Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @3f250797   12/19/17 17:00:45 joel mcf5206elite: Simplify bsp_specs Updates #3520. 5
(edit) @044c907a   12/19/17 17:00:18 joel mcf52235: Simplify bsp_specs Updates #3520. 5
(edit) @c079b9f   12/19/17 16:53:08 joel gen68340: Simplify bsp_specs Updates #3520. 5
(edit) @1e1d4de0   12/19/17 16:52:54 joel gen68360: Simplify bsp_specs Updates #3520. 5
(edit) @eca0eeb3   12/19/17 16:33:16 joel csb360: Simplify bsp_specs Updates #3520. 5
(edit) @9a5cf9c0   12/19/17 16:32:58 joel av5282: Simplify bsp_specs Updates #3520. 5
(edit) @00aea019   12/19/17 15:50:28 joel genmcf548x, mvme147, mvme147s, mvme162, mvme167: Simplify bsp_specs … 5
(edit) @b4361d1   12/19/17 15:29:07 joel mrm332: Simplify bsp_specs Updates #3520. 5
(edit) @f59b944   12/19/17 15:24:00 joel mcf5329: Simplify bsp_specs Updates #3520. 5
(edit) @238740a   12/20/17 10:09:42 kilian.holzinger Add support for arguments in ISRs 5
(edit) @b0b93c8a   12/18/17 23:56:20 joel gensh4: Simplify bsp_specs Updates #3250. 5
(edit) @5a1fab22   12/18/17 23:54:54 joel gensh2: Simplify bsp_specs Updates #3250. 5
(edit) @6510e1f   12/18/17 23:52:22 joel gensh1: Simplify bsp_specs Updates #3250. 5
(edit) @98aa7ca   12/18/17 23:05:32 joel shsim: Simplify bsp_specs This bsp_specs included non-standard logic … 5
(edit) @b00547b   12/18/17 22:54:05 joel rbtx4938: Simplify bsp_specs 5
(edit) @f7626ef9   12/18/17 22:53:31 joel rbtx4925: Simplify bsp_specs Updates #3250. 5
(edit) @3167e67   12/18/17 22:53:10 joel malta: Simplify bsp_specs Updates #3250. 5
(edit) @72dd9f0   12/18/17 22:52:51 joel jmr3904: Simplify bsp_specs Updates #3250. 5
(edit) @88eaf59   12/18/17 22:52:13 joel hurricane: Simplifies bsp_specs Updates #3250. 5
(edit) @e46b1b4   12/18/17 22:51:53 joel csb350: Simplify bsp_specs Updates #3250. 5
(edit) @205b19e   12/18/17 22:14:10 joel sparc64 BSPs: Simplify bsp_specs Updates #3520. 5
(edit) @bb59269   12/18/17 22:04:57 joel ARM BSPs: Simplify bsp_specs Updates #3520. 5
(edit) @b228f55   12/18/17 20:46:58 joel riscv_generic: Simplify bsp_specs Updates #3520. 5
(edit) @48679b7   12/18/17 20:41:10 joel TLL6527M: Simplify bsp_specs Updates #3520. 5
(edit) @26b3a98   12/18/17 20:40:43 joel eZKit533: Simplify bsp_specs Updates #3520. 5
(edit) @8870da8   12/18/17 20:40:14 joel bf537Stamp: Simplify bsp_specs Updates #3520. 5
(edit) @5ca6d259   12/18/17 20:33:33 joel nios2_iss: Simplify bsp_specs Updates #3520. 5
(edit) @ae739bff   12/18/17 20:33:09 joel generic_or1k: Simplify bsp_specs Updates #3520. 5
(edit) @a14f57af   12/18/17 20:10:46 joel m32cbsp: Simplify bsp_specs Updates #3520. 5
(edit) @1e55f0cf   12/18/17 20:10:20 joel moxiesim: Simplify bsp_specs Updates #3520. 5
(edit) @ccdef98   12/18/17 20:00:26 joel milkymist: Simplify bsp_specs Updates #3520. 5
(edit) @0fd617e2   12/18/17 19:59:58 joel lm32_evr: Simplify bsp_specs Updates #3520. 5
(edit) @d386bce   12/18/17 19:54:08 joel pc386: Simplify bsp_specs If this has any issues, check that the … 5
(edit) @daa24ef   12/18/17 19:43:52 joel epiphany: Simplify bsp_specs Updates #3520. 5
(edit) @e9806ffc   12/18/17 19:38:27 joel gdbv850sim: Simplify bsp_specs Updates #3520. 5
(edit) @7edb2ef0   12/18/17 18:40:52 joel mvme167: Simplify bsp_specs This bsp-specs added many libraries which … 5
(edit) @fdca980   12/18/17 18:37:48 joel mcf5206elite: Simplify bsp_specs Removes the non-standard -qflash … 5
(edit) @9eaefea0   12/18/17 18:36:58 joel csb360: Simplify bsp_specs This patch removes the non-standard … 5
(edit) @31c8db4   12/18/17 18:35:46 joel sparc/*/bsp_specs, shared/linkcmds: Simplify bsp_specs Updates #3520. 5
(edit) @94f3c2db   12/19/17 11:53:20 Sebastian Huber bsp/altera-cyclone-v: Remove reserved memory Removed reserved memory … 5
(edit) @f0e5e17   12/19/17 10:42:10 Sebastian Huber bsp/altera-cyclone-v: Adjust work area Use FDT to adjust the work … 5
(edit) @2717032d   12/14/17 06:15:19 Sebastian Huber bsps/arm: Fix move <libcpu/arm-cp15.h> to cpukit Update #3254. 5
(edit) @c0a3c899   10/13/17 09:20:39 Sebastian Huber bsp/altera-cyclone-v: Update clock frequencies 5
(edit) @217913b   10/12/17 05:12:59 Sebastian Huber bsp/altera-cyclone-v: Enable FDT support 5
(edit) @e37ee286   10/12/17 05:12:12 Sebastian Huber bsps/arm: Disable all interrupts in GIC init 5
(edit) @8e8cf72   12/13/17 07:42:34 Sebastian Huber arm: Move <libcpu/arm-cp15.h> to cpukit Update #3254. 5
(edit) @2f91de2d   12/08/17 13:07:05 Sebastian Huber bsps/sh: Delete libcpu/sh 5
(edit) @f2969b5   12/08/17 12:37:19 Sebastian Huber bsp/gensh4: Move libcpu files to BSP Update #3254. 5
(edit) @533e2c0   12/08/17 12:31:12 Sebastian Huber bsp/gensh2: Move libcpu files to BSP Update #3254. 5
(edit) @b850e7f   12/08/17 12:23:41 Sebastian Huber bsp/gensh1: Move libcpu files to BSP Update #3254. 5
(edit) @604f080c   12/08/17 12:13:14 Sebastian Huber bsp/shsim: Move libcpu files to BSP Update #3254. 5
(edit) @b748dffe   12/08/17 07:05:04 Sebastian Huber bsp/csb337: Move libcpu files to BSP Update #3254. 5
(edit) @a1460043   12/08/17 06:57:21 Sebastian Huber bsp/smdk2410: Move libcpu files to BSP Update #3254. 5
(edit) @7829710   12/08/17 06:52:41 Sebastian Huber bsp/rtl22xx: Move libcpu files to BSP Update #3254. 5
(edit) @26ff9fd6   12/08/17 06:46:48 Sebastian Huber bsp/csb336: Move libcpu files to BSP Update #3254. 5
(edit) @586c70ad   12/08/17 06:39:49 Sebastian Huber bsps/arm: Remove obsolete s3c2400 Update #3254. 5
(edit) @e9d6114   12/08/17 06:32:10 Sebastian Huber bsp/gumstix: Move libcpu files to BSP Update #3254. 5
(edit) @102fd7c9   12/07/17 08:19:16 Sebastian Huber bsps: Do not install <libcpu/cache.h> This is a cache manager … 5
(edit) @7704f1a   12/07/17 08:07:14 Sebastian Huber bsps/or1k: Avoid <libcpu/cache.h> Update #3254. 5
(edit) @28fb9059   12/07/17 06:15:23 Sebastian Huber bsps/powerpc: Fix mpc83xx_i2cdrv.h location Update #3254. 5
(edit) @3b446741   12/01/17 06:21:43 Sebastian Huber bsp/leon3: Enable timer used for CPU counter In case no clock driver … 5
(edit) @61bd8cd6   12/05/17 13:26:59 Sebastian Huber bsp/gen5200: Avoid duplicate header installation Update #3254. 5
(edit) @57f3969a   12/02/17 19:32:37 Sebastian Huber bsps: Print internal error text Update #3248. 5
(edit) @0b40630   11/28/17 23:17:18 joel arm/*/bsp_specs: Remove extra space to increase consistency Updates #3520. 5
(edit) @46503a26   11/28/17 17:59:00 joel gdbv850sim/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @169d86f3   11/28/17 17:57:48 joel sparc64/*/bsp_specs, shared/.../start.S: Use GCC init/fini, improve … 5
(edit) @e9eb1a6d   11/28/17 17:57:14 joel leon3/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @fef9674d   11/28/17 17:56:57 joel leon2/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @2afddb49   11/28/17 17:56:46 joel erc32/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @74d2e0d3   11/28/17 17:56:18 joel riscv_generic/bsp_specs: Fix spacing and typo Updates #3520. 5
(edit) @5c43825   11/28/17 17:55:43 joel virtex/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @203ad12   11/28/17 17:55:25 joel qoriq/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @852a9aa   11/28/17 17:54:49 joel qemuppc/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @5ddac3e   11/28/17 17:54:29 joel psim/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @3cbc5be   11/28/17 17:54:12 joel mvme5500/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @e64157e   11/28/17 17:52:47 joel mvme3100/bsp_specsReorder and improve consistency Updates #3520. 5
(edit) @ad2f253   11/28/17 17:52:20 joel motorola_powerpc/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @28d7814   11/28/17 17:52:08 joel haleakala/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @ae85935b   11/28/17 17:51:34 joel gen83xx/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @20e4d55   11/28/17 17:51:14 joel beatnik/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @19cd935   11/28/17 17:50:49 joel moxiesim/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @47c5664   11/28/17 17:50:14 joel hurricane/bsp_specs: Improve consistency Updates #3520. 5
(edit) @7361ed5   11/28/17 17:45:39 joel m32cbsp/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @dd335cf   11/28/17 17:45:20 joel pc386/bsp_specs: Reorder and improve consistency Updates #3520. 5
(edit) @a94e8686   11/28/17 16:44:10 joel generic_or1k/bsp_specs: Fix spacing and typo Updates #3520. 5
(edit) @353dec3f   11/28/17 16:43:30 joel nios2_iss/bsp_specs: Fix typo Updates #3520. 5
(edit) @ad01397a   11/28/17 16:36:41 joel epiphany_sim/bsp_specs: Fix spacing and typo Updates #3520. 5
(edit) @bc45d3e   11/28/17 16:36:14 joel eZKit533/bsp_specs: Fix spacing and typo Updates #3520. 5
(edit) @6b59ec0f   11/28/17 16:35:48 joel bf537Stamp/bsp_specs: Fix spacing and typo Updates #3520. 5
(edit) @7e1011ae   11/28/17 16:35:25 joel TLL6527M/bsp_specs: Fix spacing and typo Updates #3520. 5
(edit) @2f98db6   11/28/17 15:19:15 joel m32csim-testsuite.tcfg: Add sptls04 Updates #3520. 5
(edit) @fb3f2d5   11/29/17 19:00:34 joel csb336/console/uart.c: Use PRIx constant to fix printf() format warning 5
(edit) @22928656   11/27/17 15:53:52 joel REVERT */*/bsp_specs: Increase similarity to ease future Patch was … 5
(edit) @d9769c9   11/22/17 15:35:04 joel */*/bsp_specs: Increase similarity to ease future analysis Done: … 5
(edit) @9955b24a   11/21/17 21:22:45 joel gumstix/bsp_specs: Correct permissions 5
(edit) @ea8dba41   11/21/17 19:58:25 joel powerpc/ss555/startup/linkcmds: Remove obsolete reference to bsp_specs … 5
(edit) @a0663b2   11/21/17 19:27:31 joel libbsp/*/*/configure.ac: Remove references to bsp_specs in … 5
(edit) @642ef00   11/27/17 05:23:29 Sebastian Huber bsps: Provide <tm27.h> in each BSP Since the <tm27.h> is highly … 5
(edit) @affb282   11/24/17 12:01:41 Sebastian Huber bsps: Remove empty tm27.h variants Update #3254. 5
(edit) @e58e29fd   11/24/17 06:58:55 Sebastian Huber Remove coverhd.h This header file contained timing overhead values … 5
