joel Sherrill 2002-07-16 Eric Norum <eric.norum@…> * New driver for the … 4.104.114.84.95
(edit) @a191b28   05/14/02 17:54:22 Joel Sherrill 2001-05-14 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @6f0d0527   05/14/02 15:16:39 Joel Sherrill 2002-05-07 Chris Johns <ccj@…> * … 4.104.114.84.95
(edit) @7c4ef9c   04/18/02 21:01:20 Joel Sherrill 2002-04-18 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @18b6986   04/13/02 16:42:23 Joel Sherrill 2002-04-11 Chris Johns <ccj@…> * network/rtems_bsdnet.h: To … 4.104.114.84.95
(edit) @9c6a99f   04/04/02 18:22:15 Joel Sherrill 2002-04-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @657af74   03/28/02 00:49:32 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @03e9564   01/04/02 18:17:23 Joel Sherrill 2002-01-03 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c752ff2d   11/26/01 14:34:19 Joel Sherrill 2001-11-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e414566   09/28/01 13:35:05 Joel Sherrill 2001-09-28 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
