Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @2d9eceb   10/16/14 20:12:57 Joel Sherrill mips/rbtx4925: Fix warnings 4.115
(edit) @2681fc4   10/16/14 20:12:42 Joel Sherrill mips/malta: Fix warnings 4.115
(edit) @f3a66a3   10/16/14 20:12:34 Joel Sherrill mips/hurricane: Fix warnings 4.115
(edit) @0b51575   10/16/14 20:12:21 Joel Sherrill csb350/console/console-io.c: Fix warnings 4.115
(edit) @f4c6c27   10/16/14 18:23:01 Joel Sherrill m68k/mrm332/console/sci.c: Fix missing variable error introduced by … 4.115
(edit) @139a3ab   10/16/14 18:18:44 Joel Sherrill sh/shsim: Further clean up and fixes to previous commit 4.115
(edit) @2cb449d   10/16/14 18:12:21 Joel Sherrill powerpc/beatnik: Fix warnings 4.115
(edit) @9b763110   10/16/14 18:11:58 Joel Sherrill powerpc/mvme3100: Fix warnings 4.115
(edit) @6c6a21c   10/16/14 18:11:47 Joel Sherrill powerpc/shared/startup/probeMemEnd.c: Fix warning 4.115
(edit) @29741ca   10/16/14 18:11:29 Joel Sherrill shared/vmeUniverse/vmeTsi148.c: Set defines to get all prototypes for … 4.115
(edit) @069e58b5   10/16/14 15:59:05 Joel Sherrill moxie/moxiesim/include/bsp.h: Add include of … 4.115
(edit) @94a54ae1   10/16/14 15:57:42 Joel Sherrill moxie/moxiesim: Remove main() Moxie has .init section and that is … 4.115
(edit) @863559a   10/16/14 15:56:36 Joel Sherrill moxie/moxiesim: Remove unused method MOXIEBD_Install_IRQ 4.115
(edit) @ef2e5db   10/15/14 23:38:05 Joel Sherrill powerpc/tqm8xx/startup/bspstart.c: Fix set but not used warning 4.115
(edit) @4e82838   10/15/14 23:37:26 Joel Sherrill powerpc/t32mppc/startup/bspstart.c: Fix set but not used warning 4.115
(edit) @aa97f99   10/15/14 23:37:11 Joel Sherrill powerpc/shared/startup/panic.c: Fix set but not used warning 4.115
(edit) @7f4deff   10/15/14 23:36:41 Joel Sherrill powerpc/mvme5500/pci/pcifinddevice.c: Remove unused variable 4.115
(edit) @9f224f67   10/15/14 23:36:13 Joel Sherrill powerpc/gen83xx/startup/bsprestart.c: Fix set but not used warning 4.115
(edit) @425fe40d   10/15/14 23:35:51 Joel Sherrill arm/lpc176x/misc/restart.c: Fix set but not used warning 4.115
(edit) @a94fb39   10/15/14 23:34:36 Joel Sherrill mcf5206 libcpu and mcf5206elite: Fix warnings 4.115
(edit) @46dad9d4   10/15/14 22:54:02 Joel Sherrill m68k/mvme147: Fix warnings 4.115
(edit) @ef559c7   10/15/14 22:44:14 Joel Sherrill m68k/mvme167: Fix warnings 4.115
(edit) @6e14a99   10/15/14 22:31:04 Joel Sherrill m68k/shared and sim68000: Fix warnings 4.115
(edit) @c186f2ed   10/15/14 22:17:08 Joel Sherrill m68k/mvme162: Fix warnings 4.115
(edit) @2674e84   10/16/14 14:08:10 Joel Sherrill score603e/cscope.out: Remove file accidentally added. Also added … 4.115
(edit) @751028f0   10/15/14 19:24:32 Joel Sherrill powerpc/virtex5/include/bsp.h: Fix warnings 4.115
(edit) @6a93975   10/15/14 19:24:23 Joel Sherrill powerpc/virtex4/include/bsp.h: Fix warnings 4.115
(edit) @fc22287   10/15/14 19:24:06 Joel Sherrill libcpu/powerpc/ppc403/console/console405.c: Fix warnings 4.115
(edit) @4b86f61c   10/15/14 19:23:53 Joel Sherrill libcpu/powerpc/mpc8xx/console-generic/console-generic.c: Fix warnings 4.115
(edit) @e59d26fc   10/15/14 19:23:30 Joel Sherrill libbsp/powerpc/shared/uboot_getenv.c: Fix warnings 4.115
(edit) @72866a7   10/15/14 19:23:07 Joel Sherrill libbsp/powerpc/shared/startup/zerobss.c: Fix warnings 4.115
(edit) @ad51436   10/15/14 19:22:36 Joel Sherrill libcpu/powerpc/mpc6xx: Fix warnings 4.115
(edit) @a14e7ba3   10/15/14 19:22:25 Joel Sherrill libcpu/powerpc/mpc55xx/misc/flash_support.c: Fix warnings 4.115
(edit) @3cdc08c   10/15/14 19:22:02 Joel Sherrill libcpu/powerpc/e500/mmu/mmu.c: Fix warnings 4.115
(edit) @d4ab6611   10/15/14 19:21:20 Joel Sherrill powerpc/score603e: Fix warnings 4.115
(edit) @0626dba   10/15/14 19:20:14 Joel Sherrill SH libcpu and libbsp: Fix warnings 4.115
(edit) @694debe   10/14/14 16:20:35 Joel Sherrill arm/rtl22xx/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @b3bb88be   10/14/14 16:20:35 Joel Sherrill arm/gumstix/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @c696430   10/14/14 16:20:35 Joel Sherrill arm/gp32/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @7c44572   10/14/14 16:20:35 Joel Sherrill arm/gba/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @61fde4a   10/14/14 16:20:35 Joel Sherrill arm/edb7312/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @c6120ac2   10/14/14 16:20:35 Joel Sherrill arm/csb337/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @7ec9bd59   10/15/14 14:31:41 Joel Sherrill mpc8260 libcpu and mpc6260ads BSP: Fix warnings 4.115
(edit) @4af55a8   10/14/14 21:51:49 Joel Sherrill libcpu/arm/at91rm9200/usart/usart.c: Fix warnings 4.115
(edit) @23c3b3b2   10/14/14 21:50:54 Joel Sherrill c/src/lib/libbsp/arm/rtl22xx/console/uart.c 4.115
(edit) @fc137e7d   10/14/14 21:50:45 Joel Sherrill arm/csb337: Fix warnings 4.115
(edit) @7b5da26   10/14/14 20:24:10 Joel Sherrill libcpu/powerpc/mpc8260/cpm/brg.c: Remove unneed extern 4.115
(edit) @f2ae58cf   10/14/14 20:23:46 Joel Sherrill libcpu/powerpc/mpc6xx/timer/timer.c: Formatting 4.115
(edit) @f8d228d   10/14/14 20:23:24 Joel Sherrill mpc8260ads/include/bsp.h: Add prototype to fix warning 4.115
(edit) @39afee9c   10/14/14 20:23:03 Joel Sherrill mips/shared/gdbstub/mips-stub.c: Add prototype to stay self contained 4.115
(edit) @494d2f1f   10/14/14 20:17:19 Joel Sherrill Remove unused pxa255/pmc, update csb337 and gumstix BSPs 4.115
(edit) @f62c7daa   10/14/14 19:10:22 Joel Sherrill mpc5xx libcpu and ss555 BSP: Fix warnings 4.115
(edit) @c7e77ee   10/14/14 17:39:57 Joel Sherrill mcf5282: Move cache to libcpu and update av5282 and uC5282 BSPs 4.115
(edit) @ed6365a   10/14/14 16:03:38 Joel Sherrill bfin libcpu and libbsp: Fix warnings 4.115
(edit) @c28f503   10/14/14 14:34:52 Joel Sherrill m68k/gen68340: Fix warnings 4.115
(edit) @3785ed6c   10/14/14 00:08:36 Joel Sherrill i386/pc386: Fix warnings 4.115
(edit) @1ecb21d8   10/14/14 00:08:14 Joel Sherrill libbsp/i386/shared: Fix warnings 4.115
(edit) @2f3f206   10/14/14 00:07:53 Joel Sherrill libcpu/i388: Fix warning i displayCpu.c 4.115
(edit) @92a8cee   10/13/14 21:55:01 Joel Sherrill libcpu/m68k/mcf532x/cache/cachepd.c: Fix warnings 4.115
(edit) @e7c4f77   10/13/14 21:54:50 Joel Sherrill libcpu/m68k/mcf5235/cache/cachepd.c: Fix warnings 4.115
(edit) @991261f   10/13/14 21:54:30 Joel Sherrill libcpu/m68k/mcf5223x/cache/cachepd.c: Fix warnings 4.115
(edit) @af03345   10/13/14 21:54:12 Joel Sherrill Move CPU cache support from mcf5225x BSP to libcpu 4.115
(edit) @bf49991f   10/13/14 20:53:11 Joel Sherrill i386/shared/comm/uart.c: Remove unused uart_set_driver_handler() method 4.115
(edit) @451d323   10/13/14 20:52:34 Joel Sherrill tqm8xx/clock/p_clock.c: Remove unused BSP_get_clock_irq_level() method 4.115
(edit) @a8ac803e   10/13/14 20:52:01 Joel Sherrill tqm8xx/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @27474fb   10/13/14 20:52:00 Joel Sherrill ss555/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @c506cc98   10/13/14 20:52:00 Joel Sherrill shared/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @0697180   10/13/14 20:52:00 Joel Sherrill qemuppc/startup/cmain.c: Remove myCpu variables and clean up 4.115
(edit) @0af227c   10/13/14 20:52:00 Joel Sherrill mpc8260ads/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @0549cd7   10/13/14 20:52:00 Joel Sherrill mbx8xx/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @5271fd0   10/13/14 20:52:00 Joel Sherrill ep1a/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @01746c4   10/13/14 20:50:45 Joel Sherrill virtex5/startup/bspstart.c: Fix header 4.115
(edit) @1e77dde7   10/13/14 20:50:37 Joel Sherrill virtex4/startup/bspstart.c: Fix header 4.115
(edit) @becc686   10/13/14 20:49:46 Joel Sherrill mvme3100/startup/bspstart.c: Remove myCpu variables and clean up 4.115
(edit) @3916cec   10/13/14 19:56:07 Joel Sherrill powerpc/virtex: Fix unused variable warnings 4.115
(edit) @cfff78f   10/13/14 19:55:54 Joel Sherrill powerpc/mbx8xx: Fix unused variable warnings 4.115
(edit) @e81fe6d   10/13/14 19:55:35 Joel Sherrill powerpc/gen83xx: Fix unused variable warnings 4.115
(edit) @cba474e   10/13/14 19:50:12 Joel Sherrill m68k/ods68302: Fix warnings 4.115
(edit) @b4ed4cb   10/13/14 19:10:32 Joel Sherrill libcpu/arm/shared/../mmu: Fix warnings 4.115
(edit) @d6236971   10/13/14 19:10:11 Joel Sherrill gp32/startup/bspstart.c: Fix warnings 4.115
(edit) @c144c09   10/13/14 19:09:51 Joel Sherrill csb336/startup/bspstart.c: Fix warnings 4.115
(edit) @6da91abb   10/13/14 19:09:16 Joel Sherrill m68k/idp: Fix warnings 4.115
(edit) @3c743901   10/13/14 18:20:35 Joel Sherrill arm/gp32/smc/smc.c: Remove unused sm_ECCEncode() and sm_status() 4.115
(edit) @57e8a0d   10/13/14 18:18:55 Joel Sherrill arm/gp32/smc/smc.c: Fix warnings and clean up 4.115
(edit) @c52384a   10/16/14 11:41:06 Sebastian Huber bsp/qoriq: Fix warnings 4.115
(edit) @e6386f7   10/15/14 14:31:03 Joel Sherrill h8300/h8sim: Exit simulator cleanly 4.115
(edit) @85c533b   10/15/14 14:26:07 Joel Sherrill h8300/h8sim/startup/main.c: Removed. Obsolete remnant of COFF. 4.115
(edit) @d5262fcb   10/14/14 06:39:43 Sebastian Huber bsps/powerpc: Fix the warning fix 4.115
(edit) @6db0f56   10/14/14 06:15:10 Sebastian Huber bsps/mpc55xx: Fix MPC5674F memory map 4.115
(edit) @116ef2e9   10/13/14 13:19:12 Sebastian Huber bsps/arm: Convert PL011 and PL050 console drivers Use Termios device API. 4.115
(edit) @393e8ea   10/10/14 16:43:08 Hesham Almatary libbsp/or1ksim: Fix warnings. 4.115
(edit) @fcc1d157   10/13/14 19:25:47 Gedare Bloom sparc64: use null in empty argument list 4.115
(edit) @b7d32736   10/13/14 19:24:31 Gedare Bloom sparc64: make local functions static in conscfg 4.115
(edit) @a0f27360   10/13/14 19:21:14 Gedare Bloom sparc64: fix warnings for ofw function calls 4.115
(edit) @2d7029d5   10/13/14 19:07:10 Gedare Bloom sparc64: remove sparc64_install_isr_entries and its callers. … 4.115
(edit) @37885d5d   10/10/14 17:23:08 Hesham Almatary libcpu/or1k: Fix warnings. 4.115
(edit) @c7d8be5   10/13/14 16:47:10 Joel Sherrill mips/rbtx4938/start/start.S: Fix nested comment 4.115
(edit) @635119b   10/13/14 16:46:57 Joel Sherrill mips/rbtx4925/start/start.S: Fix nested comment 4.115
(edit) @54560d3   10/13/14 16:12:37 Joel Sherrill h8sxsim-testsuite.tcfg: Disable capture test - uses too many task … 4.115
(edit) @e6e63f8   10/13/14 00:18:09 Joel Sherrill libcpu/i386/cache.c: Fix warnings 4.115
